Hyundai
86
176,834
JLG Boom Lift 670SJ SELF LEVELING Parts Manual 31220658
Brand: JLG
Type of Machine: Boom Lift
Model: JLG 670SJ SELF LEVELING Boom Lift
Part Number: 31220658
Publication Date: 2024
Number of Pages: 654 Pages
SECTION 1 - FRAME
FIGURE 1-1. AXLE INSTALLATION​
FIGURE 1-2. STEER INSTALLATION​
FIGURE 1-3. WHEEL DRIVE INSTALLATION​
FIGURE 1-4. DRIVE MOTOR ASSEMBLY​
FIGURE 1-5. DRIVE HUB ASSEMBLY​
FIGURE 1-6. AXLE CONTROL VALVE ASSEMBLY​
FIGURE 1-7. TRACTION VALVE ASSEMBLY​
FIGURE 1-8. TIRE & WHEEL INSTALLATION - IN355-55 D625 FOAM FILLED (AVAILABLE ON ALL SPECS)​
FIGURE 1-9. TIRE & WHEEL INSTALLATION - IN355-55 D625 FOAM FILLED NON-MARKING (AVAILABLE ON ALL SPECS)​
FIGURE 1-10. FRAME COVERS INSTALLATION​
SECTION 2 - TURNTABLE
FIGURE 2-1. VALVE INSTALLATION​
FIGURE 2-2. MAIN CONTROL VALVE ASSEMBLY​
FIGURE 2-3. SWING DRIVE INSTALLATION​
FIGURE 2-4. SWING MOTOR/HUB ASSEMBLY​
FIGURE 2-5. TURNTABLE BEARING AND LUBE INSTALLATION​
FIGURE 2-6. TURNTABLE LOCK INSTALLATION​
FIGURE 2-7. ROTARY COUPLING INSTALLATION (Prior to SN 0300298213)​
FIGURE 2-8. ROTARY COUPLING INSTALLATION (SN 0300298213 to Present)​
FIGURE 2-9. ROTARY COUPLING AND COLLECTOR RING ASSEMBLY​
FIGURE 2-10. TANKS INSTALLATION (WITH HELGESEN HYDRAULIC TANK)​
FIGURE 2-11. TANKS INSTALLATION (WITH JIANGYING HYDRAULIC TANK)​
FIGURE 2-12. HYDRAULIC TANK ASSEMBLY - HELGESEN​
FIGURE 2-13. HYDRAULIC TANK ASSEMBLY - JIANGYING​
FIGURE 2-14. BATTERY AND AUXILIARY PUMP INSTALLATION​
FIGURE 2-15. BATTERY AND AUXILIARY PUMP WITH DISCONNECT SWITCH INSTALLATION​
FIGURE 2-16. GROUND CONTROL ASSEMBLY (DEUTZ D2011 & DEUTZ TD2.9L4 ENGINES)​
FIGURE 2-17. GROUND CONTROL ASSEMBLY (DEUTZ TD2.2L3 ENGINES)​
FIGURE 2-18. KEYSWITCH INSTALLATION (ALL SPECS EXCEPT CE SPECS)​
FIGURE 2-19. KEYSWITCH INSTALLATION (CE SPECS)​
FIGURE 2-20. CONTROLLER COVER INSTALLATION​
FIGURE 2-21. STROBE LIGHT INSTALLATION - AMBER (OPTIONAL) (Prior to SN 0300298213)​
FIGURE 2-22. STROBE LIGHT INSTALLATION - AMBER (OPTIONAL) (SN 0300298213 to Present)​
FIGURE 2-23. STROBE LIGHT INSTALLATION - BLUE (OPTIONAL) (Prior to SN 0300298213)​
FIGURE 2-24. STROBE LIGHT INSTALLATION - BLUE (OPTIONAL) (SN 0300298213 to Present)​
FIGURE 2-25. STROBE LIGHT INSTALLATION - RED (OPTIONAL) (Prior to SN 0300298213)​
FIGURE 2-26. STROBE LIGHT INSTALLATION - RED (OPTIONAL) (SN 0300298213 to Present)​
FIGURE 2-27. NO STOBE LIGHT INSTALLATION​
FIGURE 2-28. WHITE NOISE ALARM INSTALLATION​
FIGURE 2-29. HOODS INSTALLATIONS - ABS (DEUTZ TD2.2L3 - STAGE V ENGINES) (Prior to SN 0300298213)​
FIGURE 2-30. HOODS INSTALLATIONS - ABS (DEUTZ TD2.2L3 - STAGE V ENGINES) (SN 0300298213 to Present)​
FIGURE 2-31. HOODS INSTALLATIONS - ABS (DEUTZ D2011 & DEUTZ TD2.9L4 ENGINES) (Prior to SN 0300298213)​
FIGURE 2-32. HOODS INSTALLATIONS - ABS (DEUTZ D2011 & DEUTZ TD2.9L4 ENGINES) (SN 0300298213 to Present)​
FIGURE 2-33. HOOD ASSEMBLY - ENGINE SIDE (ABS)​
FIGURE 2-34. HOOD ASSEMBLY - TANK SIDE (ABS) (Prior to SN 0300298213)​
FIGURE 2-35. HOOD ASSEMBLY - TANK SIDE (ABS) (SN 0300298213 to Present)​
FIGURE 2-36. HOODS INSTALLATIONS - STEEL (DEUTZ TD2.2L3 - STAGE V ENGINES) (Prior to SN 0300298213)​
FIGURE 2-37. HOODS INSTALLATIONS - STEEL (DEUTZ TD2.2L3 - STAGE V ENGINES) (SN 0300298213 to Present)​
FIGURE 2-38. HOODS INSTALLATIONS - STEEL (DEUTZ D2011 & DEUTZ TD2.9L4 ENGINES) (Prior to SN 0300298213)​
FIGURE 2-39. HOODS INSTALLATIONS - STEEL (DEUTZ D2011 & DEUTZ TD2.9L4 ENGINES) (SN 0300298213 to Present)​
FIGURE 2-40. HOOD ASSEMBLY - ENGINE SIDE (STEEL)​
FIGURE 2-41. HOOD ASSEMBLY - TANK SIDE (STEEL) (Prior to SN 0300298213)​
FIGURE 2-42. HOOD ASSEMBLY - TANK SIDE (STEEL) (SN 0300298213 to Present)​
FIGURE 2-43. NOISE REDUCTION PACKAGE​
FIGURE 2-44. HOOD INSULATION INSTALLATION (AUSTRALIAN SPECS)​
SECTION 3 - ENGINE
FIGURE 3-1. DEUTZ D2011 ENGINE INSTALLATION​
FIGURE 3-2. DEUTZ D2011 ENGINE AND PUMPS SUB-ASSEMBLY​
FIGURE 3-3. DEUTZ D2011 ENGINE ASSEMBLY​
FIGURE 3-4. DEUTZ D2011 ENGINE COMPONENTS​
FIGURE 3-5. DEUTZ TD2.2L3 (STAGE V) ENGINE INSTALLATION​
FIGURE 3-6. DEUTZ TD2.2L3 (STAGE V) ENGINE AND PUMPS SUB-ASSEMBLY​
FIGURE 3-7. DEUTZ TD2.2L3 (STAGE V) ENGINE ASSEMBLY (Prior to SN 0300298213)​
FIGURE 3-8. DEUTZ TD2.2L3 (STAGE V) ENGINE ASSEMBLY (SN 0300298213 to Present)​
FIGURE 3-9. DEUTZ TD2.2L3 (STAGE V) ENGINE COMPONENTS​
FIGURE 3-10. DEUTZ TD2.9L4 ENGINE INSTALLATION​
FIGURE 3-11. DEUTZ TD2.9L4 ENGINE AND PUMPS SUB-ASSEMBLY​
FIGURE 3-12. DEUTZ TD2.9L4 ENGINE ASSEMBLY​
FIGURE 3-13. DEUTZ TD2.9L4 ENGINE COMPONENTS​
FIGURE 3-14. RADIATOR ASSEMBLY - DUETZ D2.2L3 ENGINE​
FIGURE 3-15. PUMP COUPLING KIT (DEUTZ ENGINES)​
FIGURE 3-16. PUMPS ASSEMBLY​
FIGURE 3-17. FUEL FILTER INSTALLATION (OPTIONAL)​
FIGURE 3-18. MUFFLER INSTALLATION - SPARK ARRESTING (DEUTZ D2011 ENGINES)​
FIGURE 3-19. EXHAUST PIPE INSTALLATION - (DEUTZ D2011 ENGINES)​
FIGURE 3-20. MOTOR MOUNT INSTALLATION - WITHOUT GENERATOR (DEUTZ D2011 ENGINES)​
FIGURE 3-21. MOTOR MOUNT INSTALLATION - WITHOUT GENERATOR (DEUTZ TD2.2L3 (STAGE V) ENGINES)​
FIGURE 3-22. MOTOR MOUNT INSTALLATION - WITHOUT GENERATOR (DEUTZ TD2.9L4 - 67HP ENGINES)​
FIGURE 3-23. MOTOR MOUNT INSTALLATION - WITH GENERATOR (DEUTZ D2011 ENGINES)​
FIGURE 3-24. MOTOR MOUNT INSTALLATION - WITH GENERATOR (DEUTZ TD2.9L4 - 67HP ENGINES)​
FIGURE 3-25. MOTOR MOUNT INSTALLATION - WITH GENERATOR (DEUTZ TD2.2L3 (STAGE V) ENGINES)​
FIGURE 3-26. BREATHER HEATER INSTALLATION - DEUTZ TD2.9L4 & TD2.3L3 ENGINES) (OPTIONAL)​
FIGURE 3-27. TRAY JACK INSTALLATION (DEUTZ D2011 & DEUTZ TD2.9L4 ENGINES)​
FIGURE 3-28. TRAY JACK INSTALLATION (DEUTZ TD2.2.L3 ENGINES)​
FIGURE 3-29. ENGINE HOOD BAFFLES INSTALLATION - ABS HOODS (DEUTZ D2011 & DEUTZ TD2.9L4 ENGINES)​
FIGURE 3-30. ENGINE HOOD BAFFLES INSTALLATION - ABS HOODS (DEUTZ D2.2L3 STAGE V ENGINES)​
FIGURE 3-31. ENGINE HOOD BAFFLES INSTALLATION - STEEL HOODS (DEUTZ D2011 & DEUTZ TD2.9L4 ENGINES)​
FIGURE 3-32. ENGINE HOOD BAFFLES INSTALLATION - STEEL HOODS (DEUTZ D2.2L3 STAGE V ENGINES)​
FIGURE 3-33. 2500W GENERATOR INSTALLATION - 110V/60HZ (DEUTZ D2011 ENGINES) (OPTIONAL)​
FIGURE 3-34. 2500W GENERATOR INSTALLATION - 110V/60HZ (DEUTZ TD2.9L4 ENGINES) (OPTIONAL)​
FIGURE 3-35. 2500W GENERATOR INSTALLATION - 220V/50HZ (DEUTZ D2011 ENGINES) (OPTIONAL)​
FIGURE 3-36. 4000W GENERATOR INSTALLATION - 110V/60HZ (DEUTZ D2011 ENGINES) (OPTIONAL)​
FIGURE 3-37. 4000W GENERATOR INSTALLATION - 110V/60HZ (DEUTZ TD2.9L4 ENGINES) (OPTIONAL)​
FIGURE 3-38. 4000W GENERATOR INSTALLATION - 220V/50HZ (DEUTZ D2011 ENGINES) (OPTIONAL)​
FIGURE 3-39. 4000W GENERATOR INSTALLATION - 220V/50HZ (DEUTZ TD2.2L3 (STAGE V) ENGINE) (OPTIONAL)​
FIGURE 3-40. 7500W SKYPOWER GENERATOR INSTALLATION - 110/60HZ (DEUTZ D2011 ENGINES) (OPTIONAL)​
FIGURE 3-41. 7500W SKYPOWER GENERATOR INSTALLATION - 110V/60HZ (DEUTZ TD2.9L4 ENGINES) (OPTIONAL)​
FIGURE 3-42. 7500W SKYPOWER GENERATOR INSTALLATION - 220V/50HZ (DEUTZ D2011 ENGINES) (OPTIONAL)​
FIGURE 3-43. QUICKFIT OIL DRAIN (DEUTZ ENGINES)​
SECTION 4 - BOOM
FIGURE 4-1. BOOM INSTALLATION​
FIGURE 4-2. BOOM ASSEMBLY​
FIGURE 4-3. JIB ASSEMBLY​
FIGURE 4-4. PLATFORM ROTATOR ASSEMBLY​
FIGURE 4-5. POWER TRACK INSTALLATION​
FIGURE 4-6. BOOM VALVES INSTALLATION​
FIGURE 4-7. PLATFORM VALVE ASSEMBLY​
FIGURE 4-8. BOOM SENSORS INSTALLATION​
FIGURE 4-9. PLATFORM SUPPORT INSTALLATION​
SECTION 5 - PLATFORM
FIGURE 5-1. PLATFORM ASSEMBLY - 30IN X 3FT (76CM X .91M) - DROP BAR ENTRY​
FIGURE 5-2. PLATFORM ASSEMBLY - 30IN X 4FT (76CM X 1.22M) WITH SWING GATE​
FIGURE 5-3. PLATFORM ASSEMBLY - 30IN X 4FT (76CM X 1.22M) WITH DROP BAR​
FIGURE 5-4. PLATFORM ASSEMBLY - 30IN X 5FT (76CM X 1.52M) WITH SWING GATE​
FIGURE 5-5. PLATFORM ASSEMBLY - 30IN X 5FT (76CM X 1.52M) WITH DROP BAR​
FIGURE 5-6. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) WITH SWING GATE​
FIGURE 5-7. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) WITH DROP BAR​
FIGURE 5-8. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) TRI-ENTRY WITH SWING GATE​
FIGURE 5-9. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) TRI-ENTRY WITH DROP BAR​
FIGURE 5-10. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH SWING GATE​
FIGURE 5-11. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH DROP BAR​
FIGURE 5-12. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) TRI-ENTRY WITH SWING GATE​
FIGURE 5-13. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) TRI-ENTRY WITH DROP BAR​
FIGURE 5-14. TRAY ASSEMBLY​
FIGURE 5-15. PLATFORM CONSOLE AND FOOTSWITCH INSTALLATION​
FIGURE 5-16. CONSOLE BOX ASSEMBLY​
FIGURE 5-17. DISPLAY INSTALLATION​
FIGURE 5-18. DISPLAY PROTECTION INSTALLATION​
FIGURE 5-19. CONTROLLER ASSEMBLY (DRIVE AND STEER)​
FIGURE 5-20. CONTROLLER ASSEMBLY (LIFT AND SWING)​
FIGURE 5-21. FOOTSWITCH ASSEMBLY​
FIGURE 5-22. SKYEYE INSTALLATION​
FIGURE 5-23. SKYGUARD BAR INSTALLATION​
FIGURE 5-24. SKYLINE INSTALLATION​
FIGURE 5-25. SKYGLAZIER INSTALLATION (ANSI, AUSTRALIAN AND CSA SPECS​
FIGURE 5-26. SKYWELDER INSTALLATION (50HZ)​
FIGURE 5-27. SKYWELDER INSTALLATION (60HZ)​
FIGURE 5-28. SKYWELDER PREP PACKAGE (60HZ)​
FIGURE 5-29. WELDER ASSEMBLY​
FIGURE 5-30. FALL ARREST INSTALLATION (BOLT-ON) (4FT/1.22M PLATFORM)​
FIGURE 5-31. FALL ARREST INSTALLATION (BOLT-ON EXTERNAL) (5FT/1.52M PLATFORM)​
FIGURE 5-32. FALL ARREST INSTALLATION (BOLT-ON EXTERNAL) (6FT/1.82M PLATFORM)​
FIGURE 5-33. FALL ARREST INSTALLATION (BOLT-ON EXTERNAL) (6FT/1.82M TRI-ENTRY PLATFORM)​
FIGURE 5-34. FALL ARREST INSTALLATION (BOLT-ON EXTERNAL) (8FT/2.4M PLATFORM)​
SECTION 6 - CYLINDER
FIGURE 6-1. LEVEL CYLINDER ASSEMBLY - CHASSIS​
FIGURE 6-2. LEVEL CYLINDER ASSEMBLY - PLATFORM SLAVE​
FIGURE 6-3. LIFT CYLINDER ASSEMBLY - BOOM​
FIGURE 6-4. LIFT CYLINDER ASSEMBLY - JIB​
FIGURE 6-5. STEER CYLINDER ASSEMBLY​
FIGURE 6-6. TELESCOPE CYLINDER ASSEMBLY​
SECTION 7 - HYDRAULIC
FIGURE 7-1. HYDRAULIC DIAGRAM - BOOM AND TURNTABLE​
FIGURE 7-2. HYDRAULIC DIAGRAM - CHASSIS​
SECTION 8 - ELECTRICAL
FIGURE 8-1. 670SJ ELECTRICAL LAYOUT​
FIGURE 8-2. ELECTRICAL INSTALLATION (DEUTZ D2011 & DEUTZ DT2.9L4 ENGINES) (Prior to SN 0300298213)​
FIGURE 8-3. ELECTRICAL INSTALLATION (DEUTZ D2011 & DEUTZ DT2.9L4 ENGINES) (SN 0300298213 to Present)​
FIGURE 8-4. ELECTRICAL INSTALLATION (DEUTZ DT2.2L3 - STAGE V ENGINES) (Prior to SN 0300298213)​
FIGURE 8-5. ELECTRICAL INSTALLATION (DEUTZ DT2.2L3 - STAGE V ENGINES) (SN 0300298213 to Present)​
FIGURE 8-6. AC BOX AT PLATFORM INSTALLATION - 110V (ALL SPECS EXCEPT AUSTRALIAN & CE SPECS AND WITHOUT 4000W GENERATOR)​
FIGURE 8-7. AC BOX AT PLATFORM INSTALLATION - 110V IEC YELLOW (CE SPECS WITHOUT 4000W/50HZ GENERATOR)​
FIGURE 8-8. AC BOX AT PLATFORM INSTALLATION - 110V IEC YELLOW (CE SPECS WITH 4000W/50HZ GENERATOR)​
FIGURE 8-9. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE (CE SPECS WITHOUT 4000W/50HZ GENERATOR)​
FIGURE 8-10. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE (CE SPECS WITH 4000W/50HZ GENERATOR)​
FIGURE 8-11. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 2IN X 4IN POST GROUND (CE SPECS WITHOUT 4000W/50HZ GENERATOR)​
FIGURE 8-12. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 2IN X 4IN POST GROUND (CE SPECS WITH 4000W/50HZ GENERATOR)​
FIGURE 8-13. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 2IN X 4IN SIDE GROUND (CE SPECS WITHOUT 4000W/50HZ GENERATOR)​
FIGURE 8-14. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 2IN X 4IN SIDE GROUND (CE SPECS WITH 4000W/50HZ GENERATOR)​
FIGURE 8-15. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT107 (CE SPECS WITHOUT 4000W/50HZ GENERATOR)​
FIGURE 8-16. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT107 (CE SPECS WITH 4000W/50HZ GENERATOR)​
FIGURE 8-17. AC BOX AT PLATFORM INSTALLATION - 220V CUSTOMER SUPPLIED COMPONENTS (ANSI EXPORT, AUSTRALIAN, CE AND CHINA SPECS)​
FIGURE 8-18. AC BOX AT PLATFORM INSTALLATION - 240V (WITH 4000W GENERATOR) (ALL SPECS EXCEPT AUSTRALIAN & CE SPECS)​
FIGURE 8-19. AC BOX AT PLATFORM INSTALLATION - 240V (WITH 7500W SKYPOWER GENERATOR) (ALL SPECS EXCEPT AUSTRALIAN & CE SPECS)​
FIGURE 8-20. AC BREAKER BOX INSTALLATION - SINGLE DOUBLE POLE BREAKER​
FIGURE 8-21. AC BREAKER BOX INSTALLATION - 3 BREAKERS​
FIGURE 8-22. AC CABLES AND CLAMPS INSTALLATION - WITHOUT GENERATOR (ANSI, CSA AND JAPANESE SPECS)​
FIGURE 8-23. AC CABLES AND CLAMPS INSTALLATION - WITHOUT GENERATOR (ANSI EXPORT, AUSTRALIAN & CE SPECS)​
FIGURE 8-24. AC CABLES AND CLAMPS INSTALLATION - WITH 2500W GENERATOR (ALL SPECS EXCEPT AUSTRALIAN & CE SPECS)​
FIGURE 8-25. AC CABLES AND CLAMPS INSTALLATION - WITH 4000W/50HZ GENERATOR (ANSI EXPORT, AUSTRALIAN AND CE SPECS)​
FIGURE 8-26. AC CABLES AND CLAMPS INSTALLATION - WITH 4000W/60HZ GENERATOR (ALL SPECS EXCEPT AUSTRALIAN & CE SPECS)​
FIGURE 8-27. AC CABLES AND CLAMPS INSTALLATION - WITH 7500W SKYPOWER GENERATOR​
FIGURE 8-28. AXLE HARNESS​
FIGURE 8-29. BATTERY DISCONNECT SWITCH INSTALLATION​
FIGURE 8-30. BREAKER BOX KIT - SINGLE DOUBLE POLE BREAKER (WITHOUT 4000W/50HZ GENERATOR)​
FIGURE 8-31. BREAKER BOX KIT - SINGLE DOUBLE POLE BREAKER (WITH 4000W/50HZ GENERATOR)​
FIGURE 8-32. BREAKER BOX KIT - 3 BREAKERS​
FIGURE 8-33. BOOM ANGLE SENSOR HARNESS​
FIGURE 8-34. BOOM CABLE - LOWER​
FIGURE 8-35. BOOM CABLE - UPPER​
FIGURE 8-36. CAPACITY PROXIMITY HARNESS​
FIGURE 8-37. CAPACITY PROXIMITY HARNESS​
FIGURE 8-38. CHASSIS HARNESS​
FIGURE 8-39. CLEARSKY TELEMATICS INSTALLATION - 3 WIRE CONNECTION​
FIGURE 8-40. CLEARSKY TELEMATICS INSTALLATION - CANBUS CONNECTION (ANSI & CSA SPECS)​
FIGURE 8-41. CLEARSKY TELEMATICS INSTALLATION - CANBUS CONNECTION (AUSTRALIAN SPECS)​
FIGURE 8-42. CLEARSKY TELEMATICS INSTALLATION - CANBUS CONNECTION (CE SPECS)​
FIGURE 8-43. CLEARSKY HARNESS​
FIGURE 8-44. ECU POWER JUMPER HARNESS​
FIGURE 8-45. ENGINE HARNESS - DEUTZ D2011 ENGINES​
FIGURE 8-46. ENGINE HARNESS - DEUTZ TD2.2L3 (STAGE V) ENGINE (Prior to SN 0300298213)​
FIGURE 8-47. ENGINE HARNESS - DEUTZ TD2.2L3 (STAGE V) ENGINE (SN 0300298213 to Present)​
FIGURE 8-48. ENGINE HARNESS - DEUTZ D2.9L4 ENGINES​
FIGURE 8-49. FUEL HARNESS - DEUTZ TD2.2L3 (STAGE V) ENGINE​
FIGURE 8-50. FUEL PUMP HARNESS - DEUTZ TD2.9L4 & DEUTZ TD2.2L3 (STAGE V) ENGINES​
FIGURE 8-51. GENERATOR HARNESS - 2500W​
FIGURE 8-52. GENERATOR HARNESS - 4000W​
FIGURE 8-53. GENERATOR HARNESS - 7500W SKYPOWER​
FIGURE 8-54. GENERATOR TO ENGINE HARNESS - 7500W SKYPOWER GENERATOR (DEUTZ D2011 ONLY)​
FIGURE 8-55. GROUND CONTROL HARNESS​
FIGURE 8-56. LIFT CYLINDER HARNESS​
FIGURE 8-57. PLATFORM BOX HARNESS​
FIGURE 8-58. PLATFORM DISPLAY HARNESS​
FIGURE 8-59. RECEPTACLE BOX KIT - 110V IEC YELLOW (CE SPEC)​
FIGURE 8-60. RECEPTACLE BOX KIT - 220V IEC BLUE (CE SPEC)​
FIGURE 8-61. RECEPTACLE BOX KIT - 220V CEE7 POST GROUND 2X4 BOX (CE SPEC)​
FIGURE 8-62. RECEPTACLE BOX KIT - 220V CEE7 SIDE GROUND (CE SPEC)​
FIGURE 8-63. RECEPTACLE BOX KIT - 220V AFSINT 107 (CE SPEC)​
FIGURE 8-64. SKYEYE EMITTER HARNESS​
FIGURE 8-65. SKYEYE INTERMEDIATE HARNESS​
FIGURE 8-66. SKYEYE RECEIVER HARNESS​
FIGURE 8-67. SKYGUARD INTERFACE HARNESS​
FIGURE 8-68. SKYLINE HARNESS​
FIGURE 8-69. STEER HARNESS​
FIGURE 8-70. STROBE LIGHT CONTROL HARNESS​
FIGURE 8-71. TELE PROXIMITY HARNESS​
FIGURE 8-72. TURNTABLE HARNESS (Prior to SN 0300298213)​
FIGURE 8-73. TURNTABLE HARNESS (SN 0300298213 to Present)​
FIGURE 8-74. TURNTABLE AUXILIARY HARNESS​
FIGURE 8-75. VALVE HARNESS - MAIN CONTROL (Prior to SN 0300298213)​
FIGURE 8-76. VALVE HARNESS - MAIN CONTROL (SN 0300298213 to Present)​
FIGURE 8-77. VALVE HARNESS - PLATFORM​
FIGURE 8-78. WHITE NOISE ALARM HARNESS​
SECTION 9 - DECALS
FIGURE 9-1. DECAL INSTALLATION (ANSI SPECS - ENGLISH LANGUAGE)​
FIGURE 9-2. DECAL INSTALLATION (BRAZIL SPECS - PORTUGUESE/SPANISH LANGUAGES)​
FIGURE 9-3. DECAL INSTALLATION (CHINA SPECS - CHINESE/ENGLISH LANGUAGES) (SIMPLIFIED)​
FIGURE 9-4. DECAL INSTALLATION (CHINA SPECS - CHINESE/ENGLISH LANGUAGES) (TRADITIONAL)​
FIGURE 9-5. DECAL INSTALLATION (CSA SPECS - FRENCH/ENGLISH LANGUAGES)​
FIGURE 9-6. DECAL INSTALLATION (JAPANESE SPECS - JAPANESE/ENGLISH LANGUAGES)​
FIGURE 9-7. DECAL INSTALLATION (KOREAN SPECS - KOREAN/ENGLISH LANGUAGES)​
FIGURE 9-8. DECAL INSTALLATION (LATIN AMERICAN SPECS - SPANISH/ENGLISH LANGUAGES)​
FIGURE 9-9. DECAL INSTALLATION (AUSTRALIAN SPECS - ENGLISH LANGUAGE)​
FIGURE 9-10. DECAL INSTALLATION (CE SPECS - ENGLISH LANGUAGE)​
FIGURE 9-11. PLATFORM BOX DECALS INSTALLATION​
FIGURE 9-12. DECALS INSTALLATION - OPTIONS​
FIGURE 9-13. DECAL INSTALLATION - SKYWELDER (50HZ)​
FIGURE 9-14. DECAL INSTALLATION - SKYWELDER (60HZ)​
SECTION 11 - SPECIAL OPTIONS
FIGURE 11-1. SPECIAL OPTIONS​
PART NUMBER INDEX
