JLG Boom Lift 800AJ Parts Catalog 31223031
Brand: JLG
Type of Machine: Boom Lift
Model: JLG 800AJ Boom Lift
Part Number: 31223031
Publication Date: 2025
Number of Pages: 992 Pages
SECTION 1 - FRAME
Brand: JLG
SECTION 1 - FRAME
FIGURE 1-1. AXLE INSTALLATION - FIXED
FIGURE 1-2. AXLE INSTALLATION - OSCILLATING
FIGURE 1-3. AXLE INSTALLATION - OSCILLATING WITH TOW PACKAGE
FIGURE 1-4. STEER INSTALLATION - 2WS
FIGURE 1-5. STEER INSTALLATION - 2WS WITH TOW PACKAGE
FIGURE 1-6. STEER INSTALLATION - 4WS
FIGURE 1-7. WHEEL DRIVE AND FRAME VALVES INSTALLATION - 2WD
FIGURE 1-8. WHEEL DRIVE AND FRAME VALVES INSTALLATION - 4WD/2WS
FIGURE 1-9. WHEEL DRIVE AND FRAME VALVES INSTALLATION - 4WD/4WS
FIGURE 1-10. HUB ASSEMBELY - 2WD FRONT
FIGURE 1-11. DRIVE HUB/BRAKE ASSEMBLY
FIGURE 1-12. DRIVE MOTOR ASSEMBLY - 2WD
FIGURE 1-13. DRIVE MOTOR ASSEMBLY - 4WD
FIGURE 1-14. TIRE AND WHEEL INSTALLATION 18-625 NHS FOAM-FILLED TIRE
FIGURE 1-15. TIRE AND WHEEL INSTALLATION 18-625 NHS FOAM-FILLED NON-MARKING TIRE
FIGURE 1-16. TIRE AND WHEEL INSTALLATION 18-625 NHS FOAM-FILLED SAND TIRE
FIGURE 1-17. LP TANK BRACKETS INSTALLATIONS
FIGURE 1-18. FRAME SHIELDS INSTALLATION - 2WS
FIGURE 1-19. FRAME SHIELDS INSTALLATION - 4WS
FIGURE 1-20. TOW PACKAGE INSTALLATION - 2WS (ENGLISH LANGUAGE DECALS)
FIGURE 1-21. TOW PACKAGE INSTALLATION - 2WS (CE & UK CA SPECS)
FIGURE 1-22. TOW BAR ASSEMBLY
SECTION 2 - TURNTABLEFIGURE 2-1. CONTROL VALVES INSTALLATION - WITH 2WS
FIGURE 2-2. CONTROL VALVES INSTALLATION - WITH 4WS
FIGURE 2-3. CONTROL VALVE ASSEMBLY - 2WS MACHINES
FIGURE 2-4. CONTROL VALVE ASSEMBLY - 4WS MACHINES
FIGURE 2-5. SWING DRIVE INSTALLATION (Prior to SN 0300315179)
FIGURE 2-6. SWING DRIVE INSTALLATION (SN 0300315179 to Present)
FIGURE 2-7. SWING MOTOR/HUB ASSEMBLY (Prior to SN 0300315179)
FIGURE 2-8. SWING MOTOR/HUB ASSEMBLY (SN 0300315179 to Present)
FIGURE 2-9. TURNTABLE BEARING INSTALLATION
FIGURE 2-10. TURNTABLE LOCK INSTALLATION
FIGURE 2-11. ROTARY COUPLING INSTALLATION - 2WS MACHINES
FIGURE 2-12. ROTARY COUPLING INSTALLATION - 4WS MACHINES
FIGURE 2-13. TANK INSTALLATION - DIESEL MACHINE (FUEL TANK WITHOUT SIGHT GLASS) (HELGESEN 6IN DIA BREATHER HYDRAULIC TANK - 25 GAL CAPACITY)
FIGURE 2-14. TANK INSTALLATION - DIESEL MACHINE (FUEL TANK WITHOUT SIGHT GLASS) (JIANGYING 4IIN DIA BREATHER HYDRAULIC TANK - 25 GAL CAPACITY)
FIGURE 2-15. TANK INSTALLATION - DIESEL MACHINE (FUEL TANK WITH SIGHT GLASS) (HELGESEN 6IIN DIA BREATHER HYDRAULIC TANK - 25 GAL CAPACITY)
FIGURE 2-16. TANK INSTALLATION - DIESEL MACHINE (FUEL TANK WITH SIGHT GLASS) (JIANGYING 4IN DIA BREATHER HYDRAULIC TANK - 25 GAL CAPACITY)
FIGURE 2-17. TANK INSTALLATION - GAS ENGINES (HELGESEN 6IN DIA BREATHER HYDRAULIC TANK - 25 GAL CAPACITY)
FIGURE 2-18. TANK INSTALLATION - GAS ENGINES (JIANGYING 4IN DIA BREATHER HYDRAULIC TANK - 25 GAL CAPACITY)
FIGURE 2-19. HYDRAULIC TANK ASSEMBLY (HELGESEN 6IN DIA BREATHER HYDRAULIC TANK - 25 GAL CAPACITY)
FIGURE 2-20. HYDRAULIC TANK ASSEMBLY (JIANGYING 4IN DIA BREATHER HYDRAULIC TANK - 25 GAL CAPACITY)
FIGURE 2-21. AUXILIARY POWER INSTALLATION - WITHOUT BATTERY DISCONNECT
FIGURE 2-22. AUXILIARY POWER INSTALLATION - WITH BATTERY DISCONNECT
FIGURE 2-23. AUXILIARY POWER PUMP/MOTOR ASSEMBLY
FIGURE 2-24. GROUND CONTROL BOX ASSEMBLY - WITH DEUTZ D2011 ENGINES - WITH MECHANICAL HOUR METER (ANSI EXPORT LRC AND AUSTRALIAN SPECS) (Prior to SN 0300315754)
FIGURE 2-25. GROUND CONTROL BOX ASSEMBLY - WITH DEUTZ D2011 ENGINES - WITH MECHANICAL HOUR METER (ANSI EXPORT LRC AND AUSTRALIAN SPECS) (SN 0300315754 to Present)
FIGURE 2-26. GROUND CONTROL BOX ASSEMBLY - WITH DEUTZ D2011 AND TOWER STOW - WITH MECHANICAL HOUR METER (ANSI EXPORT LRC AND AUSTRALIAN SPECS) (Prior to SN 0300315754)
FIGURE 2-27. GROUND CONTROL BOX ASSEMBLY - WITH DEUTZ D2011 AND TOWER STOW - WITH MECHANICAL HOUR METER (ANSI EXPORT LRC AND AUSTRALIAN SPECS) (SN 0300315754 to Present)
FIGURE 2-28. GROUND CONTROL BOX ASSEMBLY - WITH DEUTZ D2011 (CE & UK CA LRC SPECS) (Prior to SN 0300315754)
FIGURE 2-29. GROUND CONTROL BOX ASSEMBLY - WITH DEUTZ D2011 (CE & UK CA LRC SPECS) (SN 0300315754 to Present)
FIGURE 2-30. GROUND CONTROL BOX ASSEMBLY - WITH DEUTZ D2011 AND WITH TOWER STOW (CE & UK CA LRC SPECS) (Prior to SN 0300315754)
FIGURE 2-31. GROUND CONTROL BOX ASSEMBLY - WITH DEUTZ D2011 AND WITH TOWER STOW (CE & UK CA LRC SPECS) (SN 0300315754 to Present)
FIGURE 2-32. GROUND CONTROL BOX ASSEMBLY - WITH DEUTZ TD2.9L4 - WITH MECHANICAL HOUR METER (ANSI SPECS) (Prior to SN 0300315754)
FIGURE 2-33. GROUND CONTROL BOX ASSEMBLY - WITH DEUTZ TD2.9L4 - WITH MECHANICAL HOUR METER (ANSI SPECS) (SN 0300315754 to Present)
FIGURE 2-34. GROUND CONTROL BOX ASSEMBLY - WITH DEUTZ TD2.9L4 AND TOWER STOW - WITH MECHANICAL HOUR METER (ANSI SPECS) (Prior to SN 0300315754)
FIGURE 2-35. GROUND CONTROL BOX ASSEMBLY - WITH DEUTZ TD2.9L4 AND TOWER STOW - WITH MECHANICAL HOUR METER (ANSI SPECS) (SN 0300315754 to Present)
FIGURE 2-36. GROUND CONTROL BOX ASSEMBLY - WITH DEUTZ TD2.9L4 (STAGE V) (CE & UK CA SPECS) (Prior to SN 0300315754)
FIGURE 2-37. GROUND CONTROL BOX ASSEMBLY - WITH DEUTZ TD2.9L4 (STAGE V) (CE & UK CA SPECS) (SN 0300315754 to Present)
FIGURE 2-38. GROUND CONTROL BOX ASSEMBLY - WITH DEUTZ TD2.9L4 (STAGE V) AND WITH TOWER STOW (CE & UK CA SPECS) (Prior to SN 0300315754)
FIGURE 2-39. GROUND CONTROL BOX ASSEMBLY - WITH DEUTZ TD2.9L4 (STAGE V) AND WITH TOWER STOW (CE & UK CA SPECS) (SN 0300315754 to Present)
FIGURE 2-40. GROUND CONTROL BOX ASSEMBLY - WITH FORD ENGINES - WITH MECHANICAL HOUR METER (Prior to SN 0300315754)
FIGURE 2-41. GROUND CONTROL BOX ASSEMBLY - WITH FORD ENGINES - WITH MECHANICAL HOUR METER (SN 0300315754 to Present)
FIGURE 2-42. GROUND CONTROL BOX ASSEMBLY - WITH FORD ENGINES AND TOWER STOW - WITH MECHANICAL HOUR METER (Prior to SN 0300315754)
FIGURE 2-43. GROUND CONTROL BOX ASSEMBLY - WITH FORD ENGINES AND TOWER STOW - WITH MECHANICAL HOUR METER (SN 0300315754 to Present)
FIGURE 2-44. LIGHT PANEL INSTALLATION
FIGURE 2-45. ALARM INSTALLATION
FIGURE 2-46. WHITE NOISE ALARM INSTALLATION - ADJUSTABLE AMBIENT
FIGURE 2-47. WHITE NOISE MOTION ALARM INSTALLATION - AMBIENT
FIGURE 2-48. SKYAIR AIR COMPRESSOR INSTALLATION (ANSI EXPORT AND CHINA SPECS)
FIGURE 2-49. SKYAIR AIR COMPRESSOR INSTALLATION (ANSI AND CSA SPECS)
FIGURE 2-50. AIR COMPRESSOR ASSEMBLY
FIGURE 2-51. HOODS INSTALLATION - ABS (DEUTZ D2011 ENGINES)
FIGURE 2-52. HOODS INSTALLATION - ABS (DEUTZ TD2.9L4 ENGINES AND DEUTZ TD2.9L4 (STAGE V PRE-BUY) ENGINES)
FIGURE 2-53. HOODS INSTALLATION - ABS (DEUTZ TD2.9L4 (STAGE V) ENGINES)
FIGURE 2-54. HOODS INSTALLATION - STEEL (DEUTZ D2011 ENGINES)
FIGURE 2-55. HOODS INSTALLATION - STEEL (DEUTZ TD2.9L4 ENGINES)
FIGURE 2-56. HOODS INSTALLATION - STEEL (FORD ENGINES)
FIGURE 2-57. EXHAUST COVER AND HEAT SHIELDS INSTALLATION - STEEL HOODS (DEUTZ D2011 ENGINES)
FIGURE 2-58. EXHAUST COVER AND HEAT SHIELDS INSTALLATION - STEEL HOODS (DEUTZ TD2.9L4 ENGINES)
FIGURE 2-59. EXHAUST COVER INSTALLATION - STEEL HOODS (FORD ENGINES)
SECTION 3 - ENGINEFIGURE 3-1. DEUTZ D2011 ENGINE INSTALLATION (WITHOUT ARCTIC PACKAGE)
FIGURE 3-2. DEUTZ D2011 ENGINE INSTALLATION (WITH ARCTIC PACKAGE)
FIGURE 3-3. DEUTZ D2011 ENGINE AND PUMP SUB-ASSEMBLY (WITHOUT ARCTIC PACKAGE)
FIGURE 3-4. DEUTZ TD2.9L4 ENGINE AND PUMP SUB ASSEMBLY (WITH ARCTIC PACKAGE)
FIGURE 3-5. DEUTZ D2011 ENGINE ASSEMBLY (WITHOUT ARCTIC PACKAGE)
FIGURE 3-6. DEUTZ D2011 ENGINE ASSEMBLY (WITH ARCTIC PACKAGE)
FIGURE 3-7. DEUTZ D2011 ENGINE COMPONENTS
FIGURE 3-8. DEUTZ TD2.9L4 ENGINE INSTALLATION (STAGE V)
FIGURE 3-9. DEUTZ TD2.9L4 ENGINE INSTALLATION (CHINA III)
FIGURE 3-10. DEUTZ TD2.9L4 ENGINE INSTALLATION (CHINA IV)
FIGURE 3-11. DEUTZ TD2.9L4 ENGINE AND PUMP SUB-ASSEMBLY (STAGE V)
FIGURE 3-12. DEUTZ TD2.9L4 ENGINE AND PUMP SUB-ASSEMBLY (CHINA III)
FIGURE 3-13. DEUTZ TD2.9L4 ENGINE AND PUMP SUB-ASSEMBLY (CHINA IV)
FIGURE 3-14. DEUTZ TD2.9L4 ENGINE ASSEMBLY (STAGE V)
FIGURE 3-15. DEUTZ TD2.9L4 ENGINE ASSEMBLY (CHINA III)
FIGURE 3-16. DEUTZ TD2.9L4 ENGINE ASSEMBLY (CHINA IV) (Prior to SN 0300312810, Except SN 0300312099 through 0300312102)
FIGURE 3-17. DEUTZ TD2.9L4 ENGINE ASSEMBLY (CHINA IV) (SN 0300312810 to Present, SN 0300312099 through 0300312102, Including 0300312016)
FIGURE 3-18. DEUTZ TD2.9L4 ENGINE COMPONENTS (STAGE V)
FIGURE 3-19. DEUTZ TD2.9L4 ENGINE COMPONENTS (CHINA III)
FIGURE 3-20. DEUTZ ENGINE COMPONENTS - CHINA IV
FIGURE 3-21. DEUTZ D2.9L4 - EMR5 ENGINE INSTALLATION WITH ARCTIC PACKAGE
FIGURE 3-22. DEUTZ D2.9L4 - EMR5 ENGINE AND PUMP SUB-ASSEMBLY WITH ARCTIC PACKAGE
FIGURE 3-23. ENGINE ASSEMBLY - DEUTZ D2.9L4 EMR5 ENGINE (WITH ARCTIC PACKAGE)
FIGURE 3-24. DEUTZ D2.9L4 - EMR5 ENGINE INSTALLATION WITHOUT ARCTIC PACKAGE
FIGURE 3-25. DEUTZ D2.9L4 - EMR5 ENGINE AND PUMP SUB-ASSEMBLY WITHOUT ARCTIC PACKAGE
FIGURE 3-26. ENGINE ASSEMBLY - DEUTZ D2.9L4 EMR5 ENGINE (WITHOUT ARCTIC PACKAGE)
FIGURE 3-27. ENGINE COMPONENTS - DEUTZ D2.9L4 EMR5 ENGINE
FIGURE 3-28. FUEL PUMP/FILTER BRACKET ASSEMBLY (DEUTZ TD2.9L4 ENGINES)
FIGURE 3-29. FUEL PUMP/FILTER BRACKET ASSEMBLY (DEUTZ TD2.9L4 (STAGE V) ENGINES)
FIGURE 3-30. FUEL PUMP/FILTER BRACKET ASSEMBLY (DEUTZ TD2.9L4 ENGINES) (CHINA III)
FIGURE 3-31. BREATHER HEATER INST (DEUTZ TD2.9L4 ENGINES)
FIGURE 3-32. PUMP COUPLING KIT (DEUTZ ENGINES)
FIGURE 3-33. FORD ENGINE INSTALLATION (WITHOUT ARCTIC PACKAGE)
FIGURE 3-34. FORD ENGINE INSTALLATION (WITH ARCTIC PACKAGE)
FIGURE 3-35. FORD ENGINE AND PUMP SUB-ASSEMBLY (WITHOUT ARCTIC PACKAGE)
FIGURE 3-36. FORD ENGINE AND PUMP SUB-ASSEMBLY (WITH ARCTIC PACKAGE)
FIGURE 3-37. FORD ENGINE ASSEMBLY (WITHOUT ARCTIC PACKAGE)
FIGURE 3-38. FORD ENGINE ASSEMBLY (WITH ARCTIC PACKAGE)
FIGURE 3-39. FORD ENGINE DRIVE BELT INSTALLATION (MACHINES WITHOUT GENERATOR)
FIGURE 3-40. FORD ENGINE COMPONENTS
FIGURE 3-41. FORD ENGINE PREP ASSEMBLY
FIGURE 3-42. FORD ENGINE BRACKETS AND EXHAUST MANIFOLD INSTALLATION
FIGURE 3-43. HYDROSTATIC PUMP ASSEMBLY
FIGURE 3-44. VARIABLE PUMP ASSEMBLY - DANFOSS
FIGURE 3-45. VARIABLE PUMP ASSEMBLY - HENGLI
FIGURE 3-46. HYDROSTATIC PUMP ASSEMBLY
FIGURE 3-47. EXHAUST PIPE INSTALLATION - DEUTZ TD2.9L4 ENGINES AND DEUTZ TD2.9L4 (STAGE V PRE-BUY) ENGINES
FIGURE 3-48. EXHAUST PIPE INSTALLATION - DEUTZ TD2.9L4 (STAGE V) ENGINES
FIGURE 3-49. EXHAUST PIPE INSTALLATION - FORD ENGINES
FIGURE 3-50. SPARK ARRESTOR MUFFLER INSTALLATION - DEUTZ D2011 ENGINES
FIGURE 3-51. SPARK ARRESTOR MUFFLER INSTALLATION - DEUTZ TD2.9L4 ENGINES
FIGURE 3-52. SPARK ARRESTOR MUFFLER INSTALLATION - FORD ENGINES
FIGURE 3-53. SPARK ARRESTOR INSTALLATION (WITH STEEL HOODS) (SN 0300314141 to Present, SN 0300314136 through 0300314137)
FIGURE 3-54. SPARK ARRESTOR INSTALLATION (WITH PLASTIC HOODS) (SN 0300314141 to Present, SN 0300314136 through 0300314137)
FIGURE 3-55. FUEL-WATER SEPARATOR INSTALLATION - DEUTZ D2011 ENGINES
FIGURE 3-56. FUEL-WATER SEPARATOR INSTALLATION - DEUTZ TD2.9L4 ENGINES
FIGURE 3-57. RIGHT ENGINE SUPPORT INSTALLATION (DEUTZ D2011 ENGINES MACHINES WITHOUT GENERATORS)
FIGURE 3-58. RIGHT ENGINE SUPPORT INSTALLATION (DEUTZ D2011 ENGINES MACHINES WITH GENERATORS)
FIGURE 3-59. ENGINE HOOD BAFFLE INSTALLATION - DEUTZ TD2.9L4 ENGINES, DEUTZ TD2.9L4 (STAGE V PRE-BUY) ENGINES AND DEUTZ TD2.9L4 (STAGE V) ENGINES WITH ABS HOODS
FIGURE 3-60. ENGINE HOOD BAFFLE INSTALLATION - DEUTZ TD2.9L4 ENGINES WITH STEEL HOODS
FIGURE 3-61. ENGINE TRAY JACK INSTALLATION - DEUTZ ENGINES
FIGURE 3-62. ENGINE TRAY JACK INSTALLATION - FORD ENGINES
FIGURE 3-63. 2500W/110V/60HZ GENERATOR INSTALLATION - DEUTZ D2011 ENGINES
FIGURE 3-64. 2500W/110V/60HZ GENERATOR INSTALLATION - DEUTZ TD2.9L4 ENGINES
FIGURE 3-65. 2500W/110V/60HZ GENERATOR INSTALLATION - FORD ENGINES
FIGURE 3-66. 2500W/220V/50HZ GENERATOR INSTALLATION - DEUTZ D2011 ENGINES
FIGURE 3-67. 4000W/50HZ GENERATOR INSTALLATION - DEUTZ D2011 ENGINES
FIGURE 3-68. 4000W/50HZ GENERATOR INSTALLATION - DEUTZ TD2.9L4 ENGINES, DEUTZ TD2.9L4 (STAGE V PRE-BUY) ENGINES AND DEUTZ TD2.9L4 (STAGE V) ENGINES
FIGURE 3-69. 4000W/60HZ GENERATOR INSTALLATION - DEUTZ D2011 ENGINES
FIGURE 3-70. 4000W/60HZ GENERATOR INSTALLATION - DEUTZ TD2.9L4 ENGINES
FIGURE 3-71. 7500W/50HZ SKYPOWER GENERATOR INSTALLATION - DEUTZ D2011 ENGINES
FIGURE 3-72. 7500W/50HZ SKYPOWER GENERATOR INSTALLATION - DEUTZ TD2.9L4 ENGINES, DEUTZ TD2.9L4 (STAGE V PRE-BUY) ENGINES AND DEUTZ TD2.9L4 (STAGE V) ENGINES
FIGURE 3-73. 7500W/60HZ SKYPOWER GENERATOR INSTALLATION - DEUTZ D2011 ENGINES
FIGURE 3-74. 7500W/60HZ SKYPOWER GENERATOR INSTALLATION - DEUTZ TD2.9L4 ENGINES
FIGURE 3-75. 7500W/60HZ SKYPOWER GENERATOR INSTALLATION - FORD ENGINES
FIGURE 3-76. QUICKFIT OIL VALVE
SECTION 4 - BOOMFIGURE 4-1. BOOM AND CYLINDER INSTALLATION - WITHOUT ARCTIC PACKAGE
FIGURE 4-2. BOOM AND CYLINDER INSTALLATION - WITH ARCTIC PACKAGE
FIGURE 4-3. BOOM ASSEMBLY - MAIN (WITHOUT ARCTIC PACKAGE)
FIGURE 4-4. BOOM ASSEMBLY - MAIN (WITH ARCTIC PACKAGE)
FIGURE 4-5. TOWER BOOM ASSEMBLY
FIGURE 4-6. JIB ASSEMBLY (Prior to SN 0300307186)
FIGURE 4-7. JIB ASSEMBLY (SN 0300307186 to Present)
FIGURE 4-8. ROTATOR ASSEMBLY
FIGURE 4-9. SUPPORT, PLATFORM INSTALLATION
FIGURE 4-10. BOOM VALVES AND PROXIMITY SWITCHES INSTALLATION
FIGURE 4-11. BOOM VALVES AND PROXIMITY SWITCHES INSTALLATION WITH TOWER STOW
FIGURE 4-12. CONTROL VALVES INSTALLATION - WITH 2WS
FIGURE 4-13. CONTROL VALVES INSTALLATION - WITH 4WS
FIGURE 4-14. BOOM VALVE ASSEMBLY
FIGURE 4-15. CONTROL VALVE ASSEMBLY
FIGURE 4-16. POWER TRACK INSTALLATION - MAIN BOOM
FIGURE 4-17. POWER TRACK INSTALLATION - TOWER BOOM WITHOUT ARCTIC PACKAGE
FIGURE 4-18. POWER TRACK INSTALLATION - TOWER BOOM WITH ARCTIC PACKAGE
FIGURE 4-19. TRANSPORT POSITION SWITCH INSTALLATION
FIGURE 4-20. UPRIGHT TILT SENSOR INSTALLATION
SECTION 5 - PLATFORMFIGURE 5-1. PLATFORM ASSEMBLY WITH DROP-BAR - 30IN X 3FT (76CM X 1M)
FIGURE 5-2. PLATFORM ASSEMBLY WITH GATE - 30IN X 4FT (76CM X 1.22M)
FIGURE 5-3. PLATFORM ASSEMBLY WITH DROP-BAR - 30IN X 4FT (76CM X 1.22M)
FIGURE 5-4. PLATFORM ASSEMBLY WITH GATE - 30IN X 6FT (76CM X 1.83M)
FIGURE 5-5. PLATFORM ASSEMBLY WITH GATE- 36IN X 6FT (91.5CM X 1.83M)
FIGURE 5-6. PLATFORM ASSEMBLY WITH DROP-BAR - 30IN X 6FT (76CM X 1.83M)
FIGURE 5-7. PLATFORM ASSEMBLY WITH DROP-BAR - 36IN X 6FT (91.5CM X 1.83M)
FIGURE 5-8. PLATFORM ASSEMBLY WITH 1 GATE / 2 DROP BARS (TRI-ENTRY) - 36IN X 6FT (91.5CM X 1.83M)
FIGURE 5-9. PLATFORM ASSEMBLY WITH 3 DROP BARS (TRI-ENTRY) - 36IN X 6FT (91.5CM X 1.83M)
FIGURE 5-10. PLATFORM ASSEMBLY WITH FALL ARREST (6FT)
FIGURE 5-11. PLATFORM ASSEMBLY WITH GATE - 36IN X 8FT (91.5CM X 2.44M)
FIGURE 5-12. PLATFORM ASSEMBLY WITH DROP-BAR - 36IN X 8FT (91.5CM X 2.44M)
FIGURE 5-13. PLATFORM ASSEMBLY WITH 1 GATE / 2 DROP BARS (TRI-ENTRY) - 36IN X 8FT (91.5CM X 2.44M)
FIGURE 5-14. PLATFORM ASSEMBLY WITH 3 DROP BARS (TRI-ENTRY) - 36IN X 8FT (91.5CM X 2.44M)
FIGURE 5-15. PLATFORM ASSEMBLY WITH FALL ARREST (8FT)
FIGURE 5-16. CONSOLE AND FOOT SWITCH INSTALLATION
FIGURE 5-17. CONSOLE AND FOOT SWITCH INSTALLATION WITH TOWER STOW
FIGURE 5-18. CONSOLE BOX ASSEMBLY WITH FOOTSWITCH (Prior to SN 0300316654)
FIGURE 5-19. CONSOLE BOX ASSEMBLY WITH FOOTSWITCH (WITHOUT TOWER STOW) (SN 0300316654 to Present)
FIGURE 5-20. CONSOLE BOX ASSEMBLY WITH FOOTSWITCH WITH TOWER STOW (Prior to SN 0300316654)
FIGURE 5-21. CONSOLE BOX ASSEMBLY WITH FOOTSWITCH (WITH TOWER STOW) (SN 0300316654 to Present)
FIGURE 5-22. FOOTSWITCH ASSEMBLY
FIGURE 5-23. JIB SWITCH INSTALLATION - 800AJ
FIGURE 5-24. LIGHT PANEL INSTALLATION
FIGURE 5-25. STEER SWITCH INSTALLATION - 4WS
FIGURE 5-26. FALL ARREST INSTALLATION (BOLT-ON) 30IN X 4FT (76CM X 1.22M) PLATFORM
FIGURE 5-27. FALL ARREST INSTALLATION (BOLT-ON) 36IN X 6FT (91.2CM X 1.82M) PLATFORM
FIGURE 5-28. FALL ARREST INSTALLATION (BOLT-ON) 30IN X 6FT (76CM X 1.83M) PLATFORM
FIGURE 5-29. FALL ARREST INSTALLATION (BOLT-ON) 36IN X 8FT (91.5CM X 2.4M) PLATFORM
FIGURE 5-30. FALL ARREST INSTALLATION (BOLT-ON) 36IN X 6FT (91.5CM X 1.82M) TRI-ENTRY PLATFORM)
FIGURE 5-31. SKYCUTTER INSTALLATION
FIGURE 5-32. PLASMA CUTTER ASSEMBLY
FIGURE 5-33. SKYEYE INSTALLATION
FIGURE 5-34. SKYGLAZIER INSTALLATION (ENGLISH LANGUAGE DECALS)
FIGURE 5-35. SKYGLAZIER INSTALLATION (SPANISH LANGUAGE DECALS)
FIGURE 5-36. SKYGLAZIER INSTALLATION (PORTUGUESE LANGUAGE DECALS)
FIGURE 5-37. SKYGUARD BAR INSTALLATION
FIGURE 5-38. SKYLINE INSTALLATION
FIGURE 5-39. SKYWELDER INSTALLATION (50HZ)
FIGURE 5-40. SKYWELDER INSTALLATION (60HZ)
FIGURE 5-41. SKYWELDER/SKYCUTTER COMBO INSTALLATION (60HZ)
FIGURE 5-42. WELDER ASSEMBLY
FIGURE 5-43. SKYWELDER PREP PACKAGE (60HZ)
FIGURE 5-44. SOFT TOUCH SYSTEM INSTALLATION - 6FT/1.83M PLATFORM
FIGURE 5-45. SOFT TOUCH SYSTEM INSTALLATION - 6FT/1.83M FALL ARREST PLATFORM
FIGURE 5-46. SOFT TOUCH SYSTEM INSTALLATION - 8FT/2.44M PLATFORM
FIGURE 5-47. SOFT TOUCH SYSTEM INSTALLATION - 8FT/2.44M FALL ARREST PLATFORM
FIGURE 5-48. STORAGE TRAY INSTALLATION - CENTER
FIGURE 5-49. USB CHARGER INSTALLATION
FIGURE 6-2. LEVEL (SLAVE) CYLINDER ASSEMBLY - JIB
FIGURE 6-3. LEVEL CYLINDER ASSEMBLY - UPRIGHT
FIGURE 6-4. LIFT CYLINDER ASSEMBLY - JIB (Prior to SN 0300307186)
FIGURE 6-5. LIFT CYLINDER ASSEMBLY - JIB (SN 0300307186 to Present)
FIGURE 6-6. LIFT CYLINDER ASSEMBLY - MAIN BOOM
FIGURE 6-7. LIFT CYLINDER ASSEMBLY - TOWER BOOM
FIGURE 6-8. MASTER CYLINDER ASSEMBLY
FIGURE 6-9. STEER CYLINDER ASSEMBLY
FIGURE 6-10. TELESCOPE CYLINDER ASSEMBLY - MAIN BOOM (WITHOUT ARCTIC PACKAGE)
FIGURE 6-11. TELESCOPE CYLINDER ASSEMBLY - MAIN BOOM (WITH ARCTIC PACKAGE)
FIGURE 6-12. TELESCOPE CYLINDER ASSEMBLY - TOWER BOOM
SECTION 7 - HYDRAULICFIGURE 7-1. HYDRAULIC DIAGRAM - AXLE (OSCILLATING)
FIGURE 7-2. HYDRAULIC DIAGRAM - DRIVE (2WD/2WS WITHOUT TOW PACKAGE)
FIGURE 7-3. HYDRAULIC DIAGRAM - DRIVE (2WD/2WS WITH TOW PACKAGE)
FIGURE 7-4. HYDRAULIC DIAGRAM - DRIVE (4WD/2WS WITHOUT TOW PACKAGE/WITHOUT ARCTIC PACKAGE)
FIGURE 7-5. HYDRAULIC DIAGRAM - DRIVE (4WD/2WS WITHOUT TOW PACKAGE/WITH ARCTIC PACKAGE)
FIGURE 7-6. HYDRAULIC DIAGRAM - DRIVE (4WD/2WS WITH TOW PACKAGE/WITHOUT ARCTIC PACKAGE)
FIGURE 7-7. HYDRAULIC DIAGRAM - DRIVE (4WD/2WS WITH TOW PACKAGE/WITH ARCTIC PACKAGE)
FIGURE 7-8. HYDRAULIC DIAGRAM - DRIVE (4WD/4WS WITHOUT TOW PACKAGE/WITHOUT ARCTIC PACKAGE)
FIGURE 7-9. HYDRAULIC DIAGRAM - DRIVE (4WD/4WS WITHOUT TOW PACKAGE/WITH ARCTIC PACKAGE)
FIGURE 7-10. HYDRAULIC DIAGRAM - DRIVE (2WD/2WS WITHOUT TOW PACKAGE) (ALL SPECS EXCEPT CE & UK CA)
FIGURE 7-11. HYDRAULIC DIAGRAM - DRIVE (4WD/4WS WITHOUT TOW PACKAGE) (ALL SPECS)
FIGURE 7-12. HYDRAULIC DIAGRAM - DRIVE (2WD/2WS WITH TOW PACKAGE) (ANSI SPEC ONLY)
FIGURE 7-13. HYDRAULIC DIAGRAM - DRIVE (4WD/2WS WITH TOW PACKAGE) (CE & UK CA SPECS ONLY)
FIGURE 7-14. HYDRAULIC DIAGRAM - DRIVE (4WD/2WS WITH TOW PACKAGE AND ARCTIC PACKAGE) (ANSI SPEC ONLY)
FIGURE 7-15. HYDRAULIC DIAGRAM - DRIVE (4WD/2WS WITHOUT TOW PACKAGE AND WITHOUT ARCTIC PACKAGE) (ALL SPECS)
FIGURE 7-16. HYDRAULIC DIAGRAM - DRIVE (4WD/2WS WITHOUT TOW PACKAGE AND WITH ARCTIC PACKAGE) (CSA AND ANSI SPECS)
FIGURE 7-17. HYDRAULIC DIAGRAM - DRIVE (4WD/4WS WITHOUT TOW PACKAGE AND WITH ARCTIC PACKAGE) (CSA AND ANSI SPECS)
FIGURE 7-18. HYDRAULIC DIAGRAM - STANDARD 800AJ
SECTION 8 - ELECTRICALFIGURE 8-1. 800AJ ELECTRICAL LAYOUT
FIGURE 8-2. AC BOX AT PLATFORM INSTALLATION - 110V GFI RECEPTACLE (ALL SPECS EXCEPT AUSTRALIAN, CE & UK CA SPECS)
FIGURE 8-3. AC BOX AT PLATFORM INSTALLATION - 220V (ANSI, CSA & JAPANESE SPECS)
FIGURE 8-4. AC BOX AT PLATFORM MID-BOOM PLUG INSTALLATION (WITH 4000W/60HZ GENERATOR) (ANSI, ANSI EXPORT, CHINA, CSA & JAPANESE SPECS)
FIGURE 8-5. AC BOX AT PLATFORM MID-BOOM PLUG INSTALLATION (WITHOUT 7500W SKYPOWER GENERATOR) (ALL SPECS EXCEPT ANSI & CSA SPECS)
FIGURE 8-6. AC BOX AT PLATFORM MID-BOOM PLUG INSTALLATION (WITH 7500W SKYPOWER GENERATOR)
FIGURE 8-7. AC BOX AT PLATFORM INSTALLATION - 110V IEC YELLOW (CE & UK CA SPECS) (MACHINES WITH 2500W GENERATOR OR NO GENERATOR OPTION)
FIGURE 8-8. AC BOX AT PLATFORM INSTALLATION - 110V IEC YELLOW (CE & UK CA SPECS) (MACHINES WITH 4000W GENERATOR)
FIGURE 8-9. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE (CE & UK CA SPECS) (MACHINES WITH 2500W GENERATOR OR NO GENERATOR OPTION)
FIGURE 8-10. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE (CE & UK CA SPECS) (MACHINES WITH 4000W GENERATOR)
FIGURE 8-11. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 POST GROUND (CE & UK CA SPECS) (MACHINES WITH 2500W GENERATOR OR NO GENERATOR OPTION)
FIGURE 8-12. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 POST GROUND (CE & UK CA SPECS) (MACHINES WITH 4000W GENERATOR)
FIGURE 8-13. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 SIDE GROUND (CE & UK CA SPECS) (MACHINES WITH 2500W GENERATOR OR NO GENERATOR OPTION)
FIGURE 8-14. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 SIDE GROUND (CE & UK CA SPECS) (MACHINES WITH 4000W GENERATOR)
FIGURE 8-15. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT 107 KEYED GROUND (CE & UK CA SPECS) (MACHINES WITH 2500W GENERATOR OR NO GENERATOR OPTION)
FIGURE 8-16. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT 107 KEYED GROUND (CE & UK CA SPECS) (MACHINES WITH 4000W GENERATOR)
FIGURE 8-17. AC BOX AT PLATFORM INSTALLATION - 220V (2X4 BOX & COVER ONLY - LOCALLY SUPPLIED RECEPTACLE) (4000W GENERATOR)
FIGURE 8-18. AC BOX AT PLATFORM INSTALLATION - 240V GFCI RECEPTACLE (ANSI, ANSI EXPORT AND CSA SPECS WITH 4000W SKYPOWER GENERATOR)
FIGURE 8-19. AC BOX AT PLATFORM INSTALLATION - 240V GFCI RECEPTACLE (ANSI AND CSA SPECS WITH 7500W SKYPOWER GENERATOR)
FIGURE 8-20. BATTERY DISCONNECT SWITCH INSTALLATION
FIGURE 8-21. BOOM CABLES INSTALLATION - WITH 2500W GENERATOR OR NO GENERATOR OPTION (ANSI & CSA SPECS)
FIGURE 8-22. BOOM CABLES INSTALLATION - WITH 2500W GENERATOR OR NO GENERATOR OPTION (CE & UK CA SPECS)
FIGURE 8-23. BOOM CABLES INSTALLATION - WITH 2500W GENERATOR OR NO GENERATOR OPTION (ANSI EXPORT, AUSTRALIAN, CHINA & JAPANESE SPECS)
FIGURE 8-24. BOOM CABLES INSTALLATION - WITH 2500W GENERATOR OR NO GENERATOR OPTION & ARCTIC PACKAGE (ANSI, ANSI EXPORT, CHINA & CSA SPECS)
FIGURE 8-25. BOOM CABLES INSTALLATION - WITH 4000W GENERATOR (ALL SPECS)
FIGURE 8-26. BOOM CABLES INSTALLATION - WITH 7500W SKYPOWER GENERATOR (ALL SPECS EXCEPT CE & UK CA SPECS)
FIGURE 8-27. BOOM CABLES INSTALLATION - WITH 7500W SKYPOWER GENERATOR (CE & UK CA SPECS)
FIGURE 8-28. BOOM CABLES INSTALLATION - WITH 7500W SKYPOWER GENERATOR & ARCTIC PACKAGE (ANIT, ANSI EXPORT, CHINA & CSA SPECS)
FIGURE 8-29. BOOM CABLES INSTALLATION - WITH 7500W SKYPOWER GENERATOR AND COMMUNICATION CABLES (ANSI SPECS)
FIGURE 8-30. BOOM CABLE - MAIN BOOM (WITH ARCTIC PACKAGE)
FIGURE 8-31. BOOM CABLE - MAIN BOOM
FIGURE 8-32. BOOM CABLE - TOWER BOOM WITHOUT ARCTIC PACKAGE
FIGURE 8-33. BOOM CABLE - TOWER BOOM WITH ARCTIC PACKAGE
FIGURE 8-34. BOOM VALVE HARNESS
FIGURE 8-35. BREAKER BOX INSTALLATION (BRAZIL SPECS)
FIGURE 8-36. BREAKER BOX INSTALLATION (CE & UK CA SPECS WITHOUT 4000W GENERATOR)
FIGURE 8-37. BREAKER BOX KIT - ONE DOUBLE 16AMP BREAKER (BRAZIL SPECS, CE & UK CA SPECS WITHOUT 4000W GENERATOR)
FIGURE 8-38. BREAKER BOX KIT - ONE DOUBLE 16AMP BREAKER (CE & UK CA SPECS WITH 4000W GENERATOR)
FIGURE 8-39. CLEARSKY CS550 BEACON INSTALLATION
FIGURE 8-40. ECU POWER JUMPER HARNESS
FIGURE 8-41. ENGINE HARNESS - DEUTZ TD2.9L4 AND DEUTZ TD2.9L4 (CHINA III) ENGINES
FIGURE 8-42. ENGINE HARNESS - DEUTZ TD2.9L4 (STAGE V & CHINA IV) ENGINES
FIGURE 8-43. ENGINE HARNESS - FORD ENGINES
FIGURE 8-44. FUEL PUMP HARNESS - DEUTZ TD2.9L4 ENGINES
FIGURE 8-45. FUEL HARNESS - DEUTZ TD2.9L4 (STAGE V) ENGINE
FIGURE 8-46. GENERATOR HARNESS - 4000W GENERATOR
FIGURE 8-47. GENERATOR HARNESS - 7500W SKYPOWER GENERATOR
FIGURE 8-48. GENERATOR TO ENGINE HARNESS - 2500W (FORD ENGINES)
FIGURE 8-49. GENERATOR TO ENGINE HARNESS - 4000W (DEUTZ D2011 ENGINES)
FIGURE 8-50. GENERATOR TO ENGINE HARNESS - 4000W (DEUTZ TD2.9L4 ENGINES)
FIGURE 8-51. GENERATOR TO ENGINE HARNESS - 7500W SKYPOWER GENERATOR (DEUTZ D2011 ENGINES)
FIGURE 8-52. GENERATOR TO ENGINE HARNESS - 7500W SKYPOWER (FORD DF 2.5L ENGINES)
FIGURE 8-53. GENERATOR HARNESS - 7500W SKYPOWER (DEUTZ TD2.9L4 T4F ENGINES)
FIGURE 8-54. GENERATOR TO REAR OF BOOM HARNESS - 110V
FIGURE 8-55. GENERATOR TO REAR OF BOOM HARNESS - 220V
FIGURE 8-56. GROUND CONTROL BOX HARNESS (Prior to SN 0300315754)
FIGURE 8-57. GROUND CONTROL BOX HARNESS (SN 0300315754 to Present)
FIGURE 8-58. GROUND CONTROL ENGINE HARNESS - DEUTZ D2011 ENGINES
FIGURE 8-59. GROUND CONTROL ENGINE HARNESS - DEUTZ TD2.9L4 (STAGE V) ENGINE
FIGURE 8-60. PLATFORM CONSOLE BOX HARNESS (Prior to SN 0300316654)
FIGURE 8-61. PLATFORM CONSOLE BOX HARNESS (SN 0300316654 to Present)
FIGURE 8-62. RECEPTACLE BOX KIT - 110V IEC YELLOW (CE & UK CA SPECS)
FIGURE 8-63. RECEPTACLE BOX KIT - 220V IEC BLUE (CE & UK CA SPECS)
FIGURE 8-64. RECEPTACLE BOX KIT - 220V CEE7 POST GROUND 2X4 BOX (CE & UK CA SPECS)
FIGURE 8-65. RECEPTACLE BOX KIT - 220V CEE7 SIDE GROUND 2X4 BOX (CE & UK CA SPECS)
FIGURE 8-66. RECEPTACLE BOX KIT - 220V AFSINT107 KEYED GROUND (CE & UK CA SPECS)
FIGURE 8-67. RECEPTACLE/BREAKER BOX ASSEMBLY - 240V (7500W SKYPOWER GENERATORS) (ANSI, ANSI EXPORT AND CSA SPECS)
FIGURE 8-68. SKYEYE EMITTER HARNESS
FIGURE 8-69. SKYEYE INTERMEDIATE HARNESS
FIGURE 8-70. SKYEYE RECEIVER HARNESS
FIGURE 8-71. SKYLINE HARNESS
FIGURE 8-72. SKYGUARD INTERFACE HARNESS
FIGURE 8-73. VALVE HARNESS
FIGURE 8-74. WHITE NOISE ALARM HARNESS
SECTION 9 - DECALSFIGURE 9-1. DECAL INSTALLATION - ANSI SPECS (800AJ)
FIGURE 9-2. DECAL INSTALLATION - AUSTRALIAN SPECS (800AJ)
FIGURE 9-3. DECAL INSTALLATION - BRAZILIAN SPECS (800AJ)
FIGURE 9-4. DECAL INSTALLATION - CE & UK CA SPECS (800AJ)
FIGURE 9-5. DECAL INSTALLATION - CHINESE SPECS (800AJ)
FIGURE 9-6. DECAL INSTALLATION - CSA SPECS (800AJ)
FIGURE 9-7. DECAL INSTALLATION - JAPANESE SPECS (800AJ)
FIGURE 9-8. DECAL INSTALLATION - KOREAN SPECS (800AJ)
FIGURE 9-9. DECAL INSTALLATION - LATIN AMERICAN SPECS (800AJ)
FIGURE 9-10. DECAL INSTALLATION - OPTIONS
FIGURE 9-11. SKYCUTTER DECAL INSTALLATION
FIGURE 9-12. SKYWELDER DECAL INSTALLATION - 50HZ
FIGURE 9-13. SKYWELDER DECAL INSTALLATION - 60HZ
SECTION 11 - SPECIAL OPTIONSFIGURE 11-1. SPECIAL OPTIONS/ACCESSORIES/KITS
PART NUMBER INDEX
- SuperPac Parts Manual
- StratoLift Parts Manual
