Hyundai
86
176,834
JLG Boom Lift 830P 1030P Service & Maintenance Manual 31215863 2025
Brand: JLG
Type of Machine: Boom Lift
Model: JLG 830P 1030P Boom Lift
Part Number: 31215863
Publication Date: 2025
Number of Pages: 62 Pages
Section A. INTRODUCTION - MAINTENANCE SAFETY PRECAUTIONS
a. General​
b. Hydraulic System Safety​
c. Maintenance​
REVISON LOG
Section 1. MACHINE SPECIFICATIONS
1.1 General​
Working Specifications​
Dimensions​
Power Source​
Battery Charger​
Hydraulic Oil​
Working Envelope​
1.2 Serial Number Plate Identification​
1.3 Battery Charger​
830P​
1030P​
1.4 Lubrication Intervals​
1.5 Torque Charts​
SAE Fasteners​
Metric Fasteners​
Section 2. General Maintenance Information
2.1 Machine Preparation, Inspection, and Maintenance​
Pre-Start Inspection​
Pre-Delivery Inspection and Frequent Inspection​
Annual Machine Inspection​
Preventative Maintenance​
Inspection and Maintenance Table​
2.2 Preventive Maintenance and Inspection Schedule​
2.3 Servicing and Maintenance Guidelines​
General​
Safety and Workmanship​
Cleanliness​
Components Removal and Installation​
Component Disassembly and Reassembly​
Pressure-Fit Parts​
Bearings​
Gaskets​
Bolt Usage and Torque Application​
2.4 Hydraulic System Information​
Hydraulic Lines and Electrical Wiring​
Hydraulic System​
Lubrication and Servicing​
Changing Hydraulic Oil​
Section 3. Components ASSEMBLY
3.1 830P​
Chassis​
Platform​
Electrical​
Hydraulic​
Mast Disassembly​
Mast Assembly Notes​
3.2 1030P​
Boom​
Platform​
Electrical​
Section 4. Electrical/Hydraulic Information and Machine Schematics
4.1 General​
4.2 Hydraulic Circuit Checks​
4.3 Electrical System - Multimeter Basics​
Grounding​
Backprobing​
Min/Max​
Polarity​
Scale​
Continuity Measurement Over Long Distances​
Requirements​
Procedure​
4.4 Electrical Switch Testing​
Basic Check​
Limit Switches​
Automatic Switches​
Switch Wiring - Low Side, High Side​
4.5 Electrical/Hydraulic Components​
1030P - Hydraulic​
1030P - Electrical​
4.6 Electrical Schematics​
830P​
1030P​
4.7 Hydraulic Schematics​
830P​
1030P​
Section 5. Machine mAINTENANCE and Service
5.1 General​
5.2 Castor Wheel Maintenance​
5.3 Battery/Battery Charger​
830P​
5.4 830P​
Troubleshooting Table​
Rear Axle Adjustment​
Contactor Solenoid Replacement​
5.5 1030P​
Emergency Lowering Valve Spindle​
Gate Spring Mechanism​
Inspect Main Boom Pivot Pins​
Inspect Main Boom Pivot Pin Screws​
Replace Main Pivot Pin​
Replace the Lift Cylinder​
Replace a Rear Wheel​
