JLG Boom Lift E400Anarrow, E400AJPnarrow Service & Maintenance Manual 3122568400 2026
Brand: JLG
Type of Machine: Boom Lift
Model: JLG E400Anarrow, E400AJPnarrow Boom Lift
Part Number: 3122568400
Publication Date: 2026
Number of Pages: 638 Pages
Cover Page
Safety
Brand: JLG
Cover Page
Safety
General
1.1.1 Disclaimer
1.1.2 Operation & Safety Manual
Safety Information
1.2.1 Safety Alert System and Signal Words
Safety Hazards
1.3.1 Personal Hazards
1.3.2 Equipment Hazards
1.3.3 General Hazards
1.3.4 Operational Hazards
Safety Decals
Machine Verification
General Machine Information and SpecificationsSpecifications
2.1.1 Machine Specifications
2.1.2 Machine Dimensional Data
2.1.3 Tires
2.1.4 Critical Stability Weights
2.1.5 Torque Specifications
2.1.6 Major Component Weights
Machine Temperature Chart
Serial Number Location
Fluids and Lubrication
2.4.1 General Information
2.4.2 Hydraulic Oil
2.4.3 Changing Hydraulic Oil
2.4.4 Lubrication Specifications
2.4.5 Fluids
2.4.6 Capacities
2.4.7 Lubrication Schedule
Clearsky Smart Fleet (If Equipped)
2.5.1 General
2.5.2 ClearSky Smart Fleet™ — Access Control
Maintenance and Inspection SchedulesMachine Preparation, Inspection, and Maintenance
3.1.1 General
3.1.2 Preparation, Inspection, and Maintenance
3.1.3 Pre-Start Inspection
3.1.4 Pre-Delivery Inspection and Frequent Inspection
3.1.5 Annual Machine Inspection
3.1.6 Preventive Maintenance
Service and Guidelines
3.2.1 General
3.2.2 Safety and Workmanship
3.2.3 Cleanliness
3.2.4 Components Removal and Installation
3.2.5 Component Disassembly and Reassembly
3.2.6 Pressure-Fit Parts
3.2.7 Bearings
3.2.8 Gaskets
3.2.9 Bolt Usage and Torque Application
3.2.10 Hydraulic Lines and Electrical Wiring
3.2.11 Hydraulic System
3.2.12 Lubrication
3.2.13 Battery
3.2.14 Welding on JLG Equipment
Preventive Maintenance and Inspection Schedule
3.3.1 First 50 Hours and Every 6 Months or 300 Hours
3.3.2 Every 150 Hours or 3 Months
3.3.3 Every 1200 Hours or 2 Years
Pins and Composite Bearing Repair Guidelines
Tires and Wheels
3.5.1 Tire Inflation
3.5.2 Tire Damage
Boom Inspection and Maintenance
3.6.1 Boom Cleanliness Guidelines
3.6.2 Wear Pads
3.6.3 Boom Limit Switches
Turntable Bearing Inspection
3.7.1 Turntable Bearing Mounting Bolt Condition Check
3.7.2 Wear Tolerance
Battery Maintenance and Charging (task)
3.8.1 Battery Maintenance, Quarterly
3.8.2 Battery Charging (On Board Charger)
Battery Charger
3.9.1 Operating Instructions
3.9.2 Maintenance Instructions
3.9.3 Delta-Q - Battery Charger
3.9.4 Excessive Battery Watering Requirements or Strong Sulphur (Rotten Egg) Smell
3.9.5 Checking/Changing the Battery Charger Algorithm
Testing, Calibrations and Special ProceduresSpecial Tools
4.1.1 Multimeter Basics
4.1.2 Threadlocking Compound
4.1.3 Tools Catalog
Testing Procedures
4.2.1 SkyGuard
4.2.2 Diagnostics and Troubleshooting
4.2.3 LSS Testing and Evaluation
4.2.4 Troubleshooting
Calibration Procedures
4.3.1 JLG Analyzer
4.3.2 Calibration Preparation
4.3.3 Load Sensing System Calibration
4.3.4 Calibrating Steer
4.3.5 Calibrating Tilt Sensor
4.3.6 Calibrating Load Sensing
Special Procedure
4.4.1 Drive Cutout Override Service Mode
4.4.2 Cylinder Drift
4.4.3 Cylinder Leakage Test
4.4.4 Cylinder Thermal Drift
Wheel Drive Hub
4.5.1 Roll and Leak Testing
4.5.2 Tightening and Torquing Bolts
System SoftwareLoad Sensing System (LSS)
5.1.1 Theory of Operation
5.1.2 Load Sensing Gauge Removal/ Installation
JLG Analyzer
5.2.1 Machine Data Access
5.2.2 Hand Held Analyzer
5.2.3 Mobile Analyzer
5.2.4 Analyzer Flow Chart
Analyzer Software Accessibility
5.3.1 Analyzer Diagnostics Menu Structure
5.3.2 System Self Test
5.3.3 Machine Set-Up
5.3.4 Machine Personality Settings
Function Test
5.4.1 Machine Orientation When Performing Test
ClearSky (CS550) Configuration and Troubleshooting
5.5.1 ClearSky Smart FleetTM CS550 Configuration
5.5.2 Troubleshooting
Fault CodesFault Codes Introduction
Machine Fault Codes
6.2.1 Help Descriptions and Fault Flash Codes
6.2.2 General
6.2.3 ClearSky Smart Fleet DTC Fault Codes
ClearSky CS550 Troubleshooting Procedures
HydraulicsGeneral Information and Safety
Theories of Operation
7.2.1 Cylinders
7.2.2 Valves
Hydraulic Components
7.3.1 Pressure Setting Procedures
Torque Values
7.4.1 Valve Torque Specifications
Standard Hydraulic Diagram- Boom And Turntable
ElectricalsGeneral Information
8.1.1 Applying Silicone Dielectric Compound to Electrical Connections
8.1.2 Dielectric Grease Application
Electrical Connectors
8.2.1 Deutsch Connectors
Electrical Component Terminology
Harness Layouts
Board Layouts
8.5.1 Power Module - LH
8.5.2 Power Module - RH
8.5.3 Ground Control Module
8.5.4 Platform Control Module
8.5.5 Platform Control Module — UL
Checking Switches
8.6.1 Basic Check
8.6.2 Limit Switches
8.6.3 Automatic Switches
8.6.4 Switch Wiring - Low Side, High Side
8.6.5 Tilt Module
8.6.6 Speed Sensor
AMP Connector
8.7.1 Applying Silicone Dielectric Compound to AMP Connectors
8.7.2 Assembly
8.7.3 Disassembly
8.7.4 Wedge Lock
8.7.5 Service - Voltage Reading
Wiring Harness and Connector Label Diagrams
8.8.1 Connector Labels
8.8.2 Component Labels
Removal and InstallationWheel and Tire
Chassis/Frame Assembly
9.2.1 Axle and Drive Assemblies Troubleshooting
9.2.2 Chassis Component Location
9.2.3 Drive Hub and Motor
Boom
9.3.1 Boom Components Terminology
9.3.2 Main Boom Powertrack
9.3.3 Boom Synchronizing Procedure
9.3.4 Footswitch Adjustment
9.3.5 Boom Maintenance
9.3.6 Articulating JIB Boom
Platform
9.4.1 Platform (Rapid Replaceable Platform)
9.4.2 Platform Support (Traditional Platform)
9.4.3 Platform Support (Rapid Replaceable Platform)
Hydraulic Cylinders
9.5.1 Main Boom Lift Cylinder
9.5.2 Mid Boom Lift Cylinder
9.5.3 Lower Boom Lift Cylinder
9.5.4 Main Boom Telescope Cylinder
9.5.5 Lower Lift Cylinder Bleeding Procedure
9.5.6 Rotator and Slave Cylinder
9.5.7 Steer Cylinder
Hydraulic Valves
9.6.1 Main Control Valve
9.6.2 Steer Valve
9.6.3 Releveling Valve
9.6.4 Jib Plus Valve (E400AJPn only)
Electrical Components
9.7.1 Battery
Turntable
9.8.1 Replacement of Swing Bearing
9.8.2 Swing Bearing Torque Value
9.8.3 Checking Worm Gear End Play
9.8.4 Adjusting End Play
ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)
9.9.1 ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)
Disassembly and AssemblyDrive Assembly
10.1.1 Drive Hub
10.1.2 Drive Motor
10.1.3 Spindle
Boom and Jib Assembly
10.2.1 Main Boom
Articulating Jib Boom
Rotary Actuator
Hydraulic Cylinders
10.5.1 Slave Cylinder (E400An only)
10.5.2 Slave Cylinder (E400AJPn only)
10.5.3 Jib Lift Cylinder
10.5.4 Lower Lift Cylinder (E400An only)
10.5.5 Lower Lift Cylinder (E400AJPn only)
10.5.6 Mid Lift Cylinder(E400An only)
10.5.7 Mid Lift Cylinder (E400AJPn only)
10.5.8 Upper Lift Cylinder
10.5.9 Master Cylinder (E400An only)
10.5.10 Master Cylinder (E400AJPn only)
10.5.11 Steer Cylinder
10.5.12 Telescope Cylinder (E400An only)
10.5.13 Telescope Cylinder (E400AJPn only)
Turntable
10.6.1 Swing Motor
Generator Disassembly and Assembly
10.7.1 Supplementary Fuse for APU
Powertrack Maintenance
10.8.1 Removing a Link
10.8.2 Installing a New Link
10.8.3 Replacing Fixed End Brackets
10.8.4 Replacing Moving End Brackets
Torque/Connection InformationHydraulic Fittings
11.1.1 Tapered Thread Types
11.1.2 Straight Thread Types, Tube and Hose Connections
11.1.3 Straight Thread Types, Port Connections
11.1.4 Flange Connection Types
11.1.5 Tightening Methods
11.1.6 Assembly and Torque Specifications
11.1.7 General Tube Type Fitting Assembly Instructions
11.1.8 Assembly Instructions for American Standard Pipe Thread Tapered Connections.
11.1.9 Assembly Instructions for British Standard Pipe Thread Tapered Connections
11.1.10 Assembly Instructions for 37° (JIC) Flare Fittings
11.1.11 Assembly Instructions for 45° SAE Flare Fittings
11.1.12 Assembly Instructions for O-Ring Face Seal (ORFS) Fittings
11.1.13 Assembly Instructions for DIN 24° Flare Bite Type Fittings (MBTL and MBTS)
11.1.14 Assembly Instructions for Bulkhead (BH) Fittings
11.1.15 Assembly Instructions for O-Ring Boss (ORB) Fittings
11.1.16 Assembly Instructions for Adjustable Port End Metric Fittings
11.1.17 Assembly Instructions for Metric ISO 6149 (MPP) Port Assembly Stud Ends
11.1.18 Assembly instructions for Adjustable Port End (BSPP) Fittings
11.1.19 Assembly Instructions for Flange Connections: (FL61 and FL62)
11.1.20 Double Wrench Method
11.1.21 FFWR and TFFT Methods
11.1.22 Adjustable Stud End Assembly
11.1.23 O-ring Installation (Replacement)
Torque Charts
11.2.1 SAE Fastener Torque Chart
11.2.2 Metric Fastener Torque Chart
SchematicsHydraulic Schematics
Electrical Schematics
- SuperPac Parts Manual
- StratoLift Parts Manual
