Hyundai
86
176,834
JLG Boom Lift EC450AJ Parts Catalog 31217105
Brand: JLG
Type of Machine: Boom Lift
Model: JLG EC450AJ Boom Lift
Part Number: 31217105
Publication Date: 2025
Number of Pages: 316 Pages
SECTION 1 - FRAME
FIGURE 1-1. AXLE INSTALLATION​
FIGURE 1-2. STEER INSTALLATION​
FIGURE 1-3. WHEEL DRIVE INSTALLATION (2WD)​
FIGURE 1-4. HUB - SPINDLE ASSEMBLY​
FIGURE 1-5. DRIVE MOTOR ASSEMBLY​
FIGURE 1-6. BATTERY INSTALLATION​
FIGURE 1-7. FRAME SHIELD INSTALLATION​
FIGURE 1-8. TIRE AND WHEEL INSTALLATION - 33 X 12-20 SOLID NON-MARKING​
FIGURE 1-9. TIRE AND WHEEL INSTALLATION - 315/55 D20 FOAM FILLED​
FIGURE 1-10. TIRE AND WHEEL INSTALLATION - 315/55 D20 FOAM FILLED NON-MARKING​
FIGURE 1-11. CONTROL VALVES INSTALLATION - FRAME MOUNTED​
FIGURE 1-12. OSCILLATING AXLE VALVE ASSEMBLY​
SECTION 2 - TURNTABLE
FIGURE 2-1. CONTROL VALVES INSTALLATION - TURNTABLE MOUNTED​
FIGURE 2-2. MAIN VALVE ASSEMBLY​
FIGURE 2-3. AUXILIARY PUMP ASSEMBLY​
FIGURE 2-4. ENCLOSURE INSTALLATION​
FIGURE 2-5. SWING DRIVE AND TURNTABLE BEARING INSTALLATION​
FIGURE 2-6. SWING MOTOR ASSEMBLY​
FIGURE 2-7. TURNTABLE BEARING ASSEMBLY​
FIGURE 2-8. TURNTABLE COVERS INSTALLATION​
FIGURE 2-9. TURNTABLE LOCK INSTALLATION​
FIGURE 2-10. TANK AND PUMPS INSTALLATION​
FIGURE 2-11. HYDRAULIC TANK INSTALLATION​
FIGURE 2-12. MOTOR ASSEMBLY​
FIGURE 2-13. DRIVE ORIENTATION INSTALLATION​
FIGURE 2-14. GROUND CONTROL ASSEMBLY​
FIGURE 2-15. GROUND CONTROL ASSEMBLY (ANSI, AUATRALIAN AND CSA SPECS)​
FIGURE 2-16. GROUND CONTROL ASSEMBLY - WITH 4 INCH DISPLAY (CE SPECS)​
FIGURE 2-17. LIGHT PANEL INSTALLATION – GROUND CONTROL​
FIGURE 2-18. LIGHT PANEL INSTALLATION – GROUND CONTROL (CE SPECS ONLY)​
FIGURE 2-19. ELECTRICAL SYSTEM INSTALLATION​
FIGURE 2-20. BATTERY CHARGER INSTALLATION – WITH NO PLUG​
FIGURE 2-21. BATTERY CHARGER INSTALLATION - 110V (ANSI AND CSA SPECS)​
FIGURE 2-22. BATTERY CHARGER INSTALLATION - 220V (AUSTRALIAN SPECS)​
FIGURE 2-23. BATTERY CHARGER INSTALLATION​
FIGURE 2-24. BATTERY CHARGER INSTALLATION – WITH 110 IEC PLUG (YELLOW) (CE SPECS)​
FIGURE 2-25. BATTERY CHARGER INSTALLATION (CEE7) (CE SPECS)​
FIGURE 2-26. BATTERY CHARGER INSTALLATION (ASFINT KEYED GRD) (CE SPECS)​
FIGURE 2-27. BATTERY AND CABLE INSTALLATION​
FIGURE 2-28. ALARM WHITE NOISE INSTALLATION​
FIGURE 2-29. BEACON LIGHT INSTALLATION - AMBER​
FIGURE 2-30. BEACON LIGHT INSTALLATION - BLUE​
FIGURE 2-31. BEACON LIGHT INSTALLATION - RED​
FIGURE 2-32. HOODS INSTALLATION​
FIGURE 2-33. HOOD ASSEMBLY - TANK SIDE​
FIGURE 2-34. HOOD ASSEMBLY - ENGINE SIDE​
FIGURE 2-35. COVERS INSTALLATION - COUNTERWEIGHT​
SECTION 3 - BOOM
FIGURE 3-1. CYLINDERS INSTALLATION (SN C180000101 through C180000103, Prior to SN C300000243)​
FIGURE 3-2. CYLINDERS INSTALLATION (SN C300000243 through C300000325)​
FIGURE 3-3. BOOM INSTALLATION - WITHOUT AIRLINES​
FIGURE 3-4. BOOM INSTALLATION - WITH AIRLINE​
FIGURE 3-5. BOOM AIRLINE INSTALLATION​
FIGURE 3-6. AIRLINE FITTINGS INSTALLATION​
FIGURE 3-7. MAIN BOOM INSTALLATION​
FIGURE 3-8. MAIN BOOM ASSEMBLY​
FIGURE 3-9. TOWER BOOM ASSEMBLY​
FIGURE 3-10. JIB INSTALLATION​
FIGURE 3-11. ROTATOR ASSEMBLY​
FIGURE 3-12. PLATFORM SUPPORT INSTALLATION - WITH 1 CELL LSS​
FIGURE 3-13. BOOM VALVES INSTALLATION​
FIGURE 3-14. BOOM VALVE ASSEMBLY​
FIGURE 3-15. UPRIGHT VALVE ASSEMBLY​
SECTION 4 - PLATFORM
FIGURE 4-1. PLATFORM ASSEMBLY - 30IN X 4FT (76CM X 1.22M) - SIDE GATE ENTRY​
FIGURE 4-2. PLATFORM ASSEMBLY - 30IN X 5FT (76CM X 1.52M) - SIDE GATE ENTRY​
FIGURE 4-3. PLATFORM ASSEMBLY - 30IN X 6FT (76CM X 1.83M) - SIDE GATE ENTRY​
FIGURE 4-4. PLATFORM ASSEMBLY - 30IN X 3FT (76CM X .91M) - DROP BAR ENTRY​
FIGURE 4-5. PLATFORM ASSEMBLY - 30IN X 4FT (76CM X 1.22M) - WITH DROP BAR​
FIGURE 4-6. PLATFORM ASSEMBLY - 30IN X 5FT (76CM X 1.52M) - WITH DROP BAR​
FIGURE 4-7. PLATFORM ASSEMBLY - 30IN X 6FT (76CM X 1.83M) - WITH DROP BAR​
FIGURE 4-8. CONSOLE BOX INSTALLATION - WITH SKYGUARD​
FIGURE 4-9. PLATFORM CONSOLE BOX ASSEMBLY - WITH SKYGUARD​
FIGURE 4-10. LIGHT PANEL INSTALLATION - PLATFORM CONTROL​
FIGURE 4-11. LIGHT PANEL INSTALLATION - PLATFORM CONTROL (CE SPECS ONLY)​
FIGURE 4-12. CONTROLLER ASSEMBLY - DRIVE AND STEER​
FIGURE 4-13. CONTROLLER ASSEMBLY - LIFT AND SWING​
FIGURE 4-14. FOOTSWITCH ASSEMBLY​
FIGURE 4-15. PLATFORM CHARGER (12V)​
FIGURE 4-16. PLATFORM CHARGER (USB)​
FIGURE 4-17. TRAY ASSEMBLY​
FIGURE 4-18. SKYEYE INSTALLATION​
FIGURE 4-19. SKYGUARD BAR INSTALLATION​
FIGURE 4-20. SKYLINE INSTALLATION​
FIGURE 4-21. PIPE RACK INSTALLATION​
SECTION 5 - CYLINDER
FIGURE 5-1. AXLE LOCKOUT CYLINDER ASSEMBLY​
FIGURE 5-2. LEVEL (PLATFORM SLAVE) CYLINDER ASSEMBLY​
FIGURE 5-3. LIFT CYLINDER ASSEMBLY - JIB​
FIGURE 5-4. LIFT CYLINDER ASSEMBLY - MAIN BOOM (SN C180000101 through C180000103, Prior to SN C300000243)​
FIGURE 5-5. LIFT CYLINDER ASSEMBLY - MAIN BOOM (SN C300000243 through C300000325)​
FIGURE 5-6. LIFT CYLINDER ASSEMBLY - TOWER BOOM (SN C180000101 through C180000103, Prior to SN C300000243)​
FIGURE 5-7. LIFT CYLINDER ASSEMBLY - TOWER BOOM (SN C300000243 through C300000325)​
FIGURE 5-8. MASTER CYLINDER ASSEMBLY​
FIGURE 5-9. STEER CYLINDER ASSEMBLY​
FIGURE 5-10. TELESCOPE CYLINDER ASSEMBLY (SN C180000101 through C180000103, Prior to SN C300000243)​
FIGURE 5-11. TELESCOPE CYLINDER ASSEMBLY (SN C300000243 through C300000325)​
SECTION 6 - HYDRAULIC
FIGURE 6-1. BOOM HYDRAULIC SYSTEM INSTALLATION​
FIGURE 6-2. CHASSIS HYDRAULIC SYSTEM INSTALLATION​
SECTION 7 - ELECTRICAL
FIGURE 7-1. BEACON LIGHT HARNESS​
FIGURE 7-2. BMS HARNESS​
FIGURE 7-3. BOOM CABLES AND CLAMPS​
FIGURE 7-4. BOOM HARNESS - MAIN BOOM​
FIGURE 7-5. BOOM HARNESS - MAIN BOOM AC CABLE​
FIGURE 7-6. BOOM HARNESS - TOWER BOOM​
FIGURE 7-7. BOOM HARNESS - TOWER BOOM AC CABLE​
FIGURE 7-8. BOOM VALVE HARNESS​
FIGURE 7-9. CHASSIS HARNESS ASSEMBLY​
FIGURE 7-10. CONTROLLER BRACKET ASSEMBLY​
FIGURE 7-11. DISPLAY ADAPTER HARNESS​
FIGURE 7-12. DRIVE MOTOR HARNESS (RIGHT REAR)​
FIGURE 7-13. DRIVE MOTOR HARNESS (LEFT REAR)​
FIGURE 7-14. FUSE PLATE ASSEMBLY​
FIGURE 7-15. GROUND CONTROL PANEL HARNESS​
FIGURE 7-16. PLATFORM TO BOOM HARNESS​
FIGURE 7-17. PLATFORM CONSOLE BOX HARNESS​
FIGURE 7-18. PLATFORM INTERFACE HARNESS​
FIGURE 7-19. PLATFORM VALVE HARNESS​
FIGURE 7-20. STEER SENSOR HARNESS​
FIGURE 7-21. SKYEYE INTERMEDIATE HARNESS​
FIGURE 7-22. SKYEYE RECEIVER HARNESS​
FIGURE 7-23. SKYEYE EMITTER HARNESS​
FIGURE 7-24. SKYLINE HARNESS​
FIGURE 7-25. TRACTION HARNESS​
FIGURE 7-26. VALVE HARNESS - MAIN​
FIGURE 7-27. WHEEL DRIVE ELECTRICAL HARNESS INSTALLATION (2WD)​
SECTION 8 - DECALS
FIGURE 8-1. DECAL INSTALLATION - ANSI SPECS​
FIGURE 8-2. DECAL INSTALLATION - AUSTRALIAN SPECS​
FIGURE 8-3. DECAL INSTALLATION – CE SPECS​
FIGURE 8-4. DECAL INSTALLATION - CSA SPECS​
FIGURE 8-5. DECAL INSTALLATION - OPTIONS​
SECTION 9 - RECOMMENED SERVICE PARTS STOCK
FIGURE 9-1. RECOMMENDED SERVICE PARTS STOCK​
SECTION 10 - SPECIAL OPTIONS
FIGURE 10-1. SPECIAL OPTIONS​
PART NUMBER INDEX
