JLG Boom Lift E300AJP Service & Maintenance Manual 3122336700 2025
Brand: JLG
Type of Machine: Boom Lift
Model: JLG E300AJP Boom Lift
Part Number: 3122336700
Publication Date: 2025
Number of Pages: 582 Pages
Safety
Brand: JLG
Safety
General
1.1.1 Disclaimer
1.1.2 Operation & Safety Manual
Safety Information
1.2.1 Safety Alert System and Signal Words
Safety Hazards
1.3.1 Personal Hazards
1.3.2 Equipment Hazards
1.3.3 General Hazards
1.3.4 Operational Hazards
Safety Decals
Machine Verification
General Machine Information and SpecificationsSpecifications
2.1.1 Machine Specification E300AJP
2.1.2 Machine Dimensional Data
2.1.3 Tires
2.1.4 Critical Stability Weights
2.1.5 Major Component Weights
Serial Number Location
Fluids and Lubrication
2.3.1 General Information
2.3.2 Hydraulic Oil
2.3.3 Changing Hydraulic Oil
2.3.4 Lubrication Specifications
2.3.5 Fluids
2.3.6 Capacities
2.3.7 Lubrication Schedule
Machine Characteristics
2.4.1 Chassis tilt Indicator System
2.4.2 Ground Control Keyswitch System
2.4.3 Side Entry Platform
2.4.4 Platform Control Enable System
2.4.5 Drive Orientation System
2.4.6 Function Speed Control System
2.4.7 Transport Position Interlock System
2.4.8 Above Elevation (Above Horizontal) Cutout System
2.4.9 Platform Load Control System
2.4.10 Positive Opening Switch Systems
2.4.11 Tires and Counterweight
2.4.12 Controller Programming
Clearsky Smart Fleet (If Equipped)
2.5.1 General
2.5.2 ClearSky Smart Fleet™ — Access Control
Maintenance and Inspection SchedulesMachine Preparation, Inspection, and Maintenance
3.1.1 General
3.1.2 Preparation, Inspection, and Maintenance
3.1.3 Pre-Start Inspection
3.1.4 Pre-Delivery Inspection and Frequent Inspection
3.1.5 Annual Machine Inspection
3.1.6 Preventive Maintenance
Service and Guidelines
3.2.1 General
3.2.2 Safety and Workmanship
3.2.3 Cleanliness
3.2.4 Components Removal and Installation
3.2.5 Component Disassembly and Reassembly
3.2.6 Pressure-Fit Parts
3.2.7 Bearings
3.2.8 Gaskets
3.2.9 Bolt Usage and Torque Application
3.2.10 Hydraulic Lines and Electrical Wiring
3.2.11 Hydraulic System
3.2.12 Lubrication
3.2.13 Battery
3.2.14 Welding on JLG Equipment
Preventive Maintenance and Inspection Schedule
3.3.1 Daily
3.3.2 First 50 Hours
3.3.3 Every 150 Hours or 3 Months
3.3.4 First 300 Hours or 6 Months
3.3.5 Every 1200 Hours or 2 Years
Pins and Composite Bearing Repair Guidelines
Tires and Wheels
3.5.1 Tire Inflation
3.5.2 Tire Damage
Boom Inspection and Maintenance
3.6.1 Boom Cleanliness Guidelines
3.6.2 Wear Pads
Turntable Bearing Inspection
3.7.1 Turntable Bearing Mounting Bolt Condition Check
3.7.2 Wear Tolerance
Battery Maintenance and Charging
3.8.1 Battery Maintenance, Quarterly
Battery Charger
3.9.1 Operating Instructions
3.9.2 Maintenance Instructions
3.9.3 Delta-Q - Battery Charger
3.9.4 Excessive Battery Watering Requirements or Strong Sulphur (Rotten Egg) Smell
3.9.5 Instructions for using the Delta-Q QuiQ Programmer CTQuiQ Programming Kit
3.9.6 INSTALLING QUIQ PROGRAMMER CT SOFTWARE AND DRIVERS
3.9.7 Checking/Changing the Battery Charger Algorithm
Testing, Calibrations and Special ProceduresSpecial Tools
4.1.1 Multimeter Basics
4.1.2 Threadlocking Compound
4.1.3 Tools Catalog
Testing Procedures
4.2.1 SkyGuard
4.2.2 LSS Testing and Evaluation
4.2.3 Troubleshooting
Calibration Procedures
4.3.1 JLG Analyzer
4.3.2 Calibration Preparation
4.3.3 Load Sensing System Calibration
4.3.4 Calibrating Tilt Sensor
4.3.5 Calibrating Load Sensing
4.3.6 Calibrating Steer
Special Procedure
4.4.1 Drive Cutout Override Service Mode
4.4.2 Cylinder Checking Procedure
4.4.3 Cylinder Drift
4.4.4 Hydraulic Circuits
4.4.5 Hoods
Wheel Drive Hub
4.5.1 Roll and Leak Testing
4.5.2 Tightening and Torquing Bolts
System SoftwareLoad Sensing System (LSS)
5.1.1 Theory of Operation
5.1.2 Load Sensing Gauge Removal/ Installation
JLG Analyzer
5.2.1 Machine Data Access
5.2.2 Hand Held Analyzer
5.2.3 Analyzer Flow Chart
Analyzer Software Accessibility
5.3.1 Machine Configuration Programming Information
5.3.2 Machine Personality Settings
5.3.3 Operator Tools
5.3.4 Calibrations
5.3.5 System Self Test
5.3.6 Analyzer Diagnostics Menu Structure
Function Test
5.4.1 Test Notes
CANBUS Communications
ClearSky (CS550) Configuration and Troubleshooting
5.6.1 ClearSky Smart FleetTM CS550 Configuration
5.6.2 Troubleshooting
Fault CodesFault Codes Introduction
Machine Fault Codes
6.2.1 General
6.2.2 ClearSky Smart Fleet DTC Fault Codes
6.2.3 Help Descriptions and Fault Flash Codes
ClearSky CS550 Troubleshooting Procedures
HydraulicsGeneral Information and Safety
Theories of Operation
7.2.1 Cylinders
7.2.2 Valves
Hydraulic Components
7.3.1 Pressure Settings Procedures
7.3.2 Initial Hydraulic Pump Start-up Procedure
ElectricalsGeneral Information
8.1.1 Applying Silicone Dielectric Compound to Electrical Connections
8.1.2 Dielectric Grease Application
Electrical Connectors
8.2.1 Deutsch Connectors
Electrical Component Terminology
Harness Layouts
Board Layouts
8.5.1 Platform Control Module (E300AJP)
8.5.2 Platform Control Module (E300AJP) – UL
8.5.3 Power Module - LH
8.5.4 Power Module - RH
8.5.5 Ground Control Module
Checking Switches
8.6.1 Speed Sensor
AMP Connector
8.7.1 Assembly
8.7.2 Disassembly
8.7.3 Wedge Lock
8.7.4 Service - Voltage Reading
Wiring Harness and Connector Label Diagrams
8.8.1 Connector Labels
8.8.2 Component Labels
Removal and InstallationWheel and Tire
Chassis/Frame Assembly
9.2.1 Axle and Drive Assemblies Troubleshooting
9.2.2 Chassis Component Location
9.2.3 Drive Hub and Motor
Boom
9.3.1 Boom Components Terminology
9.3.2 Main Boom Powertrack
9.3.3 Boom Synchronizing Procedure
9.3.4 Footswitch Adjustment
9.3.5 Main Boom Maintenance
9.3.6 Boom Limit Switches
9.3.7 Articulating Jib Boom
9.3.8 Tilt Sensor Check
Platform
9.4.1 Platform (Rapid Replaceable Platform)
9.4.2 Platform Support (Traditional Design)
9.4.3 Platform Support (Rapid Replaceable Platform)
Hydraulic Cylinders
9.5.1 Main Boom Lift Cylinder
9.5.2 Main Boom Telescope Cylinder
9.5.3 Phase Check Cartridge
9.5.4 Steer Cylinder
Hydraulic Valves
9.6.1 Main Control Valve
9.6.2 Boom Function Valve
Electrical Components
9.7.1 Battery
Turntable
9.8.1 Replacement of Swing Bearing
ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)
9.9.1 ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)
Disassembly and AssemblyDrive Assembly
10.1.1 Drive Hub
10.1.2 Drive Motor
10.1.3 Spindle
Boom and Jib Assembly
10.2.1 Main Boom
Rotary Actuator
10.3.1 Rotator Assembly
10.4.1 Disassembly
10.4.2 Inspection
10.4.3 Assembly
Hydraulic Cylinders
10.5.1 Platform Level Cylinder
10.5.2 Jib Lift Cylinder
10.5.3 Main Boom Lift Cylinder
10.5.4 Master Cylinder
10.5.5 Tower Boom Lift Cylinder
10.5.6 Steer Cylinder
10.5.7 Telescope Cylinder
Turntable
10.6.1 Swing Drive
10.6.2 Swing Motor
Powertrack Maintenance (task)
10.7.1 Removing a Link
10.7.2 Installing a New Link
10.7.3 Replacing Fixed End Brackets
10.7.4 Replacing Moving End Brackets
Torque/Connection InformationHydraulic Fittings
11.1.1 Tapered Thread Types
11.1.2 Straight Thread Types, Tube and Hose Connections
11.1.3 Straight Thread Types, Port Connections
11.1.4 Flange Connection Types
11.1.5 Tightening Methods
11.1.6 Assembly and Torque Specifications
11.1.7 General Tube Type Fitting Assembly Instructions
11.1.8 Assembly Instructions for American Standard Pipe Thread Tapered Connections.
11.1.9 Assembly Instructions for British Standard Pipe Thread Tapered Connections
11.1.10 Assembly Instructions for 37° (JIC) Flare Fittings
11.1.11 Assembly Instructions for 45° SAE Flare Fittings
11.1.12 Assembly Instructions for O-Ring Face Seal (ORFS) Fittings
11.1.13 Assembly Instructions for DIN 24° Flare Bite Type Fittings (MBTL and MBTS)
11.1.14 Assembly Instructions for Bulkhead (BH) Fittings
11.1.15 Assembly Instructions for O-Ring Boss (ORB) Fittings
11.1.16 Assembly Instructions for Adjustable Port End Metric Fittings
11.1.17 Assembly Instructions for Metric ISO 6149 (MPP) Port Assembly Stud Ends
11.1.18 Assembly instructions for Adjustable Port End (BSPP) Fittings
11.1.19 Assembly Instructions for Flange Connections: (FL61 and FL62)
11.1.20 Double Wrench Method
11.1.21 FFWR and TFFT Methods
11.1.22 Adjustable Stud End Assembly
11.1.23 O-ring Installation (Replacement)
Torque Charts
11.2.1 SAE Fastener Torque Chart
11.2.2 Metric Fastener Torque Chart
SchematicsHydraulic Schematics
Electrical Schematics
- SuperPac Parts Manual
- StratoLift Parts Manual
