JLG Boom Lift 800S 860SJ Parts Catalog 3121270
Brand: JLG
Type of Machine: Boom Lift
Model: JLG 800S, 860SJ Boom Lift
Part Number: 3121270
Publication Date: 2025
Number of Pages: 314 Pages
SECTION 1 - FRAME
Brand: JLG
SECTION 1 - FRAME
FIGURE 1-1. AXLE AND STEERING INSTALLATION WITHOUT TOW PACKAGE
FIGURE 1-2. AXLE AND STEERING INSTALLATION WITH TOW PACKAGE
FIGURE 1-3. TIRE AND WHEEL DRIVE INSTALLATIONS
FIGURE 1-4. DRIVE HUB/BRAKE ASSEMBLY
FIGURE 1-5. DRIVE MOTOR ASSEMBLY (5 BOLT ASSEMBLY)
FIGURE 1-6. FRAME VALVES AND SHIELDS INSTALLATIONS
FIGURE 1-7. TOW PACKAGE INSTALLATION
SECTION 2 - TURNTABLEFIGURE 2-1. CONTROL VALVES INSTALLATIONS
FIGURE 2-2. MAIN CONTROL VALVE ASSEMBLY
FIGURE 2-3. TURNTABLE AND SWING DRIVE INSTALLATION
FIGURE 2-4. SWING MOTOR/HUB ASSEMBLY
FIGURE 2-5. CATERPILLAR ENGINE INSTALLATION
FIGURE 2-6. DEUTZ ENGINE INSTALLATION
FIGURE 2-7. GM ENGINE INSTALLATION
FIGURE 2-8. PUMP ASSEMBLY (SAUER-DANFOSS)
FIGURE 2-9. PUMP ASSEMBLY (EATON)
FIGURE 2-10. LOAD SENSING PUMP ASSEMBLY
FIGURE 2-11. TANK INSTALLATIONS
FIGURE 2-12. LP TANK INSTALLATIONS (GM ENGINE MACHINES ONLY)
FIGURE 2-13. ROTARY COUPLING INSTALLATION
FIGURE 2-14. GROUND CONTROL BOX ASSEMBLY
FIGURE 2-15. LIMIT SWITCHES, LIGHTS AND ALARM INSTALLATIONS
FIGURE 2-16. HOODS INSTALLATION (ABS)
FIGURE 2-17. HOODS INSTALLATION (STEEL)
FIGURE 2-18. ENGINE TRAY JACK INSTALLATION (OPTIONAL)
FIGURE 2-19. 2500W GENERATOR INSTALLATION - CATERPILLAR MACHINES (OPTIONAL)
FIGURE 2-20. 2500W GENERATOR INSTALLATION - DEUTZ MACHINES (OPTIONAL)
FIGURE 2-21. 2500W GENERATOR INSTALLATION - GM MACHINES (OPTIONAL)
FIGURE 2-22. 7500W SKYPOWER GENERATOR INSTALLATION - CATERPILLAR AND DEUTZ ENGINES
FIGURE 2-23. 7500W SKYPOWER GENERATOR INSTALLATION - GM ENGINES
SECTION 3 - BOOMFIGURE 3-1. TOWER BOOM, UPRIGHT AND CYLINDERS INSTALLATION
FIGURE 3-2. MAIN BOOM INSTALLATION (800S)
FIGURE 3-3. MAIN BOOM INSTALLATION (860SJ)
FIGURE 3-4. MAIN BOOM ASSEMBLIES
FIGURE 3-5. ROTATOR ASSEMBLIES
FIGURE 3-6. PLATFORM SUPPORT AND CONTROL VALVES INSTALLATIONS
FIGURE 3-7. BOOM CABLE CLAMPS INSTALLATIONS
SECTION 4 - PLATFORMFIGURE 4-1. PLATFORM ASSEMBLIES
FIGURE 4-2. PLATFORM COMPONENTS INSTALLATION (FALL ARREST PLATFORM)
FIGURE 4-3. PLATFORM CONSOLE ASSEMBLY
FIGURE 4-4. CONTROLLER ASSEMBLY (LIFT AND SWING)
FIGURE 4-5. CONTROLLER ASSEMBLY (LIFT AND SWING)
FIGURE 4-6. CONTROLLER ASSEMBLY (LIFT AND SWING)
FIGURE 4-7. CONTROLLER ASSEMBLY (DRIVE AND STEER)
FIGURE 4-8. CONTROLLER ASSEMBLY (DRIVE AND STEER)
FIGURE 4-9. CONTROLLER ASSEMBLY (DRIVE AND STEER)
FIGURE 4-10. SOFT TOUCH SYSTEM INSTALLATION (OPTIONAL)
FIGURE 4-11. PLATFORM BUMPER PADDING INSTALLATION (OPTIONAL)
SECTION 5 - CYLINDERFIGURE 5-1. AXLE LOCKOUT CYLINDER ASSEMBLY
FIGURE 5-2. LEVEL CYLINDER ASSEMBLY - PLATFORM SLAVE
FIGURE 5-3. LEVEL CYLINDER ASSEMBLY - PLATFORM SLAVE (SERVICE REPLACEMENT) (800S)
FIGURE 5-4. LEVEL CYLINDER ASSEMBLY - PLATFORM SLAVE (SERVICE REPLACEMENT) (860SJ)
FIGURE 5-5. LEVEL CYLINDER ASSEMBLY - PLATFORM SLAVE (860SJ)
FIGURE 5-6. LIFT CYLINDER ASSEMBLY - JIB (ORIGINAL EQUIPMENT) (860SJ)
FIGURE 5-7. LIFT CYLINDER ASSEMBLY - JIB (USAGE MAY VARY) (SERVICE REPLACEMENT) (860SJ)
FIGURE 5-8. LIFT CYLINDER ASSEMBLY - JIB (USAGE MAY VARY) (SERVICE REPLACEMENT) (860SJ)
FIGURE 5-9. LIFT CYLINDER ASSEMBLY - MAIN BOOM
FIGURE 5-10. LIFT CYLINDER ASSEMBLY - MAIN BOOM (SERVICE REPLACEMENT) (800S)
FIGURE 5-11. LIFT CYLINDER ASSEMBLY - MAIN BOOM (SERVICE REPLACEMENT) (860SJ)
FIGURE 5-12. STEER CYLINDER ASSEMBLY (SN 0300140000 through 0300142665)
FIGURE 5-13. STEER CYLINDER ASSEMBLY (SN 0300014266 through 0300182743, SN B300000100 through B300001091)
FIGURE 5-14. TELESCOPE CYLINDER ASSEMBLY
FIGURE 5-15. TELESCOPE CYLINDER ASSEMBLY (SERVICE REPLACEMENT) (800S)
FIGURE 5-16. TELESCOPE CYLINDER ASSEMBLY (SERVICE REPLACEMENT) (860SJ)
SECTION 6 - HYDRAULICFIGURE 6-1. AXLE LOCKOUT HYDRAULIC DIAGRAM
FIGURE 6-2. DRIVE HYDRAULIC DIAGRAM - 2WD
FIGURE 6-3. DRIVE HYDRAULIC DIAGRAM - 4WD
FIGURE 6-4. MANUAL DESCENT HYDRAULIC DIAGRAM (OPTIONAL)
FIGURE 6-5. STANDARD HYDRAULIC DIAGRAM
FIGURE 6-6. HYDRAULIC DIAGRAM LIST
SECTION 7 - ELECTRICALFIGURE 7-1. ELECTRICAL DIAGRAM LIST
FIGURE 7-2. HARNESS COMPONENTS INSTALLATION
SECTION 8 - DECALSFIGURE 8-1. DECAL INSTALLATION (ANSI SPEC)
FIGURE 8-2. DECAL INSTALLATION (COUNTRY SPEC)
FIGURE 8-3. DECAL INSTALLATION (AUSTRALIAN AND CE SPEC)
SECTION 9 - RECOMMENDED SERVICE PARTS STOCKFIGURE 9-1. STANDARD PARTS
FIGURE 9-2. VARIABLE PARTS
SECTION 10 - SPECIAL OPTIONSFIGURE 10-1. SPECIAL OPTIONS
PART NUMBER INDEX
- SuperPac Parts Manual
- StratoLift Parts Manual
