Hyundai
86
176,834
JLG Boom Lift 800S, 860SJ Service & Maintenance Manual 3122561600 2026
Brand: JLG
Type of Machine: Boom Lift
Model: JLG 800S, 860SJ Boom Lift
Part Number: 3122561600
Publication Date: 2026
Number of Pages: 856 Pages
Safety
General​
1.1.1 Disclaimer​
Safety Information​
Safety Hazards​
1.3.1 Personal Hazards​
1.3.2 Equipment Hazards​
1.3.3 General Hazards​
1.3.4 Operational Hazards​
Safety Decals​
Machine Verification​
Specifications​
2.1.1 Machine Specifications​
2.1.2 Machine Dimensional Data​
2.1.3 Engine Data​
2.1.4 Tires​
2.1.5 Critical Stability Weights​
2.1.6 Torque Requirements​
2.1.7 Pressure Settings​
2.1.8 Battery​
Machine Temperature Chart​
Serial Number Location​
Fluids and Lubrication​
2.4.1 General Information​
2.4.2 Hydraulic Oil​
2.4.3 Changing Hydraulic Oil​
2.4.4 Lubrication Specifications​
2.4.5 Fluids​
2.4.6 Capacities​
2.4.7 Lubrication Schedule​
Machine Characteristics​
2.5.1 Ground Control Keyswitch System​
2.5.2 Platform Control Enable System​
2.5.3 Cold Start System (Diesel)​
2.5.4 Fuel level Cutout System​
2.5.5 HRC Engine Emission Characteristics​
2.5.6 Diesel Particulate Filter (If Equipped)​
2.5.7 Drive System​
2.5.8 Drive Orientation System​
2.5.9 Function Speed Control System​
2.5.10 Oscillating Axle System​
2.5.11 Chassis Tilt Indicator System​
2.5.12 Platform Load Sensing System​
2.5.13 Auxiliary Power System​
2.5.14 Tires and Counterweight​
2.5.15 Platform​
2.5.16 Transport Position Sensing System​
2.5.17 Beyond Transport - Drive Speed Cutback System​
2.5.18 Drive/Steer – Boom Function Interlock System​
2.5.19 Dual Capacity System​
2.5.20 Ground Panel Display​
2.5.21 Main Lift Soft Stop Control System​
Clearsky Smart Fleet (If Equipped)​
2.6.1 General​
2.6.2 ClearSky Smart Fleet™ — Access Control​
Machine Preparation, Inspection, and Maintenance​
3.1.1 General​
3.1.2 Preparation, Inspection, and Maintenance​
3.1.3 Pre-Start Inspection​
3.1.4 Pre-Delivery Inspection and Frequent Inspection​
3.1.5 Annual Machine Inspection​
3.1.6 Preventive Maintenance​
Service and Guidelines​
3.2.1 General​
3.2.2 Safety and Workmanship​
3.2.3 Cleanliness​
3.2.6 Pressure-Fit Parts​
3.2.7 Bearings​
3.2.8 Gaskets​
3.2.11 Hydraulic System​
3.2.12 Lubrication​
3.2.13 Battery​
3.2.14 Welding on JLG Equipment​
Preventive Maintenance and Inspection Schedule​
3.3.1 First 50 Hours​
3.3.2 Every 150 Hours or 3 Months​
3.3.3 First 300 Hours or 6 Months​
3.3.4 Every 600 Hours or 1 Year​
3.3.5 Every 1200 Hours or 1 Year​
3.3.6 Every 1200 Hours or 2 Years​
Pins and Composite Bearing Repair Guidelines​
Tires and Wheels​
3.5.1 Tire Inflation​
3.5.2 Tire Damage​
Fuel Tank Inspection​
Boom Inspection and Maintenance​
3.7.1 Wire Rope Tensioning Procedure​
3.7.2 Wire Rope​
3.7.3 Boom Cleanliness Guidelines​
3.7.4 Boom Wear Pad Inspection​
Hydraulic Filter Replacement​
3.8.1 Hydraulic Filter Removal​
3.8.2 Hydraulic Filter Installation​
Turntable Bearing Inspection​
3.9.1 Turntable Bearing Mounting Bolt Condition Check​
Engine General Inspection​
3.10.1 General Maintenance​
3.10.2 Checking Oil Level​
3.10.3 Changing Engine Oil​
3.10.4 Replacing the Oil Filter​
3.10.5 Replacing the Primary Fuel Filters​
3.10.6 Replacing the Fuel Pre-Filter​
3.10.7 Water in Fuel Sensing System (Optional)​
3.10.8 Draining Water​
3.10.9 Auxiliary Fuel Filter​
3.10.10 Clean Fuel Strainer for Deutz D2011LO40 (only)​
3.10.11 Spark Arrester Cleaning Instructions for Deutz D2011LO40 (only)​
3.10.12 Glow Plugs​
Bio Fuel In Deutz Engines​
3.11.1 General​
3.11.2 Bio Fuel​
3.11.3 Biological Contamination In Fuels​
Deutz EMR2​
Deutz EMR5​
Generator Inspection​
3.14.1 2500W Generator​
3.14.2 4000W Generator​
3.14.3 7500W Generator​
Testing, Calibrations and Special Procedures
Special Tools​
4.1.1 Multimeter Basics​
4.1.2 Threadlocking Compound​
4.1.3 Tools Catalog​
Testing Procedures​
4.2.1 Starter​
4.2.2 SkyGuard​
4.2.3 LSS Testing and Evaluation​
4.2.4 Troubleshooting​
Calibration Procedures​
4.3.1 JLG Analyzer​
4.3.2 Calibration Preparation​
4.3.3 Load Sensing System Calibration​
4.3.4 Tilt Sensor Calibration​
4.3.5 Boom Angle Calibration​
4.3.6 Calibrating the Load Sensor​
Special Procedures​
4.4.1 Drive Cutout Override Service Mode​
4.4.2 Fuel Tank Cleaning and Drying​
4.4.3 Cylinder Checking Procedure​
4.4.4 Cylinder Drift​
4.4.5 Hydraulic Circuits​
4.4.6 Lockout Cylinder Bleeding​
4.4.7 Oscillating Axle Lockout Test​
4.4.8 Free Wheeling Option​
Wheel Drive Hub​
4.5.1 Roll and Leak Test​
Swing Drive​
4.6.1 Roll, Leak and Brake Testing​
4.6.2 Tightening and Torquing Bolts​
System Software
Load Sensing System (LSS)​
5.1.1 Theory of Operation​
5.1.2 Load Sensing Gauge Removal/ Installation​
JLG Analyzer​
5.2.1 Machine Data Access​
5.2.2 Hand Held Analyzer​
5.2.3 Mobile Analyzer​
5.2.4 Analyzer Flowchart​
Analyzer Software Accessibility​
5.3.1 Analyzer Diagnostics Menu Structure​
5.3.2 Machine Set-Up​
5.3.3 Personalities​
5.3.4 Operator Tools​
5.3.5 Calibrations​
Function Test​
CANBUS Communications​
Service Mode​
5.6.1 Load Sensing System​
5.6.2 Drive Cutout Override​
Electronic Platform Leveling​
5.7.1 Description​
5.7.2 Normal Operation​
5.7.3 Platform Leveling Fault​
5.7.4 CAN Errors​
5.7.5 Replacing the Level Sensors​
5.7.6 Additional Platform and Jib Valves​
5.7.7 Platform Leveling Calibration Procedure​
5.8.1 ClearSky Smart FleetTM CS550 Configuration​
5.8.2 Troubleshooting​
Fault Codes
Fault Codes Introduction​
Engine Diagnostic​
6.2.1 Deutz TD2.9L4 Engine​
6.2.2 Deutz TD2.9L4 (Stage V) Engine​
6.2.3 Deutz D2011LO40 Engine​
6.2.4 Ford Engine​
Machine Fault Codes​
6.3.1 General​
6.3.2 LSS Troubleshooting​
6.3.3 ClearSky Smart Fleet DTC Fault Codes​
ClearSky CS550 Troubleshooting Procedures​
Hydraulics
General Information and Safety​
Theories of Operation​
7.2.1 Cylinders​
7.2.2 Valves​
Hydraulic Components​
7.3.1 Start-up After Overhaul or Replacement of Components​
7.3.2 Set Up of the Function Pump​
7.3.3 Adjustments Made at the Main Valve Block​
7.3.4 Adjustments Made at the Platform Valve Assembly​
Torque Values​
7.4.1 Valve Torque Specifications​
Standard Hydraulic Diagram- Boom and Turntable​
7.5.1 For 800S (without tow bar)​
7.5.2 For 800S (with tow bar)​
7.5.3 For 860SJ (without tow bar)​
7.5.4 For 860SJ (with tow bar)​
Hydraulic Diagram - Chassis​
7.6.1 Oscillating Axle​
7.6.2 2WD​
7.6.3 4WD (Sauer)​
7.6.4 4WD, 2WS (with arctic package)​
7.6.5 2WD (with tow bar package)​
7.6.6 4WD (with tow bar package)​
7.6.7 4WD, 2WS For Deutz Engine​
7.6.8 2WD, 2WS (with Tow bar) For Deutz Engine​
7.6.9 4WD, 2WS (with Tow bar) For (PMP)​
7.6.10 2WD, 2WS For Deutz Engine​
Electricals
8.1.1 Applying Silicone Dielectric Compound to Electrical Connections​
Electrical Connectors​
8.2.1 Deutsch Connectors​
Electrical Component Terminology​
Harness Layouts​
Board Layouts​
8.5.1 Ground Control Module Pin Connections​
8.5.2 Platform Control Module Pin Connections​
AMP Connector​
8.6.1 Assembly​
8.6.2 Disassembly​
8.6.3 Wedge Lock​
8.6.4 Service - Voltage Reading​
Telematics Gateway​
8.7.1 Telematics-Ready (TCU) Plug​
Wheel and Tire​
Chassis/Frame Assembly​
9.2.1 Axle and Drive Assemblies Troubleshooting​
9.2.2 Drive Hub and Motor​
9.2.3 Spindle Assembly​
9.2.4 Axle Assembly​
Boom​
9.3.1 Boom Components Terminology​
9.3.2 Troubleshooting​
9.3.3 Main Boom Powertrack​
9.3.4 Main Boom Assembly​
9.3.5 Boom Sensors​
9.3.6 Jib (860SJ Only)​
Platform​
9.4.1 Platform (Rapid Replaceable Platform)​
9.4.2 Platform Support (Traditional Design)​
9.4.3 Platform Support (Rapid Replaceable Platform)​
9.4.4 Bolt-On External Fall Arrest​
Engine​
9.5.1 Component Terminology​
9.5.2 Engine Serial Number​
9.5.3 Engine Replacement​
9.5.4 Surge Tank (Deutz TD2.9L4 (T4F, Stage V, China III and IV))​
9.5.5 Pump Coupling Kit​
9.5.6 Air Filter Assembly​
9.5.7 Radiator Assembly​
9.5.8 Thermostat​
9.5.9 Coolant Temperature Sensor​
9.5.10 Relay Assembly​
9.5.11 Starter​
9.5.12 Alternator​
9.5.13 Fuel Tank​
9.5.14 Pre-Fuel Filter and Fuel Pump​
9.5.15 Ford 2.5L Engine Fuel System Repair​
Transmission​
Hydraulic Cylinders​
9.7.1 Main Lift Cylinder​
9.7.2 Telescope Cylinder/Boom Cable​
9.7.3 Rotator and Platform Level Cylinder (800S)​
9.7.4 Rotator and Platform Level Cylinder (860SJ)​
9.7.5 Steer Cylinder​
9.7.6 Jib Lift Cylinder (860SJ)​
Hydraulic Valves​
9.8.1 Platform Control Valve (Traditional Design)​
9.8.2 Platform Valve (Rapid Replaceable Platform)​
9.8.3 Main Control Valve​
Hydraulic Pumps​
9.9.1 Variable Pump Assembly​
9.9.2 Hydrostatic Pump Assembly​
Electrical Components​
9.10.1 Battery​
Generator and Pulley​
9.11.1 For 7500W and 4000W - Deutz TD2.9L4/D2011L040/T4F and Stage V Engines​
9.11.2 For 2500W Generator - Ford MSG425-DF​
9.11.3 For 2500W Generator - Deutz D2011L040​
9.11.4 For 7500W Skypower Generator- Ford DF 2.5L MSG425​
9.11.5 For 2500W Generator - Deutz TD2.9L4​
Turntable​
9.12.1 Swing Bearing​
9.12.2 Counterweight​
9.12.3 Rotary Coupling​
9.13.1 ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)​
Disassembly and Assembly
Drive Assembly​
10.1.1 Drive Hub​
10.1.2 Drive Brake​
10.1.3 Drive Motor​
Boom and Jib Assembly​
10.2.1 Main Boom​
10.2.2 Jib (860SJ only)​
10.2.3 Helac Rotary Actuator​
10.2.4 Platform Rotate Actuator (Machines with SN Starting with B3)​
10.3.1 Axle Lockout Cylinder (US Built)​
10.3.2 Axle Lockout Cylinder (China Built)​
10.3.3 Jib Lift Cylinder (860SJ US Built)​
10.3.4 Jib Lift Cylinder (860SJ China Built)​
10.3.5 Main Boom Lift Cylinder (800S)​
10.3.6 Main Boom Lift Cylinder (860SJ US Built)​
10.3.7 Main Boom Lift Cylinder (860SJ China Built)​
10.3.8 Platform Level Cylinder​
10.3.9 Steer Cylinder (800S and 860SJ US Built)​
10.3.10 Steer Cylinder (860SJ China Built)​
10.3.11 Telescope Cylinder​
Turntable​
10.4.1 Swing Drive​
10.4.2 Swing Motor​
10.4.3 Procedure for Setting Swing Gear Backlash​
10.4.4 Rotary Coupling​
10.4.5 Rotary Coupling Seal Kit​
Generator Disassembly and Assembly​
10.5.1 7500W Generator​
10.5.2 4000W Generator​
Powertrack Maintenance (task)​
10.6.1 One Piece Bracket Maintenance​
10.6.2 Two Piece Bracket Maintenance​
10.6.3 Snap Rings and Screws​
Torque/Connection Information
Hydraulic Fittings​
11.1.1 Tapered Thread Types​
11.1.2 Straight Thread Types, Tube and Hose Connections​
11.1.3 Straight Thread Types, Port Connections​
11.1.4 Flange Connection Types​
11.1.5 Tightening Methods​
11.1.6 Assembly and Torque Specifications​
11.1.7 General Tube Type Fitting Assembly Instructions​
11.1.8 Assembly Instructions for American Standard Pipe Thread Tapered Connections.​
11.1.9 Assembly Instructions for British Standard Pipe Thread Tapered Connections​
11.1.10 Assembly Instructions for 37° (JIC) Flare Fittings​
11.1.11 Assembly Instructions for 45° SAE Flare Fittings​
11.1.12 Assembly Instructions for O-Ring Face Seal (ORFS) Fittings​
11.1.13 Assembly Instructions for DIN 24° Flare Bite Type Fittings (MBTL and MBTS)​
11.1.14 Assembly Instructions for Bulkhead (BH) Fittings​
11.1.15 Assembly Instructions for O-Ring Boss (ORB) Fittings​
11.1.16 Assembly Instructions for Adjustable Port End Metric Fittings​
11.1.17 Assembly Instructions for Metric ISO 6149 (MPP) Port Assembly Stud Ends​
11.1.18 Assembly instructions for Adjustable Port End (BSPP) Fittings​
11.1.19 Assembly Instructions for Flange Connections: (FL61 and FL62)​
11.1.20 Double Wrench Method​
11.1.21 FFWR and TFFT Methods​
11.1.22 Adjustable Stud End Assembly​
11.1.23 O-ring Installation (Replacement)​
Torque Charts​
11.2.1 SAE Fastener Torque Chart​
11.2.2 Metric Fastener Torque Chart​
Schematics
Hydraulic Schematics​
Electrical Schematics​
Deutz EMR2 Schematics​
12.3.1 Vehicle Side Connection Diagram​
12.3.2 Engine Side Connection Diagram - Sheet 1 of 2​
12.3.3 Engine Side Connection Diagram - Sheet 2 of 2​
12.3.4 Engine Plug Pin​
12.3.5 Vehicle Plug Pin Identification​
Deutz EMR5 Schematics​
12.4.1 Power Harness​
12.4.2 Exhaust After Treatment Harness​
12.4.3 Equipment Harness - Sheet 1 of 5​
12.4.4 Equipment Harness - Sheet 2 of 5​
12.4.5 Equipment Harness - Sheet 3 of 5​
12.4.6 Equipment Harness - Sheet 4 of 5​
12.4.7 Equipment Harness - Sheet 5 of 5​
12.4.8 Engine Plug Pin Identification​
12.4.9 Vehicle Plug Pin Identification​
4000W Generator Schematic​
12.5.1 Generator and Controller Circuit Diagram​
12.5.2 Lead Connection List​
7500W Generator Schematic​
12.6.1 Troubleshooting Circuit Diagram​
12.6.2 Generator and Controller Circuit Diagram​
12.6.3 Power Board PC1 Circuit Diagram​
12.6.4 Power Board PC2 Electrical Circuit Diagram​
12.6.5 Lead Connection List​
