Hyundai
86
176,834
JLG Boom Lift E400Anarrow E400AJPnarrow Service & Maintenance Manual 31215960 2026
Brand: JLG
Type of Machine: Boom Lift
Model: JLG E400Anarrow, E400AJPnarrow Boom Lift
Part Number: 31215960
Publication Date: 2026
Number of Pages: 468 Pages
Section 1. Specifications​
1.1 Operating Specifications​
1.2 Capacities​
1.3 Tires​
1.4 Dimensional Data​
1.5 Lubrication Specifications​
1.6 Critical Stability Weights​
1.7 Torque Specifications​
1.8 Major Component Weights​
1.9 Serial Number Locations​
1.10 Maintenance and Lubrication​
1.11 Threadlocking Compound​
1.12 Torque Charts​
Section 2. General​
2.1 Machine Preparation, Inspection, and Maintenance​
2.2 Service and Guidelines​
2.3 Lubrication and Information​
2.4 Cylinder Drift​
2.5 Pins and Composite Bearing Repair Guidelines​
2.6 Welding on JLG Equipment​
Section 3. Chassis & Turntable​
3.1 Tires & Wheels​
3.2 Spindle​
3.3 Tilt Module​
3.4 Speed Sensor​
3.5 Drive Hub​
3.6 Drive Motor​
3.7 Swing Bearing​
3.8 Swing Motor​
3.9 Battery Maintenance and Charging​
3.10 Battery Charger​
3.11 Generator​
3.12 Supplementary Fuse for APU​
Section 4. Boom & Platform​
4.1 Platform​
4.2 Rotator and Slave Cylinder Removal​
4.3 Main Boom Powertrack​
4.4 Boom Maintenance​
4.5 Wear Pads​
4.6 Boom Limit Switches​
4.7 Boom Cleanliness Guidelines​
4.8 Articulating Jib Boom​
4.9 Boom Synchronizing Procedure​
4.10 Footswitch Adjustment​
4.11 Rotary actuator​
4.12 Powertrack Maintenance​
4.13 Skyguard​
Section 5. Basic Hydraulic Information & Schematics​
5.1 Lubricating O-Rings in the Hydraulic System​
5.2 Hydraulic Connection Assembly and Torque Specification​
5.3 Hydraulic Cylinders​
5.4 Cylinder Removal And Installation​
5.5 Lower Lift Cylinder Bleeding Procedure​
5.6 Pressure Setting Procedures​
5.7 Hydraulic Schematic​
Section 6. JLG Control System​
6.1 JLG Control System Analyzer Kit Instructions​
6.2 Machine Personality Settings​
6.3 Machine Orientation When performing test​
6.4 Function Speed​
6.5 Calibrating Steer​
6.6 Calibrating Tilt Sensor​
6.7 Calibrating Load Sensing​
6.8 LSS System​
6.9 Drive Cutout Override Service Mode​
6.10 Resetting The MSSO System​
Section 7. Basic Electrical Information & Schematics​
7.1 General​
7.2 Multimeter Basics​
7.3 Checking Switches​
7.4 Applying Silicone Dielectric Compound to Electrical Connections​
7.5 Dielectric Grease Application​
7.6 AMP Connector​
7.7 DEUTSCH Connectors​
7.8 Wiring Harness Connector Labels​
7.9 Electrical Schematics​
