Hyundai
86
176,834
JLG Boom Lift EC450AJ Compact Service & Maintenance Manual 3122328700 2025
Brand: JLG
Type of Machine: Boom Lift
Model: JLG EC450AJ Compact Boom Lift
Part Number: 3122328700
Publication Date: 2025
Number of Pages: 584 Pages
Safety
General​
1.1.1 Disclaimer​
Safety Information​
Safety Hazards​
1.3.1 Personal Hazards​
1.3.2 Equipment Hazards​
1.3.3 General Hazards​
1.3.4 Operational Hazards​
Safety Decals​
Machine Verification​
Specifications​
2.1.1 Machine Specifications​
2.1.2 Machine Dimensional Data​
2.1.3 Battery​
2.1.4 Battery Charger​
2.1.5 Tires​
2.1.6 Critical Stability Weights​
Machine Temperature Chart​
Serial Number Location​
Fluids and Lubrication​
2.4.1 General Information​
2.4.2 Hydraulic Oil​
2.4.3 Changing Hydraulic Oil​
2.4.4 Lubrication Specifications​
2.4.5 Fluids​
2.4.6 Capacities​
Machine Characteristics​
2.5.1 Platform Control Enable System​
2.5.2 Drive System (2WD and 4WD)​
2.5.3 Oscillating Axle System​
2.5.4 Chassis Tilt Indicator System​
2.5.5 Platform Load Sensing System (LSS)​
2.5.6 Transport Position Sensing System​
2.5.7 Beyond Transport – Drive Speed Cutback System​
2.5.8 Drive/Steer – Boom Function Interlock System​
Clearsky Smart Fleet​
2.6.1 General​
2.6.2 ClearSky Smart Fleet™ — Access Control​
Machine Preparation, Inspection, and Maintenance​
3.1.1 General​
3.1.2 Preparation, Inspection, and Maintenance​
3.1.3 Pre-Start Inspection​
3.1.4 Pre-Delivery Inspection and Frequent Inspection​
3.1.5 Annual Machine Inspection​
3.1.6 Preventive Maintenance​
Service and Guidelines​
3.2.1 General​
3.2.2 Safety and Workmanship​
3.2.3 Cleanliness​
3.2.6 Pressure-Fit Parts​
3.2.7 Bearings​
3.2.8 Gaskets​
3.2.11 Hydraulic System​
3.2.12 Lubrication​
3.2.13 Battery​
3.2.14 Welding on JLG Equipment​
Preventive Maintenance and Inspection Schedule​
3.3.1 Inspection Schedules​
3.3.2 Maintenance Schedules​
Pins and Composite Bearing Repair Guidelines​
Tires and Wheels​
3.5.1 Tire Inflation​
3.5.2 Tire Damage​
Boom Inspection and Maintenance​
3.6.1 Boom Cleanliness Guidelines​
3.6.2 Boom Wear Pad Inspection​
Hydraulic Filter Replacement​
3.7.1 Removal​
3.7.2 Installation​
Turntable Bearing Inspection​
3.8.1 Turntable Bearing Mounting Bolt Condition Check​
3.8.2 Wear Tolerance​
Battery Packs​
3.9.1 Battery Monitoring System​
Battery Maintenance​
3.10.1 Battery Maintenance and Inspection​
3.10.2 Battery Charging​
3.10.3 Long-Term Storage of Battery​
Battery Charger​
3.11.1 General Information​
3.11.2 Battery Charger​
3.11.3 Battery Charger User Interface​
3.11.4 LED Indicators​
Electric Motor​
Auxiliary Power System​
Testing, Calibrations and Special Procedures
Special Tools​
4.1.1 Multimeter Basics​
4.1.2 Threadlocking Compound​
4.1.3 Tools Catalog​
SkyGuard​
4.2.1 Operation​
4.2.2 Function Test​
4.2.3 Diagnostics and Troubleshooting​
4.2.4 Fault Codes​
Load Sensing System​
4.3.1 Preparation​
4.3.2 Testing LSS Control System Warnings and Interlocks​
4.3.3 Testing LSS Control System Capacity Indication​
4.3.4 Testing LSS Platform Load Reading with Calibrated Weights​
4.3.5 Testing LSS Platform Load Reading with a Known Weight​
Calibration Preparation​
4.4.1 JLG Analyzer​
4.4.2 Calibration Preparation​
Load Sensing System Calibration​
Tilt Sensor Calibration​
Steer Calibration​
Wheel Drive Hub​
Cylinder Drift​
4.9.1 Theory​
4.9.2 Cylinder Leakage Test​
4.9.3 Cylinder Thermal Drift​
Axle Lockout Cylinder Bleeding​
System Software
5.1.1 Theory of Operation​
JLG Analyzer​
5.2.1 Machine Data Access​
5.2.2 Hand Held Analyzer​
5.2.3 Analyzer Software Level 2​
Analyzer Software Accessibility​
5.3.1 Analyzer Diagnostics Menu Structure​
5.3.2 Machine Set-Up​
Personalities​
5.4.1 Machine Personality Settings and Function Speed​
Function Test​
5.6.1 ClearSky Smart FleetTM CS550 Configuration​
5.6.2 Troubleshooting​
Fault Codes
Fault Codes Introduction​
Machine Fault Codes​
6.2.1 Diagnostic Trouble Code - Machine Operation​
Battery Sub-System Fault Code​
ClearSky CS550 Troubleshooting Procedures​
Hydraulics
General Information and Safety​
Theories of Operation​
7.2.1 Cylinders​
7.2.2 Valves​
Hydraulic Components​
7.3.1 Hydraulic Oil Tank​
7.3.2 Hydraulic Pump Pre-Fill Procedure​
7.3.3 Main System Relief​
7.3.4 Steer Left Relief​
7.3.5 Steer Right Relief​
7.3.6 Boom Swing Relief​
7.3.7 Platform Level Up Relief​
7.3.8 Platform Level Down Relief​
7.3.9 Jib Lift Down Relief​
Torque Values​
7.4.1 Cylinder Torque Specifications​
7.4.2 Valve Torque Specifications​
Standard Hydraulic Diagram - Boom And Turntable​
Hydraulic Diagram - Chassis​
Electricals
8.1.1 Applying Silicone Dielectric Compound to Electrical Connections​
Electrical Connectors​
8.2.1 Deutsch Connectors​
Electrical Component Terminology​
Harness Layouts​
Board Layouts​
8.5.1 Drive Control Module Pin Connections​
Wiring Harness and Connector Label Diagrams​
8.6.1 Connector Labels​
8.6.2 Component Labels​
Platform Worklight Harness​
Skyline Harness​
Charger Harness​
Chassis Harness​
Tower Boom Extension Harness​
Main Boom Extension Harness​
Platform Harness​
Platform Controls Harness​
Main Boom EV Extension Harness​
Drive Harness​
Light Harness​
Front Left-Drive Extension Cable​
Rear Left - Engine Extension Harness​
Rear Right - Engine Extension Harness​
Rear Left - Engine Harness​
Rear Right - Engine Harness​
Chassis Control Harness​
L.REAR.MOTOR​
PROL. FRONT RIGHT MOTOR​
CABLE W MOT.EL.ANT.LFT EBOOM B525​
CABLE U MOT.E.L.ANT.SX​
CABLE U MOT.E.L.ANT.DX​
CABLE V MOT.ELEC.ANT.RIGHT​
CABLE W MOT.ELE.ANT.DX​
CABLE V MOT.ELE.ANT.LEFT EBOOM B525​
BMS CONNECTION PROL​
STEERING SENSOR FRONT RIGHT 2WD EBOOM B525​
LINK EXTENSION 1 B525​
LINK EXTENSION 2 B525​
DOUBLE HEADLIGHT LINE BASKET EBOOM B525​
J70NX-0410-08X-08X-XX-C1 -48V​
J50RT-1480-06X-08X-C1-XX +48V​
J50RT-0460-08X-10X-XX-XX +48V​
J70RT-0460-08X-08X-XX-XX +48V​
J70RT-2030-10X-12X-XX-C1 +48V​
J50RT-0980-08X-08X-XX-XX - CABLE​
J50RT-0450-08X-08X-XX-C1 - CABLE​
Wheel and Tire​
Chassis/Frame Assembly​
9.2.1 Axle and Drive Assemblies Troubleshooting​
9.2.2 Front Axle​
9.2.3 Electric Drive Motor and Spindle Assembly (2WD)​
9.2.4 Knuckle​
Boom​
9.3.1 Boom Components Terminology​
9.3.2 Troubleshooting​
9.3.3 Main Boom Powertrack​
9.3.4 Main Boom Assembly​
9.3.5 Tower Boom Assembly​
9.3.6 Jib and Rotator Assembly​
Platform​
9.4.1 Platform​
9.4.2 Rotator Assembly​
Electrical Components​
9.5.1 Electric Motor​
9.5.2 Boom Angle Sensor​
Hydraulic Cylinders​
9.6.1 Main Boom Lift and Leveling Cylinder​
9.6.2 Platform Level Cylinder​
9.6.3 Tower Boom Lift Cylinder​
9.6.4 Telescopic Cylinder​
9.6.5 Jib Lift Cylinder​
9.6.6 Steer Cylinder​
9.6.7 Axle Lockout Cylinder​
Hydraulic Valves​
9.7.1 Main Hydraulic Valve​
9.7.2 Axle Control Valve​
9.7.3 Manifold Valve​
9.7.4 Oscillation control valve​
Hydraulic Pumps​
9.8.1 Hydraulic Pump​
9.8.2 Auxiliary Pump and Motor​
Battery​
9.9.1 Lithium Ion Battery​
9.9.2 12V Battery​
Battery Charger​
9.10.1 Battery Charger - 3 kW (1100V IEC)​
9.10.2 Battery Charger 9 kW 3-Phase​
Turntable​
9.11.1 Swing Bearing​
9.11.2 Swing Motor​
9.11.3 Counterweight​
9.12.1 ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)​
Disassembly and Assembly
Drive Assembly​
10.1.1 Drive Hub​
10.1.2 Drive Motor​
Boom and Jib Assembly​
10.2.1 Main Boom Assembly​
10.2.2 Jib Disassembly/Assembly​
Hydraulic Valves​
10.5.1 Hydraulic Oil Tank​
Turntable​
Powertrack​
Torque/Connection Information
Hydraulic Fittings​
11.1.1 Tapered Thread Types​
11.1.2 Straight Thread Types, Tube and Hose Connections​
11.1.3 Straight Thread Types, Port Connections​
11.1.4 Flange Connection Types​
11.1.5 Tightening Methods​
11.1.6 Assembly and Torque Specifications​
11.1.7 General Tube Type Fitting Assembly Instructions​
11.1.8 Assembly Instructions for American Standard Pipe Thread Tapered Connections.​
11.1.9 Assembly Instructions for British Standard Pipe Thread Tapered Connections​
11.1.10 Assembly Instructions for 37° (JIC) Flare Fittings​
11.1.11 Assembly Instructions for 45° SAE Flare Fittings​
11.1.12 Assembly Instructions for O-Ring Face Seal (ORFS) Fittings​
11.1.13 Assembly Instructions for DIN 24° Flare Bite Type Fittings (MBTL and MBTS)​
11.1.14 Assembly Instructions for Bulkhead (BH) Fittings​
11.1.15 Assembly Instructions for O-Ring Boss (ORB) Fittings​
11.1.16 Assembly Instructions for Adjustable Port End Metric Fittings​
11.1.17 Assembly Instructions for Metric ISO 6149 (MPP) Port Assembly Stud Ends​
11.1.18 Assembly instructions for Adjustable Port End (BSPP) Fittings​
11.1.19 Assembly Instructions for Flange Connections: (FL61 and FL62)​
11.1.20 Double Wrench Method​
11.1.21 FFWR and TFFT Methods​
11.1.22 Adjustable Stud End Assembly​
11.1.23 O-ring Installation (Replacement)​
Torque Charts​
11.2.1 SAE Fastener Torque Chart​
11.2.2 Metric Fastener Torque Chart​
Schematics
Hydraulic Schematics​
Electrical Schematics​
