JLG Boom Lift 660SJC Parts Catalog 3122339800
Brand: JLG
Type of Machine: Boom Lift
Model: JLG 660SJC Boom Lift
Part Number: 3122339800
Publication Date: 2025
Number of Pages: 718 Pages
SECTION 1 - FRAME
Brand: JLG
SECTION 1 - FRAME
FIGURE 1-1. HINOWA FRAME ASSEMBLY (WITH STEEL TRACKS)
FIGURE 1-2. HINOWA FRAME ASSEMBLY (WITH RUBBER TRACKS)
FIGURE 1-3. HINOWA FRAME ASSEMBLY (WITH RUBBER PADS)
SECTION 2 - TURNTABLEFIGURE 2-1. VALVE INSTALLATION (Prior to SN 0300332801)
FIGURE 2-2. VALVE INSTALLATION (SN 0300332802 to Present)
FIGURE 2-3. MAIN VALVE ASSEMBLY
FIGURE 2-4. SWING DRIVE INSTALLATION
FIGURE 2-5. SWING MOTOR/HUB ASSEMBLY
FIGURE 2-6. TURNTABLE BEARING AND LUBE INSTALLATION
FIGURE 2-7. TURNTABLE LOCK INSTALLATION
FIGURE 2-8. ROTARY COUPLING INSTALLATION
FIGURE 2-9. TANKS INSTALLATION - DIESEL MACHINES (POLY FUEL TANK) (HELGESEN HYDRAULIC TANK)
FIGURE 2-10. TANKS INSTALLATION - DIESEL MACHINES (POLY FUEL TANK) (JIANGYING HYDRAULIC TANK)
FIGURE 2-11. TANKS INSTALLATION - DIESEL MACHINES (STEEL FUEL TANK) (HELGESEN HYDRAULIC TANK)
FIGURE 2-12. TANKS INSTALLATION - DIESEL MACHINES (STEEL FUEL TANK) (JIANGYING HYDRAULIC TANK)
FIGURE 2-13. HYDRAULIC TANK ASSEMBLY (HELGESEN HYDRAULIC TANK)
FIGURE 2-14. HYDRAULIC TANK ASSEMBLY
FIGURE 2-15. BATTERY AND AUXILIARY PUMP INSTALLATION
FIGURE 2-16. BATTERY AND AUXILIARY PUMP W/DISCONNECT SWITCH INSTALLATION
FIGURE 2-17. ELECTRICAL COMPONENTS INSTALLATION
FIGURE 2-18. ELECTRICAL COMPONENTS INSTALLATION (DEUTZ TD2.9L4 (STAGE V) ENGINES)
FIGURE 2-19. GROUND CONTROL PANEL ASSEMBLY
FIGURE 2-20. GROUND CONTROL PANEL ASSEMBLY - WITH DEUTZ TD2.9L4 (STAGE V) ENGINE
FIGURE 2-21. KEYSWITCH INSTALLATION (ALL SPECS EXCEPT CE & UK CA SPECS)
FIGURE 2-22. KEYSWITCH INSTALLATION (CE & UK CA SPECS)
FIGURE 2-23. LIGHT PANEL INSTALLTION
FIGURE 2-24. STROBE LIGHT INSTALLATION - AMBER (OPTIONAL)
FIGURE 2-25. STROBE LIGHT INSTALLATION - BLUE (OPTIONAL)
FIGURE 2-26. STROBE LIGHT INSTALLATION - RED (OPTIONAL)
FIGURE 2-27. WHITE NOISE ALARM INSTALLATION
FIGURE 2-28. HOODS INSTALLATIONS - ABS
FIGURE 2-29. HOOD ASSEMBLY - TANK SIDE (ABS)
FIGURE 2-30. HOOD ASSEMBLY - ENGINE SIDE (ABS)
FIGURE 2-31. HOODS INSTALLATIONS - STEEL
FIGURE 2-32. HOOD ASSEMBLY - TANK SIDE (STEEL)
FIGURE 2-33. HOOD ASSEMBLY - ENGINE SIDE (STEEL)
FIGURE 2-34. HOOD INSULATION INSTALLATION (STEEL HOODS)
FIGURE 2-35. HOOD PLUG INSTALLATION (NO BEACON)
FIGURE 2-36. NOISE REDUCTION PACKAGE
FIGURE 2-37. COVERS INSTALLATION
SECTION 3 - ENGINEFIGURE 3-1. DEUTZ D2011 ENGINE INSTALLATION - WITHOUT ARCTIC PACKAGE
FIGURE 3-2. DEUTZ D2011 ENGINE AND PUMPS SUB-ASSEMBLY - WITHOUT ARCTIC PACKAGE
FIGURE 3-3. DEUTZ D2011 ENGINE ASSEMBLY - WITHOUT ARCTIC PACKAGE
FIGURE 3-4. DEUTZ D2011 ENGINE INSTALLATION - WITH ARCTIC PACKAGE
FIGURE 3-5. DEUTZ TD 2.9L4 (UN R96) ENGINE INSTALLATION - WITH ARCTIC PACKAGE
FIGURE 3-6. DEUTZ TD 2.9L4 (UN R96) ENGINE AND PUMPS SUB-ASSEMBLY - WITH ARCTIC PACKAGE
FIGURE 3-7. DEUTZ TD 2.9L4 (UN R96) ENGINE ASSEMBLY - WITH ARCTIC PACKAGE
FIGURE 3-8. DEUTZ TD 2.9L4 (UN R96) ENGINE INSTALLATION - WITHOUT ARCTIC PACKAGE
FIGURE 3-9. DEUTZ TD 2.9L4 (UN R96) ENGINE AND PUMPS SUB-ASSEMBLY - WITHOUT ARCTIC PACKAGE
FIGURE 3-10. DEUTZ TD 2.9L4 (UN R96) ENGINE ASSEMBLY - WITHOUT ARCTIC PACKAGE
FIGURE 3-11. DEUTZ D2011 ENGINE AND PUMPS SUB-ASSEMBLY - WITH ARCTIC PACKAGE
FIGURE 3-12. DEUTZ D2011 ENGINE ASSEMBLY - WITH ARCTIC PACKAGE
FIGURE 3-13. DEUTZ D2011 ENGINE COMPONENTS
FIGURE 3-14. DEUTZ TD2.9L4 ENGINE COMPONENTS
FIGURE 3-15. DEUTZ TD2.9L4 ENGINE COMPONENTS (CHINA SPECS ONLY)
FIGURE 3-16. DEUTZ TD2.9L4 (STAGE V PRE-BUY) ENGINE INSTALLATION
FIGURE 3-17. DEUTZ TD2.9L4 (STAGE V PRE-BUY) ENGINE AND PUMP SUB-ASSEMBLY
FIGURE 3-18. DEUTZ TD2.9L4 (STAGE V PRE-BUY) ENGINE ASSEMBLY
FIGURE 3-19. DEUTZ TD2.9L4 (STAGE V PRE-BUY) ENGINE COMPONENTS
FIGURE 3-20. DEUTZ TD2.9L4 (STAGE V) ENGINE INSTALLATION
FIGURE 3-21. DEUTZ TD2.9L4 (STAGE V) ENGINE AND PUMP SUB-ASSEMBLY
FIGURE 3-22. DEUTZ TD2.9L4 (STAGE V) ENGINE ASSEMBLY
FIGURE 3-23. DEUTZ TD2.9L4 (STAGE V) ENGINE COMPONENTS
FIGURE 3-24. DEUTZ D2.9L4 - EMR5 ENGINE INSTALLATION WITH ARCTIC PACKAGE
FIGURE 3-25. DEUTZ D2.9L4 - EMR5 ENGINE AND PUMPS SUB-ASSEMBLY WITH ARCTIC PACKAGE
FIGURE 3-26. DEUTZ D2.9L4 - EMR5 ENGINE ASSEMBLY WITH ARCTIC PACKAGE
FIGURE 3-27. DEUTZ D2.9L4 - EMR5 ENGINE INSTALLATION WITHOUT ARCTIC PACKAGE
FIGURE 3-28. DEUTZ D2.9L4 - EMR5 ENGINE AND PUMPS SUB-ASSEMBLY WITHOUT ARCTIC PACKAGE
FIGURE 3-29. DEUTZ D2.9L4 - EMR5 (67HP) ENGINE ASSEMBLY WITHOUT ARCTIC PACKAGE
FIGURE 3-30. DEUTZ TD2.9L4 EMR5 ENGINE COMPONENTS
FIGURE 3-31. DEUTZ TD2.9L4 (UN R96) ENGINE COMPONENTS
FIGURE 3-32. PUMP COUPLING KIT (DEUTZ ENGINES)
FIGURE 3-33. PISTON PUMP ASSEMBLY- FRONT
FIGURE 3-34. PISTON PUMP ASSEMBLY- REAR
FIGURE 3-35. FUEL FILTER INSTALLATION (STEEL FUEL TANK) (DEUTZ D2011 ENGINES)
FIGURE 3-36. FUEL FILTER INSTALLATION (DEUTZ TD2.9L4 ENGINES)
FIGURE 3-37. FUEL FILTER ASSEMBLY (DEUTZ TD2.9L4 ENGINES)
FIGURE 3-38. BREATHER HEATER INSTALLATION - DEUTZ D2.9L4 ENGINE WITH ARCTIC PACKAGE
FIGURE 3-39. DEUTZ 2.9L4 EXHAUST INSTALLATION (CHINA SPECS ONLY)
FIGURE 3-40. ENGINE HOOD BAFFLES INSTALLATION - ABS HOODS
FIGURE 3-41. ENGINE HOOD BAFFLES INSTALLATION - STEEL HOODS
FIGURE 3-42. TRAY JACK INSTALLATION
FIGURE 3-43. MOTOR MOUNT INSTALLATION - WITHOUT GENERATOR (DEUTZ D2011 ENGINES)
FIGURE 3-44. MOTOR MOUNT INSTALLATION - WITH GENERATOR (DEUTZ D2011 ENGINES)
FIGURE 3-45. MOTOR MOUNT INSTALLATION - WITHOUT GENERATOR (DEUTZ TD2.9L4 ENGINES)
FIGURE 3-46. MOTOR MOUNT INSTALLATION - WITH GENERATOR (DEUTZ TD2.9L4 ENGINES)
FIGURE 3-47. MUFFLER INSTALLATION
FIGURE 3-48. 2500W GENERATOR INSTALLATION - 220V/50HZ (DEUTZ D2011 ENGINES) (OPTIONAL)
FIGURE 3-49. 2500W GENERATOR INSTALLATION - 110V/60HZ (DEUTZ D2011 ENGINES) (OPTIONAL)
FIGURE 3-50. 2500W GENERATOR INSTALLATION - 110V/60HZ (DEUTZ TD2.9L4 ENGINES) (OPTIONAL)
FIGURE 3-51. 4000W GENERATOR INSTALLATION - 220V/50HZ (DEUTZ D2011 ENGINES) (OPTIONAL)
FIGURE 3-52. 4000W GENERATOR INSTALLATION - 110V/60HZ (DEUTZ D2011 ENGINES) (OPTIONAL) (Prior to SN 0300332801)
FIGURE 3-53. 4000W GENERATOR INSTALLATION - 110V/60HZ (DEUTZ D2011 ENGINES) (OPTIONAL) (SN 0300332802 to Present)
FIGURE 3-54. 4000W GENERATOR INSTALLATION - 220V/50HZ (DEUTZ TD2.9L4 ENGINES) (OPTIONAL)
FIGURE 3-55. 4000W GENERATOR INSTALLATION - 110V/60HZ (DEUTZ TD2.9L4 ENGINES) (OPTIONAL) (Prior to SN 0300332801)
FIGURE 3-56. 4000W GENERATOR INSTALLATION - 110V/60HZ (DEUTZ TD2.9L4 ENGINES) (OPTIONAL) (SN 0300332802 to Present)
FIGURE 3-57. 7500W SKYPOWER GENERATOR INSTALLATION - 220V/50HZ (DEUTZ D2011 ENGINES) (OPTIONAL) (Prior to SN 0300332801)
FIGURE 3-58. 7500W SKYPOWER GENERATOR INSTALLATION - 220V/50HZ (DEUTZ D2011 ENGINES) (OPTIONAL) (SN 0300332802 to Present)
FIGURE 3-59. 7500W SKYPOWER GENERATOR INSTALLATION - 110V/60HZ (DEUTZ D2011 ENGINES) (OPTIONAL) (Prior to SN 0300332801)
FIGURE 3-60. 7500W SKYPOWER GENERATOR INSTALLATION - 110V/60HZ (DEUTZ D2011 ENGINES) (OPTIONAL) (SN 0300332802 to Present)
FIGURE 3-61. 7500W GENERATOR INSTALLATION - 220V/50HZ (DEUTZ TD2.9L4 ENGINES) (OPTIONAL) (Prior to SN 0300332801)
FIGURE 3-62. 7500W GENERATOR INSTALLATION - 220V/50HZ (DEUTZ TD2.9L4 ENGINES) (OPTIONAL) (SN 0300332802 to Present)
FIGURE 3-63. 7500W SKYPOWER GENERATOR INSTALLATION - 110V/60HZ (DEUTZ TD2.9L4 ENGINES) (OPTIONAL) (Prior to SN 0300332801)
FIGURE 3-64. 7500W SKYPOWER GENERATOR INSTALLATION - 110V/60HZ (DEUTZ TD2.9L4 ENGINES) (OPTIONAL) (SN 0300332802 to Present)
SECTION 4 - BOOMFIGURE 4-1. BOOM INSTALLATION
FIGURE 4-2. BOOM ASSEMBLY
FIGURE 4-3. JIB ASSEMBLY
FIGURE 4-4. PLATFORM ROTATOR ASSEMBLY
FIGURE 4-5. POWER TRACK INSTALLATION WITH PLASTIC CLAMP
FIGURE 4-6. POWER TRACK INSTALLATION WITH STEEL CLAMP
FIGURE 4-7. BOOM VALVES INSTALLATION (660SJC) (Prior to SN 0300332801)
FIGURE 4-8. BOOM VALVES INSTALLATION (660SJC) (SN 0300332802 to Present)
FIGURE 4-9. PLATFORM VALVE ASSEMBLY
FIGURE 4-10. BOOM SENSORS INSTALLATION
FIGURE 4-11. PLATFORM SUPPORT INSTALLATION - WITH LSS (Prior to SN 0300328321)
FIGURE 4-12. TRADITIONAL PLATFORM SUPPORT INSTALLATION (SN 0300328322 through 0300332801)
FIGURE 4-13. RAPID REPLACEABLE PLATFORM INSTALLATION (SN 0300332802 to Present)
SECTION 5 - PLATFORMFIGURE 5-1. TRADITIONAL PLATFORM ASSEMBLY - 30IN X 3FT (76CM X .91M) - DROP BAR ENTRY (Prior to SN 0300332801)
FIGURE 5-2. TRADITIONAL PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) WITH SWING GATE (Prior to SN 0300332801)
FIGURE 5-3. TRADITIONAL PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) WITH DROP BAR (Prior to SN 0300332801)
FIGURE 5-4. TRADITIONAL PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) TRI-ENTRY WITH SWING GATE (Prior to SN 0300332801)
FIGURE 5-5. TRADITIONAL PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) TRI-ENTRY WITH DROPBAR (Prior to SN 0300332801)
FIGURE 5-6. TRADITIONAL PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) TRI-ENTRY WITH DROPBAR (Prior to SN 0300332801)
FIGURE 5-7. TRADITIONAL PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) TRI-ENTRY WITH DROPGATE (Prior to SN 0300332801)
FIGURE 5-8. TRADITIONAL PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH SWING GATE (Prior to SN 0300332801)
FIGURE 5-9. TRADITIONAL PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH DROP BAR (Prior to SN 0300332801)
FIGURE 5-10. TRADITIONAL PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) WITH FALL ARREST
FIGURE 5-11. TRADITIONAL PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH FALL ARREST (SN 0300332802 to Present)
FIGURE 5-12. TRADITIONAL PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH TRI-ENTRY (SN 0300332802 to Present)
FIGURE 5-13. RAPID REPLACEABLE PLATFORM (36IN X 6FT (91.5CM X 1.83M)
FIGURE 5-14. RAPID REPLACEABLE PLATFORM (36IN X 8FT (91.5CM X 2.44M)
FIGURE 5-15. PLATFORM - SWING GATE INSTALLATION
FIGURE 5-16. PLATFORM - DROP BAR INSTALLATION
FIGURE 5-17. JOYSTICK (DRIVE/STEER)
FIGURE 5-18. TRAY ASSEMBLY
FIGURE 5-19. PLATFORM CONSOLE AND FOOTSWITCH INSTALLATION (Prior to SN 0300331058)
FIGURE 5-20. PLATFORM CONSOLE AND FOOTSWITCH INSTALLATION (SN 0300331059 to Present)
FIGURE 5-21. CONSOLE BOX ASSEMBLY (Prior to SN 0300330746)
FIGURE 5-22. CONSOLE BOX ASSEMBLY (SN 0300330747 through 0300331058)
FIGURE 5-23. CONSOLE BOX ASSEMBLY (SN 0300331059 to Present)
FIGURE 5-24. LIGHT PANEL INSTALLATION
FIGURE 5-25. FOOTSWITCH ASSEMBLY
FIGURE 5-26. SKYGLAZIER INSTALLATION (ANSI, AUSTRALIAN AND CSA SPECS)
FIGURE 5-27. SKYGLAZIER INSTALLATION (CE CA & UK SPECS)
FIGURE 5-28. SKYLINE INSTALLATION (Prior to SN 0300332801)
FIGURE 5-29. SKYLINE INSTALLATION (SN 0300332802 to Present)
FIGURE 5-30. SKYWELDER INSTALLATION (50HZ)
FIGURE 5-31. SKYWELDER INSTALLATION (60HZ)
FIGURE 5-32. SKYWELDER PREP PACKAGE (60HZ)
FIGURE 5-33. USB CHARGER INSTALLATION (Prior to SN 0300332801)
FIGURE 5-34. USB CHARGER INSTALLATION (SN 0300332802 to Present)
FIGURE 5-35. WELDER ASSEMBLY
SECTION 6 - CYLINDERFIGURE 6-1. LEVEL CYLINDER ASSEMBLY - PLATFORM SLAVE
FIGURE 6-2. LIFT CYLINDER ASSEMBLY - BOOM
FIGURE 6-3. LIFT CYLINDER ASSEMBLY - JIB
FIGURE 6-4. TELESCOPE CYLINDER ASSEMBLY (660S & 660SJ STANDARD)
FIGURE 6-5. VALVE ASSEMBLY - TELESCOPE CYLINDER
SECTION 7 - HYDRAULICFIGURE 7-1. STANDARD HYDRAULIC DIAGRAM
SECTION 8 - ELECTRICALFIGURE 8-1. 660SJC ELECTRICAL LAYOUT
FIGURE 8-2. AC BOX AT PLATFORM INSTALLATION -110V (ALL SPECS EXCEPT AUSTRALIAN, CE & UK CA SPECS)
FIGURE 8-3. AC BOX AT PLATFORM INSTALLATION - 110V IEC YELLOW (CE & UK CA SPECS WITHOUT 4000W/50HZ GENERATOR) (Prior to SN 0300330557)
FIGURE 8-4. AC BOX AT PLATFORM INSTALLATION - 110V IEC YELLOW (CE & UK CA SPECS WITH 4000W/50HZ GENERATOR) (Prior to SN 0300330557)
FIGURE 8-5. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE (CE & UK CA SPECS WITHOUT 4000W/50HZ GENERATOR) (Prior to SN 0300330557)
FIGURE 8-6. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE (CE & UK CA SPECS WITH 4000W/50HZ GENERATOR) (Prior to SN 0300330557)
FIGURE 8-7. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 2IN X 4IN POST GROUND (CE & UK CA SPECS WITHOUT 4000W/50HZ GENERATOR) (Prior to SN 0300330557)
FIGURE 8-8. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 2IN X 4IN POST GROUND (CE & UK CA SPECS WITH 4000W/50HZ GENERATOR) (Prior to SN 0300330557)
FIGURE 8-9. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 2IN X 4IN SIDE GROUND (CE & UK CA SPECS WITHOUT 4000W/50HZ GENERATOR) (Prior to SN 0300330557)
FIGURE 8-10. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 2IN X 4IN SIDE GROUND (CE & UK CA SPECS WITH 4000W/50HZ GENERATOR) (Prior to SN 0300330557)
FIGURE 8-11. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT107 (CE & UK CA SPECS WITHOUT 4000W/50HZ GENERATOR) (Prior to SN 0300330557)
FIGURE 8-12. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT107 (CE & UK CA SPECS WITH 4000W/50HZ GENERATOR) (Prior to SN 0300330557)
FIGURE 8-13. AC BOX AT PLATFORM INSTALLATION - 220V CUSTOMER SUPPLIED COMPONENTS (ANSI EXPORT, AUSTRALIAN, CHINA, CE & UK CA SPECS) (Prior to SN 0300330557)
FIGURE 8-14. AC BOX AT PLATFORM INSTALLATION - 240V (WITH 4000W GENERATOR) (ALL SPECS EXCEPT AUSTRALIAN, CE & UK CA SPECS)
FIGURE 8-15. AC BOX AT PLATFORM INSTALLATION - 240V (WITH 7500WSKYPOWER GENERATOR) (ALL SPECS EXCEPT AUSTRALIAN, CE & UK CA SPECS)
FIGURE 8-16. AC BOX AT PLATFORM INSTALLATION - 110V IEC YELOW (SN 0300330558 to Present)
FIGURE 8-17. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE (SN 0300330558 to Present)
FIGURE 8-18. AC BOX AT PLATFORM INSTALLATION- 220V CEE7 2IN X 4IN POST GROUND (SN 0300330558 to Present)
FIGURE 8-19. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 2IN X 4IN SIDE GROUND (SN 0300330558 to Present)
FIGURE 8-20. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT107 (SN 0300330558 to Present)
FIGURE 8-21. AC BOX AT PLATFORM INSTALLATION - 220V CUSTOMER SUPPLIED COMPONENTS (SN 0300330558 to Present)
FIGURE 8-22. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 POST GROUND (MACHINES WITH SN STARTING WITH 03) (SN 0300330558 to Present)
FIGURE 8-23. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 SIDE GROUND (MACHINES WITH SN STARTING WITH 03) (SN 0300330558 to Present)
FIGURE 8-24. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT107 (CE & UK CA SPECS WITHOUT 4000S/50HZ GENERATOR) (MACHINES WITH SN STARTING WITH 03) (SN 0300330558 to Present)
FIGURE 8-25. AC BOX AT PLATFORM INSTALLATION - 110C IEC YELLOW (CE & UK CA SPECS WITHOUT 4000S/50HZ GENERATOR) (MACHINES WITH SN STARTING WITH 03) (SN 0300330558 to Present)
FIGURE 8-26. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE (CE & UK CA SPECS WITHOUT 4000S/50HZ GENERATOR) (MACHINES WITH SN STARTING WITH 03) (SN 0300330558 to Present)
FIGURE 8-27. AC BREAKER BOX INSTALLATION - SINGLE DOUBLE POLE BREAKER
FIGURE 8-28. AC BREAKER BOX INSTALLATION - 3 BREAKERS
FIGURE 8-29. AC CABLES AND CLAMPS INSTALLATION - WITHOUT GENERATOR (ALL SPECS EXCEPT ANSI & CSA SPECS)
FIGURE 8-30. AC CABLES AND CLAMPS INSTALLATION - WITHOUT GENERATOR (ANSI & CSA SPECS)
FIGURE 8-31. AC CABLES AND CLAMPS INSTALLATION - WITH 2500W GENERATOR
FIGURE 8-32. AC CABLES AND CLAMPS INSTALLATION - WITH 4000W-50HZ GENERATOR
FIGURE 8-33. AC CABLES AND CLAMPS INSTALLATION - WITH 4000W-60HZ GENERATOR (Prior to SN 0300329413)
FIGURE 8-34. AC CABLES AND CLAMPS INSTALLATION - WITH 4000W-60HZ GENERATOR (SN 0300329414 to Present)
FIGURE 8-35. AC CABLES AND CLAMPS INSTALLATION - WITH 7500W SKYPOWER GENERATOR (Prior to SN 0300329413)
FIGURE 8-36. AC CABLES AND CLAMPS INSTALLATION - WITH 7500W SKYPOWER GENERATOR (SN 0300329414 to Present)
FIGURE 8-37. BATTERY DISCONNECT SWITCH INSTALLATION
FIGURE 8-38. BREAKER BOX KIT - SINGLE DOUBLE POLE BREAKER (WITHOUT 4000W/50HZ GENERATOR)
FIGURE 8-39. BREAKER BOX KIT - SINGLE DOUBLE POLE BREAKER (WITH 4000W/50HZ GENERATOR)
FIGURE 8-40. BREAKER BOX KIT - 3 BREAKERS
FIGURE 8-41. BOOM ANGLE SENSOR HARNESS
FIGURE 8-42. BOOM CABLE - LOWER
FIGURE 8-43. BOOM CABLE - UPPER (660SJC)
FIGURE 8-44. CAPACITY PROXIMITY HARNESS
FIGURE 8-45. CAPACITY PROXIMITY HARNESS
FIGURE 8-46. CAPACITY PROXIMITY HARNESS (DEUTZ TD2.9L4 (STAGE V) ENGINES)
FIGURE 8-47. CLEARSKY CS550 - WITH BEACON INSTALLATION (PLASTIC HOOD)
FIGURE 8-48. CLEARSKY CS550 - WITH BEACON INSTALLATION (METAL HOOD)
FIGURE 8-49. ECU POWER JUMPER HARNESS
FIGURE 8-50. ELECTRICAL COMPONENTS INSTALLATION
FIGURE 8-51. ELECTRICAL COMPONENTS INSTALLATION (DEUTZ TD2.9L4 (STAGE V) ENGINES)
FIGURE 8-52. ENGINE HARNESS - DEUTZ D2011 ENGINES
FIGURE 8-53. ENGINE HARNESS - DEUTZ TD2.9L4 ENGINES AND DEUTZ TD2.9L4 (STAGE V PRE-BUY) ENGINES
FIGURE 8-54. ENGINE HARNESS - DEUTZ TD2.9L4 (STAGE V) ENGINES
FIGURE 8-55. FUEL PUMP HARNESS - DEUTZ TD2.9L4 ENGINE
FIGURE 8-56. FUEL HARNESS - DEUTZ TD2.2L4 (STAGE V) ENGINE
FIGURE 8-57. GENERATOR HARNESS - 2500W
FIGURE 8-58. GENERATOR HARNESS - 4000W
FIGURE 8-59. GENERATOR HARNESS - 7500W SKYPOWER
FIGURE 8-60. GENERATOR TO ENGINE HARNESS - 7500W SKYPOWER GENERATOR (DEUTZ D2011 ONLY)
FIGURE 8-61. GROUND CONTROL HARNESS
FIGURE 8-62. HOUR METER JUMPER HARNESS
FIGURE 8-63. INTERFACE HARNESS - WITH 1 CELL LSS
FIGURE 8-64. LEFT DRIVE HARNESS
FIGURE 8-65. LIFT CYLINDER HARNESS
FIGURE 8-66. MAIN VALVE HARNESS
FIGURE 8-67. PLATFORM BEACON INSTALLATION (SN 0300332802 to Present)
FIGURE 8-68. PLATFORM BEACON HARNESS (SN 0300332802 to Present)
FIGURE 8-69. PLATFORM CONSOLE HARNESS
FIGURE 8-70. PLATFORM VALVE HARNESS
FIGURE 8-71. RECEPTACLE BOX KIT - 110V IEC YELLOW (CE & UK CA SPEC)
FIGURE 8-72. RECEPTACLE BOX KIT - 220V IEC BLUE (CE & UK CA SPEC)
FIGURE 8-73. RECEPTACLE BOX KIT - 220V CEE7 POST GROUND 2X4 BOX (CE & UK CA SPEC)
FIGURE 8-74. RECEPTACLE BOX KIT - 220V CEE7 SIDE GROUND (CE & UK CA SPEC)
FIGURE 8-75. RECEPTACLE BOX KIT - 220V AFSINT107 (CE & UK CA SPEC)
FIGURE 8-76. SKYEYE INTERMEDIATE HARNESS
FIGURE 8-77. SKYEYE EMITTER HARNESS
FIGURE 8-78. 4. SKYEYE RECEIVER HARNESS
FIGURE 8-79. SKYLINE HARNESS
FIGURE 8-80. STROBE LIGHT CONTROL HARNESS
FIGURE 8-81. STOBE JUMPER HARNESS (RED & BLUE)
FIGURE 8-82. STROBE JUMPER HARNESS (AMBER)
FIGURE 8-83. TELE PROXIMITY HARNESS
FIGURE 8-84. TURNTABLE HARNESS
FIGURE 8-85. USB HARNESS
FIGURE 8-86. WHITE NOISE ALARM HARNESS
FIGURE 8-87. WORKLIGHT HARNESS
SECTION 9 - DECALSFIGURE 9-1. DECAL INSTALLATION - 660SJC (ANSI SPECS - ENGLISH LANGUAGE) (Prior to SN 0300332801)
FIGURE 9-2. DECAL INSTALLATION - 660SJC (ANSI SPECS - ENGLISH LANGUAGE) (SN 0300332802 to Present)
FIGURE 9-3. DECAL INSTALLATION - 660SJC (BRAZIL SPECS - PORTUGUESE/SPANISH LANGUAGES) (Prior to SN 0300332801)
FIGURE 9-4. DECAL INSTALLATION - 660SJC (BRAZIL SPECS - PORTUGUESE/SPANISH LANGUAGES) (SN 0300332802 to Present)
FIGURE 9-5. DECAL INSTALLATION - 660SJC (CE & UK CA SPECS - ENGLISH LANGUAGE) (Prior to SN 0300332801)
FIGURE 9-6. DECAL INSTALLATION - 660SJC (CE & UK CA SPECS - ENGLISH LANGUAGE) (SN 0300332802 to Present)
FIGURE 9-7. DECAL INSTALLATION - 660SJC (CHINESE SPECS - ENGLISH/SIMPLIFIED CHINESE LANGUAGES) (Prior to SN 0300332801)
FIGURE 9-8. DECAL INSTALLATION - 660SJC (CHINESE SPECS - ENGLISH/SIMPLIFIED CHINESE LANGUAGES) (SN 0300332802 to Present)
FIGURE 9-9. DECAL INSTALLATION - 660SJC (CHINESE SPECS - ENGLISH/TRADITIONAL CHINESE LANGUAGES) (Prior to SN 0300332801)
FIGURE 9-10. DECAL INSTALLATION - 660SJC (CHINESE SPECS - ENGLISH/TRADITIONAL CHINESE LANGUAGES) (SN 0300332802 to Present)
FIGURE 9-11. DECAL INSTALLATION - 660SJC (CSA SPECS - ENGLISH/FRENCH LANGUAGES) (Prior to SN 0300332801)
FIGURE 9-12. DECAL INSTALLATION - 660SJC (CSA SPECS - ENGLISH/FRENCH LANGUAGES) (SN 0300332802 to Present)
FIGURE 9-13. DECAL INSTALLATION - 660SJC (JAPANESE SPECS - ENGLISH/JAPANESE LANGUAGES) (Prior to SN 0300332801)
FIGURE 9-14. DECAL INSTALLATION - 660SJC (JAPANESE SPECS - ENGLISH/JAPANESE LANGUAGES) (SN 0300332802 to Present)
FIGURE 9-15. DECAL INSTALLATION - 660SJC (KOREAN SPECS - ENGLISH/KOREAN LANGUAGES) (Prior to SN 0300332801)
FIGURE 9-16. DECAL INSTALLATION - 660SJC (KOREAN SPECS - ENGLISH/KOREAN LANGUAGES) (SN 0300332802 to Present)
FIGURE 9-17. DECAL INSTALLATION - 660SJC (LATIN AMERICA SPECS - ENGLISH/SPANISH LANGUAGES) (Prior to SN 0300332801)
FIGURE 9-18. DECAL INSTALLATION - 660SJC (LATIN AMERICA SPECS - ENGLISH/SPANISH LANGUAGES) (SN 0300332802 to Present)
FIGURE 9-19. DECAL INSTALLATION - OPTIONS
FIGURE 9-20. SKYWELDER DECAL INSTALLATION - 50HZ (AUSTRALIAN, CE & UK CA SPECS)
FIGURE 9-21. SKYWELDER DECAL INSTALLATION - 60HZ (ALL SPECS EXCEPT AUSTRALIAN, CE & UK CA SPECS)
PART NUMBER INDEX
- SuperPac Parts Manual
- StratoLift Parts Manual
