JLG Boom Lift EC520AJ Parts Catalog 31217108
Brand: JLG
Type of Machine: Boom Lift
Model: JLG EC520AJ Boom Lift
Part Number: 31217108
Publication Date: 2025
Number of Pages: 314 Pages
SECTION 1 - FRAME
Brand: JLG
SECTION 1 - FRAME
FIGURE 1-1. AXLE INSTALLATION
FIGURE 1-2. STEER INSTALLATION
FIGURE 1-3. WHEEL DRIVE INSTALLATION (2WD)
FIGURE 1-4. HUB - SPINDLE ASSEMBLY
FIGURE 1-5. DRIVE MOTOR ASSEMBLY
FIGURE 1-6. BATTERY INSTALLATION
FIGURE 1-7. FRAME SHIELD INSTALLATION
FIGURE 1-8. TIRE AND WHEEL INSTALLATION - 33 X 12-20 SOLID NON-MARKING
FIGURE 1-9. TIRE AND WHEEL INSTALLATION - 315/55 D20 FOAM FILLED
FIGURE 1-10. TIRE AND WHEEL INSTALLATION - 315/55 D20 FOAM FILLED NON-MARKING
FIGURE 1-11. CONTROL VALVES INSTALLATION - FRAME MOUNTED
FIGURE 1-12. OSCILLATING AXLE VALVE ASSEMBLY
SECTION 2 - TURNTABLEFIGURE 2-1. CONTROL VALVES INSTALLATION - TURNTABLE MOUNTED
FIGURE 2-2. MAIN VALVE ASSEMBLY
FIGURE 2-3. AUXILIARY PUMP ASSEMBLY
FIGURE 2-4. ENCLOSURE INSTALLATION
FIGURE 2-5. SWING DRIVE AND TURNTABLE BEARING INSTALLATION
FIGURE 2-6. SWING MOTOR ASSEMBLY
FIGURE 2-7. TURNTABLE BEARING ASSEMBLY
FIGURE 2-8. TURNTABLE COVERS INSTALLATION
FIGURE 2-9. TURNTABLE LOCK INSTALLATION
FIGURE 2-10. TANK AND PUMPS INSTALLATION
FIGURE 2-11. HYDRAULIC TANK INSTALLATION
FIGURE 2-12. MOTOR ASSEMBLY
FIGURE 2-13. DRIVE ORIENTATION INSTALLATION
FIGURE 2-14. GROUND CONTROL ASSEMBLY
FIGURE 2-15. GROUND CONTROL ASSEMBLY (ANSI, AUATRALIAN AND CSA SPECS)
FIGURE 2-16. GROUND CONTROL ASSEMBLY - WITH 4 INCH DISPLAY (CE SPECS)
FIGURE 2-17. LIGHT PANEL INSTALLATION – GROUND CONTROL
FIGURE 2-18. LIGHT PANEL INSTALLATION – GROUND CONTROL (CE SPECS ONLY)
FIGURE 2-19. ELECTRICAL SYSTEM INSTALLATION
FIGURE 2-20. BATTERY CHARGER INSTALLATION – WITH NO PLUG
FIGURE 2-21. BATTERY CHARGER INSTALLATION - 220V (AUSTRALIAN SPECS)
FIGURE 2-22. BATTERY CHARGER INSTALLATION – WITH 230 IEC PLUG (CE SPECS)
FIGURE 2-23. BATTERY CHARGER INSTALLATION – WITH 110 IEC PLUG (YELLOW) (CE SPECS)
FIGURE 2-24. BATTERY CHARGER INSTALLATION (CEE7) (CE SPECS)
FIGURE 2-25. BATTERY CHARGER INSTALLATION (ASFINT KEYED GRD) (CE SPECS)
FIGURE 2-26. BATTERY CHARGER INSTALLATION - 110V (ANSI AND CSA SPECS)
FIGURE 2-27. BATTERY AND CABLE INSTALLATION
FIGURE 2-28. ALARM WHITE NOISE INSTALLATION
FIGURE 2-29. BEACON LIGHT INSTALLATION - AMBER
FIGURE 2-30. BEACON LIGHT INSTALLATION - BLUE
FIGURE 2-31. BEACON LIGHT INSTALLATION - RED
FIGURE 2-32. HOODS INSTALLATION
FIGURE 2-33. HOOD ASSEMBLY - TANK SIDE
FIGURE 2-34. HOOD ASSEMBLY - ENGINE SIDE
FIGURE 2-35. COVERS INSTALLATION - COUNTERWEIGHT
SECTION 3 - BOOMFIGURE 3-1. CYLINDERS INSTALLATION (SN C180000105 through C180000106, Prior to SN C300000204)
FIGURE 3-2. CYLINDERS INSTALLATION (SN C300000204 through C300000329)
FIGURE 3-3. BOOM INSTALLATION - WITHOUT AIRLINES
FIGURE 3-4. BOOM INSTALLATION - WITH AIRLINE
FIGURE 3-5. BOOM AIRLINE INSTALLATION
FIGURE 3-6. AIRLINE FITTINGS INSTALLATION
FIGURE 3-7. MAIN BOOM INSTALLATION
FIGURE 3-8. MAIN BOOM ASSEMBLY
FIGURE 3-9. TOWER BOOM ASSEMBLY
FIGURE 3-10. JIB INSTALLATION
FIGURE 3-11. ROTATOR ASSEMBLY
FIGURE 3-12. PLATFORM SUPPORT INSTALLATION - WITH 1 CELL LSS
FIGURE 3-13. BOOM VALVES INSTALLATION
FIGURE 3-14. BOOM VALVE ASSEMBLY
FIGURE 3-15. UPRIGHT VALVE ASSEMBLY
SECTION 4 - PLATFORMFIGURE 4-1. PLATFORM ASSEMBLY - 30IN X 4FT (76CM X 1.22M) - SIDE GATE ENTRY
FIGURE 4-2. PLATFORM ASSEMBLY - 30IN X 5FT (76CM X 1.52M) - SIDE GATE ENTRY
FIGURE 4-3. PLATFORM ASSEMBLY - 30IN X 6FT (76CM X 1.83M) - SIDE GATE ENTRY
FIGURE 4-4. PLATFORM ASSEMBLY - 30IN X 3FT (76CM X .91M) - DROP BAR ENTRY
FIGURE 4-5. PLATFORM ASSEMBLY - 30IN X 4FT (76CM X 1.22M) - WITH DROP BAR
FIGURE 4-6. PLATFORM ASSEMBLY - 30IN X 5FT (76CM X 1.52M) - WITH DROP BAR
FIGURE 4-7. PLATFORM ASSEMBLY - 30IN X 6FT (76CM X 1.83M) - WITH DROP BAR
FIGURE 4-8. CONSOLE BOX INSTALLATION - WITH SKYGUARD
FIGURE 4-9. PLATFORM CONSOLE BOX ASSEMBLY - WITH SKYGUARD
FIGURE 4-10. LIGHT PANEL INSTALLATION - PLATFORM CONTROL
FIGURE 4-11. LIGHT PANEL INSTALLATION - PLATFORM CONTROL (CE SPECS ONLY)
FIGURE 4-12. CONTROLLER ASSEMBLY - DRIVE AND STEER
FIGURE 4-13. CONTROLLER ASSEMBLY - LIFT AND SWING
FIGURE 4-14. FOOTSWITCH ASSEMBLY
FIGURE 4-15. PLATFORM CHARGER (12V)
FIGURE 4-16. PLATFORM CHARGER (USB)
FIGURE 4-17. TRAY ASSEMBLY
FIGURE 4-18. SKYEYE INSTALLATION
FIGURE 4-19. SKYGUARD BAR INSTALLATION
FIGURE 4-20. SKYLINE INSTALLATION
FIGURE 4-21. PIPE RACK INSTALLATION
SECTION 5 - CYLINDERFIGURE 5-1. AXLE LOCKOUT CYLINDER ASSEMBLY
FIGURE 5-2. LEVEL (PLATFORM SLAVE) CYLINDER ASSEMBLY
FIGURE 5-3. LIFT CYLINDER ASSEMBLY - JIB
FIGURE 5-4. LIFT CYLINDER ASSEMBLY - MAIN BOOM (SN C180000105 through C180000106, Prior to SN C300000204)
FIGURE 5-5. LIFT CYLINDER ASSEMBLY - MAIN BOOM (SN C300000204 through C300000329)
FIGURE 5-6. LIFT CYLINDER ASSEMBLY - TOWER BOOM (SN C180000105 through C180000106, Prior to SN C300000204)
FIGURE 5-7. LIFT CYLINDER ASSEMBLY - TOWER BOOM (SN C300000204 through C300000329)
FIGURE 5-8. MASTER CYLINDER ASSEMBLY
FIGURE 5-9. STEER CYLINDER ASSEMBLY
FIGURE 5-10. TELESCOPE CYLINDER ASSEMBLY (SN C180000105 through C180000106, Prior to SN C300000204)
FIGURE 5-11. TELESCOPE CYLINDER ASSEMBLY (SN C300000204 through C300000329)
SECTION 6 - HYDRAULICFIGURE 6-1. BOOM HYDRAULIC SYSTEM INSTALLATION
FIGURE 6-2. CHASSIS HYDRAULIC SYSTEM INSTALLATION
SECTION 7 - ELECTRICALFIGURE 7-1. BEACON LIGHT HARNESS
FIGURE 7-2. BMS HARNESS
FIGURE 7-3. BOOM CABLES AND CLAMPS (SN C180000105 through C18000106, Prior to SN C300000185)
FIGURE 7-4. BOOM CABLES AND CLAMPS (SN C300000185 through C300000329)
FIGURE 7-5. BOOM HARNESS - MAIN BOOM
FIGURE 7-6. BOOM HARNESS - MAIN BOOM AC CABLE
FIGURE 7-7. BOOM HARNESS - TOWER BOOM
FIGURE 7-8. BOOM HARNESS - TOWER BOOM AC CABLE
FIGURE 7-9. BOOM VALVE HARNESS
FIGURE 7-10. CHASSIS HARNESS ASSEMBLY
FIGURE 7-11. CONTROLLER BRACKET ASSEMBLY
FIGURE 7-12. DISPLAY ADAPTER HARNESS
FIGURE 7-13. DRIVE MOTOR HARNESS (RIGHT REAR)
FIGURE 7-14. DRIVE MOTOR HARNESS (LEFT REAR)
FIGURE 7-15. FUSE PLATE ASSEMBLY
FIGURE 7-16. GROUND CONTROL HARNESS
FIGURE 7-17. PLATFORM TO BOOM HARNESS
FIGURE 7-18. PLATFORM CONSOLE BOX HARNESS
FIGURE 7-19. PLATFORM INTERFACE HARNESS
FIGURE 7-20. PLATFORM VALVE HARNESS
FIGURE 7-21. STEER SENSOR HARNESS
FIGURE 7-22. SKYEYE INTERMEDIATE HARNESS
FIGURE 7-23. SKYEYE RECEIVER HARNESS
FIGURE 7-24. SKYEYE EMITTER HARNESS
FIGURE 7-25. SKYLINE HARNESS
FIGURE 7-26. TRACTION HARNESS
FIGURE 7-27. VALVE HARNESS - MAIN VALVE
FIGURE 7-28. WHEEL DRIVE ELECTRICAL HARNESS INSTALLATION (2WD)
SECTION 8 - DECALSFIGURE 8-1. DECAL INSTALLATION - AUSTRALIAN SPECS
FIGURE 8-2. DECAL INSTALLATION - CE SPECS
FIGURE 8-3. DECAL INSTALLATION - OPTIONS
SECTION 9 - RECOMMENDED SERVICE PARTS STOCKFIGURE 9-1. RECOMMENDED SERVICE PARTS STOCK
SECTION 10 - SPECIAL OPTIONSFIGURE 10-1. SPECIAL OPTIONS
PART NUMBER INDEX
- SuperPac Parts Manual
- StratoLift Parts Manual
