Hyundai
86
176,834
JLG Boom Lift 600SC 660SJC Parts Catalog 3121251
Brand: JLG
Type of Machine: Boom Lift
Model: JLG 600SC 660SJC Boom Lift
Part Number: 3121251
Publication Date: 2025
Number of Pages: 356 Pages
SECTION 1 - FRAME
FIGURE 1-1. GRADALL FRAME ASSEMBLY​
FIGURE 1-2. GRADALL FRAME DRIVE ASSEMBLY​
FIGURE 1-3. GRADALL DRIVE TRACK ROLLER ASSEMBLY (BOTTOM)​
FIGURE 1-4. GRADALL FRAME TRACK ROLLER ASSEMBLY (CARRIER)​
FIGURE 1-5. GRADALL FRAME TRACK CHAIN ASSEMBLY​
FIGURE 1-6. GRADALL FRAME IDLER ASSEMBLY​
FIGURE 1-7. GRADALL FRAME SPRING AND SHOCK ASSEMBLIES​
FIGURE 1-8. GRADALL FRAME ROTARY COUPLING ASSEMBLY​
FIGURE 1-9. CATERPILLAR FRAME ASSEMBLY​
FIGURE 1-10. CATERPILLAR FRAME IDLER ASSEMBLY​
FIGURE 1-11. CATERPILLAR FRAME TRACK ROLLER INSTALLATION​
FIGURE 1-12. CATERPILLAR FRAME TRACK SHOE INSTALLATION​
FIGURE 1-13. CATERPILLAR FRAME DRIVE MOTOR ASSEMBLY​
FIGURE 1-14. CATERPILLAR FRAME DRIVE VALVE ASSEMBLY​
FIGURE 1-15. CATERPILLAR FRAME DRIVE HUB ASSEMBLY​
FIGURE 1-16. CATERPILLAR FRAME ROTARY COUPLING ASSEMBLY​
SECTION 2 - TURNTABLE
FIGURE 2-1. CONTROL VALVES INSTALLATIONS​
FIGURE 2-2. MAIN CONTROL VALVE ASSEMBLY​
FIGURE 2-3. ARTICULATING JIB VALVE ASSEMBLY (660SJC)​
FIGURE 2-4. SWING DRIVE, TURNTABLE BEARING AND LOCK INSTALLATIONS​
FIGURE 2-5. SWING HUB ASSEMBLY (SN 0300128000 through 0300137440)​
FIGURE 2-6. SWING MOTOR ASSEMBLY (WHITE ROLLER STATOR) (ORIGINAL EQUIPMENT) (SN 0300128000 through 0300137440)​
FIGURE 2-7. SWING MOTOR ASSEMBLY (PARKER) (SERVICE REPLACEMENT) (SN 0300128000 through 0300137440)​
FIGURE 2-8. SWING MOTOR/BRAKE/HUB ASSEMBLY (PARKER/FAIRFIELD) (SN 0300137441 through 0300174703)​
FIGURE 2-9. CATERPILLAR ENGINE INSTALLATION (SN 0300128000 through 0300149851)​
FIGURE 2-10. CATERPILLAR ENGINE INSTALLATION (SN 0300149852 through 0300174703)​
FIGURE 2-11. DEUTZ ENGINE INSTALLATION (WITHOUT UGM)​
FIGURE 2-12. DEUTZ ENGINE INSTALLATION (WITH UGM)​
FIGURE 2-13. PISTON PUMP ASSEMBLY​
FIGURE 2-14. GEAR PUMP ASSEMBLY​
FIGURE 2-15. TANK INSTALLATIONS​
FIGURE 2-16. GROUND CONTROL ASSEMBLY (WITHOUT UGM)​
FIGURE 2-17. GROUND CONTROL ASSEMBLY (WITH UGM)​
FIGURE 2-18. ELECTRICAL OPTIONS INSTALLATION (TURNTABLE MOUNTED)​
FIGURE 2-19. HOODS (ABS) AND LIFTING PLATE INSTALLATIONS​
FIGURE 2-20. HOODS (STEEL) AND LIFTING PLATE INSTALLATIONS​
FIGURE 2-21. ENGINE TRAY JACK INSTALLATION​
FIGURE 2-22. 2500W GENERATOR INSTALLATION - CATERPILLAR MACHINES (OPTIONAL)​
FIGURE 2-23. 2500W GENERATOR INSTALLATION - DEUTZ MACHINES (OPTIONAL)​
FIGURE 2-24. 7500W SKYPOWER GENERATOR INSTALLATION​
FIGURE 2-25. SKYAIR AIR COMPRESSOR INSTALLATION​
FIGURE 2-26. AIR COMPRESSOR ASSEMBLY​
SECTION 3 - BOOM
FIGURE 3-1. BOOM INSTALLATION (600SC)​
FIGURE 3-2. BOOM INSTALLATION (660SJC)​
FIGURE 3-3. MAIN BOOM ASSEMBLIES - ANSI AND ANSI EXPORT SPECS​
FIGURE 3-4. MAIN BOOM ASSEMBLIES - AUSTRALIAN AND CE SPECS​
FIGURE 3-5. ROTATOR ASSEMBLIES​
FIGURE 3-6. PLATFORM SUPPORT INSTALLATION​
FIGURE 3-7. POWER TRACK INSTALLATION​
SECTION 4 - PLATFORM
FIGURE 4-1. PLATFORM COMPONENTS INSTALLATION​
FIGURE 4-2. PLATFORM CONSOLE ASSEMBLY​
FIGURE 4-3. CONTROLLER ASSEMBLY (LIFT AND SWING) (ORIGINAL EQUIPMENT)​
FIGURE 4-4. CONTROLLER ASSEMBLY (LIFT AND SWING) (SERVICE REPLACEMENT)​
FIGURE 4-5. CONTROLLER ASSEMBLY (LIFT AND SWING) (SERVICE REPLACEMENT)​
FIGURE 4-6. CONTROLLER ASSEMBLY (DRIVE AND STEER)​
FIGURE 4-7. SKYGLAZIER INSTALLATION​
FIGURE 4-8. SKYCUTTER INSTALLATION - 60HZ POWER SUPPLY​
FIGURE 4-9. SKYWELDER/SKYCUTTER COMBO INSTALLATION (60HZ)​
FIGURE 4-10. SKYWELDER INSTALLATION (60HZ)​
FIGURE 4-11. SKYWELDER INSTALLATION (50HZ)​
FIGURE 4-12. WELDER ASSEMBLY​
FIGURE 4-13. PLASMA CUTTER ASSEMBLY - 60HZ POWER SUPPLY​
FIGURE 4-14. PLASMA CUTTER ASSEMBLY​
SECTION 5 - CYLINDER
FIGURE 5-1. JIB CYLINDER ASSEMBLY (ORIGINAL EQUIPMENT)​
FIGURE 5-2. JIB CYLINDER ASSEMBLY (SERVICE REPLACEMENT)​
FIGURE 5-3. JIB CYLINDER ASSEMBLY (SERVICE REPLACEMENT)​
FIGURE 5-4. LEVEL CYLINDER ASSEMBLY (ORIGINAL EQUIPMENT) (600SC)​
FIGURE 5-5. LEVEL CYLINDER ASSEMBLY (SERVICE REPLACEMENT) (600SC)​
FIGURE 5-6. LEVEL CYLINDER ASSEMBLY (SERVICE REPLACEMENT) (600SC)​
FIGURE 5-7. LEVEL CYLINDER ASSEMBLY (ORIGINAL EQUIPMENT) (660SJC)​
FIGURE 5-8. LEVEL CYLINDER ASSEMBLIES (SERVICE REPLACEMENT) (660SJC)​
FIGURE 5-9. LEVEL CYLINDER ASSEMBLY (SERVICE REPLACEMENT) (660SJC)​
FIGURE 5-10. LIFT CYLINDER ASSEMBLY​
FIGURE 5-11. MASTER CYLINDER ASSEMBLY​
FIGURE 5-12. MASTER CYLINDER ASSEMBLY (SERVICE REPACEMENT)​
FIGURE 5-13. TELESCOPE CYLINDER ASSEMBLY​
SECTION 6 - HYDRAULIC
FIGURE 6-1. FRAME HYDRAULIC DIAGRAM (CATERPILLAR CHASSIS)​
FIGURE 6-2. FRAME HYDRAULIC DIAGRAM (GRADALL CHASSIS)​
FIGURE 6-3. STANDARD HYDRAULIC DIAGRAM - CATERPILLAR ENGINE (SN 0300128000 through 0300149851)​
FIGURE 6-4. STANDARD HYDRAULIC DIAGRAM - CATERPILLAR ENGINE (SN 0300149852 through 0300174703)​
FIGURE 6-5. STANDARD HYDRAULIC DIAGRAM - DEUTZ ENGINE (SN 0300128000 through 0300169157)​
FIGURE 6-6. STANDARD HYDRAULIC DIAGRAM - DEUTZ ENGINE (SN 0300169158 through 0300174703)​
FIGURE 6-7. HYDRAULIC DIAGRAM LIST​
SECTION 7 - ELECTRICAL
FIGURE 7-1. ELECTRICAL DIAGRAM LIST​
FIGURE 7-2. ELECTRICAL SCHEMATIC (WITHOUT UGM)​
FIGURE 7-3. ELECTRICAL SCHEMATIC (WITH UGM)​
FIGURE 7-4. HARNESS COMPONENTS INSTALLATION (WITHOUT UGM)​
FIGURE 7-5. HARNESS COMPONENTS INSTALLATION (WITH UGM)​
SECTION 8 - DECALS
FIGURE 8-1. DECAL INSTALLATION (ANSI SPECS)​
FIGURE 8-2. DECAL INSTALLATION (ANSI EXPORT SPECS)​
FIGURE 8-3. DECAL INSTALLATION (AUSTRALIAN AND CE SPECS)​
SECTION 9 - RECOMMENDED SERVICE PARTS STOCK
FIGURE 9-1. STANDARD PARTS​
FIGURE 9-2. VARIABLE PARTS​
SECTION 10 - SPECIAL OPTIONS
FIGURE 10-1. SPECIAL OPTIONS LIST​
PART NUMBER INDEX
