JLG Boom Lift 660SJC Service & Maintenance Manual 3122560700 2026
Brand: JLG
Type of Machine: Boom Lift
Model: JLG 660SJC Boom Lift
Part Number: 3122560700
Publication Date: 2026
Number of Pages: 842 Pages
Safety
Brand: JLG
Safety
General
1.1.1 Disclaimer
1.1.2 Operation & Safety Manual
Safety Information
1.2.1 Safety Alert System and Signal Words
Safety Hazards
1.3.1 Personal Hazards
1.3.2 Equipment Hazards
1.3.3 General Hazards
1.3.4 Operational Hazards
Safety Decals
Machine Verification
General Machine Information and SpecificationsSpecifications
2.1.1 Machine Specifications
2.1.2 Machine Dimensional Data
2.1.3 Engine Data
2.1.4 Critical Stability Weights
2.1.5 Torque Requirements
Machine Temperature Chart
Serial Number Location
Fluids and Lubrication
2.4.1 General Information
2.4.2 Hydraulic Oil
2.4.3 Changing Hydraulic Oil
2.4.4 Lubrication Specifications
2.4.5 Fluids
2.4.6 Capacities
2.4.7 Lubrication Schedule
Machine Characteristics
2.5.1 Ground Control Keyswitch System
2.5.2 Platform Control Enable System
2.5.3 Cold Start System (Diesel)
2.5.4 Fuel level Cutout System
2.5.5 HRC Engine Emission Characteristics
2.5.6 Diesel Particulate Filter (If Equipped)
2.5.7 Drive System
2.5.8 Drive Orientation System
2.5.9 Function Speed Control System
2.5.10 Oscillating Axle System
2.5.11 Electronic Platform Leveling
2.5.12 Chassis Tilt Indicator System
2.5.13 Platform Load Sensing System (LSS)
2.5.14 Auxiliary Power System
2.5.15 ClearSky™ System Ready
2.5.16 Platform
2.5.17 Wire Rope Break Indicator
2.5.18 Transport Position Sensing System
2.5.19 Beyond Transport - Drive Speed Cutback System
2.5.20 Transport Position Interlock System (CE/UKCA Only)
2.5.21 Capacity System
2.5.22 Ground Panel Display
Clearsky Smart Fleet (If Equipped)
2.6.1 General
2.6.2 ClearSky Smart Fleet™ — Access Control
Maintenance and Inspection SchedulesMachine Preparation, Inspection, and Maintenance
3.1.1 General
3.1.2 Preparation, Inspection, and Maintenance
3.1.3 Pre-Start Inspection
3.1.4 Pre-Delivery Inspection and Frequent Inspection
3.1.5 Annual Machine Inspection
3.1.6 Preventive Maintenance
Service and Guidelines
3.2.1 General
3.2.2 Safety and Workmanship
3.2.3 Cleanliness
3.2.4 Components Removal and Installation
3.2.5 Component Disassembly and Reassembly
3.2.6 Pressure-Fit Parts
3.2.7 Bearings
3.2.8 Gaskets
3.2.9 Bolt Usage and Torque Application
3.2.10 Hydraulic Lines and Electrical Wiring
3.2.11 Hydraulic System
3.2.12 Lubrication
3.2.13 Battery
3.2.14 Welding on JLG Equipment
Preventive Maintenance and Inspection Schedule
3.3.1 First 50 Hours
3.3.2 Every 150 Hours or 3 Months
3.3.3 First 300 Hours or 6 Months
3.3.4 Every 600 Hours
3.3.5 Every 1000 Hours or 2 Year
3.3.6 Every 1200 Hours
Pins and Composite Bearing Repair Guidelines
Tires and Wheels
Fuel Tank Inspection
Boom Inspection and Maintenance
3.7.1 Boom Rope Torquing Procedures
3.7.2 Wire Rope
3.7.3 Boom Cleanliness Guidelines
3.7.4 Boom Wear Pad Inspection
Hydraulic Filter Replacement
3.8.1 Hydraulic Filter Removal
3.8.2 Hydraulic Filter Installation
Turntable Bearing Inspection
3.9.1 Turntable Bearing Inspection
Engine General Inspection
3.10.1 General Maintenance
3.10.2 Glow Plugs
3.10.3 Replacing Engine Oil
3.10.4 Replacing the Oil Filter
3.10.5 Replacing the Primary Fuel Filters
3.10.6 Replacing the Fuel Pre-Filter for Deutz TD2.9L4 (T4F) and TD2.9L4 (Stage V)
3.10.7 Replacing the Auxiliary Fuel Filter for Deutz D2011L04 T4I (Only)
3.10.8 Spark Arrester Cleaning Instructions for Deutz D2011L04 T4I (Only)
3.10.9 Replacing the Fuel Strainer for Deutz D2011L04 T4I (Only)
Bio Fuel In Deutz Engines
3.11.1 General
3.11.2 Bio Fuel
3.11.3 Biological Contamination In Fuels
Deutz EMR2
Deutz EMR4
Deutz EMR5
Generator Inspection
3.15.1 2500W Generator
3.15.2 4000W Generator
3.15.3 7500W Generator
Testing, Calibrations and Special ProceduresSpecial Tools
4.1.1 Multimeter Basics
4.1.2 Threadlocking Compound
4.1.3 Tools Catalog
Testing Procedures
4.2.1 Starter
4.2.2 SkyGuard
4.2.3 LSS Testing and Evaluation
4.2.4 Testing LSS Control System Warnings and Interlocks:
4.2.5 System Test
Calibration Procedures
4.3.1 JLG Analyzer
4.3.2 Calibration Preparation
4.3.3 Load Sensing System Calibration
4.3.4 Calibrating Tilt Sensor
4.3.5 Calibrating Boom Angle
4.3.6 Calibrating Level Up Crackpoint
4.3.7 Calibrating Level Down Crackpoint
4.3.8 Calibrating Platform Angle Sensor
Special Procedure
4.4.1 Emergency Boom Lowering Procedure
4.4.2 Drive Cutout Override Service Mode
4.4.3 Fuel Tank Cleaning and Drying
4.4.4 Cylinder Checking Procedure
4.4.5 Cylinder Drift
4.4.6 Hydraulic Circuits
4.4.7 Hydraulic Pressure Settings and Adjustments
4.4.8 Hydraulic Pressures
Wheel Drive Hub
Swing Drive
System SoftwareLoad Sensing System (LSS)
5.1.1 Theory of Operation
5.1.2 Load Sensing Gauge Removal/Installation
JLG Analyzer
5.2.1 Machine Data Access
5.2.2 Hand Held Analyzer
5.2.3 Mobile Analyzer
5.2.4 Analyzer Flow Chart
Analyzer Software Accessibility
5.3.1 Access Level
5.3.2 Diagnostic
5.3.3 Machine Set-Up
5.3.4 Personalities
5.3.5 Operator Tools
5.3.6 Calibrations
Function Test
CANBUS Communications
Service Mode
5.6.1 Load Sensing System
5.6.2 Drive Cutout Override
ClearSky (CS550) Configuration and Troubleshooting
5.7.1 ClearSky Smart FleetTM CS550 Configuration
5.7.2 Troubleshooting
Fault CodesFault Codes Introduction
Engine Diagnostic
6.2.1 Deutz TD2.9L4 (T4F) Engine Trouble Codes
6.2.2 Deutz TD2.9L4 (T4F)/(Stage V) Engine Trouble Codes
6.2.3 Deutz D2011L04 (T4I) Engine Trouble Codes
Machine Fault Codes
6.3.1 General
6.3.2 LSS Troubleshooting
6.3.3 ClearSky Smart Fleet DTC Fault Codes
6.3.4 System Test Messages
ClearSky CS550 Troubleshooting Procedures
Machine Diagnostics Parameters
Deutz EMR Fault Codes
6.6.1 EMR2 Fault Codes
6.6.2 EMR4 Fault Codes
6.6.3 EMR5 Fault Codes
HydraulicsGeneral Information and Safety
Theories of Operation
7.2.1 Cylinders
7.2.2 Valves
Hydraulic Components
7.3.1 Hydraulic Oil Tank
7.3.2 Hydraulic Pump Pre-Fill Procedures
7.3.3 Main Valve Block Pressure Setting Procedure
7.3.4 Platform Valve Block Pressure Setting Procedure
Torque Values
7.4.1 Cylinder Torque Specifications
7.4.2 Value Torque Specifications
Standard Hydraulic Diagram- Boom And Turntable
ElectricalsGeneral Information
8.1.1 Applying Silicone Dielectric Compound to Electrical Connections
8.1.2 Dielectric Grease Application
Electrical Connectors
8.2.1 Deutsch Connectors
Electrical Component Terminology
Harness Layouts
8.4.1 Turntable - 1 of 2
8.4.2 Turntable - 2 of 2
8.4.3 Engine TD2.9L4
8.4.4 Engine D2011L04
8.4.5 Boom
8.4.6 Platform
8.4.7 Controls
Board Layouts
8.5.1 Ground Control Module Pin Connections
8.5.2 Platform Control Module Pin Connections
AMP Connector
8.6.1 Assembly
8.6.2 Disassembly
8.6.3 Wedge Lock
8.6.4 Service - Voltage Reading
Wiring Harness and Connector Label Diagrams
8.7.1 Connector Labels
8.7.2 Component Labels
Telematics Gateway
8.8.1 Telematics-Ready (TCU) Plug
Removal and InstallationWheel and Tire
Chassis/Frame Assembly
Boom
9.3.1 Boom Components Terminology
9.3.2 Troubleshooting
9.3.3 Main Boom Powertrack
9.3.4 Main Boom Assembly
9.3.5 Boom Sensors
9.3.6 Jib and Rotator Assembly
Platform
9.4.1 Platform (Rapid Replaceable Platform)
9.4.2 Platform Support (Traditional Design)
9.4.3 Platform Support (Rapid Replaceable Platform)
9.4.4 Bolt-On External Fall Arrest
9.5.1 Component Terminology
9.5.2 Engine Serial Number
9.5.3 Engine Replacement
9.5.4 Surge Tank (Deutz TD2.9L4 T4F/TD2.9L4 Stage V)
9.5.5 Pump Coupling Kit
9.5.6 Air Filter Assembly
9.5.7 Radiator Assembly
9.5.8 Thermostat
9.5.9 Coolant Temperature Sensor
9.5.10 Relay Assembly
9.5.11 Starter
9.5.12 Alternator
9.5.13 Fuel Tank
9.5.14 Pre- Fuel Filter and Fuel Supply Pump Assembly
Hydraulic Cylinders
9.7.1 Main Boom Lift Cylinder
9.7.2 Platform Level Cylinder
9.7.3 Steer Cylinder
9.7.4 Jib Lift Cylinder
9.7.5 Chassis Level Cylinder
Hydraulic Valves
9.8.1 Platform Valve
9.8.2 Main Control Valve
Hydraulic Pumps
9.9.1 Function Pump Assembly
9.9.2 Variable Drive Pump Assembly
Electrical Components
9.10.1 Battery
Turntable
9.11.1 Swing Drive
9.11.2 Rotary Coupling
9.11.3 Swing Bearing
9.11.4 Counterweight
Generator and Pulley
9.12.1 For 7500W and 4000W Generator — Deutz TD2.9L4
9.12.2 For 2500W Generator - Deutz TD2.9L4
ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)
9.13.1 ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)
Disassembly and AssemblyChassis Components and Assembly
10.1.1 Service Notes
10.1.2 Track and Chain
10.1.3 Replace Track
10.1.4 Track tensioning
10.1.5 Rubber Track Pad Installation
10.1.6 Rollers
10.1.7 Idler Roller Assembly
Boom and Jib Assembly
10.2.1 Main Boom Assembly
10.2.2 Rotator Assembly
Platform
Engine Components
10.4.1 Engine Disassembly, Inspection and Service
10.4.2 Fuel Tank
Pumps
10.5.1 Function Pump
10.5.2 Drive Pump
Hydraulic Cylinders
10.6.1 Main Lift Cylinder
10.6.2 Jib Lift Cylinder
10.6.3 Platform Level Cylinder
10.6.4 Telescope Cylinder
Hydraulic Valves
10.8.1 Hydraulic Oil Tank
Turntable
10.9.1 Swing Motor
10.9.2 Rotary Coupling
10.9.3 Rotary Coupling Seal Kit
Generator Disassembly and Assembly
10.10.1 7500W Generator
10.10.2 4000W Generator
Powertrack
10.11.1 Remove Link
10.11.2 Install New Link
10.11.3 Replace Fixed End Brackets
10.11.4 Replace Moving End Brackets
Torque/Connection InformationHydraulic Fittings
11.1.1 Tapered Thread Types
11.1.2 Straight Thread Types, Tube and Hose Connections
11.1.3 Straight Thread Types, Port Connections
11.1.4 Flange Connection Types
11.1.5 Tightening Methods
11.1.6 Assembly and Torque Specifications
11.1.7 General Tube Type Fitting Assembly Instructions
11.1.8 Assembly Instructions for American Standard Pipe Thread Tapered Connections.
11.1.9 Assembly Instructions for British Standard Pipe Thread Tapered Connections
11.1.10 Assembly Instructions for 37° (JIC) Flare Fittings
11.1.11 Assembly Instructions for 45° SAE Flare Fittings
11.1.12 Assembly Instructions for O-Ring Face Seal (ORFS) Fittings
11.1.13 Assembly Instructions for DIN 24° Flare Bite Type Fittings (MBTL and MBTS)
11.1.14 Assembly Instructions for Bulkhead (BH) Fittings
11.1.15 Assembly Instructions for O-Ring Boss (ORB) Fittings
11.1.16 Assembly Instructions for Adjustable Port End Metric Fittings
11.1.17 Assembly Instructions for Metric ISO 6149 (MPP) Port Assembly Stud Ends
11.1.18 Assembly instructions for Adjustable Port End (BSPP) Fittings
11.1.19 Assembly Instructions for Flange Connections: (FL61 and FL62)
11.1.20 Double Wrench Method
11.1.21 FFWR and TFFT Methods
11.1.22 Adjustable Stud End Assembly
11.1.23 O-ring Installation (Replacement)
Torque Charts
11.2.1 SAE Fastener Torque Chart
11.2.2 Metric Fastener Torque Chart
SchematicsHydraulic Schematics
Electrical Schematics
Deutz EMR2 Schematics
12.3.1 Vehicle Side Connection Diagram
12.3.2 Engine Side Connection Diagram - Sheet 1 of 2
12.3.3 Engine Side Connection Diagram - Sheet 2 of 2
12.3.4 Engine Plug Pin
12.3.5 Vehicle Plug Pin Identification
Deutz EMR4 Schematics
12.4.1 Power Harness
12.4.2 Equipment Harness
12.4.3 D2.1 Engine Plug Pin Assignment
12.4.4 D2.2 Unit Plug Pin Assignment
Deutz EMR5 Schematics
12.5.1 Power Harness
12.5.2 Exhaust After Treatment Harness
12.5.3 Equipment Harness - Sheet 1 of 5
12.5.4 Equipment Harness - Sheet 2 of 5
12.5.5 Equipment Harness - Sheet 3 of 5
12.5.6 Equipment Harness - Sheet 4 of 5
12.5.7 Equipment Harness - Sheet 5 of 5
12.5.8 Engine Plug Pin Identification
12.5.9 Vehicle Plug Pin Identification
7500W Generator Schematic
12.6.1 Troubleshooting Circuit Diagram
12.6.2 Generator and Controller Circuit Diagram
12.6.3 Power Board PC1 Circuit Diagram
12.6.4 Power Board PC2 Electrical Circuit Diagram
12.6.5 Lead Connection List
4000W Generator Schematic
12.7.1 Generator and Controller Circuit Diagram
12.7.2 Lead Connection List
- SuperPac Parts Manual
- StratoLift Parts Manual
