JLG Boom Lift E400Anarrow E400AJPnarrow Service & Maintenance Manual 31215010 2026
Brand: JLG
Type of Machine: Boom Lift
Model: JLG E400Anarrow, E400AJPnarrow Boom Lift
Part Number: 31215010
Publication Date: 2026
Number of Pages: 482 Pages
Brand: JLG
Section 1. Specifications
1.1 Operating Specifications
1.2 Capacities
1.3 Tires
1.4 Dimensional Data
1.5 Lubrication Specifications
1.6 Critical Stability Weights
1.7 Torque Specifications
1.8 Major Component Weights
1.9 Serial Number Locations
1.10 Maintenance and Lubrication
1.11 Threadlocking Compound
1.12 Torque Charts
Section 2. General
2.1 Machine Preparation, Inspection, and Maintenance
2.2 Service and Guidelines
2.3 Lubrication and Information
2.4 Cylinder Drift
2.5 Pins and Composite Bearing Repair Guidelines
2.6 Welding on JLG Equipment
Section 3. Chassis & Turntable
3.1 Tires & Wheels
3.2 Spindle
3.3 Tilt Module
3.4 Speed Sensor
3.5 Drive Hub
3.6 Drive Motor
3.7 Swing Bearing
3.8 Swing Motor
3.9 Battery Maintenance and Charging
3.10 Battery Charger
3.11 Generator
3.12 Supplementary Fuse for APU
Section 4. Boom & Platform
4.1 Platform
4.2 Rotator and Slave Cylinder Removal
4.3 Main Boom Powertrack
4.4 Boom Maintenance
4.5 Wear Pads
4.6 Boom Limit Switches
4.7 Boom Cleanliness Guidelines
4.8 Articulating Jib Boom
4.9 Boom Synchronizing Procedure
4.10 Footswitch Adjustment
4.11 Rotary actuator
4.12 Powertrack Maintenance
4.13 Skyguard
Section 5. Basic Hydraulic Information & Schematics
5.1 Lubricating O-Rings in the Hydraulic System
5.2 Hydraulic Connection Assembly and Torque Specification
5.3 Hydraulic Cylinders
5.4 Cylinder Removal And Installation
5.5 Lower Lift Cylinder Bleeding Procedure
5.6 Pressure Setting Procedures
5.7 Hydraulic Schematic
Section 6. JLG Control System
6.1 JLG Control System Analyzer Kit Instructions
6.2 Machine Configuration Programming Information
6.3 Machine Personality Settings
6.4 Machine Orientation When performing test
6.5 Function Speed
6.6 Calibrating Steer
6.7 Calibrating Tilt Sensor
6.8 Calibrating Load Sensing
6.9 LSS System
6.10 Drive Cutout Override Service Mode
6.11 Resetting The MSSO System
Section 7. Basic Electrical Information & Schematics
7.1 General
7.2 Multimeter Basics
7.3 Checking Switches
7.4 Applying Silicone Dielectric Compound to Electrical Connections
7.5 Dielectric Grease Application
7.6 AMP Connector
7.7 DEUTSCH Connectors
7.8 Wiring Harness Connector Labels
7.9 Electrical Schematics
- SuperPac Parts Manual
- StratoLift Parts Manual
