Hyundai
86
176,834
JLG Boom Lift 660SJC Parts Manual 3122560800
Brand: JLG
Type of Machine: Boom Lift
Model: JLG 660SJC Boom Lift
Part Number: 3122560800
Publication Date: 2025
Number of Pages: 614 Pages
SECTION 1 - FRAME
FIGURE 1-1. HINOWA FRAME ASSEMBLY (WITH STEEL TRACKS)​
FIGURE 1-2. HINOWA FRAME ASSEMBLY (WITH RUBBER TRACKS)​
FIGURE 1-3. HINOWA FRAME ASSEMBLY (WITH RUBBER PADS)​
SECTION 2 - TURNTABLE
FIGURE 2-1. VALVE INSTALLATION​
FIGURE 2-2. MAIN VALVE ASSEMBLY​
FIGURE 2-3. SWING DRIVE INSTALLATION​
FIGURE 2-4. SWING MOTOR/HUB ASSEMBLY​
FIGURE 2-5. TURNTABLE BEARING AND LUBE INSTALLATION​
FIGURE 2-6. TURNTABLE LOCK INSTALLATION​
FIGURE 2-7. ROTARY COUPLING INSTALLATION​
FIGURE 2-8. TANKS INSTALLATION - DIESEL MACHINES (POLY FUEL TANK) (HELGESEN HYDRAULIC TANK)​
FIGURE 2-9. TANKS INSTALLATION - DIESEL MACHINES (POLY FUEL TANK) (JIANGYING HYDRAULIC TANK)​
FIGURE 2-10. TANKS INSTALLATION - DIESEL MACHINES (STEEL FUEL TANK) (HELGESEN HYDRAULIC TANK)​
FIGURE 2-11. TANKS INSTALLATION - DIESEL MACHINES (STEEL FUEL TANK) (JIANGYING HYDRAULIC TANK)​
FIGURE 2-12. HYDRAULIC TANK ASSEMBLY (HELGESEN HYDRAULIC TANK)​
FIGURE 2-13. HYDRAULIC TANK ASSEMBLY​
FIGURE 2-14. BATTERY AND AUXILIARY PUMP INSTALLATION​
FIGURE 2-15. BATTERY AND AUXILIARY PUMP W/DISCONNECT SWITCH INSTALLATION​
FIGURE 2-16. ELECTRICAL COMPONENTS INSTALLATION​
FIGURE 2-17. ELECTRICAL COMPONENTS INSTALLATION (DEUTZ TD2.9L4 (STAGE V) ENGINES)​
FIGURE 2-18. GROUND CONTROL PANEL ASSEMBLY​
FIGURE 2-19. GROUND CONTROL PANEL ASSEMBLY - WITH DEUTZ TD2.9L4 (STAGE V) ENGINE​
FIGURE 2-20. KEYSWITCH INSTALLATION (ALL SPECS EXCEPT CE & UK CA SPECS)​
FIGURE 2-21. KEYSWITCH INSTALLATION (CE & UK CA SPECS)​
FIGURE 2-22. LIGHT PANEL INSTALLTION​
FIGURE 2-23. STROBE LIGHT INSTALLATION - AMBER (OPTIONAL)​
FIGURE 2-24. STROBE LIGHT INSTALLATION - BLUE (OPTIONAL)​
FIGURE 2-25. STROBE LIGHT INSTALLATION - RED (OPTIONAL)​
FIGURE 2-26. WHITE NOISE ALARM INSTALLATION​
FIGURE 2-27. HOODS INSTALLATIONS - ABS​
FIGURE 2-28. HOOD ASSEMBLY - TANK SIDE (ABS)​
FIGURE 2-29. HOOD ASSEMBLY - ENGINE SIDE (ABS)​
FIGURE 2-30. HOODS INSTALLATIONS - STEEL​
FIGURE 2-31. HOOD ASSEMBLY - TANK SIDE (STEEL)​
FIGURE 2-32. HOOD ASSEMBLY - ENGINE SIDE (STEEL)​
FIGURE 2-33. HOOD INSULATION INSTALLATION (STEEL HOODS)​
FIGURE 2-34. NOISE REDUCTION PACKAGE​
FIGURE 2-35. COVERS INSTALLATION​
SECTION 3 - ENGINE
FIGURE 3-1. DEUTZ D2011 ENGINE INSTALLATION - WITHOUT ARCTIC PACKAGE​
FIGURE 3-2. DEUTZ D2011 ENGINE AND PUMPS SUB-ASSEMBLY - WITHOUT ARCTIC PACKAGE​
FIGURE 3-3. DEUTZ D2011 ENGINE ASSEMBLY - WITHOUT ARCTIC PACKAGE​
FIGURE 3-4. DEUTZ D2011 ENGINE INSTALLATION - WITH ARCTIC PACKAGE​
FIGURE 3-5. DEUTZ TD 2.9L4 (UN R96) ENGINE INSTALLATION - WITH ARCTIC PACKAGE​
FIGURE 3-6. DEUTZ TD 2.9L4 (UN R96) ENGINE AND PUMPS SUB-ASSEMBLY - WITH ARCTIC PACKAGE​
FIGURE 3-7. DEUTZ TD 2.9L4 (UN R96) ENGINE ASSEMBLY - WITH ARCTIC PACKAGE​
FIGURE 3-8. DEUTZ TD 2.9L4 (UN R96) ENGINE INSTALLATION - WITHOUT ARCTIC PACKAGE​
FIGURE 3-9. DEUTZ TD 2.9L4 (UN R96) ENGINE AND PUMPS SUB-ASSEMBLY - WITHOUT ARCTIC PACKAGE​
FIGURE 3-10. DEUTZ TD 2.9L4 (UN R96) ENGINE ASSEMBLY - WITHOUT ARCTIC PACKAGE​
FIGURE 3-11. DEUTZ D2011 ENGINE AND PUMPS SUB-ASSEMBLY - WITH ARCTIC PACKAGE​
FIGURE 3-12. DEUTZ D2011 ENGINE ASSEMBLY - WITH ARCTIC PACKAGE​
FIGURE 3-13. DEUTZ D2011 ENGINE COMPONENTS​
FIGURE 3-14. DEUTZ TD2.9L4 ENGINE COMPONENTS​
FIGURE 3-15. DEUTZ TD2.9L4 ENGINE COMPONENTS (CHINA SPECS ONLY)​
FIGURE 3-16. DEUTZ TD2.9L4 (STAGE V PRE-BUY) ENGINE INSTALLATION​
FIGURE 3-17. DEUTZ TD2.9L4 (STAGE V PRE-BUY) ENGINE AND PUMP SUB-ASSEMBLY​
FIGURE 3-18. DEUTZ TD2.9L4 (STAGE V PRE-BUY) ENGINE ASSEMBLY​
FIGURE 3-19. DEUTZ TD2.9L4 (STAGE V PRE-BUY) ENGINE COMPONENTS​
FIGURE 3-20. DEUTZ TD2.9L4 (STAGE V) ENGINE INSTALLATION​
FIGURE 3-21. DEUTZ TD2.9L4 (STAGE V) ENGINE AND PUMP SUB-ASSEMBLY​
FIGURE 3-22. DEUTZ TD2.9L4 (STAGE V) ENGINE ASSEMBLY​
FIGURE 3-23. DEUTZ TD2.9L4 (STAGE V) ENGINE COMPONENTS​
FIGURE 3-24. DEUTZ D2.9L4 - EMR5 ENGINE INSTALLATION WITH ARCTIC PACKAGE​
FIGURE 3-25. DEUTZ D2.9L4 - EMR5 ENGINE AND PUMPS SUB-ASSEMBLY WITH ARCTIC PACKAGE​
FIGURE 3-26. DEUTZ D2.9L4 - EMR5 ENGINE ASSEMBLY WITH ARCTIC PACKAGE​
FIGURE 3-27. DEUTZ D2.9L4 - EMR5 ENGINE INSTALLATION WITHOUT ARCTIC PACKAGE​
FIGURE 3-28. DEUTZ D2.9L4 - EMR5 ENGINE AND PUMPS SUB-ASSEMBLY WITHOUT ARCTIC PACKAGE​
FIGURE 3-29. DEUTZ D2.9L4 - EMR5 (67HP) ENGINE ASSEMBLY WITHOUT ARCTIC PACKAGE​
FIGURE 3-30. DEUTZ TD2.9L4 EMR5 ENGINE COMPONENTS​
FIGURE 3-31. DEUTZ TD2.9L4 (UN R96) ENGINE COMPONENTS​
FIGURE 3-32. PUMP COUPLING KIT (DEUTZ ENGINES)​
FIGURE 3-33. PISTON PUMP ASSEMBLY- FRONT​
FIGURE 3-34. PISTON PUMP ASSEMBLY- REAR​
FIGURE 3-35. FUEL FILTER INSTALLATION (STEEL FUEL TANK) (DEUTZ D2011 ENGINES)​
FIGURE 3-36. FUEL FILTER INSTALLATION (DEUTZ TD2.9L4 ENGINES)​
FIGURE 3-37. FUEL FILTER ASSEMBLY (DEUTZ TD2.9L4 ENGINES)​
FIGURE 3-38. BREATHER HEATER INSTALLATION - DEUTZ D2.9L4 ENGINE WITH ARCTIC PACKAGE​
FIGURE 3-39. DEUTZ 2.9L4 EXHAUST INSTALLATION (CHINA SPECS ONLY)​
FIGURE 3-40. ENGINE HOOD BAFFLES INSTALLATION - ABS HOODS​
FIGURE 3-41. ENGINE HOOD BAFFLES INSTALLATION - STEEL HOODS​
FIGURE 3-42. TRAY JACK INSTALLATION​
FIGURE 3-43. MOTOR MOUNT INSTALLATION - WITHOUT GENERATOR (DEUTZ D2011 ENGINES)​
FIGURE 3-44. MOTOR MOUNT INSTALLATION - WITH GENERATOR (DEUTZ D2011 ENGINES)​
FIGURE 3-45. MOTOR MOUNT INSTALLATION - WITHOUT GENERATOR (DEUTZ TD2.9L4 ENGINES)​
FIGURE 3-46. MOTOR MOUNT INSTALLATION - WITH GENERATOR (DEUTZ TD2.9L4 ENGINES)​
FIGURE 3-47. MUFFLER INSTALLATION​
FIGURE 3-48. 2500W GENERATOR INSTALLATION - 220V/50HZ (DEUTZ D2011 ENGINES) (OPTIONAL)​
FIGURE 3-49. 2500W GENERATOR INSTALLATION - 110V/60HZ (DEUTZ D2011 ENGINES) (OPTIONAL)​
FIGURE 3-50. 2500W GENERATOR INSTALLATION - 110V/60HZ (DEUTZ TD2.9L4 ENGINES) (OPTIONAL)​
FIGURE 3-51. 4000W GENERATOR INSTALLATION - 220V/50HZ (DEUTZ D2011 ENGINES) (OPTIONAL)​
FIGURE 3-52. 4000W GENERATOR INSTALLATION - 110V/60HZ (DEUTZ D2011 ENGINES) (OPTIONAL)​
FIGURE 3-53. 4000W GENERATOR INSTALLATION - 220V/50HZ (DEUTZ TD2.9L4 ENGINES) (OPTIONAL)​
FIGURE 3-54. 4000W GENERATOR INSTALLATION - 110V/60HZ (DEUTZ TD2.9L4 ENGINES) (OPTIONAL)​
FIGURE 3-55. 7500W SKYPOWER GENERATOR INSTALLATION - 220V/50HZ (DEUTZ D2011 ENGINES) (OPTIONAL)​
FIGURE 3-56. 7500W SKYPOWER GENERATOR INSTALLATION - 110V/60HZ (DEUTZ D2011 ENGINES) (OPTIONAL)​
FIGURE 3-57. 7500W GENERATOR INSTALLATION - 220V/50HZ (DEUTZ TD2.9L4 ENGINES) (OPTIONAL)​
FIGURE 3-58. 7500W SKYPOWER GENERATOR INSTALLATION - 110V/60HZ (DEUTZ TD2.9L4 ENGINES) (OPTIONAL)​
SECTION 4 - BOOM
FIGURE 4-1. BOOM INSTALLATION​
FIGURE 4-2. BOOM ASSEMBLY​
FIGURE 4-3. JIB ASSEMBLY​
FIGURE 4-4. PLATFORM ROTATOR ASSEMBLY​
FIGURE 4-5. POWER TRACK INSTALLATION WITH PLASTIC CLAMP​
FIGURE 4-6. POWER TRACK INSTALLATION WITH STEEL CLAMP​
FIGURE 4-7. BOOM VALVES INSTALLATION (660SJC)​
FIGURE 4-8. PLATFORM VALVE ASSEMBLY​
FIGURE 4-9. BOOM SENSORS INSTALLATION​
FIGURE 4-10. RAPID REPLACEABLE PLATFORM SUPPORT INSTALLATION​
SECTION 5 - PLATFORM
FIGURE 5-1. TRADITIONAL PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH TRI-ENTRY (MACHINES WITH SN STARTING WITH 03)​
FIGURE 5-2. TRADITIONAL PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH TRI-ENTRY (MACHINES WITH SN STARTING WITH B3)​
FIGURE 5-3. RAPID REPLACEABLE PLATFORM (36IN X 6FT (91.5CM X 1.83M) (MACHINES WITH SN STARTING WITH 03)​
FIGURE 5-4. RAPID REPLACEABLE PLATFORM (36IN X 8FT (91.5CM X 2.44M) (MACHINES WITH SN STARTING WITH 03)​
FIGURE 5-5. RAPID REPLACEABLE PLATFORM (36IN X 6FT (91.5CM X 1.83M) (MACHINES WITH SN STARTING WITH B3)​
FIGURE 5-6. RAPID REPLACEABLE PLATFORM (36IN X 8FT (91.5CM X 2.44M) (MACHINES WITH SN STARTING WITH B3)​
FIGURE 5-7. PLATFORM - SWING GATE INSTALLATION (MACHINES WITH SN STARTING WITH 03)​
FIGURE 5-8. PLATFORM - DROP BAR INSTALLATION (MACHINES WITH SN STARTING WITH 03)​
FIGURE 5-9. PLATFORM - SWING GATE INSTALLATION (MACHINES WITH SN STARTING WITH B3)​
FIGURE 5-10. PLATFORM - DROP BAR INSTALLATION (MACHINES WITH SN STARTING WITH B3)​
FIGURE 5-11. JOYSTICK (DRIVE/STEER)​
FIGURE 5-12. TRAY ASSEMBLY​
FIGURE 5-13. PLATFORM CONSOLE AND FOOTSWITCH INSTALLATION​
FIGURE 5-14. CONSOLE BOX ASSEMBLY​
FIGURE 5-15. LIGHT PANEL INSTALLATION​
FIGURE 5-16. FOOTSWITCH ASSEMBLY​
FIGURE 5-17. SKYGLAZIER INSTALLATION (ANSI, AUSTRALIAN AND CSA SPECS)​
FIGURE 5-18. SKYGLAZIER INSTALLATION (CE CA & UK SPECS)​
FIGURE 5-19. SKYLINE INSTALLATION​
FIGURE 5-20. SKYWELDER INSTALLATION (50HZ)​
FIGURE 5-21. SKYWELDER INSTALLATION (60HZ)​
FIGURE 5-22. SKYWELDER PREP PACKAGE (60HZ)​
FIGURE 5-23. USB CHARGER INSTALLATION​
FIGURE 5-24. WELDER ASSEMBLY​
SECTION 6 - CYLINDER
FIGURE 6-1. LEVEL CYLINDER ASSEMBLY - PLATFORM SLAVE​
FIGURE 6-2. LIFT CYLINDER ASSEMBLY - BOOM​
FIGURE 6-3. LIFT CYLINDER ASSEMBLY - JIB​
FIGURE 6-4. TELESCOPE CYLINDER ASSEMBLY (660S & 660SJ STANDARD)​
FIGURE 6-5. VALVE ASSEMBLY - TELESCOPE CYLINDER​
SECTION 7 - HYDRAULIC
FIGURE 7-1. STANDARD HYDRAULIC DIAGRAM​
SECTION 8 - ELECTRICAL
FIGURE 8-1. 660SJC ELECTRICAL LAYOUT​
FIGURE 8-2. AC BOX AT PLATFORM INSTALLATION -110V (ALL SPECS EXCEPT AUSTRALIAN, CE & UK CA SPECS)​
FIGURE 8-3. AC BOX AT PLATFORM INSTALLATION - 240V (WITH 4000W GENERATOR) (ALL SPECS EXCEPT AUSTRALIAN, CE & UK CA SPECS)​
FIGURE 8-4. AC BOX AT PLATFORM INSTALLATION - 240V (WITH 7500WSKYPOWER GENERATOR) (ALL SPECS EXCEPT AUSTRALIAN, CE & UK CA SPECS)​
FIGURE 8-5. AC BOX AT PLATFORM INSTALLATION - 110V IEC YELOW​
FIGURE 8-6. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE​
FIGURE 8-7. AC BOX AT PLATFORM INSTALLATION- 220V CEE7 2IN X 4IN POST GROUND​
FIGURE 8-8. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 2IN X 4IN SIDE GROUND​
FIGURE 8-9. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT107​
FIGURE 8-10. AC BOX AT PLATFORM INSTALLATION - 220V CUSTOMER SUPPLIED COMPONENTS​
FIGURE 8-11. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 POST GROUND (MACHINES WITH SN STARTING WITH 03)​
FIGURE 8-12. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 SIDE GROUND (MACHINES WITH SN STARTING WITH 03)​
FIGURE 8-13. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT107 (CE & UK CA SPECS WITHOUT 4000S/50HZ GENERATOR) (MACHINES WITH SN STARTING WITH 03)​
FIGURE 8-14. AC BOX AT PLATFORM INSTALLATION - 110C IEC YELLOW (CE & UK CA SPECS WITHOUT 4000S/50HZ GENERATOR) (MACHINES WITH SN STARTING WITH 03)​
FIGURE 8-15. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE (CE & UK CA SPECS WITHOUT 4000S/50HZ GENERATOR) (MACHINES WITH SN STARTING WITH 03)​
FIGURE 8-16. AC BREAKER BOX INSTALLATION - SINGLE DOUBLE POLE BREAKER​
FIGURE 8-17. AC BREAKER BOX INSTALLATION - 3 BREAKERS​
FIGURE 8-18. AC CABLES AND CLAMPS INSTALLATION - WITHOUT GENERATOR (ALL SPECS EXCEPT ANSI & CSA SPECS)​
FIGURE 8-19. AC CABLES AND CLAMPS INSTALLATION - WITHOUT GENERATOR (ANSI & CSA SPECS)​
FIGURE 8-20. AC CABLES AND CLAMPS INSTALLATION - WITH 2500W GENERATOR​
FIGURE 8-21. AC CABLES AND CLAMPS INSTALLATION - WITH 4000W-50HZ GENERATOR​
FIGURE 8-22. AC CABLES AND CLAMPS INSTALLATION - WITH 4000W-60HZ GENERATOR​
FIGURE 8-23. AC CABLES AND CLAMPS INSTALLATION - WITH 7500W SKYPOWER GENERATOR​
FIGURE 8-24. BATTERY DISCONNECT SWITCH INSTALLATION​
FIGURE 8-25. BREAKER BOX KIT - SINGLE DOUBLE POLE BREAKER (WITHOUT 4000W/50HZ GENERATOR)​
FIGURE 8-26. BREAKER BOX KIT - SINGLE DOUBLE POLE BREAKER (WITH 4000W/50HZ GENERATOR)​
FIGURE 8-27. BREAKER BOX KIT - 3 BREAKERS​
FIGURE 8-28. BOOM ANGLE SENSOR HARNESS​
FIGURE 8-29. BOOM CABLE - LOWER​
FIGURE 8-30. BOOM CABLE - UPPER (660SJC)​
FIGURE 8-31. CAPACITY PROXIMITY HARNESS​
FIGURE 8-32. CAPACITY PROXIMITY HARNESS​
FIGURE 8-33. CAPACITY PROXIMITY HARNESS (DEUTZ TD2.9L4 (STAGE V) ENGINES)​
FIGURE 8-34. CLEARSKY CS550 - WITH BEACON INSTALLATION (PLASTIC HOOD)​
FIGURE 8-35. CLEARSKY CS550 - WITH BEACON INSTALLATION (METAL HOOD)​
FIGURE 8-36. ECU POWER JUMPER HARNESS​
FIGURE 8-37. ELECTRICAL COMPONENTS INSTALLATION​
FIGURE 8-38. ELECTRICAL COMPONENTS INSTALLATION (DEUTZ TD2.9L4 (STAGE V) ENGINES)​
FIGURE 8-39. ENGINE HARNESS - DEUTZ D2011 ENGINES​
FIGURE 8-40. ENGINE HARNESS - DEUTZ TD2.9L4 ENGINES AND DEUTZ TD2.9L4 (STAGE V PRE-BUY) ENGINES​
FIGURE 8-41. ENGINE HARNESS - DEUTZ TD2.9L4 (STAGE V) ENGINES​
FIGURE 8-42. FUEL PUMP HARNESS - DEUTZ TD2.9L4 ENGINE​
FIGURE 8-43. FUEL HARNESS - DEUTZ TD2.2L4 (STAGE V) ENGINE​
FIGURE 8-44. GENERATOR HARNESS - 2500W​
FIGURE 8-45. GENERATOR HARNESS - 4000W​
FIGURE 8-46. GENERATOR HARNESS - 7500W SKYPOWER​
FIGURE 8-47. GENERATOR TO ENGINE HARNESS - 7500W SKYPOWER GENERATOR (DEUTZ D2011 ONLY)​
FIGURE 8-48. GROUND CONTROL HARNESS​
FIGURE 8-49. HOUR METER JUMPER HARNESS​
FIGURE 8-50. INTERFACE HARNESS - WITH 1 CELL LSS​
FIGURE 8-51. LEFT DRIVE HARNESS​
FIGURE 8-52. LIFT CYLINDER HARNESS​
FIGURE 8-53. MAIN VALVE HARNESS​
FIGURE 8-54. PLATFORM BEACON INSTALLATION​
FIGURE 8-55. PLATFORM BEACON HARNESS​
FIGURE 8-56. PLATFORM CONSOLE HARNESS​
FIGURE 8-57. PLATFORM VALVE HARNESS​
FIGURE 8-58. RECEPTACLE BOX KIT - 110V IEC YELLOW (CE & UK CA SPEC)​
FIGURE 8-59. RECEPTACLE BOX KIT - 220V IEC BLUE (CE & UK CA SPEC)​
FIGURE 8-60. RECEPTACLE BOX KIT - 220V CEE7 POST GROUND 2X4 BOX (CE & UK CA SPEC)​
FIGURE 8-61. RECEPTACLE BOX KIT - 220V CEE7 SIDE GROUND (CE & UK CA SPEC)​
FIGURE 8-62. RECEPTACLE BOX KIT - 220V AFSINT107 (CE & UK CA SPEC)​
FIGURE 8-63. SKYEYE INTERMEDIATE HARNESS​
FIGURE 8-64. SKYEYE EMITTER HARNESS​
FIGURE 8-65. 4. SKYEYE RECEIVER HARNESS​
FIGURE 8-66. SKYLINE HARNESS​
FIGURE 8-67. STROBE LIGHT CONTROL HARNESS​
FIGURE 8-68. STOBE JUMPER HARNESS (RED & BLUE)​
FIGURE 8-69. STROBE JUMPER HARNESS (AMBER)​
FIGURE 8-70. TELE PROXIMITY HARNESS​
FIGURE 8-71. TURNTABLE HARNESS​
FIGURE 8-72. USB HARNESS​
FIGURE 8-73. WHITE NOISE ALARM HARNESS​
FIGURE 8-74. WORKLIGHT HARNESS​
SECTION 9 - DECALS
FIGURE 9-1. DECAL INSTALLATION - 660SJC (ANSI SPECS - ENGLISH LANGUAGE)​
FIGURE 9-2. DECAL INSTALLATION - 660SJC (BRAZIL SPECS - PORTUGUESE/SPANISH LANGUAGES)​
FIGURE 9-3. DECAL INSTALLATION - 660SJC (CE & UK CA SPECS - ENGLISH LANGUAGE)​
FIGURE 9-4. DECAL INSTALLATION - 660SJC (CHINESE SPECS - ENGLISH/SIMPLIFIED CHINESE LANGUAGES)​
FIGURE 9-5. DECAL INSTALLATION - 660SJC (CHINESE SPECS - ENGLISH/TRADITIONAL CHINESE LANGUAGES)​
FIGURE 9-6. DECAL INSTALLATION - 660SJC (CSA SPECS - ENGLISH/FRENCH LANGUAGES)​
FIGURE 9-7. DECAL INSTALLATION - 660SJC (JAPANESE SPECS - ENGLISH/JAPANESE LANGUAGES)​
FIGURE 9-8. DECAL INSTALLATION - 660SJC (KOREAN SPECS - ENGLISH/KOREAN LANGUAGES)​
FIGURE 9-9. DECAL INSTALLATION - 660SJC (LATIN AMERICA SPECS - ENGLISH/SPANISH LANGUAGES)​
FIGURE 9-10. DECAL INSTALLATION - OPTIONS​
FIGURE 9-11. SKYWELDER DECAL INSTALLATION - 50HZ (AUSTRALIAN, CE & UK CA SPECS)​
FIGURE 9-12. SKYWELDER DECAL INSTALLATION - 60HZ (ALL SPECS EXCEPT AUSTRALIAN, CE & UK CA SPECS)​
SECTION 11 - SPECIAL OPTIONS/ACCESSORIES/KITS
PART NUMBER INDEX
