JLG Boom Lift E400Anarrow E400AJPnarrow Parts Manual 3122568500
Brand: JLG
Type of Machine: Boom Lift
Model: JLG E400Anarrow, E400AJPnarrow Boom Lift
Part Number: 3122568500
Publication Date: 2025
Number of Pages: 426 Pages
SECTION 1 - FRAME
Brand: JLG
SECTION 1 - FRAME
FIGURE 1-1. STEERING INSTALLATION
FIGURE 1-2. HUB - SPINDLE ASSEMBLY - RH
FIGURE 1-3. HUB - SPINDLE ASSEMBLY - LH
FIGURE 1-4. DRIVE INSTALLATION - NON-UL SPECS
FIGURE 1-5. DRIVE INSTALLATION - UL SPECS
FIGURE 1-6. DRIVE HUB ASSEMBLY
FIGURE 1-7. DRIVE MOTOR ASSEMBLY
FIGURE 1-8. ELECTRICAL PLATE ASSEMBLY - LH
FIGURE 1-9. ELECTRICAL PLATE ASSEMBLY - LH - UL SPECS
FIGURE 1-10. ELECTRICAL PLATE ASSEMBLY - RH
FIGURE 1-11. ELECTRICAL PLATE ASSEMBLY - RH - UL SPECS
FIGURE 1-12. TIRE/WHEEL - SOLID NON-MARKING
FIGURE 1-13. MOTOR/PUMP/TANK - NON-UL SPECS
FIGURE 1-14. MOTOR/PUMP/TANK INSTALLATION - UL SPECS
FIGURE 1-15. MOTOR/PUMP ASSEMBLY
FIGURE 1-16. HYDRAULIC TANK ASSEMBLY
FIGURE 1-17. VALVE INSTALLATION - FRAME MOUNTED (E400ANARROW)
FIGURE 1-18. VALVE INSTALLATION - FRAME MOUNTED (E400AJPNARROW)
FIGURE 1-19. BRAKE/STEER VALVE ASSEMBLY
FIGURE 1-20. BATTERY BOX INSTALLATION - STANDARD
FIGURE 1-21. BATTERY BOX INSTALLATION - AGM BATTERIES
FIGURE 1-22. BATTERY CHARGER INSTALLATION (ALL SPECS EXCEPT AUSTRALIAN, CE & UK CA SPECS)
FIGURE 1-23. BATTERY CHARGER INSTALLATION (ANSI EXPORT, CE, CHINA & UK CA SPECS)
FIGURE 1-24. BATTERY CHARGER INSTALLATION (ANSI EXPORT, CE, CHINA & UK CA SPECS)
FIGURE 1-25. INVERTER INSTALLATION
FIGURE 1-26. FRAME COVER INSTALLATION
SECTION 2 - TURNTABLEFIGURE 2-1. VALVE INSTALLATION- TURNTABLE MOUNTED (E400ANARROW)
FIGURE 2-2. VALVE INSTALLATION- TURNTABLE MOUNTED (E400AJPNARROW)
FIGURE 2-3. MAIN CONTROL VALVE ASSEMBLY
FIGURE 2-4. RELEVELING VALVE ASSEMBLY
FIGURE 2-5. JIB VALVE ASSEMBLY
FIGURE 2-6. MOTION ALARM INSTALLATION
FIGURE 2-7. TURNTABLE BEARING AND SWING DRIVE INSTALLATION
FIGURE 2-8. SWING MOTOR ASSEMBLY
FIGURE 2-9. SWING BEARING ASSEMBLY
FIGURE 2-10. REMOTE BEARING LUBE INSTALLATION - OPTIONAL
FIGURE 2-11. DRIVE ORIENTATION INSTALLATION
FIGURE 2-12. GROUND CONTROL BOX INSTALLATION (ALL SPECS) (E400ANARROW)
FIGURE 2-13. GROUND CONTROL BOX INSTALLATION (ALL SPECS EXCEPT CE & UK CA SPEC) (E400AJPNARROW)
FIGURE 2-14. GROUND CONTROL BOX ELECTRICAL ASSEMBLY - DISPLAY WITHOUT BUTTONS (ALL SPECS) (E400ANARROW)
FIGURE 2-15. GROUND CONTROL BOX ELECTRICAL ASSEMBLY - DISPLAY WITHOUT BUTTONS (ALL SPECS) (E400AJPNARROW)
FIGURE 2-16. STROBE LIGHT INSTALLATION - AMBER
FIGURE 2-17. BEACON LIGHT INSTALLATION - BLUE
FIGURE 2-18. BEACON LIGHT INSTALLATION - RED
FIGURE 2-19. HOOD PLUGS INSTALLATION
FIGURE 2-20. HOOD INSTALLATION
SECTION 3 - BOOMFIGURE 3-1. BOOM AND CYLINDERS INSTALLATION (E400ANARROW)
FIGURE 3-2. BOOM AND CYLINDERS INSTALLATION (E400AJPNARROW)
FIGURE 3-3. MAIN BOOM ASSEMBLY (E400ANARROW)
FIGURE 3-4. MAIN BOOM ASSEMBLY (E400AJPNARROW)
FIGURE 3-5. JIB INSTALLATION (SN 0300320019 to Present)
FIGURE 3-6. ROTATOR ASSEMBLY (SN 0300320019 to Present)
FIGURE 3-7. ROTATOR ASSEMBLY - PLATFORM (SN 0300320019 to Present)
FIGURE 3-8. ROTATOR ASSEMBLY (SN 0300320019 to Present)
FIGURE 3-9. BOOM LIMIT SWITCHES INSTALLATION
SECTION 4 - PLATFORMFIGURE 4-1. RAPID REPLACEABLE PLATFORM (30IN X 4FT (76.2CM X 1.22M) (MACHINES WITH SN STARTING WITH 03)
FIGURE 4-2. RAPID REPLACEABLE PLATFORM (30IN X 5FT (76.2CM X 1.52M) (MACHINES WITH SN STARTING WITH 03)
FIGURE 4-3. RAPID REPLACEABLE PLATFORM (WITH STOP) (30IN X 5FT (76.2CM X 1.52M) (MACHINES WITH SN STARTING WITH 03)
FIGURE 4-4. RAPID REPLACEABLE PLATFORM (30IN X 4FT (76.2CM X 1.22M) (MACHINES WITH SN STARTING WITH B3)
FIGURE 4-5. RAPID REPLACEABLE PLATFORM (WITH STOP) (30IN X 5FT (76.2CM X 1.52M) (MACHINES WITH SN STARTING WITH B3)
FIGURE 4-6. RAPID REPLACEABLE PLATFORM SUPPORT (MACHINES WITH SN STARTING WITH 03)
FIGURE 4-7. RAPID REPLACEABLE PLATFORM SUPPORT (MACHINES WITH SN STARTING WITH B3)
FIGURE 4-8. PLATFORM SWING GATE INSTALLATION (MACHINES WITH SN STARTING WITH 03)
FIGURE 4-9. PLATFORM DROP BAR INSTALLATION (MACHINES WITH SN STARTING WITH 03)
FIGURE 4-10. PLATFORM SWING GATE INSTALLATION (MACHINES WITH SN STARTING WITH B3)
FIGURE 4-11. PLATFORM DROP BAR INSTALLATION (MACHINES WITH SN STARTING WITH B3)
FIGURE 4-12. PLATFORM CONTROL AND FOOTSWITH INSTALLATION - NON-UL LISTED (E400ANARROW)
FIGURE 4-13. PLATFORM CONTROL AND FOOTSWITH INSTALLATION - UL LISTED (E400ANARROW)
FIGURE 4-14. PLATFORM CONTROL AND FOOTSWITH INSTALLATION - NON-UL LISTED (E400AJPNARROW)
FIGURE 4-15. PLATFORM CONTROL AND FOOTSWITH INSTALLATION - UL LISTED (E400AJPNARROW)
FIGURE 4-16. PLATFORM CONSOLE ASSEMBLY - NON UL LISTED (E400ANARROW)
FIGURE 4-17. PLATFORM CONSOLE ASSEMBLY - UL LISTED (E400ANARROW)
FIGURE 4-18. PLATFORM CONSOLE ASSEMBLY - NON UL LISTED (E400AJPNARROW)
FIGURE 4-19. PLATFORM CONSOLE ASSEMBLY - UL LISTED (E400AJPNARROW)
FIGURE 4-20. PLATFORM BEACON (WITHOUT CLEARSKY) INSTALLATION
FIGURE 4-21. LIGHT PANEL INSTALLATION
FIGURE 4-22. FOOTSWITCH ASSEMBLY
FIGURE 4-23. TRAY ASSEMBLY
FIGURE 4-24. SKYEYE INSTALLATION
FIGURE 4-25. SKYGUARD BAR INSTALLATION
FIGURE 4-26. SKYLINE INSTALLATION
FIGURE 4-27. SKYSENSE MID TUBE SENSOR ASSEMBLY
FIGURE 4-28. SKYSENSE OVERHEAD SENSOR ASSEMBLY
FIGURE 4-29. USB CHARGER INSTALLATION
SECTION 5 - CYLINDERFIGURE 5-1. LEVEL (PLATFORM SLAVE) CYLINDER ASSEMBLY (E400ANARROW)
FIGURE 5-2. LEVEL (PLATFORM SLAVE) CYLINDER ASSEMBLY (E400AJPNARROW)
FIGURE 5-3. LIFT CYLINDER ASSEMBLY - JIB (E400AJPNARROW)
FIGURE 5-4. LIFT CYLINDER ASSEMBLY - LOWER (E400ANARROW)
FIGURE 5-5. CYLINDER ASSEMBLY - LOWER (E400AJPNARROW)
FIGURE 5-6. LIFT CYLINDER ASSEMBLY - MID (E400ANARROW)
FIGURE 5-7. LIFT CYLINDER ASSEMBLY - MID (E400AJPNARROW)
FIGURE 5-8. LIFT CYLINDER - UPPER (E400ANARROW)
FIGURE 5-9. LIFT CYLINDER - UPPER (E400AJPNARROW)
FIGURE 5-10. MASTER CYLINDER ASSEMBLY (E400ANARROW)
FIGURE 5-11. MASTER CYLINDER ASSEMBLY (E400AJPNARROW)
FIGURE 5-12. STEER CYLINDER ASSEMBLY
FIGURE 5-13. TELESCOPE CYLINDER ASSEMBLY (E400ANARROW)
FIGURE 5-14. TELESCOPE CYLINDER ASSEMBLY (E400AJPNARROW)
FIGURE 5-15. COUNTERBALANCE VALVE ASSEMBLY
SECTION 6 - HYDRAULICFIGURE 6-1. HYDRAULIC DIAGRAM (E400ANARROW)
FIGURE 6-2. HYDRAULIC DIAGRAM (E400AJPNARROW)
SECTION 7 - ELECTRICALFIGURE 7-1. AC PLUGS AND SOCKETS INSTALLATION - AFSINT 107-2-01 KEYED GROUND - 2 X 4 BOX (CE & UK CA SPEC)
FIGURE 7-2. AC PLUGS AND SOCKETS INSTALLATION - CEE7 POST GROUND (CE & UK CA SPEC)
FIGURE 7-3. AC PLUGS AND SOCKETS INSTALLATION - CEE 7 SIDE GROUND (CE & UK CA SPEC)
FIGURE 7-4. AC PLUGS AND SOCKETS INSTALLATION - CEE7 POST GROUND - 2 X 4 BOX (CE & UK CA SPEC)
FIGURE 7-5. AC PLUGS AND SOCKETS INSTALLATION - CEE7 SIDE GROUND - 2 X 4 BOX (CE & UK CA SPEC)
FIGURE 7-6. AC PLUGS AND SOCKETS INSTALLATION - IEC 60309 BLUE (CE & UK CA SPEC)
FIGURE 7-7. AC PLUGS AND SOCKETS INSTALLATION - IEC 60309 YELLOW (CE & UK CA SPEC)
FIGURE 7-8. BATTERY CABLE KIT
FIGURE 7-9. BATTERY CABLE KIT - UL SPECS
FIGURE 7-10. BOOM CABLE - LOWER
FIGURE 7-11. BOOM CABLE - UPPER
FIGURE 7-12. BOOM LIMIT SWITCH HARNESS - LOWER
FIGURE 7-13. BOOM LIMIT SWITCH HARNESS - UPPER
FIGURE 7-14. BREAKER BOX KIT WITH ONE BREAKERS - CE & UK CA SPEC
FIGURE 7-15. BREAKER BOX KIT WITH TWO BREAKERS - CE & UK CA SPEC
FIGURE 7-16. CABLES AND CLAMPS INSTALLATION (E400ANARROW)
FIGURE 7-17. CABLES AND CLAMPS INSTALLATION (E400AJPNARROW)
FIGURE 7-18. CLEARSKY CS550 BEACON INSTALLATION
FIGURE 7-19. CHARGER HARNESS
FIGURE 7-20. CHARGER CORD PLUG INSTALLATION - 110V - IEC 60309 - YELLOW (CE & UK CA SPEC)
FIGURE 7-21. CHARGER CORD PLUG INSTALLATION - 220V - AFSINT 107 KEYED GROUND (CE & UK CA SPEC)
FIGURE 7-22. CHARGER CORD PLUG INSTALLATION - 220V - CEE7 POST GROUND (CE & UK CA SPEC)
FIGURE 7-23. CHARGER CORD PLUG INSTALLATION - 220V - CEE7 SIDE GROUND (CE & UK CA SPEC)
FIGURE 7-24. CHARGER CORD PLUG INSTALLATION - 220V - IEC 60309 - BLUE (CE & UK CA SPEC)
FIGURE 7-25. CHARGER DC CONNECTION HARNESS
FIGURE 7-26. CHASSIS TO TURNTABLE HARNESS
FIGURE 7-27. STROBE LIGHT JUMPER HARNESS
FIGURE 7-28. GROUND CONTROL PANEL HARNESS
FIGURE 7-29. GROUND CONTROL PANEL HARNESS
FIGURE 7-30. INVERTER HARNESS
FIGURE 7-31. INVERTER IGNITION HARNESS
FIGURE 7-32. INVERTER IGNITION HARNESS
FIGURE 7-33. LOWER BOOM 110V HARNESS ASSEMBLY
FIGURE 7-34. LOWER BOOM 220V HARNESS ASSEMBLY - CE & UK CA SPEC
FIGURE 7-35. LOWER BOOM 220V HARNESS ASSEMBLY - CE & UK CA SPEC
FIGURE 7-36. PLATFORM CONSOLE HARNESS (NON-UL SPECS)
FIGURE 7-37. PLATFORM CONSOLE HARNESS
FIGURE 7-38. PLATFORM BEACON HARNESS
FIGURE 7-39. PLUG AND RECEPTACLE INSTALLATION - 110V
FIGURE 7-40. PLUG AND RECEPTACLE INSTALLATION - 220V
FIGURE 7-41. PLUG AND RECEPTACLE INSTALLATION - SUPPLIED LOCALLY
FIGURE 7-42. PLUG AND RECEPTACLE 110V INSTALLATION - IEC 60309 - YELLOW (CE & UK CA SPEC)
FIGURE 7-43. PLUG AND RECEPTACLE 220V INSTALLATION - AFSINT 107 KEYED GROUND - 2 X 4 BOX (CE & UK CA SPEC)
FIGURE 7-44. PLUG AND RECEPTACLE 220V INSTALLATION - CEE7 POST GROUND - 2 X 4 BOX (CE & UK CA SPEC)
FIGURE 7-45. PLUG AND RECEPTACLE 220VINSTALLATION - CEE7 POST GROUND - 70MM X 70MM BOX (CE & UK CA SPEC)
FIGURE 7-46. PLUG AND RECEPTACLE 220 INSTALLATION - CEE7 SIDE GROUND - 2 X 4 BOX (CE & UK CA SPEC)
FIGURE 7-47. PLUG AND RECEPTACLE 220VINSTALLATION - CEE7 SIDE GROUND - 70MM X 70MM BOX (CE & UK CA SPEC)
FIGURE 7-48. PLUG AND RECEPTACLE 220VINSTALLATION - IEC 60309 - BLUE (CE & UK CA SPEC)
FIGURE 7-49. SKYEYE INTERMEDIATE HARNESS
FIGURE 7-50. SKYEYE RECEIVER HARNESS
FIGURE 7-51. SKYEYE EMITTER HARNESS
FIGURE 7-52. SKYGUARD HARNESS - WITH 1 CELL LSS
FIGURE 7-53. SKYLINE HARNESS
FIGURE 7-54. STEER/BRAKE HARNESS
FIGURE 7-55. TRACTION HARNESS
FIGURE 7-56. TURNTABLE HARNESS
FIGURE 7-57. TURNTABLE HARNESS
FIGURE 7-58. UPPER BOOM 110V HARNESS ASSEMBLY
FIGURE 7-59. UPPER BOOM 220V HARNESS ASSEMBLY - CE & UK CA SPEC
FIGURE 7-60. USB HARNESS
FIGURE 7-61. VALVE HARNESS
FIGURE 7-62. VALVE HARNESS
FIGURE 7-63. WORKLIGHT HARNESS
SECTION 8 - DECALSFIGURE 8-1. DECAL INSTALLATION - ANSI SPEC
FIGURE 8-2. DECAL INSTALLATION - AUSTRALIAN SPEC
FIGURE 8-3. DECAL INSTALLATION - CE & UK CA SPEC
FIGURE 8-4. DECAL INSTALLATION - CHINESE/ENGLISH
FIGURE 8-5. DECAL INSTALLATION - FRENCH/ENGLISH SPECS
FIGURE 8-6. DECAL INSTALLATION - JAPANESE SPEC
FIGURE 8-7. DECAL INSTALLATION - KOREAN SPEC
FIGURE 8-8. DECAL INSTALLATION - SPANISH/ENGLISH SPECS
FIGURE 8-9. DECAL INSTALLATION - SPANISH/PORTUGUESE SPECS
FIGURE 8-10. DECAL INSTALLATION - OPTIONS
SECTION 9 - RECOMMENDED SERVICE PARTS STOCKFIGURE 9-1. RECOMMENDED SERVICE PARTS STOCK
SECTION 10 - SPECIAL OPTIONS/ACCESSORIES/KITSFIGURE 10-1. SPECIAL OPTIONS/ACCESSORIES/KITS
PART NUMBER INDEX
- SuperPac Parts Manual
- StratoLift Parts Manual
