Hyundai
86
176,834
JLG Boom Lift 800AJ HC3 Parts Catalog 3122324000
Brand: JLG
Type of Machine: Boom Lift
Model: JLG 800AJ HC3 Boom Lift
Part Number: 3122324000
Publication Date: 2025
Number of Pages: 940 Pages
SECTION 1 - FRAME
FIGURE 1-1. AXLE INSTALLATION - OSCILLATING​
FIGURE 1-2. AXLE INSTALLATION - OSCILLATING WITH TOW PACKAGE​
FIGURE 1-3. STEER INSTALLATION - 2WS​
FIGURE 1-4. STEER INSTALLATION - 2WS WITH TOW PACKAGE​
FIGURE 1-5. WHEEL DRIVE AND FRAME VALVES INSTALLATION - 4WD/2WS​
FIGURE 1-6. DRIVE HUB/BRAKE ASSEMBLY​
FIGURE 1-7. DRIVE MOTOR ASSEMBLY - 4WD​
FIGURE 1-8. TIRE AND WHEEL INSTALLATION 18-625 NHS FOAM-FILLED TIRE​
FIGURE 1-9. TIRE AND WHEEL INSTALLATION 18-625 NHS FOAM-FILLED NON-MARKING TIRE​
FIGURE 1-10. TIRE AND WHEEL INSTALLATION 18-625 NHS FOAM-FILLED SAND TIRE​
FIGURE 1-11. LP TANK BRACKETS INSTALLATIONS​
FIGURE 1-12. FRAME SHIELDS INSTALLATION - 2WS​
FIGURE 1-13. TOW PACKAGE INSTALLATION - 2WS (ENGLISH LANGUAGE DECALS)​
FIGURE 1-14. TOW PACKAGE INSTALLATION - 2WS (CE & UK CA SPECS)​
FIGURE 1-15. TOW BAR ASSEMBLY​
SECTION 2 - TURNTABLE
FIGURE 2-1. CONTROL VALVES INSTALLATION - WITH 2WS​
FIGURE 2-2. CONTROL VALVE ASSEMBLY - 2WS MACHINES​
FIGURE 2-3. SWING DRIVE INSTALLATION (Prior to SN 0300321160)​
FIGURE 2-4. SWING DRIVE INSTALLATION (SN 0300321161 to Present)​
FIGURE 2-5. SWING MOTOR/HUB ASSEMBLY (Prior to SN 0300321160)​
FIGURE 2-6. SWING MOTOR/HUB ASSEMBLY (SN 0300321161 to Present)​
FIGURE 2-7. TURNTABLE BEARING INSTALLATION​
FIGURE 2-8. TURNTABLE LOCK INSTALLATION​
FIGURE 2-9. ROTARY COUPLING INSTALLATION - 2WS MACHINES​
FIGURE 2-10. TANK INSTALLATION - DIESEL MACHINE (FUEL TANK WITHOUT SIGHT GLASS) (HELGESEN 6IN DIA BREATHER HYDRAULIC TANK - 25 GAL CAPACITY)​
FIGURE 2-11. TANK INSTALLATION - DIESEL MACHINE (FUEL TANK WITHOUT SIGHT GLASS) (JIANGYING 4IIN DIA BREATHER HYDRAULIC TANK - 25 GAL CAPACITY)​
FIGURE 2-12. TANK INSTALLATION - DIESEL MACHINE (FUEL TANK WITH SIGHT GLASS) (HELGESEN 6IIN DIA BREATHER HYDRAULIC TANK - 25 GAL CAPACITY)​
FIGURE 2-13. TANK INSTALLATION - DIESEL MACHINE (FUEL TANK WITH SIGHT GLASS) (JIANGYING 4IN DIA BREATHER HYDRAULIC TANK - 25 GAL CAPACITY)​
FIGURE 2-14. TANK INSTALLATION - GAS ENGINES (HELGESEN 6IN DIA BREATHER HYDRAULIC TANK - 25 GAL CAPACITY)​
FIGURE 2-15. TANK INSTALLATION - GAS ENGINES (JIANGYING 4IN DIA BREATHER HYDRAULIC TANK - 25 GAL CAPACITY)​
FIGURE 2-16. HYDRAULIC TANK ASSEMBLY (HELGESEN 6IN DIA BREATHER HYDRAULIC TANK - 25 GAL CAPACITY)​
FIGURE 2-17. HYDRAULIC TANK ASSEMBLY (JIANGYING 4IN DIA BREATHER HYDRAULIC TANK - 25 GAL CAPACITY)​
FIGURE 2-18. AUXILIARY POWER INSTALLATION - WITHOUT BATTERY DISCONNECT​
FIGURE 2-19. AUXILIARY POWER INSTALLATION - WITH BATTERY DISCONNECT​
FIGURE 2-20. AUXILIARY POWER PUMP/MOTOR ASSEMBLY​
FIGURE 2-21. GROUND CONTROL BOX ASSEMBLY - WITH DEUTZ D2011 ENGINES - WITH MECHANICAL HOUR METER (ANSI EXPORT LRC AND AUSTRALIAN SPECS)​
FIGURE 2-22. GROUND CONTROL BOX ASSEMBLY - WITH DEUTZ D2011 AND TOWER STOW - WITH MECHANICAL HOUR METER (ANSI EXPORT LRC AND AUSTRALIAN SPECS)​
FIGURE 2-23. GROUND CONTROL BOX ASSEMBLY - WITH DEUTZ D2011 ENGINES (CE & UK CA SPECS)​
FIGURE 2-24. GROUND CONTROL BOX ASSEMBLY - WITH DEUTZ D2011 ENGINES - WITH FORD ENGINES - WITH MECHANICAL HOUR METER​
FIGURE 2-25. GROUND CONTROL BOX ASSEMBLY - WITH DEUTZ D2011 ENGINES AND WITH TOWER STOW (CE & UK CA LRC SPECS)​
FIGURE 2-26. GROUND CONTROL BOX ASSEMBLY - WITH DEUTZ TD2.9L4 ENGINES - WITH MECHANICAL HOUR METER (ANSI, ANSI EXPORT, CSA, CHINA & JAPANESE SPECS)​
FIGURE 2-27. GROUND CONTROL BOX ASSEMBLY - WITH DEUTZ TD2.9L4 AND TOWER STOW - WITH MECHANICAL HOUR METER (ANSI, ANSI EXPORT, CSA, CHINA & JAPANESE SPECS)​
FIGURE 2-28. GROUND CONTROL BOX ASSEMBLY - WITH DEUTZ TD2.9L4 (STAGE V) ENGINES (CE & UK CA SPECS)​
FIGURE 2-29. GROUND CONTROL BOX ASSEMBLY - WITH DEUTZ TD2.9L4 (STAGE V) ENGINES AND WITH TOWER STOW (CE & UK CA SPECS)​
FIGURE 2-30. GROUND CONTROL BOX ASSEMBLY - WITH FORD ENGINES AND TOWER STOW - WITH MECHANICAL HOUR METER​
FIGURE 2-31. LIGHT PANEL INSTALLATION​
FIGURE 2-32. ALARM INSTALLATION​
FIGURE 2-33. HOODS INSTALLATION - ABS (DEUTZ D2011 ENGINES)​
FIGURE 2-34. HOODS INSTALLATION - ABS (DEUTZ TD2.9L4 ENGINES)​
FIGURE 2-35. HOODS INSTALLATION - ABS (DEUTZ TD2.9L4 (STAGE V) ENGINES)​
FIGURE 2-36. HOODS INSTALLATION - STEEL (DEUTZ D2011 ENGINES)​
FIGURE 2-37. HOODS INSTALLATION - STEEL (DEUTZ TD2.9L4 ENGINES)​
FIGURE 2-38. HOODS INSTALLATION - STEEL (FORD ENGINES)​
FIGURE 2-39. EXHAUST COVER AND HEAT SHIELDS INSTALLATION - STEEL HOODS (DEUTZ D2011 ENGINES)​
FIGURE 2-40. EXHAUST COVER AND HEAT SHIELDS INSTALLATION - STEEL HOODS (DEUTZ TD2.9L4 ENGINES)​
FIGURE 2-41. EXHAUST COVER INSTALLATION - STEEL HOODS (FORD ENGINES)​
FIGURE 2-42. SKYAIR AIR COMPRESSOR INSTALLATION​
FIGURE 2-43. SKYAIR AIR COMPRESSOR INSTALLATION​
FIGURE 2-44. AIR COMPRESSOR ASSEMBLY​
FIGURE 2-45. WHITE NOISE ALARM INSTALLATION - ADJUSTABLE AMBIENT​
FIGURE 2-46. WHITE NOISE MOTION ALARM INSTALLATION - AMBIENT​
SECTION 3 - ENGINE
FIGURE 3-1. DEUTZ D2011 ENGINE INSTALLATION (WITHOUT ARCTIC PACKAGE)​
FIGURE 3-2. DEUTZ D2011 ENGINE INSTALLATION (WITH ARCTIC PACKAGE)​
FIGURE 3-3. DEUTZ D2011 ENGINE/PUMP SUB ASSEMBLY (WITHOUT ARCTIC PACKAGE)​
FIGURE 3-4. DEUTZ TD2.9L4 ENGINE/PUMP SUB ASSEMBLY (WITH ARCTIC PACKAGE)​
FIGURE 3-5. DEUTZ D2011 ENGINE ASSEMBLY (WITHOUT ARCTIC PACKAGE)​
FIGURE 3-6. DEUTZ D2011 ENGINE ASSEMBLY (WITH ARCTIC PACKAGE)​
FIGURE 3-7. DEUTZ D2011 ENGINE COMPONENTS​
FIGURE 3-8. DEUTZ TD2.9L4 ENGINE INSTALLATION (STAGE V)​
FIGURE 3-9. DEUTZ TD2.9L4 ENGINE INSTALLATION (CHINA III)​
FIGURE 3-10. DEUTZ TD2.9L4 ENGINE INSTALLATION (CHINA IV)​
FIGURE 3-11. DEUTZ ENGINE COMPONENTS - CHINA IV​
FIGURE 3-12. DEUTZ TD2.9L4 ENGINE/PUMP SUB ASSEMBLY (CHINA III)​
FIGURE 3-13. DEUTZ TD2.9L4 ENGINE/PUMP SUB ASSEMBLY (CHINA IV)​
FIGURE 3-14. DEUTZ TD2.9L4 ENGINE ASSEMBLY (CHINA IV)​
FIGURE 3-15. DEUTZ TD2.9L4 ENGINE ASSEMBLY (CHINA IV)​
FIGURE 3-16. DEUTZ TD2.9L4 ENGINE ASSEMBLY (STAGE V) (Prior to SN 0300321374)​
FIGURE 3-17. DEUTZ TD2.9L4 ENGINE ASSEMBLY (STAGE V) (SN 0300321375 to Present)​
FIGURE 3-18. DEUTZ TD2.9L4 ENGINE ASSEMBLY (CHINA III SPECS)​
FIGURE 3-19. DEUTZ TD2.9L4 ENGINE/PUMP SUB ASSEMBLY (STAGE V)​
FIGURE 3-20. DEUTZ TD2.9L4 ENGINE COMPONENTS (STAGE V)​
FIGURE 3-21. DEUTZ TD2.9L4 ENGINE COMPONENTS (CHINA III SPECS)​
FIGURE 3-22. DEUTZ D2.9L4 - EMR5 ENGINE INSTALLATION WITH ARCTIC PACKAGE​
FIGURE 3-23. DEUTZ D2.9L4 - EMR5 ENGINE AND PUMP SUB-ASSEMBLY WITH ARCTIC PACKAGE​
FIGURE 3-24. ENGINE ASSEMBLY - DEUTZ D2.9L4 EMR5 ENGINE (WITH ARCTIC PACKAGE) (Prior to SN 0300321374)​
FIGURE 3-25. ENGINE ASSEMBLY - DEUTZ D2.9L4 EMR5 ENGINE (WITH ARCTIC PACKAGE) (SN 0300321375 to Present)​
FIGURE 3-26. DEUTZ D2.9L4 - EMR5 ENGINE INSTALLATION WITHOUT ARCTIC PACKAGE​
FIGURE 3-27. DEUTZ D2.9L4 - EMR5 ENGINE AND PUMP SUB-ASSEMBLY WITHOUT ARCTIC PACKAGE​
FIGURE 3-28. ENGINE ASSEMBLY - DEUTZ D2.9L4 EMR5 ENGINE (WITHOUT ARCTIC PACKAGE) (Prior to SN 0300321374)​
FIGURE 3-29. ENGINE ASSEMBLY - DEUTZ D2.9L4 EMR5 ENGINE (WITHOUT ARCTIC PACKAGE) (SN 0300321375 to Present)​
FIGURE 3-30. ENGINE COMPONENTS - DEUTZ D2.9L4 EMR5 ENGINE​
FIGURE 3-31. DEUTZ TD 2.9L4 (UN R96) ENGINE INSTALLATION - WITHOUT ARCTIC PACKAGE (WITH STEEL HOODS)​
FIGURE 3-32. DEUTZ TD 2.9L4 (UN R96) ENGINE INSTALLATION - WITHOUT ARCTIC PACKAGE (WITH PLASTIC HOODS)​
FIGURE 3-33. DEUTZ TD 2.9L4 (UN R96) ENGINE AND PUMP SUB-ASSEMBLY - WITHOUT ARCTIC PACKAGE​
FIGURE 3-34. DEUTZ TD 2.9L4 (UN R96) ENGINE ASSEMBLY - WITHOUT ARCTIC PACKAGE​
FIGURE 3-35. DEUTZ TD 2.9L4 (UN R96) ENGINE INSTALLATION - WITH ARCTIC PACKAGE (WITH COLD WEATHER PACKAGE AND STEEL HOODS)​
FIGURE 3-36. DEUTZ TD 2.9L4 (UN R96) ENGINE INSTALLATION - WITH ARCTIC PACKAGE (WITH COLD WEATHER PACKAGE AND PLASTIC HOODS)​
FIGURE 3-37. DEUTZ TD 2.9L4 (UN R96) ENGINE AND PUMP SUB-ASSEMBLY - WITH ARCTIC PACKAGE​
FIGURE 3-38. DEUTZ TD 2.9L4 (UN R96) ENGINE ASSEMBLY - WITH ARCTIC PACKAGE​
FIGURE 3-39. DEUTZ TD2.9L4 (UN R96) ENGINE COMPONENTS​
FIGURE 3-40. FUEL PUMP/FILTER BRACKET ASSEMBLY (DEUTZ TD2.9L4 ENGINES)​
FIGURE 3-41. FUEL PUMP/FILTER BRACKET ASSEMBLY (DEUTZ TD2.9L4 (STAGE V) ENGINES)​
FIGURE 3-42. FUEL PUMP/FILTER BRACKET ASSEMBLY (DEUTZ TD2.9L4 ENGINES) (CHINA III ENGINES)​
FIGURE 3-43. BREATHER HEATER INST (DEUTZ TD2.9L4 ENGINES)​
FIGURE 3-44. FORD ENGINE INSTALLATION (WITHOUT ARCTIC PACKAGE)​
FIGURE 3-45. FORD ENGINE INSTALLATION (WITH ARCTIC PACKAGE)​
FIGURE 3-46. FORD ENGINE AND PUMP SUB-ASSEMBLY (WITHOUT ARCTIC PACKAGE)​
FIGURE 3-47. FORD ENGINE AND PUMP SUB-ASSEMBLY (WITH ARCTIC PACKAGE)​
FIGURE 3-48. FORD ENGINE ASSEMBLY (WITHOUT ARCTIC PACKAGE)​
FIGURE 3-49. FORD ENGINE ASSEMBLY (WITH ARCTIC PACKAGE)​
FIGURE 3-50. FORD ENGINE PREP ASSEMBLY​
FIGURE 3-51. FORD ENGINE BRACKETS AND EXHAUST MANIFOLD INSTALLATION​
FIGURE 3-52. FORD ENGINE DRIVE BELT INSTALLATION (MACHINES WITHOUT GENERATOR)​
FIGURE 3-53. FORD ENGINE COMPONENTS​
FIGURE 3-54. PUMP COUPING KIT (DEUTZ ENGINES)​
FIGURE 3-55. HYDROSTATIC PUMP ASSEMBLY​
FIGURE 3-56. VARIABLE PUMP ASSEMBLY​
FIGURE 3-57. VARIABLE PUMP ASSEMBLY - HENGLI​
FIGURE 3-58. HYDROSTATIC PUMP ASSEMBLY​
FIGURE 3-59. EXHAUST PIPE INSTALLATION - DEUTZ TD2.9L4 ENGINES​
FIGURE 3-60. EXHAUST PIPE INSTALLATION - DEUTZ TD2.9L4 (STAGE V) ENGINES​
FIGURE 3-61. EXHAUST PIPE INSTALLATION - FORD ENGINES​
FIGURE 3-62. SPARK ARRESTOR MUFFLER INSTALLATION - DEUTZ D2011 ENGINES​
FIGURE 3-63. SPARK ARRESTOR INSTALLATION (WITH STEEL HOODS)​
FIGURE 3-64. SPARK ARRESTOR INSTALLATION (WITH PLASTIC HOODS)​
FIGURE 3-65. FUEL-WATER SEPARATOR INSTALLATION - DEUTZ D2011 ENGINES​
FIGURE 3-66. FUEL-WATER SEPARATOR INSTALLATION - DEUTZ TD2.9L4 ENGINES​
FIGURE 3-67. RIGHT ENGINE SUPPORT INSTALLATION (DEUTZ D2011 ENGINES MACHINES WITHOUT GENERATORS)​
FIGURE 3-68. RIGHT ENGINE SUPPORT INSTALLATION (DEUTZ D2011 ENGINES MACHINES WITH GENERATORS)​
FIGURE 3-69. ENGINE HOOD BAFFLE INSTALLATION - DEUTZ TD2.9L4 ENGINES AND DEUTZ TD2.9L4 (STAGE V) ENGINES WITH ABS HOODS​
FIGURE 3-70. ENGINE HOOD BAFFLE INSTALLATION - DEUTZ TD2.9L4 ENGINES WITH STEEL HOODS​
FIGURE 3-71. ENGINE TRAY JACK INSTALLATION - DEUTZ ENGINES​
FIGURE 3-72. ENGINE TRAY JACK INSTALLATION - FORD ENGINES​
FIGURE 3-73. 2500W/110V/60HZ GENERATOR INSTALLATION - DEUTZ D2011 ENGINES​
FIGURE 3-74. 2500W/110V/60HZ GENERATOR INSTALLATION - DEUTZ TD2.9L4 ENGINES​
FIGURE 3-75. 2500W/110V/60HZ GENERATOR INSTALLATION - FORD ENGINES​
FIGURE 3-76. 2500W/220V/50HZ GENERATOR INSTALLATION - DEUTZ D2011 ENGINES​
FIGURE 3-77. 4000W/50HZ GENERATOR INSTALLATION - DEUTZ D2011 ENGINES​
FIGURE 3-78. 4000W/50HZ GENERATOR INSTALLATION - DEUTZ TD2.9L4 ENGINES AND DEUTZ TD2.9L4 (STAGE V) ENGINES​
FIGURE 3-79. 4000W/60HZ GENERATOR INSTALLATION - DEUTZ D2011 ENGINES​
FIGURE 3-80. 4000W/60HZ GENERATOR INSTALLATION - DEUTZ TD2.9L4 ENGINES​
FIGURE 3-81. 7500W/50HZ SKYPOWER GENERATOR INSTALLATION - DEUTZ D2011 ENGINES​
FIGURE 3-82. 7500W/50HZ SKYPOWER GENERATOR INSTALLATION - DEUTZ TD2.9L4 ENGINES AND DEUTZ TD2.9L4 (STAGE V) ENGINES​
FIGURE 3-83. 7500W/60HZ SKYPOWER GENERATOR INSTALLATION - DEUTZ D2011 ENGINES​
FIGURE 3-84. 7500W/60HZ SKYPOWER GENERATOR INSTALLATION - DEUTZ TD2.9L4 ENGINES​
FIGURE 3-85. 7500W/60HZ SKYPOWER GENERATOR INSTALLATION - FORD ENGINES​
FIGURE 3-86. QUICKFIT OIL VALVE (DEUTZ ENGINES)​
SECTION 4 - BOOM
FIGURE 4-1. BOOM AND CYLINDER INSTALLATION​
FIGURE 4-2. MAIN BOOM ASSEMBLY​
FIGURE 4-3. TOWER BOOM ASSEMBLY​
FIGURE 4-4. JIB ASSEMBLY​
FIGURE 4-5. PLATFORM ROTATOR ASSEMBLY​
FIGURE 4-6. SUPPORT, PLATFORM INSTALLATION​
FIGURE 4-7. POWER TRACK INSTALLATION - MAIN BOOM​
FIGURE 4-8. POWER TRACK INSTALLATION - TOWER BOOM​
FIGURE 4-9. CONTROL VALVES INSTALLATION - WITH 2WS​
FIGURE 4-10. CONTROL VALVE ASSEMBLY​
FIGURE 4-11. BOOM VALVES AND PROXIMITY SWITCHES INSTALLATION​
FIGURE 4-12. BOOM VALVES AND PROXIMITY SWITCHES INSTALLATION WITH TOWER STOW​
FIGURE 4-13. TRANSPORT POSITION SWITCH INSTALLATION​
SECTION 5 - PLATFORM
FIGURE 5-1. PLATFORM ASSEMBLY WITH DROP-BAR - 30IN X 3FT (76CM X 1M)​
FIGURE 5-2. PLATFORM ASSEMBLY WITH GATE - 30IN X 4FT (76CM X 1.22M)​
FIGURE 5-3. PLATFORM ASSEMBLY WITH DROP-BAR - 30IN X 4FT (76CM X 1.22M)​
FIGURE 5-4. PLATFORM ASSEMBLY WITH GATE - 30IN X 6FT (76CM X 1.83M)​
FIGURE 5-5. PLATFORM ASSEMBLY WITH GATE- 36IN X 6FT (91.5CM X 1.83M)​
FIGURE 5-6. PLATFORM ASSEMBLY WITH DROP-BAR - 30IN X 6FT (76CM X 1.83M)​
FIGURE 5-7. PLATFORM ASSEMBLY WITH DROP-BAR - 36IN X 6FT (91.5CM X 1.83M)​
FIGURE 5-8. PLATFORM ASSEMBLY WITH 1 GATE / 2 DROP BARS (TRI-ENTRY) - 36IN X 6FT (91.5CM X 1.83M)​
FIGURE 5-9. PLATFORM ASSEMBLY WITH 3 DROP BARS (TRI-ENTRY) - 36IN X 6FT (91.5CM X 1.83M)​
FIGURE 5-10. PLATFORM ASSEMBLY WITH FALL ARREST (6FT)​
FIGURE 5-11. PLATFORM ASSEMBLY WITH GATE - 36IN X 8FT (91.5CM X 2.44M)​
FIGURE 5-12. PLATFORM ASSEMBLY WITH DROP-BAR - 36IN X 8FT (91.5CM X 2.44M)​
FIGURE 5-13. PLATFORM ASSEMBLY WITH 1 GATE / 2 DROP BARS (TRI-ENTRY) - 36IN X 8FT (91.5CM X 2.44M)​
FIGURE 5-14. PLATFORM ASSEMBLY WITH 3 DROP BARS (TRI-ENTRY) - 36IN X 8FT (91.5CM X 2.44M)​
FIGURE 5-15. PLATFORM ASSEMBLY WITH FALL ARREST (8FT)​
FIGURE 5-16. CONSOLE AND FOOT SWITCH INSTALLATION​
FIGURE 5-17. CONSOLE AND FOOT SWITCH INSTALLATION WITH TOWER STOW​
FIGURE 5-18. CONSOLE BOX ASSEMBLY WITH FOOTSWITCH (WITHOUT TOWER STOW)​
FIGURE 5-19. CONSOLE BOX ASSEMBLY WITH FOOTSWITCH (WITH TOWER STOW)​
FIGURE 5-20. LIGHT PANEL INSTALLATION​
FIGURE 5-21. FOOTSWITCH ASSEMBLY​
FIGURE 5-22. JIB SWITCH INSTALLATION​
FIGURE 5-23. SKYEYE INSTALLATION​
FIGURE 5-24. SKYGUARD BAR INSTALLATION​
FIGURE 5-25. SKYLINE INSTALLATION​
FIGURE 5-26. STORAGE TRAY INSTALLATION - CENTER​
FIGURE 5-27. MANUAL STORAGE BOX INSTALLATION​
FIGURE 5-28. SKYCUTTER INSTALLATION​
FIGURE 5-29. SKYWELDER/SKYCUTTER COMBO INSTALLATION (60HZ)​
FIGURE 5-30. PLASMA CUTTER ASSEMBLY​
FIGURE 5-31. SKYWELDER INSTALLATION (50HZ)​
FIGURE 5-32. SKYWELDER INSTALLATION (60HZ)​
FIGURE 5-33. WELDER ASSEMBLY​
FIGURE 5-34. SKYWELDER PREP PACKAGE (60HZ)​
FIGURE 5-35. SKYGLAZIER INSTALLATION (ALL SPECS EXCEPT CHINA AND JAPANESES SPECS)​
FIGURE 5-36. SKYGLAZIER INSTALLATION (ENGLISH LANGUAGE DECALS)​
FIGURE 5-37. SOFT TOUCH SYSTEM INSTALLATION - 6FT/1.83M PLATFORM​
FIGURE 5-38. SOFT TOUCH SYSTEM INSTALLATION - 6FT/1.83M FALL ARREST PLATFORM​
FIGURE 5-39. SOFT TOUCH SYSTEM INSTALLATION - 8FT/2.44M PLATFORM​
FIGURE 5-40. SOFT TOUCH SYSTEM INSTALLATION - 8FT/2.44M FALL ARREST PLATFORM​
FIGURE 5-41. FALL ARREST INSTALLATION (BOLT-ON) 30IN X 4FT (76CM X 1.22M) PLATFORM​
FIGURE 5-42. FALL ARREST INSTALLATION (BOLT-ON) 36IN X 6FT (91.2CM X 1.82M) PLATFORM​
FIGURE 5-43. FALL ARREST INSTALLATION (BOLT-ON) 30IN X 6FT (76CM X 1.83M) PLATFORM​
FIGURE 5-44. FALL ARREST INSTALLATION (BOLT-ON) 36IN X 8FT (91.5CM X 2.4M) PLATFORM​
FIGURE 5-45. FALL ARREST INSTALLATION (BOLT-ON) 36IN X 6FT (91.5CM X 1.82M) TRI-ENTRY PLATFORM)​
FIGURE 5-46. USB CHARGER INSTALLATION​
SECTION 6 - CYLINDER
FIGURE 6-1. AXLE LOCKOUT CYLINDER ASSEMBLY​
FIGURE 6-2. LEVEL CYLINDER ASSEMBLY - PLATFORM SLAVE​
FIGURE 6-3. LEVEL CYLINDER ASSEMBLY - UPRIGHT​
FIGURE 6-4. LIFT CYLINDER ASSEMBLY - JIB​
FIGURE 6-5. LIFT CYLINDER ASSEMBLY - MAIN BOOM​
FIGURE 6-6. LIFT CYLINDER ASSEMBLY - TOWER BOOM​
FIGURE 6-7. MASTER CYLINDER ASSEMBLY​
FIGURE 6-8. STEER CYLINDER ASSEMBLY​
FIGURE 6-9. TELESCOPE CYLINDER ASSEMBLY - MAIN BOOM​
FIGURE 6-10. TELESCOPE CYLINDER ASSEMBLY - TOWER BOOM​
SECTION 7 - HYDRAULIC
FIGURE 7-1. HYDRAULIC DIAGRAM - AXLE (OSCILLATING)​
FIGURE 7-2. HYDRAULIC DIAGRAM - DRIVE (4WD/2WS WITHOUT TOW PACKAGE/WITHOUT ARCTIC PACKAGE) (Prior to SN 0300322909)​
FIGURE 7-3. HYDRAULIC DIAGRAM - DRIVE (4WD/2WS WITHOUT TOW PACKAGE/WITHOUT ARCTIC PACKAGE) (SN 0300322910 to Present, Including 0300322368)​
FIGURE 7-4. HYDRAULIC DIAGRAM - DRIVE (4WD/2WS WITHOUT TOW PACKAGE/WITH ARCTIC PACKAGE)​
FIGURE 7-5. HYDRAULIC DIAGRAM - DRIVE (4WD/2WS WITH TOW PACKAGE/WITHOUT ARCTIC PACKAGE) (Prior to SN 0300321985)​
FIGURE 7-6. HYDRAULIC DIAGRAM - DRIVE (4WD/2WS WITH TOW PACKAGE/WITHOUT ARCTIC PACKAGE) (SN 0300321986 to Present)​
FIGURE 7-7. HYDRAULIC DIAGRAM - DRIVE (4WD/2WS WITH TOW PACKAGE/WITH ARCTIC PACKAGE) (Prior to SN 0300322909)​
FIGURE 7-8. HYDRAULIC DIAGRAM - DRIVE (4WD/2WS WITH TOW PACKAGE/WITH ARCTIC PACKAGE) (SN 0300322910 to Present, Including 0300322368)​
FIGURE 7-9. HYDRAULIC DIAGRAM - DRIVE (4WD/2WS WITH TOW PACKAGE)(CE & UK CA SPECS ONLY) (Prior to SN 0300322909)​
FIGURE 7-10. HYDRAULIC DIAGRAM - DRIVE (4WD/2WS WITH TOW PACKAGE)(CE & UK CA SPECS ONLY) (SN 0300322910 to Present, Including 0300322368)​
FIGURE 7-11. HYDRAULIC DIAGRAM - DRIVE (4WD/2WS WITH TOW PACKAGE AND ARCTIC PACKAGE)(ANSI SPEC ONLY)​
FIGURE 7-12. HYDRAULIC DIAGRAM - DRIVE (4WD/2WS WITHOUT TOW PACKAGE AND WITHOUT ARCTIC PACKAGE)(ALL SPECS) (Prior to SN 0300322909)​
FIGURE 7-13. HYDRAULIC DIAGRAM - DRIVE (4WD/2WS WITHOUT TOW PACKAGE AND WITHOUT ARCTIC PACKAGE)(ALL SPECS) (SN 0300322910 to Present, Including 0300322368)​
FIGURE 7-14. HYDRAULIC DIAGRAM - DRIVE (4WD/2WS WITHOUT TOW PACKAGE AND WITH ARCTIC PACKAGE)(CSA AND ANSI SPECS)​
FIGURE 7-15. HYDRAULIC DIAGRAM - STANDARD​
SECTION 8 - ELECTRICAL
FIGURE 8-1. ELECTRICAL LAYOUT​
FIGURE 8-2. AC BOX AT PLATFORM INSTALLATION - 110V GFI RECEPTACLE (ALL SPECS EXCEPT AUSTRALIAN, CE & UK CA SPECS)​
FIGURE 8-3. AC BOX AT PLATFORM INSTALLATION - 220V (ANSI, CSA & JAPANESE SPECS)​
FIGURE 8-4. AC BOX AT PLATFORM MID-BOOM PLUG INSTALLATION (WITH 4000W/60HZ GENERATOR) (ANSI, ANSI EXPORT, CSA & JAPANESE SPECS)​
FIGURE 8-5. AC BOX AT PLATFORM MID-BOOM PLUG INSTALLATION (WITHOUT 7500W SKYPOWER GENERATOR) (ALL SPECS EXCEPT ANSI, JAPANESE & CSA SPECS)​
FIGURE 8-6. AC BOX AT PLATFORM MID-BOOM PLUG INSTALLATION (WITH 7500W SKYPOWER GENERATOR)​
FIGURE 8-7. AC BOX AT PLATFORM INSTALLATION - 110V IEC YELLOW (CE & UK CA SPECS) (MACHINES WITH 2500W GENERATOR OR NO GENERATOR OPTION)​
FIGURE 8-8. AC BOX AT PLATFORM INSTALLATION - 110V IEC YELLOW (CE & UK CA SPECS) (MACHINES WITH 4000W GENERATOR)​
FIGURE 8-9. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE (CE & UK CA SPECS) (MACHINES WITH 2500W GENERATOR OR NO GENERATOR OPTION)​
FIGURE 8-10. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE (CE & UK CA SPECS) (MACHINES WITH 4000W GENERATOR)​
FIGURE 8-11. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 POST GROUND (CE & UK CA SPECS) (MACHINES WITH 2500W GENERATOR OR NO GENERATOR OPTION)​
FIGURE 8-12. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 POST GROUND (CE & UK CA SPECS) (MACHINES WITH 4000W GENERATOR)​
FIGURE 8-13. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 SIDE GROUND (CE & UK CA SPECS) (MACHINES WITH 2500W GENERATOR OR NO GENERATOR OPTION)​
FIGURE 8-14. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 SIDE GROUND (CE & UK CA SPECS) (MACHINES WITH 4000W GENERATOR)​
FIGURE 8-15. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT 107 KEYED GROUND (CE & UK CA SPECS) (MACHINES WITH 2500W GENERATOR OR NO GENERATOR OPTION)​
FIGURE 8-16. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT 107 KEYED GROUND (CE & UK CA SPECS) (MACHINES WITH 4000W GENERATOR)​
FIGURE 8-17. AC BOX AT PLATFORM INSTALLATION - 220V (2X4 BOX & COVER ONLY - LOCALLY SUPPLIED RECEPTACLE) (4000W GENERATOR)​
FIGURE 8-18. AC BOX AT PLATFORM INSTALLATION - 240V GFCI RECEPTACLE (ALL SPECS EXCEPT CE, UK CA, AUSTRALIAN & CHINESE SPECS WITH 4000W SKYPOWER GENERATOR)​
FIGURE 8-19. AC BOX AT PLATFORM INSTALLATION - 240V GFCI RECEPTACLE (ALL SPECS EXCEPT CE, UK CA, AUSTRALIAN & CHINESE SPECS WITH 7500W SKYPOWER GENERATOR)​
FIGURE 8-20. BATTERY DISCONNECT​
FIGURE 8-21. BOOM CABLES INSTALLATION - WITH 2500W GENERATOR​
FIGURE 8-22. BOOM CABLES INSTALLATION - WITH 4000W GENERATOR (50HZ)​
FIGURE 8-23. BOOM CABLES INSTALLATION - WITH 4000W GENERATOR (60HZ)​
FIGURE 8-24. BOOM CABLES INSTALLATION - WITH 7500W SKYPOWER GENERATOR​
FIGURE 8-25. BOOM CABLE - MAIN BOOM​
FIGURE 8-26. BOOM CABLE (TOWER BOOM)​
FIGURE 8-27. BOOM VALVE HARNESS​
FIGURE 8-28. BREAKER BOX INSTALLATION (BRAZIL SPECS)​
FIGURE 8-29. BREAKER BOX INSTALLATION (CE & UK CA SPECS WITHOUT 4000W GENERATOR)​
FIGURE 8-30. BREAKER BOX KIT - ONE DOUBLE 16AMP BREAKER (BRAZIL, CE & UK CA SPECS WITHOUT 4000W GENERATOR)​
FIGURE 8-31. BREAKER BOX KIT - WITH 3 BREAKERS (CE & UK CA SPECS WITH 4000W GENERATOR)​
FIGURE 8-32. BREAKER BOX KIT - ONE DOUBLE 16AMP BREAKER (CE & UK CA SPECS WITH 4000W GENERATOR)​
FIGURE 8-33. CLEARSKY CS550 BEACON INSTALLATION​
FIGURE 8-34. ECU POWER JUMPER HARNESS​
FIGURE 8-35. ENGINE HARNESS - DEUTZ D2011 ENGINES​
FIGURE 8-36. GROUND CONTROL ENGINE HARNESS - DEUTZ TD2.9L4 (STAGE V) ENGINE​
FIGURE 8-37. ENGINE HARNESS - DEUTZ TD2.9L4 ENGINES AND DEUTZ TD2.9L4 (STAGE V PRE-BUY) ENGINES​
FIGURE 8-38. ENGINE HARNESS - DEUTZ TD2.9L4 (STAGE V) ENGINES​
FIGURE 8-39. ENGINE HARNESS - FORD ENGINES​
FIGURE 8-40. FUEL PUMP HARNESS - DEUTZ TD2.9L4 ENGINES​
FIGURE 8-41. FUEL HARNESS - DEUTZ TD2.9L4 (STAGE V) ENGINE​
FIGURE 8-42. GENERATOR HARNESS - 4000W GENERATOR​
FIGURE 8-43. GENERATOR HARNESS - 7500W SKYPOWER GENERATOR​
FIGURE 8-44. GENERATOR TO ENGINE HARNESS - 2500W (FORD ENGINES)​
FIGURE 8-45. GENERATOR TO ENGINE HARNESS - 4000W (DEUTZ D2011 ENGINES)​
FIGURE 8-46. GENERATOR TO ENGINE HARNESS - 4000W (DEUTZ TD2.9L4 ENGINES)​
FIGURE 8-47. GENERATOR TO ENGINE HARNESS - 7500W SKYPOWER GENERATOR (DEUTZ D2011 ENGINES)​
FIGURE 8-48. GENERATOR TO ENGINE HARNESS - 7500W SKYPOWER (FORD DF 2.5L ENGINES)​
FIGURE 8-49. GENERATOR HARNESS - 7500W SKYPOWER (DEUTZ TD2.9L4 T4F ENGINES)​
FIGURE 8-50. GENERATOR TO REAR OF BOOM HARNESS - 110V​
FIGURE 8-51. GENERATOR TO REAR OF BOOM HARNESS - 220V​
FIGURE 8-52. GROUND CONTROL BOX HARNESS​
FIGURE 8-53. MID BOOM PROXIMITY SENSOR HARNESS​
FIGURE 8-54. PLATFORM CONSOLE BOX HARNESS​
FIGURE 8-55. RECEPTACLE BOX KIT - 110V IEC YELLOW (CE & UK CA SPECS)​
FIGURE 8-56. RECEPTACLE BOX KIT - 220V IEC BLUE (CE & UK CA SPECS)​
FIGURE 8-57. RECEPTACLE BOX KIT - 220V CEE7 POST GROUND 2X4 BOX (CE & UK CA SPEC)​
FIGURE 8-58. RECEPTACLE BOX KIT - 220V CEE7 SIDE GROUND 2X4 BOX (CE & UK CA SPEC)​
FIGURE 8-59. RECEPTACLE BOX KIT - 220V AFSINT107 KEYED GROUND (CE & UK CA SPECS)​
FIGURE 8-60. SKYEYE EMITTER HARNESS​
FIGURE 8-61. SKYEYE INTERMEDIATE HARNESS​
FIGURE 8-62. SKYEYE RECEIVER HARNESS​
FIGURE 8-63. SKYLINE HARNESS​
FIGURE 8-64. SKYGUARD INTERFACE HARNESS​
FIGURE 8-65. TOWER STOW HARNESS​
FIGURE 8-66. VALVE HARNESS​
FIGURE 8-67. WHITE NOISE ALARM HARNESS​
SECTION 9 - DECALS
FIGURE 9-1. DECAL INSTALLATION (ANSI SPECS)​
FIGURE 9-2. DECAL INSTALLATION (AUSTRALIAN SPECS)​
FIGURE 9-3. DECAL INSTALLATION (BRAZILIAN SPECS)​
FIGURE 9-4. DECAL INSTALLATION (CE & UK CA SPECS)​
FIGURE 9-5. DECAL INSTALLATION (CHINA SPECS)​
FIGURE 9-6. DECAL INSTALLATION (CSA SPECS)​
FIGURE 9-7. DECAL INSTALLATION (JAPANESE SPECS)​
FIGURE 9-8. DECAL INSTALLATION (KOREAN SPECS)​
FIGURE 9-9. DECAL INSTALLATION (LATIN AMERICAN SPECS)​
FIGURE 9-10. DECAL INSTALLATION - OPTIONS​
FIGURE 9-11. SKYCUTTER DECAL INSTALLATION​
FIGURE 9-12. SKYWELDER DECAL INSTALLATION - 50HZ​
FIGURE 9-13. DECAL INSTALLATION - SKYWELDER (60HZ)​
SECTION 11 - SPECIAL OPTIONS
FIGURE 11-1. SPECIAL OPTIONS/ACCESSORES/KITS​
PART NUMBER INDEX
