JLG Boom Lift 800S 860SJ Parts Catalog 31221372
Brand: JLG
Type of Machine: Boom Lift
Model: JLG 800S, 860SJ Boom Lift
Part Number: 31221372
Publication Date: 2025
Number of Pages: 1072 Pages
SECTION 1 - FRAME
Brand: JLG
SECTION 1 - FRAME
FIGURE 1-1. AXLE INSTALLATION - FIXED (WITHOUT TOW PACKAGE)
FIGURE 1-2. AXLE INSTALLATION - OSCILLATING (WITHOUT TOW PACKAGE) (MACHINES WITH SN STARTING WITH 03 OR 13)
FIGURE 1-3. AXLE INSTALLATION - OSCILLATING (WITHOUT TOW PACKAGE) (MACHINES WITH SN STARTING WITH B3)
FIGURE 1-4. AXLE INSTALLATION - OSCILLATING (WITH TOW PACKAGE) (MACHINES WITH SN STARTING WITH 03)
FIGURE 1-5. AXLE INSTALLATION - OSCILLATING (WITH TOW PACKAGE) (MACHINES WITH SN STARTING WITH B3)
FIGURE 1-6. STEERING INSTALLATION - WITHOUT TOW PACKAGE (MACHINES WITH SN STARTING WITH 03 OR 13)
FIGURE 1-7. STEERING INSTALLATION - WITHOUT TOW PACKAGE (MACHINES WITH SN STARTING WITH B3)
FIGURE 1-8. STEERING INSTALLATION - WITH TOW PACKAGE (MACHINES WITH SN STARTING WITH 03)
FIGURE 1-9. STEERING INSTALLATION - WITH TOW PACKAGE (MACHINES WITH SN STARTING WITH B3)
FIGURE 1-10. WHEEL DRIVE AND FRAME VALVES INSTALLATION - 2WD
FIGURE 1-11. WHEEL DRIVE AND FRAME VALVES INSTALLATION – 4WD - DANFOSS MOTOR
FIGURE 1-12. WHEEL DRIVE AND FRAME VALVES INSTALLATION - 4WD - HENGLI MOTOR
FIGURE 1-13. HUB ASSEMBELY - 2WD FRONT
FIGURE 1-14. DRIVE HUB/BRAKE ASSEMBLY
FIGURE 1-15. DRIVE MOTOR ASSEMBLY - 2WD
FIGURE 1-16. DRIVE MOTOR ASSEMBLY - 4WD - DANFOSS MOTOR
FIGURE 1-17. DRIVE MOTOR ASSEMBLY - 4WD - HENGLI MOTOR
FIGURE 1-18. TIRE & WHEEL INSTALLATION - 15-625 NHS FOAM-FILLED
FIGURE 1-19. TIRE AND WHEEL INSTALLATION 18-625 NHS FOAM-FILLED TIRE
FIGURE 1-20. TIRE AND WHEEL INSTALLATION 18-625 NHS FOAM-FILLED NON-MARKING TIRE
FIGURE 1-21. TIRE AND WHEEL INSTALLATION 18-22.5 NHS FOAM-FILLED NON-MARKING TIRE
FIGURE 1-22. LP TANK BRACKETS INSTALLATIONS
FIGURE 1-23. FRAME SHIELDS INSTALLATION - 2WS
FIGURE 1-24. TOW PACKAGE INSTALLATION (ENGLISH DECALS)
FIGURE 1-25. TOW PACKAGE INSTALLATION (FRENCH/ENGLISH DECALS)
FIGURE 1-26. TOW BAR ASSEMBLY
SECTION 2 - TURNTABLEFIGURE 2-1. CONTROL VALVES INSTALLATION (800S)
FIGURE 2-2. CONTROL VALVES INSTALLATION (860SJ)
FIGURE 2-3. MAIN CONTROL VALVE ASSEMBLY
FIGURE 2-4. SWING DRIVE INSTALLATION
FIGURE 2-5. SWING MOTOR/HUB ASSEMBLY
FIGURE 2-6. TURNTABLE BEARING INSTALLATION (ALL SPECS EXCEPT CHINA SPECS)
FIGURE 2-7. TURNTABLE BEARING INSTALLATION (CHINA SPECS)
FIGURE 2-8. REMOTE BEARING LUBE INSTALLATION
FIGURE 2-9. TURNTABLE LOCK INSTALLATION
FIGURE 2-10. ROTARY COUPLING INSTALLATION (MACHINES WITH SN STARTING WITH 03)
FIGURE 2-11. ROTARY COUPLING INSTALLATION (MACHINES WITH SN STARTING WITH B3) (860SJ) (Prior to SN B300021569, Except SN B300019011 through B300019018)
FIGURE 2-12. ROTARY COUPLING INSTALLATION (MACHINES WITH SN STARTING WITH B3) (860SJ) (SN B300021569 to Present, SN B300019011 through B300019018)
FIGURE 2-13. ROTARY COUPLING ASSEMBLY (MACHINES WITH SN STARTING WITH B3) (860SJ) (SN B300021569 to Present, SN B300019011 through B300019018)
FIGURE 2-14. TANK INSTALLATION - GAS ENGINES (HELGESEN 25 GAL HYDRAULIC TANK WITH 6IN DIA BREATHER)
FIGURE 2-15. TANK INSTALLATION - GAS ENGINES (JIANGYING 25 GAL HYDRAULIC TANK WITH 4IN DIA BREATHER)
FIGURE 2-16. TANK INSTALLATION - DIESEL ENGINES (HELGESEN 25 GAL HYDRAULIC TANK WITH 6IN BREATHER)
FIGURE 2-17. TANK INSTALLATION - DIESEL ENGINES (JIANGYING 25 GAL HYDRAULIC TANK WITH 4IN DIA BREATHER)
FIGURE 2-18. TANK INSTALLATION - DIESEL ENGINES (MACHINES WITH HOSTILE ENVIRONMENT PACKAGE) (25 GAL HYDRAULIC TANK WITH 6 INCH BREATHER)
FIGURE 2-19. TANK INSTALLATION - DIESEL ENGINES (MACHINES WITH HOSTILE ENVIRONMENT PACKAGE) (25 GAL HYDRAULIC TANK WITH 4 INCH BREATHER)
FIGURE 2-20. HYDRAULIC TANK ASSEMBLY (HELGESEN 25 GAL HYDRAULIC TANK WITH 6IN DIA BREATHER)
FIGURE 2-21. HYDRAULIC TANK ASSEMBLY (JIANGYING 25 GAL HYDRAULIC TANK WITH 4IN DIA BREATHER)
FIGURE 2-22. AUXILIARY PUMP WITHOUT BATTERY DISCONNECT SWITCH INSTALLATION (MACHINES WITH SN STARTING WITH 03)
FIGURE 2-23. AUXILIARY PUMP WITHOUT BATTERY DISCONNECT SWITCH INSTALLATION (MACHINES WITH SN STARTING WITH B3)
FIGURE 2-24. AUXILIARY PUMP WITH BATTERY DISCONNECT SWITCH INSTALLATION (MACHINES WITH SN STARTING WITH 03)
FIGURE 2-25. AUXILIARY PUMP WITH BATTERY DISCONNECT SWITCH INSTALLATION (MACHINES WITH SN STARTING WITH B3)
FIGURE 2-26. AUXILIARY PUMP WITH BATTERY DISCONNECT SWITCH INSTALLATION (MACHINES WITH SN STARTING WITH B3)
FIGURE 2-27. GROUND CONTROL BOX ASSEMBLY - WITH DEUTZ D2011 - WITH DIGITAL DISPLAY (ANSI EXPORT (LRC) AND AUSTRALIAN SPECS) (800S)
FIGURE 2-28. GROUND CONTROL BOX ASSEMBLY - WITH DEUTZ D2011 - WITH MECHANICAL HOUR METER (ANSI EXPORT (LRC) AND AUSTRALIAN SPECS) (800S)
FIGURE 2-29. GROUND CONTROL BOX ASSEMBLY - WITH DEUTZ D2011 (CE & UK CA SPECS) (800S)
FIGURE 2-30. GROUND CONTROL BOX ASSEMBLY - WITH DEUTZ D2011 - WITH DIGITAL DISPLAY (ANSI EXPORT (LRC) AND AUSTRALIAN SPECS) WITH TILT SENSOR (860SJ)
FIGURE 2-31. GROUND CONTROL BOX ASSEMBLY - WITH DEUTZ D2011 - WITH MECHANICAL HOUR METER (ANSI EXPORT (LRC) AND AUSTRALIAN SPECS) WITH TILT SENSOR (860SJ)
FIGURE 2-32. GROUND CONTROL BOX ASSEMBLY - WITH DEUTZ D2011 (CE & UK CA SPECS) WITH TILT SENSOR (860SJ)
FIGURE 2-33. GROUND CONTROL BOX ASSEMBLY - WITH DEUTZ D2011 (HIGH TEMP MARKETS) (ANSI EXPORT (LRC) AND AUSTRALIAN SPECS) (860SJ)
FIGURE 2-34. GROUND CONTROL BOX ASSEMBLY - WITH DEUTZ TD2.9L4 - WITH DIGITAL DISPLAY (ANSI, ANSI EXPORT (HRC), CSA AND JAPANESE SPECS) (800S)
FIGURE 2-35. GROUND CONTROL BOX ASSEMBLY - WITH DEUTZ TD2.9L4 - WITH MECHANICAL HOUR METER (ANSI, ANSI EXPORT (HRC), CSA AND JAPANESE SPECS) (800S)
FIGURE 2-36. GROUND CONTROL BOX ASSEMBLY - WITH DEUTZ TD2.9L4 (STAGE V) (CE & UK CA SPECS) (800S)
FIGURE 2-37. GROUND CONTROL BOX ASSEMBLY - WITH DEUTZ TD2.9L4 - WITH DIGITAL DISPLAY (ANSI, ANSI EXPORT (HRC), ANSI EXPORT (LRC WITH SN B3), CSA, JAPANESE, AUSTRALIAN (SN B3), RUSSIAN (SN B3) AND CHINA SPECS) WITH TILT SENSOR (860SJ)
FIGURE 2-38. GROUND CONTROL BOX ASSEMBLY - WITH DEUTZ TD2.9L4 - WITH MECHANICAL HOUR METER (ANSI, ANSI EXPORT (HRC), ANSI EXPORT (LRC WITH SN B3), CSA, JAPANESE, AUSTRALIAN (SN B3), RUSSIAN (SN B3) AND CHINA SPECS) WITH TILT SENSOR (860SJ)
FIGURE 2-39. GROUND CONTROL BOX ASSEMBLY - WITH DEUTZ TD2.9L4 (STAGE V) (CE & UK CA SPECS) WITH TILT SENSOR (860SJ)
FIGURE 2-40. GROUND CONTROL BOX ASSEMBLY - WITH FORD DF 2.5L - WITH DIGITAL DISPLAY (ANSI, ANSI EXPORT (LRC & HRC) AND CSA SPECS) (800S)
FIGURE 2-41. GROUND CONTROL BOX ASSEMBLY - WITH FORD DF 2.5L - WITH MECHANICAL HOUR METER (ANSI, ANSI EXPORT (LRC & HRC) AND CSA SPECS) (800S)
FIGURE 2-42. GROUND CONTROL BOX ASSEMBLY - WITH FORD DF 2.5L - WITH DIGITAL DISPLAY (ANSI, ANSI EXPORT (LRC & HRC), AUSTRALIAN AND CSA SPECS) (860SJ)
FIGURE 2-43. GROUND CONTROL BOX ASSEMBLY - WITH FORD DF 2.5L - WITH MECHANICAL HOUR METER (ANSI, ANSI EXPORT (LRC & HRC), AUSTRALIAN AND CSA SPECS) (860SJ)
FIGURE 2-44. LIGHT PANEL INSTALLATION (MACHINES WITH SN STARTING WITH 03 OR 13)
FIGURE 2-45. LIGHT PANEL INSTALLATION (MACHINES WITH SN STARTING WITH B3)
FIGURE 2-46. ALARM INSTALLATION
FIGURE 2-47. WHITE NOISE ALARM INSTALLATION - AMBIENT
FIGURE 2-48. WHITE NOISE ALARM INSTALLATION - CONSTANT
FIGURE 2-49. STROBE LIGHT INSTALLATION (AMBER) (ALL SPECS EXCEPT CHINA SPECS) (WITHOUT CLEARSKY BEACON)
FIGURE 2-50. STROBE LIGHT INSTALLATION (AMBER) (CHINA SPECS) (WITHOUT CLEARSKY BEACON)
FIGURE 2-51. STROBE LIGHT INSTALLATION (BLUE) (WITHOUT CLEARSKY BEACON)
FIGURE 2-52. STROBE LIGHT INSTALLATION (RED) (WITHOUT CLEARSKY BEACON)
FIGURE 2-53. DUAL CAPACITY INSTALLATION - ELEVATION AND TRANSPORTATION (800S)
FIGURE 2-54. DUAL CAPACITY INSTALLATION - ELEVATION AND TRANSPORTATION (860SJ)
FIGURE 2-55. LOWER SENSOR ASSEMBLY
FIGURE 2-56. EXHAUST STACK INSTALLATION - STEEL HOOD (DEUTZ D2011 ENGINES)
FIGURE 2-57. EXHAUST STACK INSTALLATION - STEEL HOOD WITH HOSTILE ENVIRONMENT MACHINES (DEUTZ D2011 ENGINES)
FIGURE 2-58. EXHAUST STACK INSTALLATION - STEEL HOOD WITH HOSTILE ENVIRONMENT MACHINES (DEUTZ TD2.9L4 ENGINES) (MACHINES WITH SN STARTING WITH B3)
FIGURE 2-59. EXHAUST STACK INSTALLATION - STEEL HOOD (DEUTZ TD2.9L4 ENGINES) (MACHINES WITH SN STARTING WITH 03 OR 13)
FIGURE 2-60. EXHAUST STACK INSTALLATION - STEEL HOOD (DEUTZ TD2.9L4 (STAGE V) ENGINES) (MACHINES WITH SN STARTING WITH 03)
FIGURE 2-61. EXHAUST STACK INSTALLATION - STEEL HOOD (DEUTZ TD2.9L4 ENGINES) (MACHINES WITH SN STARTING WITH B3)
FIGURE 2-62. EXHAUST STACK INSTALLATION - STEEL HOOD (DEUTZ TD2.9L4 (STAGE V) ENGINES) (MACHINES WITH SN STARTING WITH B3)
FIGURE 2-63. EXHAUST STACK INSTALLATION - STEEL HOOD WITH HOSTILE ENVIRONMENT MACHINES (DEUTZ TD2.9L4 ENGINES) (MACHINES WITH SN STARTING WITH 03 OR 13)
FIGURE 2-64. EXHAUST STACK INSTALLATION - STEEL HOOD (FORD DF 2.5L ENGINES)
FIGURE 2-65. HOODS INSTALLATION - ABS (DEUTZ D2011 ENGINES)
FIGURE 2-66. HOODS INSTALLATION - ABS (DEUTZ TD2.9L4 AND DEUTZ TD2.9L4 (STAGE V) ENGINES) (CE & UK CA SPECS ONLY)
FIGURE 2-67. HOODS INSTALLATION - STEEL (DEUTZ D2011 ENGINES)
FIGURE 2-68. HOODS INSTALLATION - STEEL WITH HOSTILE ENVIRONMENT MACHINES (DEUTZ D2011 ENGINES) (MACHINES WITH SN STARTING WITH 03 OR 13)
FIGURE 2-69. HOODS INSTALLATION – STEEL WITH HOSTILE ENVIRONMENT MACHINES (DEUTZ TD2.9L4 ENGINES) (MACHINES WITH SN STARTING WITH B3)
FIGURE 2-70. HOODS INSTALLATION – STEEL (DEUTZ TD2.9L4 AND DEUTZ TD2.9L4 (STAGE V) ENGINES) (MACHINES WITH SN STARTING WITH 03 OR 13)
FIGURE 2-71. HOODS INSTALLATION - STEEL (DEUTZ TD2.9L4 ENGINES) (MACHINES WITH SN STARTING WITH B3)
FIGURE 2-72. HOODS INSTALLATION - STEEL (DEUTZ TD2.9L4 (STAGE V) ENGINES) (MACHINES WITH SN STARTING WITH B3)
FIGURE 2-73. HOODS INSTALLATION – STEEL WITH HOSTILE ENVIRONMENT MACHINES (DEUTZ TD2.9L4 ENGINES)
FIGURE 2-74. HOODS INSTALLATION – STEEL (FORD DF 2.5L ENGINES)
FIGURE 2-75. HOOD ASSEMBLY - ENGINE SIDE REAR (DEUTZ TD2.9L4 ENGINES) (MACHINES WITH SN STARTING WITH B3)
FIGURE 2-76. HOOD ASSEMBLY - ENGINE SIDE REAR (DEUTZ TD2.9L4 (STAGE V) ENGINES) (MACHINES WITH SN STARTING WITH B3)
FIGURE 2-77. HOOD ASSEMBLY - TANK SIDE REAR (DEUTZ TD2.9L4 AND DEUTZ TD2.9L4 (STAGE V) ENGINES) (MACHINES WITH SN STARTING WITH B3)
FIGURE 2-78. LIFTING PLATE INSTALLATION
FIGURE 2-79. SKYAIR AIR COMPRESSOR INSTALLATION (DEUTZ D2011 AND FORD DF 2.5L ENGINES)
FIGURE 2-80. SKYAIR AIR COMPRESSOR INSTALLATION (DEUTZ TD2.9L4 ENGINES)
FIGURE 2-81. AIR COMPRESSOR ASSEMBLY
FIGURE 2-82. WHITE NOISE ALARM HARNESS
SECTION 3 - ENGINEFIGURE 3-1. DEUTZ D2011 ENGINE INSTALLATION - (WITHOUT ARCTIC PACKAGE)
FIGURE 3-2. DEUTZ D2011 ENGINE INSTALLATION - (WITH ARCTIC PACKAGE) (WITH 25 GAL CAPACITY HYDRAULIC TANK)
FIGURE 3-3. DEUTZ D2011 ENGINE INSTALLATION - (WITH ARCTIC PACKAGE) (WITH 47.8 GAL CAPACITY HYDRAULIC TANK)
FIGURE 3-4. DEUTZ D2011 ENGINE INSTALLATION - (HIGH TEMP MARKETS)
FIGURE 3-5. DEUTZ D2011 ENGINE AND PUMP SUB-ASSEMBLY - (WITHOUT ARCTIC PACKAGE)
FIGURE 3-6. DEUTZ D2011 ENGINE AND PUMP SUB-ASSEMBLY - (WITH ARCTIC PACKAGE) (WITH 25 GAL CAPACITY HYDRAULIC TANK)
FIGURE 3-7. DEUTZ D2011 ENGINE AND PUMP SUB-ASSEMBLY - (WITH ARCTIC PACKAGE) (WITH 47.8 GAL CAPACITY HYDRAULIC TANK)
FIGURE 3-8. DEUTZ D2011 ENGINE ASSEMBLY (WITHOUT ARCTIC PACKAGE)
FIGURE 3-9. DEUTZ D2011 ENGINE ASSEMBLY (WITH ARCTIC PACKAGE)
FIGURE 3-10. DEUTZ D2011 ENGINE COMPONENTS
FIGURE 3-11. DEUTZ TD2.9L4 ENGINE INSTALLATION - (WITHOUT ARCTIC PACKAGE)
FIGURE 3-12. DEUTZ TD2.9L4 ENGINE INSTALLATION - (WITH ARCTIC PACKAGE) (WITH 25 GAL CAPACITY HYDRAULIC TANK)
FIGURE 3-13. DEUTZ TD2.9L4 (STAGE V) ENGINE INSTALLATION
FIGURE 3-14. DEUTZ TD2.9L4 ENGINE INSTALLATION - (WITH ARCTIC PACKAGE) (WITH 47.8 GAL CAPACITY HYDRAULIC TANK)
FIGURE 3-15. DEUTZ TD2.9L4 ENGINE INSTALLATION - (CHINA III ENGINES)
FIGURE 3-16. DEUTZ TD2.9L4 ENGINE INSTALLATION (CHINA IV ENGINES)
FIGURE 3-17. DEUTZ TD2.9L4 ENGINE AND PUMP SUB-ASSEMBLY - (WITHOUT ARCTIC PACKAGE)
FIGURE 3-18. DEUTZ TD2.9L4 ENGINE AND PUMP SUB-ASSEMBLY - (WITH ARCTIC PACKAGE) (WITH 25 GAL CAPACITY HYDRAULIC TANK)
FIGURE 3-19. DEUTZ TD2.9L4 ENGINE AND PUMP SUB-ASSEMBLY - (WITH ARCTIC PACKAGE) (WITH 47.8 GAL CAPACITY HYDRAULIC TANK)
FIGURE 3-20. DEUTZ TD2.9L4 (STAGE V) ENGINE AND PUMP SUB-ASSEMBLY
FIGURE 3-21. DEUTZ TD2.9L4 ENGINE AND PUMP SUB-ASSEMBLY - (CHINA III ENGINE)
FIGURE 3-22. DEUTZ TD2.9L4 ENGINE AND PUMP SUB-ASSEMBLY (CHINA IV ENGINE)
FIGURE 3-23. DEUTZ TD2.9L4 ENGINE ASSEMBLY (WITHOUT ARCTIC PACKAGE)
FIGURE 3-24. DEUTZ TD2.9L4 ENGINE ASSEMBLY (WITH ARCTIC PACKAGE)
FIGURE 3-25. DEUTZ TD2.9L4 ENGINE ASSEMBLY (STAGE V)
FIGURE 3-26. DEUTZ TD2.9L4 ENGINE ASSEMBLY (STAGE V)
FIGURE 3-27. DEUTZ TD2.9L4 ENGINE ASSEMBLY (CHINA III ENGINE)
FIGURE 3-28. DEUTZ TD2.9L4 ENGINE ASSEMBLY (CHINA IV ENGINE)
FIGURE 3-29. DEUTZ TD2.9L4 ENGINE COMPONENTS
FIGURE 3-30. DEUTZ TD2.9L4 ENGINE COMPONENTS (STAGE V)
FIGURE 3-31. DEUTZ TD2.9L4 ENGINE COMPONENTS (CHINA III ENGINE)
FIGURE 3-32. DEUTZ TD2.9L4 ENGINE COMPONENTS (CHINA IV ENGINE)
FIGURE 3-33. FUEL PUMP/FILTER BRACKET ASSEMBLY (DEUTZ TD2.9L4 ENGINES)
FIGURE 3-34. FUEL PUMP/FILTER BRACKET ASSEMBLY (DEUTZ TD2.9L4 (STAGE V) ENGINES)
FIGURE 3-35. FUEL PUMP/FILTER BRACKET ASSEMBLY (DEUTZ TD2.9L4 ENGINES) (CHINA III & CHINA IV ENGINE)
FIGURE 3-36. BREATHER HEATER INST (DEUTZ TD2.9L4 ENGINES)
FIGURE 3-37. FORD ENGINE INSTALLATION - (WITHOUT ARCTIC PACKAGE)
FIGURE 3-38. FORD ENGINE AND PUMP SUB-ASSEMBLY - (WITHOUT ARCTIC PACKAGE)
FIGURE 3-39. FORD ENGINE ASSEMBLY (WITHOUT ARCTIC PACKAGE)
FIGURE 3-40. FORD ENGINE PREP ASSEMBLY
FIGURE 3-41. FORD ENGINE BRACKETS AND EXHAUST MANIFOLD INSTALLATION
FIGURE 3-42. FORD ENGINE DRIVE BELT INSTALLATION (MACHINES WITHOUT GENERATOR)
FIGURE 3-43. FORD ENGINE COMPONENTS
FIGURE 3-44. PUMP COUPING KIT (DEUTZ ENGINES)
FIGURE 3-45. HYDROSTATIC PUMP ASSEMBLY
FIGURE 3-46. VARIABLE PUMP ASSEMBLY - DEUTZ TD2.9L4 STAGE V ENGINES
FIGURE 3-47. VARIABLE PUMP ASSEMBLY - ALL ENGINES EXCEPT FOR DEUTZ TD2.9L4 STAGE V ENGINES
FIGURE 3-48. EXHAUST PIPE INSTALLATION - DEUTZ TD2.9L4 ENGINES
FIGURE 3-49. EXHAUST PIPE INSTALLATION - DEUTZ TD2.9L4 (STAGE V) ENGINES
FIGURE 3-50. EXHAUST PIPE INSTALLATION - FORD DF 2.5L ENGINES
FIGURE 3-51. SPARK ARRESTOR MUFFLER INSTALLATION - DEUTZ D2011 ENGINES
FIGURE 3-52. SPARK ARRESTING PIPE (MACHINES WITH SN STARTING WITH B3)
FIGURE 3-53. FUEL-WATER SEPARATOR INSTALLATION - DEUTZ D2011
FIGURE 3-54. FUEL-WATER SEPARATOR INSTALLATION - DEUTZ TD2.9L4
FIGURE 3-55. FUEL FILTER ASSEMBLY (DEUTZ TD2.9L4 ENGINES)
FIGURE 3-56. RIGHT ENGINE SUPPORT INSTALLATION (DEUTZ D2011 ENGINES MACHINES WITHOUT GENERATORS)
FIGURE 3-57. RIGHT ENGINE SUPPORT INSTALLATION (DEUTZ D2011 ENGINES MACHINES WITH GENERATORS)
FIGURE 3-58. ENGINE HOOD BAFFLE INSTALLATION - DEUTZ TD2.9L4 AND DEUTZ 2.9L4 (STAGE V) ENGINES WITH ABS HOODS
FIGURE 3-59. ENGINE HOOD BAFFLE INSTALLATION - DEUTZ TD2.9L4 AND DEUTZ 2.9L4 (STAGE V) ENGINES WITH STEEL HOODS
FIGURE 3-60. ENGINE TRAY JACK INSTALLATION - DEUTZ ENGINES
FIGURE 3-61. ENGINE TRAY JACK INSTALLATION - FORD ENGINES
FIGURE 3-62. QUICKFIT OIL DRAIN VALVE (DEUTZ ENGINES)
FIGURE 3-63. 2500W/110V/60HZ GENERATOR INSTALLATION - DEUTZ D2011 ENGINES
FIGURE 3-64. 2500W/110V/60HZ GENERATOR INSTALLATION - DEUTZ TD2.9L4 ENGINES
FIGURE 3-65. 2500W/110V/60HZ GENERATOR INSTALLATION - FORD ENGINES
FIGURE 3-66. 2500W/220V/50HZ GENERATOR INSTALLATION - DEUTZ D2011 ENGINES
FIGURE 3-67. 4000W/50HZ GENERATOR INSTALLATION - DEUTZ D2011 ENGINES
FIGURE 3-68. 4000W/60HZ GENERATOR INSTALLATION - DEUTZ D2011 ENGINES
FIGURE 3-69. 4000W/50HZ GENERATOR INSTALLATION - DEUTZ TD2.9L4 AND DEUTZ TD2.9L4 (STAGE V) ENGINES
FIGURE 3-70. 4000W/60HZ GENERATOR INSTALLATION - DEUTZ TD2.9L4 ENGINES
FIGURE 3-71. 7500W/50HZ SKYPOWER GENERATOR INSTALLATION - DEUTZ D2011 ENGINES
FIGURE 3-72. 7500W/60HZ SKYPOWER GENERATOR INSTALLATION - DEUTZ D2011 ENGINES
FIGURE 3-73. 7500W/50HZ SKYPOWER GENERATOR INSTALLATION - DEUTZ TD2.9L4 AND DEUTZ TD2.9L4 (STAGE V) ENGINES
FIGURE 3-74. 7500W/60HZ SKYPOWER GENERATOR INSTALLATION - DEUTZ TD2.9L4 AND DEUTZ TD2.9L4 (STAGE V) ENGINES
FIGURE 3-75. 7500W/60HZ SKYPOWER GENERATOR INSTALLATION – FORD DF 2.5L ENGINES
SECTION 4 - BOOMFIGURE 4-1. BOOMS AND CYLINDERS INSTALLATION (800S)
FIGURE 4-2. BOOMS AND CYLINDERS INSTALLATION (MACHINES WITH SN STARTING WITH 03 OR 13) (860SJ)
FIGURE 4-3. BOOMS AND CYLINDERS INSTALLATION (MACHINES WITH SN STARTING WITH B3) (860SJ)
FIGURE 4-4. MAIN BOOM ASSEMBLY (800S)
FIGURE 4-5. MAIN BOOM ASSEMBLY (MACHINES WITH SN STARTING WITH 03 OR 13) (860SJ)
FIGURE 4-6. MAIN BOOM ASSEMBLY (MACHINES WITH SN STARTING WITH B3) (860SJ)
FIGURE 4-7. JIB ASSEMBLY (MACHINES WITH SN STARTING WITH 03 OR 13)
FIGURE 4-8. JIB ASSEMBLY (MACHINES WITH SN STARTING WITH B3)
FIGURE 4-9. ROTATOR ASSEMBLY (800S)
FIGURE 4-10. ROTATOR ASSEMBLY (860SJ)
FIGURE 4-11. PLATFORM SUPPORT INSTALLATION
FIGURE 4-12. POWER TRACK INSTALLATION - MAIN BOOM (800S)
FIGURE 4-13. POWER TRACK INSTALLATION - MAIN BOOM (860SJ)
FIGURE 4-14. POWERTRACK WITH PLASTIC CLAMP INSTALLATION (MACHINES WITH SN STARTING WITH B3) (EXCEPT CHINESE SPECS)
FIGURE 4-15. POWERTRACK WITH STEEL CLAMP INSTALLATION (MACHINES WITH SN STARTING WITH 03) (ALL SPECS) (800S)
FIGURE 4-16. POWERTRACK WITH STEEL CLAMP INSTALLATION (MACHINES WITH SN STARTING WITH 03) (ALL SPECS) (860SJ)
FIGURE 4-17. POWERTRACK WITH STEEL CLAMP INSTALLATION (MACHINES WITH SN STARTING WITH B3) (CHINESE SPECS)
FIGURE 4-18. POWER TRACK SUPPORT BRACKET INSTALLATION - MAIN BOOM (860SJ)
FIGURE 4-19. CONTROL VALVE INSTALLATION (800S)
FIGURE 4-20. CONTROL VALVE INSTALLATION (860SJ)
FIGURE 4-21. PLATFORM VALVE ASSEMBLY (800S)
FIGURE 4-22. PLATFORM VALVE ASSEMBLY (860SJ)
FIGURE 4-23. LEVEL SENSOR SWITCH INSTALLATION
SECTION 5 - PLATFORMFIGURE 5-1. PLATFORM ASSEMBLY WITH DROP-BAR - 30IN X 3FT (76CM X 1M)
FIGURE 5-2. PLATFORM ASSEMBLY WITH DROP-BAR - 30IN X 4FT (76CM X 1.22M)
FIGURE 5-3. PLATFORM ASSEMBLY WITH DROP-BAR - 30IN X 5FT (76CM X 1.52M)
FIGURE 5-4. PLATFORM ASSEMBLY WITH DROP-BAR - 36IN X 6FT (91.5CM X 1.83M)
FIGURE 5-5. PLATFORM ASSEMBLY WITH DROP BAR - 36IN X 6FT (91.5CM X 1.83M) (SHIPYARD MACHINES)
FIGURE 5-6. PLATFORM ASSEMBLY WITH DROP BAR - 36IN X 6FT (91.5CM X 1.83M) (SHIPYARD MACHINES WITH PLATFORM BUMPERS REQIRED)
FIGURE 5-7. PLATFORM ASSEMBLY WITH DROP-BAR - 36IN X 8FT (91.5CM X 2.44M)
FIGURE 5-8. PLATFORM ASSEMBLY WITH GATE - 30IN X 4FT (76CM X 1.22M)
FIGURE 5-9. PLATFORM ASSEMBLY WITH GATE - 30IN X 5FT (76CM X 1.52M)
FIGURE 5-10. PLATFORM ASSEMBLY WITH GATE- 36IN X 6FT (91.5CM X 1.83M)
FIGURE 5-11. PLATFORM ASSEMBLY WITH GATE - 36IN X 8FT (91.5CM X 2.44M)
FIGURE 5-12. PLATFORM ASSEMBLY WITH 1 GATE / 2 DROP BARS (TRI-ENTRY) - 36IN X 6FT (91.5CM X 1.83M)
FIGURE 5-13. PLATFORM ASSEMBLY WITH 3 DROP BARS (TRI-ENTRY) - 36IN X 6FT (91.5CM X 1.83M)
FIGURE 5-14. PLATFORM ASSEMBLY WITH 1 GATE / 2 DROP BARS (TRI-ENTRY) - 36IN X 8FT (91.5CM X 2.44M)
FIGURE 5-15. PLATFORM ASSEMBLY WITH 3 DROP BARS (TRI-ENTRY) - 36IN X 8FT (91.5CM X 2.44M)
FIGURE 5-16. PLATFORM ASSEMBLY WITH FALL ARREST (6FT)
FIGURE 5-17. PLATFORM ASSEMBLY WITH FALL ARREST (8FT)
FIGURE 5-18. PLATFORM CONSOLE AND FOOTSWITCH INSTALLATION
FIGURE 5-19. PLATFORM CONSOLE ASSEMBLY
FIGURE 5-20. FOOTSWITCH ASSEMBLY
FIGURE 5-21. FALL ARREST INSTALLATION (BOLT-ON) (4FT/1.22M PLATFORM)
FIGURE 5-22. FALL ARREST INSTALLATION (BOLT-ON) (6FT/1.82M PLATFORM)
FIGURE 5-23. FALL ARREST INSTALLATION (BOLT-ON) (8FT/2.4M PLATFORM)
FIGURE 5-24. FALL ARREST INSTALLATION (BOLT-ON) (6FT/1.82M TRI-ENTRY PLATFORM)
FIGURE 5-25. LIGHT PANEL INSTALLATION (MACHINES WITH SN STARTING WITH 03 OR 13)
FIGURE 5-26. LIGHT PANEL INSTALLATION (MACHINES WITH SN STARTING WITH B3)
FIGURE 5-27. JIB SWITCH INSTALLATION (860SJ)
FIGURE 5-28. SKYEYE INSTALLATION
FIGURE 5-29. SKYGUARD BAR INSTALLATION
FIGURE 5-30. SKYLINE INSTALLATION
FIGURE 5-31. STORAGE TRAY INSTALLATION - CENTER
FIGURE 5-32. SKYCUTTER INSTALLATION
FIGURE 5-33. SKYWELDER/SKYCUTTER COMBO INSTALLATION (60HZ)
FIGURE 5-34. SKYWELDER/SKYCUTTER COMBO INSTALLATION (60HZ)
FIGURE 5-35. PLASMA CUTTER ASSEMBLY
FIGURE 5-36. SKYWELDER INSTALLATION (50HZ)
FIGURE 5-37. SKYWELDER INSTALLATION (60HZ)
FIGURE 5-38. WELDER ASSEMBLY
FIGURE 5-39. SKYWELDER PREP PACKAGE (60HZ)
FIGURE 5-40. SKYGLAZIER INSTALLATION (ENGLISH LANGUAGE DECALS)
FIGURE 5-41. SKYGLAZIER INSTALLATION (SPANISH LANGUAGE DECALS)
FIGURE 5-42. SKYGLAZIER INSTALLATION (PORTUGUESE LANGUAGE DECALS)
FIGURE 5-43. SOFT TOUCH SYSTEM INSTALLATION - 6FT/1.83M PLATFORM
FIGURE 5-44. SOFT TOUCH SYSTEM INSTALLATION - 6FT/1.83M FALL ARREST PLATFORM
FIGURE 5-45. SOFT TOUCH SYSTEM INSTALLATION - 8FT/2.44M PLATFORM
FIGURE 5-46. SOFT TOUCH SYSTEM INSTALLATION - 8FT/2.44M FALL ARREST PLATFORM
FIGURE 5-47. PLATFORM BUMPER PADDING INSTALLATION (OPTIONAL)
FIGURE 5-48. USB CHARGER INSTALLATION
FIGURE 6-2. AXLE LOCKOUT CYLINDER ASSEMBLY
FIGURE 6-3. LEVEL CYLINDER ASSEMBLY - PLATFORM SLAVE (800S)
FIGURE 6-4. LEVEL CYLINDER ASSEMBLY - PLATFORM SLAVE (MACHINES WITH SN STARTING WITH 03 OR 13) (860SJ)
FIGURE 6-5. LEVEL CYLINDER ASSEMBLY - PLATFORM SLAVE (MACHINES WITH SN STARTING WITH B3) (860SJ)
FIGURE 6-6. LIFT CYLINDER ASSEMBLY - JIB (860SJ)
FIGURE 6-7. LIFT CYLINDER ASSEMBLY - JIB (860SJ)
FIGURE 6-8. LIFT CYLINDER ASSEMBLY - MAIN BOOM (800S)
FIGURE 6-9. LIFT CYLINDER ASSEMBLY - MAIN BOOM (860SJ)
FIGURE 6-10. LIFT CYLINDER ASSEMBLY - MAIN BOOM (860SJ)
FIGURE 6-11. STEER CYLINDER ASSEMBLY
FIGURE 6-12. STEER CYLINDER ASSEMBLY
FIGURE 6-13. TELESCOPE CYLINDER ASSEMBLY (800S)
FIGURE 6-14. TELESCOPE CYLINDER ASSEMBLY (860SJ)
SECTION 7 - HYDRAULICFIGURE 7-1. HYDRAULIC DIAGRAM - AXLE (OSCILLATING)
FIGURE 7-2. HYDRAULIC DIAGRAM - DRIVE (2WD)
FIGURE 7-3. HYDRAULIC DIAGRAM - DRIVE (2WD WITH TOW BAR PACKAGE)
FIGURE 7-4. HYDRAULIC DIAGRAM - DRIVE (4WD WITHOUT ARCTIC PACKAGE)
FIGURE 7-5. HYDRAULIC DIAGRAM - DRIVE (4WD WITH ARCTIC PACKAGE)
FIGURE 7-6. HYDRAULIC DIAGRAM - DRIVE (4WD WITH TOW BAR PACKAGE)
FIGURE 7-7. HYDRAULIC DIAGRAM - DRIVE (4WD WITH ARCTIC & TOW BAR PACKAGE)
FIGURE 7-8. HYDRAULIC DIAGRAM - DRIVE (4WD WITH ARCTIC PACKAGE)
FIGURE 7-9. HYDRAULIC DIAGRAM - STANDARD (WITH TOW BAR PACKAGE) (800S)
FIGURE 7-10. HYDRAULIC DIAGRAM - STANDARD (WITHOUT TOW BAR PACKAGE) (860SJ)
FIGURE 7-11. HYDRAULIC DIAGRAM - STANDARD (WITH TOW BAR PACKAGE) (860SJ)
SECTION 8 - ELECTRICALFIGURE 8-1. AC BOX AT PLATFORM INSTALLATION - 110V GFI RECEPTACLE (ALL SPECS EXCEPT AUSTRALIAN, CE & UK CA SPECS)
FIGURE 8-2. AC BOX AT PLATFORM INSTALLATION - 220V (ANSI, CSA & JAPANESE SPECS)
FIGURE 8-3. AC BOX AT PLATFORM MID-BOOM PLUG INSTALLATION (WITHOUT 7500W SKYPOWER GENERATOR) (ANSI EXPORT, AUSTRALIAN, CE & UK CA SPECS)
FIGURE 8-4. AC BOX AT PLATFORM MID-BOOM PLUG INSTALLATION (WITHOUT GENERATOR) (CHINA SPECS)
FIGURE 8-5. AC BOX AT PLATFORM INSTALLATION - 110V IEC 60309 YELLOW WITHOUT 2500W GENERATOR (CE & UK CA SPECS)
FIGURE 8-6. AC BOX AT PLATFORM INSTALLATION - 110V IEC 60309 YELLOW WITH 2500W GENERATOR (CE & UK CA SPECS)
FIGURE 8-7. AC BOX AT PLATFORM INSTALLATION - 110V IEC YELLOW (CE & UK CA SPECS) (MACHINES WITH 4000W GENERATOR)
FIGURE 8-8. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE (CE & UK CA SPECS) (MACHINES WITH 2500W GENERATOR OR NO GENERATOR OPTION)
FIGURE 8-9. AC BOX AT PLATFORM INSTALLATION - 220V IEC 60309 BLUE WITH 2500W GENERATOR (CE & UK CA SPECS)
FIGURE 8-10. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE (CE & UK CA SPECS) (MACHINES WITH 4000W GENERATOR)
FIGURE 8-11. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 POST GROUND (CE & UK CA SPECS) (MACHINES WITH 2500W GENERATOR OR NO GENERATOR OPTION)
FIGURE 8-12. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 POST GROUND (2X4 BOX) WITH 2500W GENERATOR (CE & UK CA SPECS)
FIGURE 8-13. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 POST GROUND (CE & UK CA SPECS) (MACHINES WITH 4000W GENERATOR)
FIGURE 8-14. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 SIDE GROUND (CE & UK CA SPECS) (MACHINES WITH 2500W GENERATOR OR NO GENERATOR OPTION)
FIGURE 8-15. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 SIDE GROUND (2X4 BOX) WITH 2500W GENERATOR (CE & UK CA SPECS)
FIGURE 8-16. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 SIDE GROUND (CE & UK CA SPECS) (MACHINES WITH 4000W GENERATOR)
FIGURE 8-17. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT 107 KEYED GROUND (CE & UK CA SPECS) (MACHINES WITH 2500W GENERATOR OR NO GENERATOR OPTION)
FIGURE 8-18. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT 107 KEYED GROUND (2X4 BOX) WITH 2500W GENERATOR (CE & UK CA SPECS)
FIGURE 8-19. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT 107 KEYED GROUND (CE & UK CA SPECS) (MACHINES WITH 4000W GENERATOR)
FIGURE 8-20. AC BOX AT PLATFORM INSTALLATION - 220V (2X4 BOX & COVER ONLY - LOCALLY SUPPLIED RECEPTACLE) (4000W GENERATOR)
FIGURE 8-21. AC BOX AT PLATFORM INSTALLATION - 240V GFCI RECEPTACLE (ANSI, ANSI EXPORT AND CSA SPECS WITH 4000W SKYPOWER GENERATOR)
FIGURE 8-22. AC BOX AT PLATFORM INSTALLATION - 240V GFCI RECEPTACLE (ANSI AND CSA SPECS WITH 7500W SKYPOWER GENERATOR)
FIGURE 8-23. AC CABLE WITH 16 AMP BREAKER INSTALLATION (WITHOUT 7500W SKYPOWER GENERATOR) (CE & UK CA SPECS)
FIGURE 8-24. AC CABLE WITH 10 AMP BREAKER INSTALLATION (WITHOUT 7500W SKYPOWER GENERATOR) (CE & UK CA SPECS)
FIGURE 8-25. ANALYZER CABLE HARNESS
FIGURE 8-26. BEACON CONTROL HARNESS (BLUE AND RED STROBE LIGHTS)
FIGURE 8-27. BATTERY DISCONNECT SWITCH INSTALLATION
FIGURE 8-28. BOOM CABLES INSTALLATION - WITHOUT ARCTIC PACKAGE (ALL SPECS) (800S)
FIGURE 8-29. BOOM CABLES INSTALLATION - WITH ARCTIC PACKAGE (ANSI, ANSI EXPORT AND CSA SPECS) (800S)
FIGURE 8-30. BOOM CABLES INSTALLATION - WITH 4000W GENERATOR AND WITHOUT ARCTIC PACKAGE (ANSI, ANSI EXPORT, CSA AND JAPANESE SPECS) (800S)
FIGURE 8-31. BOOM CABLES INSTALLATION - WITH 7500W GENERATOR AND WITHOUT ARCTIC PACKAGE (ALL SPECS) (800S)
FIGURE 8-32. BOOM CABLES INSTALLATION - WITH 7500W GENERATOR AND WITH ARCTIC PACKAGE (ANSI, ANSI EXPORT AND CSA SPECS) (800S)
FIGURE 8-33. BOOM CABLES INSTALLATION - WITHOUT ARCTIC PACKAGE (ALL SPECS) (860SJ)
FIGURE 8-34. BOOM CABLES INSTALLATION - WITH ARCTIC PACKAGE (ANSI, ANSI EXPORT AND CSA SPECS) (860SJ)
FIGURE 8-35. BOOM CABLES INSTALLATION - WITH 4000W GENERATOR AND WITHOUT ARCTIC PACKAGE (ANSI, ANSI EXPORT, CSA AND JAPANESE SPECS) (860SJ)
FIGURE 8-36. BOOM CABLES INSTALLATION - WITH 7500W GENERATOR AND WITHOUT ARCTIC PACKAGE (ALL SPECS) (860SJ)
FIGURE 8-37. BOOM CABLES INSTALLATION - WITH 7500W GENERATOR AND WITH ARCTIC PACKAGE (ANSI, ANSI EXPOERT AND CSA SPECS) (860SJ)
FIGURE 8-38. BOOM CABLES INSTALLATION - WITHOUT AC CABLES (CHINA SPECS) (860SJ)
FIGURE 8-39. BOOM HARNESS (MAIN BOOM) (WITHOUT ARCTIC PACKAGE) (800S)
FIGURE 8-40. BOOM HARNESS (MAIN BOOM) (WITH ARCTIC PACKAGE) (800S)
FIGURE 8-41. BOOM HARNESS (MAIN BOOM) (WITHOUT ARCTIC PACKAGE) (860SJ)
FIGURE 8-42. BOOM HARNESS (MAIN BOOM) (WITH ARCTIC PACKAGE) (860SJ)
FIGURE 8-43. BOOM CABLE (TOWER BOOM) (WITHOUT ARCTIC PACKAGE)
FIGURE 8-44. BOOM CABLE (TOWER BOOM) (WITHOUT ARCTIC PACKAGE)
FIGURE 8-45. BREAKER BOX KIT - ONE DOUBLE 16AMP BREAKER (CE & UK CA SPECS WITHOUT 7500W GENERATOR)
FIGURE 8-46. BREAKER BOX KIT - ONE DOUBLE 16AMP BREAKER (WITH 4000W/50HZ GENERATOR)
FIGURE 8-47. BREAKER BOX KIT - 10 AMP (CE & UK CA SPECS WITHOUT 7500W GENERATOR)
FIGURE 8-48. CLEARSKY 3-WIRE TELEMATICS INSTALLATION (ALL SPECS EXCEPT UL & CHINA SPECS)
FIGURE 8-49. CLEARSKY 3G CANBUS TELEMATICS INSTALLATION (ANSI EXPORT, CE & UK CA SPECS)
FIGURE 8-50. CLEARSKY 3G CANBUS TELEMATICS INSTALLATION (AUSTRALIAN SPECS)
FIGURE 8-51. CLEARSKY 4G CANBUS TELEMATICS INSTALLATION (ANSI & CSA SPECS)
FIGURE 8-52. CLEARSKY 4G CANBUS TELEMATICS INSTALLATION (CHINA SPECS)
FIGURE 8-53. CLEARSKY CS550 BEACON INSTALLATION
FIGURE 8-54. CLEARSKY HARNESS - 3-WIRE TELEMATICS
FIGURE 8-55. CLEARSKY HARNESS - CANBUS TELEMATICS
FIGURE 8-56. CSB HARNESS
FIGURE 8-57. ECU POWER JUMPER HARNESS
FIGURE 8-58. ENGINE HARNESS - DEUTZ D2011 ENGINES (ANSI EXPORT (LRC) AND AUSTRALIAN SPECS)
FIGURE 8-59. ENGINE HARNESS - DEUTZ D2011 ENGINES (CE & UK CA SPECS)
FIGURE 8-60. ENGINE HARNESS - DEUTZ TD2.9L4 AND DEUTZ 2.9L4 (STAGE V) ENGINES
FIGURE 8-61. ENGINE HARNESS - DEUTZ TD2.9L4 ENGINES & CHINA IV ENGINES WITHOUT DIESEL PARTICULATE FILTER
FIGURE 8-62. ENGINE HARNESS - DEUTZ TD2.9L4 (STAGE V & CHINA IV) ENGINES WITH DIESEL PARTICULATE FILTER
FIGURE 8-63. ENGINE HARNESS - FORD DF 2.5L ENGINES
FIGURE 8-64. FUEL PUMP HARNESS - DEUTZ TD2.9L4 ENGINES
FIGURE 8-65. FUEL HARNESS - DEUTZ TD2.9L4 (STAGE V) ENGINE
FIGURE 8-66. GENERATOR TO ENGINE HARNESS - 2500W (FORD ENGINES)
FIGURE 8-67. GENERATOR TO ENGINE HARNESS - 4000W/50HZ (DEUTZ D2011 ENGINES)
FIGURE 8-68. GENERATOR TO ENGINE HARNESS - 4000W/60HZ (DEUTZ ENGINES)
FIGURE 8-69. GENERATOR TO ENGINE HARNESS - 4000W/50HZ (DEUTZ TD2.9L4 ENGINES)
FIGURE 8-70. GENERATOR TO ENGINE HARNESS - 7500W SKYPOWER GENERATOR (DEUTZ D2011 ENGINES)
FIGURE 8-71. GENERATOR HARNESS - 7500W SKYPOWER (DEUTZ TD2.9L4 T4F ENGINES)
FIGURE 8-72. GENERATOR TO ENGINE HARNESS - 7500W SKYPOWER (FORD DF 2.5L ENGINES)
FIGURE 8-73. GENERATOR TO REAR OF BOOM HARNESS - 110V
FIGURE 8-74. GENERATOR TO REAR OF BOOM HARNESS - 220V
FIGURE 8-75. GROUND CONTROL BOX HARNESS
FIGURE 8-76. HOLDING VALVE/LIFT DUMP HARNESS ASSEMBLY (WITHOUT ARCTIC PACKAGE)
FIGURE 8-77. HOLDING VALVE/LIFT DUMP HARNESS ASSEMBLY (WITH ARCTIC PACKAGE)
FIGURE 8-78. PLATFORM CONSOLE BOX HARNESS
FIGURE 8-79. RECEPTACLE BOX KIT - 110V IEC YELLOW WITHOUT 2500W GENERATOR (CE & UK CA SPECS)
FIGURE 8-80. RECEPTACLE BOX KIT - 110V IEC YELLOW WITH 2500W GENERATOR (CE & UK CA SPECS)
FIGURE 8-81. RECEPTACLE BOX KIT - 220V IEC BLUE WITHOUT 2500W GENERATOR (CE & UK CA SPECS)
FIGURE 8-82. RECEPTACLE BOX KIT - 220V IEC BLUE WITH 2500W GENERATOR (CE & UK CA SPECS)
FIGURE 8-83. RECEPTACLE BOX KIT - 220V CEE7 POST GROUND 2X4 BOX (CE & UK CA SPEC)
FIGURE 8-84. RECEPTACLE BOX KIT - 220V CEE7 POST GROUND 2X4 BOX WITH 2500W GENERATOR (CE & UK CA SPEC)
FIGURE 8-85. RECEPTACLE BOX KIT - 220V CEE7 SIDE GROUND 2X4 BOX (CE & UK CA SPEC)
FIGURE 8-86. RECEPTACLE BOX KIT - 220V CEE7 SIDE GROUND 2X4 BOX WITH 2500W GENERATOR (CE & UK CA SPEC)
FIGURE 8-87. RECEPTACLE BOX KIT - 220V AFSINT107 KEYED GROUND (CE & UK CA SPECS)
FIGURE 8-88. RECEPTACLE BOX KIT - 220V AFSINT107 KEYED GROUND 2X4 BOX WITH 2500W GENERATOR (CE & UK CA SPECS)
FIGURE 8-89. SKYEYE INTERMEDIATE HARNESS
FIGURE 8-90. SKYEYE RECEIVER HARNESS
FIGURE 8-91. SKYEYE EMITTER HARNESS
FIGURE 8-92. SKYLINE HARNESS
FIGURE 8-93. SKYGUARD INTERFACE HARNESS
FIGURE 8-94. STROBE LIGHT JUMPER HARNESS
FIGURE 8-95. TILT SENSOR HARNESS
FIGURE 8-96. VALVE HARNESS
SECTION 9 - DECALSFIGURE 9-1. DECAL INSTALLATION (ANSI SPECS) (800S)
FIGURE 9-2. DECAL INSTALLATION (AUSTRALIAN SPECS) (800S)
FIGURE 9-3. DECAL INSTALLATION (BRAZILIAN SPECS) (800S)
FIGURE 9-4. DECAL INSTALLATION (CE & UK CA SPECS) (800S)
FIGURE 9-5. DECAL INSTALLATION (CHINESE SPECS) (800S)
FIGURE 9-6. DECAL INSTALLATION (CSA SPECS) (800S)
FIGURE 9-7. DECAL INSTALLATION (JAPANESE SPECS) (800S)
FIGURE 9-8. DECAL INSTALLATION (KOREAN SPECS) (800S)
FIGURE 9-9. DECAL INSTALLATION (LATIN AMERICAN SPECS) (800S)
FIGURE 9-10. DECAL INSTALLATION (ANSI SPECS) (860SJ)
FIGURE 9-11. DECAL INSTALLATION (AUSTRALIAN SPECS) (860SJ)
FIGURE 9-12. DECAL INSTALLATION (BRAZILIAN SPECS) (860SJ)
FIGURE 9-13. DECAL INSTALLATION (CE & UK CA SPECS) (860SJ)
FIGURE 9-14. DECAL INSTALLATION (CHINESE SPECS) (860SJ)
FIGURE 9-15. DECAL INSTALLATION (CSA SPECS) (860SJ)
FIGURE 9-16. DECAL INSTALLATION (JAPANESE SPECS) (860SJ)
FIGURE 9-17. DECAL INSTALLATION (KOREAN SPECS) (860SJ)
FIGURE 9-18. DECAL INSTALLATION (LATIN AMERICAN SPECS) (860SJ)
FIGURE 9-19. DECAL INSTALLATION - OPTIONS
FIGURE 9-20. SKYWELDER DECAL INSTALLATION - 50HZ
FIGURE 9-21. SKYWELDER DECAL INSTALLATION - 60HZ
PART NUMBER INDEX
- SuperPac Parts Manual
- StratoLift Parts Manual
