Hyundai
86
176,834
JLG Boom Lift 60HT 60HTH Parts Catalog 3120258
Brand: JLG
Type of Machine: Boom Lift
Model: JLG 60HT 60HTH Boom Lift
Part Number: 3120258
Publication Date: 1987
Number of Pages: 298 Pages
SECTION 1 - ILLUSTRATED PARTS LIST
FIGURE 1-1. BOOM AND LIMIT SWITCH INSTALLATION​
FIGURE 1-2. BOOM ASSEMBLY​
FIGURE 1-3. TELESCOPE CYLINDER ASSEMBLY​
FIGURE 1-4. SLAVE CYLINDER ASSEMBLY​
FIGURE 1-5. SLAVE CYLINDER ASSEMBLY​
FIGURE 1-6. MASTER CYLINDER ASSEMBLY​
FIGURE 1-7. LIFT CYLINDER ASSEMBLY​
FIGURE 1-8. BOOM WIPERS INSTALLATION​
FIGURE 1-9. BOOM PROP INSTALLATION​
FIGURE 1-10. STEERING TUBE SUPPORT INSTALLATION​
FIGURE 1-11. PLATFORMS AND CONTROLS STANDS ASSEMBLIES AND INSTALLATIONS​
FIGURE 1-12. HYDRAULIC MOTOR ASSEMBLY​
FIGURE 1-13. PLATFORM CONTROL ASSEMBLY (VICKERS VALVES AND OEM CONTROLLERS)​
FIGURE 1-14. PLATFORM CONTROL BOX ASSEMBLY (VICKERS VALVES, PQ CONTROLLERS AND PROPORTIONAL TELESCOPE)​
FIGURE 1-15. PLATFORM CONTROL BOX ASSEMBLY (PQ CONTROLLERS AND NON-PROPORTIONAL TELESCOPE)​
FIGURE 1-16. PLATFORM CONTROL BOX ASSEMBLY (RACINE VALVES)​
FIGURE 1-17. GROUND CONTROLS ASSEMBLY AND INSTALLATION​
FIGURE 1-18. GROUND CONTROLS ASSEMBLY AND INSTALLATION​
FIGURE 1-19. CONTROL VALVES INSTALLATION - RACINE​
FIGURE 1-20. PROPORTIONAL CONTROL VALVE ASSEMBLY (RACINE)​
FIGURE 1-21. WORKING SECTIONS - PROPORTIONAL CONTROL VALVE (RACINE)​
FIGURE 1-22. INLET SECTION - PROPORTIONAL CONTROL VALVE (RACINE)​
FIGURE 1-23. SERVO SECTION - PROPORTIONAL CONTROL VALVE (RACINE)​
FIGURE 1-24. CONTROL VALVES INSTALLATIONS - VICKERS​
FIGURE 1-25. CONTROL VALVE ASSEMBLY - VICKERS​
FIGURE 1-26. CONTROL VALVE - RACINE BANG-BANG​
FIGURE 1-27. ENGINE AND COMPONENTS ASSEMBLY AND INSTALLATION - FORD LSG-423 GAS​
FIGURE 1-28. DUAL FUEL INSTALLATION - FORD​
FIGURE 1-29. PRECISION GOVERNOR INSTALLATION - FORD​
FIGURE 1-30. ADECO THROTTLE INSTALLATION - FORD​
FIGURE 1-31. AC GENERATOR INSTALLATION - FORD​
FIGURE 1-32. REMOTE OIL FILTER AND DRAIN - FORD​
FIGURE 1-33. ENGINE AND COMPONENTS ASSEMBLY AND INSTALLATION - DEUTZ F3L912 DIESEL​
FIGURE 1-34. FUEL SHUT-OFF AND HIGH ENGINE INSTALLATIONS (DEUTZ)​
FIGURE 1-35. ADECO THROTTLE COMPONENTS INSTALLATION - DEUTZ​
FIGURE 1-36. AC GENERATOR INSTALLATION - DEUTZ​
FIGURE 1-37. ENGINE AND COMPONENTS ASSEMBLY AND INSTALLATION - WISCONSIN V465D GAS​
FIGURE 1-38. OXY CATALYST PURIFIER INSTALLATION​
FIGURE 1-39. MAIM PUMP ASSEMBLY - GEAR (WITHOUT PORTED END)​
FIGURE 1-40. MAIN PUMP ASSEMBLY - GEAR (WITH PORTED END)​
FIGURE 1-41. MAIN PUMP ASSEMBLY - PISTON​
FIGURE 1-42. GEAR PUMP ASSEMBLY​
FIGURE 1-43. TANK INSTALLATION (RACINE)​
FIGURE 1-44. TANK INSTALLATION (VICKERS)​
FIGURE 1-45. LP GAS TANKS INSTALLATION​
FIGURE 1-46. HOOD INSTALLATION AND ACCESSORIES (STANDARD)​
FIGURE 1-47. HOOD INSTALLATION AND ACCESSORIES (7FT X 7FT, VICKERS AND 60HTH)​
FIGURE 1-48. TILT INDICATOR INSTALLATION​
FIGURE 1-49. OIL COOLER INSTALLATION​
FIGURE 1-50. TURNTABLES AND SWING COMPONENTS ASSEMBLIES AND INSTALLATION​
FIGURE 1-51. SWING DRIVE MOTOR ASSEMBLY​
FIGURE 1-52. SWING DRIVE BRAKE ASSEMBLY (AUSCO)​
FIGURE 1-53. SWING DRIVE BRAKE ASSEMBLY (MICO)​
FIGURE 1-54. SWING DRIVE HUB ASSEMBLY​
FIGURE 1-55. FRAME, STEERING AND DRIVE COMPONENTS, ASSEMBLIES AND INSTALLATIONS - FIXED AXLE (STANDARD AND 7FT X 7FT)​
FIGURE 1-56. FRAME, STEERING AND DRIVE COMPONENTS, ASSEMBLIES AND INSTALLATIONS - FIXED AXLE (VICKERS AND 60HTH)​
FIGURE 1-57. FRAME, STEERING AND DRIVE COMPONENTS, ASSEMBLIES AND INSTALLATIONS - OSCILLATING AXLE (60HTH)​
FIGURE 1-58. FRAME, STEERING AND DRIVE COMPONENTS, ASSEMBLIES AND INSTALLATIONS - 4WD​
FIGURE 1-59. DRIVE MOTOR (STANDARD AND 7FT X 7FT FIXED AXLE)​
FIGURE 1-60. DRIVE MOTOR (VICKERS FIXED, 60HTH FIXED AND OSCILLATING AND 4WD REAR)​
FIGURE 1-61. DRIVE MOTOR (4WD FRONT)​
FIGURE 1-62. DRIVE BRAKE - AUSCO (ALL FIXED AND OSCILLATING AXLES EXCEPT VICKERS AND 4WD)​
FIGURE 1-63. DRIVE BRAKE - MICO (ALL FIXED AND OSCILLATING AXLES EXCEPT VICKERS AND 4WD)​
FIGURE 1-64. DRIVE BRAKE (VICKERS AND 4WD)​
FIGURE 1-65. DRIVE REDUCER (VICKERS FIXED AND 60HTH FIXED AND OSCILLATING)​
FIGURE 1-66. DRIVE TORQUE HUB​
FIGURE 1-67. STEER CYLINDER ASSEMBLIES​
FIGURE 1-68. LOCKOUT CYLINDER ASSEMBLIES​
FIGURE 1-69. VALVES INSTALLATION (FRAME MOUNTED)​
FIGURE 1-70. LOCKOUT VALVE ASSEMBLY​
FIGURE 1-71. TOW PACKAGE INSTALLATION​
FIGURE 1-72. NAMEPLATES AND DECALS INSTALLATIONS​
FIGURE 1-73. AXLE LOCKOUT CIRCUIT, HYDRAULIC​
FIGURE 1-74. DRIVE CIRCUIT, HYDRAULIC (STANDARD AND 7FT X 7FT)​
FIGURE 1-75. DRIVE CIRCUIT, HYDRAULIC (VICKERS AND 60HTH)​
FIGURE 1-76. DRIVE CIRCUIT, HYDRAULIC (4WD)​
FIGURE 1-77. LEVEL CIRCUIT, HYDRAULIC​
FIGURE 1-78. LIFT CIRCUIT, HYDRAULIC (STANDARD AND 7FT X 7FT)​
FIGURE 1-79. LIFT CIRCUIT, HYDRAULIC (VICKERS AND 60HTH)​
FIGURE 1-80. MANUAL DESCENT CIRCUIT, HYDRAULIC​
FIGURE 1-81. PUMP CIRCUIT, HYDRAULIC (STANDARD AND 7FT X 7FT WITH GEAR PUMP AND WITHOUT STEERING WHEEL)​
FIGURE 1-82. PUMP CIRCUIT, HYDRAULIC (STANDARD AND 7FT X 7FT WITH GEAR PUMP AND WITH STEERING WHEEL)​
FIGURE 1-83. PUMP CIRCUIT, HYDRAULIC (STANDARD AND 7FT X 7FT WITH PISTON PUMP)​
FIGURE 1-84. PUMP CIRCUIT, HYDRAULIC (VICKERS AND 60HTH WITHOUT STEERING WHEEL)​
FIGURE 1-85. PUMP CIRCUIT, HYDRAULIC (VICKERS AND 60HT WITH STEERING WHEEL​
FIGURE 1-86. ROTATE CIRCUIT, HYDRAULIC​
FIGURE 1-87. STEER CIRCUIT, HYDRAULIC (WITHOUT STEERING WHEEL)​
FIGURE 1-88. STEER CIRCUIT, HYDRAULIC (WITH STEERING WHEEL)​
FIGURE 1-89. SWING CIRCUIT, HYDRAULIC (GEAR PUMP)​
FIGURE 1-90. SWING CIRCUIT, HYDRAULIC (PISTON PUMP)​
FIGURE 1-91. TELESCOPE CIRCUIT, HYDRAULIC (STANDARD/7FT X 7FT WITH GEAR PUMP AND VICKERS/60HTH WITH PROP TELE)​
FIGURE 1-92. TELESCOPE CIRCUIT, HYDRAULIC (STANDARD/7FT X 7FT WITH PISTON PUMP)​
FIGURE 1-93. TELESCOPE CIRCUIT, HYDRAULIC (VICKERS/60HTH WITHOUT PROP TELE)​
FIGURE 1-94. TOWING CIRCUIT, HYDRAULIC​
SECTION 2 - RECOMMENDED SERVICE PARTS STOCK
FIGURE 2-1. MODEL 60HT/60HTH ELECTRICAL​
FIGURE 2-2. MODEL 60HT/60HTH HYDRAULIC​
FIGURE 2-3. MODEL 60HT/60HTH MISCELLANEOUS​
PART NUMBER INDEX
