JLG Boom Lift EC520AJ Parts Catalog 31219190
Brand: JLG
Type of Machine: Boom Lift
Model: JLG EC520AJ Boom Lift
Part Number: 31219190
Publication Date: 2025
Number of Pages: 348 Pages
SECTION 1 - FRAME
Brand: JLG
SECTION 1 - FRAME
FIGURE 1-1. AXLE INSTALLATION
FIGURE 1-2. STEER INSTALLATION
FIGURE 1-3. WHEEL DRIVE INSTALLATION (2WD) (SN C300000326 through C300000699)
FIGURE 1-4. HUB - SPINDLE ASSEMBLY
FIGURE 1-5. DRIVE MOTOR ASSEMBLY
FIGURE 1-6. BATTERY INSTALLATION (4 BATTERIES) (Prior to SN C300000501)
FIGURE 1-7. BATTERY INSTALLATION (4 BATTERIES) (SN C300000326 through C300000699)
FIGURE 1-8. BATTERY INSTALLATION (6 BATTERIES) (SN C300000326 through C300000699)
FIGURE 1-9. FRAME SHIELD INSTALLATION (SN C300000326 through C300000699)
FIGURE 1-10. TIRE AND WHEEL INSTALLATION - 33 X 12-20 SOLID NON-MARKING
FIGURE 1-11. TIRE AND WHEEL INSTALLATION - 315/55 D20 FOAM FILLED
FIGURE 1-12. TIRE AND WHEEL INSTALLATION - 315/55 D20 FOAM FILLED NON-MARKING
FIGURE 1-13. CONTROL VALVES INSTALLATION - FRAME MOUNTED
FIGURE 1-14. OSCILLATING AXLE VALVE ASSEMBLY
SECTION 2 - TURNTABLEFIGURE 2-1. CONTROL VALVES INSTALLATION - TURNTABLE MOUNTED
FIGURE 2-2. MAIN VALVE ASSEMBLY
FIGURE 2-3. AUXILIARY PUMP ASSEMBLY
FIGURE 2-4. ENCLOSURE INSTALLATION (SN C300000326 through C300000699)
FIGURE 2-5. SWING DRIVE AND TURNTABLE BEARING INSTALLATION
FIGURE 2-6. SWING MOTOR ASSEMBLY
FIGURE 2-7. TURNTABLE BEARING ASSEMBLY
FIGURE 2-8. TURNTABLE COVERS INSTALLATION
FIGURE 2-9. TURNTABLE LOCK INSTALLATION
FIGURE 2-10. TANK AND PUMPS INSTALLATION
FIGURE 2-11. HYDRAULIC TANK INSTALLATION
FIGURE 2-12. MOTOR ASSEMBLY
FIGURE 2-13. DRIVE ORIENTATION INSTALLATION
FIGURE 2-14. GROUND CONTROL ASSEMBLY (SN C300000326 through C300000699)
FIGURE 2-15. GROUND CONTROL ASSEMBLY (ANSI, AUATRALIAN AND CSA SPECS) (SN C300000326 through C300000699)
FIGURE 2-16. GROUND CONTROL ASSEMBLY - WITH 4 INCH DISPLAY (CE & UK CA SPECS)
FIGURE 2-17. LIGHT PANEL INSTALLATION – GROUND CONTROL (SN C300000326 through C300000699)
FIGURE 2-18. LIGHT PANEL INSTALLATION – GROUND CONTROL (CE & UK CA SPECS ONLY)
FIGURE 2-19. ELECTRICAL SYSTEM INSTALLATION (SN C300000326 through C300000699)
FIGURE 2-20. BATTERY CHARGER INSTALLATION – WITH NO PLUG (SN C300000326 through C300000699)
FIGURE 2-21. BATTERY CHARGER INSTALLATION - 220V (AUSTRALIAN SPECS) (SN C300000326 through C300000699)
FIGURE 2-22. BATTERY CHARGER INSTALLATION – WITH 230 IEC PLUG (CE & UK CA SPECS) (SN C300000326 through C300000699)
FIGURE 2-23. BATTERY CHARGER INSTALLATION – WITH 110V IEC PLUG (YELLOW) (CE & UK CA SPECS) (SN C300000326 through C300000699)
FIGURE 2-24. BATTERY CHARGER INSTALLATION - WITH CEE7 PLUG (CE & UK CA SPECS) (SN C300000326 through C300000699)
FIGURE 2-25. BATTERY CHARGER INSTALLATION - WITH ASFINT KEYED PLUG (CE & UK CA SPECS) (SN C300000326 through C300000699)
FIGURE 2-26. BATTERY CHARGER INSTALLATION - WITH 110V PLUG (ANSI AND CSA SPECS) (SN C300000326 through C300000699)
FIGURE 2-27. BATTERY AND CABLE INSTALLATION
FIGURE 2-28. ALARM WHITE NOISE INSTALLATION
FIGURE 2-29. BEACON LIGHT INSTALLATION - AMBER (Prior to SN C300000398)
FIGURE 2-30. BEACON LIGHT INSTALLATION - BLUE (SN C300000398 to Present)
FIGURE 2-31. BEACON LIGHT INSTALLATION - BLUE (SN C300000398 to Present)
FIGURE 2-32. BEACON LIGHT INSTALLATION - RED (SN C300000398 to Present)
FIGURE 2-33. BEACON LIGHT INSTALLATION - RED
FIGURE 2-34. HOODS INSTALLATION (SN C300000326 through C300000699)
FIGURE 2-35. HOOD ASSEMBLY - TANK SIDE
FIGURE 2-36. HOOD ASSEMBLY - ENGINE SIDE
FIGURE 2-37. COVERS INSTALLATION - COUNTERWEIGHT
FIGURE 2-38. CLEARSKY INSTALLATION - AUSTRALIAN SPEC
FIGURE 2-39. CLEARSKY INSTALLATION - CE SPEC
SECTION 3 - BOOMFIGURE 3-1. CYLINDERS INSTALLATION
FIGURE 3-2. BOOM INSTALLATION - WITHOUT AIRLINES
FIGURE 3-3. BOOM INSTALLATION - WITH AIRLINE
FIGURE 3-4. BOOM AIRLINE INSTALLATION
FIGURE 3-5. AIRLINE FITTINGS INSTALLATION
FIGURE 3-6. MAIN BOOM INSTALLATION
FIGURE 3-7. MAIN BOOM ASSEMBLY
FIGURE 3-8. TOWER BOOM ASSEMBLY
FIGURE 3-9. JIB INSTALLATION
FIGURE 3-10. ROTATOR ASSEMBLY
FIGURE 3-11. PLATFORM SUPPORT INSTALLATION
FIGURE 3-12. BOOM VALVES INSTALLATION
FIGURE 3-13. BOOM VALVE ASSEMBLY
FIGURE 3-14. UPRIGHT VALVE ASSEMBLY
SECTION 4 - PLATFORMFIGURE 4-1. PLATFORM ASSEMBLY - 30IN X 4FT (76CM X 1.22M) - SIDE GATE ENTRY
FIGURE 4-2. PLATFORM ASSEMBLY - 30IN X 5FT (76CM X 1.52M) - SIDE GATE ENTRY
FIGURE 4-3. PLATFORM ASSEMBLY - 30IN X 6FT (76CM X 1.83M) - SIDE GATE ENTRY
FIGURE 4-4. PLATFORM ASSEMBLY - 30IN X 3FT (76CM X .91M) - DROP BAR ENTRY
FIGURE 4-5. PLATFORM ASSEMBLY - 30IN X 4FT (76CM X 1.22M) - WITH DROP BAR
FIGURE 4-6. PLATFORM ASSEMBLY - 30IN X 5FT (76CM X 1.52M) - WITH DROP BAR
FIGURE 4-7. PLATFORM ASSEMBLY - 30IN X 6FT (76CM X 1.83M) - WITH DROP BAR
FIGURE 4-8. CONSOLE BOX INSTALLATION - WITH SKYGUARD
FIGURE 4-9. PLATFORM CONSOLE BOX ASSEMBLY - WITH SKYGUARD
FIGURE 4-10. LIGHT PANEL INSTALLATION - PLATFORM CONTROL
FIGURE 4-11. LIGHT PANEL INSTALLATION - PLATFORM CONTROL
FIGURE 4-12. CONTROLLER ASSEMBLY - DRIVE AND STEER
FIGURE 4-13. CONTROLLER ASSEMBLY - LIFT AND SWING
FIGURE 4-14. FOOTSWITCH ASSEMBLY
FIGURE 4-15. PLATFORM CHARGER (12V)
FIGURE 4-16. PLATFORM CHARGER (USB)
FIGURE 4-17. TRAY ASSEMBLY
FIGURE 4-18. SKYEYE INSTALLATION
FIGURE 4-19. SKYGUARD BAR INSTALLATION
FIGURE 4-20. SKYLINE INSTALLATION
FIGURE 4-21. PIPE RACK INSTALLATION (Prior to SN C300000330)
SECTION 5 - CYLINDERFIGURE 5-1. AXLE LOCKOUT CYLINDER ASSEMBLY
FIGURE 5-2. LEVEL (PLATFORM SLAVE) CYLINDER ASSEMBLY
FIGURE 5-3. LIFT CYLINDER ASSEMBLY - JIB
FIGURE 5-4. LIFT CYLINDER ASSEMBLY - MAIN BOOM
FIGURE 5-5. LIFT CYLINDER ASSEMBLY - TOWER BOOM
FIGURE 5-6. MASTER CYLINDER ASSEMBLY
FIGURE 5-7. STEER CYLINDER ASSEMBLY
FIGURE 5-8. TELESCOPE CYLINDER ASSEMBLY
SECTION 6 - HYDRAULICFIGURE 6-1. BOOM HYDRAULIC SYSTEM INSTALLATION
FIGURE 6-2. CHASSIS HYDRAULIC SYSTEM INSTALLATION
SECTION 7 - ELECTRICALFIGURE 7-1. CLEARSKY BEACON LIGHT HARNESS
FIGURE 7-2. BEACON LIGHT HARNESS
FIGURE 7-3. BMS HARNESS
FIGURE 7-4. BOOM CABLES AND CLAMPS (Prior to SN C300000185)
FIGURE 7-5. BOOM CABLES AND CLAMPS (SN C300000185 to Present)
FIGURE 7-6. BOOM HARNESS - MAIN BOOM
FIGURE 7-7. BOOM HARNESS - MAIN BOOM AC CABLE
FIGURE 7-8. BOOM HARNESS - TOWER BOOM
FIGURE 7-9. BOOM HARNESS - TOWER BOOM AC CABLE
FIGURE 7-10. BOOM VALVE HARNESS
FIGURE 7-11. CHASSIS HARNESS ASSEMBLY (Prior to SN C300000468)
FIGURE 7-12. CHASSIS HARNESS ASSEMBLY
FIGURE 7-13. CLEARSKY HARNESS
FIGURE 7-14. CONTROLLER BRACKET ASSEMBLY
FIGURE 7-15. DISPLAY ADAPTER HARNESS
FIGURE 7-16. DRIVE MOTOR HARNESS (RIGHT REAR)
FIGURE 7-17. DRIVE MOTOR HARNESS (LEFT REAR)
FIGURE 7-18. FUSE PLATE ASSEMBLY
FIGURE 7-19. GROUND CONTROL HARNESS
FIGURE 7-20. PLATFORM TO BOOM HARNESS
FIGURE 7-21. PLATFORM CONSOLE BOX HARNESS
FIGURE 7-22. PLATFORM INTERFACE HARNESS
FIGURE 7-23. PLATFORM VALVE HARNESS
FIGURE 7-24. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 2X4 BOX POST GROUND
FIGURE 7-25. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 2X4 BOX SIDE GROUND
FIGURE 7-26. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT 107 2X4 BOX KEYED GROUND
FIGURE 7-27. AC BOX AT PLATFORM INSTALLATION - 110V IEC YELLOW
FIGURE 7-28. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE
FIGURE 7-29. AC BOX AT PLATFORM INSTALLATION - WITH TWO BREAKERS
FIGURE 7-30. AC BOX AT PLATFORM INSTALLATION - WITH THREE BREAKERS
FIGURE 7-31. STEER SENSOR HARNESS
FIGURE 7-32. SKYEYE INTERMEDIATE HARNESS
FIGURE 7-33. SKYEYE RECEIVER HARNESS
FIGURE 7-34. SKYEYE EMITTER HARNESS
FIGURE 7-35. SKYLINE HARNESS
FIGURE 7-36. TRACTION HARNESS
FIGURE 7-37. VALVE HARNESS - MAIN VALVE
FIGURE 7-38. WHEEL DRIVE ELECTRICAL HARNESS INSTALLATION (2WD)
SECTION 8 - DECALSFIGURE 8-1. DECAL INSTALLATION - AUSTRALIAN SPECS
FIGURE 8-2. DECAL INSTALLATION - CE & UK CA SPECS
FIGURE 8-3. DECAL INSTALLATION - OPTIONS
SECTION 9 - RECOMMENDED SERVICE PARTS STOCKFIGURE 9-1. RECOMMENDED SERVICE PARTS STOCK
SECTION 10 - SPECIAL OPTIONSFIGURE 10-1. SPECIAL OPTIONS
PART NUMBER INDEX
- SuperPac Parts Manual
- StratoLift Parts Manual
