JLG Boom Lift 800S 860SJ Operation Safety Manual 3122340500
Brand: JLG
Type of Machine: Boom Lift
Type of Manual: Operation Safety Manual
Model: JLG 800S 860SJ Boom Lift
Part Number: 3122340500
Publication Date: 2025
Number of Pages: 164 Pages
800S 860SJ PVC 2501 Cover Page
Foreword
800S 860SJ PVC 2501 Revision Log
Brand: JLG
Foreword
Other Publications Available
Serial Number Location
Safety PrecautionsGeneral
Pre-Operation
1.2.1 Operator Training and Knowledge
1.2.2 Workplace Inspection
1.2.3 Machine Inspection
Operation
1.3.1 General
1.3.2 Trip and Fall Hazards
1.3.3 Electrocution Hazards
1.3.4 Tipping Hazards
1.3.5 Crushing and Collision Hazards
Towing, Lifting, and Hauling
Maintenance
1.5.1 Maintenance Hazards
1.5.2 Battery Hazards
Long-Term Storage
User Responsibilities, Machine Preparation, and InspectionPersonnel Training
2.1.1 Operator Training
2.1.2 Training Supervision
2.1.3 Operator Responsibility
2.1.4 Machine Familiarization
Preparation, Inspection and Maintenance
Machine Components
Pre-Start Inspection
Walk-Around Inspection
2.5.1 Walk-Around Inspection
Function Check - SJ Model
SkyGuard® Function Check
Horizontal & Capacity Proximity Switches
Oscillating Axle Lockout Test (If Equipped)
Machine Controls and IndicatorsGeneral
Ground Control Station
3.3.1 800S Ground Control Station
3.3.2 860SJ Ground Control Station
3.3.3 Ground Control Station Functions
Multifunction Display - ICE V3
3.4.1 Multifunction Display Diagnostic Screen
Ground Control Indicator Panel - ICE - Fuel Gauge
3.5.1 Ground Control Indicator Panel Functions
800S/860SJ Platform Control Station
3.6.1 Platform Control Station Functions
800S 860SJ Platform Indicator Panel
3.7.1 Platform Control Indicator Panel Functions
Beacons (With SkyGuard)
3.8.1 ClearSky® LED Motion / Amber Beacon (CS550)
3.8.2 Amber Beacon
3.8.3 Blue or Red SkyGuard® Beacon
Machine OperationGeneral SJ 360 Continuous Swing
Operating Characteristics And Limitations
4.2.1 Operating Conditions
4.2.2 Platform Load Sensing System (LSS)
800S/860SJ Stability
Engine Operation
4.4.1 Starting Procedure
4.4.2 Shutdown Procedure
Air Shutoff Valve (ASOV)
Fuel Shutoff System (Reserve) - Fuel Gauge
Diesel Particulate Filter - Standstill Cleaning(If Equipped)
4.7.1 Standstill Cleaning/ Maintenance Standstill Cleaning
DPF - Canceling/Unsuccessful Standstill
4.8.1 Canceling Maintenance Standstill/Standstill Cleaning
4.8.2 Unsuccessful Cleaning Event
DPF Filter Replacement Due to Ash Load
800S/860SJ Traveling (Grade/Side Slope)
4.10.1 Traveling on a Grade
Traveling (Driving)
4.11.1 Traveling Forward and Reverse
Steering
Platform - Standard Booms
4.13.1 Platform Level Adjustment
4.13.2 Platform Rotation
Boom - SJ Models
4.14.1 Swinging the Boom
4.14.2 Raising and Lowering the Main Boom
4.14.3 Telescoping the Main Boom
Function Speed Control - SJ Core Boom
USB Charging Port
ClearSky Smart Fleet
Access Control (Boom)
SkyGuard Activation/Deactivation - SJ
Emergency Towing
Towing (If Equipped)
Shut Down And Park
Lifting And Tie Down
4.24.1 Lifting
4.24.2 Tie Down
800SJ
800S 860SJ Safety Decals
4.26.1 Safety Decal Locations and Legend
Emergency ProceduresGeneral
Incident Notification - Boom
Emergency Operation
5.3.1 Operator Unable to Control Machine
5.3.2 Platform or Boom Caught Overhead
Emergency Towing Procedures
ClearSky Smart Fleet - Locked Out State
Accessories800S 860SJ Accessory Table
Bolt-On External Fall Arrest
6.2.1 Inspection Before Use
Cable Ladder Carrier
Fabric Mesh to Mid/Top Rail
Fall Arrest Platform
6.5.1 Safety Precautions
Nite Bright
Pipe Racks
6.7.1 Capacity Specifications
6.7.2 Safety Precautions
6.7.3 Preparation and Inspection
6.7.4 Operation
Platform Mesh to Mid/Top Rail
Platform Mid Rail Deck
6.9.1 Accessory Installation
6.9.2 Access to Manual Box
Platform Top Rail Extension
Platform Work Lights
Platform Work Surface
SkyAir
6.13.1 Compressor Specifications
6.13.2 Accessory Ratings
6.13.3 Safety Precautions
6.13.4 Preparation and Inspection
6.13.5 Operation
SkyCutter
6.14.1 Safety Precautions
6.14.2 Generator Output
6.14.3 Preparation and Inspection
6.14.4 Operation
6.14.5 Accessory Ratings
SkyGlazier
6.15.1 Capacity Specifications
6.15.2 Safety Precautions
6.15.3 Preparation and Inspection
6.15.4 Operation
SkyPower 7.5kW and Generator 4kW
6.16.1 Output
6.16.2 Safety Precautions
6.16.3 Preparation and Inspection
6.16.4 Operation
SkySense
6.17.1 Preparation and Inspection
6.17.2 Operation
6.17.3 SkySense Platform Panel Indicators
6.17.4 SkySense Alarm
6.17.5 SkySense Override Button
6.17.6 SkySense Coverage Areas
SkySense Platform Bumper Padding
SkyWelder
6.19.1 Operation
6.19.2 Generator Output
6.19.3 Welding Accessories
6.19.4 Safety Precautions
6.19.5 Preparation and Inspection
Soft Touch
General Specifications and Operator MaintenanceGeneral
800S/860SJ Operating Specifications
7.2.1 Specifications and Performance Data
7.2.2 Capacities
7.2.3 Engine Data
7.2.4 Battery
7.2.5 Tires
7.2.6 Major Component Weights
Hydraulic Oil Specifications - Introduction
Hydraulic Oil Operating Temperature - Deutz/Ford
Engine Oil Operating Temp Spec - Introduction Note
Engine Oil Operating Temperature - Deutz TD
Engine Oil Operating Temp Spec - Deutz T4F/Stage V
Engine Oil Operating Temp Spec - Ford Engine
Operator Maintenance and Lubrication Diagram 800S/860SJ
Operator Maintenance 800S/860SJ
Tires and Wheels - 10 Lug Nuts
7.11.1 Tire Damage
7.11.2 Tire Replacement
7.11.3 Wheel Replacement
7.11.4 Wheel Installation
Propane Fuel Filter Replacement (GM Engine)
7.12.1 Removal
7.12.2 Installation
Propane Fuel System Pressure Relief
Radio Frequency (RF) Information
7.14.1 Federal Communications Commission (FCC)
7.14.2 Innovation, Science and Economic Development (ISED)
7.14.3 European Union Conformity (CE)
Supplemental Information Only Applicable to CE/UKCA Machines
800S 860SJ EC Declaration of Conformity
800S 860SJ UKCA Declaration of Conformity
- SuperPac Parts Manual
- StratoLift Parts Manual
