JLG Boom Lift 800AJ HC3 Parts Catalog 31222413
Brand: JLG
Type of Machine: Boom Lift
Model: JLG 800AJ HC3 Boom Lift
Part Number: 31222413
Publication Date: 2025
Number of Pages: 894 Pages
SECTION 1 - FRAME
Brand: JLG
SECTION 1 - FRAME
FIGURE 1-1. AXLE INSTALLATION - OSCILLATING
FIGURE 1-2. AXLE INSTALLATION - OSCILLATING WITH TOW PACKAGE
FIGURE 1-3. STEER INSTALLATION - 2WS
FIGURE 1-4. STEER INSTALLATION - 2WS WITH TOW PACKAGE
FIGURE 1-5. WHEEL DRIVE AND FRAME VALVES INSTALLATION - 4WD/2WS
FIGURE 1-6. DRIVE HUB/BRAKE ASSEMBLY
FIGURE 1-7. DRIVE MOTOR ASSEMBLY - 4WD
FIGURE 1-8. TIRE AND WHEEL INSTALLATION 18-625 NHS FOAM-FILLED TIRE
FIGURE 1-9. TIRE AND WHEEL INSTALLATION 18-625 NHS FOAM-FILLED NON-MARKING TIRE
FIGURE 1-10. TIRE AND WHEEL INSTALLATION 18-625 NHS FOAM-FILLED SAND TIRE
FIGURE 1-11. LP TANK BRACKETS INSTALLATIONS
FIGURE 1-12. FRAME SHIELDS INSTALLATION - 2WS
FIGURE 1-13. TOW PACKAGE INSTALLATION - 2WS (ENGLISH LANGUAGE DECALS)
FIGURE 1-14. TOW PACKAGE INSTALLATION - 2WS (CE & UK CA SPECS)
FIGURE 1-15. TOW BAR ASSEMBLY
SECTION 2 - TURNTABLEFIGURE 2-1. CONTROL VALVES INSTALLATION - WITH 2WS
FIGURE 2-2. CONTROL VALVE ASSEMBLY - 2WS MACHINES
FIGURE 2-3. SWING DRIVE INSTALLATION
FIGURE 2-4. SWING MOTOR/HUB ASSEMBLY
FIGURE 2-5. TURNTABLE BEARING INSTALLATION
FIGURE 2-6. TURNTABLE LOCK INSTALLATION
FIGURE 2-7. ROTARY COUPLING INSTALLATION - 2WS MACHINES
FIGURE 2-8. TANK INSTALLATION - DIESEL MACHINE (FUEL TANK WITHOUT SIGHT GLASS) (HELGESEN 6IN DIA BREATHER HYDRAULIC TANK - 25 GAL CAPACITY)
FIGURE 2-9. TANK INSTALLATION - DIESEL MACHINE (FUEL TANK WITHOUT SIGHT GLASS) (JIANGYING 4IIN DIA BREATHER HYDRAULIC TANK - 25 GAL CAPACITY)
FIGURE 2-10. TANK INSTALLATION - DIESEL MACHINE (FUEL TANK WITH SIGHT GLASS) (HELGESEN 6IIN DIA BREATHER HYDRAULIC TANK - 25 GAL CAPACITY)
FIGURE 2-11. TANK INSTALLATION - DIESEL MACHINE (FUEL TANK WITH SIGHT GLASS) (JIANGYING 4IN DIA BREATHER HYDRAULIC TANK - 25 GAL CAPACITY)
FIGURE 2-12. TANK INSTALLATION - GAS ENGINES (HELGESEN 6IN DIA BREATHER HYDRAULIC TANK - 25 GAL CAPACITY)
FIGURE 2-13. TANK INSTALLATION - GAS ENGINES (JIANGYING 4IN DIA BREATHER HYDRAULIC TANK - 25 GAL CAPACITY)
FIGURE 2-14. HYDRAULIC TANK ASSEMBLY (HELGESEN 6IN DIA BREATHER HYDRAULIC TANK - 25 GAL CAPACITY)
FIGURE 2-15. HYDRAULIC TANK ASSEMBLY (JIANGYING 4IN DIA BREATHER HYDRAULIC TANK - 25 GAL CAPACITY)
FIGURE 2-16. AUXILIARY POWER INSTALLATION - WITHOUT BATTERY DISCONNECT
FIGURE 2-17. AUXILIARY POWER INSTALLATION - WITH BATTERY DISCONNECT
FIGURE 2-18. AUXILIARY POWER PUMP/MOTOR ASSEMBLY
FIGURE 2-19. GROUND CONTROL BOX ASSEMBLY - WITH DEUTZ D2011 ENGINES - WITH MECHANICAL HOUR METER (ANSI EXPORT LRC AND AUSTRALIAN SPECS)
FIGURE 2-20. GROUND CONTROL BOX ASSEMBLY - WITH DEUTZ D2011 AND TOWER STOW - WITH MECHANICAL HOUR METER (ANSI EXPORT LRC AND AUSTRALIAN SPECS)
FIGURE 2-21. GROUND CONTROL BOX ASSEMBLY - WITH DEUTZ D2011 ENGINES (CE & UK CA SPECS)
FIGURE 2-22. GROUND CONTROL BOX ASSEMBLY - WITH DEUTZ D2011 ENGINES AND WITH TOWER STOW (CE & UK CA LRC SPECS)
FIGURE 2-23. GROUND CONTROL BOX ASSEMBLY - WITH DEUTZ TD2.9L4 ENGINES - WITH MECHANICAL HOUR METER (ANSI, ANSI EXPORT, CSA, CHINA & JAPANESE SPECS)
FIGURE 2-24. GROUND CONTROL BOX ASSEMBLY - WITH DEUTZ TD2.9L4 AND TOWER STOW - WITH MECHANICAL HOUR METER (ANSI, ANSI EXPORT, CSA, CHINA & JAPANESE SPECS)
FIGURE 2-25. GROUND CONTROL BOX ASSEMBLY - WITH DEUTZ TD2.9L4 (STAGE V) ENGINES (CE & UK CA SPECS)
FIGURE 2-26. GROUND CONTROL BOX ASSEMBLY - WITH DEUTZ TD2.9L4 (STAGE V) ENGINES AND WITH TOWER STOW (CE & UK CA SPECS)
FIGURE 2-27. GROUND CONTROL BOX ASSEMBLY - WITH FORD ENGINES AND TOWER STOW - WITH MECHANICAL HOUR METER
FIGURE 2-28. LIGHT PANEL INSTALLATION
FIGURE 2-29. ALARM INSTALLATION
FIGURE 2-30. STROBE LIGHT INSTALLATION (AMBER) (WITHOUT CLEARSKY BEACON)
FIGURE 2-31. STROBE LIGHT INSTALLATION (BLUE) (WITHOUT CLEARSKY BEACON)
FIGURE 2-32. STROBE LIGHT INSTALLATION (RED) (WITHOUT CLEARSKY BEACON)
FIGURE 2-33. HOODS INSTALLATION - ABS (DEUTZ D2011 ENGINES)
FIGURE 2-34. HOODS INSTALLATION - ABS (DEUTZ TD2.9L4 ENGINES)
FIGURE 2-35. HOODS INSTALLATION - ABS (DEUTZ TD2.9L4 (STAGE V) ENGINES)
FIGURE 2-36. HOODS INSTALLATION - STEEL (DEUTZ D2011 ENGINES)
FIGURE 2-37. HOODS INSTALLATION - STEEL (DEUTZ TD2.9L4 ENGINES)
FIGURE 2-38. HOODS INSTALLATION - STEEL (FORD ENGINES)
FIGURE 2-39. EXHAUST COVER AND HEAT SHIELDS INSTALLATION - STEEL HOODS (DEUTZ D2011 ENGINES)
FIGURE 2-40. EXHAUST COVER AND HEAT SHIELDS INSTALLATION - STEEL HOODS (DEUTZ TD2.9L4 ENGINES)
FIGURE 2-41. EXHAUST COVER INSTALLATION - STEEL HOODS (FORD ENGINES)
FIGURE 2-42. SKYAIR AIR COMPRESSOR INSTALLATION
FIGURE 2-43. SKYAIR AIR COMPRESSOR INSTALLATION
FIGURE 2-44. AIR COMPRESSOR ASSEMBLY
FIGURE 2-45. WHITE NOISE ALARM INSTALLATION - ADJUSTABLE AMBIENT
FIGURE 2-46. WHITE NOISE MOTION ALARM INSTALLATION - AMBIENT
SECTION 3 - ENGINEFIGURE 3-1. DEUTZ D2011 ENGINE INSTALLATION (WITHOUT ARCTIC PACKAGE)
FIGURE 3-2. DEUTZ D2011 ENGINE INSTALLATION (WITH ARCTIC PACKAGE)
FIGURE 3-3. DEUTZ D2011 ENGINE/PUMP SUB ASSEMBLY (WITHOUT ARCTIC PACKAGE)
FIGURE 3-4. DEUTZ TD2.9L4 ENGINE/PUMP SUB ASSEMBLY (WITH ARCTIC PACKAGE)
FIGURE 3-5. DEUTZ D2011 ENGINE ASSEMBLY (WITHOUT ARCTIC PACKAGE)
FIGURE 3-6. DEUTZ D2011 ENGINE ASSEMBLY (WITH ARCTIC PACKAGE)
FIGURE 3-7. DEUTZ D2011 ENGINE COMPONENTS
FIGURE 3-8. DEUTZ TD2.9L4 ENGINE INSTALLATION (WITHOUT ARCTIC PACKAGE)
FIGURE 3-9. DEUTZ TD2.9L4 ENGINE INSTALLATION (WITH ARCTIC PACKAGE)
FIGURE 3-10. DEUTZ TD2.9L4 ENGINE INSTALLATION (STAGE V)
FIGURE 3-11. DEUTZ TD2.9L4 ENGINE INSTALLATION (CHINA III)
FIGURE 3-12. DEUTZ TD2.9L4 ENGINE INSTALLATION (CHINA IV)
FIGURE 3-13. DEUTZ TD2.9L4 ENGINE/PUMP SUB ASSEMBLY (WITHOUT ARCTIC PACKAGE)
FIGURE 3-14. DEUTZ TD2.9L4 ENGINE/PUMP SUB ASSEMBLY (WITH ARCTIC PACKAGE)
FIGURE 3-15. DEUTZ TD2.9L4 ENGINE/PUMP SUB ASSEMBLY (STAGE V)
FIGURE 3-16. DEUTZ TD2.9L4 ENGINE/PUMP SUB ASSEMBLY (CHINA III)
FIGURE 3-17. DEUTZ TD2.9L4 ENGINE/PUMP SUB ASSEMBLY (CHINA IV)
FIGURE 3-18. DEUTZ TD2.9L4 ENGINE ASSEMBLY (CHINA IV)
FIGURE 3-19. DEUTZ TD2.9L4 ENGINE ASSEMBLY (CHINA IV)
FIGURE 3-20. DEUTZ TD2.9L4 ENGINE ASSEMBLY (WITHOUT ARCTIC PACKAGE)
FIGURE 3-21. DEUTZ TD2.9L4 ENGINE ASSEMBLY (WITH ARCTIC PACKAGE)
FIGURE 3-22. DEUTZ TD2.9L4 ENGINE ASSEMBLY (STAGE V)
FIGURE 3-23. DEUTZ TD2.9L4 ENGINE ASSEMBLY (CHINA III SPECS)
FIGURE 3-24. DEUTZ TD2.9L4 ENGINE COMPONENTS
FIGURE 3-25. DEUTZ TD2.9L4 ENGINE COMPONENTS (STAGE V)
FIGURE 3-26. DEUTZ TD2.9L4 ENGINE COMPONENTS (CHINA III SPECS)
FIGURE 3-27. DEUTZ D2.9L4 - EMR5 ENGINE INSTALLATION WITH ARCTIC PACKAGE
FIGURE 3-28. DEUTZ D2.9L4 - EMR5 ENGINE AND PUMP SUB-ASSEMBLY WITH ARCTIC PACKAGE
FIGURE 3-29. ENGINE ASSEMBLY - DEUTZ D2.9L4 EMR5 ENGINE (WITH ARCTIC PACKAGE)
FIGURE 3-30. DEUTZ D2.9L4 - EMR5 ENGINE INSTALLATION WITHOUT ARCTIC PACKAGE
FIGURE 3-31. DEUTZ D2.9L4 - EMR5 ENGINE AND PUMP SUB-ASSEMBLY WITHOUT ARCTIC PACKAGE
FIGURE 3-32. ENGINE ASSEMBLY - DEUTZ D2.9L4 EMR5 ENGINE (WITHOUT ARCTIC PACKAGE)
FIGURE 3-33. ENGINE COMPONENTS - DEUTZ D2.9L4 EMR5 ENGINE
FIGURE 3-34. FUEL PUMP/FILTER BRACKET ASSEMBLY (DEUTZ TD2.9L4 ENGINES)
FIGURE 3-35. FUEL PUMP/FILTER BRACKET ASSEMBLY (DEUTZ TD2.9L4 (STAGE V) ENGINES)
FIGURE 3-36. FUEL PUMP/FILTER BRACKET ASSEMBLY (DEUTZ TD2.9L4 ENGINES) (CHINA III ENGINES)
FIGURE 3-37. BREATHER HEATER INST (DEUTZ TD2.9L4 ENGINES)
FIGURE 3-38. FORD ENGINE INSTALLATION (WITHOUT ARCTIC PACKAGE)
FIGURE 3-39. FORD ENGINE INSTALLATION (WITH ARCTIC PACKAGE)
FIGURE 3-40. FORD ENGINE AND PUMP SUB-ASSEMBLY (WITHOUT ARCTIC PACKAGE)
FIGURE 3-41. FORD ENGINE AND PUMP SUB-ASSEMBLY (WITH ARCTIC PACKAGE)
FIGURE 3-42. FORD ENGINE ASSEMBLY (WITHOUT ARCTIC PACKAGE)
FIGURE 3-43. FORD ENGINE ASSEMBLY (WITH ARCTIC PACKAGE)
FIGURE 3-44. FORD ENGINE PREP ASSEMBLY
FIGURE 3-45. FORD ENGINE BRACKETS AND EXHAUST MANIFOLD INSTALLATION
FIGURE 3-46. FORD ENGINE DRIVE BELT INSTALLATION (MACHINES WITHOUT GENERATOR)
FIGURE 3-47. FORD ENGINE COMPONENTS
FIGURE 3-48. PUMP COUPING KIT (DEUTZ ENGINES)
FIGURE 3-49. HYDROSTATIC PUMP ASSEMBLY
FIGURE 3-50. VARIABLE PUMP ASSEMBLY
FIGURE 3-51. VARIABLE PUMP ASSEMBLY - HENGLI
FIGURE 3-52. HYDROSTATIC PUMP ASSEMBLY
FIGURE 3-53. EXHAUST PIPE INSTALLATION - DEUTZ TD2.9L4 ENGINES
FIGURE 3-54. EXHAUST PIPE INSTALLATION - DEUTZ TD2.9L4 (STAGE V) ENGINES
FIGURE 3-55. EXHAUST PIPE INSTALLATION - FORD ENGINES
FIGURE 3-56. SPARK ARRESTOR MUFFLER INSTALLATION - DEUTZ D2011 ENGINES
FIGURE 3-57. FUEL-WATER SEPARATOR INSTALLATION - DEUTZ D2011 ENGINES
FIGURE 3-58. FUEL-WATER SEPARATOR INSTALLATION - DEUTZ TD2.9L4 ENGINES
FIGURE 3-59. RIGHT ENGINE SUPPORT INSTALLATION (DEUTZ D2011 ENGINES MACHINES WITHOUT GENERATORS)
FIGURE 3-60. RIGHT ENGINE SUPPORT INSTALLATION (DEUTZ D2011 ENGINES MACHINES WITH GENERATORS)
FIGURE 3-61. ENGINE HOOD BAFFLE INSTALLATION - DEUTZ TD2.9L4 ENGINES AND DEUTZ TD2.9L4 (STAGE V) ENGINES WITH ABS HOODS
FIGURE 3-62. ENGINE HOOD BAFFLE INSTALLATION - DEUTZ TD2.9L4 ENGINES WITH STEEL HOODS
FIGURE 3-63. ENGINE TRAY JACK INSTALLATION - DEUTZ ENGINES
FIGURE 3-64. ENGINE TRAY JACK INSTALLATION - FORD ENGINES
FIGURE 3-65. 2500W/110V/60HZ GENERATOR INSTALLATION - DEUTZ D2011 ENGINES
FIGURE 3-66. 2500W/110V/60HZ GENERATOR INSTALLATION - DEUTZ TD2.9L4 ENGINES
FIGURE 3-67. 2500W/110V/60HZ GENERATOR INSTALLATION - FORD ENGINES
FIGURE 3-68. 2500W/220V/50HZ GENERATOR INSTALLATION - DEUTZ D2011 ENGINES
FIGURE 3-69. 4000W/50HZ GENERATOR INSTALLATION - DEUTZ D2011 ENGINES
FIGURE 3-70. 4000W/50HZ GENERATOR INSTALLATION - DEUTZ TD2.9L4 ENGINES AND DEUTZ TD2.9L4 (STAGE V) ENGINES
FIGURE 3-71. 4000W/60HZ GENERATOR INSTALLATION - DEUTZ D2011 ENGINES
FIGURE 3-72. 4000W/60HZ GENERATOR INSTALLATION - DEUTZ TD2.9L4 ENGINES
FIGURE 3-73. 7500W/50HZ SKYPOWER GENERATOR INSTALLATION - DEUTZ D2011 ENGINES
FIGURE 3-74. 7500W/50HZ SKYPOWER GENERATOR INSTALLATION - DEUTZ TD2.9L4 ENGINES AND DEUTZ TD2.9L4 (STAGE V) ENGINES
FIGURE 3-75. 7500W/60HZ SKYPOWER GENERATOR INSTALLATION - DEUTZ D2011 ENGINES
FIGURE 3-76. 7500W/60HZ SKYPOWER GENERATOR INSTALLATION - DEUTZ TD2.9L4 ENGINES
FIGURE 3-77. 7500W/60HZ SKYPOWER GENERATOR INSTALLATION - FORD ENGINES
FIGURE 3-78. QUICKFIT OIL VALVE (DEUTZ ENGINES)
SECTION 4 - BOOMFIGURE 4-1. BOOM AND CYLINDER INSTALLATION
FIGURE 4-2. MAIN BOOM ASSEMBLY
FIGURE 4-3. TOWER BOOM ASSEMBLY
FIGURE 4-4. JIB ASSEMBLY
FIGURE 4-5. ROTATOR ASSEMBLY
FIGURE 4-6. SUPPORT, PLATFORM INSTALLATION
FIGURE 4-7. POWER TRACK INSTALLATION - MAIN BOOM
FIGURE 4-8. POWER TRACK INSTALLATION - TOWER BOOM
FIGURE 4-9. CONTROL VALVES INSTALLATION - WITH 2WS
FIGURE 4-10. CONTROL VALVE ASSEMBLY
FIGURE 4-11. BOOM VALVES AND PROXIMITY SWITCHES INSTALLATION
FIGURE 4-12. BOOM VALVES AND PROXIMITY SWITCHES INSTALLATION WITH TOWER STOW
FIGURE 4-13. TRANSPORT POSITION SWITCH INSTALLATION
SECTION 5 - PLATFORMFIGURE 5-1. PLATFORM ASSEMBLY WITH DROP-BAR - 30IN X 3FT (76CM X 1M)
FIGURE 5-2. PLATFORM ASSEMBLY WITH GATE - 30IN X 4FT (76CM X 1.22M)
FIGURE 5-3. PLATFORM ASSEMBLY WITH DROP-BAR - 30IN X 4FT (76CM X 1.22M)
FIGURE 5-4. PLATFORM ASSEMBLY WITH GATE - 30IN X 6FT (76CM X 1.83M)
FIGURE 5-5. PLATFORM ASSEMBLY WITH GATE- 36IN X 6FT (91.5CM X 1.83M)
FIGURE 5-6. PLATFORM ASSEMBLY WITH DROP-BAR - 30IN X 6FT (76CM X 1.83M)
FIGURE 5-7. PLATFORM ASSEMBLY WITH DROP-BAR - 36IN X 6FT (91.5CM X 1.83M)
FIGURE 5-8. PLATFORM ASSEMBLY WITH 1 GATE / 2 DROP BARS (TRI-ENTRY) - 36IN X 6FT (91.5CM X 1.83M)
FIGURE 5-9. PLATFORM ASSEMBLY WITH 3 DROP BARS (TRI-ENTRY) - 36IN X 6FT (91.5CM X 1.83M)
FIGURE 5-10. PLATFORM ASSEMBLY WITH FALL ARREST (6FT)
FIGURE 5-11. PLATFORM ASSEMBLY WITH GATE - 36IN X 8FT (91.5CM X 2.44M)
FIGURE 5-12. PLATFORM ASSEMBLY WITH DROP-BAR - 36IN X 8FT (91.5CM X 2.44M)
FIGURE 5-13. PLATFORM ASSEMBLY WITH 1 GATE / 2 DROP BARS (TRI-ENTRY) - 36IN X 8FT (91.5CM X 2.44M)
FIGURE 5-14. PLATFORM ASSEMBLY WITH 3 DROP BARS (TRI-ENTRY) - 36IN X 8FT (91.5CM X 2.44M)
FIGURE 5-15. PLATFORM ASSEMBLY WITH FALL ARREST (8FT)
FIGURE 5-16. CONSOLE AND FOOT SWITCH INSTALLATION
FIGURE 5-17. CONSOLE AND FOOT SWITCH INSTALLATION WITH TOWER STOW
FIGURE 5-18. CONSOLE BOX ASSEMBLY WITH FOOTSWITCH
FIGURE 5-19. CONSOLE BOX ASSEMBLY WITH FOOTSWITCH WITH TOWER STOW
FIGURE 5-20. LIGHT PANEL INSTALLATION
FIGURE 5-21. FOOTSWITCH ASSEMBLY
FIGURE 5-22. JIB SWITCH INSTALLATION
FIGURE 5-23. SKYEYE INSTALLATION
FIGURE 5-24. SKYGUARD BAR INSTALLATION
FIGURE 5-25. SKYLINE INSTALLATION
FIGURE 5-26. STORAGE TRAY INSTALLATION - CENTER
FIGURE 5-27. MANUAL STORAGE BOX INSTALLATION
FIGURE 5-28. SKYCUTTER INSTALLATION
FIGURE 5-29. SKYWELDER/SKYCUTTER COMBO INSTALLATION (60HZ)
FIGURE 5-30. PLASMA CUTTER ASSEMBLY
FIGURE 5-31. SKYWELDER INSTALLATION (50HZ)
FIGURE 5-32. SKYWELDER INSTALLATION (60HZ)
FIGURE 5-33. WELDER ASSEMBLY
FIGURE 5-34. SKYWELDER PREP PACKAGE (60HZ)
FIGURE 5-35. SKYGLAZIER INSTALLATION (ALL SPECS EXCEPT CHINA AND JAPANESES SPECS)
FIGURE 5-36. SKYGLAZIER INSTALLATION (ENGLISH LANGUAGE DECALS)
FIGURE 5-37. SOFT TOUCH SYSTEM INSTALLATION - 6FT/1.83M PLATFORM
FIGURE 5-38. SOFT TOUCH SYSTEM INSTALLATION - 6FT/1.83M FALL ARREST PLATFORM
FIGURE 5-39. SOFT TOUCH SYSTEM INSTALLATION - 8FT/2.44M PLATFORM
FIGURE 5-40. SOFT TOUCH SYSTEM INSTALLATION - 8FT/2.44M FALL ARREST PLATFORM
FIGURE 5-41. FALL ARREST INSTALLATION (BOLT-ON) 30IN X 4FT (76CM X 1.22M) PLATFORM
FIGURE 5-42. FALL ARREST INSTALLATION (BOLT-ON) 36IN X 6FT (91.2CM X 1.82M) PLATFORM
FIGURE 5-43. FALL ARREST INSTALLATION (BOLT-ON) 30IN X 6FT (76CM X 1.83M) PLATFORM
FIGURE 5-44. FALL ARREST INSTALLATION (BOLT-ON) 36IN X 8FT (91.5CM X 2.4M) PLATFORM
FIGURE 5-45. FALL ARREST INSTALLATION (BOLT-ON) 36IN X 6FT (91.5CM X 1.82M) TRI-ENTRY PLATFORM)
FIGURE 5-46. USB CHARGER INSTALLATION
FIGURE 6-2. LEVEL CYLINDER ASSEMBLY - PLATFORM SLAVE
FIGURE 6-3. LEVEL CYLINDER ASSEMBLY - UPRIGHT
FIGURE 6-4. LIFT CYLINDER ASSEMBLY - JIB
FIGURE 6-5. LIFT CYLINDER ASSEMBLY - MAIN BOOM
FIGURE 6-6. LIFT CYLINDER ASSEMBLY - TOWER BOOM
FIGURE 6-7. MASTER CYLINDER ASSEMBLY
FIGURE 6-8. STEER CYLINDER ASSEMBLY
FIGURE 6-9. TELESCOPE CYLINDER ASSEMBLY - MAIN BOOM
FIGURE 6-10. TELESCOPE CYLINDER ASSEMBLY - TOWER BOOM
SECTION 7 - HYDRAULICFIGURE 7-1. HYDRAULIC DIAGRAM - AXLE (OSCILLATING)
FIGURE 7-2. HYDRAULIC DIAGRAM - DRIVE (4WD/2WS WITHOUT TOW PACKAGE/WITHOUT ARCTIC PACKAGE)
FIGURE 7-3. HYDRAULIC DIAGRAM - DRIVE (4WD/2WS WITHOUT TOW PACKAGE/WITH ARCTIC PACKAGE)
FIGURE 7-4. HYDRAULIC DIAGRAM - DRIVE (4WD/2WS WITH TOW PACKAGE/WITHOUT ARCTIC PACKAGE)
FIGURE 7-5. HYDRAULIC DIAGRAM - DRIVE (4WD/2WS WITH TOW PACKAGE/WITH ARCTIC PACKAGE)
FIGURE 7-6. HYDRAULIC DIAGRAM - DRIVE (4WD/2WS WITH TOW PACKAGE)(CE & UK CA SPECS ONLY)
FIGURE 7-7. HYDRAULIC DIAGRAM - DRIVE (4WD/2WS WITH TOW PACKAGE AND ARCTIC PACKAGE)(ANSI SPEC ONLY)
FIGURE 7-8. HYDRAULIC DIAGRAM - DRIVE (4WD/2WS WITHOUT TOW PACKAGE AND WITHOUT ARCTIC PACKAGE)(ALL SPECS)
FIGURE 7-9. HYDRAULIC DIAGRAM - DRIVE (4WD/2WS WITHOUT TOW PACKAGE AND WITH ARCTIC PACKAGE)(CSA AND ANSI SPECS)
FIGURE 7-10. HYDRAULIC DIAGRAM - STANDARD
SECTION 8 - ELECTRICALFIGURE 8-1. ELECTRICAL LAYOUT
FIGURE 8-2. AC BOX AT PLATFORM INSTALLATION - 110V GFI RECEPTACLE (ALL SPECS EXCEPT AUSTRALIAN, CE & UK CA SPECS)
FIGURE 8-3. AC BOX AT PLATFORM INSTALLATION - 220V (ANSI, CSA & JAPANESE SPECS)
FIGURE 8-4. AC BOX AT PLATFORM MID-BOOM PLUG INSTALLATION (WITH 4000W/60HZ GENERATOR) (ANSI, ANSI EXPORT, CSA & JAPANESE SPECS)
FIGURE 8-5. AC BOX AT PLATFORM MID-BOOM PLUG INSTALLATION (WITHOUT 7500W SKYPOWER GENERATOR) (ALL SPECS EXCEPT ANSI, JAPANESE & CSA SPECS)
FIGURE 8-6. AC BOX AT PLATFORM MID-BOOM PLUG INSTALLATION (WITH 7500W SKYPOWER GENERATOR)
FIGURE 8-7. AC BOX AT PLATFORM INSTALLATION - 110V IEC YELLOW (CE & UK CA SPECS) (MACHINES WITH 2500W GENERATOR OR NO GENERATOR OPTION)
FIGURE 8-8. AC BOX AT PLATFORM INSTALLATION - 110V IEC YELLOW (CE & UK CA SPECS) (MACHINES WITH 4000W GENERATOR)
FIGURE 8-9. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE (CE & UK CA SPECS) (MACHINES WITH 2500W GENERATOR OR NO GENERATOR OPTION)
FIGURE 8-10. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE (CE & UK CA SPECS) (MACHINES WITH 4000W GENERATOR)
FIGURE 8-11. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 POST GROUND (CE & UK CA SPECS) (MACHINES WITH 2500W GENERATOR OR NO GENERATOR OPTION)
FIGURE 8-12. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 POST GROUND (CE & UK CA SPECS) (MACHINES WITH 4000W GENERATOR)
FIGURE 8-13. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 SIDE GROUND (CE & UK CA SPECS) (MACHINES WITH 2500W GENERATOR OR NO GENERATOR OPTION)
FIGURE 8-14. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 SIDE GROUND (CE & UK CA SPECS) (MACHINES WITH 4000W GENERATOR)
FIGURE 8-15. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT 107 KEYED GROUND (CE & UK CA SPECS) (MACHINES WITH 2500W GENERATOR OR NO GENERATOR OPTION)
FIGURE 8-16. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT 107 KEYED GROUND (CE & UK CA SPECS) (MACHINES WITH 4000W GENERATOR)
FIGURE 8-17. AC BOX AT PLATFORM INSTALLATION - 220V (2X4 BOX & COVER ONLY - LOCALLY SUPPLIED RECEPTACLE) (4000W GENERATOR)
FIGURE 8-18. AC BOX AT PLATFORM INSTALLATION - 240V GFCI RECEPTACLE (ALL SPECS EXCEPT CE, UK CA, AUSTRALIAN & CHINESE SPECS WITH 4000W SKYPOWER GENERATOR)
FIGURE 8-19. AC BOX AT PLATFORM INSTALLATION - 240V GFCI RECEPTACLE (ALL SPECS EXCEPT CE, UK CA, AUSTRALIAN & CHINESE SPECS WITH 7500W SKYPOWER GENERATOR)
FIGURE 8-20. BEACON CONTROL HARNESS (BLUE AND RED STROBE LIGHTS)
FIGURE 8-21. BATTERY DISCONNECT
FIGURE 8-22. BOOM CABLES INSTALLATION - WITH 2500W GENERATOR
FIGURE 8-23. BOOM CABLES INSTALLATION - WITH 4000W GENERATOR (50HZ)
FIGURE 8-24. BOOM CABLES INSTALLATION - WITH 4000W GENERATOR (60HZ)
FIGURE 8-25. BOOM CABLES INSTALLATION - WITH 7500W SKYPOWER GENERATOR
FIGURE 8-26. BOOM CABLE - MAIN BOOM
FIGURE 8-27. BOOM CABLE (TOWER BOOM)
FIGURE 8-28. BOOM VALVE HARNESS
FIGURE 8-29. BREAKER BOX INSTALLATION (BRAZIL SPECS)
FIGURE 8-30. BREAKER BOX INSTALLATION (CE & UK CA SPECS WITHOUT 4000W GENERATOR)
FIGURE 8-31. BREAKER BOX KIT - ONE DOUBLE 16AMP BREAKER (BRAZIL, CE & UK CA SPECS WITHOUT 4000W GENERATOR)
FIGURE 8-32. BREAKER BOX KIT - WITH 3 BREAKERS (CE & UK CA SPECS WITH 4000W GENERATOR)
FIGURE 8-33. BREAKER BOX KIT - ONE DOUBLE 16AMP BREAKER (CE & UK CA SPECS WITH 4000W GENERATOR)
FIGURE 8-34. CSB HARNESS
FIGURE 8-35. CLEARSKY 3-WIRE TELEMATICS INSTALLATION (ALL SPECS)
FIGURE 8-36. CLEARSKY 3-WIRE TELEMATICS INSTALLATION (ANSI & CSA SPECS)
FIGURE 8-37. CLEARSKY 3-WIRE TELEMATICS INSTALLATION (ANSI EXPORT, CE & UK CA SPECS)
FIGURE 8-38. CLEARSKY 3G CANBUS TELEMATICS INSTALLATION (AUSTRALIAN SPECS)
FIGURE 8-39. CLEARSKY 3G CANBUS TELEMATICS INSTALLATION (CE SPECS)
FIGURE 8-40. CLEARSKY 4G CANBUS TELEMATICS INSTALLATION (ANSI SPECS)
FIGURE 8-41. CLEARSKY 4G CANBUS TELEMATICS INSTALLATION (CHINA SPECS)
FIGURE 8-42. CLEARSKY CS550 BEACON INSTALLATION
FIGURE 8-43. CLEARSKY HARNESS - 3-WIRE TELEMATICS (ALL SPECS)
FIGURE 8-44. CLEARSKY HARNESS - 3-WIRE TELEMATICS (ANSI, ANSI EXPORT, CE & UK CA & CSA SPECS)
FIGURE 8-45. CLEARSKY HARNESS - CANBUS TELEMATICS
FIGURE 8-46. ECU POWER JUMPER HARNESS
FIGURE 8-47. ENGINE HARNESS - DEUTZ D2011 ENGINES
FIGURE 8-48. GROUND CONTROL ENGINE HARNESS - DEUTZ TD2.9L4 (STAGE V) ENGINE
FIGURE 8-49. ENGINE HARNESS - DEUTZ TD2.9L4 ENGINES AND DEUTZ TD2.9L4 (STAGE V PRE-BUY) ENGINES
FIGURE 8-50. ENGINE HARNESS - DEUTZ TD2.9L4 (STAGE V) ENGINES
FIGURE 8-51. ENGINE HARNESS - FORD ENGINES
FIGURE 8-52. FUEL PUMP HARNESS - DEUTZ TD2.9L4 ENGINES
FIGURE 8-53. FUEL HARNESS - DEUTZ TD2.9L4 (STAGE V) ENGINE
FIGURE 8-54. GENERATOR HARNESS - 4000W GENERATOR
FIGURE 8-55. GENERATOR HARNESS - 7500W SKYPOWER GENERATOR
FIGURE 8-56. GENERATOR TO ENGINE HARNESS - 2500W (FORD ENGINES)
FIGURE 8-57. GENERATOR TO ENGINE HARNESS - 4000W (DEUTZ D2011 ENGINES)
FIGURE 8-58. GENERATOR TO ENGINE HARNESS - 4000W (DEUTZ TD2.9L4 ENGINES)
FIGURE 8-59. GENERATOR TO ENGINE HARNESS - 7500W SKYPOWER GENERATOR (DEUTZ D2011 ENGINES)
FIGURE 8-60. GENERATOR TO ENGINE HARNESS - 7500W SKYPOWER (FORD DF 2.5L ENGINES)
FIGURE 8-61. GENERATOR HARNESS - 7500W SKYPOWER (DEUTZ TD2.9L4 T4F ENGINES)
FIGURE 8-62. GENERATOR TO REAR OF BOOM HARNESS - 110V
FIGURE 8-63. GENERATOR TO REAR OF BOOM HARNESS - 220V
FIGURE 8-64. GROUND CONTROL BOX HARNESS
FIGURE 8-65. MID BOOM PROXIMITY SENSOR HARNESS
FIGURE 8-66. PLATFORM CONSOLE BOX HARNESS
FIGURE 8-67. RECEPTACLE BOX KIT - 110V IEC YELLOW (CE & UK CA SPECS)
FIGURE 8-68. RECEPTACLE BOX KIT - 220V IEC BLUE (CE & UK CA SPECS)
FIGURE 8-69. RECEPTACLE BOX KIT - 220V CEE7 POST GROUND 2X4 BOX (CE & UK CA SPEC)
FIGURE 8-70. RECEPTACLE BOX KIT - 220V CEE7 SIDE GROUND 2X4 BOX (CE & UK CA SPEC)
FIGURE 8-71. RECEPTACLE BOX KIT - 220V AFSINT107 KEYED GROUND (CE & UK CA SPECS)
FIGURE 8-72. SKYEYE EMITTER HARNESS
FIGURE 8-73. SKYEYE INTERMEDIATE HARNESS
FIGURE 8-74. SKYEYE RECEIVER HARNESS
FIGURE 8-75. SKYLINE HARNESS
FIGURE 8-76. SKYGUARD INTERFACE HARNESS
FIGURE 8-77. STROBE LIGHT JUMPER HARNESS
FIGURE 8-78. TOWER STOW HARNESS
FIGURE 8-79. VALVE HARNESS
FIGURE 8-80. WHITE NOISE ALARM HARNESS
SECTION 9 - DECALSFIGURE 9-1. DECAL INSTALLATION (ANSI SPECS)
FIGURE 9-2. DECAL INSTALLATION (AUSTRALIAN SPECS)
FIGURE 9-3. DECAL INSTALLATION (BRAZILIAN SPECS)
FIGURE 9-4. DECAL INSTALLATION (CE & UK CA SPECS)
FIGURE 9-5. DECAL INSTALLATION (CHINA SPECS)
FIGURE 9-6. DECAL INSTALLATION (CSA SPECS)
FIGURE 9-7. DECAL INSTALLATION (JAPANESE SPECS)
FIGURE 9-8. DECAL INSTALLATION (KOREAN SPECS)
FIGURE 9-9. DECAL INSTALLATION (LATIN AMERICAN SPECS)
FIGURE 9-10. DECAL INSTALLATION - OPTIONS
FIGURE 9-11. SKYCUTTER DECAL INSTALLATION
FIGURE 9-12. SKYWELDER DECAL INSTALLATION - 50HZ
FIGURE 9-13. DECAL INSTALLATION - SKYWELDER (60HZ)
SECTION 11 - SPECIAL OPTIONSFIGURE 11-1. SPECIAL OPTIONS/ACCESSORES/KITS
PART NUMBER INDEX
- SuperPac Parts Manual
- StratoLift Parts Manual
