JLG Boom Lift 800S HC3 860SJ HC3 Operation Safety Manual 31223065
Brand: JLG
Type of Machine: Boom Lift
Type of Manual: Operation Safety Manual
Model: JLG 800S HC3, 860SJ HC3 Boom Lift
Part Number: 31223065
Publication Date: 2024
Number of Pages: 162 Pages
800S HC3 860JS HC3 PVC 2401 cover page
Foreword
800S HC3 860SJ HC3 2401 revision log
Brand: JLG
Foreword
Other Publications Available
Safety PrecautionsGeneral
Pre-Operation
1.2.1 Operator Training and Knowledge
1.2.2 Workplace Inspection
1.2.3 Machine Inspection
Operation
1.3.1 General
1.3.2 Trip and Fall Hazards
1.3.3 Electrocution Hazards
1.3.4 Tipping Hazards
1.3.5 Crushing and Collision Hazards
Towing, Lifting, and Hauling
Maintenance
1.5.1 Maintenance Hazards
1.5.2 Battery Hazards
User Responsibilities, Machine Preparation, and InspectionPersonnel Training
2.1.1 Operator Training
2.1.2 Training Supervision
2.1.3 Operator Responsibility
2.1.4 Machine Familiarization
Preparation, Inspection and Maintenance
Machine Components
Pre-Start Inspection
Walk-Around Inspection
2.5.1 Walk-Around Inspection
Function Check - SJ Model
SkyGuard® Function Check
Oscillating Axle Lockout Test (If Equipped)
Machine Controls and IndicatorsGeneral
Ground Control Station
3.3.1 800S HC3 Ground Control Station
3.3.2 860SJ HC3 Ground Control Station
Ground Control Indicator Panel - ICE HC3 - Fuel Gauge
3.4.1 Ground Control Indicator Panel Functions
800S/860SJ Platform Control Station
3.5.1 Platform Control Station Functions
Platform Indicator Panel - ICE HC3 - Fuel Gauge
3.6.1 Platform Control Indicator Panel Functions
Beacons (With SkyGuard)
3.7.1 ClearSky® LED Motion / Amber Beacon (CS550)
3.7.2 Amber Beacon
3.7.3 Blue or Red SkyGuard® Beacon
Machine OperationGeneral SJ 360 Continuous Swing
Operating Characteristics And Limitations - 800 HC3
4.2.1 Operating Conditions
4.2.2 Platform Load Sensing System (LSS)
4.2.3 Capacity Zones (Triple Capacity)
800S/860SJ HC3 Reach Chart
800S/860SJ Stability
Engine Operation
4.5.1 Starting Procedure
4.5.2 Shutdown Procedure
Fuel Shutoff System (Reserve) - Fuel Gauge
Diesel Particulate Filter (If Equipped)
Traveling (Driving)
4.8.1 Traveling Forward and Reverse
Air Shutoff Valve (ASOV)
800S/860SJ Traveling (Grade/Side Slope)
4.10.1 Traveling on a Grade
Steering
Platform - Standard Booms
4.12.1 Platform Level Adjustment
4.12.2 Platform Rotation
Boom - SJ Models
4.13.1 Swinging the Boom
4.13.2 Raising and Lowering the Main Boom
4.13.3 Telescoping the Main Boom
Function Speed Control - SJ Core Boom
USB Charging Port
ClearSky Smart Fleet
Access Control (Boom)
Machine Safety System Override (MSSO) (If Equipped)
SkyGuard Activation/Deactivation - SJ
Emergency Towing
Towing (If Equipped)
Shut Down And Park
Lifting And Tie Down
4.24.1 Lifting
4.24.2 Tie Down
800SJ
800S HC3 860SJ HC3 Safety Decals
4.26.1 Safety Decal Locations
Emergency ProceduresGeneral
Incident Notification - Boom
Emergency Operation
5.3.1 Operator Unable to Control Machine
5.3.2 Platform or Boom Caught Overhead
Emergency Towing Procedures
ClearSky Smart Fleet - Locked Out State
Accessories800S HC3 860SJ HC3 Accessory Table
Bolt-On External Fall Arrest
6.2.1 Inspection Before Use
Fabric Mesh to Mid/Top Rail
Fall Arrest Platform
6.4.1 Safety Precautions
Nite Bright
Pipe Racks
6.6.1 Capacity Specifications (Australia Only)
6.6.2 Safety Precautions
6.6.3 Preparation and Inspection
6.6.4 Operation
Platform Mesh to Mid/Top Rail
Platform Mid Rail Deck
6.8.1 Accessory Installation
6.8.2 Access to Manual Box
Platform Top Rail Extension
Platform Work Lights
Platform Work Surface
SkyAir
6.12.1 Compressor Specifications
6.12.2 Accessory Ratings
6.12.3 Safety Precautions
6.12.4 Preparation and Inspection
6.12.5 Operation
SkyCutter
6.13.1 Safety Precautions
6.13.2 Generator Output
6.13.3 Preparation and Inspection
6.13.4 Operation
6.13.5 Accessory Ratings
SkyGlazier
6.14.1 Capacity Specifications
6.14.2 Safety Precautions
6.14.3 Preparation and Inspection
6.14.4 Operation
SkyPower 7.5kW and Generator 4kW
6.15.1 Output
6.15.2 Safety Precautions
6.15.3 Preparation and Inspection
6.15.4 Operation
SkySense
6.16.1 Preparation and Inspection
6.16.2 Operation
6.16.3 SkySense Platform Panel Indicators
6.16.4 SkySense Alarm
6.16.5 SkySense Override Button
6.16.6 SkySense Coverage Areas
SkySense Platform Bumper Padding
SkyWelder
6.18.1 Operation
6.18.2 Generator Output
6.18.3 Welding Accessories
6.18.4 Safety Precautions
6.18.5 Preparation and Inspection
Soft Touch
General Specifications and Operator MaintenanceGeneral
800S/860SJ HC3 Operating Specifications
7.2.1 Specifications and Performance Data
7.2.2 Capacities
7.2.3 Engine Data
7.2.4 Battery
7.2.5 Tires
7.2.6 Major Component Weights
Serial Number Location 800S/860SJ
Hydraulic Oil Specifications - Introduction
Hydraulic Oil Operating Temperature - Deutz/Ford
Engine Oil Operating Temp Spec - Introduction Note
Engine Oil Operating Temp Spec - Deutz 2011
Engine Oil Operating Temp Spec - Deutz Engine
Engine Oil Operating Temp Spec - Ford Engine
Operator Maintenance and Lubrication Diagram 800S/860SJ
Operator Maintenance 800S/860SJ
Tires and Wheels - 10 Lug Nuts
7.12.1 Tire Damage
7.12.2 Tire Replacement
7.12.3 Wheel Replacement
7.12.4 Wheel Installation
Propane Fuel Filter Replacement (GM Engine)
7.13.1 Removal
7.13.2 Installation
Propane Fuel System Pressure Relief
Radio Frequency (RF) Information
7.15.1 Federal Communications Commission (FCC)
7.15.2 Innovation, Science and Economic Development (ISED)
Supplemental Information Only Applicable to CE/UKCA
800S/860SJ/800S HC3/860SJ HC3 EC Declaration of Conformity
800S/860SJ/800S HC3/860SJ HC3 UKCA Declaration of Conformity
- SuperPac Parts Manual
- StratoLift Parts Manual
