JLG Boom Lift 800AJ HC3 Service & Maintenance Manual 3122565200 2026
Brand: JLG
Type of Machine: Boom Lift
Model: JLG 800AJ HC3 Boom Lift
Part Number: 3122565200
Publication Date: 2026
Number of Pages: 952 Pages
Safety
Brand: JLG
Safety
General
1.1.1 Disclaimer
1.1.2 Operation & Safety Manual
Safety Information
1.2.1 Safety Alert System and Signal Words
Safety Hazards
1.3.1 Personal Hazards
1.3.2 Equipment Hazards
1.3.3 General Hazards
1.3.4 Operational Hazards
Safety Decals
Machine Verification
General Machine Information and SpecificationsSpecifications
2.1.1 Operating Specification
2.1.2 Engine Data
2.1.3 Tires
2.1.4 Critical Stability Weights
2.1.5 Torque Requirements
2.1.6 Component Data
2.1.7 Major Component Weights
Machine Temperature Chart
Serial Number Location
Fluids and Lubrication
2.4.1 General Information
2.4.2 Hydraulic Oil
2.4.3 Changing Hydraulic Oil
2.4.4 Lubrication Specifications
2.4.5 Fluids
2.4.6 Capacities
2.4.7 Lubrication Schedule
Machine Characteristics
2.5.1 Ground Control Keyswitch System
2.5.2 Platform Control Enable System
2.5.3 Cold Start System (Diesel)
2.5.4 Fuel level Cutout System
2.5.5 HRC Engine Emission Characteristics
2.5.6 Drive System
2.5.7 Drive Orientation System
2.5.8 Function Speed Control System
2.5.9 Oscillating Axle System
2.5.10 Main Lift End Stroke Dampening System
2.5.11 Chassis Tilt Indicator System
2.5.12 Platform Load Sensing System (LSS)
2.5.13 ClearSky™ System Ready
2.5.14 Tires and Counterweight
2.5.15 Platform
2.5.16 QuikStick Lift System
2.5.17 Auxiliary Power System
2.5.18 Transport Position Sensing System
2.5.19 Beyond Transport - Drive Speed Cutback System
2.5.20 Drive Steer Boom Function
2.5.21 Tower Boom Sequence Valve System
2.5.22 Ground Panel Display
2.5.23 Upright Level System
2.5.24 Dual Fuel System
2.5.25 Counterweight
2.5.26 TELESCOPE RETRACTED SENSOR
2.5.27 TRIPLE CAPACITY SYSTEM
2.5.28 Diesel Particulate Filter (If Equipped)
Clearsky Smart Fleet (If Equipped)
2.6.1 General
2.6.2 ClearSky Smart Fleet™ — Access Control
Maintenance and Inspection SchedulesMachine Preparation, Inspection, and Maintenance
3.1.1 General
3.1.2 Preparation, Inspection, and Maintenance
3.1.3 Pre-Start Inspection
3.1.4 Pre-Delivery Inspection and Frequent Inspection
3.1.5 Annual Machine Inspection
3.1.6 Preventive Maintenance
Service and Guidelines
3.2.1 General
3.2.2 Safety and Workmanship
3.2.3 Cleanliness
3.2.4 Components Removal and Installation
3.2.5 Component Disassembly and Reassembly
3.2.6 Pressure-Fit Parts
3.2.7 Bearings
3.2.8 Gaskets
3.2.9 Bolt Usage and Torque Application
3.2.10 Hydraulic Lines and Electrical Wiring
3.2.11 Hydraulic System
3.2.12 Lubrication
3.2.13 Battery
3.2.14 Welding on JLG Equipment
Preventive Maintenance and Inspection Schedule
3.3.1 Daily
3.3.2 First 50 Hours
3.3.3 Every 150 Hours or 3 Months
3.3.4 First 300 Hours or 6 Months
3.3.5 Every 600 Hours or 1 Year
3.3.6 Every 300 Hours or 1 Year
3.3.7 Every 1200 Hours or 1 Year
3.3.8 Every 1000 Hours or 2 Year
3.3.9 Every 1200 Hours or 2 Years
Pins and Composite Bearing Repair Guidelines
Tires and Wheels
3.5.1 Tire Inflation
3.5.2 Tire Damage
Fuel Tank Inspection
Boom Inspection and Maintenance
3.7.1 Boom Cleanliness Guidelines
3.7.2 Boom Wear Pad Inspection
Hydraulic Filter Replacement
3.8.1 Removal
3.8.2 Installation
Engine General Inspection
3.9.1 General Maintenance
3.9.2 Glow Plugs
3.9.3 Replacing Engine Oil
3.9.4 Replacing the Oil Filter
3.9.5 Replacing the Primary Fuel Filters
3.9.6 Replacing the Fuel Pre-Filter
3.9.7 Replacing the Auxiliary Fuel Filter For Deutz D2011LO40 (T4I) (Only)
3.9.8 Spark Arrester Cleaning Instructions For Deutz D2011LO40 (T4I) (Only)
3.9.9 Replacing the Fuel Strainer For Deutz D2011LO40 (T4I) (Only)
Bio Fuel In Deutz Engines
3.10.1 General
3.10.2 Bio Fuel
3.10.3 Biological Contamination In Fuels
Deutz EMR2
Deutz EMR4
Deutz EMR5
Generator Inspection
3.14.1 2500W Generator
3.14.2 4000W Generator
3.14.3 7500W Generator
Testing, Calibrations and Special ProceduresSpecial Tools
4.1.1 Multimeter Basics
4.1.2 Threadlocking Compound
4.1.3 Tools Catalog
Testing Procedures
4.2.1 Starter
4.2.2 SkyGuard
4.2.3 LSS Testing and Evaluation
4.2.4 Test from the Platform
4.2.5 Test from the Ground Station
Calibration Procedures
4.3.1 JLG Analyzer
4.3.2 Calibration Preparation
4.3.3 Load Sensing System Calibration
4.3.4 Tilt Sensor Calibration
4.3.5 Calibrating Boom Angle
4.3.6 Calibrating Level Up CRKPT
4.3.7 Calibrating Level Down Crackpoint
Special Procedures
4.4.1 Emergency Boom Lowering Procedure
4.4.2 Fuel Tank Cleaning and Drying
4.4.3 Cylinder Checking Procedure
4.4.4 Cylinder Drift
4.4.5 Cylinder Thermal Drift
4.4.6 Hydraulic Circuits
4.4.7 Hydraulic Pressure Settings and Adjustments
4.4.8 Hydraulic Pressures
4.4.9 Limit Switches Adjustment
4.4.10 Oscillating Axle Lockout Test
4.4.11 Auxiliary Power System
4.4.12 Foot Switch Adjustment
4.4.13 Lubricating O-Rings in the Hydraulic System
Swing Drive
System SoftwareLoad Sensing System (LSS)
5.1.1 Theory of Operation
5.1.2 Load Sensing Gauge Removal/ Installation
JLG Analyzer
5.2.1 Machine Data Access
5.2.2 Hand Held Analyzer
5.2.3 To Connect the JLG Control System Analyzer
5.2.4 Using the Analyzer
5.2.5 Changing the Access Level of the Hand Held Analyzer
5.2.6 Adjusting Parameters Using the Hand Held Analyzer
5.2.7 Machine Setup
5.2.8 Level Vehicle Description
5.2.9 Analyzer Flow Chart
Analyzer Software Accessibility
5.3.1 Access Level
5.3.2 Diagnostic
5.3.3 Machine Set-Up
5.3.4 Personalities
5.3.5 Operator Tools
5.3.6 Calibrations
Function Test
CANBUS Communications
Service Mode
5.6.1 Load Sensing System
Upright Monitoring System (UMS)
5.7.1 Re-Synchronizing Upright
5.7.2 Calibration
5.7.3 Calibration Faults
5.7.4 Function Check
5.7.5 Service Mode/Tower Boom Retrieval
ClearSky (CS550) Configuration and Troubleshooting
5.8.1 ClearSky Smart FleetTM CS550 Configuration
5.8.2 Troubleshooting
Fault CodesFault Codes Introduction
Engine Diagnostic
6.2.1 Deutz D2011LO40 Engine
6.2.2 Deutz TD2.9L4 (Stage V) Engine
6.2.3 Deutz TD2.9L4 (T4F)/TD2.9L4 China III Engine
6.2.4 Ford MSG425-DF Engine
Machine Fault Codes
6.3.1 General
6.3.2 LSS Troubleshooting
6.3.3 ClearSky Smart Fleet DTC Fault Codes
6.3.4 System Test Messages
ClearSky CS550 Troubleshooting Procedures
Machine Diagnostics Parameters
UMS Troubleshooting and Diagnostic Trouble Codes (DTC)
6.6.1 Backward Stability Concern DTC (2532)
6.6.2 Forward Stability Concern DTC (2530)
6.6.3 Out of Usable Range DTC (2531)
6.6.4 UMS Sensor Not Calibrated DTC (816)
6.6.5 UMS Sensor Faulted DTC (817)
6.6.6 Calibration Faults
HydraulicsGeneral Information and Safety
Theories of Operation
7.2.1 Cylinders
7.2.2 Valves
Hydraulic Components
7.3.1 Hydraulic Oil Tank
7.3.2 Hydraulic Component Start-Up Procedures And Recommendations
7.3.3 Hydraulic Pump Pre-Fill Procedures
7.3.4 Main Control Valve Pressure Setting Procedure
7.3.5 Platform Control Valve Pressure Setting Procedure
Torque Valve
7.4.1 Cylinder Torque Specifications
7.4.2 Valve Torque Specifications
Hydraulic Diagram - Chassis
7.5.1 4WD, 2WS (FOR FORD ENGINE)
7.5.2 4WD 2WS (TOW BAR) (FOR FORD ENGINE)
7.5.3 4WD 2WS (FOR DEUTZ T4i, T4F, CHINA III, STAGE V)
7.5.4 4WD 2WS (TOW BAR) (FOR DEUTZ T4i, T4F, CHINA III, STAGE V)
ElectricalsGeneral Information
8.1.1 Applying Silicone Dielectric Compound to Electrical Connections
8.1.2 Dielectric Grease Application
Electrical Connectors
8.2.1 Deutsch Connectors
Electrical Component Terminology
Harness Layouts
8.4.1 Electrical Turntable Harness
8.4.2 Electrical Turntable Component
8.4.3 Engine Deutz D2011
8.4.4 Engine Deutz 2.9L4
8.4.5 Engine Ford DF
8.4.6 Electrical Boom
8.4.7 Electrical Platform
8.4.8 Electrical Controls
Board Layouts
8.5.1 Platform Control Module Pin Connections
8.5.2 Analyzer Diagnostics Menu Structure
AMP Connector
8.6.1 Applying Silicone Dielectric Compound to AMP Connectors
8.6.2 Assembly
8.6.3 Disassembly
8.6.4 Wedge Lock
8.6.5 Service - Voltage Reading
Wiring Harness and Connector Label Diagrams
8.7.1 Connector Labels
8.7.2 Component Labels
Telematics Gateway
8.8.1 Telematics-Ready (TCU) Plug
Removal and InstallationWheel and Tire
Chassis/Frame Assembly
9.2.1 Axle and Drive Assemblies Troubleshooting
9.2.2 Front and Rear Axle Assembly
9.2.3 Drive Hub and Motor
9.2.4 Spindle Assembly
Boom
9.3.1 Boom Components Terminology
9.3.2 Troubleshooting
9.3.3 Main Boom Powertrack
9.3.4 Main Boom Assembly
9.3.5 Upright
9.3.6 Tower Boom Assembly
9.3.7 Jib Assembly
9.3.8 Dual Axis Sensor
Platform
9.4.1 Platform Control Valve
9.4.2 Platform (Rapid Replaceable Platform)
9.4.3 Platform Support (Traditional Design)
9.4.4 Platform Support (Rapid Replaceable Platform)
9.4.5 Bolt-On External Fall Arrest
9.5.1 Component Terminology
9.5.2 Engine Serial Number
9.5.3 Engine Replacement
9.5.4 Surge Tank (Deutz TD2.9L4 (T4F)/TD2.9L4 (Stage V)/TD2.9L4 (China III))
9.5.5 Pump Coupling Kit
9.5.6 Air Filter Assembly
9.5.7 Radiator Assembly
9.5.8 Thermostat
9.5.9 Coolant Temperature Sensor
9.5.10 Relay Assembly
9.5.11 Starter
9.5.12 Alternator
9.5.13 Fuel Tank
9.5.14 Pre-Fuel Filter and Fuel Pump
Hydraulic Cylinders
9.7.1 Main Boom Lift Cylinder
9.7.2 Main Boom Telescope Cylinder
9.7.3 Upright Level Cylinder
9.7.4 Tower Boom Lift Cylinder
9.7.5 Tower Telescope Cylinder
9.7.6 Master Cylinder
9.7.7 Rotator and Platform Level Cylinder
9.7.8 Steer Cylinder
9.7.9 Axle Lockout Cylinder
Hydraulic Valves
9.8.1 Platform Control Valve
9.8.2 Main Control Valve
9.8.3 Brake/2 Speed Valve
9.8.4 Loop Flushing Valve
9.8.5 Anti-Cavitation Valve
Hydraulic Pumps
9.9.1 Variable Pump Assembly
9.9.2 Hydrostatic Pump Assembly
Electrical Components
9.10.1 Battery
Turntable
9.11.1 Swing Drive
9.11.2 Swing Bearing
Generator and Pulley
9.12.1 For 7500W and 4000W Generator - Deutz TD2.9L4
9.12.2 For 2500W Generator - Ford MSG425-DF
9.12.3 For 2500W Generator - Deutz D20110L40
9.12.4 For 7500W Skypower Generator - Deutz D20110L40
9.12.5 For 7500W Skypower Generator - Ford MSG425-DF
9.12.6 For 4000W Generator - Deutz D20110L40
9.12.7 For 2500W Generator - Kubota WG2503 and Deutz T4F
ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)
9.13.1 ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)
Disassembly and AssemblyDrive Assembly
10.1.1 Drive Hub
10.1.2 Drive Brake
10.1.3 Drive Motor
Boom and Jib Assembly
10.2.1 Main Boom Assembly
10.2.2 Tower Boom Assembly
10.2.3 Rotator Assembly
Platform
Engine Components
10.4.1 Engine Disassembly, Inspection and Service
10.4.2 Fuel Tank
Pumps
10.5.1 Function Pump
10.5.2 Servo Controlled Piston Pump
10.5.3 Charge Pump Adapter Assembly
10.5.4 Manual Servo Control Basic Assembly
10.5.5 Manual Servo Control Assembly Options
10.5.6 Rotating Kit Assembly
10.5.7 Fault- logic Troubleshooting
10.5.8 Start-up Procedure
Hydraulic Cylinders
10.6.1 Axle Lockout Cylinder
10.6.2 Platform Level Cylinder
10.6.3 Jib Lift Cylinder
10.6.4 Master Cylinder
10.6.5 Steer Cylinder
10.6.6 Main Boom Telescope Cylinder
10.6.7 Tower Boom Telescope Cylinder
Hydraulic Valves
10.8.1 Hydraulic Oil Tank
Turntable
10.9.1 Swing Motor
10.9.2 Rotary Coupling Seal Kit
Generator Disassembly and Assembly
10.10.1 7500W Generator
10.10.2 4000W Generator
Torque/Connection InformationHydraulic Fittings
11.1.1 Tapered Thread Types
11.1.2 Straight Thread Types, Tube and Hose Connections
11.1.3 Straight Thread Types, Port Connections
11.1.4 Flange Connection Types
11.1.5 Tightening Methods
11.1.6 Assembly and Torque Specifications
11.1.7 General Tube Type Fitting Assembly Instructions
11.1.8 Assembly Instructions for American Standard Pipe Thread Tapered Connections.
11.1.9 Assembly Instructions for British Standard Pipe Thread Tapered Connections
11.1.10 Assembly Instructions for 37° (JIC) Flare Fittings
11.1.11 Assembly Instructions for 45° SAE Flare Fittings
11.1.12 Assembly Instructions for O-Ring Face Seal (ORFS) Fittings
11.1.13 Assembly Instructions for DIN 24° Flare Bite Type Fittings (MBTL and MBTS)
11.1.14 Assembly Instructions for Bulkhead (BH) Fittings
11.1.15 Assembly Instructions for O-Ring Boss (ORB) Fittings
11.1.16 Assembly Instructions for Adjustable Port End Metric Fittings
11.1.17 Assembly Instructions for Metric ISO 6149 (MPP) Port Assembly Stud Ends
11.1.18 Assembly instructions for Adjustable Port End (BSPP) Fittings
11.1.19 Assembly Instructions for Flange Connections: (FL61 and FL62)
11.1.20 Double Wrench Method
11.1.21 FFWR and TFFT Methods
11.1.22 Adjustable Stud End Assembly
11.1.23 O-ring Installation (Replacement)
Torque Charts
11.2.1 SAE Fastener Torque Chart
11.2.2 Metric Fastener Torque Chart
SchematicsHydraulic Schematics
Electrical Schematics
Deutz EMR2 Schematics
12.3.1 Vehicle Side Connection Diagram
12.3.2 Engine Side Connection Diagram - Sheet 1 of 2
12.3.3 Engine Side Connection Diagram - Sheet 2 of 2
12.3.4 Engine Plug Pin
12.3.5 Vehicle Plug Pin Identification
Deutz EMR4 Schematics
12.4.1 Power Harness
12.4.2 Equipment Harness
12.4.3 D2.1 Engine Plug Pin Assignment
12.4.4 D2.2 Unit Plug Pin Assignment
Deutz EMR5 Schematics
12.5.1 Power Harness
12.5.2 Exhaust After Treatment Harness
12.5.3 Equipment Harness - Sheet 1 of 5
12.5.4 Equipment Harness - Sheet 2 of 5
12.5.5 Equipment Harness - Sheet 3 of 5
12.5.6 Equipment Harness - Sheet 4 of 5
12.5.7 Equipment Harness - Sheet 5 of 5
12.5.8 Engine Plug Pin Identification
12.5.9 Vehicle Plug Pin Identification
7500W Generator Schematic
12.6.1 Troubleshooting Circuit Diagram
12.6.2 Generator and Controller Circuit Diagram
12.6.3 Power Board PC1 Circuit Diagram
12.6.4 Power Board PC2 Electrical Circuit Diagram
12.6.5 Lead Connection List
4000W Generator Schematic
12.7.1 Generator and Controller Circuit Diagram
12.7.2 Lead Connection List
- SuperPac Parts Manual
- StratoLift Parts Manual
