Hyundai
86
176,834
JLG Boom Lift E450AJ Parts Manual 31222498
Brand: JLG
Type of Machine: Boom Lift
Model: JLG E450AJ Boom Lift
Part Number: 31222498
Publication Date: 2025
Number of Pages: 430 Pages
SECTION 1 - FRAME
FIGURE 1-1. BATTERY BOX INSTALLATION - AGM BATTERIES​
FIGURE 1-2. BATTERY BOX INSTALLATION - AGM BATTERIES (6V)​
FIGURE 1-3. BATTERY BOX INSTALLATION - STANDARD​
FIGURE 1-4. BATTERY CHARGER INSTALLATION (ANSI EXPORT AND CHINA SPECS)​
FIGURE 1-5. BATTERY CHARGER INSTALLATION (ALL SPECS EXCEPT AUSTRALIAN, CE, CHINA, RUSSIAN & UK CA SPECS)​
FIGURE 1-6. BATTERY CHARGER INSTALLATION (AUSTRALIAN SPEC)​
FIGURE 1-7. BATTERY CHARGER INSTALLATION (GREEN POWER)​
FIGURE 1-8. BATTERY CHARGER INSTALLATION (ANSI EXPORT, CE, RUSSIAN & UK CA SPECS)​
FIGURE 1-9. DRIVE INSTALLATION - NON-UL SPECS​
FIGURE 1-10. DRIVE INSTALLATION - UL SPECS​
FIGURE 1-11. DRIVE HUB ASSEMBLY​
FIGURE 1-12. DRIVE MOTOR ASSEMBLY​
FIGURE 1-13. ELECTRICAL PLATE ASSEMBLY - LH (NON-UL SPECS)​
FIGURE 1-14. ELECTRICAL PLATE ASSEMBLY - LH (UL SPECS)​
FIGURE 1-15. ELECTRICAL PLATE ASSEMBLY - RH (NON-UL SPECS)​
FIGURE 1-16. ELECTRICAL PLATE ASSEMBLY - RH (UL SPECS)​
FIGURE 1-17. FRAME COVER INSTALLATION​
FIGURE 1-18. INVERTER INSTALLATION​
FIGURE 1-19. INVERTER (2000W/60HZ) INSTALLATION (SN 0300313296 to Present, SN 0300311772 to Present)​
FIGURE 1-20. INVERTER INSTALLATION (3000W)​
FIGURE 1-21. MOTOR/PUMP/TANK INSTALLATION - NON-UL SPECS​
FIGURE 1-22. MOTOR/PUMP/TANK INSTALLATION - UL SPECS​
FIGURE 1-23. MOTOR/PUMP/TANK INSTALLATION WITHOUT MOTOR BAND​
FIGURE 1-24. MOTOR/PUMP/TANK INSTALLATION​
FIGURE 1-25. HYDRAULIC TANK ASSEMBLY (MACHINES WITH SN STARTING WITH 03)​
FIGURE 1-26. HYDRAULIC TANK ASSEMBLY (MACHINES WITH SN STARTING WITH B3)​
FIGURE 1-27. MOTOR/PUMP ASSEMBLY​
FIGURE 1-28. STEERING INSTALLATION (MACHINES WITH SN STARTING WITH 03)​
FIGURE 1-29. STEERING INSTALLATION (MACHINES WITH SN STARTING WITH B3)​
FIGURE 1-30. HUB - SPINDLE ASSEMBLY - LH​
FIGURE 1-31. HUB - SPINDLE ASSEMBLY - RH​
FIGURE 1-32. TIRE/WHEEL - IN240/55 - 17.5 FOAM FILLED​
FIGURE 1-33. TIRE/WHEEL - IN240/55-17.5 FOAM FILLED NON MARKING​
FIGURE 1-34. TIRE/WHEEL - 26 X 7 X 20 - SOLID NON MARKING​
FIGURE 1-35. VALVE INSTALLATION - FRAME MOUNTED​
FIGURE 1-36. BRAKE/STEER VALVE ASSEMBLY​
FIGURE 1-37. VOLTAGE GUARD INSTALLATION​
SECTION 2 - TURNTABLE
FIGURE 2-1. VALVE INSTALLATION - TURNTABLE MOUNTED​
FIGURE 2-2. MAIN CONTROL VALVE ASSEMBLY​
FIGURE 2-3. RELEVELING VALVE ASSEMBLY​
FIGURE 2-4. JIB VALVE ASSEMBLY​
FIGURE 2-5. MOTION ALARM INSTALLATION​
FIGURE 2-6. TURNTABLE BEARING AND SWING DRIVE INSTALLATION​
FIGURE 2-7. TURNTABLE BEARING AND SWING DRIVE INSTALLATION (ZJ MOTOR)​
FIGURE 2-8. SWING BEARING ASSEMBLY​
FIGURE 2-9. SWING MOTOR ASSEMBLY​
FIGURE 2-10. SWING MOTOR ASSEMBLY (ZJ MOTOR)​
FIGURE 2-11. REMOTE BEARING LUBE INSTALLATION - OPTIONAL​
FIGURE 2-12. DRIVE ORIENTATION INSTALLATION​
FIGURE 2-13. GROUND CONTROL BOX INSTALLATION (ALL SPECS EXCEPT CE, CHINA, RUSSIAN & UK CA SPECS)​
FIGURE 2-14. GROUND CONTROL BOX INSTALLATION (CE, CHINA, RUSSIAN & UK CA SPECS)​
FIGURE 2-15. GROUND CONTROL BOX ELECTRICAL ASSEMBLY - DISPLAY WITHOUT BUTTONS (ALL SPECS EXCEPT CE, CHINA, RUSSIAN & UK CA SPECS)​
FIGURE 2-16. GROUND CONTROL BOX ELECTRICAL ASSEMBLY - DISPLAY WITHOUT BUTTONS (CE, CHINA, RUSSIAN & UK CA SPECS)​
FIGURE 2-17. GROUND CONTROL BOX ELECTRICAL ASSEMBLY - DISPLAY WITHOUT BUTTONS (ALL SPECS EXCEPT CE & UK CA SPECS)​
FIGURE 2-18. HOOD INSTALLATION​
SECTION 3 - ENGINE
FIGURE 3-1. KUBOTA MOTOR/GENERATOR ASSEMBLY​
FIGURE 3-2. KUBOTA ENGINE COMPONENTS​
SECTION 4 - BOOM
FIGURE 4-1. BOOM AND CYLINDERS INSTALLATION (MACHINES WITH SN STARTING WITH 03)​
FIGURE 4-2. BOOM AND CYLINDERS INSTALLATION (MACHINES WITH SN STARTING WITH B3)​
FIGURE 4-3. BOOM AND CYLINDERS INSTALLATION (CHINA SPEC)​
FIGURE 4-4. MAIN BOOM ASSEMBLY (MACHINES WITH SN STARTING WITH 03)​
FIGURE 4-5. MAIN BOOM ASSEMBLY (MACHINES WITH SN STARTING WITH B3)​
FIGURE 4-6. MAIN BOOM ASSEMBLY (CHINA SPEC)​
FIGURE 4-7. JIB INSTALLATION (MACHINES WITH SN STARTING WITH 03)​
FIGURE 4-8. JIB INSTALLATION (MACHINES WITH SN STARTING WITH B3)​
FIGURE 4-9. ROTATOR ASSEMBLY​
FIGURE 4-10. PLATFORM SUPPORT INSTALLATION​
FIGURE 4-11. BOOM LIMIT SWITCHES INSTALLATION​
SECTION 5 - PLATFORM
FIGURE 5-1. PLATFORM ASSEMBLY - 4FT/1.22M - SIDE GATE ENTRY​
FIGURE 5-2. PLATFORM ASSEMBLY - 5FT/1.52M - SIDE GATE ENTRY​
FIGURE 5-3. PLATFORM ASSEMBLY - 4FT/1.22M - DROP BAR ENTRY​
FIGURE 5-4. PLATFORM ASSEMBLY - 5FT/1.52M - DROP BAR ENTRY​
FIGURE 5-5. PLATFORM ASSEMBLY - 30IN X 3FT (76CM X .91M) - DROP BAR ENTRY​
FIGURE 5-6. PLATFORM ASSEMBLY - 6FT/1.83M - DROP BAR ENTRY​
FIGURE 5-7. PLATFORM ASSEMBLY - 5FT/1.52M - FALL ARREST​
FIGURE 5-8. PLATFORM ASSEMBLY - 6FT/1.83M - FALL ARREST​
FIGURE 5-9. PLATFORM CONSOLE AND FOOTSWITCH INSTALLATION (NON-UL SPECS)​
FIGURE 5-10. PLATFORM CONSOLE AND FOOTSWITCH INSTALLATION (UL SPECS)​
FIGURE 5-11. PLATFORM CONSOLE ASSEMBLY (NON-UL SPECS)​
FIGURE 5-12. PLATFORM CONSOLE ASSEMBLY (UL SPECS)​
FIGURE 5-13. LIGHT PANEL INSTALLATION​
FIGURE 5-14. JIB SWITCH INSTALLATION​
FIGURE 5-15. FOOTSWITCH ASSEMBLY​
FIGURE 5-16. USB CHARGER INSTALLATION​
FIGURE 5-17. TRAY ASSEMBLY​
FIGURE 5-18. SKYEYE INSTALLATION​
FIGURE 5-19. SKYGUARD BAR INSTALLATION​
FIGURE 5-20. SKYLINE INSTALLATION​
FIGURE 5-21. SKYSENSE MID TUBE SENSOR ASSEMBLY​
FIGURE 5-22. SKYSENSE OVERHEAD SENSOR ASSEMBLY​
FIGURE 5-23. SOFT-TOUCH INSTALLATION​
SECTION 6 - CYLINDER
FIGURE 6-1. LEVEL (PLATFORM SLAVE) CYLINDER ASSEMBLY (MACHINES WITH SN STARTING WITH 03)​
FIGURE 6-2. LEVEL (PLATFORM SLAVE) CYLINDER ASSEMBLY (MACHINES WITH SN STARTING WITH B3)​
FIGURE 6-3. LIFT CYLINDER ASSEMBLY - JIB (MACHINES WITH SN STARTING WITH 03)​
FIGURE 6-4. LIFT CYLINDER ASSEMBLY - JIB (MACHINES WITH SN STARTING WITH B3)​
FIGURE 6-5. LIFT CYLINDER ASSEMBLY - LOWER (MACHINES WITH SN STARTING WITH 03) (Prior to SN 0300292776, SN 0300321238 through 0300321245, SN 0300321447 through 0300321781, Prior to SN B300002463, Except SN 0300286744 through 0300286748, Including 0300...​
FIGURE 6-6. LIFT CYLINDER ASSEMBLY - LOWER (MACHINES WITH SN STARTING WITH 03) (SN 0300286744 through 0300286748, SN 0300293054 through 0300320938, SN 0300320940 through 0300320945, SN 0300321246 through 0300321248, SN 0300321250 to Present, SN B30000...​
FIGURE 6-7. LIFT CYLINDER ASSEMBLY - LOWER (MACHINES WITH SN STARTING WITH B3)​
FIGURE 6-8. LIFT CYLINDER ASSEMBLY - MID (MACHINES WITH SN STARTING WITH 03) (Prior to SN 0300291339, SN 0300291343 through 0300291672, SN 0300291677 through 0300291682, Prior to SN B300002463, Except SN 0300286741 through 0300286748, Including 030029...​
FIGURE 6-9. LIFT CYLINDER ASSEMBLY - MID (MACHINES WITH SN STARTING WITH 03) (SN 0300286741 through 0300286748, SN 0300291676 to Present, SN B300002463 to Present, Except SN 0300291677 through 0300291682, Including 0300291339, 0300291342 and 0300291673)​
FIGURE 6-10. LIFT CYLINDER ASSEMBLY - MID (MACHINES WITH SN STARTING WITH B3)​
FIGURE 6-11. LIFT CYLINDER ASSEMBLY - UPPER (MACHINES WITH SN STARTING WITH 03)​
FIGURE 6-12. LIFT CYLINDER ASSEMBLY - UPPER (MACHINES WITH SN STARTING WITH B3)​
FIGURE 6-13. MASTER CYLINDER ASSEMBLY (MACHINES WITH SN STARTING WITH 03)​
FIGURE 6-14. MASTER CYLINDER ASSEMBLY (MACHINES WITH SN STARTING WITH B3)​
FIGURE 6-15. STEER CYLINDER ASSEMBLY (MACHINES WITH SN STARTING WITH 03)​
FIGURE 6-16. STEER CYLINDER ASSEMBLY (MACHINES WITH SN STARTING WITH B3)​
FIGURE 6-17. TELESCOPE CYLINDER ASSEMBLY (MACHINES WITH SN STARTING WITH 03)​
FIGURE 6-18. TELESCOPE CYLINDER ASSEMBLY (MACHINES WITH SN STARTING WITH B3)​
FIGURE 6-19. COUNTERBALANCE VALVE ASSEMBLY​
SECTION 7 - HYDRAULIC
FIGURE 7-1. HYDRAULIC DIAGRAM​
SECTION 8 - ELECTRICAL
FIGURE 8-1. AC PLUGS AND SOCKETS INSTALLATION - AFSINT 107-2-01 KEYED GROUND - 2 X 4 BOX (CE & UK CA SPEC)​
FIGURE 8-2. AC PLUGS AND SOCKETS INSTALLATION - CEE7 POST GROUND (CE & UK CA SPEC)​
FIGURE 8-3. AC PLUGS AND SOCKETS INSTALLATION - CEE 7 SIDE GROUND (CE & UK CA SPEC)​
FIGURE 8-4. AC PLUGS AND SOCKETS INSTALLATION - CEE7 POST GROUND - 2 X 4 BOX (CE & UK CA SPEC)​
FIGURE 8-5. AC PLUGS AND SOCKETS INSTALLATION - CEE7 SIDE GROUND - 2 X 4 BOX (CE & UK CA SPEC)​
FIGURE 8-6. AC PLUGS AND SOCKETS INSTALLATION - IEC 60309 BLUE (CE & UK CA SPEC)​
FIGURE 8-7. AC PLUGS AND SOCKETS INSTALLATION - IEC 60309 YELLOW (CE & UK CA SPEC)​
FIGURE 8-8. BATTERY CABLE KIT (NON-UL SPECS)​
FIGURE 8-9. BATTERY CABLE KIT (UL SPECS)​
FIGURE 8-10. BOOM CABLE - LOWER​
FIGURE 8-11. BOOM CABLE - UPPER​
FIGURE 8-12. BOOM LIMIT SWITCH HARNESS - LOWER​
FIGURE 8-13. BOOM LIMIT SWITCH HARNESS - UPPER​
FIGURE 8-14. BREAKER BOX KIT WITH ONE BREAKERS - CE & UK CA SPEC​
FIGURE 8-15. BREAKER BOX KIT WITH TWO BREAKERS - CE & UK CA SPEC​
FIGURE 8-16. BREAKER BOX KIT WITH ONE BREAKER​
FIGURE 8-17. CABLES AND CLAMPS INSTALLATION​
FIGURE 8-18. CHARGER HARNESS​
FIGURE 8-19. CHARGER CORD PLUG INSTALLATION - 110V - IEC 60309 - YELLOW (CE & UK CA SPEC)​
FIGURE 8-20. CHARGER CORD PLUG INSTALLATION - 220V - AFSINT 107 KEYED GROUND (CE & UK CA SPEC)​
FIGURE 8-21. CHARGER CORD PLUG INSTALLATION - 220V - CEE7 POST GROUND (CE & UK CA SPEC)​
FIGURE 8-22. CHARGER CORD PLUG INSTALLATION - 220V - CEE7 SIDE GROUND (CE & UK CA SPEC)​
FIGURE 8-23. CHARGER CORD PLUG INSTALLATION - 220V - IEC 60309 - BLUE (CE & UK CA SPEC)​
FIGURE 8-24. CHARGER DC CONNECTION HARNESS​
FIGURE 8-25. CHASSIS TO TURNTABLE HARNESS​
FIGURE 8-26. CLEARSKY CS550 BEACON INSTALLATION​
FIGURE 8-27. STROBE LIGHT JUMPER HARNESS​
FIGURE 8-28. GROUND CONTROL PANEL HARNESS​
FIGURE 8-29. INVERTER HARNESS​
FIGURE 8-30. INVERTER IGNITION HARNESS​
FIGURE 8-31. INVERTER IGNITION HARNESS (SN 0300313296 to Present, SN 0300311772 to Present)​
FIGURE 8-32. LOWER BOOM 110V HARNESS ASSEMBLY​
FIGURE 8-33. LOWER BOOM 220V HARNESS ASSEMBLY​
FIGURE 8-34. PLATFORM CONSOLE HARNESS - WITH 1 CELL LSS (UL SPECS)​
FIGURE 8-35. PLUG AND RECEPTACLE INSTALLATION - SUPPLIED LOCALLY​
FIGURE 8-36. PLUG AND RECEPTACLE INSTALLATION - 110V​
FIGURE 8-37. PLUG AND RECEPTACLE INSTALLATION - 220V​
FIGURE 8-38. PLUG AND RECEPTACLE 110V INSTALLATION - IEC 60309 - YELLOW (CE & UK CA SPEC)​
FIGURE 8-39. PLUG AND RECEPTACLE 220V INSTALLATION - AFSINT 107 KEYED GROUND - 2 X 4 BOX (CE & UK CA SPEC)​
FIGURE 8-40. PLUG AND RECEPTACLE 220V INSTALLATION - CEE7 POST GROUND - 2 X 4 BOX (CE & UK CA SPEC)​
FIGURE 8-41. PLUG AND RECEPTACLE 220V INSTALLATION - CEE7 POST GROUND - 70MM X 70MM BOX (CE & UK CA SPEC)​
FIGURE 8-42. PLUG AND RECEPTACLE 220 INSTALLATION - CEE7 SIDE GROUND - 2 X 4 BOX (CE & UK CA SPEC)​
FIGURE 8-43. PLUG AND RECEPTACLE 220V INSTALLATION - CEE7 SIDE GROUND - 70MM X 70MM BOX (CE & UK CA SPEC)​
FIGURE 8-44. PLUG AND RECEPTACLE 220V INSTALLATION - IEC 60309 - BLUE (CE & UK CA SPEC)​
FIGURE 8-45. PLUG & RECEPTACLE 220V - CEE7 POST GROUND 2X4 BOX (CE, GB, & CIS SPECS)​
FIGURE 8-46. PLUG & RECEPTACLE 220V - AFSINT 107 KEYED GROUND 2X4 BOX (CE, GB, & CIS SPECS)​
FIGURE 8-47. SKYEYE INTERMEDIATE HARNESS​
FIGURE 8-48. SKYEYE RECEIVER HARNESS​
FIGURE 8-49. SKYEYE EMITTER HARNESS​
FIGURE 8-50. SKYGUARD HARNESS - WITH 1 CELL LSS​
FIGURE 8-51. SKYLINE HARNESS​
FIGURE 8-52. STEER/BRAKE HARNESS​
FIGURE 8-53. TRACTION HARNESS​
FIGURE 8-54. TURNTABLE HARNESS​
FIGURE 8-55. UPPER BOOM 110V HARNESS ASSEMBLY​
FIGURE 8-56. UPPER BOOM 220V HARNESS ASSEMBLY​
FIGURE 8-57. VALVE HARNESS​
SECTION 9 - DECALS
FIGURE 9-1. DECAL INSTALLATION - ANSI, ANSI EXPORT AND UL SPECS - ENGLISH (MACHINES WITH SN STARTING WITH 03)​
FIGURE 9-2. DECAL INSTALLATION - ANSI EXPORT SPEC - ENGLISH (MACHINES WITH SN STARTING WITH B3)​
FIGURE 9-3. DECAL INSTALLATION - AUSTRALIAN SPEC​
FIGURE 9-4. DECAL INSTALLATION - CE, CHINA & & UK CA SPECS​
FIGURE 9-5. DECAL INSTALLATION - CHINESE/ENGLISH (MACHINES WITH SN STARTING WITH 03)​
FIGURE 9-6. DECAL INSTALLATION - CHINESE/ENGLISH (MACHINES WITH SN STARTING WITH B3)​
FIGURE 9-7. DECAL INSTALLATION - FRENCH/ENGLISH SPECS​
FIGURE 9-8. DECAL INSTALLATION - JAPANESE SPEC (MACHINES WITH SN STARTING WITH 03)​
FIGURE 9-9. DECAL INSTALLATION - JAPANESE SPEC (MACHINES WITH SN STARTING WITH B3)​
FIGURE 9-10. DECAL INSTALLATION - KOREAN SPEC (MACHINES WITH SN STARTING WITH 03)​
FIGURE 9-11. DECAL INSTALLATION - KOREAN SPEC (MACHINES WITH SN STARTING WITH B3)​
FIGURE 9-12. DECAL INSTALLATION - SPANISH/ENGLISH SPECS​
FIGURE 9-13. DECAL INSTALLATION - SPANISH/PORTUGUESE SPECS​
FIGURE 9-14. DECAL INSTALLATION - OPTIONS​
SECTION 11 - SPECIAL OPTIONS
FIGURE 11-1. SPECIAL OPTIONS/ACCESORIES/KITS​
PART NUMBER INDEX
