Hyundai
86
176,834
JLG Boom Lift E400Anarrow, E400AJPnarrow Service & Maintenance Manual 3122337000 2025
Brand: JLG
Type of Machine: Boom Lift
Model: JLG E400Anarrow, E400AJPnarrow Boom Lift
Part Number: 3122337000
Publication Date: 2025
Number of Pages: 638 Pages
Safety
General​
1.1.1 Disclaimer​
Safety Information​
Safety Hazards​
1.3.1 Personal Hazards​
1.3.2 Equipment Hazards​
1.3.3 General Hazards​
1.3.4 Operational Hazards​
Safety Decals​
Machine Verification​
Specifications​
2.1.1 Machine Specifications​
2.1.2 Machine Dimensional Data​
2.1.3 Tires​
2.1.4 Critical Stability Weights​
2.1.5 Torque Specifications​
2.1.6 Major Component Weights​
Machine Temperature Chart​
Serial Number Location​
Fluids and Lubrication​
2.4.1 General Information​
2.4.2 Hydraulic Oil​
2.4.3 Changing Hydraulic Oil​
2.4.4 Lubrication Specifications​
2.4.5 Fluids​
2.4.6 Capacities​
2.4.7 Lubrication Schedule​
Clearsky Smart Fleet (If Equipped)​
2.5.1 General​
2.5.2 ClearSky Smart Fleet™ — Access Control​
Machine Preparation, Inspection, and Maintenance​
3.1.1 General​
3.1.2 Preparation, Inspection, and Maintenance​
3.1.3 Pre-Start Inspection​
3.1.4 Pre-Delivery Inspection and Frequent Inspection​
3.1.5 Annual Machine Inspection​
3.1.6 Preventive Maintenance​
Service and Guidelines​
3.2.1 General​
3.2.2 Safety and Workmanship​
3.2.3 Cleanliness​
3.2.6 Pressure-Fit Parts​
3.2.7 Bearings​
3.2.8 Gaskets​
3.2.11 Hydraulic System​
3.2.12 Lubrication​
3.2.13 Battery​
3.2.14 Welding on JLG Equipment​
Preventive Maintenance and Inspection Schedule​
3.3.1 First 50 Hours and Every 6 Months or 300 Hours​
3.3.2 Every 150 Hours or 3 Months​
3.3.3 Every 1200 Hours or 2 Years​
Pins and Composite Bearing Repair Guidelines​
Tires and Wheels​
3.5.1 Tire Inflation​
3.5.2 Tire Damage​
Boom Inspection and Maintenance​
3.6.1 Boom Cleanliness Guidelines​
3.6.2 Wear Pads​
3.6.3 Boom Limit Switches​
Turntable Bearing Inspection​
3.7.1 Turntable Bearing Mounting Bolt Condition Check​
3.7.2 Wear Tolerance​
Battery Maintenance and Charging (task)​
3.8.1 Battery Maintenance, Quarterly​
3.8.2 Battery Charging (On Board Charger)​
Battery Charger​
3.9.1 Operating Instructions​
3.9.2 Maintenance Instructions​
3.9.3 Delta-Q - Battery Charger​
3.9.4 Excessive Battery Watering Requirements or Strong Sulphur (Rotten Egg) Smell​
3.9.5 Checking/Changing the Battery Charger Algorithm​
Testing, Calibrations and Special Procedures
Special Tools​
4.1.1 Multimeter Basics​
4.1.2 Threadlocking Compound​
4.1.3 Tools Catalog​
Testing Procedures​
4.2.1 SkyGuard​
4.2.2 Diagnostics and Troubleshooting​
4.2.3 LSS Testing and Evaluation​
4.2.4 Troubleshooting​
Calibration Procedures​
4.3.1 JLG Analyzer​
4.3.2 Calibration Preparation​
4.3.3 Load Sensing System Calibration​
4.3.4 Calibrating Steer​
4.3.5 Calibrating Tilt Sensor​
4.3.6 Calibrating Load Sensing​
Special Procedure​
4.4.1 Drive Cutout Override Service Mode​
4.4.2 Cylinder Drift​
4.4.3 Cylinder Leakage Test​
4.4.4 Cylinder Thermal Drift​
Wheel Drive Hub​
4.5.1 Roll and Leak Testing​
4.5.2 Tightening and Torquing Bolts​
System Software
Load Sensing System (LSS)​
5.1.1 Theory of Operation​
5.1.2 Load Sensing Gauge Removal/ Installation​
JLG Analyzer​
5.2.1 Machine Data Access​
5.2.2 Hand Held Analyzer​
5.2.3 Mobile Analyzer​
5.2.4 Analyzer Flow Chart​
Analyzer Software Accessibility​
5.3.1 Analyzer Diagnostics Menu Structure​
5.3.2 System Self Test​
5.3.3 Machine Set-Up​
5.3.4 Machine Personality Settings​
Function Test​
5.4.1 Machine Orientation When Performing Test​
5.5.1 ClearSky Smart FleetTM CS550 Configuration​
5.5.2 Troubleshooting​
Fault Codes
Fault Codes Introduction​
Machine Fault Codes​
6.2.1 Help Descriptions and Fault Flash Codes​
6.2.2 General​
6.2.3 ClearSky Smart Fleet DTC Fault Codes​
ClearSky CS550 Troubleshooting Procedures​
Hydraulics
General Information and Safety​
Theories of Operation​
7.2.1 Cylinders​
7.2.2 Valves​
Hydraulic Components​
7.3.1 Pressure Setting Procedures​
Torque Values​
7.4.1 Valve Torque Specifications​
Standard Hydraulic Diagram- Boom And Turntable​
Electricals
8.1.1 Applying Silicone Dielectric Compound to Electrical Connections​
Electrical Connectors​
8.2.1 Deutsch Connectors​
Electrical Component Terminology​
Harness Layouts​
Board Layouts​
8.5.1 Power Module - LH​
8.5.2 Power Module - RH​
8.5.3 Ground Control Module​
8.5.4 Platform Control Module​
8.5.5 Platform Control Module — UL​
Checking Switches​
8.6.1 Basic Check​
8.6.2 Limit Switches​
8.6.3 Automatic Switches​
8.6.4 Switch Wiring - Low Side, High Side​
8.6.5 Tilt Module​
8.6.6 Speed Sensor​
AMP Connector​
8.7.1 Applying Silicone Dielectric Compound to AMP Connectors​
8.7.2 Assembly​
8.7.3 Disassembly​
8.7.4 Wedge Lock​
8.7.5 Service - Voltage Reading​
Wiring Harness and Connector Label Diagrams​
8.8.1 Connector Labels​
8.8.2 Component Labels​
Wheel and Tire​
Chassis/Frame Assembly​
9.2.1 Axle and Drive Assemblies Troubleshooting​
9.2.2 Chassis Component Location​
9.2.3 Drive Hub and Motor​
Boom​
9.3.1 Boom Components Terminology​
9.3.2 Main Boom Powertrack​
9.3.3 Boom Synchronizing Procedure​
9.3.4 Footswitch Adjustment​
9.3.5 Boom Maintenance​
9.3.6 Articulating JIB Boom​
Platform​
9.4.1 Platform (Rapid Replaceable Platform)​
9.4.2 Platform Support (Traditional Platform)​
9.4.3 Platform Support (Rapid Replaceable Platform)​
Hydraulic Cylinders​
9.5.1 Main Boom Lift Cylinder​
9.5.2 Mid Boom Lift Cylinder​
9.5.3 Lower Boom Lift Cylinder​
9.5.4 Main Boom Telescope Cylinder​
9.5.5 Lower Lift Cylinder Bleeding Procedure​
9.5.6 Rotator and Slave Cylinder​
9.5.7 Steer Cylinder​
Hydraulic Valves​
9.6.1 Main Control Valve​
9.6.2 Steer Valve​
9.6.3 Releveling Valve​
9.6.4 Jib Plus Valve (E400AJPn only)​
Electrical Components​
9.7.1 Battery​
Turntable​
9.8.1 Replacement of Swing Bearing​
9.8.2 Swing Bearing Torque Value​
9.8.3 Checking Worm Gear End Play​
9.8.4 Adjusting End Play​
9.9.1 ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)​
Disassembly and Assembly
Drive Assembly​
10.1.1 Drive Hub​
10.1.2 Drive Motor​
10.1.3 Spindle​
Boom and Jib Assembly​
10.2.1 Main Boom​
Articulating Jib Boom​
Rotary Actuator​
10.5.1 Slave Cylinder (E400An only)​
10.5.2 Slave Cylinder (E400AJPn only)​
10.5.3 Jib Lift Cylinder​
10.5.4 Lower Lift Cylinder (E400An only)​
10.5.5 Lower Lift Cylinder (E400AJPn only)​
10.5.6 Mid Lift Cylinder(E400An only)​
10.5.7 Mid Lift Cylinder (E400AJPn only)​
10.5.8 Upper Lift Cylinder​
10.5.9 Master Cylinder (E400An only)​
10.5.10 Master Cylinder (E400AJPn only)​
10.5.11 Steer Cylinder​
10.5.12 Telescope Cylinder (E400An only)​
10.5.13 Telescope Cylinder (E400AJPn only)​
Turntable​
10.6.1 Swing Motor​
Generator Disassembly and Assembly​
10.7.1 Supplementary Fuse for APU​
Powertrack Maintenance​
10.8.1 Removing a Link​
10.8.2 Installing a New Link​
10.8.3 Replacing Fixed End Brackets​
10.8.4 Replacing Moving End Brackets​
Torque/Connection Information
Hydraulic Fittings​
11.1.1 Tapered Thread Types​
11.1.2 Straight Thread Types, Tube and Hose Connections​
11.1.3 Straight Thread Types, Port Connections​
11.1.4 Flange Connection Types​
11.1.5 Tightening Methods​
11.1.6 Assembly and Torque Specifications​
11.1.7 General Tube Type Fitting Assembly Instructions​
11.1.8 Assembly Instructions for American Standard Pipe Thread Tapered Connections.​
11.1.9 Assembly Instructions for British Standard Pipe Thread Tapered Connections​
11.1.10 Assembly Instructions for 37° (JIC) Flare Fittings​
11.1.11 Assembly Instructions for 45° SAE Flare Fittings​
11.1.12 Assembly Instructions for O-Ring Face Seal (ORFS) Fittings​
11.1.13 Assembly Instructions for DIN 24° Flare Bite Type Fittings (MBTL and MBTS)​
11.1.14 Assembly Instructions for Bulkhead (BH) Fittings​
11.1.15 Assembly Instructions for O-Ring Boss (ORB) Fittings​
11.1.16 Assembly Instructions for Adjustable Port End Metric Fittings​
11.1.17 Assembly Instructions for Metric ISO 6149 (MPP) Port Assembly Stud Ends​
11.1.18 Assembly instructions for Adjustable Port End (BSPP) Fittings​
11.1.19 Assembly Instructions for Flange Connections: (FL61 and FL62)​
11.1.20 Double Wrench Method​
11.1.21 FFWR and TFFT Methods​
11.1.22 Adjustable Stud End Assembly​
11.1.23 O-ring Installation (Replacement)​
Torque Charts​
11.2.1 SAE Fastener Torque Chart​
11.2.2 Metric Fastener Torque Chart​
Schematics
Hydraulic Schematics​
Electrical Schematics​
