Hyundai
86
176,834
JLG Boom Lift 670SJ SELF LEVELING Service & Maintenance Manual 3122340000 2025
Brand: JLG
Type of Machine: Boom Lift
Model: JLG 670SJ SELF LEVELING Boom Lift
Part Number: 3122340000
Publication Date: 2025
Number of Pages: 954 Pages
Cover Page
Effectivity Page
Read This First
Modifications​
Safety
General​
1.1.1 Disclaimer​
Safety Information​
Safety Hazards​
1.3.1 Personal Hazards​
1.3.2 Equipment Hazards​
1.3.3 General Hazards​
1.3.4 Operational Hazards​
Safety Decals​
Machine Verification​
Specifications​
2.1.1 Machine Specifications​
2.1.2 Machine Dimensional Data​
2.1.3 Engine Data​
2.1.4 Tires​
2.1.5 Critical Stability Weights​
2.1.6 Torque Requirements​
Machine Temperature Chart​
Serial Number Location​
Fluids and Lubrication​
2.4.1 General Information​
2.4.2 Hydraulic Oil​
2.4.3 Changing Hydraulic Oil​
2.4.4 Lubrication Specifications​
2.4.5 Fluids​
2.4.6 Capacities​
2.4.7 Lubrication Schedule​
Machine Characteristics​
2.5.1 Ground Control Key Switch System​
2.5.2 Platform Control Enable System​
2.5.3 Hot Weather Operation​
2.5.4 Cold Weather Operation​
2.5.5 Cold Start System Diesel​
2.5.6 Fuel Level Cutout System (Diesel Only)​
2.5.7 Diesel Particulate Filter (If Equipped)​
2.5.8 HRC Engine Emission Characteristics​
2.5.9 Steering Control System​
2.5.10 Drive System​
2.5.11 Drive/Steer - Boom Function Interlock System​
2.5.12 Traction Control System​
2.5.13 Drive Orientation System​
2.5.14 Beyond Stowed Position – Drive Speed Cutback System​
2.5.15 Main Boom End of Stroke Damping​
2.5.16 Stowed Position Sensing System​
2.5.17 Function Speed Control​
2.5.18 Oscillating Axle System​
2.5.19 Electronic Platform Leveling​
2.5.20 Platform Capacity System​
2.5.21 Axle System​
2.5.22 Self Leveling - Auto Level Mode​
2.5.23 Shipping Mode​
2.5.24 Machine Mode Transitions​
2.5.25 Chassis Tilt Indicator System​
2.5.26 Platform Load Sensing System​
2.5.27 Wire Rope Service Indicator System​
2.5.28 Auxiliary Power System​
2.5.29 ClearSky™ System Ready​
2.5.30 Generators​
2.5.31 Cold Weather Package​
2.5.32 Machine Sensors and Switches​
Clearsky Smart Fleet (If Equipped)​
2.6.1 General​
2.6.2 ClearSky Smart Fleet™ — Access Control​
Machine Preparation, Inspection, and Maintenance​
3.1.1 General​
3.1.2 Preparation, Inspection, and Maintenance​
3.1.3 Pre-Start Inspection​
3.1.4 Pre-Delivery Inspection and Frequent Inspection​
3.1.5 Annual Machine Inspection​
3.1.6 Preventive Maintenance​
Service and Guidelines​
3.2.1 General​
3.2.2 Safety and Workmanship​
3.2.3 Cleanliness​
3.2.6 Pressure-Fit Parts​
3.2.7 Bearings​
3.2.8 Gaskets​
3.2.11 Hydraulic System​
3.2.12 Lubrication​
3.2.13 Battery​
3.2.14 Welding on JLG Equipment​
Preventive Maintenance and Inspection Schedule​
3.3.1 First 50 Hours​
3.3.2 Every 150 Hours or 3 Months​
3.3.3 First 300 Hours or 6 Months​
3.3.4 Every 600 Hours​
3.3.5 Every 1000 Hours or 2 Year​
3.3.6 Every 1200 Hours​
Pins and Composite Bearing Repair Guidelines​
Tires and Wheels​
3.5.1 Tire Inflation​
3.5.2 Tire Damage​
Fuel Tank Inspection​
Boom Inspection and Maintenance​
3.7.1 Boom Rope Torquing Procedures​
3.7.2 Wire Rope​
3.7.3 Boom Cleanliness Guidelines​
3.7.4 Boom Wear Pad Inspection​
Hydraulic Filter Replacement​
3.8.1 Hydraulic Filter Removal​
3.8.2 Hydraulic Filter Installation​
Turntable Bearing Inspection​
Engine General Inspection​
3.10.1 General Maintenance​
3.10.2 Glow Plugs​
3.10.3 Replacing Engine Oil​
3.10.4 Replacing the Oil Filter​
3.10.5 Replacing the Primary Fuel Filters​
3.10.6 Replacing the Fuel Pre-Filter For Deutz TD 2.9L4 (T4F)/TD 2.2L3 (Stage V)​
3.10.7 Replacing the Auxiliary Fuel Filter For Deutz D2011L04 T4I (Only)​
3.10.8 Spark Arrester Cleaning Instructions For Deutz D2011L04 T4I (Only)​
3.10.9 Replacing the Fuel Strainer For Deutz D2011L04 T4I (Only)​
Bio Fuel In Deutz Engines​
3.11.1 General​
3.11.2 Bio Fuel​
3.11.3 Biological Contamination In Fuels​
Deutz EMR2​
Deutz EMR4​
Deutz EMR5​
Generator Inspection​
3.15.1 2500W Generator​
3.15.2 4000W Generator​
3.15.3 7500W Generator​
Testing, Calibrations and Special Procedures
Special Tools​
4.1.1 Multimeter Basics​
4.1.2 Threadlocking Compound​
4.1.3 Tools Catalog​
Testing Procedures​
4.2.1 Starter​
4.2.2 SkyGuard​
4.2.3 LSS Testing and Evaluation​
4.2.4 System Test​
Calibration Procedures​
4.3.1 JLG Analyzer​
4.3.2 Calibration Preparation​
4.3.3 Load Sensing System Calibration​
4.3.4 Steer Angle Calibration​
4.3.5 Boom Angle Calibration​
4.3.6 Level Up Crackpoint Calibration​
4.3.7 Level Down Crackpoint Calibration​
4.3.8 Platform Angle Sensor Calibration​
4.3.9 Level Cylinder Length Sensor Calibration​
4.3.10 Calibrating Tilt Sensor​
Special Procedures​
4.4.1 Emergency Lowering Procedure​
4.4.2 Drive Cutout Override Service Mode​
4.4.3 Fuel Tank Cleaning and Drying​
4.4.4 Cylinder Checking Procedure​
4.4.5 Cylinder Drift Test​
4.4.6 Hydraulic Circuits​
4.4.7 Hydraulic Pressure Settings and Adjustments​
4.4.8 Hydraulic Pressures​
4.4.9 Chassis Leveling Test Procedure​
Wheel Drive Hub​
Swing Drive​
System Software
Load Sensing System (LSS)​
5.1.1 Theory of Operation​
5.1.2 Load Sensing Gauge Removal/ Installation​
JLG Analyzer​
5.2.1 Machine Data Access​
5.2.2 Hand Held Analyzer​
5.2.3 Mobile Analyzer​
5.2.4 Analyzer Software Versions P2.28​
Analyzer Software Accessibility​
5.3.1 Access Level​
5.3.2 Diagnostic​
5.3.3 Machine Set-up​
5.3.4 Personalities​
5.3.5 Operator Tools​
5.3.6 Calibrations​
Function Test​
CANBUS Communications​
Service Mode​
5.6.1 Load Sensing System​
5.6.2 Drive Cutout Override​
5.7.1 ClearSky Smart FleetTM CS550 Configuration​
5.7.2 Troubleshooting​
Fault Codes
Fault Codes Introduction​
Engine Diagnostic​
6.2.1 Deutz D2011L04/TD 2.9L4 Engine Trouble Codes​
6.2.2 Deutz TD 2.2L3 Engine Trouble Codes​
Machine Fault Codes​
6.3.1 General​
6.3.2 LSS Troubleshooting​
6.3.3 ClearSky Smart Fleet DTC Fault Codes​
6.3.4 Level Cylinder Length Sensors​
6.3.5 Level Cylinder Pressure Transducers​
6.3.6 Steer Sensors​
6.3.7 Steer Valves​
6.3.8 CAN Communications​
6.3.9 SLC Valves​
6.3.10 Calibration Faults​
6.3.11 Brake Release Valves​
6.3.12 Power System / Software Mismatch Fault Detection​
6.3.13 Turntable Rotary Sensor​
6.3.14 Chassis Enable Valve Faults​
6.3.15 APU Dump Valve Faults​
ClearSky CS550 Troubleshooting Procedures​
Machine Diagnostics Parameters​
Deutz EMR Fault Codes​
6.6.1 EMR2 Fault Codes​
6.6.2 EMR4 Fault Codes​
6.6.3 EMR5 Fault Codes​
Hydraulics
General Information and Safety​
Theories of Operation​
7.2.1 Cylinders​
7.2.2 Valves​
Hydraulic Components​
7.3.1 Hydraulic Oil Tank​
7.3.2 Hydraulic Pump Pre-Fill Procedures​
7.3.3 Self-Leveling System Air Removal Procedure​
7.3.4 Self Leveling Diagnostic Tests​
7.3.5 Pressure Specifications​
Torque Values​
7.4.1 Cylinder Torque Specifications​
7.4.2 Valve Torque Specifications​
Standard Hydraulic Diagram- Boom And Turntable​
Hydraulic Diagram - Chassis​
Electricals
8.1.1 Applying Silicone Dielectric Compound to Electrical Connections​
Electrical Connectors​
8.2.1 Deutsch Connectors​
Electrical Component Terminology​
Harness Layouts​
8.4.1 Frame​
8.4.2 Turntable - 1 of 2​
8.4.3 Turntable- 2 of 2​
8.4.4 Engine TD2.9L4​
8.4.5 Engine D2011L04​
8.4.6 Engine TD2.2L3​
8.4.7 Boom​
8.4.8 Platform​
8.4.9 Controls​
Board Layouts​
8.5.1 Ground Control Module Pin Connections​
8.5.2 Platform Control Module Pin Connections​
8.5.3 Frame Module Pin Connections​
AMP Connector​
8.6.1 Assembly​
8.6.2 Disassembly​
8.6.3 Wedge Lock​
8.6.4 Service - Voltage Reading​
Wiring Harness and Connector Label Diagrams​
8.7.1 Connector Labels​
8.7.2 Component Labels​
Telematics Gateway​
8.8.1 Telematics-Ready (TCU) Plug​
Wheel and Tire​
Chassis/Frame Assembly​
9.2.1 Swing Axle and Drive Assemblies Troubleshooting​
9.2.2 Drive Hub and Motor​
9.2.3 Spindle Assembly​
9.2.4 Front and Rear Axle Assembly​
Boom​
9.3.1 Boom Components Terminology​
9.3.2 Troubleshooting​
9.3.3 Main Boom Powertrack​
9.3.4 Main Boom Assembly​
9.3.5 Boom Sensors​
9.3.6 Jib and Rotator​
Platform​
9.4.1 Platform Support​
9.4.2 Bolt-on External Fall Arrest​
Engine​
9.5.1 Component Terminology​
9.5.2 Engine Serial Number​
9.5.3 Engine Replacement​
9.5.4 Surge Tank (Deutz TD2.9L4 T4F and TD2.2L3 Stage V)​
9.5.5 Pump Coupling Kit​
9.5.6 Air Filter Assembly​
9.5.7 Radiator Assembly​
9.5.8 Thermostat​
9.5.9 Engine Coolant Temperature Sensor​
9.5.10 Relay Assembly​
9.5.11 Starter​
9.5.12 Alternator​
9.5.13 Fuel Tank​
9.5.14 Pre- Fuel Filter and Fuel Supply Pump Assembly​
Transmission​
Hydraulic Cylinders​
9.7.1 Main Boom Lift Cylinder​
9.7.2 Platform Level Cylinder​
9.7.3 Steer Cylinder​
9.7.4 Jib Lift Cylinder​
9.7.5 Chassis Level Cylinder​
Hydraulic Valves​
9.8.1 Platform Valve​
9.8.2 Main Control Valve​
9.8.3 Chassis Valves​
Hydraulic Pumps​
9.9.1 Function Pump Assembly​
9.9.2 Drive Pump Assembly​
Electrical Components​
9.10.1 Battery​
Turntable​
9.11.1 Swing Drive Hub​
9.11.2 Rotary Coupling​
9.11.3 Swing Bearing​
9.11.4 Counterweight​
Generator and Pulley​
9.12.1 4000W Generator - 220V/50Hz (Deutz TD2.2L3 Stage V Engine)​
9.12.2 7500W (SkyPower)/4000W Generator - 110V/60Hz (Deutz TD2.9L4 Engines)​
9.12.3 2500W Generator - 110V/60Hz (Deutz TD2.9L4 Engines)​
9.12.4 7500W SkyPower Generator - 110V/60Hz and 220V/50Hz (Deutz D2011L04 Engines)​
9.12.5 2500W Generator - 110V/60Hz and 220V/ 50Hz (Deutz D2011L04 Engines)​
9.12.6 4000W Generator - 110V/60Hz and 220V/ 50Hz (Deutz D2011L04 Engines)​
9.13.1 ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)​
Disassembly and Assembly
Drive Assembly​
10.1.1 Drive Hub​
10.1.2 Drive Motor​
Boom and Jib Assembly​
10.2.1 Main Boom Assembly​
10.2.2 Rotator Assembly​
Platform​
Engine Components​
10.4.1 Engine Disassembly, Inspection and Service​
10.4.2 Fuel Tank​
Pumps​
10.5.1 Function Pump​
10.5.2 Drive Pump​
10.6.1 Main Lift Cylinder​
10.6.2 Platform Level Cylinder​
10.6.3 Jib Lift Cylinder​
10.6.4 Steer Cylinder​
10.6.5 Chassis Level Cylinder​
10.6.6 Telescope Cylinder​
Hydraulic Valves​
10.8.1 Hydraulic Oil Tank​
Turntable​
10.9.1 Swing Motor​
10.9.2 Rotary Coupling​
10.9.3 Rotary Coupling Seal Kit​
Generator Disassembly and Assembly​
10.10.1 7500W Generator​
10.10.2 4000W Generator​
Powertrack​
10.11.1 Remove Link​
10.11.2 Install New Link​
10.11.3 Replace Fixed End Brackets​
10.11.4 Replace Moving End Brackets​
Torque/Connection Information
Hydraulic Fittings​
11.1.1 Tapered Thread Types​
11.1.2 Straight Thread Types, Tube and Hose Connections​
11.1.3 Straight Thread Types, Port Connections​
11.1.4 Flange Connection Types​
11.1.5 Tightening Methods​
11.1.6 Assembly and Torque Specifications​
11.1.7 General Tube Type Fitting Assembly Instructions​
11.1.8 Assembly Instructions for American Standard Pipe Thread Tapered Connections.​
11.1.9 Assembly Instructions for British Standard Pipe Thread Tapered Connections​
11.1.10 Assembly Instructions for 37° (JIC) Flare Fittings​
11.1.11 Assembly Instructions for 45° SAE Flare Fittings​
11.1.12 Assembly Instructions for O-Ring Face Seal (ORFS) Fittings​
11.1.13 Assembly Instructions for DIN 24° Flare Bite Type Fittings (MBTL and MBTS)​
11.1.14 Assembly Instructions for Bulkhead (BH) Fittings​
11.1.15 Assembly Instructions for O-Ring Boss (ORB) Fittings​
11.1.16 Assembly Instructions for Adjustable Port End Metric Fittings​
11.1.17 Assembly Instructions for Metric ISO 6149 (MPP) Port Assembly Stud Ends​
11.1.18 Assembly instructions for Adjustable Port End (BSPP) Fittings​
11.1.19 Assembly Instructions for Flange Connections: (FL61 and FL62)​
11.1.20 Double Wrench Method​
11.1.21 FFWR and TFFT Methods​
11.1.22 Adjustable Stud End Assembly​
11.1.23 O-ring Installation (Replacement)​
Torque Charts​
11.2.1 SAE Fastener Torque Chart​
11.2.2 Metric Fastener Torque Chart​
Schematics
Hydraulic Schematics​
Electrical Schematics​
12.2.1 Chassis Schematic​
Deutz EMR2 Schematics​
12.3.1 Vehicle Side Connection Diagram​
12.3.2 Engine Side Connection Diagram - Sheet 1 of 2​
12.3.3 Engine Side Connection Diagram - Sheet 2 of 2​
12.3.4 Engine Plug Pin​
12.3.5 Vehicle Plug Pin Identification​
Deutz EMR4 Schematics​
12.4.1 Power Harness​
12.4.2 Equipment Harness​
12.4.3 D2.1 Engine Plug Pin Assignment​
12.4.4 D2.2 Unit Plug Pin Assignment​
Deutz EMR5 Schematics​
12.5.1 Power Harness​
12.5.2 Exhaust After Treatment Harness​
12.5.3 Equipment Harness - Sheet 1 of 5​
12.5.4 Equipment Harness - Sheet 2 of 5​
12.5.5 Equipment Harness - Sheet 3 of 5​
12.5.6 Equipment Harness - Sheet 4 of 5​
12.5.7 Equipment Harness - Sheet 5 of 5​
12.5.8 Engine Plug Pin Identification​
12.5.9 Vehicle Plug Pin Identification​
7500W Generator Schematic​
12.6.1 Troubleshooting Circuit Diagram​
12.6.2 Generator and Controller Circuit Diagram​
12.6.3 Power Board PC1 Circuit Diagram​
12.6.4 Power Board PC2 Electrical Circuit Diagram​
12.6.5 Lead Connection List​
4000W Generator Schematic​
12.7.1 Generator and Controller Circuit Diagram​
12.7.2 Lead Connection List​
