Hyundai
86
176,834
JLG Boom Lift 800A 800AJ Parts Catalog 3121629
Brand: JLG
Type of Machine: Boom Lift
Model: JLG 800A 800AJ Boom Lift
Part Number: 3121629
Publication Date: 2025
Number of Pages: 488 Pages
SECTION 1 - FRAME
FIGURE 1-1. AXLE AND STEERING INSTALLATION WITHOUT TOW PACKAGE​
FIGURE 1-2. AXLE AND STEERING INSTALLATION WITH TOW PACKAGE​
FIGURE 1-3. TIRE AND WHEEL DRIVE INSTALLATIONS​
FIGURE 1-4. DRIVE HUB/BRAKE ASSEMBLY (SN 0300183034 through 0300244579)​
FIGURE 1-5. DRIVE HUB/BRAKE ASSEMBLY (SN 0300244580 through 0300272376)​
FIGURE 1-6. DRIVE MOTOR ASSEMBLY​
FIGURE 1-7. FRAME VALVES AND SHIELDS INSTALLATIONS​
FIGURE 1-8. TOW PACKAGE INSTALLATION​
SECTION 2 - TURNTABLE
FIGURE 2-1. CONTROL VALVES AND AUXILIARY PUMP INSTALLATIONS​
FIGURE 2-2. MAIN CONTROL VALVE ASSEMBLY (SN 0300183034 through 0300194139)​
FIGURE 2-3. MAIN CONTROL VALVE ASSEMBLY (SN 0300194140 through 0300238223)​
FIGURE 2-4. MAIN VALVE ASSEMBLY (SN 0300238224 through 0300272376)​
FIGURE 2-5. MAIN VALVE ASSEMBLY (SN 0300238224 through 0300272376)​
FIGURE 2-6. ACCESSORY VALVE ASSEMBLY​
FIGURE 2-7. AUXILIARY PUMP ASSEMBLY​
FIGURE 2-8. TURNTABLE BEARING AND SWING DRIVE INSTALLATION​
FIGURE 2-9. SWING MOTOR/HUB ASSEMBLY (Prior to SN 0300270085)​
FIGURE 2-10. SWING MOTOR/HUB ASSEMBLY (SN 0300270085 through 0300272376)​
FIGURE 2-11. DEUTZ D2011 ENGINE INSTALLATION​
FIGURE 2-12. DEUTZ TD2.9L4 ENGINE INSTALLATION​
FIGURE 2-13. FORD ENGINE INSTALLATION​
FIGURE 2-14. GM ENGINE INSTALLATION​
FIGURE 2-15. HYDROSTATIC PUMP ASSEMBLY (SN 0300183034 through 0300207789)​
FIGURE 2-16. HYDROSTATIC PUMP ASSEMBLY (SN 0300207790 through 0300272376)​
FIGURE 2-17. VARIABLE PUMP ASSEMBLY​
FIGURE 2-18. BREATHER HEATER INSTALLATION - DEUTZ D2.9L4 ENGINES WITH ARCTIC PACKAGE​
FIGURE 2-19. FUEL-WATER SEPARATOR INSTALLATION - DEUTZ TD2011 (OPTIONAL)​
FIGURE 2-20. FUEL-WATER SEPARATOR INSTALLATION (CHINA SPECS) (SN 0300238788 through 0300246968)​
FIGURE 2-21. FUEL-WATER SEPARATOR INSTALLATION (CHINA SPECS) (SN 0300246969 through 0300272376)​
FIGURE 2-22. TANK INSTALLATIONS​
FIGURE 2-23. LP TANK INSTALLATIONS (FORD AND GM ENGINE MACHINES ONLY)​
FIGURE 2-24. ROTARY COUPLING INSTALLATION​
FIGURE 2-25. GROUND CONTROL BOX ASSEMBLY​
FIGURE 2-26. ELECTRICAL OPTIONS INSTALLATION (TURNTABLE MOUNTED)​
FIGURE 2-27. HOODS INSTALLATION (ABS)​
FIGURE 2-28. HOODS INSTALLATION (STEEL)​
FIGURE 2-29. ENGINE TRAY JACK INSTALLATION (OPTIONAL)​
FIGURE 2-30. 2500W GENERATOR INSTALLATION - DEUTZ D2011 MACHINES (OPTIONAL)​
FIGURE 2-31. 2500W GENERATOR INSTALLATION - DEUTZ TD2.9L4 MACHINES (OPTIONAL)​
FIGURE 2-32. 2500W GENERATOR INSTALLATION - FORD MACHINES (OPTIONAL)​
FIGURE 2-33. 2500W GENERATOR INSTALLATION - GM MACHINES (OPTIONAL)​
FIGURE 2-34. 4000W GENERATOR INSTALLATION - DEUTZ TD2.9L4 ENGINES​
FIGURE 2-35. 4000W GENERATOR INSTALLATION - DEUTZ D2011 ENGINES​
FIGURE 2-36. 4000W GENERATOR INSTALLATION - GM ENGINES​
FIGURE 2-37. 7500W SKYPOWER GENERATOR INSTALLATION - DEUTZ ENGINE MACHINES​
FIGURE 2-38. 7500W SKYPOWER GENERATOR INSTALLATION - FORD ENGINES​
FIGURE 2-39. 7500W SKYPOWER GENERATOR INSTALLATION - GM MACHINES​
FIGURE 2-40. SKYAIR AIR COMPRESSOR INSTALLATION​
FIGURE 2-41. AIR COMPRESSOR ASSEMBLY​
FIGURE 2-42. AUXILIARY PUMP WITHOUT BATTERY DISCONNECT (SN 0300259889 through 0300272376)​
FIGURE 2-43. AUXILIARY PUMP WITH BATTERY DISCONNECT (SN 0300259889 through 0300272376)​
SECTION 3 - BOOM
FIGURE 3-1. BOOM AND CYLINDER INSTALLATION (800A)​
FIGURE 3-2. BOOM AND CYLINDER INSTALLATION (800AJ)​
FIGURE 3-3. TOWER BOOM ASSEMBLY​
FIGURE 3-4. MAIN BOOM ASSEMBLY​
FIGURE 3-5. ROTATOR ASSEMBLY​
FIGURE 3-6. PLATFORM SUPPORT INSTALLATION - WITHOUT LSS​
FIGURE 3-7. PLATFORM SUPPORT INSTALLATION - WITH 4 CELL LSS​
FIGURE 3-8. PLATFORM SUPPORT INSTALLATION - WITH 1 CELL LSS​
FIGURE 3-9. VALVE AND LIMIT SWITCH INSTALLATIONS (BOOM MOUNTED)​
SECTION 4 - PLATFORM
FIGURE 4-1. PLATFORM COMPONENTS INSTALLATION​
FIGURE 4-2. PLATFORM COMPONENTS INSTALLATION (FALL ARREST FOR PLATFORM)​
FIGURE 4-3. PLATFORM CONSOLE ASSEMBLY (WITHOUT SKYGUARD)​
FIGURE 4-4. PLATFORM CONSOLE ASSEMBLY - WITH SKYGUARD​
FIGURE 4-5. CONTROLLER ASSEMBLY - SWING AND LIFT (SN 0300183034 through 0300188905)​
FIGURE 4-6. CONTROLLER ASSEMBLY - SWING AND LIFT (SN 0300188906 through 0300272376)​
FIGURE 4-7. CONTROLLER ASSEMBLY - DRIVE AND STEER (SN 0300183034 through 0300188905)​
FIGURE 4-8. CONTROLLER ASSEMBLY - DRIVE AND STEER (SN 0300188906 through 0300272376)​
FIGURE 4-9. SOFT TOUCH SYSTEM INSTALLATION (OPTIONAL)​
FIGURE 4-10. SKYGUARD SYSTEM INSTALLATION (SN 0300183034 through 0300259888)​
FIGURE 4-11. SKYGUARD SYSTEM INSTALLATION (SN 0300259889 through 0300272376)​
FIGURE 4-12. CROSS RAIL INSTALLATION​
FIGURE 4-13. SKYEYE INSTALLATION​
FIGURE 4-14. SKYGLAZIER INSTALLATION​
FIGURE 4-15. SKYLINE INSTALLATION​
FIGURE 4-16. SKYWELDER/SKYCUTTER COMBO INSTALLATION (60HZ)​
FIGURE 4-17. SKYWELDER INSTALLATION (50HZ)​
FIGURE 4-18. SKYWELDER INSTALLATION (60HZ)​
FIGURE 4-19. SKYWELDER PREP PACKAGE (60HZ)​
FIGURE 4-20. WELDER ASSEMBLY​
FIGURE 4-21. SKYWELDER LOCKING BRACKET INSTALLATION​
FIGURE 4-22. SKYCUTTER INSTALLATION​
FIGURE 4-23. PLASMA CUTTER ASSEMBLY​
FIGURE 4-24. PIPE RACKS INSTALLATION​
FIGURE 4-25. FALL ARREST INSTALLATION (BOLT-ON EXTERNAL) (6FT/1.82M PLATFORM)​
FIGURE 4-26. FALL ARREST INSTALLATION (BOLT-ON EXTERNAL) (6FT/1.82M TRI-ENTRY PLATFORM)​
FIGURE 4-27. FALL ARREST INSTALLATION (BOLT-ON EXTERNAL) (8FT/2.4M PLATFORM)​
FIGURE 4-28. BATTERY DISCONNECT (SN 0300240507 through 0300272376)​
SECTION 5 - CYLINDER
FIGURE 5-1. AXLE LOCKOUT CYLINDER ASSEMBLY​
FIGURE 5-2. LEVEL (SLAVE) CYLINDER ASSEMBLY - JIB (800AJ) (SN 0300183034 through 0300240878)​
FIGURE 5-3. LEVEL (SLAVE) CYLINDER ASSEMBLY - JIB (800AJ) (SN 0300240879 through 0300272376)​
FIGURE 5-4. LEVEL (SLAVE) CYLINDER ASSEMBLY - PLATFORM (800A) (SN 0300183034 through 0300245050)​
FIGURE 5-5. LEVEL (SLAVE) CYLINDER ASSEMBLY - PLATFORM (800A) (SN 0300245051 through 0300272376)​
FIGURE 5-6. LEVEL (SLAVE) CYLINDER ASSEMBLY - UPRIGHT (SN 0300183034 through 0300239885)​
FIGURE 5-7. LEVEL (SLAVE) CYLINDER ASSEMBLY - UPRIGHT (SN 0300239886 through 0300272376)​
FIGURE 5-8. LIFT CYLINDER ASSEMBLY - JIB (800AJ) (SN 0300183034 through 0300245050)​
FIGURE 5-9. LIFT CYLINDER ASSEMBLY - JIB (USAGE MAY VARY) (800AJ) (SN 0300245051 through 0300245146)​
FIGURE 5-10. LIFT CYLINDER ASSEMBLY - JIB (USAGE MAY VARY) (800AJ) (SN 0300245051 through 0300245146)​
FIGURE 5-11. LIFT CYLINDER ASSEMBLY - JIB (800AJ) (SN 0300245147 through 0300272376)​
FIGURE 5-12. LIFT CYLINDER ASSEMBLY - MAIN BOOM (SN 0300183034 through 0300239885)​
FIGURE 5-13. LIFT CYLINDER ASSEMBLY - MAIN BOOM (SN 0300239886 through 0300272376)​
FIGURE 5-14. LIFT CYLINDER ASSEMBLY - TOWER BOOM (SN 0300183034 through 0300239885)​
FIGURE 5-15. LIFT CYLINDER ASSEMBLY - TOWER BOOM (SN 0300239886 through 0300272376)​
FIGURE 5-16. MASTER CYLINDER ASSEMBLY (800A) (SN 0300183034 through 0300245050)​
FIGURE 5-17. MASTER CYLINDER ASSEMBLY (800A) (SN 0300245051 through 0300272376)​
FIGURE 5-18. MASTER CYLINDER ASSEMBLY (800AJ) (SN 0300183034 through 0300243317)​
FIGURE 5-19. MASTER CYLINDER ASSEMBLY (800AJ) (SN 0300243318 through 0300272376)​
FIGURE 5-20. STEER CYLINDER ASSEMBLY​
FIGURE 5-21. TELESCOPE CYLINDER ASSEMBLY - MAIN BOOM​
FIGURE 5-22. TELESCOPE CYLINDER ASSEMBLY - MAIN BOOM (800A) (SN 0300245051 through 0300272376)​
FIGURE 5-23. TELESCOPE CYLINDER ASSEMBLY - MAIN BOOM (800AJ) (SN 0300243318 through 0300272376)​
FIGURE 5-24. TELESCOPE CYLINDER ASSEMBLY - TOWER BOOM​
FIGURE 5-25. TELESCOPE CYLINDER ASSEMBLY - TOWER BOOM (SN 0300243318 through 0300272376)​
SECTION 6 - HYDRAULIC
FIGURE 6-1. AXLE LOCKOUT HYDRAULIC DIAGRAM​
FIGURE 6-2. DRIVE HYDRAULIC DIAGRAM - 2WD (SN 0300183034 through 0300196955)​
FIGURE 6-3. DRIVE HYDRAULIC DIAGRAM - 2WD (SN 0300196956 through 0300272376)​
FIGURE 6-4. DRIVE HYDRAULIC DIAGRAM - 4WD/2WS (SN 0300183034 through 0300196955)​
FIGURE 6-5. DRIVE HYDRAULIC DIAGRAM - 4WD/2WS (SN 0300196956 through 0300272376)​
FIGURE 6-6. STANDARD HYDRAULIC DIAGRAM (SN 0300183034 through 0300194139)​
FIGURE 6-7. STANDARD HYDRAULIC DIAGRAM (SN 0300194140 through 0300196955)​
FIGURE 6-8. STANDARD HYDRAULIC DIAGRAM (SN 0300196956 through 0300272376)​
FIGURE 6-9. HYDRAULIC DIAGRAM LIST​
SECTION 7 - ELECTRICAL
FIGURE 7-1. ELECTRICAL DIAGRAM LIST​
FIGURE 7-2. HARNESS COMPONENTS INSTALLATION​
FIGURE 7-3. SKYEYE INTERMEDIATE HARNESS​
FIGURE 7-4. SKYEYE EMITTER HARNESS​
FIGURE 7-5. SKYEYE RECEIVER HARNESS​
FIGURE 7-6. SKYLINE HARNESS​
SECTION 8 - DECALS
FIGURE 8-1. DECAL INSTALLATION (ANSI SPEC)​
FIGURE 8-2. DECAL INSTALLATION (COUNTRY SPEC)​
FIGURE 8-3. DECAL INSTALLATION (AUSTRALIAN AND CE SPEC)​
SECTION 9 - RECOMMENDED SERVICE PARTS STOCK
FIGURE 9-1. STANDARD PARTS​
FIGURE 9-2. VARIABLE PARTS​
SECTION 10 - SPECIAL OPTIONS
FIGURE 10-1. SPECIAL OPTION​
PART NUMBER INDEX
