JLG Boom Lift E450AJ Parts Catalog 31217479
Brand: JLG
Type of Machine: Boom Lift
Model: JLG E450AJ Boom Lift
Part Number: 31217479
Publication Date: 2025
Number of Pages: 424 Pages
SECTION 1 - FRAME
Brand: JLG
SECTION 1 - FRAME
FIGURE 1-1. BATTERY BOX INSTALLATION - AGM BATTERIES (ALL SPECS EXCEPT AUSTRALIAN CE, CHINA, RUSSIAN & UK CA SPECS)
FIGURE 1-2. BATTERY BOX INSTALLATION - AGM BATTERIES (AUSTRALIAN, CE, CHINA, RUSSIAN & UK CA SPECS)
FIGURE 1-3. BATTERY BOX INSTALLATION - STANDARD (ALL SPECS EXCEPT AUSTRALIAN, CE, CHINA, RUSSIAN & UK CA SPECS)
FIGURE 1-4. BATTERY BOX INSTALLATION - STANDARD (AUSTRALIAN, CE, CHINA, RUSSIAN & UK CA SPECS)
FIGURE 1-5. BATTERY CHARGER INSTALLATION (ANSI EXPORT AND CHINA SPECS)
FIGURE 1-6. BATTERY CHARGER INSTALLATION (ALL SPECS EXCEPT AUSTRALIAN, CE, CHINA, RUSSIAN & UK CA SPECS)
FIGURE 1-7. BATTERY CHARGER INSTALLATION (AUSTRALIAN SPEC)
FIGURE 1-8. BATTERY CHARGER INSTALLATION (ANSI EXPORT, CE, RUSSIAN & UK CA SPECS)
FIGURE 1-9. DRIVE INSTALLATION - NON-UL SPECS
FIGURE 1-10. DRIVE INSTALLATION - UL SPECS
FIGURE 1-11. DRIVE HUB ASSEMBLY
FIGURE 1-12. DRIVE MOTOR ASSEMBLY
FIGURE 1-13. ELECTRICAL PLATE ASSEMBLY - LH (NON-UL SPECS)
FIGURE 1-14. ELECTRICAL PLATE ASSEMBLY - LH (UL SPECS)
FIGURE 1-15. ELECTRICAL PLATE ASSEMBLY - RH (NON-UL SPECS)
FIGURE 1-16. ELECTRICAL PLATE ASSEMBLY - RH (UL SPECS)
FIGURE 1-17. FRAME COVER INSTALLATION
FIGURE 1-18. INVERTER INSTALLATION
FIGURE 1-19. MOTOR/PUMP/TANK INSTALLATION - NON-UL SPECS
FIGURE 1-20. MOTOR/PUMP/TANK INSTALLATION - UL SPECS
FIGURE 1-21. MOTOR/PUMP/TANK INSTALLATION - CHINA SPEC ONLY (SN 0300287224 to Present, Including B300013060, Excluding 0300282040, B300012454 and B300012485)
FIGURE 1-22. HYDRAULIC TANK ASSEMBLY
FIGURE 1-23. MOTOR/PUMP ASSEMBLY
FIGURE 1-24. STEERING INSTALLATION (MACHINES WITH SN STARTING WITH 03)
FIGURE 1-25. STEERING INSTALLATION (MACHINES WITH SN STARTING WITH B3)
FIGURE 1-26. HUB - SPINDLE ASSEMBLY - LH
FIGURE 1-27. HUB - SPINDLE ASSEMBLY - RH
FIGURE 1-28. TIRE/WHEEL - IN240/55 - 17.5 FOAM FILLED
FIGURE 1-29. TIRE/WHEEL - IN240/55-17.5 FOAM FILLED NON MARKING
FIGURE 1-30. TIRE/WHEEL - 26 X 7 X 20 - SOLID NON MARKING
FIGURE 1-31. VALVE INSTALLATION - FRAME MOUNTED
FIGURE 1-32. BRAKE/STEER VALVE ASSEMBLY
FIGURE 1-33. VOLTAGE GUARD INSTALLATION
SECTION 2 - TURNTABLEFIGURE 2-1. VALVE INSTALLATION - TURNTABLE MOUNTED
FIGURE 2-2. MAIN CONTROL VALVE ASSEMBLY
FIGURE 2-3. RELEVELING VALVE ASSEMBLY
FIGURE 2-4. JIB VALVE ASSEMBLY
FIGURE 2-5. MOTION ALARM INSTALLATION
FIGURE 2-6. TURNTABLE BEARING AND SWING DRIVE INSTALLATION
FIGURE 2-7. SWING MOTOR ASSEMBLY
FIGURE 2-8. SWING BEARING ASSEMBLY
FIGURE 2-9. REMOTE BEARING LUBE INSTALLATION - OPTIONAL
FIGURE 2-10. DRIVE ORIENTATION INSTALLATION
FIGURE 2-11. GROUND CONTROL BOX INSTALLATION (ALL SPECS EXCEPT CE, CHINA, RUSSIAN & UK CA SPECS)
FIGURE 2-12. GROUND CONTROL BOX INSTALLATION (CE, CHINA, RUSSIAN & UK CA SPECS)
FIGURE 2-13. GROUND CONTROL BOX ELECTRICAL ASSEMBLY - DISPLAY WITH BUTTONS (ALL SPECS EXCEPT CE, CHINA, RUSSIAN & UK CA SPECS)
FIGURE 2-14. GROUND CONTROL BOX ELECTRICAL ASSEMBLY - DISPLAY WITHOUT BUTTONS (ALL SPECS EXCEPT CE, CHINA, RUSSIAN & UK CA SPECS)
FIGURE 2-15. GROUND CONTROL BOX ELECTRICAL ASSEMBLY - DISPLAY WITH BUTTONS (CE, CHINA, RUSSIAN & UK CA SPECS)
FIGURE 2-16. GROUND CONTROL BOX ELECTRICAL ASSEMBLY - DISPLAY WITHOUT BUTTONS (CE, CHINA, RUSSIAN & UK CA SPECS)
FIGURE 2-17. STROBE LIGHT INSTALLATION - AMBER
FIGURE 2-18. BEACON LIGHT INSTALLATION - BLUE
FIGURE 2-19. BEACON LIGHT INSTALLATION - RED
FIGURE 2-20. HOOD INSTALLATION
SECTION 3 - ENGINEFIGURE 3-1. KUBOTA MOTOR/GENERATOR ASSEMBLY
FIGURE 3-2. KUBOTA ENGINE COMPONENTS
SECTION 4 - BOOMFIGURE 4-1. BOOM AND CYLINDERS INSTALLATION (MACHINES WITH SN STARTING WITH 03)
FIGURE 4-2. BOOM AND CYLINDERS INSTALLATION (MACHINES WITH SN STARTING WITH B3)
FIGURE 4-3. MAIN BOOM ASSEMBLY (MACHINES WITH SN STARTING WITH 03)
FIGURE 4-4. MAIN BOOM ASSEMBLY (MACHINES WITH SN STARTING WITH B3)
FIGURE 4-5. JIB INSTALLATION (MACHINES WITH SN STARTING WITH 03)
FIGURE 4-6. JIB INSTALLATION (MACHINES WITH SN STARTING WITH B3)
FIGURE 4-7. ROTATOR ASSEMBLY
FIGURE 4-8. PLATFORM SUPPORT INSTALLATION
FIGURE 4-9. BOOM LIMIT SWITCHES INSTALLATION
SECTION 5 - PLATFORMFIGURE 5-1. PLATFORM ASSEMBLY - 4FT/1.22M - SIDE GATE ENTRY
FIGURE 5-2. PLATFORM ASSEMBLY - 5FT/1.52M - SIDE GATE ENTRY
FIGURE 5-3. PLATFORM ASSEMBLY - 4FT/1.22M - DROP BAR ENTRY
FIGURE 5-4. PLATFORM ASSEMBLY - 5FT/1.52M - DROP BAR ENTRY
FIGURE 5-5. PLATFORM ASSEMBLY - 30IN X 3FT (76CM X .91M) - DROP BAR ENTRY
FIGURE 5-6. PLATFORM ASSEMBLY - 6FT/1.83M - DROP BAR ENTRY
FIGURE 5-7. PLATFORM ASSEMBLY - 5FT/1.52M - FALL ARREST
FIGURE 5-8. PLATFORM ASSEMBLY - 6FT/1.83M - FALL ARREST
FIGURE 5-9. PLATFORM CONSOLE AND FOOTSWITCH INSTALLATION - WITH 1 CELL LSS AND WITH SKYGUARD (NON-UL SPECS)
FIGURE 5-10. PLATFORM CONSOLE AND FOOTSWITCH INSTALLATION - WITH 1 CELL LSS AND WITH SKYGUARD (UL SPECS)
FIGURE 5-11. PLATFORM CONSOLE ASSEMBLY - WITH 1 CELL LSS AND WITH SKYGUARD (NON-UL SPECS)
FIGURE 5-12. PLATFORM CONSOLE ASSEMBLY - WITH 1 CELL LSS AND WITH SKYGUARD (UL SPECS)
FIGURE 5-13. LIGHT PANEL INSTALLATION
FIGURE 5-14. JIB SWITCH INSTALLATION
FIGURE 5-15. CONTROLLER ASSEMBLY - DRIVE AND STEER
FIGURE 5-16. CONTROLLER ASSEMBLY - LIFT AND SWING
FIGURE 5-17. FOOTSWITCH ASSEMBLY
FIGURE 5-18. USB CHARGER INSTALLATION
FIGURE 5-19. TRAY ASSEMBLY
FIGURE 5-20. SKYEYE INSTALLATION
FIGURE 5-21. SKYGUARD BAR INSTALLATION
FIGURE 5-22. SKYLINE INSTALLATION
FIGURE 5-23. SKYSENSE MID TUBE SENSOR ASSEMBLY
FIGURE 5-24. SKYSENSE OVERHEAD SENSOR ASSEMBLY
FIGURE 5-25. PIPE RACK INSTALLATION
FIGURE 5-26. SOFT-TOUCH INSTALLATION
SECTION 6 - CYLINDERFIGURE 6-1. LEVEL (PLATFORM SLAVE) CYLINDER ASSEMBLY (MACHINES WITH SN STARTING WITH 03)
FIGURE 6-2. LEVEL (PLATFORM SLAVE) CYLINDER ASSEMBLY (MACHINES WITH SN STARTING WITH B3)
FIGURE 6-3. LIFT CYLINDER ASSEMBLY - JIB (MACHINES WITH SN STARTING WITH 03)
FIGURE 6-4. LIFT CYLINDER ASSEMBLY - JIB (MACHINES WITH SN STARTING WITH B3)
FIGURE 6-5. LIFT CYLINDER ASSEMBLY - LOWER (MACHINES WITH SN STARTING WITH 03)
FIGURE 6-6. LIFT CYLINDER ASSEMBLY - LOWER (MACHINES WITH SN STARTING WITH B3)
FIGURE 6-7. LIFT CYLINDER ASSEMBLY - MID (MACHINES WITH SN STARTING WITH 03)
FIGURE 6-8. LIFT CYLINDER ASSEMBLY - MID (MACHINES WITH SN STARTING WITH B3)
FIGURE 6-9. LIFT CYLINDER ASSEMBLY - UPPER (MACHINES WITH SN STARTING WITH 03)
FIGURE 6-10. LIFT CYLINDER ASSEMBLY - UPPER (MACHINES WITH SN STARTING WITH B3)
FIGURE 6-11. MASTER CYLINDER ASSEMBLY (MACHINES WITH SN STARTING WITH 03)
FIGURE 6-12. MASTER CYLINDER ASSEMBLY (MACHINES WITH SN STARTING WITH B3)
FIGURE 6-13. STEER CYLINDER ASSEMBLY (MACHINES WITH SN STARTING WITH 03)
FIGURE 6-14. STEER CYLINDER ASSEMBLY (MACHINES WITH SN STARTING WITH B3)
FIGURE 6-15. TELESCOPE CYLINDER ASSEMBLY (MACHINES WITH SN STARTING WITH 03)
FIGURE 6-16. TELESCOPE CYLINDER ASSEMBLY (MACHINES WITH SN STARTING WITH B3)
FIGURE 6-17. COUNTERBALANCE VALVE ASSEMBLY
SECTION 7 - HYDRAULICFIGURE 7-1. HYDRAULIC DIAGRAM
SECTION 8 - ELECTRICALFIGURE 8-1. AC PLUGS AND SOCKETS INSTALLATION - AFSINT 107-2-01 KEYED GROUND - 2 X 4 BOX (CE & UK CA SPEC)
FIGURE 8-2. AC PLUGS AND SOCKETS INSTALLATION - CEE7 POST GROUND (CE & UK CA SPEC)
FIGURE 8-3. AC PLUGS AND SOCKETS INSTALLATION - CEE 7 SIDE GROUND (CE & UK CA SPEC)
FIGURE 8-4. AC PLUGS AND SOCKETS INSTALLATION - CEE7 POST GROUND - 2 X 4 BOX (CE & UK CA SPEC)
FIGURE 8-5. AC PLUGS AND SOCKETS INSTALLATION - CEE7 SIDE GROUND - 2 X 4 BOX (CE & UK CA SPEC)
FIGURE 8-6. AC PLUGS AND SOCKETS INSTALLATION - IEC 60309 BLUE (CE & UK CA SPEC)
FIGURE 8-7. AC PLUGS AND SOCKETS INSTALLATION - IEC 60309 YELLOW (CE & UK CA SPEC)
FIGURE 8-8. BATTERY CABLE KIT (NON-UL SPECS)
FIGURE 8-9. BATTERY CABLE KIT (UL SPECS)
FIGURE 8-10. BLUETOOTH MODULE INSTALLATION
FIGURE 8-11. BLUETOOTH MODULE HARNESS
FIGURE 8-12. BOOM CABLE - LOWER
FIGURE 8-13. BOOM CABLE - UPPER
FIGURE 8-14. BOOM LIMIT SWITCH HARNESS - LOWER
FIGURE 8-15. BOOM LIMIT SWITCH HARNESS - UPPER
FIGURE 8-16. BREAKER BOX KIT WITH ONE BREAKERS - CE & UK CA SPEC
FIGURE 8-17. BREAKER BOX KIT WITH TWO BREAKERS - CE & UK CA SPEC
FIGURE 8-18. CABLES AND CLAMPS INSTALLATION
FIGURE 8-19. CHARGER HARNESS
FIGURE 8-20. CHARGER CORD PLUG INSTALLATION - 110V - IEC 60309 - YELLOW (CE & UK CA SPEC)
FIGURE 8-21. CHARGER CORD PLUG INSTALLATION - 220V - AFSINT 107 KEYED GROUND (CE & UK CA SPEC)
FIGURE 8-22. CHARGER CORD PLUG INSTALLATION - 220V - CEE7 POST GROUND (CE & UK CA SPEC)
FIGURE 8-23. CHARGER CORD PLUG INSTALLATION - 220V - CEE7 SIDE GROUND (CE & UK CA SPEC)
FIGURE 8-24. CHARGER CORD PLUG INSTALLATION - 220V - IEC 60309 - BLUE (CE & UK CA SPEC)
FIGURE 8-25. CHARGER DC CONNECTION HARNESS
FIGURE 8-26. CHARGER EBOOM HARNESS
FIGURE 8-27. CHASSIS TO TURNTABLE HARNESS
FIGURE 8-28. GROUND CONTROL PANEL HARNESS
FIGURE 8-29. INVERTER HARNESS
FIGURE 8-30. INVERTER IGNITION HARNESS
FIGURE 8-31. LOWER BOOM 110V HARNESS ASSEMBLY
FIGURE 8-32. LOWER BOOM 220V HARNESS ASSEMBLY
FIGURE 8-33. PLATFORM CONSOLE HARNESS - WITH 1 CELL LSS (UL SPECS)
FIGURE 8-34. PLATFORM CONSOLE HARNESS - WITH 1 CELL LSS (NON-UL SPECS)
FIGURE 8-35. PLUG AND RECEPTACLE INSTALLATION - SUPPLIED LOCALLY
FIGURE 8-36. PLUG AND RECEPTACLE INSTALLATION - 110V
FIGURE 8-37. PLUG AND RECEPTACLE INSTALLATION - 220V
FIGURE 8-38. PLUG AND RECEPTACLE 110V INSTALLATION - IEC 60309 - YELLOW (CE & UK CA SPEC)
FIGURE 8-39. PLUG AND RECEPTACLE 220V INSTALLATION - AFSINT 107 KEYED GROUND - 2 X 4 BOX (CE & UK CA SPEC)
FIGURE 8-40. PLUG AND RECEPTACLE 220V INSTALLATION - CEE7 POST GROUND - 2 X 4 BOX (CE & UK CA SPEC)
FIGURE 8-41. PLUG AND RECEPTACLE 220V INSTALLATION - CEE7 POST GROUND - 70MM X 70MM BOX (CE & UK CA SPEC)
FIGURE 8-42. PLUG AND RECEPTACLE 220 INSTALLATION - CEE7 SIDE GROUND - 2 X 4 BOX (CE & UK CA SPEC)
FIGURE 8-43. PLUG AND RECEPTACLE 220V INSTALLATION - CEE7 SIDE GROUND - 70MM X 70MM BOX (CE & UK CA SPEC)
FIGURE 8-44. PLUG AND RECEPTACLE 220V INSTALLATION - IEC 60309 - BLUE (CE & UK CA SPEC)
FIGURE 8-45. SKYEYE INTERMEDIATE HARNESS
FIGURE 8-46. SKYEYE RECEIVER HARNESS
FIGURE 8-47. SKYEYE EMITTER HARNESS
FIGURE 8-48. SKYGUARD HARNESS - WITH 1 CELL LSS
FIGURE 8-49. SKYLINE HARNESS
FIGURE 8-50. STEER/BRAKE HARNESS
FIGURE 8-51. TRACTION HARNESS
FIGURE 8-52. TURNTABLE HARNESS
FIGURE 8-53. UPPER BOOM 110V HARNESS ASSEMBLY
FIGURE 8-54. UPPER BOOM 220V HARNESS ASSEMBLY
FIGURE 8-55. VALVE HARNESS
SECTION 9 - DECALSFIGURE 9-1. DECAL INSTALLATION - ANSI, ANSI EXPORT AND UL SPECS - ENGLISH (MACHINES WITH SN STARTING WITH 03)
FIGURE 9-2. DECAL INSTALLATION - ANSI EXPORT SPEC - ENGLISH (MACHINES WITH SN STARTING WITH B3)
FIGURE 9-3. DECAL INSTALLATION - AUSTRALIAN SPEC
FIGURE 9-4. DECAL INSTALLATION - CE, CHINA & & UK CA SPECS
FIGURE 9-5. DECAL INSTALLATION - CHINESE/ENGLISH (MACHINES WITH SN STARTING WITH 03)
FIGURE 9-6. DECAL INSTALLATION - CHINESE/ENGLISH (MACHINES WITH SN STARTING WITH B3)
FIGURE 9-7. DECAL INSTALLATION - FRENCH/ENGLISH SPECS
FIGURE 9-8. DECAL INSTALLATION - JAPANESE SPEC (MACHINES WITH SN STARTING WITH 03)
FIGURE 9-9. DECAL INSTALLATION - JAPANESE SPEC (MACHINES WITH SN STARTING WITH B3)
FIGURE 9-10. DECAL INSTALLATION - KOREAN SPEC (MACHINES WITH SN STARTING WITH 03)
FIGURE 9-11. DECAL INSTALLATION - KOREAN SPEC (MACHINES WITH SN STARTING WITH B3)
FIGURE 9-12. DECAL INSTALLATION - SPANISH/ENGLISH SPECS
FIGURE 9-13. DECAL INSTALLATION - SPANISH/PORTUGUESE SPECS
FIGURE 9-14. DECAL INSTALLATION - OPTIONS
SECTION 11 - SPECIAL OPTIONS/ACCESSORIES/KITSFIGURE 11-1. SPECIAL OPTIONS/ACCESORIES/KITS
PART NUMBER INDEX
- SuperPac Parts Manual
- StratoLift Parts Manual
