JLG Boom Lift 660SJC Parts Catalog 31222419
Brand: JLG
Type of Machine: Boom Lift
Model: JLG 660SJC Boom Lift
Part Number: 31222419
Publication Date: 2025
Number of Pages: 634 Pages
SECTION 1 - FRAME
Brand: JLG
SECTION 1 - FRAME
FIGURE 1-1. HINOWA FRAME ASSEMBLY (WITH STEEL TRACKS)
FIGURE 1-2. HINOWA FRAME ASSEMBLY (WITH RUBBER TRACKS)
FIGURE 1-3. HINOWA FRAME ASSEMBLY (WITH RUBBER PADS)
SECTION 2 - TURNTABLEFIGURE 2-1. VALVE INSTALLATION
FIGURE 2-2. MAIN VALVE ASSEMBLY
FIGURE 2-3. SWING DRIVE INSTALLATION
FIGURE 2-4. SWING MOTOR/HUB ASSEMBLY
FIGURE 2-5. TURNTABLE BEARING AND LUBE INSTALLATION
FIGURE 2-6. TURNTABLE LOCK INSTALLATION
FIGURE 2-7. ROTARY COUPLING INSTALLATION
FIGURE 2-8. TANKS INSTALLATION - DIESEL MACHINES (POLY FUEL TANK) (HELGESEN HYDRAULIC TANK)
FIGURE 2-9. TANKS INSTALLATION - DIESEL MACHINES (POLY FUEL TANK) (JIANGYING HYDRAULIC TANK)
FIGURE 2-10. TANKS INSTALLATION - DIESEL MACHINES (STEEL FUEL TANK) (HELGESEN HYDRAULIC TANK)
FIGURE 2-11. TANKS INSTALLATION - DIESEL MACHINES (STEEL FUEL TANK) (JIANGYING HYDRAULIC TANK)
FIGURE 2-12. HYDRAULIC TANK ASSEMBLY (HELGESEN HYDRAULIC TANK)
FIGURE 2-13. HYDRAULIC TANK ASSEMBLY (JIANGYING HYDRAULIC TANK)
FIGURE 2-14. BATTERY AND AUXILIARY PUMP INSTALLATION
FIGURE 2-15. BATTERY AND AUXILIARY PUMP W/DISCONNECT SWITCH INSTALLATION
FIGURE 2-16. ELECTRICAL COMPONENTS INSTALLATION
FIGURE 2-17. ELECTRICAL COMPONENTS INSTALLATION (DEUTZ TD2.9L4 (STAGE V) ENGINES)
FIGURE 2-18. GROUND CONTROL PANEL ASSEMBLY
FIGURE 2-19. GROUND CONTROL PANEL ASSEMBLY - WITH DEUTZ TD2.9L4 (STAGE V) ENGINE
FIGURE 2-20. KEYSWITCH INSTALLATION (ALL SPECS EXCEPT CE & UK CA SPECS)
FIGURE 2-21. KEYSWITCH INSTALLATION (CE & UK CA SPECS)
FIGURE 2-22. LIGHT PANEL INSTALLTION
FIGURE 2-23. STROBE LIGHT INSTALLATION - AMBER (WITHOUT CLEARSKY BEACON)
FIGURE 2-24. STROBE LIGHT INSTALLATION - BLUE (WITHOUT CLEARSKY BEACON)
FIGURE 2-25. STROBE LIGHT INSTALLATION - RED (WITHOUT CLEARSKY BEACON)
FIGURE 2-26. WHITE NOISE ALARM INSTALLATION
FIGURE 2-27. HOODS INSTALLATIONS - ABS
FIGURE 2-28. HOOD ASSEMBLY - TANK SIDE (ABS)
FIGURE 2-29. HOOD ASSEMBLY - ENGINE SIDE (ABS)
FIGURE 2-30. HOODS INSTALLATIONS - STEEL
FIGURE 2-31. HOOD ASSEMBLY - TANK SIDE (STEEL)
FIGURE 2-32. HOOD ASSEMBLY - ENGINE SIDE (STEEL)
FIGURE 2-33. HOOD INSULATION INSTALLATION (STEEL HOODS)
FIGURE 2-34. HOOD PLUG INSTALLATION (NO BEACON)
FIGURE 2-35. NOISE REDUCTION PACKAGE
FIGURE 2-36. COVERS INSTALLATION
SECTION 3 - ENGINEFIGURE 3-1. DEUTZ D2011 ENGINE INSTALLATION - WITHOUT ARCTIC PACKAGE
FIGURE 3-2. DEUTZ D2011 ENGINE AND PUMPS SUB-ASSEMBLY - WITHOUT ARCTIC PACKAGE
FIGURE 3-3. DEUTZ D2011 ENGINE ASSEMBLY - WITHOUT ARCTIC PACKAGE
FIGURE 3-4. DEUTZ D2011 ENGINE INSTALLATION - WITH ARCTIC PACKAGE
FIGURE 3-5. DEUTZ D2011 ENGINE AND PUMPS SUB-ASSEMBLY - WITH ARCTIC PACKAGE
FIGURE 3-6. DEUTZ D2011 ENGINE ASSEMBLY - WITH ARCTIC PACKAGE
FIGURE 3-7. DEUTZ D2011 ENGINE COMPONENTS
FIGURE 3-8. DEUTZ TD2.9L4 ENGINE INSTALLATION - WITHOUT ARCTIC PACKAGE
FIGURE 3-9. DEUTZ TD2.9L4 ENGINE AND PUMPS SUB-ASSEMBLY - WITHOUT ARCTIC PACKAGE
FIGURE 3-10. DEUTZ TD2.9L4 ENGINE ASSEMBLY - WITHOUT ARCTIC PACKAGE
FIGURE 3-11. DEUTZ TD2.9L4 ENGINE INSTALLATION - WITH ARCTIC PACKAGE
FIGURE 3-12. DEUTZ TD2.9L4 ENGINE AND PUMPS SUB-ASSEMBLY - WITH ARCTIC PACKAGE
FIGURE 3-13. DEUTZ TD2.9L4 ENGINE ASSEMBLY - WITH ARCTIC PACKAGE
FIGURE 3-14. DEUTZ TD2.9L4 ENGINE COMPONENTS
FIGURE 3-15. DEUTZ TD2.9L4 ENGINE INSTALLATION - WITHOUT ARCTIC PACKAGE (CHINA SPECS ONLY)
FIGURE 3-16. DEUTZ TD2.9L4 ENGINE AND PUMPS SUB-ASSEMBLY - WITHOUT ARCTIC PACKAGE (CHINA SPECS ONLY)
FIGURE 3-17. DEUTZ TD2.9L4 ENGINE ASSEMBLY - WITHOUT ARCTIC PACKAGE (CHINA SPECS ONLY)
FIGURE 3-18. DEUTZ TD2.9L4 ENGINE INSTALLATION - WITH ARCTIC PACKAGE (CHINA SPECS ONLY)
FIGURE 3-19. DEUTZ TD2.9L4 ENGINE AND PUMPS SUB-ASSEMBLY - WITH ARCTIC PACKAGE (CHINA SPECS ONLY)
FIGURE 3-20. DEUTZ TD2.9L4 ENGINE ASSEMBLY - WITH ARCTIC PACKAGE (CHINA SPECS ONLY)
FIGURE 3-21. DEUTZ TD2.9L4 ENGINE COMPONENTS (CHINA SPECS ONLY)
FIGURE 3-22. DEUTZ TD2.9L4 (STAGE V PRE-BUY) ENGINE INSTALLATION
FIGURE 3-23. DEUTZ TD2.9L4 (STAGE V PRE-BUY) ENGINE AND PUMP SUB-ASSEMBLY
FIGURE 3-24. DEUTZ TD2.9L4 (STAGE V PRE-BUY) ENGINE ASSEMBLY
FIGURE 3-25. DEUTZ TD2.9L4 (STAGE V PRE-BUY) ENGINE COMPONENTS
FIGURE 3-26. DEUTZ TD2.9L4 (STAGE V) ENGINE INSTALLATION
FIGURE 3-27. DEUTZ TD2.9L4 (STAGE V) ENGINE AND PUMP SUB-ASSEMBLY
FIGURE 3-28. DEUTZ TD2.9L4 (STAGE V) ENGINE ASSEMBLY
FIGURE 3-29. DEUTZ TD2.9L4 (STAGE V) ENGINE COMPONENTS
FIGURE 3-30. DEUTZ D2.9L4 - EMR5 ENGINE INSTALLATION WITH ARCTIC PACKAGE
FIGURE 3-31. DEUTZ D2.9L4 - EMR5 ENGINE AND PUMPS SUB-ASSEMBLY WITH ARCTIC PACKAGE
FIGURE 3-32. DEUTZ D2.9L4 - EMR5 ENGINE ASSEMBLY WITH ARCTIC PACKAGE
FIGURE 3-33. DEUTZ D2.9L4 - EMR5 ENGINE INSTALLATION WITHOUT ARCTIC PACKAGE
FIGURE 3-34. DEUTZ D2.9L4 - EMR5 ENGINE AND PUMPS SUB-ASSEMBLY WITHOUT ARCTIC PACKAGE
FIGURE 3-35. DEUTZ D2.9L4 - EMR5 (67HP) ENGINE ASSEMBLY WITHOUT ARCTIC PACKAGE
FIGURE 3-36. PUMP COUPLING KIT (DEUTZ ENGINES)
FIGURE 3-37. PISTON PUMP ASSEMBLY- FRONT
FIGURE 3-38. PISTON PUMP ASSEMBLY- REAR
FIGURE 3-39. FUEL FILTER INSTALLATION (STEEL FUEL TANK) (DEUTZ D2011 ENGINES)
FIGURE 3-40. FUEL FILTER INSTALLATION (DEUTZ TD2.9L4 ENGINES)
FIGURE 3-41. FUEL FILTER ASSEMBLY (DEUTZ TD2.9L4 ENGINES)
FIGURE 3-42. BREATHER HEATER INSTALLATION - DEUTZ D2.9L4 ENGINE WITH ARCTIC PACKAGE
FIGURE 3-43. DEUTZ 2.9L4 EXHAUST INSTALLATION (CHINA SPECS ONLY)
FIGURE 3-44. ENGINE HOOD BAFFLES INSTALLATION - ABS HOODS
FIGURE 3-45. ENGINE HOOD BAFFLES INSTALLATION - STEEL HOODS
FIGURE 3-46. TRAY JACK INSTALLATION
FIGURE 3-47. MOTOR MOUNT INSTALLATION - WITHOUT GENERATOR (DEUTZ D2011 ENGINES)
FIGURE 3-48. MOTOR MOUNT INSTALLATION - WITH GENERATOR (DEUTZ D2011 ENGINES)
FIGURE 3-49. MOTOR MOUNT INSTALLATION - WITHOUT GENERATOR (DEUTZ TD2.9L4 ENGINES)
FIGURE 3-50. MOTOR MOUNT INSTALLATION - WITH GENERATOR (DEUTZ TD2.9L4 ENGINES)
FIGURE 3-51. 2500W GENERATOR INSTALLATION - 220V/50HZ (DEUTZ D2011 ENGINES) (OPTIONAL)
FIGURE 3-52. 2500W GENERATOR INSTALLATION - 110V/60HZ (DEUTZ D2011 ENGINES) (OPTIONAL)
FIGURE 3-53. 2500W GENERATOR INSTALLATION - 110V/60HZ (DEUTZ TD2.9L4 ENGINES) (OPTIONAL)
FIGURE 3-54. 4000W GENERATOR INSTALLATION - 220V/50HZ (DEUTZ D2011 ENGINES) (OPTIONAL)
FIGURE 3-55. 4000W GENERATOR INSTALLATION - 110V/60HZ (DEUTZ D2011 ENGINES) (OPTIONAL)
FIGURE 3-56. 4000W GENERATOR INSTALLATION - 220V/50HZ (DEUTZ TD2.9L4 ENGINES) (OPTIONAL)
FIGURE 3-57. 4000W GENERATOR INSTALLATION - 110V/60HZ (DEUTZ TD2.9L4 ENGINES) (OPTIONAL)
FIGURE 3-58. 7500W SKYPOWER GENERATOR INSTALLATION - 220V/50HZ (DEUTZ D2011 ENGINES) (OPTIONAL)
FIGURE 3-59. 7500W SKYPOWER GENERATOR INSTALLATION - 110V/60HZ (DEUTZ D2011 ENGINES) (OPTIONAL)
FIGURE 3-60. 7500W GENERATOR INSTALLATION - 220V/50HZ (DEUTZ TD2.9L4 ENGINES) (OPTIONAL)
FIGURE 3-61. 7500W SKYPOWER GENERATOR INSTALLATION - 110V/60HZ (DEUTZ TD2.9L4 ENGINES) (OPTIONAL)
SECTION 4 - BOOMFIGURE 4-1. BOOM INSTALLATION
FIGURE 4-2. BOOM ASSEMBLY
FIGURE 4-3. JIB ASSEMBLY
FIGURE 4-4. PLATFORM ROTATOR ASSEMBLY
FIGURE 4-5. POWER TRACK INSTALLATION WITH PLASTIC CLAMP
FIGURE 4-6. POWER TRACK INSTALLATION WITH STEEL CLAMP
FIGURE 4-7. BOOM VALVES INSTALLATION
FIGURE 4-8. PLATFORM VALVE ASSEMBLY
FIGURE 4-9. BOOM SENSORS INSTALLATION
FIGURE 4-10. PLATFORM SUPPORT INSTALLATION - WITH LSS
SECTION 5 - PLATFORMFIGURE 5-1. PLATFORM ASSEMBLY - 30IN X 3FT (76CM X .91M) - DROP BAR ENTRY
FIGURE 5-2. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) WITH SWING GATE
FIGURE 5-3. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) WITH DROP BAR
FIGURE 5-4. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) TRI-ENTRY WITH SWING GATE
FIGURE 5-5. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) TRI-ENTRY WITH DROPBAR
FIGURE 5-6. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) TRI-ENTRY WITH DROPBAR
FIGURE 5-7. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) TRI-ENTRY WITH DROPGATE
FIGURE 5-8. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH SWING GATE
FIGURE 5-9. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH DROP BAR
FIGURE 5-10. TRAY ASSEMBLY
FIGURE 5-11. PLATFORM CONSOLE AND FOOTSWITCH INSTALLATION
FIGURE 5-12. CONSOLE BOX ASSEMBLY
FIGURE 5-13. JOYSTICK (DRIVE/STEER)
FIGURE 5-14. LIGHT PANEL INSTALLATION
FIGURE 5-15. FOOTSWITCH ASSEMBLY
FIGURE 5-16. SKYGUARD BAR INSTALLATION
FIGURE 5-17. SKYEYE INSTALLATION
FIGURE 5-18. SKYGLAZIER INSTALLATION (ANSI, AUSTRALIAN AND CSA SPECS)
FIGURE 5-19. SKYLINE INSTALLATION
FIGURE 5-20. SKYWELDER INSTALLATION (50HZ)
FIGURE 5-21. SKYWELDER INSTALLATION (60HZ)
FIGURE 5-22. SKYWELDER PREP PACKAGE (60HZ)
FIGURE 5-23. USB CHARGER INSTALLATION
FIGURE 5-24. WELDER ASSEMBLY
SECTION 6 - CYLINDERFIGURE 6-1. LEVEL CYLINDER ASSEMBLY - PLATFORM SLAVE
FIGURE 6-2. LIFT CYLINDER ASSEMBLY - BOOM
FIGURE 6-3. LIFT CYLINDER ASSEMBLY - JIB
FIGURE 6-4. TELESCOPE CYLINDER ASSEMBLY
SECTION 7 - HYDRAULICFIGURE 7-1. STANDARD HYDRAULIC DIAGRAM
SECTION 8 - ELECTRICALFIGURE 8-1. ELECTRICAL LAYOUT
FIGURE 8-2. AC BOX AT PLATFORM INSTALLATION -110V (ALL SPECS EXCEPT AUSTRALIAN, CE & UK CA SPECS)
FIGURE 8-3. AC BOX AT PLATFORM INSTALLATION - 110V IEC YELLOW (CE & UK CA SPECS WITHOUT 4000W/50HZ GENERATOR)
FIGURE 8-4. AC BOX AT PLATFORM INSTALLATION - 110V IEC YELLOW (CE & UK CA SPECS WITH 4000W/50HZ GENERATOR)
FIGURE 8-5. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE (CE & UK CA SPECS WITHOUT 4000W/50HZ GENERATOR)
FIGURE 8-6. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE (CE & UK CA SPECS WITH 4000W/50HZ GENERATOR)
FIGURE 8-7. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 2IN X 4IN POST GROUND (CE & UK CA SPECS WITHOUT 4000W/50HZ GENERATOR)
FIGURE 8-8. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 2IN X 4IN POST GROUND (CE & UK CA SPECS WITH 4000W/50HZ GENERATOR)
FIGURE 8-9. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 2IN X 4IN SIDE GROUND (CE & UK CA SPECS WITHOUT 4000W/50HZ GENERATOR)
FIGURE 8-10. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 2IN X 4IN SIDE GROUND (CE & UK CA SPECS WITH 4000W/50HZ GENERATOR)
FIGURE 8-11. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT107 (CE & UK CA SPECS WITHOUT 4000W/50HZ GENERATOR)
FIGURE 8-12. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT107 (CE & UK CA SPECS WITH 4000W/50HZ GENERATOR)
FIGURE 8-13. AC BOX AT PLATFORM INSTALLATION - 220V CUSTOMER SUPPLIED COMPONENTS (ANSI EXPORT, AUSTRALIAN, CHINA, CE & UK CA SPECS)
FIGURE 8-14. AC BOX AT PLATFORM INSTALLATION - 240V (WITH 4000W GENERATOR) (ALL SPECS EXCEPT AUSTRALIAN, CE & UK CA SPECS)
FIGURE 8-15. AC BOX AT PLATFORM INSTALLATION - 240V (WITH 7500WSKYPOWER GENERATOR) (ALL SPECS EXCEPT AUSTRALIAN, CE & UK CA SPECS)
FIGURE 8-16. AC BREAKER BOX INSTALLATION - SINGLE DOUBLE POLE BREAKER
FIGURE 8-17. AC BREAKER BOX INSTALLATION - 3 BREAKERS
FIGURE 8-18. AC CABLES AND CLAMPS INSTALLATION - WITHOUT GENERATOR (ALL SPECS EXCEPT ANSI & CSA SPECS)
FIGURE 8-19. AC CABLES AND CLAMPS INSTALLATION - WITHOUT GENERATOR (ANSI & CSA SPECS)
FIGURE 8-20. AC CABLES AND CLAMPS INSTALLATION - WITH 2500W GENERATOR
FIGURE 8-21. AC CABLES AND CLAMPS INSTALLATION - WITH 4000W-50HZ GENERATOR
FIGURE 8-22. AC CABLES AND CLAMPS INSTALLATION - WITH 4000W-60HZ GENERATOR
FIGURE 8-23. AC CABLES AND CLAMPS INSTALLATION - WITH 7500W SKYPOWER GENERATOR
FIGURE 8-24. BATTERY DISCONNECT SWITCH INSTALLATION
FIGURE 8-25. BREAKER BOX KIT - SINGLE DOUBLE POLE BREAKER (WITHOUT 4000W/50HZ GENERATOR)
FIGURE 8-26. BREAKER BOX KIT - SINGLE DOUBLE POLE BREAKER (WITH 4000W/50HZ GENERATOR)
FIGURE 8-27. BREAKER BOX KIT - 3 BREAKERS
FIGURE 8-28. BOOM ANGLE SENSOR HARNESS
FIGURE 8-29. BOOM CABLE - LOWER
FIGURE 8-30. BOOM CABLE - UPPER
FIGURE 8-31. CAPACITY PROXIMITY HARNESS
FIGURE 8-32. CAPACITY PROXIMITY HARNESS
FIGURE 8-33. CAPACITY PROXIMITY HARNESS (DEUTZ TD2.9L4 (STAGE V) ENGINES)
FIGURE 8-34. CLEARSKY 3-WIRE TELEMATICS INSTALLATION (ALL SPECS EXCEPT CHINA SPECS)
FIGURE 8-35. CLEARSKY 3G CANBUS TELEMATICS INSTALLATION (ANSI EXPORT, CE & UK CA SPECS)
FIGURE 8-36. CLEARSKY 4G CANBUS TELEMATICS INSTALLATION (ANSI & CSA SPECS)
FIGURE 8-37. CLEARSKY CS550 BEACON INSTALLATION - WITH PLASTIC HOOD
FIGURE 8-38. CLEARSKY CS550 BEACON INSTALLATION - WITH METAL HOOD
FIGURE 8-39. CLEARSKY HARNESS - 3-WIRE TELEMATICS
FIGURE 8-40. CLEARSKY HARNESS - CANBUS TELEMATICS
FIGURE 8-41. ECU POWER JUMPER HARNESS
FIGURE 8-42. ELECTRICAL COMPONENTS INSTALLATION
FIGURE 8-43. ELECTRICAL COMPONENTS INSTALLATION (DEUTZ TD2.9L4 (STAGE V) ENGINES)
FIGURE 8-44. ENGINE HARNESS - DEUTZ D2011 ENGINES
FIGURE 8-45. ENGINE HARNESS - DEUTZ TD2.9L4 ENGINES AND DEUTZ TD2.9L4 (STAGE V PRE-BUY) ENGINES
FIGURE 8-46. ENGINE HARNESS - DEUTZ TD2.9L4 (STAGE V) ENGINES
FIGURE 8-47. FUEL PUMP HARNESS - DEUTZ TD2.9L4 ENGINE
FIGURE 8-48. FUEL HARNESS - DEUTZ TD2.2L4 (STAGE V) ENGINE
FIGURE 8-49. GENERATOR HARNESS - 2500W
FIGURE 8-50. GENERATOR HARNESS - 4000W
FIGURE 8-51. GENERATOR HARNESS - 7500W SKYPOWER
FIGURE 8-52. GENERATOR TO ENGINE HARNESS - 7500W SKYPOWER GENERATOR (DEUTZ D2011 ONLY)
FIGURE 8-53. GROUND CONTROL HARNESS
FIGURE 8-54. HOUR METER JUMPER HARNESS
FIGURE 8-55. INTERFACE HARNESS - WITH 1 CELL LSS
FIGURE 8-56. LEFT DRIVE HARNESS
FIGURE 8-57. LIFT CYLINDER HARNESS
FIGURE 8-58. MAIN VALVE HARNESS
FIGURE 8-59. PLATFORM CONSOLE HARNESS
FIGURE 8-60. PLATFORM VALVE HARNESS
FIGURE 8-61. RECEPTACLE BOX KIT - 110V IEC YELLOW (CE & UK CA SPEC)
FIGURE 8-62. RECEPTACLE BOX KIT - 220V IEC BLUE (CE & UK CA SPEC)
FIGURE 8-63. RECEPTACLE BOX KIT - 220V CEE7 POST GROUND 2X4 BOX (CE & UK CA SPEC)
FIGURE 8-64. RECEPTACLE BOX KIT - 220V CEE7 SIDE GROUND (CE & UK CA SPEC)
FIGURE 8-65. RECEPTACLE BOX KIT - 220V AFSINT107 (CE & UK CA SPEC)
FIGURE 8-66. SKYEYE INTERMEDIATE HARNESS
FIGURE 8-67. SKYEYE EMITTER HARNESS
FIGURE 8-68. 4. SKYEYE RECEIVER HARNESS
FIGURE 8-69. SKYLINE HARNESS
FIGURE 8-70. STROBE LIGHT CONTROL HARNESS
FIGURE 8-71. STOBE JUMPER HARNESS (RED & BLUE)
FIGURE 8-72. STROBE JUMPER HARNESS (AMBER)
FIGURE 8-73. TELE PROXIMITY HARNESS
FIGURE 8-74. TURNTABLE HARNESS
FIGURE 8-75. TURNTABLE HARNESS
FIGURE 8-76. WHITE NOISE ALARM HARNESS
SECTION 9 - DECALSFIGURE 9-1. DECAL INSTALLATION - 660SJC (ANSI SPECS - ENGLISH LANGUAGE)
FIGURE 9-2. DECAL INSTALLATION - 660SJC (BRAZIL SPECS - PORTUGUESE/SPANISH LANGUAGES)
FIGURE 9-3. DECAL INSTALLATION - 660SJC (CE & UK CA SPECS - ENGLISH LANGUAGE)
FIGURE 9-4. DECAL INSTALLATION - 660SJC (CHINESE SPECS - ENGLISH/SIMPLIFIED CHINESE LANGUAGES)
FIGURE 9-5. DECAL INSTALLATION - 660SJC (CHINESE SPECS - ENGLISH/TRADITIONAL CHINESE LANGUAGES)
FIGURE 9-6. DECAL INSTALLATION - 660SJC (CSA SPECS - ENGLISH/FRENCH LANGUAGES)
FIGURE 9-7. DECAL INSTALLATION - 660SJC (JAPANESE SPECS - ENGLISH/JAPANESE LANGUAGES)
FIGURE 9-8. DECAL INSTALLATION - 660SJC (KOREAN SPECS - ENGLISH/KOREAN LANGUAGES)
FIGURE 9-9. DECAL INSTALLATION - 660SJC (LATIN AMERICA SPECS - ENGLISH/SPANISH LANGUAGES)
FIGURE 9-10. DECAL INSTALLATION - OPTIONS
FIGURE 9-11. SKYWELDER DECAL INSTALLATION - 50HZ (AUSTRALIAN, CE & UK CA SPECS)
FIGURE 9-12. SKYWELDER DECAL INSTALLATION - 60HZ (ALL SPECS EXCEPT AUSTRALIAN, CE & UK CA SPECS)
PART NUMBER INDEX
- SuperPac Parts Manual
- StratoLift Parts Manual
