Hyundai
86
176,684
JLG Boom Lift 800S HC3 860SJ HC3 Parts Manual 3122565600
Brand: JLG
Type of Machine: Boom Lift
Model: JLG 800S HC3, 860SJ HC3 Boom Lift
Part Number: 3122565600
Publication Date: 2025
Number of Pages: 934 Pages
SECTION 1 - FRAME
FIGURE 1-1. AXLE INSTALLATION - FIXED​
FIGURE 1-2. AXLE INSTALLATION - OSCILLATING (WITHOUT TOW PACKAGE) (MACHINES WITH SN STARTING WITH 03)​
FIGURE 1-3. AXLE INSTALLATION - OSCILLATING (WITHOUT TOW PACKAGE) (MACHINES WITH SN STARTING WITH B3 OR C3) (860SJ HC3)​
FIGURE 1-4. AXLE INSTALLATION - OSCILLATING (WITH TOW PACKAGE) (MACHINES WITH SN STARTING WITH 03)​
FIGURE 1-5. AXLE INSTALLATION - OSCILLATING (WITH TOW PACKAGE) (MACHINES WITH SN STARTING WITH B3) (860SJ HC3)​
FIGURE 1-6. STEERING INSTALLATION - WITHOUT TOW PACKAGE​
FIGURE 1-7. STEERING INSTALLATION - WITH TOW PACKAGE​
FIGURE 1-8. WHEEL DRIVE AND FRAME VALVES INSTALLATION - 2WD (800S HC3)​
FIGURE 1-9. WHEEL DRIVE AND FRAME VALVES INSTALLATION - 4WD​
FIGURE 1-10. HUB ASSEMBLY (NON-DRIVE) (800S HC3)​
FIGURE 1-11. DRIVE HUB ASSEMBLY​
FIGURE 1-12. DRIVE MOTOR ASSEMBLY - 2WD​
FIGURE 1-13. DRIVE MOTOR ASSEMBLY - 4WD​
FIGURE 1-14. TIRE AND WHEEL INSTALLATION (15-625 NHS FOAM-FILLED)​
FIGURE 1-15. TIRE AND WHEEL INSTALLATION (18-625 NHS FOAM-FILLED)​
FIGURE 1-16. TIRE AND WHEEL INSTALLATION (18-625 NHS FOAM-FILLED) (NON-MARKING)​
FIGURE 1-17. TIRE AND WHEEL INSTALLATION (41 X 18LL X 22.5)​
FIGURE 1-18. LP TANK BRACKETS INSTALLATION​
FIGURE 1-19. TOW PACKAGE INSTALLATION (ENGLISH DECALS)​
FIGURE 1-20. TOW PACKAGE INSTALLATION (FRENCH/ENGLISH DECALS)​
FIGURE 1-21. TOW BAR ASSEMBLY​
FIGURE 1-22. FRAME SHIELDS INSTALLATION​
SECTION 2 - TURNTABLE
FIGURE 2-1. CONTROL VALVES INSTALLATION (800S HC3)​
FIGURE 2-2. CONTROL VALVES INSTALLATION (860SJ HC3) (Prior to SN C300003189, Including C300003290)​
FIGURE 2-3. CONTROL VALVES INSTALLATION (860SJ HC3) (SN B300031393 to Present, SN C300003189 to Present, Excluding C300003290)​
FIGURE 2-4. MAIN CONTROL VALVE ASSEMBLY​
FIGURE 2-5. SWING DRIVE INSTALLATION​
FIGURE 2-6. SWING MOTOR/HUB ASSEMBLY​
FIGURE 2-7. TURNTABLE BEARING INSTALLATION​
FIGURE 2-8. REMOTE BEARING LUBE INSTALLATION​
FIGURE 2-9. TURNTABLE LOCK INSTALLATION​
FIGURE 2-10. ROTARY COUPLING INSTALLATION (MACHINES WITH SN STARTING WITH 03)​
FIGURE 2-11. ROTARY COUPLING INSTALLATION (MACHINES WITH SN STARTING WITH B3 OR C3) (860SJ HC3)​
FIGURE 2-12. ROTARY COUPLING ASSEMBLY (MACHINES WITH SN STARTING WITH B3 OR C3) (860SJ HC3)​
FIGURE 2-13. TANK INSTALLATION - GAS ENGINES​
FIGURE 2-14. TANK INSTALLATION - DIESEL ENGINES (MACHINES WITH SN STARTING WITH 03)​
FIGURE 2-15. TANK INSTALLATION - DIESEL ENGINES (MACHINES WITH SN STARTING WITH B3 OR C3) (860SJ HC3)​
FIGURE 2-16. HYDRAULIC TANK ASSEMBLY (MACHINES WITH SN STARTING WITH 03)​
FIGURE 2-17. HYDRAULIC TANK ASSEMBLY (MACHINES WITH SN STARTING WITH B3 OR C3) (860SJ HC3)​
FIGURE 2-18. ALARM INSTALLATION (860SJ HC3)​
FIGURE 2-19. AUXILIARY PUMP - WITHOUT BATTERY DISCONNECT SWITCH (MACHINES WITH SN STARTING WITH 03)​
FIGURE 2-20. AUXILIARY PUMP - WITHOUT BATTERY DISCONNECT SWITCH (MACHINES WITH SN STARTING WITH B3 OR C3) (860SJ HC3)​
FIGURE 2-21. AUXILIARY PUMP - WITH BATTERY DISCONNECT SWITCH(MACHINES WITH SN STARTING WITH 03)​
FIGURE 2-22. AUXILIARY PUMP - WITH BATTERY DISCONNECT SWITCH (MACHINES WITH SN STARTING WITH B3 OR C3) (860SJ HC3)​
FIGURE 2-23. BEACON INSTALLATION (WITHOUT CLEARSKY BEACON)​
FIGURE 2-24. GROUND CONTROL BOX ASSEMBLY - WITH DEUTZ TD2.9L4 (UN R96) & TD2.9L4 EMR5 ENGINES (800S HC3)​
FIGURE 2-25. GROUND CONTROL BOX ASSEMBLY - WITH DEUTZ TD2.9L4 (UN R96) & TD2.9L4 EMR5 ENGINES (860SJ HC3)​
FIGURE 2-26. GROUND CONTROL BOX ASSEMBLY - WITH DEUTZ TD2.9L4 (STAGE V) ENGINES (860SJ HC3)​
FIGURE 2-27. GROUND CONTROL BOX ASSEMBLY - WITH FORD ENGINES (800S HC3)​
FIGURE 2-28. GROUND CONTROL BOX ASSEMBLY - WITH FORD ENGINES (860SJ HC3)​
FIGURE 2-29. EXHAUST STACK INSTALLATION - STEEL HOOD (DEUTZ TD2.9L4 (CHINA IV) ENGINES) (860SJ HC3)​
FIGURE 2-30. EXHAUST STACK INSTALLATION - STEEL HOOD (DEUTZ TD2.9L4 (STAGE V) ENGINES)​
FIGURE 2-31. EXHAUST STACK INSTALLATION - STEEL HOOD (DEUTZ TD2.9L4 (UN R96) & TD2.9L4 EMR5 ENGINES)​
FIGURE 2-32. EXHAUST STACK INSTALLATION - STEEL HOOD (DEUTZ TD2.9L4 (UN R96) & TD2.9L4 EMR5 ENGINES) (SHIPYARD MACHINES) (MACHINES WITH SN STARTING WITH 03) (860SJ HC3)​
FIGURE 2-33. EXHAUST STACK INSTALLATION - STEEL HOOD (DEUTZ TD2.9L4 (UN R96) & TD2.9L4 EMR5 ENGINES) (SHIPYARD MACHINES) (MACHINES WITH SN STARTING WITH B3) (860SJ HC3)​
FIGURE 2-34. EXHAUST STACK INSTALLATION - STEEL HOOD (FORD ENGINES)​
FIGURE 2-35. HOODS INSTALLATION - ABS (WITH CAST COUNTERWEIGHT)​
FIGURE 2-36. HOODS INSTALLATION - ABS (WITH FABRICATED COUNTERWEIGHT) (860SJ HC3)​
FIGURE 2-37. HOODS INSTALLATION - STEEL (DEUTZ TD2.9L4 (CHINA IV) ENGINES) (860SJ HC3)​
FIGURE 2-38. HOODS INSTALLATION - STEEL (DEUTZ TD2.9L4 (STAGE V), TD2.9L4 (UN R96) & TD2.9L4 EMR5 ENGINES)​
FIGURE 2-39. HOODS INSTALLATION - STEEL (DEUTZ TD2.9L4 (UN R96) & TD2.9L4 EMR5 ENGINES) (SHIPYARD MACHINES) (MACHINES WITH SN STARTING WITH 03) (860SJ HC3)​
FIGURE 2-40. HOODS INSTALLATION - STEEL (DEUTZ TD2.9L4 (UN R96) & TD2.9L4 EMR5 ENGINES) (SHIPYARD MACHINES) (MACHINES WITH SN STARTING WITH B3) (860SJ HC3)​
FIGURE 2-41. HOODS INSTALLATION - STEEL (FORD ENGINES)​
FIGURE 2-42. HOOD ASSEMBLY - ENGINE SIDE REAR (DEUTZ TD2.9L4 (CHINA IV) ENGINES) (860SJ HC3)​
FIGURE 2-43. HOOD ASSEMBLY - ENGINE SIDE REAR (DEUTZ TD2.9L4 (UN R96) & TD2.9L4 EMR5 ENGINES) (SHIPYARD MACHINES) (MACHINES WITH SN STARTING WITH B3) (860SJ HC3)​
FIGURE 2-44. HOOD ASSEMBLY - TANK SIDE REAR (DEUTZ TD2.9L4 (CHINA IV) ENGINES) (860SJ HC3)​
FIGURE 2-45. HOOD ASSEMBLY - TANK SIDE REAR (DEUTZ TD2.9L4 (UN R96) & TD2.9L4 EMR5 ENGINES) (SHIPYARD MACHINES) (MACHINES WITH SN STARTING WITH B3) (860SJ HC3)​
FIGURE 2-46. LIFTING PLATE INSTALLATION​
FIGURE 2-47. LIFTING PLATE INSTALLATION (REINFORCED) (860SJ HC3)​
FIGURE 2-48. LIGHT PANEL INSTALLATION (MACHINES WITH SN STARTING WITH 03 OR C3) (CE & UK CA (HRC) SPEC MACHINES WITH SN STARTING WITH B3)​
FIGURE 2-49. LIGHT PANEL INSTALLATION (MACHINES WITH SN STARTING WITH B3 ALL SPECS EXCEPT CE & UK CA (HRC) SPEC) (860SJ HC3)​
FIGURE 2-50. SKYAIR AIR COMPRESSOR INSTALLATION (ANSI EXPORT SPECS)​
FIGURE 2-51. SKYAIR AIR COMPRESSOR INSTALLATION (ANSI & CSA SPECS)​
FIGURE 2-52. AIR COMPRESSOR ASSEMBLY​
FIGURE 2-53. WHITE NOISE ALARM INSTALLATION - AMBIENT​
FIGURE 2-54. WHITE NOISE ALARM INSTALLATION - CONSTANT​
FIGURE 2-55. WHITE NOISE ALARM HARNESS​
SECTION 3 - ENGINE
FIGURE 3-1. DEUTZ TD2.9L4 (CHINA IV) ENGINE INSTALLATION (860SJ HC3)​
FIGURE 3-2. DEUTZ TD2.9L4 (CHINA IV) ENGINE AND PUMP SUB-ASSEMBLY (860SJ HC3)​
FIGURE 3-3. DEUTZ TD2.9L4 (CHINA IV) ENGINE ASSEMBLY (860SJ HC3)​
FIGURE 3-4. DEUTZ ENGINE COMPONENTS - CHINA IV (860SJ HC3)​
FIGURE 3-5. DEUTZ TD2.9L4 (STAGE V) ENGINE INSTALLATION (860SJ HC3)​
FIGURE 3-6. DEUTZ TD2.9L4 (STAGE V) ENGINE/PUMP SUB ASSEMBLY (860SJ HC3)​
FIGURE 3-7. DEUTZ TD2.9L4 (STAGE V) ENGINE ASSEMBLY (860SJ HC3)​
FIGURE 3-8. DEUTZ TD2.9L4 (STAGE V) ENGINE COMPONENTS (860SJ HC3)​
FIGURE 3-9. DEUTZ TD2.9L4 (UN R96) ENGINE INSTALLATION - WITHOUT ARCTIC PACKAGE (WITH PLASTIC HOODS) (860SJ HC3)​
FIGURE 3-10. DEUTZ TD2.9L4 (UN R96) ENGINE INSTALLATION - WITHOUT ARCTIC PACKAGE (WITH STEEL HOODS) (860SJ HC3)​
FIGURE 3-11. DEUTZ TD2.9L4 (UN R96) ENGINE AND PUMP SUB-ASSEMBLY - WITHOUT ARCTIC PACKAGE (860SJ HC3)​
FIGURE 3-12. DEUTZ TD2.9L4 (UN R96) ENGINE ASSEMBLY - WITHOUT ARCTIC PACKAGE (860SJ HC3)​
FIGURE 3-13. DEUTZ TD2.9L4 (UN R96) ENGINE INSTALLATION - WITH ARCTIC PACKAGE (WITH PLASTIC HOODS) (860SJ HC3)​
FIGURE 3-14. DEUTZ TD2.9L4 (UN R96) ENGINE INSTALLATION - WITH ARCTIC PACKAGE (WITH STEEL HOODS)​
FIGURE 3-15. DEUTZ TD2.9L4 (UN R96) ENGINE AND PUMP SUB-ASSEMBLY - WITH ARCTIC PACKAGE (WITH STEEL HOODS)​
FIGURE 3-16. DEUTZ TD2.9L4 (UN R96) ENGINE ASSEMBLY - WITH ARCTIC PACKAGE​
FIGURE 3-17. DEUTZ TD2.9L4 (UN R96) ENGINE COMPONENTS​
FIGURE 3-18. DEUTZ TD2.9L4 EMR5 ENGINE INSTALLATION - WITHOUT ARCTIC PACKAGE​
FIGURE 3-19. DEUTZ TD2.9L4 EMR5 ENGINE AND PUMP SUB-ASSEMBLY - WITHOUT ARCTIC PACKAGE​
FIGURE 3-20. DEUTZ TD2.9L4 EMR5 ENGINE ASSEMBLY - WITHOUT ARCTIC PACKAGE​
FIGURE 3-21. DEUTZ TD2.9L4 EMR5 ENGINE INSTALLATION - WITH ARCTIC PACKAGE​
FIGURE 3-22. DEUTZ TD2.9L4 EMR5 ENGINE AND PUMP SUB-ASSEMBLY - WITH ARCTIC PACKAGE​
FIGURE 3-23. DEUTZ TD2.9L4 EMR5 ENGINE ASSEMBLY - WITH ARCTIC PACKAGE​
FIGURE 3-24. DEUTZ TD2.9L4 EMR5 ENGINE COMPONENTS​
FIGURE 3-25. BREATHER HEATER INSTALLATION (DEUTZ TD2.9L4 (UN R96) & TD2.9L4 EMR5 ENGINES)​
FIGURE 3-26. FUEL PUMP/FILTER BRACKET ASSEMBLY (DEUTZ TD2.9L4 (STAGE V) & TD2.9L4 EMR5 ENGINES)​
FIGURE 3-27. FUEL PUMP/FILTER BRACKET ASSEMBLY (DEUTZ TD2.9L4 (CHINA IV) & TD2.9L4 (UN R96) ENGINES)​
FIGURE 3-28. FORD ENGINE INSTALLATION​
FIGURE 3-29. FORD ENGINE AND PUMP SUB-ASSEMBLY​
FIGURE 3-30. FORD ENGINE ASSEMBLY​
FIGURE 3-31. FORD ENGINE PREP ASSEMBLY​
FIGURE 3-32. FORD ENGINE BRACKETS AND EXHAUST MANIFOLD INSTALLATION​
FIGURE 3-33. FORD ENGINE DRIVE BELT INSTALLATION (MACHINES WITHOUT GENERATOR)​
FIGURE 3-34. FORD ENGINE COMPONENTS​
FIGURE 3-35. PUMP COUPING KIT (DEUTZ ENGINES)​
FIGURE 3-36. HYDROSTATIC PUMP ASSEMBLY (DEUTZ TD2.9L4 (CHINA IV), TD2.9L4 (UN R96), AND FORD ENGINES)​
FIGURE 3-37. HYDROSTATIC PUMP ASSEMBLY (DEUTZ TD2.9L4 (STAGE V) AND TD2.9L4 EMR5 ENGINES)​
FIGURE 3-38. VARIABLE PUMP ASSEMBLY (ALL ENGINES EXCEPT DEUTZ TD2.9L4 (CHINA IV) ENGINES)​
FIGURE 3-39. VARIABLE PUMP ASSEMBLY (DEUTZ TD2.9L4 (CHINA IV) ENGINES) (860SJ HC3)​
FIGURE 3-40. EXHAUST PIPE INSTALLATION - DEUTZ TD2.9L4 EMR5 ENGINES​
FIGURE 3-41. EXHAUST PIPE INSTALLATION - DEUTZ TD2.9L4 (STAGE V) ENGINES (860SJ HC3)​
FIGURE 3-42. EXHAUST PIPE INSTALLATION - FORD ENGINES​
FIGURE 3-43. SPARK ARRESTOR INSTALLATION (WITH STEEL HOODS)​
FIGURE 3-44. SPARK ARRESTOR INSTALLATION (WITH PLASTIC HOODS)​
FIGURE 3-45. FUEL-WATER SEPARATOR INSTALLATION​
FIGURE 3-46. FUEL FILTER ASSEMBLY​
FIGURE 3-47. ENGINE HOOD BAFFLE INSTALLATION - WITH ABS HOODS​
FIGURE 3-48. ENGINE HOOD BAFFLE INSTALLATION - WITH STEEL HOODS​
FIGURE 3-49. ENGINE TRAY JACK INSTALLATION - DEUTZ ENGINES​
FIGURE 3-50. ENGINE TRAY JACK INSTALLATION - FORD ENGINES​
FIGURE 3-51. QUICKFIT OIL DRAIN VALVE (DEUTZ ENGINES)​
FIGURE 3-52. 2500W/110V/60HZ GENERATOR INSTALLATION​
FIGURE 3-53. 2500W/120V/60HZ GENERATOR INSTALLATION​
FIGURE 3-54. 2500W/220V/50HZ GENERATOR INSTALLATION​
FIGURE 3-55. 4000W/50HZ GENERATOR INSTALLATION​
FIGURE 3-56. 4000W/60HZ GENERATOR INSTALLATION​
FIGURE 3-57. 7500W/50HZ SKYPOWER GENERATOR INSTALLATION​
FIGURE 3-58. 7500W/60HZ SKYPOWER GENERATOR INSTALLATION - DEUTZ TD2.9L4 (UN R96) & TD2.9L4 EMR5 ENGINES​
FIGURE 3-59. 7500W/60HZ SKYPOWER GENERATOR INSTALLATION - FORD ENGINES​
SECTION 4 - BOOM
FIGURE 4-1. BOOM AND CYLINDERS INSTALLATION (800S HC3)​
FIGURE 4-2. BOOM AND CYLINDERS INSTALLATION (MACHINES WITH SN STARTING WITH 03) (860SJ HC3)​
FIGURE 4-3. BOOM AND CYLINDERS INSTALLATION (MACHINES WITH SN STARTING WITH B3 OR C3) (860SJ HC3)​
FIGURE 4-4. MAIN BOOM ASSEMBLY (800S HC3)​
FIGURE 4-5. MAIN BOOM ASSEMBLY (MACHINES WITH SN STARTING WITH 03) (860SJ HC3)​
FIGURE 4-6. MAIN BOOM ASSEMBLY (MACHINES WITH SN STARTING WITH B3) (860SJ HC3)​
FIGURE 4-7. JIB BOOM ASSEMBLY (MACHINES WITH SN STARTING WITH 03) (860SJ HC3)​
FIGURE 4-8. JIB BOOM ASSEMBLY (MACHINES WITH SN STARTING WITH B3 OR C3) (860SJ HC3)​
FIGURE 4-9. PLATFORM ROTATOR ASSEMBLY (800S HC3)​
FIGURE 4-10. PLATFORM ROTATOR ASSEMBLY (MACHINES WITH SN STARTING WITH 03) (860SJ HC3)​
FIGURE 4-11. PLATFORM ROTATOR ASSEMBLY (MACHINES WITH SN STARTING WITH B3 OR C3) (860SJ HC3)​
FIGURE 4-12. TRADITIONAL PLATFORM SUPPORT (860SJ HC3)​
FIGURE 4-13. RAPID REPLACEABLE PLATFORM SUPPORT (MACHINES WITH SN STARTING WITH 03)​
FIGURE 4-14. RAPID REPLACEABLE PLATFORM SUPPORT (MACHINES WITH SN STARTING WITH B3 OR C3) (860SJ HC3)​
FIGURE 4-15. CONTROL VALVE INSTALLATION (800S HC3)​
FIGURE 4-16. CONTROL VALVE INSTALLATION (860SJ HC3) (Prior to SN C300003189, Including C300003290)​
FIGURE 4-17. CONTROL VALVE INSTALLATION (860SJ HC3) (SN B300031393 to Present, SN C300003189 to Present, Excluding C300003290)​
FIGURE 4-18. PLATFORM VALVE ASSEMBLY (800S HC3)​
FIGURE 4-19. PLATFORM VALVE ASSEMBLY (860SJ HC3)​
FIGURE 4-20. POWER TRACK INSTALLATION (800S HC3)​
FIGURE 4-21. POWER TRACK INSTALLATION (MACHINES WITH SN STARTING WITH 03) (860SJ HC3)​
FIGURE 4-22. POWER TRACK INSTALLATION (MACHINES WITH SN STARTING WITH B3 OR C3) (860SJ HC3)​
FIGURE 4-23. POWER TRACK SUPPORT BRACKET INSTALLATION​
FIGURE 4-24. LIMIT SWITCHES AND COVERS INSTALLATION (800S HC3)​
FIGURE 4-25. LIMIT SWITCHES AND COVERS INSTALLATION (860SJ HC3)​
FIGURE 4-26. LOWER SENSOR ASSEMBLY​
SECTION 5 - PLATFORM
FIGURE 5-1. TRADITIONAL PLATFORM ASSEMBLY - 30IN X 3FT (76CM X 1M) WITH DROP-BAR (860SJ HC3)​
FIGURE 5-2. TRADITIONAL PLATFORM ASSEMBLY - 30IN X 4FT (76CM X 1.22M) WITH DROP BAR (860SJ HC3)​
FIGURE 5-3. TRADITIONAL PLATFORM ASSEMBLY - 30IN X 4FT (76CM X 1.22M) WITH SWING GATE (860SJ HC3)​
FIGURE 5-4. TRADITIONAL PLATFORM ASSEMBLY - 30IN X 5FT (76CM X 1.52M) WITH DROP BAR (860SJ HC3)​
FIGURE 5-5. TRADITIONAL PLATFORM ASSEMBLY - 30IN X 5FT (76CM X 1.52M) WITH SWING GATE (860SJ HC3)​
FIGURE 5-6. TRADITIONAL PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) WITH 1 GATE / 2 DROP BARS (TRI-ENTRY) (860SJ HC3)​
FIGURE 5-7. TRADITIONAL PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) WITH 3 DROP BARS (TRI-ENTRY) (860SJ HC3)​
FIGURE 5-8. TRADITIONAL PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) WITH DROP BAR (860SJ HC3)​
FIGURE 5-9. TRADITIONAL PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) WITH SWING GATE (860SJ HC3)​
FIGURE 5-10. TRADITIONAL PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH 1 GATE / 2 DROP BARS (TRI-ENTRY) (860SJ HC3)​
FIGURE 5-11. TRADITIONAL PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH 3 DROP BARS (TRI-ENTRY) (860SJ HC3)​
FIGURE 5-12. TRADITIONAL PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH DROP BAR (860SJ HC3)​
FIGURE 5-13. TRADITIONAL PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH SWING GATE (860SJ HC3)​
FIGURE 5-14. RAPID REPLACEABLE PLATFORM - 30IN X 4FT (76.2CM X 1.22M) (MACHINES WITH SN STARTING WITH 03)​
FIGURE 5-15. RAPID REPLACEABLE PLATFORM - 30IN X 4FT (76.2CM X 1.22M) (MACHINES WITH SN STARTING WITH B3 OR C3) (860SJ HC3)​
FIGURE 5-16. RAPID REPLACEABLE PLATFORM - 30IN X 5FT (76.2CM X 1.52M) (MACHINES WITH SN STARTING WITH 03)​
FIGURE 5-17. RAPID REPLACEABLE PLATFORM - 30IN X 5FT (76.2CM X 1.52M) (MACHINES WITH SN STARTING WITH B3 OR C3) (860SJ HC3)​
FIGURE 5-18. RAPID REPLACEABLE PLATFORM - 36IN X 6FT (91.5CM X 1.83M) (MACHINES WITH SN STARTING WITH 03)​
FIGURE 5-19. RAPID REPLACEABLE PLATFORM - 36IN X 6FT (91.5CM X 1.83M) (MACHINES WITH SN STARTING WITH B3 OR C3) (860SJ HC3)​
FIGURE 5-20. RAPID REPLACEABLE PLATFORM - 36IN X 6FT (91.5CM X 1.83M) WITH FALL ARREST (MACHINES WITH SN STARTING WITH 03)​
FIGURE 5-21. RAPID REPLACEABLE PLATFORM - 36IN X 6FT (91.5CM X 1.83M) WITH FALL ARREST (MACHINES WITH SN STARTING WITH B3) (860SJ HC3)​
FIGURE 5-22. RAPID REPLACEABLE PLATFORM - 36IN X 8FT (91.5CM X 2.44M) (MACHINES WITH SN STARTING WITH 03)​
FIGURE 5-23. RAPID REPLACEABLE PLATFORM - 36IN X 8FT (91.5CM X 2.44M) (MACHINES WITH SN STARTING WITH B3 OR C3) (860SJ HC3)​
FIGURE 5-24. RAPID REPLACEABLE PLATFORM - 36IN X 8FT (91.5CM X 2.44M) WITH FALL ARREST (MACHINES WITH SN STARTING WITH 03)​
FIGURE 5-25. RAPID REPLACEABLE PLATFORM - 36IN X 8FT (91.5CM X 2.44M) WITH FALL ARREST (MACHINES WITH SN STARTING WITH B3) (860SJ HC3)​
FIGURE 5-26. RAPID REPLACEABLE PLATFORM - 36IN X 8FT (91.5CM X 2.44M) WITH 1 GATE / 2 DROP BARS (TRI-ENTRY) (MACHINES WITH SN STARTING WITH 03)​
FIGURE 5-27. RAPID REPLACEABLE PLATFORM - 36IN X 8FT (91.5CM X 2.44M) WITH 1 GATE / 2 DROP BARS (TRI-ENTRY) (MACHINES WITH SN STARTING WITH B3 OR C3) (860SJ HC3)​
FIGURE 5-28. PLATFORM - SWING GATE INSTALATION (MACHINES WITH SN STARTING WITH 03)​
FIGURE 5-29. PLATFORM SWING GATE INSTALLATION (MACHINES WITH SN STARTING WITH B3 OR C3) (860SJ HC3)​
FIGURE 5-30. PLATFORM - DROP BAR INSTALATION (MACHINES WITH SN STARTING WITH 03)​
FIGURE 5-31. PLATFORM DROP BAR INSTALLATION (MACHINES WITH SN STARTING WITH B3 OR C3) (860SJ HC3)​
FIGURE 5-32. PLATFORM CONSOLE AND FOOTSWITCH INSTALLATION (860SJ HC3) (Prior to SN C300003189, Including C300003290)​
FIGURE 5-33. PLATFORM CONSOLE ASSEMBLY (860SJ HC3) (Prior to SN C300003189, Including C300003290)​
FIGURE 5-34. PLATFORM CONSOLE AND FOOTSWITCH INSTALLATION (SN 0300342152 to Present, SN B300031393 to Present, SN C300003189 to Present, Excluding C300003290)​
FIGURE 5-35. PLATFORM CONSOLE ASSEMBLY (SN 0300342152 to Present, SN B300031393 to Present, SN C300003189 to Present, Excluding C300003290)​
FIGURE 5-36. PLATFORM BEACON INSTALLATION (WITHOUT CLEARSKY BEACON)​
FIGURE 5-37. FOOTSWITCH ASSEMBLY​
FIGURE 5-38. LIGHT PANEL INSTALLATION (MACHINES WITH SN STARTING WITH 03 OR C3) (CE & UK CA (HRC) SPEC MACHINES WITH SN STARTING WITH B3)​
FIGURE 5-39. LIGHT PANEL INSTALLATION (MACHINES WITH SN STARTING WITH B3 ALL SPECS EXCEPT CE & UK CA (HRC) SPEC) (860SJ HC3)​
FIGURE 5-40. FALL ARREST INSTALLATION (BOLT-ON) (4FT/1.22M PLATFORM)​
FIGURE 5-41. FALL ARREST INSTALLATION (BOLT-ON) (6FT/1.82M PLATFORM)​
FIGURE 5-42. FALL ARREST INSTALLATION (BOLT-ON) (8FT/2.4M PLATFORM)​
FIGURE 5-43. JIB SWITCH INSTALLATION (860SJ HC3)​
FIGURE 5-44. SKYLINE INSTALLATION (860SJ HC3) (Prior to SN C300003189, Including C300003290)​
FIGURE 5-45. SKYLINE INSTALLATION (SN 0300342152 to Present, SN B300031393 to Present, SN C300003189 to Present, Excluding C300003290)​
FIGURE 5-46. STORAGE TRAY INSTALLATION - CENTER​
FIGURE 5-47. SKYGLAZIER INSTALLATION​
FIGURE 5-48. SKYWELDER INSTALLATION (50HZ)​
FIGURE 5-49. SKYWELDER INSTALLATION (60HZ)​
FIGURE 5-50. WELDER ASSEMBLY​
FIGURE 5-51. SKYWELDER PREP PACKAGE (60HZ)​
FIGURE 5-52. SOFT TOUCH SYSTEM INSTALLATION - 6FT/1.83M PLATFORM​
FIGURE 5-53. SOFT TOUCH SYSTEM INSTALLATION - 6FT/1.83M FALL ARREST PLATFORM​
FIGURE 5-54. SOFT TOUCH SYSTEM INSTALLATION - 8FT/2.44M PLATFORM​
FIGURE 5-55. SOFT TOUCH SYSTEM INSTALLATION - 8FT/2.44M FALL ARREST PLATFORM​
FIGURE 5-56. USB CHARGER INSTALLATION (860SJ HC3) (Prior to SN C300003189, Including C300003290)​
FIGURE 5-57. USB CHARGER INSTALLATION (SN 0300342152 to Present, SN B300031393 to Present, SN C300003189 to Present, Excluding C300003290)​
SECTION 6 - CYLINDER
FIGURE 6-1. AXLE LOCKOUT CYLINDER ASSEMBLY (MACHINES WITH SN STARTING WITH 03)​
FIGURE 6-2. AXLE LOCKOUT CYLINDER ASSEMBLY (MACHINES WITH SN STARTING WITH B3 OR C3) (860SJ HC3)​
FIGURE 6-3. LEVEL CYLINDER ASSEMBLY (800S HC3)​
FIGURE 6-4. LEVEL CYLINDER ASSEMBLY (860SJ HC3)​
FIGURE 6-5. LIFT CYLINDER ASSEMBLY - JIB (860SJ HC3)​
FIGURE 6-6. LIFT CYLINDER ASSEMBLY - MAIN BOOM (800S HC3)​
FIGURE 6-7. LIFT CYLINDER ASSEMBLY - MAIN BOOM (860SJ HC3)​
FIGURE 6-8. STEER CYLINDER ASSEMBLY​
FIGURE 6-9. TELESCOPE CYLINDER ASSEMBLY (800S HC3)​
FIGURE 6-10. TELESCOPE CYLINDER ASSEMBLY (MACHINES WITH SN STARTING WITH 03) (860SJ HC3)​
FIGURE 6-11. TELESCOPE CYLINDER SUB-ASSEMBLY (MACHINES WITH SN STARTING WITH B3 OR C3) (860SJ HC3)​
FIGURE 6-12. TELESCOPE CYLINDER ASSEMBLY (MACHINES WITH SN STARTING WITH B3 OR C3) (860SJ HC3)​
SECTION 7 - HYDRAULIC
FIGURE 7-1. HYDRAULIC DIAGRAM - AXLE (OSCILLATING)​
FIGURE 7-2. HYDRAULIC DIAGRAM - DRIVE (WITHOUT TOW BAR PACKAGE) (DEUTZ TD2.9L4 (CHINA IV), TD2.9L4 (UN R96), & FORD ENGINES)​
FIGURE 7-3. HYDRAULIC DIAGRAM - DRIVE (WITH TOW BAR PACKAGE) (DEUTZ TD2.9L4 (CHINA IV), TD2.9L4 (UN R96), & FORD ENGINES)​
FIGURE 7-4. HYDRAULIC DIAGRAM - DRIVE (WITHOUT TOW BAR PACKAGE) (DEUTZ TD2.9L4 (STAGE V) AND TD2.9L4 EMR5 ENGINES)​
FIGURE 7-5. HYDRAULIC DIAGRAM - DRIVE (WITH TOWBAR PACKAGE ) (DEUTZ TD2.9L4 EMR5 ENGINES)​
FIGURE 7-6. HYDRAULIC DIAGRAM - STANDARD (WITHOUT TOW BAR PACKAGE) (800S HC3)​
FIGURE 7-7. HYDRAULIC DIAGRAM - STANDARD (WITH TOW BAR PACKAGE) (800S HC3)​
FIGURE 7-8. HYDRAULIC DIAGRAM - STANDARD (WITHOUT TOW BAR PACKAGE) (SN STARTING WITH 03) (860SJ HC3)​
FIGURE 7-9. HYDRAULIC DIAGRAM - STANDARD (WITH TOW BAR PACKAGE) (SN STARTING WITH 03) (860SJ HC3)​
FIGURE 7-10. HYDRAULIC DIAGRAM - STANDARD (WITHOUT TOW BAR PACKAGE) (SN STARTING WITH B3 OR C3) (860SJ HC3)​
FIGURE 7-11. HYDRAULIC DIAGRAM - STANDARD (WITH TOW BAR PACKAGE) (SN STARTING WITH B3) (860SJ HC3)​
SECTION 8 - ELECTRICAL
FIGURE 8-1. AC BOX AT PLATFORM - 110V GFI RECEPTACLE​
FIGURE 8-2. AC BOX AT PLATFORM - 110V IEC YELLOW (WITHOUT GENERATOR) (860SJ HC3) (Prior to SN C300003189, Including C300003290)​
FIGURE 8-3. AC BOX AT PLATFORM - 110V IEC YELLOW (WITHOUT GENERATOR) (860SJ HC3) (SN 0300342152 to Present, SN B300031393 to Present, SN C300003189 to Present, Excluding C300003290)​
FIGURE 8-4. AC BOX AT PLATFORM - 110V IEC YELLOW (WITH 2500W GENERATOR) (860SJ HC3) (Prior to SN C300003189, Including C300003290)​
FIGURE 8-5. AC BOX AT PLATFORM - 110V IEC YELLOW (WITH 2500W GENERATOR) (860SJ HC3) (SN 0300342152 to Present, SN B300031393 to Present, SN C300003189 to Present, Excluding C300003290)​
FIGURE 8-6. AC BOX AT PLATFORM - 110V IEC YELLOW (WITH 4000W GENERATOR) (860SJ HC3) (Prior to SN C300003189, Including C300003290)​
FIGURE 8-7. AC BOX AT PLATFORM - 110V IEC YELLOW (WITH 4000W GENERATOR) (860SJ HC3) (SN 0300342152 to Present, SN B300031393 to Present, SN C300003189 to Present, Excluding C300003290)​
FIGURE 8-8. AC BOX AT PLATFORM - 220V AFSNIT 107 (WITH 2500W GENERATOR) (860SJ HC3) (Prior to SN C300003189, Including C300003290)​
FIGURE 8-9. AC BOX AT PLATFORM - 220V AFSNIT 107 (WITH 2500W GENERATOR) (860SJ HC3) (SN 0300342152 to Present, SN B300031393 to Present, SN C300003189 to Present, Excluding C300003290)​
FIGURE 8-10. AC BOX AT PLATFORM - 220V CEE7 POST GROUND (WITH 2500W GENERATOR) (860SJ HC3) (Prior to SN C300003189, Including C300003290)​
FIGURE 8-11. AC BOX AT PLATFORM - 220V CEE7 POST GROUND (WITH 2500W GENERATOR) (860SJ HC3) (SN 0300342152 to Present, SN B300031393 to Present, SN C300003189 to Present, Excluding C300003290)​
FIGURE 8-12. AC BOX AT PLATFORM - 220V CEE7 SIDE GROUND (WITH 2500W GENERATOR) (860SJ HC3) (Prior to SN C300003189, Including C300003290)​
FIGURE 8-13. AC BOX AT PLATFORM - 220V CEE7 SIDE GROUND (WITH 2500W GENERATOR) (860SJ HC3) (SN 0300342152 to Present, SN B300031393 to Present, SN C300003189 to Present, Excluding C300003290)​
FIGURE 8-14. AC BOX AT PLATFORM - 220V IEC BLUE (WITH 2500W GENERATOR) (860SJ HC3) (Prior to SN C300003189, Including C300003290)​
FIGURE 8-15. AC BOX AT PLATFORM - 220V IEC BLUE (WITH 2500W GENERATOR) (860SJ HC3) (SN 0300342152 to Present, SN B300031393 to Present, SN C300003189 to Present, Excluding C300003290)​
FIGURE 8-16. AC BOX AT PLATFORM - 220V RECEPTACLE​
FIGURE 8-17. AC BOX AT PLATFORM - 240V AFSNIT 107 (WITHOUT GENERATOR) (860SJ HC3) (Prior to SN C300003189, Including C300003290)​
FIGURE 8-18. AC BOX AT PLATFORM - 240V AFSNIT 107 (WITHOUT GENERATOR) (860SJ HC3) (SN 0300342152 to Present, SN B300031393 to Present, SN C300003189 to Present, Excluding C300003290)​
FIGURE 8-19. AC BOX AT PLATFORM - 240V AFSNIT 107 (WITH 4000W GENERATOR) (860SJ HC3) (Prior to SN C300003189, Including C300003290)​
FIGURE 8-20. AC BOX AT PLATFORM - 240V AFSNIT 107 (WITH 4000W GENERATOR) (860SJ HC3) (SN 0300342152 to Present, SN B300031393 to Present, SN C300003189 to Present, Excluding C300003290)​
FIGURE 8-21. AC BOX AT PLATFORM - 240V BOX ONLY (860SJ HC3) (Prior to SN C300003189, Including C300003290)​
FIGURE 8-22. AC BOX AT PLATFORM - 240V BOX ONLY (SN 0300342152 to Present, SN B300031393 to Present, SN C300003189 to Present, Excluding C300003290)​
FIGURE 8-23. AC BOX AT PLATFORM - 240V CEE7 POST GROUND (WITHOUT GENERATOR) (860SJ HC3) (Prior to SN C300003189, Including C300003290)​
FIGURE 8-24. AC BOX AT PLATFORM - 240V CEE7 POST GROUND (WITHOUT GENERATOR) (860SJ HC3) (SN 0300342152 to Present, SN B300031393 to Present, SN C300003189 to Present, Excluding C300003290)​
FIGURE 8-25. AC BOX AT PLATFORM - 240V CEE7 POST GROUND (WITH 4000W GENERATOR) (860SJ HC3) (Prior to SN C300003189, Including C300003290)​
FIGURE 8-26. AC BOX AT PLATFORM - 240V CEE7 POST GROUND (WITH 4000W GENERATOR) (860SJ HC3) (SN 0300342152 to Present, SN B300031393 to Present, SN C300003189 to Present, Excluding C300003290)​
FIGURE 8-27. AC BOX AT PLATFORM - 240V CEE7 SIDE GROUND (WITHOUT GENERATOR) (860SJ HC3) (Prior to SN C300003189, Including C300003290)​
FIGURE 8-28. AC BOX AT PLATFORM - 240V CEE7 SIDE GROUND (WITHOUT GENERATOR) (860SJ HC3) (SN 0300342152 to Present, SN B300031393 to Present, SN C300003189 to Present, Excluding C300003290)​
FIGURE 8-29. AC BOX AT PLATFORM - 240V CEE7 SIDE GROUND (WITH 4000W GENERATOR) (860SJ HC3) (Prior to SN C300003189, Including C300003290)​
FIGURE 8-30. AC BOX AT PLATFORM - 240V CEE7 SIDE GROUND (WITH 4000W GENERATOR) (860SJ HC3) (SN 0300342152 to Present, SN B300031393 to Present, SN C300003189 to Present, Excluding C300003290)​
FIGURE 8-31. AC BOX AT PLATFORM - 240V GFCI RECEPTACLE (WITH 4000W GENERATOR)​
FIGURE 8-32. AC BOX AT PLATFORM - 240V GFCI RECEPTACLE (WITH 7500W SKYPOWER GENERATOR)​
FIGURE 8-33. AC BOX AT PLATFORM - 240V IEC BLUE (WITHOUT GENERATOR) (860SJ HC3) (Prior to SN C300003189, Including C300003290)​
FIGURE 8-34. AC BOX AT PLATFORM - 240V IEC BLUE (WITHOUT GENERATOR) (860SJ HC3) (SN 0300342152 to Present, SN B300031393 to Present, SN C300003189 to Present, Excluding C300003290)​
FIGURE 8-35. AC BOX AT PLATFORM - 240V IEC BLUE (WITH 4000W GENERATOR) (860SJ HC3) (Prior to SN C300003189, Including C300003290)​
FIGURE 8-36. AC BOX AT PLATFORM - 240V IEC BLUE (WITH 4000W GENERATOR) (860SJ HC3) (SN 0300342152 to Present, SN B300031393 to Present, SN C300003189 to Present, Excluding C300003290)​
FIGURE 8-37. AC CABLE INSTALLATION (WITHOUT GENERATOR) (ALL SPECS EXCEPT CHINA SPEC)​
FIGURE 8-38. AC CABLE INSTALLATION (WITHOUT GENERATOR) (CHINA SPECS) (860SJ HC3)​
FIGURE 8-39. AC CABLE WITH 10 AMP BREAKER INSTALLATION​
FIGURE 8-40. AC CABLE WITH 16 AMP BREAKER INSTALLATION​
FIGURE 8-41. ANALYZER CABLE HARNESS​
FIGURE 8-42. BATTERY DISCONNECT SWITCH INSTALLATION​
FIGURE 8-43. BOOM CABLES INSTALLATION - WITHOUT AC CABLES (860SJ HC3)​
FIGURE 8-44. BOOM CABLES INSTALLATION - WITH 2500W 50HZ/60HZ AND 4000W 50HZ GENERATORS (800S HC3)​
FIGURE 8-45. BOOM CABLES INSTALLATION - WITH 2500W 50HZ/60HZ AND 4000W 50HZ GENERATORS (860SJ HC3)​
FIGURE 8-46. BOOM CABLES INSTALLATION - WITH 4000W 60HZ GENERATOR (800S HC3)​
FIGURE 8-47. BOOM CABLES INSTALLATION - WITH 4000W 60HZ GENERATOR (860SJ HC3)​
FIGURE 8-48. BOOM CABLES INSTALLATION - WITH 7500W GENERATORS (800S HC3)​
FIGURE 8-49. BOOM CABLES INSTALLATION - WITH 7500W GENERATORS (860SJ HC3)​
FIGURE 8-50. BOOM HARNESS (MAIN BOOM) (800S HC3)​
FIGURE 8-51. BOOM HARNESS (MAIN BOOM) (860SJ HC3)​
FIGURE 8-52. BOOM HARNESS (TOWER BOOM)​
FIGURE 8-53. BREAKER BOX KIT - 10 AMP BREAKER​
FIGURE 8-54. BREAKER BOX KIT - 16AMP DOUBLE BREAKER (10 GAUGE CABLE)​
FIGURE 8-55. BREAKER BOX KIT - 16AMP DOUBLE BREAKER (12 GAUGE CABLE)​
FIGURE 8-56. CLEARSKY CS550 BEACON INSTALLATION​
FIGURE 8-57. CSB HARNESS​
FIGURE 8-58. ENGINE HARNESS - DEUTZ ENGINES​
FIGURE 8-59. ECU POWER JUMPER HARNESS​
FIGURE 8-60. FUEL FILTER HARNESS - DEUTZ TD2.9L4 (STAGE V) ENGINES​
FIGURE 8-61. FUEL HARNESS - DEUTZ ENGINES​
FIGURE 8-62. GENERATOR TO ENGINE HARNESS - 2500W/110V/60HZ GENERATOR​
FIGURE 8-63. GENERATOR TO ENGINE HARNESS - 4000W/50HZ GENERATOR​
FIGURE 8-64. GENERATOR TO ENGINE HARNESS - 4000W/50HZ & 4000W/60HZ GENERATORS​
FIGURE 8-65. GENERATOR TO ENGINE HARNESS - 7500W GENERATORS (DEUTZ ENGINES)​
FIGURE 8-66. GENERATOR TO ENGINE HARNESS - 7500W GENERATORS (FORD ENGINES)​
FIGURE 8-67. GROUND CONTROL BOX HARNESS​
FIGURE 8-68. GROUND CONTROL ENGINE HARNESS - DEUTZ ENGINES​
FIGURE 8-69. GROUND CONTROL ENGINE HARNESS - FORD ENGINES​
FIGURE 8-70. HOLDING VALVE/LIFT DUMP HARNESS ASSEMBLY​
FIGURE 8-71. PLATFORM BEACON HARNESS​
FIGURE 8-72. PLATFORM CONSOLE BOX HARNESS​
FIGURE 8-73. RECEPTACLE BOX KIT - 110V IEC YELLOW (WITHOUT GENERATOR) (860SJ HC3)​
FIGURE 8-74. RECEPTACLE BOX KIT - 110V IEC YELLOW (WITH 2500W GENERATOR) (860SJ HC3)​
FIGURE 8-75. RECEPTACLE BOX KIT - 220V AFSNIT 107 (WITH 2500W GENERATOR) (860SJ HC3)​
FIGURE 8-76. RECEPTACLE BOX KIT - 220V CEE7 POST GROUND (WITH 2500W GENERATOR) (860SJ HC3)​
FIGURE 8-77. RECEPTACLE BOX KIT - 220V CEE7 SIDE GROUND (WITH 2500W GENERATOR) (860SJ HC3)​
FIGURE 8-78. RECEPTACLE BOX KIT - 240V IEC BLUE (WITHOUT GENERATOR) (860SJ HC3)​
FIGURE 8-79. RECEPTACLE BOX KIT - 220V IEC BLUE (WITH 2500W GENERATOR) (860SJ HC3)​
FIGURE 8-80. RECEPTACLE BOX KIT - 240V AFSNIT 107 (WITHOUT GENERATOR) (860SJ HC3)​
FIGURE 8-81. RECEPTACLE BOX KIT - 240V CEE7 POST GROUND (WITHOUT GENERATOR) (860SJ HC3)​
FIGURE 8-82. RECEPTACLE BOX KIT - 240V CEE7 SIDE GROUND (WITHOUT GENERATOR) (860SJ HC3)​
FIGURE 8-83. SKYLINE HARNESS​
FIGURE 8-84. STROBE LIGHT JUMPER HARNESS​
FIGURE 8-85. UPPER VALVE HARNESS​
FIGURE 8-86. USB HARNESS​
FIGURE 8-87. VALVE HARNESS​
FIGURE 8-88. WORKLIGHT HARNESS​
SECTION 9 - DECALS
FIGURE 9-1. DECAL INSTALLATION - ENGLISH LANGUAGE (ANSI, ANSI EXPORT & CSA SPECS) (800S HC3)​
FIGURE 9-2. DECAL INSTALLATION - ENGLISH LANGUAGE (ANSI, ANSI EXPORT & CSA SPECS) (860SJ HC3)​
FIGURE 9-3. DECAL INSTALLATION - ENGLISH LANGUAGE (AUSTRALIAN SPEC) (860SJ HC3)​
FIGURE 9-4. DECAL INSTALLATION - ENGLISH LANGUAGE (CE, CHINA, RUSSIAN & UK CA SPECS) (860SJ HC3)​
FIGURE 9-5. DECAL INSTALLATION - CHINESE/ENGLISH LANGUAGES (800S HC3)​
FIGURE 9-6. DECAL INSTALLATION - CHINESE/ENGLISH LANGUAGES (860SJ HC3)​
FIGURE 9-7. DECAL INSTALLATION - FRENCH/ENGLISH LANGUAGES (800S HC3)​
FIGURE 9-8. DECAL INSTALLATION - FRENCH/ENGLISH LANGUAGES (860SJ HC3)​
FIGURE 9-9. DECAL INSTALLATION - JAPANESE/ENGLISH LANGUAGES (800S HC3)​
FIGURE 9-10. DECAL INSTALLATION - JAPANESE/ENGLISH LANGUAGES (860SJ HC3)​
FIGURE 9-11. DECAL INSTALLATION - KOREAN/ENGLISH LANGUAGES (800S HC3)​
FIGURE 9-12. DECAL INSTALLATION - KOREAN/ENGLISH LANGUAGES (860SJ HC3)​
FIGURE 9-13. DECAL INSTALLATION - PORTUGUESE/ENGLISH LANGUAGES (800S HC3)​
FIGURE 9-14. DECAL INSTALLATION - PORTUGUESE/ENGLISH LANGUAGES (860SJ HC3)​
FIGURE 9-15. DECAL INSTALLATION - SPANISH/ENGLISH LANGUAGES (800S HC3)​
FIGURE 9-16. DECAL INSTALLATION - SPANISH/ENGLISH LANGUAGES (860SJ HC3)​
FIGURE 9-17. DECAL INSTALLATION - OPTIONS​
FIGURE 9-18. SKYWELDER DECAL INSTALLATION - 50HZ​
FIGURE 9-19. SKYWELDER DECAL INSTALLATION - 60HZ​
SECTION 11 - SPECIAL OPTIONS/ACCESSORIES/KITS
PART NUMBER INDEX
