Hyundai
86
176,834
JLG Boom Lift EC450AJ EC520AJ Service & Maintenance Manual 31221583 2025
Brand: JLG
Type of Machine: Boom Lift
Model: JLG EC450AJ, EC520AJ Boom Lift
Serial Number: C300000700 to Present
Part Number: 31221583
Publication Date: 2025
Number of Pages: 602 Pages
Section 1. Specifications​
1.1 General Specifications​
1.2 Tires​
1.3 Capacities​
1.4 Dimensional Data - EC450AJ​
1.5 Dimensional Data - EC520AJ​
1.6 Torque Specifications​
1.7 Lubrication Specifications​
1.8 Critical Stability Weights​
1.9 Major Component Weights​
1.10 Serial Number Locations​
1.11 Maintenance and Lubrication​
1.12 ThreadLocking Compound​
1.13 Torque Charts​
Section 2. General​
2.1 Machine Preparation, Inspection, and Maintenance​
2.2 Service and Guidelines​
2.3 Lubrication and Information​
2.4 Cylinder Drift​
2.5 Pins and Composite Bearing Repair Guidelines​
2.6 Welding on JLG Equipment​
Section 3. Chassis & Turntable​
3.1 Tires & Wheels​
3.2 Oscillating Axle System​
3.3 Chassis Tilt Indicator System​
3.4 Spindle​
3.5 Lockout Cylinder Bleeding​
3.6 Drive System (2WD & 4WD)​
3.7 Wheel Drive Assembly​
3.8 Speed Sensor​
3.9 Drive Hub​
3.10 Drive Motor (2WD)​
3.11 Drive Motor (4WD)​
3.12 Swing Bearing​
3.13 Swing Motor​
3.14 Battery Pack​
3.15 Charging Battery Modules​
3.16 Battery Monitoring System (BMS)​
3.17 Battery Charge Manager (BCM)​
3.18 Battery Charger​
3.19 Cold Weather Operation​
3.20 Hot Weather Operation (If Equipped)​
3.21 Battery Reductions Related To Soc% For Machine Operation​
3.22 Battery DTC Related To Reductions For Machine Operation​
3.23 Auxiliary Pump​
3.24 Counterweight​
Section 4. Boom & Platform​
4.1 Boom Systems​
4.2 Platform​
4.3 Platform Level Cylinder Removal​
4.4 Rotator​
4.5 Main Boom Powertrack​
4.6 Boom Maintenance​
4.7 Wear Pads​
4.8 Boom Cleanliness Guidelines​
4.9 Articulating Jib Boom​
4.10 Foot switch Adjustment​
4.11 Rotary Actuator​
4.12 Powertrack Maintenance​
4.13 Skyguard​
Section 5. Basic Hydraulic Information & Schematics​
5.1 Lubricating O-rings in the Hydraulic System​
5.2 Hydraulic Connection Assembly and Torque Specification​
5.3 Hydraulic Cylinders​
5.4 Cylinder Removal And Installation​
5.5 Tower Lift Cylinder Bleeding Procedure​
5.6 Pressure Setting Procedures​
5.7 Hydraulic Schematic​
Section 6. JLG Control System​
6.1 JLG Control System Analyzer Kit Instructions​
6.2 Machine Configuration Programming Information​
6.3 Machine Personality Settings​
6.4 Machine Orientation When performing test​
6.5 Calibrating Steer​
6.6 Calibrating Tilt Sensor​
6.7 Load Sensing System (LSS)​
6.8 Calibrating Boom Angle​
6.9 Calibrating Motor​
6.10 Resetting The MSSO System (If equipped)​
6.11 UGM DTC Related To Machine Operation​
6.12 UGM DTC Related To Battery Sub-system​
6.13 BCM DTC Related To Battery Sub-system​
Section 7. Basic Electrical Information & Electrical Schematics​
7.1 General​
7.2 Multimeter Basics​
7.3 Checking Switches​
7.4 Applying Silicone Dielectric Compound To Electrical Connections​
7.5 Dielectric Grease Application​
7.6 AMP Connector​
7.7 Deutsch Connectors​
7.8 Wiring Harness Connector Labels​
7.9 Electrical Schematics​
