JLG Boom Lift E450AJ Parts Catalog 31219186
Brand: JLG
Type of Machine: Boom Lift
Model: JLG E450AJ Boom Lift
Part Number: 31219186
Publication Date: 2025
Number of Pages: 428 Pages
SECTION 1 - FRAME
Brand: JLG
SECTION 1 - FRAME
FIGURE 1-1. BATTERY BOX INSTALLATION - AGM BATTERIES
FIGURE 1-2. BATTERY BOX INSTALLATION - STANDARD
FIGURE 1-3. BATTERY CHARGER INSTALLATION (ANSI EXPORT AND CHINA SPECS)
FIGURE 1-4. BATTERY CHARGER INSTALLATION (ALL SPECS EXCEPT AUSTRALIAN, CE, CHINA, RUSSIAN & UK CA SPECS)
FIGURE 1-5. BATTERY CHARGER INSTALLATION (AUSTRALIAN SPEC)
FIGURE 1-6. BATTERY CHARGER INSTALLATION (ANSI EXPORT, CE, RUSSIAN & UK CA SPECS)
FIGURE 1-7. DRIVE INSTALLATION - NON-UL SPECS
FIGURE 1-8. DRIVE INSTALLATION - UL SPECS
FIGURE 1-9. DRIVE HUB ASSEMBLY
FIGURE 1-10. DRIVE MOTOR ASSEMBLY
FIGURE 1-11. ELECTRICAL PLATE ASSEMBLY - LH (NON-UL SPECS)
FIGURE 1-12. ELECTRICAL PLATE ASSEMBLY - LH (UL SPECS)
FIGURE 1-13. ELECTRICAL PLATE ASSEMBLY - RH (NON-UL SPECS)
FIGURE 1-14. ELECTRICAL PLATE ASSEMBLY - RH (UL SPECS)
FIGURE 1-15. FRAME COVER INSTALLATION
FIGURE 1-16. INVERTER INSTALLATION
FIGURE 1-17. MOTOR/PUMP/TANK INSTALLATION - NON-UL SPECS
FIGURE 1-18. MOTOR/PUMP/TANK INSTALLATION - UL SPECS
FIGURE 1-19. MOTOR/PUMP/TANK INSTALLATION WITHOUT MOTOR BAND
FIGURE 1-20. MOTOR/PUMP/TANK INSTALLATION WITH MOTOR BAND
FIGURE 1-21. HYDRAULIC TANK ASSEMBLY (MACHINES WITH SN STARTING WITH 03)
FIGURE 1-22. HYDRAULIC TANK ASSEMBLY (MACHINES WITH SN STARTING WITH B3)
FIGURE 1-23. MOTOR/PUMP ASSEMBLY
FIGURE 1-24. STEERING INSTALLATION (MACHINES WITH SN STARTING WITH 03)
FIGURE 1-25. STEERING INSTALLATION (MACHINES WITH SN STARTING WITH B3)
FIGURE 1-26. HUB - SPINDLE ASSEMBLY - LH
FIGURE 1-27. HUB - SPINDLE ASSEMBLY - RH
FIGURE 1-28. TIRE/WHEEL - IN240/55 - 17.5 FOAM FILLED
FIGURE 1-29. TIRE/WHEEL - IN240/55-17.5 FOAM FILLED NON MARKING
FIGURE 1-30. TIRE/WHEEL - 26 X 7 X 20 - SOLID NON MARKING
FIGURE 1-31. VALVE INSTALLATION - FRAME MOUNTED
FIGURE 1-32. BRAKE/STEER VALVE ASSEMBLY
FIGURE 1-33. VOLTAGE GUARD INSTALLATION
SECTION 2 - TURNTABLEFIGURE 2-1. VALVE INSTALLATION - TURNTABLE MOUNTED
FIGURE 2-2. MAIN CONTROL VALVE ASSEMBLY
FIGURE 2-3. RELEVELING VALVE ASSEMBLY
FIGURE 2-4. JIB VALVE ASSEMBLY
FIGURE 2-5. MOTION ALARM INSTALLATION
FIGURE 2-6. TURNTABLE BEARING AND SWING DRIVE INSTALLATION
FIGURE 2-7. SWING MOTOR ASSEMBLY
FIGURE 2-8. SWING BEARING ASSEMBLY
FIGURE 2-9. REMOTE BEARING LUBE INSTALLATION - OPTIONAL
FIGURE 2-10. DRIVE ORIENTATION INSTALLATION
FIGURE 2-11. GROUND CONTROL BOX INSTALLATION (ALL SPECS EXCEPT CE, CHINA, RUSSIAN & UK CA SPECS) (Prior to SN 0300291053)
FIGURE 2-12. GROUND CONTROL BOX INSTALLATION (ALL SPECS EXCEPT CE, CHINA, RUSSIAN & UK CA SPECS) (SN 0300291053 to Present)
FIGURE 2-13. GROUND CONTROL BOX INSTALLATION (CE, CHINA, RUSSIAN & UK CA SPECS) (Prior to SN 0300291053)
FIGURE 2-14. GROUND CONTROL BOX INSTALLATION (CE, CHINA, RUSSIAN & UK CA SPECS) (SN 0300291053 to Present)
FIGURE 2-15. GROUND CONTROL BOX ELECTRICAL ASSEMBLY - DISPLAY WITH BUTTONS (ALL SPECS EXCEPT CE, CHINA, RUSSIAN & UK CA SPECS)
FIGURE 2-16. GROUND CONTROL BOX ELECTRICAL ASSEMBLY - DISPLAY WITHOUT BUTTONS (ALL SPECS EXCEPT CE, CHINA, RUSSIAN & UK CA SPECS)
FIGURE 2-17. GROUND CONTROL BOX ELECTRICAL ASSEMBLY - DISPLAY WITH BUTTONS (CE, CHINA, RUSSIAN & UK CA SPECS)
FIGURE 2-18. GROUND CONTROL BOX ELECTRICAL ASSEMBLY - DISPLAY WITHOUT BUTTONS (CE, CHINA, RUSSIAN & UK CA SPECS)
FIGURE 2-19. STROBE LIGHT INSTALLATION - AMBER
FIGURE 2-20. BEACON LIGHT INSTALLATION - BLUE
FIGURE 2-21. BEACON LIGHT INSTALLATION - RED
FIGURE 2-22. HOOD INSTALLATION
SECTION 3 - ENGINEFIGURE 3-1. KUBOTA MOTOR/GENERATOR ASSEMBLY
FIGURE 3-2. KUBOTA ENGINE COMPONENTS
SECTION 4 - BOOMFIGURE 4-1. BOOM AND CYLINDERS INSTALLATION (MACHINES WITH SN STARTING WITH 03)
FIGURE 4-2. BOOM AND CYLINDERS INSTALLATION (MACHINES WITH SN STARTING WITH B3)
FIGURE 4-3. MAIN BOOM ASSEMBLY (MACHINES WITH SN STARTING WITH 03)
FIGURE 4-4. MAIN BOOM ASSEMBLY (MACHINES WITH SN STARTING WITH B3)
FIGURE 4-5. JIB INSTALLATION (MACHINES WITH SN STARTING WITH 03)
FIGURE 4-6. JIB INSTALLATION (MACHINES WITH SN STARTING WITH B3)
FIGURE 4-7. ROTATOR ASSEMBLY
FIGURE 4-8. PLATFORM SUPPORT INSTALLATION
FIGURE 4-9. BOOM LIMIT SWITCHES INSTALLATION
SECTION 5 - PLATFORMFIGURE 5-1. PLATFORM ASSEMBLY - 4FT/1.22M - SIDE GATE ENTRY
FIGURE 5-2. PLATFORM ASSEMBLY - 5FT/1.52M - SIDE GATE ENTRY
FIGURE 5-3. PLATFORM ASSEMBLY - 4FT/1.22M - DROP BAR ENTRY
FIGURE 5-4. PLATFORM ASSEMBLY - 5FT/1.52M - DROP BAR ENTRY
FIGURE 5-5. PLATFORM ASSEMBLY - 30IN X 3FT (76CM X .91M) - DROP BAR ENTRY
FIGURE 5-6. PLATFORM ASSEMBLY - 6FT/1.83M - DROP BAR ENTRY
FIGURE 5-7. PLATFORM ASSEMBLY - 5FT/1.52M - FALL ARREST
FIGURE 5-8. PLATFORM ASSEMBLY - 6FT/1.83M - FALL ARREST
FIGURE 5-9. PLATFORM CONSOLE AND FOOTSWITCH INSTALLATION - WITH 1 CELL LSS AND WITH SKYGUARD (NON-UL SPECS)
FIGURE 5-10. PLATFORM CONSOLE AND FOOTSWITCH INSTALLATION - WITH 1 CELL LSS AND WITH SKYGUARD (UL SPECS)
FIGURE 5-11. PLATFORM CONSOLE ASSEMBLY - WITH 1 CELL LSS AND WITH SKYGUARD (NON-UL SPECS)
FIGURE 5-12. PLATFORM CONSOLE ASSEMBLY - WITH 1 CELL LSS AND WITH SKYGUARD (UL SPECS)
FIGURE 5-13. LIGHT PANEL INSTALLATION
FIGURE 5-14. JIB SWITCH INSTALLATION
FIGURE 5-15. CONTROLLER ASSEMBLY - DRIVE AND STEER
FIGURE 5-16. CONTROLLER ASSEMBLY - LIFT AND SWING
FIGURE 5-17. FOOTSWITCH ASSEMBLY
FIGURE 5-18. USB CHARGER INSTALLATION
FIGURE 5-19. TRAY ASSEMBLY
FIGURE 5-20. SKYEYE INSTALLATION
FIGURE 5-21. SKYGUARD BAR INSTALLATION
FIGURE 5-22. SKYLINE INSTALLATION
FIGURE 5-23. SKYSENSE MID TUBE SENSOR ASSEMBLY
FIGURE 5-24. SKYSENSE OVERHEAD SENSOR ASSEMBLY
FIGURE 5-25. SOFT-TOUCH INSTALLATION
SECTION 6 - CYLINDERFIGURE 6-1. LEVEL (PLATFORM SLAVE) CYLINDER ASSEMBLY (MACHINES WITH SN STARTING WITH 03)
FIGURE 6-2. LEVEL (PLATFORM SLAVE) CYLINDER ASSEMBLY (MACHINES WITH SN STARTING WITH B3)
FIGURE 6-3. LIFT CYLINDER ASSEMBLY - JIB (MACHINES WITH SN STARTING WITH 03)
FIGURE 6-4. LIFT CYLINDER ASSEMBLY - JIB (MACHINES WITH SN STARTING WITH B3)
FIGURE 6-5. LIFT CYLINDER ASSEMBLY - LOWER (MACHINES WITH SN STARTING WITH 03) (Prior to SN 0300292776, SN 0300321238 through 0300321245, SN 0300321447 through 0300321781, Prior to SN B300002463, Except SN 0300286744 through 0300286748, Including 0300...
FIGURE 6-6. LIFT CYLINDER ASSEMBLY - LOWER (MACHINES WITH SN STARTING WITH 03) (SN 0300286744 through 0300286748, SN 0300293054 through 0300320938, SN 0300320940 through 0300320945, SN 0300321246 through 0300321248, SN 0300321250 to Present, SN B30000...
FIGURE 6-7. LIFT CYLINDER ASSEMBLY - LOWER (MACHINES WITH SN STARTING WITH B3)
FIGURE 6-8. LIFT CYLINDER ASSEMBLY - MID (MACHINES WITH SN STARTING WITH 03) (Prior to SN 0300291339, SN 0300291343 through 0300291672, SN 0300291677 through 0300291682, Prior to SN B300002463, Except SN 0300286741 through 0300286748, Including 030029...
FIGURE 6-9. LIFT CYLINDER ASSEMBLY - MID (MACHINES WITH SN STARTING WITH 03) (SN 0300286741 through 0300286748, SN 0300291676 to Present, SN B300002463 to Present, Except SN 0300291677 through 0300291682, Including 0300291339, 0300291342 and 0300291673)
FIGURE 6-10. LIFT CYLINDER ASSEMBLY - MID (MACHINES WITH SN STARTING WITH B3)
FIGURE 6-11. LIFT CYLINDER ASSEMBLY - UPPER (MACHINES WITH SN STARTING WITH 03)
FIGURE 6-12. LIFT CYLINDER ASSEMBLY - UPPER (MACHINES WITH SN STARTING WITH B3)
FIGURE 6-13. MASTER CYLINDER ASSEMBLY (MACHINES WITH SN STARTING WITH 03)
FIGURE 6-14. MASTER CYLINDER ASSEMBLY (MACHINES WITH SN STARTING WITH B3)
FIGURE 6-15. STEER CYLINDER ASSEMBLY (MACHINES WITH SN STARTING WITH 03)
FIGURE 6-16. STEER CYLINDER ASSEMBLY (MACHINES WITH SN STARTING WITH B3)
FIGURE 6-17. TELESCOPE CYLINDER ASSEMBLY (MACHINES WITH SN STARTING WITH 03)
FIGURE 6-18. TELESCOPE CYLINDER ASSEMBLY (MACHINES WITH SN STARTING WITH B3)
FIGURE 6-19. COUNTERBALANCE VALVE ASSEMBLY
SECTION 7 - HYDRAULICFIGURE 7-1. HYDRAULIC DIAGRAM
SECTION 8 - ELECTRICALFIGURE 8-1. AC PLUGS AND SOCKETS INSTALLATION - AFSINT 107-2-01 KEYED GROUND - 2 X 4 BOX (CE & UK CA SPEC)
FIGURE 8-2. AC PLUGS AND SOCKETS INSTALLATION - CEE7 POST GROUND (CE & UK CA SPEC)
FIGURE 8-3. AC PLUGS AND SOCKETS INSTALLATION - CEE 7 SIDE GROUND (CE & UK CA SPEC)
FIGURE 8-4. AC PLUGS AND SOCKETS INSTALLATION - CEE7 POST GROUND - 2 X 4 BOX (CE & UK CA SPEC)
FIGURE 8-5. AC PLUGS AND SOCKETS INSTALLATION - CEE7 SIDE GROUND - 2 X 4 BOX (CE & UK CA SPEC)
FIGURE 8-6. AC PLUGS AND SOCKETS INSTALLATION - IEC 60309 BLUE (CE & UK CA SPEC)
FIGURE 8-7. AC PLUGS AND SOCKETS INSTALLATION - IEC 60309 YELLOW (CE & UK CA SPEC)
FIGURE 8-8. BATTERY CABLE KIT (NON-UL SPECS)
FIGURE 8-9. BATTERY CABLE KIT (UL SPECS)
FIGURE 8-10. BOOM CABLE - LOWER
FIGURE 8-11. BOOM CABLE - UPPER
FIGURE 8-12. BOOM LIMIT SWITCH HARNESS - LOWER
FIGURE 8-13. BOOM LIMIT SWITCH HARNESS - UPPER
FIGURE 8-14. BREAKER BOX KIT WITH ONE BREAKERS - CE & UK CA SPEC
FIGURE 8-15. BREAKER BOX KIT WITH TWO BREAKERS - CE & UK CA SPEC
FIGURE 8-16. CABLES AND CLAMPS INSTALLATION
FIGURE 8-17. CHARGER HARNESS
FIGURE 8-18. CHARGER CORD PLUG INSTALLATION - 110V - IEC 60309 - YELLOW (CE & UK CA SPEC)
FIGURE 8-19. CHARGER CORD PLUG INSTALLATION - 220V - AFSINT 107 KEYED GROUND (CE & UK CA SPEC)
FIGURE 8-20. CHARGER CORD PLUG INSTALLATION - 220V - CEE7 POST GROUND (CE & UK CA SPEC)
FIGURE 8-21. CHARGER CORD PLUG INSTALLATION - 220V - CEE7 SIDE GROUND (CE & UK CA SPEC)
FIGURE 8-22. CHARGER CORD PLUG INSTALLATION - 220V - IEC 60309 - BLUE (CE & UK CA SPEC)
FIGURE 8-23. CHARGER DC CONNECTION HARNESS
FIGURE 8-24. CHARGER EBOOM HARNESS
FIGURE 8-25. CHASSIS TO TURNTABLE HARNESS
FIGURE 8-26. GROUND CONTROL PANEL HARNESS
FIGURE 8-27. INVERTER HARNESS
FIGURE 8-28. INVERTER IGNITION HARNESS
FIGURE 8-29. LOWER BOOM 110V HARNESS ASSEMBLY
FIGURE 8-30. LOWER BOOM 220V HARNESS ASSEMBLY
FIGURE 8-31. PLATFORM CONSOLE HARNESS - WITH 1 CELL LSS (UL SPECS)
FIGURE 8-32. PLATFORM CONSOLE HARNESS - WITH 1 CELL LSS (NON-UL SPECS)
FIGURE 8-33. PLUG AND RECEPTACLE INSTALLATION - SUPPLIED LOCALLY
FIGURE 8-34. PLUG AND RECEPTACLE INSTALLATION - 110V
FIGURE 8-35. PLUG AND RECEPTACLE INSTALLATION - 220V
FIGURE 8-36. PLUG AND RECEPTACLE 110V INSTALLATION - IEC 60309 - YELLOW (CE & UK CA SPEC)
FIGURE 8-37. PLUG AND RECEPTACLE 220V INSTALLATION - AFSINT 107 KEYED GROUND - 2 X 4 BOX (CE & UK CA SPEC)
FIGURE 8-38. PLUG AND RECEPTACLE 220V INSTALLATION - CEE7 POST GROUND - 2 X 4 BOX (CE & UK CA SPEC)
FIGURE 8-39. PLUG AND RECEPTACLE 220V INSTALLATION - CEE7 POST GROUND - 70MM X 70MM BOX (CE & UK CA SPEC)
FIGURE 8-40. PLUG AND RECEPTACLE 220 INSTALLATION - CEE7 SIDE GROUND - 2 X 4 BOX (CE & UK CA SPEC)
FIGURE 8-41. PLUG AND RECEPTACLE 220V INSTALLATION - CEE7 SIDE GROUND - 70MM X 70MM BOX (CE & UK CA SPEC)
FIGURE 8-42. PLUG AND RECEPTACLE 220V INSTALLATION - IEC 60309 - BLUE (CE & UK CA SPEC)
FIGURE 8-43. SKYEYE INTERMEDIATE HARNESS
FIGURE 8-44. SKYEYE RECEIVER HARNESS
FIGURE 8-45. SKYEYE EMITTER HARNESS
FIGURE 8-46. SKYGUARD HARNESS - WITH 1 CELL LSS
FIGURE 8-47. SKYLINE HARNESS
FIGURE 8-48. STEER/BRAKE HARNESS
FIGURE 8-49. TRACTION HARNESS
FIGURE 8-50. TURNTABLE HARNESS
FIGURE 8-51. UPPER BOOM 110V HARNESS ASSEMBLY
FIGURE 8-52. UPPER BOOM 220V HARNESS ASSEMBLY
FIGURE 8-53. VALVE HARNESS
SECTION 9 - DECALSFIGURE 9-1. DECAL INSTALLATION - ANSI, ANSI EXPORT AND UL SPECS - ENGLISH (MACHINES WITH SN STARTING WITH 03)
FIGURE 9-2. DECAL INSTALLATION - ANSI EXPORT SPEC - ENGLISH (MACHINES WITH SN STARTING WITH B3)
FIGURE 9-3. DECAL INSTALLATION - AUSTRALIAN SPEC
FIGURE 9-4. DECAL INSTALLATION - CE, CHINA & & UK CA SPECS
FIGURE 9-5. DECAL INSTALLATION - CHINESE/ENGLISH (MACHINES WITH SN STARTING WITH 03)
FIGURE 9-6. DECAL INSTALLATION - CHINESE/ENGLISH (MACHINES WITH SN STARTING WITH B3)
FIGURE 9-7. DECAL INSTALLATION - FRENCH/ENGLISH SPECS
FIGURE 9-8. DECAL INSTALLATION - JAPANESE SPEC (MACHINES WITH SN STARTING WITH 03)
FIGURE 9-9. DECAL INSTALLATION - JAPANESE SPEC (MACHINES WITH SN STARTING WITH B3)
FIGURE 9-10. DECAL INSTALLATION - KOREAN SPEC (MACHINES WITH SN STARTING WITH 03)
FIGURE 9-11. DECAL INSTALLATION - KOREAN SPEC (MACHINES WITH SN STARTING WITH B3)
FIGURE 9-12. DECAL INSTALLATION - SPANISH/ENGLISH SPECS
FIGURE 9-13. DECAL INSTALLATION - SPANISH/PORTUGUESE SPECS
FIGURE 9-14. DECAL INSTALLATION - OPTIONS
SECTION 11 - SPECIAL OPTIONSFIGURE 11-1. SPECIAL OPTIONS/ACCESORIES/KITS
PART NUMBER INDEX
- SuperPac Parts Manual
- StratoLift Parts Manual
