Hyundai
86
176,834
JLG Boom Lift E450AJ Parts Catalog 3122337400
Brand: JLG
Type of Machine: Boom Lift
Model: JLG E450AJ Boom Lift
Part Number: 3122337400
Publication Date: 2025
Number of Pages: 534 Pages
SECTION 1 - FRAME
FIGURE 1-1. BATTERY BOX INSTALLATION - AGM BATTERIES​
FIGURE 1-2. BATTERY BOX INSTALLATION - AGM BATTERIES (6V)​
FIGURE 1-3. BATTERY BOX INSTALLATION - STANDARD​
FIGURE 1-4. BATTERY CHARGER INSTALLATION (ANSI EXPORT AND CHINA SPECS)​
FIGURE 1-5. BATTERY CHARGER INSTALLATION (ALL SPECS EXCEPT AUSTRALIAN, CE, CHINA, RUSSIAN & UK CA SPECS)​
FIGURE 1-6. BATTERY CHARGER INSTALLATION (AUSTRALIAN SPEC)​
FIGURE 1-7. BATTERY CHARGER INSTALLATION (GREEN POWER)​
FIGURE 1-8. BATTERY CHARGER INSTALLATION (ANSI EXPORT, CE, RUSSIAN & UK CA SPECS)​
FIGURE 1-9. DRIVE INSTALLATION - NON-UL SPECS​
FIGURE 1-10. DRIVE INSTALLATION - UL SPECS​
FIGURE 1-11. DRIVE HUB ASSEMBLY​
FIGURE 1-12. DRIVE MOTOR ASSEMBLY​
FIGURE 1-13. ELECTRICAL PLATE ASSEMBLY - LH (NON-UL SPECS)​
FIGURE 1-14. ELECTRICAL PLATE ASSEMBLY - LH (UL SPECS)​
FIGURE 1-15. ELECTRICAL PLATE ASSEMBLY - RH (NON-UL SPECS)​
FIGURE 1-16. ELECTRICAL PLATE ASSEMBLY - RH (UL SPECS)​
FIGURE 1-17. FRAME COVER INSTALLATION​
FIGURE 1-18. INVERTER INSTALLATION​
FIGURE 1-19. INVERTER (2000W/60HZ) INSTALLATION (SN 0300313296 to Present, SN 0300311772 to Present)​
FIGURE 1-20. INVERTER INSTALLATION (3000W)​
FIGURE 1-21. MOTOR/PUMP/TANK INSTALLATION - NON-UL SPECS​
FIGURE 1-22. MOTOR/PUMP/TANK INSTALLATION - UL SPECS​
FIGURE 1-23. MOTOR/PUMP/TANK INSTALLATION WITHOUT MOTOR BAND​
FIGURE 1-24. MOTOR/PUMP/TANK INSTALLATION​
FIGURE 1-25. HYDRAULIC TANK ASSEMBLY (MACHINES WITH SN STARTING WITH 03)​
FIGURE 1-26. HYDRAULIC TANK ASSEMBLY (MACHINES WITH SN STARTING WITH B3)​
FIGURE 1-27. MOTOR/PUMP ASSEMBLY​
FIGURE 1-28. STEERING INSTALLATION (MACHINES WITH SN STARTING WITH 03)​
FIGURE 1-29. STEERING INSTALLATION (MACHINES WITH SN STARTING WITH B3 OR C3) (Prior to SN B300030844, Prior to SN C300001294)​
FIGURE 1-30. STEERING INSTALLATION (MACHINES WITH SN STARTING WITH B3 OR C3) (SN B300030844 to Present, SN C300001294 to Present)​
FIGURE 1-31. HUB - SPINDLE ASSEMBLY - LH​
FIGURE 1-32. HUB - SPINDLE ASSEMBLY - RH​
FIGURE 1-33. TIRE/WHEEL - IN240/55 - 17.5 FOAM FILLED​
FIGURE 1-34. TIRE/WHEEL - IN240/55-17.5 FOAM FILLED NON MARKING​
FIGURE 1-35. TIRE/WHEEL - 26 X 7 X 20 - SOLID NON MARKING​
FIGURE 1-36. VALVE INSTALLATION - FRAME MOUNTED (Prior to SN 0300328062, Prior to SN B300029577, Prior to SN C300001294, SN B300029590 through B300029593, SN B300029624 through B300029628, Including C300001363 and C300001343)​
FIGURE 1-37. VALVE INSTALLATION - FRAME MOUNTED (SN 0300328062 through 0300332980, SN B300029577 to Present, SN C300001294 to Present, Except SN B300029590 through B300029593, Except SN B300029624 through B300029628, Excluding C300001330, C300001363 a...​
FIGURE 1-38. VALVE INSTALLATION - FRAME MOUNTED (SN 0300332980 to Present, Except SN 0300332981 through 0300332983, Excluding 0300332992 and 0300332993)​
FIGURE 1-39. BRAKE/STEER VALVE ASSEMBLY​
FIGURE 1-40. VOLTAGE GUARD INSTALLATION​
SECTION 2 - TURNTABLE
FIGURE 2-1. VALVE INSTALLATION - TURNTABLE MOUNTED (Prior to SN 0300328062, Prior to SN B300029577, Prior to SN C300001294, SN B300029590 through B300029593, SN B300029624 through B300029628, Including C300001363 and C300001343)​
FIGURE 2-2. VALVE INSTALLATION - TURNTABLE MOUNTED (SN 0300328062 through 0300332980, SN B300029577 to Present, SN C300001294 to Present, Except SN B300029590 through B300029593, Except SN B300029624 through B300029628, Excluding C300001330, C30000136...​
FIGURE 2-3. VALVE INSTALLATION - TURNTABLE MOUNTED (SN 0300332980 to Present, Except SN 0300332981 through 0300332983, Excluding 0300332992 and 0300332993)​
FIGURE 2-4. MAIN CONTROL VALVE ASSEMBLY​
FIGURE 2-5. RELEVELING VALVE ASSEMBLY (Prior to SN 0300328062, Prior to SN B300029577, Prior to SN C300001294, SN B300029590 through B300029593, SN B300029624 through B300029628, Including C300001363 and C300001343)​
FIGURE 2-6. RELEVELING VALVE ASSEMBLY (SN 0300328062 through 0300332980, SN B300029577 to Present, SN C300001294 to Present, Except SN B300029590 through B300029593, Except SN B300029624 through B300029628, Excluding C300001330, C300001363 and C300001...​
FIGURE 2-7. JIB VALVE ASSEMBLY (SN B300029577 to Present, SN C300001294 to Present, Prior to SN 0300332980, SN 0300332981 through 03003322983, Except SN B300029590 through B300029593, Except SN B300029624 through B300029628, Including 0300332992 and 0...​
FIGURE 2-8. JIB VALVE ASSEMBLY (SN 0300332980 to Present, Except SN 0300332981 through 03003322983, Excluding 0300332992 and 0300332993)​
FIGURE 2-9. MOTION ALARM INSTALLATION​
FIGURE 2-10. TURNTABLE BEARING AND SWING DRIVE INSTALLATION​
FIGURE 2-11. SWING BEARING ASSEMBLY​
FIGURE 2-12. SWING MOTOR ASSEMBLY​
FIGURE 2-13. REMOTE BEARING LUBE INSTALLATION - OPTIONAL​
FIGURE 2-14. DRIVE ORIENTATION INSTALLATION​
FIGURE 2-15. GROUND CONTROL BOX INSTALLATION (ALL SPECS EXCEPT CE, CHINA, RUSSIAN & UK CA SPECS)​
FIGURE 2-16. GROUND CONTROL BOX ELECTRICAL ASSEMBLY - DISPLAY WITHOUT BUTTONS (ALL SPECS EXCEPT CE, CHINA, RUSSIAN & UK CA SPECS)​
FIGURE 2-17. GROUND CONTROL BOX ELECTRICAL ASSEMBLY - DISPLAY WITHOUT BUTTONS (CE, CHINA, RUSSIAN & UK CA SPECS)​
FIGURE 2-18. GROUND CONTROL BOX ELECTRICAL ASSEMBLY - DISPLAY WITHOUT BUTTONS (ALL SPECS EXCEPT CE & UK CA SPECS)​
FIGURE 2-19. STROBE LIGHT INSTALLATION - AMBER​
FIGURE 2-20. BEACON LIGHT INSTALLATION (BLUE)​
FIGURE 2-21. BEACON LIGHT INSTALLATION (RED)​
FIGURE 2-22. HOOD PLUGS INSTALLATION​
FIGURE 2-23. HOOD INSTALLATION​
SECTION 3 - ENGINE
FIGURE 3-1. KUBOTA MOTOR/GENERATOR ASSEMBLY​
FIGURE 3-2. KUBOTA ENGINE COMPONENTS​
SECTION 4 - BOOM
FIGURE 4-1. BOOM AND CYLINDERS INSTALLATION (MACHINES WITH SN STARTING WITH 03)​
FIGURE 4-2. BOOM AND CYLINDERS INSTALLATION (MACHINES WITH SN STARTING WITH B3)​
FIGURE 4-3. BOOM AND CYLINDERS INSTALLATION (CHINA SPEC)​
FIGURE 4-4. MAIN BOOM ASSEMBLY (MACHINES WITH SN STARTING WITH 03)​
FIGURE 4-5. MAIN BOOM ASSEMBLY (MACHINES WITH SN STARTING WITH B3)​
FIGURE 4-6. MAIN BOOM ASSEMBLY (CHINA SPEC)​
FIGURE 4-7. JIB INSTALLATION (MACHINES WITH SN STARTING WITH B3)​
FIGURE 4-8. JIB INSTALLATION (MACHINES WITH SN STARTING WITH 03)​
FIGURE 4-9. ROTATOR ASSEMBLY - PLATFORM​
FIGURE 4-10. PLATFORM SUPPORT INSTALLATION (Prior to SN 0300336412, Prior to SN B300031060, Prior to SN C300003346, Excluding 0300031056)​
FIGURE 4-11. BOOM LIMIT SWITCHES INSTALLATION​
SECTION 5 - PLATFORM
FIGURE 5-1. PLATFORM ASSEMBLY - 4FT/1.22M - SIDE GATE ENTRY (Prior to SN 0300336412, Prior to SN B300031060, Prior to SN C300003346, Excluding B300031056)​
FIGURE 5-2. PLATFORM ASSEMBLY - 5FT/1.52M - SIDE GATE ENTRY (Prior to SN 0300336412, Prior to SN B300031060, Prior to SN C300003346, Excluding B300031056)​
FIGURE 5-3. PLATFORM ASSEMBLY - 4FT/1.22M - DROP BAR ENTRY (Prior to SN 0300336412, Prior to SN B300031060, Prior to SN C300003346, Excluding B300031056)​
FIGURE 5-4. PLATFORM ASSEMBLY - 5FT/1.52M - DROP BAR ENTRY (Prior to SN 0300336412, Prior to SN B300031060, Prior to SN C300003346, Excluding B300031056)​
FIGURE 5-5. PLATFORM ASSEMBLY - 30IN X 3FT (76CM X .91M) - DROP BAR ENTRY (Prior to SN 0300336412, Prior to SN B300031060, Prior to SN C300003346, Excluding B300031056)​
FIGURE 5-6. PLATFORM ASSEMBLY - 6FT/1.83M - DROP BAR ENTRY (Prior to SN 0300336412, Prior to SN B300031060, Prior to SN C300003346, Excluding B300031056)​
FIGURE 5-7. PLATFORM ASSEMBLY - 5FT/1.52M - FALL ARREST (Prior to SN 0300336412, Prior to SN B300031060, Prior to SN C300003346, Excluding B300031056)​
FIGURE 5-8. PLATFORM ASSEMBLY - 6FT/1.83M - FALL ARREST (Prior to SN 0300336412, Prior to SN B300031060, Prior to SN C300003346, Excluding B300031056)​
FIGURE 5-9. TRADITIONAL PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) WITH FALL ARREST (ALL SPECS EXCEPT CE ,AUSTRALIAN, JAPANESE, CIS SPECS) (MACHINES WITH SN STARTING WITH 03) (SN 0300336412 to Present)​
FIGURE 5-10. TRADITIONAL PLATFORM ASSEMBLY - 30IN X 5FT (76.2CM X 1.52M) WITH FALL ARREST (ALL SPECS EXCEPT CE, JAPANESE, CIS, & AUSTRALIAN SPECS) (MACHINES WITH SN STARTING WITH 03) (SN 0300336412 to Present)​
FIGURE 5-11. TRADITIONAL PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) WITH FALL ARREST (ANSI EXPORT OR CSA SPECS) (MACHINES WITH SN STARTING WITH B3) (SN B300031060 to Present, Including B300031056)​
FIGURE 5-12. TRADITIONAL PLATFORM ASSEMBLY - 30IN X 5FT (76.2CM X 1.52M) WITH FALL ARREST (ANSI EXPORT AND CSA SPECS) (MACHINES WITH SN STARTING WITH B3) (SN B300031060 to Present, Including B300031056)​
FIGURE 5-13. RAPID REPLACEABLE PLATFORM (30IN X 4FT (76.2CM X 1.22M) (MACHINES WITH SN STARTING WITH 03) (SN 0300336412 to Present)​
FIGURE 5-14. RAPID REPLACEABLE PLATFORM (30IN X 5FT (76.2CM X 1.52M) (MACHINES WITH SN STARTING WITH 03) (SN 0300336412 to Present)​
FIGURE 5-15. RAPID REPLACEABLE PLATORM (30IN X 6FT) (76.2CM X 1.82M) (MACHINES WITH SN STARTING WITH 03) (SN 0300336412 to Present)​
FIGURE 5-16. RAPID REPLACEABLE PLATFORM SUPPORT (MACHINES WITH SN STARTING WITH 03) (SN 0300336412 to Present)​
FIGURE 5-17. RAPID REPLACEABLE PLATFORM SUPPORT (MACHINES WITH SN STARTING WITH B3 & C3) (SN B300031060 to Present, SN C300003346 to Present, Including B300031056)​
FIGURE 5-18. RAPID REPLACEABLE PLATFORM (30IN X 4FT (76.2CM X 1.22M) (MACHINES WITH SN STARTING WITH B3 & C3) (SN B300031060 to Present, Including C300003346 and C300031056)​
FIGURE 5-19. RAPID REPLACEABLE PLATFORM (30IN X 5FT (76.2CM X 1.52M) (MACHINES WITH SN STARTING WITH B3 OR C3) (SN B300031060 to Present, Including C300003346 and C300031056)​
FIGURE 5-20. RAPID REPLACEABLE PLATFORM (30IN X 6FT) (76.2CM X 1.83M) (MACHINES WITH SN STARTING WITH B3 OR C3) (SN B300031060 to Present, SN C300003346 to Present, Including B300031056)​
FIGURE 5-21. PLATFORM - SWING GATE INSTALLATION (MACHINES WITH SN STARTING WITH 03) (SN 0300336412 to Present)​
FIGURE 5-22. PLATFORM - DROP BAR INSTALATION (MACHINES WITH SN STARTING WITH 03) (SN 0300336412 to Present)​
FIGURE 5-23. PLATFORM SWING GATE INSTALLATION (MACHINES WITH SN STARTING WITH B3 OR C3) (SN B300031060 to Present, Including C300003346 and C300031056)​
FIGURE 5-24. PLATFORM DROP BAR INSTALLATION (MACHINES WITH SN STARTING WITH B3 OR C3) (SN B300031060 to Present, Including C300003346 and C300031056)​
FIGURE 5-25. PLATFORM CONSOLE AND FOOTSWITCH INSTALLATION (NON-UL SPECS) (Prior to SN 0300336412, Prior to SN B300031060, Prior to SN C300003346, Excluding B300031056)​
FIGURE 5-26. PLATFORM CONTROL AND FOOTSWITH INSTALLATION - NON-UL LISTED (SN 0300336412 to Present, SN B300031060 to Present, SN C300003346 to Present, Including B300031056)​
FIGURE 5-27. PLATFORM CONSOLE AND FOOTSWITCH INSTALLATION (UL SPECS) (Prior to SN 0300336412)​
FIGURE 5-28. PLATFORM CONTROL AND FOOTSWITH INSTALLATION - UL LISTED (MACHINES WITH SN STARTING WITH 03) (SN 0300336412 to Present)​
FIGURE 5-29. PLATFORM CONSOLE ASSEMBLY (NON-UL SPECS) (Prior to SN 0300331229, Prior to SN B300030322, Prior to SN C300001403, Including C300002500 and C300002769, Excluding C300001308, C300001319, C300001320, C300001323, C300001325, C30001326 and C30...​
FIGURE 5-30. PLATFORM CONSOLE ASSEMBLY (NON-UL SPECS) (SN 0300331229 to Present, SN B300030322 to Present, SN C300001403 to Present, Including C300001308, C300001319, C300001320, C300001323, C300001325, C30001326 and C300001330, Excluding C300002500 a...​
FIGURE 5-31. PLATFORM CONSOLE ASSEMBLY - NON UL LISTED (SN 0300336412 to Present, SN B300031060 to Present, SN C300003346 to Present, Including B300031056)​
FIGURE 5-32. PLATFORM CONSOLE ASSEMBLY (UL SPECS) (Prior to SN 0300331229)​
FIGURE 5-33. PLATFORM CONSOLE ASSEMBLY (UL SPECS) (SN 0300331229 to Present)​
FIGURE 5-34. PLATFORM CONSOLE ASSEMBLY - UL LISTED (SN 0300336412 to Present)​
FIGURE 5-35. PLATFORM BEACON INSTALLATION​
FIGURE 5-36. LIGHT PANEL INSTALLATION​
FIGURE 5-37. JIB SWITCH INSTALLATION​
FIGURE 5-38. FOOTSWITCH ASSEMBLY​
FIGURE 5-39. USB CHARGER INSTALLATION (Prior to SN 0300336412, Prior to SN B300031060, Prior to SN C300003346, Excluding B300031056)​
FIGURE 5-40. USB CHARGER INSTALLATION (SN 0300336412 to Present, SN B300031060 to Present, SN C300003346 to Present, Including B300031056)​
FIGURE 5-41. TRAY ASSEMBLY​
FIGURE 5-42. SKYEYE INSTALLATION​
FIGURE 5-43. SKYGUARD BAR INSTALLATION​
FIGURE 5-44. SKYLINE INSTALLATION (Prior to SN 0300336412, Prior to SN B300031060, Prior to SN C300003346, Excluding B300031056)​
FIGURE 5-45. SKYLINE INSTALLATION (SN 0300336412 to Present, SN B300031060 to Present, SN C300003346 to Present, Including B300031056)​
FIGURE 5-46. SKYSENSE MID TUBE SENSOR ASSEMBLY​
FIGURE 5-47. SKYSENSE OVERHEAD SENSOR ASSEMBLY​
FIGURE 5-48. SOFT-TOUCH INSTALLATION​
SECTION 6 - CYLINDER
FIGURE 6-1. LEVEL (PLATFORM SLAVE) CYLINDER ASSEMBLY (MACHINES WITH SN STARTING WITH B3)​
FIGURE 6-2. LEVEL (PLATFORM SLAVE) CYLINDER ASSEMBLY (MACHINES WITH SN STARTING WITH 03)​
FIGURE 6-3. LIFT CYLINDER ASSEMBLY - JIB (MACHINES WITH SN STARTING WITH 03)​
FIGURE 6-4. LIFT CYLINDER ASSEMBLY - JIB (MACHINES WITH SN STARTING WITH B3)​
FIGURE 6-5. LIFT CYLINDER ASSEMBLY - LOWER (MACHINES WITH SN STARTING WITH 03)​
FIGURE 6-6. LIFT CYLINDER ASSEMBLY - LOWER (MACHINES WITH SN STARTING WITH B3)​
FIGURE 6-7. LIFT CYLINDER ASSEMBLY - MID (MACHINES WITH SN STARTING WITH 03)​
FIGURE 6-8. LIFT CYLINDER ASSEMBLY - MID (MACHINES WITH SN STARTING WITH B3)​
FIGURE 6-9. LIFT CYLINDER ASSEMBLY - UPPER (MACHINES WITH SN STARTING WITH 03)​
FIGURE 6-10. LIFT CYLINDER ASSEMBLY - UPPER (MACHINES WITH SN STARTING WITH B3)​
FIGURE 6-11. MASTER CYLINDER ASSEMBLY (MACHINES WITH SN STARTING WITH 03)​
FIGURE 6-12. MASTER CYLINDER ASSEMBLY (MACHINES WITH SN STARTING WITH B3)​
FIGURE 6-13. STEER CYLINDER ASSEMBLY (MACHINES WITH SN STARTING WITH 03)​
FIGURE 6-14. STEER CYLINDER ASSEMBLY (MACHINES WITH SN STARTING WITH B3)​
FIGURE 6-15. TELESCOPE CYLINDER ASSEMBLY (MACHINES WITH SN STARTING WITH 03)​
FIGURE 6-16. TELESCOPE CYLINDER ASSEMBLY (MACHINES WITH SN STARTING WITH B3)​
FIGURE 6-17. COUNTERBALANCE VALVE ASSEMBLY​
SECTION 7 - HYDRAULIC
FIGURE 7-1. HYDRAULIC DIAGRAM​
SECTION 8 - ELECTRICAL
FIGURE 8-1. AC PLUGS AND SOCKETS INSTALLATION - AFSINT 107-2-01 KEYED GROUND - 2 X 4 BOX (CE & UK CA SPEC)​
FIGURE 8-2. AC PLUGS AND SOCKETS INSTALLATION - CEE7 POST GROUND (CE & UK CA SPEC)​
FIGURE 8-3. AC PLUGS AND SOCKETS INSTALLATION - CEE 7 SIDE GROUND (CE & UK CA SPEC)​
FIGURE 8-4. AC PLUGS AND SOCKETS INSTALLATION - CEE7 POST GROUND - 2 X 4 BOX (CE & UK CA SPEC)​
FIGURE 8-5. AC PLUGS AND SOCKETS INSTALLATION - CEE7 SIDE GROUND - 2 X 4 BOX (CE & UK CA SPEC)​
FIGURE 8-6. AC PLUGS AND SOCKETS INSTALLATION - IEC 60309 BLUE (CE & UK CA SPEC)​
FIGURE 8-7. AC PLUGS AND SOCKETS INSTALLATION - IEC 60309 YELLOW (CE & UK CA SPEC)​
FIGURE 8-8. BATTERY CABLE KIT (NON-UL SPECS)​
FIGURE 8-9. BATTERY CABLE KIT (UL SPECS)​
FIGURE 8-10. BOOM CABLE - LOWER​
FIGURE 8-11. BOOM CABLE - UPPER​
FIGURE 8-12. BOOM LIMIT SWITCH HARNESS - LOWER​
FIGURE 8-13. BOOM LIMIT SWITCH HARNESS - UPPER​
FIGURE 8-14. BREAKER BOX KIT WITH ONE BREAKERS - CE & UK CA SPEC​
FIGURE 8-15. BREAKER BOX KIT WITH TWO BREAKERS - CE & UK CA SPEC​
FIGURE 8-16. BREAKER BOX KIT WITH ONE BREAKER​
FIGURE 8-17. CABLES AND CLAMPS INSTALLATION​
FIGURE 8-18. CLEARSKY CS550 BEACON INSTALLATION​
FIGURE 8-19. CHARGER HARNESS​
FIGURE 8-20. CHARGER CORD PLUG INSTALLATION - 110V - IEC 60309 - YELLOW (CE & UK CA SPEC)​
FIGURE 8-21. CHARGER CORD PLUG INSTALLATION - 220V - AFSINT 107 KEYED GROUND (CE & UK CA SPEC)​
FIGURE 8-22. CHARGER CORD PLUG INSTALLATION - 220V - CEE7 POST GROUND (CE & UK CA SPEC)​
FIGURE 8-23. CHARGER CORD PLUG INSTALLATION - 220V - CEE7 SIDE GROUND (CE & UK CA SPEC)​
FIGURE 8-24. CHARGER CORD PLUG INSTALLATION - 220V - IEC 60309 - BLUE (CE & UK CA SPEC)​
FIGURE 8-25. CHARGER DC CONNECTION HARNESS​
FIGURE 8-26. CHASSIS TO TURNTABLE HARNESS​
FIGURE 8-27. GROUND CONTROL PANEL HARNESS​
FIGURE 8-28. STROBE LIGHT JUMPER HARNESS​
FIGURE 8-29. VALVE HARNESS​
FIGURE 8-30. INVERTER HARNESS​
FIGURE 8-31. INVERTER IGNITION HARNESS​
FIGURE 8-32. INVERTER IGNITION HARNESS (SN 0300313296 to Present, SN 0300311772 to Present)​
FIGURE 8-33. LOWER BOOM 110V HARNESS ASSEMBLY​
FIGURE 8-34. LOWER BOOM 220V HARNESS ASSEMBLY​
FIGURE 8-35. PLATFORM CONSOLE HARNESS - WITH 1 CELL LSS (UL SPECS)​
FIGURE 8-36. PLATFORM BEACON HARNESS​
FIGURE 8-37. PLUG AND RECEPTACLE INSTALLATION - SUPPLIED LOCALLY​
FIGURE 8-38. PLUG AND RECEPTACLE INSTALLATION - 110V​
FIGURE 8-39. PLUG AND RECEPTACLE INSTALLATION - 220V​
FIGURE 8-40. PLUG AND RECEPTACLE 110V INSTALLATION - IEC 60309 - YELLOW (CE & UK CA SPEC) (Prior to SN 0300336412, Prior to SN B300031060, Prior to SN C300003346, Excluding B300031056)​
FIGURE 8-41. PLUG AND RECEPTACLE 110V INSTALLATION - IEC 60309 - YELLOW (CE & UK CA SPEC) (SN 0300336412 to Present, SN B300031060 to Present, SN C300003346 to Present, Including B300031056)​
FIGURE 8-42. PLUG AND RECEPTACLE 220V INSTALLATION - AFSINT 107 KEYED GROUND - 2 X 4 BOX (CE & UK CA SPEC) (Prior to SN 0300336412, Prior to SN B300031060, Prior to SN C300003346, Excluding B300031056)​
FIGURE 8-43. PLUG AND RECEPTACLE 220V INSTALLATION - AFSINT 107 KEYED GROUND - 2 X 4 BOX (CE & UK CA SPEC) (SN 0300336412 to Present, SN B300031060 to Present, SN C300003346 to Present, Including B300031056)​
FIGURE 8-44. PLUG AND RECEPTACLE 220V INSTALLATION - CEE7 POST GROUND - 2 X 4 BOX (CE & UK CA SPEC) (Prior to SN 0300336412, Prior to SN B300031060, Prior to SN C300003346, Excluding B300031056)​
FIGURE 8-45. PLUG AND RECEPTACLE 220V INSTALLATION - CEE7 POST GROUND - 2 X 4 BOX (CE & UK CA SPEC) (SN 0300336412 to Present, SN B300031060 to Present, SN C300003346 to Present, Including B300031056)​
FIGURE 8-46. PLUG AND RECEPTACLE 220V INSTALLATION - CEE7 POST GROUND - 70MM X 70MM BOX (CE & UK CA SPEC) (Prior to SN 0300336412, Prior to SN B300031060, Prior to SN C300003346, Excluding B300031056)​
FIGURE 8-47. PLUG AND RECEPTACLE 220V INSTALLATION - CEE7 POST GROUND - 70MM X 70MM BOX (CE & UK CA SPEC) (SN 0300336412 to Present, SN B300031060 to Present, SN C300003346 to Present, Including B300031056)​
FIGURE 8-48. PLUG AND RECEPTACLE 220 INSTALLATION - CEE7 SIDE GROUND - 2 X 4 BOX (CE & UK CA SPEC) (Prior to SN 0300336412, Prior to SN B300031060, Prior to SN C300003346, Excluding B300031056)​
FIGURE 8-49. PLUG AND RECEPTACLE 220 INSTALLATION - CEE7 SIDE GROUND - 2 X 4 BOX (CE & UK CA SPEC) (SN 0300336412 to Present, SN B300031060 to Present, SN C300003346 to Present, Including B300031056)​
FIGURE 8-50. PLUG AND RECEPTACLE 220V INSTALLATION - CEE7 SIDE GROUND - 70MM X 70MM BOX (CE & UK CA SPEC) (Prior to SN 0300336412, Prior to SN B300031060, Prior to SN C300003346, Excluding B300031056)​
FIGURE 8-51. PLUG AND RECEPTACLE 220V INSTALLATION - CEE7 SIDE GROUND - 70MM X 70MM BOX (CE & UK CA SPEC) (SN 0300336412 to Present, SN B300031060 to Present, SN C300003346 to Present, Including B300031056)​
FIGURE 8-52. PLUG AND RECEPTACLE 220V INSTALLATION - IEC 60309 - BLUE (CE & UK CA SPEC) (Prior to SN 0300336412, Prior to SN B300031060, Prior to SN C300003346, Excluding B300031056)​
FIGURE 8-53. PLUG AND RECEPTACLE 220V INSTALLATION - IEC 60309 - BLUE (CE & UK CA SPEC) (SN 0300336412 to Present, SN B300031060 to Present, SN C300003346 to Present, Including B300031056)​
FIGURE 8-54. PLUG & RECEPTACLE 220V - CEE7 POST GROUND 2X4 BOX (CE, GB, & CIS SPECS) (Prior to SN 0300336412, Prior to SN B300031060, Prior to SN C300003346, Excluding B300031056)​
FIGURE 8-55. PLUG & RECEPTACLE 220V - CEE7 POST GROUND 2X4 BOX (CE, GB, & CIS SPECS) (SN 0300336412 to Present, SN B300031060 to Present, SN C300003346 to Present, Including B300031056)​
FIGURE 8-56. PLUG & RECEPTACLE 220V - AFSINT 107 KEYED GROUND 2X4 BOX (CE, GB, & CIS SPECS) (Prior to SN 0300336412, Prior to SN B300031060, Prior to SN C300003346, Excluding B300031056)​
FIGURE 8-57. PLUG & RECEPTACLE 220V - AFSINT 107 KEYED GROUND 2X4 BOX (CE, GB, & CIS SPECS) (SN 0300336412 to Present, SN B300031060 to Present, SN C300003346 to Present, Including B300031056)​
FIGURE 8-58. SKYEYE INTERMEDIATE HARNESS​
FIGURE 8-59. SKYEYE RECEIVER HARNESS​
FIGURE 8-60. SKYEYE EMITTER HARNESS​
FIGURE 8-61. SKYGUARD HARNESS - WITH 1 CELL LSS​
FIGURE 8-62. SKYLINE HARNESS​
FIGURE 8-63. STEER/BRAKE HARNESS​
FIGURE 8-64. TRACTION HARNESS​
FIGURE 8-65. TURNTABLE HARNESS​
FIGURE 8-66. UPPER BOOM 110V HARNESS ASSEMBLY​
FIGURE 8-67. UPPER BOOM 220V HARNESS ASSEMBLY​
FIGURE 8-68. USB HARNESS​
FIGURE 8-69. WORKLIGHT HARNESS​
SECTION 9 - DECALS
FIGURE 9-1. DECAL INSTALLATION - ANSI, ANSI EXPORT AND UL SPECS - ENGLISH (MACHINES WITH SN STARTING WITH 03)​
FIGURE 9-2. DECAL INSTALLATION - ANSI EXPORT SPEC - ENGLISH (MACHINES WITH SN STARTING WITH B3)​
FIGURE 9-3. DECAL INSTALLATION - AUSTRALIAN SPEC​
FIGURE 9-4. DECAL INSTALLATION - CE, CHINA & & UK CA SPECS​
FIGURE 9-5. DECAL INSTALLATION - CHINESE/ENGLISH (MACHINES WITH SN STARTING WITH 03)​
FIGURE 9-6. DECAL INSTALLATION - CHINESE/ENGLISH (MACHINES WITH SN STARTING WITH B3)​
FIGURE 9-7. DECAL INSTALLATION - FRENCH/ENGLISH SPECS​
FIGURE 9-8. DECAL INSTALLATION - JAPANESE SPEC (MACHINES WITH SN STARTING WITH 03)​
FIGURE 9-9. DECAL INSTALLATION - JAPANESE SPEC (MACHINES WITH SN STARTING WITH B3)​
FIGURE 9-10. DECAL INSTALLATION - KOREAN SPEC (MACHINES WITH SN STARTING WITH 03)​
FIGURE 9-11. DECAL INSTALLATION - KOREAN SPEC (MACHINES WITH SN STARTING WITH B3)​
FIGURE 9-12. DECAL INSTALLATION - SPANISH/ENGLISH SPECS​
FIGURE 9-13. DECAL INSTALLATION - SPANISH/PORTUGUESE SPECS​
FIGURE 9-14. DECAL INSTALLATION - OPTIONS​
FIGURE 9-15. DROP BAR - FALL ARREST DECAL INSTALLATION​
SECTION 11 - SPECIAL OPTIONS
FIGURE 11-1. SPECIAL OPTIONS/ACCESORIES/KITS​
PART NUMBER INDEX
