JLG Boom Lift EC600SJ EC600SJP H600SJ H600SJP Parts Catalog 3122317400
Brand: JLG
Type of Machine: Boom Lift
Model: JLG EC600SJ, EC600SJP, H600SJ, H600SJP Boom Lift
Part Number: 3122317400
Publication Date: 2025
Number of Pages: 618 Pages
SECTION 1 - FRAME
Brand: JLG
SECTION 1 - FRAME
FIGURE 1-1. AXLE INSTALLATION - FIXED (2WD)
FIGURE 1-2. AXLE INSTALLATION - FIXED (4WD)
FIGURE 1-3. AXLE INSTALLATION - OSCILLATING WITHOUT TOW PACKAGE (2WD) (MACHINES WITH SN STARTING WITH 03)
FIGURE 1-4. AXLE INSTALLATION - OSCILLATING WITHOUT TOW PACKAGE (2WD) (MACHINES WITH SN STARTING WITH B3)
FIGURE 1-5. AXLE INSTALLATION - OSCILLATING WITH TOW PACKAGE (2WD)
FIGURE 1-6. AXLE INSTALLATION - OCILLATION (2WD) (MACHINES WITH SN STARTING WITH B3)
FIGURE 1-7. AXLE INSTALLATION - OSCILLATING (4WD) (MACHINES WITH SN STARTING WITH 03)
FIGURE 1-8. AXLE INSTALLATION - OSCILLATING (4WD) (MACHINES WITH SN STARTING WITH B3)
FIGURE 1-9. AXLE INSTALLATION - OCILLATION (4WD) (MACHINES WITH SN STARTING WITH B3)
FIGURE 1-10. AXLE LOCKOUT VALVE ASSEMBLY
FIGURE 1-11. STEER INSTALLATION - WITHOUT TOW PACKAGE (2WD/2WS)
FIGURE 1-12. STEER INSTALLATION - WITH TOW PACKAGE (2WD/2WS)
FIGURE 1-13. STEER INSTALLATION - (4WD/2WS)(MACHINES WITH SN STARTING WITH B3) (EC600SJP,H600SJP)
FIGURE 1-14. STEER INSTALLATION - (4WD/2WS) (EC600SJ,H600SJ)
FIGURE 1-15. STEER INSTALLATION - (4WD/2WS)(MACHINES WITH SN STARTING WITH B3) (EC600SJ,H600SJ)
FIGURE 1-16. STEER INSTALLATION - (4WD/2WS) (EC600SJP,H600SJP)
FIGURE 1-17. STEER INSTALLATION - (2WD/2WS) (MACHINES WITH SN STARTING WITH B3)
FIGURE 1-18. WHEEL DRIVE INSTALLATION (NON-UL SPECS)
FIGURE 1-19. WHEEL DRIVE INSTALLATION (UL SPECS)
FIGURE 1-20. NON-DRIVE HUB ASSEMBLY - LH (2WD FRONT)
FIGURE 1-21. NON-DRIVE HUB ASSEMBLY - RH (2WD FRONT)
FIGURE 1-22. DRIVE HUB ASSEMBLY (REAR)
FIGURE 1-23. DRIVE MOTOR ASSEMBLY (4WD FRONT)
FIGURE 1-24. DRIVE MOTOR ASSEMBLY (REAR)
FIGURE 1-25. DRIVE VALVE ASSEMBLY (4WD ONLY)
FIGURE 1-26. AC DRIVE ELECTRICAL PLATE ASSEMBLY (NON-UL SPECS)
FIGURE 1-27. AC DRIVE ELECTRICAL PLATE ASSEMBLY (UL SPECS)
FIGURE 1-28. DRIVE MODULE PLATE ASSEMBLY
FIGURE 1-29. TIRE AND WHEEL INSTALLATION - 36/14LL X 22.5 FOAM-FILLED NON-MARKING
FIGURE 1-30. TIRE AND WHEEL INSTALLATION - 355/55D625 FOAM FILLED
FIGURE 1-31. FRAME SHIELDS INSTALLATION
FIGURE 1-32. TOW PACKAGE INSTALLATION WITHOUT NATO EYE
FIGURE 1-33. TOW PACKAGE INSTALLATION WITH NATO EYE
SECTION 2 - TURNTABLEFIGURE 2-1. MAIN CONTROL INSTALLATION (EC600SJ,H600SJ)
FIGURE 2-2. MAIN CONTROL INSTALLATION (EC600SJP,H600SJP)
FIGURE 2-3. MAIN CONTROL VALVE ASSEMBLY
FIGURE 2-4. SWING DRIVE INSTALLATION
FIGURE 2-5. SWING MOTOR ASSEMBLY
FIGURE 2-6. TURNTABLE BEARING, STOP AND LUBE INSTALLATION
FIGURE 2-7. TURNTABLE BEARING, STOP AND LUBE INSTALLATION (MACHINES WITH SN STARTING WITH B3)
FIGURE 2-8. TURNTABLE LOCK INSTALLATION
FIGURE 2-9. DRIVE ORIENTATION INSTALLATION
FIGURE 2-10. HYDRAULIC TANK AND PUMP/MOTOR INSTALLATION (NON-UL SPECS)
FIGURE 2-11. HYDRAULIC TANK AND PUMP/MOTOR INSTALLATION (UL SPECS)
FIGURE 2-12. ELECTRIC MOTOR ASSEMBLY
FIGURE 2-13. FUEL TANK AND ENGINE MODULE INSTALLATION - WITH STANDARD BATTERIES (H600SJ,H600SJP)
FIGURE 2-14. FUEL TANK AND ENGINE MODULE INSTALLATION - WITH AGM BATTERIES (H600SJ,H600SJP)
FIGURE 2-15. BATTERY CHARGER INSTALLATION - 110V/60HZ SMART CHARGER (ALL SPECS EXCEPT AUSTRALIAN, CE & UK CA SPECS)
FIGURE 2-16. BATTERY CHARGER INSTALLATION - 120V-230V/45-65HZ SMART CHARGER (ALL SPECS EXCEPT UL SPECS)
FIGURE 2-17. BATTERY CHARGER INSTALLATION - 250V/50HZ SMART CHARGER (ANSI EXPORT, CE, AUSTRALIAN AND CHINA SPECS)
FIGURE 2-18. BATTERY CHARGER INSTALLATION - GREEN POWER CHARGER
FIGURE 2-19. BATTERY BOX INSTALLATION - METAL LATCH - STANDARD BATTERIES (415 AMP HOUR)
FIGURE 2-20. BATTERY BOX INSTALLATION - RUBBER LATCH - STANDARD BATTERIES (415 AMP HOUR)
FIGURE 2-21. BATTERY BOX INSTALLATION - METAL LATCH - AGM BATTERIES (390 AMP HOUR)
FIGURE 2-22. BATTERY BOX INSTALLATION - RUBBER LATCH - AGM BATTERIES (390 AMP HOUR)
FIGURE 2-23. BATTERY BOX INSTALLATION - RUBBER LATCH - AGM BATTERIES (400 AMP HOUR)
FIGURE 2-24. GROUND CONTROL ELECTRICAL SYSTEM INSTALLATION
FIGURE 2-25. GROUND CONTROL PANEL INSTALLATION - DISPLAY WITHOUT BUTTONS(ALL SPECS EXCEPT CE & UK CA SPECS) (EC600SJ,H600SJ)
FIGURE 2-26. GROUND CONTROL PANEL INSTALLATION - DISPLAY WITHOUT BUTTONS(CE & UK CA SPECS) (EC600SJ,H600SJ)
FIGURE 2-27. GROUND CONTROL PANEL INSTALLATION - DISPLAY WITHOUT BUTTONS(ALL SPECS EXCEPT CE & UK CA SPECS) (EC600SJP,H600SJP)
FIGURE 2-28. GROUND CONTROL PANEL INSTALLATION - DISPLAY WITHOUT BUTTONS(CE & UK CA SPECS) (EC600SJP,H600SJP)
FIGURE 2-29. ENGINE CONTROLS INSTALLATION - STANDARD BATTERIES (H600SJ,H600SJP)
FIGURE 2-30. ENGINE CONTROLS INSTALLATION - AGM BATTERIES (H600SJ,H600SJP)
FIGURE 2-31. LIMIT SWITCH INSTALLATION
FIGURE 2-32. ALARM INSTALLATION
FIGURE 2-33. WHITE NOISE ALARM INSTALLATION
FIGURE 2-34. BEACON LIGHT INSTALLATION - AMBER (WITHOUT CLEARSKY BEACON)
FIGURE 2-35. NO BEACON INSTALLATION
FIGURE 2-36. INVERTER INSTALLATION - 110V (OPTIONAL)
FIGURE 2-37. INVERTER INSTALLATION - 110V 3000W (OPTIONAL)
FIGURE 2-38. INVERTER INSTALLATION - 240V 2000W (SN 0300313230 to Present, SN B300024424 to Present, Including B300024318 and B300024323)
FIGURE 2-39. INVERTER INSTALLATION - 220V (OPTIONAL)
FIGURE 2-40. INVERTER INSTALLATION - 220V 3000W (OPTIONAL)
FIGURE 2-41. INVERTER INSTALLATION - 120V 2000W (SN 0300313230 to Present, SN B300024424 to Present, Including B300024318 and B300024323)
FIGURE 2-42. HOODS INSTALLATION
SECTION 3 - ENGINEFIGURE 3-1. ENGINE AND GENERATOR INSTALLATION - WITH STANDARD BATTERIES (H600SJ,H600SJP)
FIGURE 3-2. ENGINE AND GENERATOR INSTALLATION - WITH AGM BATTERIES (H600SJ,H600SJP)
FIGURE 3-3. KUBOTA ENGINE ASSEMBLY (H600SJ,H600SJP)
FIGURE 3-4. KUBOTA ENGINE COMPONENTS (H600SJ,H600SJP)
FIGURE 3-5. EXHAUST STACK AND HOOD BAFFLES INSTALLATION - STANDARD BATTERIES (H600SJ,H600SJP)
FIGURE 3-6. EXHAUST STACK AND HOOD BAFFLES INSTALLATION - AGM BATTERIES (H600SJ,H600SJP)
SECTION 4 - BOOMFIGURE 4-1. BOOM INSTALLATION (MACHINES WITH SN STARTING WITH 03) (EC600SJ,H600SJ) (Prior to SN 0300319968)
FIGURE 4-2. BOOM INSTALLATION (MACHINES WITH SN STARTING WITH 03) (EC600SJ,H600SJ) (SN 0300319969 to Present)
FIGURE 4-3. BOOM INSTALLATION (MACHINES WITH SN STARTING WITH B3) (EC600SJ,H600SJ) (Prior to SN B300026949)
FIGURE 4-4. BOOM INSTALLATION (MACHINES WITH SN STARTING WITH B3) (EC600SJ,H600SJ) (SN B300026950 to Present, SN B300026867 through B300026881, SN B300026883 through B300026884, Including B300026709, B300026737 and B300026742)
FIGURE 4-5. BOOM INSTALLATION (MACHINES WITH SN STARTING WITH 03) (EC600SJP,H600SJP) (Prior to SN 0300319968)
FIGURE 4-6. BOOM INSTALLATION (MACHINES WITH SN STARTING WITH 03) (EC600SJP,H600SJP) (SN 0300319969 to Present)
FIGURE 4-7. BOOM INSTALLATION (MACHINES WITH SN STARTING WITH B3) (EC600SJP,H600SJP) (Prior to SN B300026949)
FIGURE 4-8. BOOM INSTALLATION (MACHINES WITH SN STARTING WITH B3) (EC600SJP,H600SJP) (SN B300026950 to Present, SN B300026867 through B300026881, SN B300026883 through B300026884, Including B300026709, B300026737 and B300026742)
FIGURE 4-9. MAIN BOOM ASSEMBLY (MACHINES WITH SN STARTING WITH 03) (EC600SJ,H600SJ)
FIGURE 4-10. BOOM ASSEMBLY (MACHINES WITH SN STARTING WITH B3) (EC600SJ)
FIGURE 4-11. MAIN BOOM ASSEMBLY (MACHINES WITH SN STARTING WITH 03) (EC600SJP,H600SJP)
FIGURE 4-12. BOOM ASSEMBLY (MACHINES WITH SN STARTING WITH B3) (EC600SJP)
FIGURE 4-13. POWER TRACK ASSEMBLY
FIGURE 4-14. POWER TRACK ASSEMBLY (MACHINES WITH SN STARTING WITH B3)
FIGURE 4-15. ROTATOR ASSEMBLY (EC600SJ,H600SJ) (Prior to SN 0300319968, Prior to SN B300026949)
FIGURE 4-16. ROTATOR ASSEMBLY (MACHINES WITH SN STARTING WITH 03) (SN 0300319969 to Present)
FIGURE 4-17. ROTATOR ASSEMBLY (MACHINES WITH SN STARTING WITH B3) (SN B300026950 to Present, SN B300026867 through B300026881, SN B300026883 through B300026884, Including B300026709, B300026737 and B300026742)
FIGURE 4-18. ROTATOR ASSEMBLY - PLATFORM ROTATE (EC600SJP,H600SJP) (Prior to SN 0300319968, Prior to SN B300026949)
FIGURE 4-19. ROTATOR ASSEMBLY - PLATFORM ROTATE (MACHINES WITH SN STARTING WITH 03) (SN 0300319969 to Present)
FIGURE 4-20. ROTATOR ASSEMBLY - PLATFORM ROTATE (MACHINES WITH SN STARTING WITH B3) (SN B300026950 to Present, SN B300026867 through B300026881, SN B300026883 through B300026884, Including B300026709, B300026737 and B300026742)
FIGURE 4-21. ROTATOR ASSEMBLY - SIDE SWING ROTATE (EC600SJP,H600SJP) (Prior to SN 0300319968, Prior to SN B300026949)
FIGURE 4-22. ROTATOR ASSEMBLY - SIDE SWING ROTATE (SN B300026950 to Present, SN 0300319969 to Present, SN B300026867 through B300026881, SN B300026883 through B300026884, Including B300026709, B300026737 and B300026742)
FIGURE 4-23. PLATFORM SUPPORT INSTALLATION (Prior to SN 0300325400, Prior to SN B300028873)
FIGURE 4-24. PLATFORM SUPPORT INSTALLATION (SN 0300325401 to Present, SN B300028874 to Present)
FIGURE 4-25. BOOM VALVE INSTALLATION (EC600SJ,H600SJ)
FIGURE 4-26. BOOM VALVE INSTALLATION (EC600SJP,H600SJP)
FIGURE 4-27. BOOM VALVE ASSEMBLY (EC600SJ,H600SJ)
FIGURE 4-28. BOOM VALVE ASSEMBLY (EC600SJP,H600SJP)
FIGURE 4-29. BOOM LIMIT SWITCH INSTALLATION (CE & UK CA SPEC ONLY)
SECTION 5 - PLATFORMFIGURE 5-1. PLATFORM ASSEMBLY - 30IN X 3FT (76CM X 91.5CM) - WITH DROP BAR
FIGURE 5-2. PLATFORM ASSEMBLY - 30IN X 4FT (76CM X 1.22M) - SIDE GATE ENTRY
FIGURE 5-3. PLATFORM ASSEMBLY - 30IN X 4FT (76CM X 1.22M) - WITH DROP BAR
FIGURE 5-4. PLATFORM ASSEMBLY - 30IN X 6FT (76CM X 1.83M) - SIDE GATE ENTRY
FIGURE 5-5. PLATFORM ASSEMBLY - 30IN X 6FT (76CM X 1.83M) - WITH DROP BAR
FIGURE 5-6. PLATFORM ASSEMBLY - 30IN X 6FT (0.9M X 1.83M) (FALL ARREST PLATFORM)
FIGURE 5-7. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) WITH SWING GATE
FIGURE 5-8. PLATFORM ASSEMBLY - 3FT X 6FT (91.5CM X 1.83M) - TRI-ENTRY - 1 SWING GATE/2 DROP BARS
FIGURE 5-9. PLATFORM ASSEMBLY - 3FT X 6FT (91.5CM X 1.83M) - TRI-ENTRY - 3 DROP BARS
FIGURE 5-10. PLATFORM ASSEMBLY - 3F X 6FT (91.5CM X 1.83M) (FALL ARREST PLATFORM)
FIGURE 5-11. PLATFORM ASSEMBLY - 3FT X 8FT (91.5CM X 2.44M) WITH SWING GATE
FIGURE 5-12. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH SWING GATE
FIGURE 5-13. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH DROP BAR
FIGURE 5-14. PLATFORM CONSOLE INSTALLATION - 2WD (ALL SPECS EXCEPT UL SPECS)
FIGURE 5-15. PLATFORM CONSOLE INSTALLATION - 2WD (UL SPECS)
FIGURE 5-16. PLATFORM CONSOLE INSTALLATION - 4WD (ALL SPECS EXCEPT UL SPECS)
FIGURE 5-17. PLATFORM CONSOLE INSTALLATION - 4WD (UL SPECS)
FIGURE 5-18. PLATFORM CONSOLE ASSEMBLY - 2WD (ALL SPECS EXCEPT UL SPECS)
FIGURE 5-19. PLATFORM CONSOLE ASSEMBLY - 2WD (UL SPECS)
FIGURE 5-20. PLATFORM CONSOLE ASSEMBLY - 4WD (ALL SPECS EXCEPT UL SPECS)
FIGURE 5-21. PLATFORM CONSOLE ASSEMBLY - 4WD (UL SPECS)
FIGURE 5-22. FOOTSWITCH ASSEMBLY
FIGURE 5-23. ENGINE CONTROLS INSTALLATION - STANDARD BATTERIES (H600SJ,H600SJP)
FIGURE 5-24. ENGINE CONTROLS INSTALLATION - AGM BATTERIES (H600SJ,H600SJP)
FIGURE 5-25. JIB ROTATE SWITCH INSTALLATION (EC600SJP,H600SJP)
FIGURE 5-26. LIGHT PANEL INSTALLATION
FIGURE 5-27. TRAY ASSEMBLY
FIGURE 5-28. SKYEYE INSTALLATION
FIGURE 5-29. SKYGUARD BAR INSTALLATION
FIGURE 5-30. SKYLINE INSTALLATION
FIGURE 5-31. SKYSENSE MID TUBE SENSOR ASSEMBLY
FIGURE 5-32. SKYSENSE OVERHEAD SENSOR ASSEMBLY
FIGURE 5-33. SOFT TOUCH INSTALLATION (SIDE ENTRY PLATFORM) (OPTIONAL)
FIGURE 5-34. SOFT TOUCH INSTALLATION - WITH FALL ARREST (SIDE ENTRY PLATFORM) (OPTIONAL)
FIGURE 5-35. SKYGLAZIER INSTALLATION (ANSI AND CSA SPECS)
FIGURE 5-36. SKYGLAZIER INSTALLATION (ANSI EXPORT SPECS) (SPANISH/PORTUGUESE)
FIGURE 5-37. SKYGLAZIER INSTALLATION (ANSI EXPORT SPECS) (ENGLISH/SPANISH)
FIGURE 5-38. FALL ARREST INSTALLATION (BOLT-ON EXTERNAL) (30IN X 4FT /76CM X 1.22M PLATFORM)
FIGURE 5-39. FALL ARREST INSTALLATION (BOLT-ON EXTERNAL) (30IN X 6FT /76CM X 1.82M PLATFORM)
FIGURE 5-40. FALL ARREST INSTALLATION (BOLT-ON EXTERNAL) (6FT/1.82M PLATFORM)
FIGURE 5-41. FALL ARREST INSTALLATION (BOLT-ON EXTERNAL) (6FT/1.82M TRI-ENTRY PLATFORM)
FIGURE 5-42. FALL ARREST INSTALLATION (BOLT-ON EXTERNAL) (8FT/2.4M PLATFORM)
FIGURE 5-43. USB CHARGER INSTALLATION
SECTION 6 - CYLINDERSFIGURE 6-1. AXLE LOCKOUT CYLINDER ASSEMBLY (MACHINES WITH SN STARTING WITH 03)
FIGURE 6-2. AXLE LOCKOUT CYLINDER ASSEMBLY (MACHINES WITH SN STARTING WITH B3)
FIGURE 6-3. LEVEL CYLINDER ASSEMBLY - PLATFORM SLAVE
FIGURE 6-4. LIFT CYLINDER ASSEMBLY - JIB
FIGURE 6-5. LIFT CYLINDER ASSEMBLY - MAIN (WITH SN STARTING WITH 03) (EC600SJP,H600SJP)
FIGURE 6-6. LIFT CYLINDER ASSEMBLY - MAIN (MACHINES WITH SN STARTING WITH B3)
FIGURE 6-7. MASTER CYLINDER ASSEMBLY
FIGURE 6-8. STEER CYLINDER ASSEMBLY
FIGURE 6-9. TELESCOPE CYLINDER ASSEMBLY
SECTION 7 - HYDRAULICFIGURE 7-1. HYDRAULIC DIAGRAM - AXLE (FIXED)
FIGURE 7-2. HYDRAULIC DIAGRAM - AXLE (OSCILLATING)
FIGURE 7-3. HYDRAULIC DIAGRAM - DRIVE (2WD)
FIGURE 7-4. HYDRAULIC DIAGRAM - DRIVE (4WD)
FIGURE 7-5. HYDRAULIC DIAGRAM - STANDARD (EC600SJ,H600SJ)
FIGURE 7-6. HYDRAULIC DIAGRAM - STANDARD (EC600SJP,H600SJP)
FIGURE 7-7. HYDRAULIC DIAGRAM - TOW
SECTION 8 - ELECTRICALFIGURE 8-1. AC BOX AT PLATFORM - LOCALLY SUPPLIED COMPONENTS
FIGURE 8-2. AC BOX AT PLATFORM INSTALLATION - 110V (ALL SPECS EXCEPT AUSTRALIAN, CE & UK CA SPECS)
FIGURE 8-3. AC BOX AT PLATFORM INSTALLATION - 110V IEC YELLOW (CE & UK CA SPEC)
FIGURE 8-4. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE (CE & UK CA SPEC)
FIGURE 8-5. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 POST GROUND WITH 2IN X 4IN BOX (CE & UK CA SPEC)
FIGURE 8-6. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 SIDE GROUND WITH 2IN X 4IN BOX (CE & UK CA SPEC)
FIGURE 8-7. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT 107 KEYED GROUND WITH 2IN X 4IN BOX
FIGURE 8-8. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT 107 KEYED GROUND WITH 2IN X 4IN BOX (MACHINES WITH SN STARTING WITH B3)
FIGURE 8-9. AC BOX AT PLATFORM INSTALLATION - 110V IEC YELLOW (CE & UK CA SPEC) (MACHINES WITH SN STARTING WITH B3)
FIGURE 8-10. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE (CE & UK CA SPEC) (MACHINES WITH SN STARTING WITH B3)
FIGURE 8-11. AC BOX AT PLATFORM INSTALLATION - 220V (ANSI, CSA & JAPANESE SPECS)
FIGURE 8-12. BATTERY BOX CABLE ASSEMBLY (RH SIDE BOX) (STANDARD BATTERIES)
FIGURE 8-13. BATTERY BOX CABLE ASSEMBLY (LH SIDE BOX) (STANDARD BATTERIES)
FIGURE 8-14. BATTERY BOX CABLE ASSEMBLY - AGM BATTERIES (MACHINES WITH SN STARTING WITH 03)
FIGURE 8-15. BATTERY BOX CABLE ASSEMBLY - AGM BATTERIES (MACHINES WITH SN STARTING WITH B3)
FIGURE 8-16. BEACON LIGHT HARNESS (AMBER BEACON ONLY)
FIGURE 8-17. BOOM TRANSPORT HARNESS (CE & UK CA SPECS ONLY)
FIGURE 8-18. BOOM CABLE - LOWER
FIGURE 8-19. BOOM CABLE - UPPER (EC600SJ,H600SJ)
FIGURE 8-20. BOOM CABLE - UPPER (EC600SJP,H600SJP)
FIGURE 8-21. BREAKER BOX KIT WITH ONE BREAKER - CE & UK CA SPEC
FIGURE 8-22. BREAKER BOX KIT WITH TWO BREAKERS - CE & UK CA SPEC
FIGURE 8-23. BREAKER BOX KIT WITH ONE BREAKER - MACHINES WITH S/N STARTING WITH B3)
FIGURE 8-24. CABLES AND CLAMPS INSTALLATION (ALL SPECS EXCEPT AUSTRALIAN, CE & UK CA SPECS) (CHINA SPEC MACHINES WITH SN STARTING WITH 03) (EC600SJ,H600SJ)
FIGURE 8-25. CABLES AND CLAMPS INSTALLATION (CE & UK CA SPECS) (EC600SJ,H600SJ)
FIGURE 8-26. CABLES AND CLAMPS INSTALLATION - WITHOUT AC CABLE (CHINA SPECS WITH SN STARTING WITH B3) (EC600SJ,H600SJ)
FIGURE 8-27. CABLES AND CLAMPS INSTALLATION - WITH AC CABLE (CHINA SPEC WITH SN STARTING WITH B3) (EC600SJ,H600SJ)
FIGURE 8-28. CABLES AND CLAMPS INSTALLATION (ALL SPECS EXCEPT AUSTRALIAN, CE & UK CA SPECS) (CHINA SPEC MACHINES WITH SN STARTING WITH 03) (EC600SJP,H600SJP)
FIGURE 8-29. CABLES AND CLAMPS INSTALLATION (AUSTRALIAN, CE & UK CA SPECS) (EC600SJP,H600SJP)
FIGURE 8-30. CABLES AND CLAMPS INSTALLATION - DUAL AC BOXES (CE & UK CA SPECS) (EC600SJP,H600SJP)
FIGURE 8-31. CABLES AND CLAMPS INSTALLATION - WITHOUT AC CABLE (CHINA SPECS WITH SN STARTING WITH B3) (EC600SJP,H600SJP)
FIGURE 8-32. CABLES AND CLAMPS INSTALLATION - WITH AC CABLE (CHINA SPEC WITH SN STARTING WITH B3) (EC600SJP,H600SJP)
FIGURE 8-33. CAN JUMPER HARNESS
FIGURE 8-34. CENTRAL PANEL CAN BUSS HARNESS
FIGURE 8-35. CHARGER CORD PLUG INSTALLATION - 110V - IEC YELLOW (CE & UK CA SPEC)
FIGURE 8-36. CHARGER CORD PLUG INSTALLATION - 220V - IEC BLUE (CE & UK CA SPEC)
FIGURE 8-37. CHARGER CORD PLUG INSTALLATION - 220V - CEE7 POST GROUND (CE & UK CA SPEC)
FIGURE 8-38. CHARGER CORD PLUG INSTALLATION - 220V - CEE7 SIDE GROUND (CE & UK CA SPEC)
FIGURE 8-39. CHARGER CORD PLUG INSTALLATION - 220V - AFSINT 107 KEYED GROUND (CE & UK CA SPEC)
FIGURE 8-40. CHARGER CORD PLUG INSTALLATION (CHINA SPEC)
FIGURE 8-41. CHARGER DC CONNECTION HARNESS
FIGURE 8-42. CHARGER HARNESS
FIGURE 8-43. CLEARSKY CS550 BEACON INSTALLATION
FIGURE 8-44. DRIVE CABLE KIT (ALL SPECS EXCPET UL SPECS)
FIGURE 8-45. DRIVE CABLE KIT (UL SPECS)
FIGURE 8-46. EBOOM CAN SPLICE HARNESS
FIGURE 8-47. GENERATOR HARNESS
FIGURE 8-48. GROUND CONTROL HARNESS
FIGURE 8-49. INVERTER IGNITION HARNESS (110V INVERTER)
FIGURE 8-50. INVERTER IGNITION HARNESS (220V INVERTER)
FIGURE 8-51. INVERTER HARNESS (110V INVERTER)
FIGURE 8-52. INVERTER HARNESS (220V INVERTER)
FIGURE 8-53. LED REMOTE HARNESS
FIGURE 8-54. LIMIT SWITCH CABLE
FIGURE 8-55. PLATFORM CONSOLE HARNESS (ALL SPECS EXCEPT UL SPECS)
FIGURE 8-56. PLATFORM CONSOLE HARNESS
FIGURE 8-57. RECEPTACLE BOX KIT - 110V IEC YELLOW (CE & UK CA SPEC)
FIGURE 8-58. RECEPTACLE BOX KIT - 220V IEC BLUE (CE & UK CA SPEC)
FIGURE 8-59. RECEPTACLE BOX KIT - 220V CEE7 POST GROUND 2IN X 4IN BOX (CE & UK CA SPEC)
FIGURE 8-60. RECEPTACLE BOX KIT - 220V CEE7 SIDE GROUND 2IN X 4IN BOX (CE & UK CA SPEC)
FIGURE 8-61. RECEPTACLE BOX KIT - 220V AFSINT 107 (CE & UK CA SPEC)
FIGURE 8-62. SKYEYE EMITTER HARNESS
FIGURE 8-63. SKYEYE INTERMEDIATE HARNESS
FIGURE 8-64. SKYEYE RECEIVER HARNESS
FIGURE 8-65. SKYGUARD INTERFACE HARNESS
FIGURE 8-66. SKYLINE HARNESS
FIGURE 8-67. STEERING SENSOR HARNESS
FIGURE 8-68. TRACTION HARNESS
FIGURE 8-69. TRACTION TO TURNTABLE HARNESS
FIGURE 8-70. TURNTABLE HARNESS
FIGURE 8-71. VALVE HARNESS - BOOM VALVE
FIGURE 8-72. VALVE HARNESS – MAIN CONTROL VALVE
FIGURE 8-73. WHITE NOISE ALARM HARNESS
SECTION 9 - DECALSFIGURE 9-1. DECAL INSTALLATION - ANSI, ANSI EXPORT, CHINA & UL SPECS (ENGLISH LANGUAGE)
FIGURE 9-2. DECAL INSTALLATION - AUSTRALIAN, CE & UK CA SPECS (ENGLISH LANGUAGE)
FIGURE 9-3. DECAL INSTALLATION - BRAZIL SPECS (PORTUGUESE/SPANISH LANGUAGES)
FIGURE 9-4. DECAL INSTALLATION - CHINESE SPECS (CHINESE/ENGLISH LANGUAGES)
FIGURE 9-5. DECAL INSTALLATION - CSA & UL SPECS (ENGLISH/FRENCH LANGUAGES)
FIGURE 9-6. DECAL INSTALLATION - JAPANESE SPECS (JAPANESE LANGUAGE)
FIGURE 9-7. DECAL INSTALLATION - KOREAN SPECS (KOREAN LANGUAGE)
FIGURE 9-8. DECAL INSTALLATION - LATIN AMERICAN SPECS (SPANISH/ENGLISH LANGUAGES)
FIGURE 9-9. DECALS INSTALLATION - OPTIONS
FIGURE 9-10. TOW BAR DECAL INSTALLATION (ALL SPECS EXCEPT CSA & JAPANESE SPECS) (ENGLISH LANGUAGE)
FIGURE 9-11. TOW BAR DECAL INSTALLATION (ANSI EXPORT SPECS) (SPANISH/ENGLISH LANGUAGES)
FIGURE 9-12. TOW BAR DECAL INSTALLATION (CE & UK CA SPECS) (SPANISH LANGUAGE))
FIGURE 9-13. TOW BAR DECAL INSTALLATION (AUSTRALIAN, UL, CE & UK CA SPECS) (ALL LANGUAGES))
SECTION 11 - SPECIAL OPTIONSFIGURE 11-1. SPECIAL OPTIONS/ACCESSORIES/KITS
PART NUMBER INDEX
- SuperPac Parts Manual
- StratoLift Parts Manual
