JLG Boom Lift 600S HC3 660SJ HC3 Parts Manual 3122564700
Brand: JLG
Type of Machine: Boom Lift
Model: JLG 600S HC3, 660SJ HC3 Boom Lift
Part Number: 3122564700
Publication Date: 2025
Number of Pages: 1036 Pages
SECTION 1 - FRAME
Brand: JLG
SECTION 1 - FRAME
FIGURE 1-1. AXLE INSTALLATION (MACHINES WITH SN STARTING WITH 03)
FIGURE 1-2. AXLE INSTALLATION (MACHINES WITH SN STARTING WITH B3)
FIGURE 1-3. STEER INSTALLATION - WITHOUT TOW PACKAGE
FIGURE 1-4. STEER INSTALLATION - WITH TOW PACKAGE
FIGURE 1-5. WHEEL DRIVE INSTALLATION - 4WD/2WS (MACHINES WITH SN STARTING WITH 03) (600S HC3)
FIGURE 1-6. WHEEL DRIVE INSTALLATION - 4WD/2WS MACHINES WITH SN STARTING WITH 03) (660SJ HC3)
FIGURE 1-7. WHEEL DRIVE INSTALLATION - 4WD/2WS (MACHINES WITH SN STARTING WITH B3)
FIGURE 1-8. DRIVE MOTOR ASSEMBLY (600S HC3)
FIGURE 1-9. DRIVE MOTOR ASSEMBLY (660SJ HC3)
FIGURE 1-10. DRIVE HUB ASSEMBLY (600S HC3)
FIGURE 1-11. DRIVE HUB ASSEMBLY (660SJ HC3)
FIGURE 1-12. TRACTION VALVE ASSEMBLY
FIGURE 1-13. TIRE & WHEEL INSTALLATION - IN355-55 D625 FOAM FILLED (AVAILABLE ON ALL SPECS)
FIGURE 1-14. TIRE & WHEEL INSTALLATION - IN355-55 D625 FOAM FILLED NON-MARKING (AVAILABLE ON ALL SPECS)
FIGURE 1-15. TIRE & WHEEL INSTALLATION - 41-18LL X 22.5 FOAM FILLED TURF & SAND (AVAILABLE ON ALL SPECS EXCEPT AUSTRALIAN, RUSSIA, CE & UK CA SPECS)
FIGURE 1-16. MATTRACKS INSTALLATION
FIGURE 1-17. MATTRACKS INSTALLATION
FIGURE 1-18. LP TANKS AND BRACKETS INSTALLATION (FORD ENGINES)
FIGURE 1-19. FRAME COVERS INSTALLATION - 2WS
FIGURE 1-20. TOW BAR INSTALLATION (OPTIONAL)
SECTION 2 - TURNTABLEFIGURE 2-1. VALVE INSTALLATION (600S HC3)
FIGURE 2-2. VALVE INSTALLATION (660SJ HC3)
FIGURE 2-3. AXLE VALVE ASSEMBLY
FIGURE 2-4. MAIN VALVE ASSEMBLY - 2WS
FIGURE 2-5. SWING DRIVE INSTALLATION
FIGURE 2-6. SWING MOTOR/HUB ASSEMBLY
FIGURE 2-7. TURNTABLE BEARING AND LUBE INSTALLATION
FIGURE 2-8. TURNTABLE LOCK INSTALLATION
FIGURE 2-9. ROTARY COUPLING INSTALLATION
FIGURE 2-10. ROTARY COUPLING ASSEMBLY
FIGURE 2-11. ROTARY COUPLING INSTALLATION (MACHINES WITH SN STARTING WITH B3)
FIGURE 2-12. ROTARY COUPLING ASSEMBLY (MACHINES WITH SN STARTING WITH B3)
FIGURE 2-13. TANKS INSTALLATION - DIESEL MACHINES (POLY FUEL TANK) (HYDRAULIC TANK WITH 6 INCH BREATHER) (600S HC3)
FIGURE 2-14. TANKS INSTALLATION - DIESEL MACHINES (POLY FUEL TANK) (HYDRAULIC TANK WITH 4 INCH BREATHER) (600S HC3)
FIGURE 2-15. TANKS INSTALLATION - DIESEL MACHINES (POLY FUEL TANK) (HYDRAULIC TANK WITH 6 INCH BREATHER) (660SJ HC3)
FIGURE 2-16. TANKS INSTALLATION - DIESEL MACHINES (POLY FUEL TANK) (HYDRAULIC TANK WITH 4 INCH BREATHER) (660SJ HC3)
FIGURE 2-17. TANKS INSTALLATION - DIESEL MACHINES (STEEL FUEL TANK) (HYDRAULIC TANK WITH 6 INCH BREATHER) (600S HC3)
FIGURE 2-18. TANKS INSTALLATION - DIESEL MACHINES (STEEL FUEL TANK) (HYDRAULIC TANK WITH 4 INCH BREATHER) (600S HC3)
FIGURE 2-19. TANKS INSTALLATION - DIESEL MACHINES (STEEL FUEL TANK) (HYDRAULIC TANK WITH 6 INCH BREATHER) (660SJ HC3)
FIGURE 2-20. TANKS INSTALLATION - DIESEL MACHINES (STEEL FUEL TANK) (HYDRAULIC TANK WITH 4 INCH BREATHER) (660SJ HC3)
FIGURE 2-21. TANKS INSTALLATION - GAS MACHINES (HYDRAULIC TANK WITH 6 INCH BREATHER) (600S HC3)
FIGURE 2-22. TANKS INSTALLATION - GAS MACHINES (HYDRAULIC TANK WITH 4 INCH BREATHER) (600S HC3)
FIGURE 2-23. TANKS INSTALLATION - GAS MACHINES (HYDRAULIC TANK WITH 6 INCH BREATHER) (660SJ HC3)
FIGURE 2-24. TANKS INSTALLATION - GAS MACHINES (HYDRAULIC TANK WITH 4 INCH BREATHER) (660SJ HC3)
FIGURE 2-25. HYDRAULIC TANK ASSEMBLY (HYDRAULIC TANK WITH 6 INCH BREATHER)
FIGURE 2-26. HYDRAULIC TANK ASSEMBLY (HYDRAULIC TANK WITH 4 INCH BREATHER)
FIGURE 2-27. HYDRAULIC TANK ASSEMBLY (HYDRAULIC TANK WITH 4 INCH BREATHER)(GAS MACHINES) (660SJ HC3)
FIGURE 2-28. BATTERY AND AUXILIARY PUMP INSTALLATION (MACHINES WITH SN STARTING WITH 03)
FIGURE 2-29. BATTERY AND AUXILIARY PUMP INSTALLATION (MACHINES WITH SN STARTING WITH B3)
FIGURE 2-30. BATTERY AND AUXILIARY PUMP WITH DISCONNECT SWITCH INSTALLATION (MACHINES WITH SN STARTING WITH 03)
FIGURE 2-31. BATTERY AND AUXILIARY PUMP INSTALLATION WITH DISCONNECT SWITCH (MACHINES WITH SN STARTING WITH B3)
FIGURE 2-32. AUXILIARYMOTOR/PUMP ASSEMBLY (MACHINES WITH SN STARTING WITH B3)
FIGURE 2-33. ELECTRICAL COMPONENTS INSTALLATION (ALL SPECS EXCEPT AUSTRALIAN, CE & UK CA (ULS) SPECS)
FIGURE 2-34. ELECTRICAL COMPONENTS INSTALLATION - 1K63FT WITH 2WS (660SJ HC3)
FIGURE 2-35. ELECTRICAL COMPONENTS INSTALLATION - (CE & UK CA (ULS) SPECS)
FIGURE 2-36. ELECTRICAL COMPONENTS INSTALLATION - STANDARD WITH 2WS
FIGURE 2-37. GROUND CONTROL ASSEMBLY - (MACHINES WITH SN STARTING WITH 03 ALL SPECS EXCEPT AUSTRALIAN, CE & UK CA (ULS) SPECS) (600S HC3)
FIGURE 2-38. GROUND CONTROL ASSEMBLY - (MACHINES WITH SN STARTING WITH 03 CE & UK CA (ULS) SPECS) (600S HC3)
FIGURE 2-39. GROUND CONTROL ASSEMBLY (2WS) (CHINA IV) (660SJ HC3)
FIGURE 2-40. LIGHT PANEL INSTALLATION
FIGURE 2-41. KEYSWITCH INSTALLATION - (ANSI, ANSI EXPORT, CHINA, CSA AND JAPANESE SPECS) (600S HC3)
FIGURE 2-42. KEYSWITCH INSTALLATION - (RUSSIA, CE & UK CA SPECS) (600S HC3)
FIGURE 2-43. KEYSWITCH INSTALLATION - (ANSI, ANSI EXPORT, AUSTRALIAN, CHINA, CSA AND JAPANESE SPECS) (660SJ HC3)
FIGURE 2-44. KEYSWITCH INSTALLATION - (WITHOUT JIB) (WITH MSSO) (CE & UK CA SPECS) (660SJ HC3)
FIGURE 2-45. KEYSWITCH INSTALLATION - (WITH JIB) (WITH MSSO) (CE & UK CA SPECS) (660SJ HC3)
FIGURE 2-46. HOODS INSTALLATIONS - ABS - DEUTZ D2011, DEUTZ TD 2.9L4 67HP AND FORD ENGINES
FIGURE 2-47. HOODS INSTALLATIONS - ABS - DEUTZ TD 2.2L3 AND DEUTZ TD 2.9L4 49HP ENGINES
FIGURE 2-48. HOOD ASSEMBLY - ENGINE SIDE (ABS)
FIGURE 2-49. HOOD ASSEMBLY - TANK SIDE (ABS)
FIGURE 2-50. HOODS INSTALLATIONS - STEEL - DEUTZ D2011, DEUTZ TD 2.9L4 67HP AND FORD ENGINES (SN STARTING WITH 03)
FIGURE 2-51. HOODS INSTALLATIONS - STEEL - DEUTZ TD 2.2L3 AND DEUTZ TD 2.9L4 49HP ENGINES
FIGURE 2-52. HOOD ASSEMBLY - ENGINE SIDE (STEEL) - DEUTZ D2011, DEUTZ TD2.3L3 DEUTZ TD 2.9L4 49HP & 67HP AND FORD ENGINES
FIGURE 2-53. HOOD ASSEMBLY - TANK SIDE (STEEL) - DEUTZ D2011, DEUTZ TD2.3L3 DEUTZ TD 2.9L4 49HP & 67HP AND FORD ENGINES
FIGURE 2-54. HOODS INSTALLATIONS - STEEL - DEUTZ D2011 WITH ARCTIC AND DEUTZ TD2.2L3 ENGINES (SN STARTING WITH B3) (660SJ HC3)
FIGURE 2-55. HOODS INSTALLATION - STEEL (MACHINES WITH SN STARTING WITH B3) (DEUTZ D2.9L4 (CHINA IV) ENGINES)
FIGURE 2-56. HOOD ASSEMBLY - ENGINE SIDE (STEEL) - DEUTZ D2011 WITH ARCTIC AND DEUTZ TD2.2L3 ENGINES (660SJ HC3)
FIGURE 2-57. HOOD ASSEMBLY - ENGINE SIDE (STEEL) - DEUTZ D2011 WITH ARCTIC AND DEUTZ TD2.2L3 ENGINES (660SJ HC3)
FIGURE 2-58. HOOD ASSEMBLY - TANK SIDE (STEEL) - DEUTZ D2011 WITH ARCTIC AND DEUTZ TD2.2L3 ENGINES (660SJ HC3)
FIGURE 2-59. SIDE-SHEET ASSEMBLY - TANK SIDE (STEEL) - DEUTZ D2011 WITH ARCTIC AND DEUTZ TD2.2L3 ENGINES (660SJ HC3)
FIGURE 2-60. SIDE-SHEET ASSEMBLY - ENGINE SIDE (STEEL) - DEUTZ D2011 WITH ARCTIC AND DEUTZ TD2.2L3 ENGINES (660SJ HC3)
FIGURE 2-61. HOOD INSTALLTION - DCPD (ALL SPECS EXCEPT CHINEESE, CE & UK CA) (MACHINES WITH SN STARTING WITH B3)
FIGURE 2-62. HOOD INSTALLTION - DCPD (CHINEESE, CE & UK CA SPECS) (MACHINES WITH SN STARTING WITH B3)
FIGURE 2-63. HOOD ASSEMBLY - DCPD (CHINEESE, CE & UK CA SPECS) (MACHINES WITH SN STARTING WITH B3)
FIGURE 2-64. HOOD ASSEMBLY - DCPD (CHINEESE, CE & UK CA SPECS) (MACHINES WITH SN STARTING WITH B3)
FIGURE 2-65. NOISE REDUCTION PACKAGE (600S HC3)
FIGURE 2-66. NOISE REDUCTION PACKAGE (660SJ HC3)
FIGURE 2-67. STROBE LIGHT INSTALLATION - AMBER
FIGURE 2-68. STROBE LIGHT INSTALLATION - BLUE
FIGURE 2-69. STROBE LIGHT INSTALLATION - RED
FIGURE 2-70. TURNTABLE COVERS INSTALLATION
FIGURE 2-71. WHITE NOISE ALARM INSTALLATION (AMBIENT)
FIGURE 2-72. WHITE NOISE ALARM INSTALLATION (CONSTANT)
SECTION 3 - ENGINEFIGURE 3-1. DEUTZ D2011 ENGINE INSTALLATION - WITHOUT ARCTIC PACKAGE (MACHINES WITH SN STARTING WITH 03) (600S HC3)
FIGURE 3-2. DEUTZ D2011 ENGINE INSTALLATION - WITHOUT ARCTIC PACKAGE (MACHINES WITH SN STARTING WITH 03) (660SJ HC3)
FIGURE 3-3. DEUTZ D2011 ENGINE INSTALLATION - WITHOUT ARCTIC PACKAGE (MACHINES WITH SN STARTING WITH B3) (660SJ HC3)
FIGURE 3-4. DEUTZ D2011 ENGINE AND PUMPS SUB-ASSEMBLY - WITHOUT ARCTIC PACKAGE (600S HC3/660SJ HC3) (MACHINES WITH SN STARTING WITH 03)
FIGURE 3-5. DEUTZ D2011 ENGINE AND PUMPS SUB-ASSEMBLY - WITHOUT ARCTIC PACKAGE (MACHINES WITH SN STARTING WITH B3) (660SJ HC3)
FIGURE 3-6. DEUTZ D2011 ENGINE ASSEMBLY - WITHOUT ARCTIC PACKAGE (600S HC3/660SJ HC3)
FIGURE 3-7. DEUTZ D2011 ENGINE INSTALLATION - WITH ARCTIC PACKAGE (MACHINES WITH SN STARTING WITH 03) (600S HC3)
FIGURE 3-8. DEUTZ D2011 ENGINE INSTALLATION - WITH ARCTIC PACKAGE (MACHINES WITH SN STARTING WITH 03) (660SJ HC3)
FIGURE 3-9. DEUTZ D2011 ENGINE INSTALLATION - WITH ARCTIC PACKAGE (MACHINES WITH SN STARTING WITH B3) (660SJ HC3)
FIGURE 3-10. DEUTZ D2011 ENGINE AND PUMPS SUB-ASSEMBLY - WITH ARCTIC PACKAGE (600S HC3/660SJ HC3) (MACHINES WITH SN STARTING WITH 03)
FIGURE 3-11. DEUTZ D2011 ENGINE AND PUMPS SUB-ASSEMBLY - WITH ARCTIC PACKAGE (MACHINES WITH SN STARTING WITH B3) (660SJ HC3)
FIGURE 3-12. DEUTZ D2011 ENGINE ASSEMBLY - WITH ARCTIC PACKAGE (600S HC3/660SJ HC3)
FIGURE 3-13. DEUTZ D2011 ENGINE COMPONENTS (600S HC3/660SJ HC3)
FIGURE 3-14. DEUTZ TD 2.2L3 (STAGE V) ENGINE INSTALLATION
FIGURE 3-15. DEUTZ TD 2.2L3 (STAGE V) ENGINE INSTALLATION (660SJ HC3)
FIGURE 3-16. DEUTZ TD2.2L3 (STAGE V) ENGINE AND PUMPS SUB-ASSEMBLY
FIGURE 3-17. DEUTZ TD2.2L3 (STAGE V) ENGINE ASSEMBLY (600S HC3/660SJ HC3)
FIGURE 3-18. DEUTZ TD2.2L3 (STAGE V) ENGINE COMPONENTS
FIGURE 3-19. DEUTZ D2.9L4 - EMR5 (49HP) 600S HC3 ENGINE INSTALLATION WITHOUT ARCTIC PACKAGE
FIGURE 3-20. DEUTZ D2.9L4 - EMR5 (49HP) 660SJ HC3 ENGINE INSTALLATION WITHOUT ARCTIC PACKAGE (660SJ HC3)
FIGURE 3-21. DEUTZ D2.9L4 - EMR5 (49HP) ENGINE AND PUMPS SUB-ASSEMBLY WITHOUT ARCTIC PACKAGE
FIGURE 3-22. DEUTZ D2.9L4 - EMR5 (49HP) ENGINE ASSEMBLY WITHOUT ARCTIC PACKAGE
FIGURE 3-23. DEUTZ D2.9L4 - EMR5 (49HP) 600S HC3 ENGINE INSTALLATION WITH ARCTIC PACKAGE
FIGURE 3-24. DEUTZ D2.9L4 - EMR5 (49HP) 660SJ HC3 ENGINE INSTALLATION WITH ARCTIC PACKAGE (660SJ HC3)
FIGURE 3-25. DEUTZ D2.9L4 - EMR5 (49HP) ENGINE AND PUMPS SUB-ASSEMBLY WITH ARCTIC PACKAGE
FIGURE 3-26. DEUTZ D2.9L4 - EMR5 (49HP) ENGINE ASSEMBLY WITH ARCTIC PACKAGE
FIGURE 3-27. ENGINE COMPONENTS - DEUTZ D2.9L4 EMR5 ENGINE (ANSI, ANSI EXPORT AND CSA SPECS
FIGURE 3-28. DEUTZ D2.9L4 - EMR5 (67HP) 660SJ HC3 ENGINE INSTALLATION WITH ARCTIC PACKAGE (660SJ HC3)
FIGURE 3-29. DEUTZ D2.9L4 - EMR5 (67HP) 600S HC3 ENGINE INSTALLATION WITH ARCTIC PACKAGE
FIGURE 3-30. DEUTZ D2.9L4 - EMR5 (67HP) ENGINE AND PUMPS SUB-ASSEMBLY WITH ARCTIC PACKAGE
FIGURE 3-31. DEUTZ D2.9L4 - EMR5 (67HP) ENGINE ASSEMBLY WITH ARCTIC PACKAGE
FIGURE 3-32. DEUTZ D2.9L4 - EMR5 (67HP) 660SJ HC3 ENGINE INSTALLATION WITHOUT ARCTIC PACKAGE (660SJ HC3)
FIGURE 3-33. DEUTZ D2.9L4 - EMR5 (67HP) 600S HC3 ENGINE INSTALLATION WITHOUT ARCTIC PACKAGE
FIGURE 3-34. DEUTZ D2.9L4 - EMR5 (67HP) ENGINE AND PUMPS SUB-ASSEMBLY WITHOUT ARCTIC PACKAGE
FIGURE 3-35. DEUTZ D2.9L4 - EMR5 (67HP) ENGINE ASSEMBLY WITHOUT ARCTIC PACKAGE
FIGURE 3-36. ENGINE COMPONENTS - DEUTZ D2.9L4 EMR5 (67HP) ENGINE
FIGURE 3-37. RADIATOR ASSEMBLY
FIGURE 3-38. DEUTZ D2.9L4 ENGINE INSTALLATION
FIGURE 3-39. DEUTZ D2.9L4 ENGINE AND PUMP SUB-ASSEMBLY
FIGURE 3-40. DEUTZ D2.9L4 ENGINE ASSEMBLY
FIGURE 3-41. DEUTZ D2.9L4 ENGINE COMPONENTS
FIGURE 3-42. BREATHER HEATER INSTALLATION - DEUTZ D2.9L4 - 49HP AND DEUTZ TD2.9L4 - 67HP ENGINES WITH ARCTIC PACKAGE
FIGURE 3-43. FORD ENGINE INSTALLATION - WITHOUT ARCTIC PACKAGE
FIGURE 3-44. FORD ENGINE INSTALLATION - WITHOUT ARCTIC PACKAGE (660SJ HC3)
FIGURE 3-45. FORD ENGINE AND PUMPS SUB-ASSEMBLY WITHOUT ARCTIC PACKAGE
FIGURE 3-46. FORD ENGINE ASSEMBLY - WITHOUT ARCTIC PACKAGE
FIGURE 3-47. FORD ENGINE INSTALLATION – WITH ARCTIC PACKAGE
FIGURE 3-48. FORD ENGINE INSTALLATION - WITH ARCTIC PACKAGE (660SJ HC3)
FIGURE 3-49. FORD ENGINE AND PUMPS SUB-ASSEMBLY WITH ARCTIC PACKAGE
FIGURE 3-50. FORD ENGINE ASSEMBLY - WITH ARCTIC PACKAGE
FIGURE 3-51. FORD ENGINE PREP ASSEMBLY (600S HC3/660SJ HC3)
FIGURE 3-52. FORD ENGINE COMPONENTS (600S HC3/660SJ HC3)
FIGURE 3-53. PUMP COUPLING KIT (DEUTZ ENGINES)
FIGURE 3-54. PISTON PUMP ASSEMBLY - ALL ENGINES EXCEPT DUETZ D2011 ENGINES ON MACHINES WITH SN STARTING WITH B3
FIGURE 3-55. PISTON PUMP ASSEMBLY - DUETZ D2011 ENGINES ON MACHINES WITH SN STARTING WITH B3
FIGURE 3-56. FUEL FILTER INSTALLATION (POLY FUEL TANK)
FIGURE 3-57. FUEL FILTER INSTALLATION (STEEL FUEL TANK) (DEUTZ D2011 ENGINES)
FIGURE 3-58. FUEL FILTER INSTALLATION (STEEL FUEL TANK) (DEUTZ DT2.9L4 ENGINES)
FIGURE 3-59. FUEL FILTER INSTALLATION (PLASTIC FUEL TANK) (DEUTZ D2.9L4 ENGINES) (MACHINES WITH SN STARTING WITH B3)
FIGURE 3-60. FUEL FILTER INSTALLATION (STEEL FUEL TANK) (DEUTZ D2.9L4 ENGINES) (MACHINES WITH SN STARTING WITH B3)
FIGURE 3-61. MUFFLER INSTALLATION - SPARK ARRESTING (DEUTZ D2011 ENGINES)
FIGURE 3-62. EXHAUST PIPE INSTALLATION - (DEUTZ D2011 ENGINES)
FIGURE 3-63. MOTOR MOUNT INSTALLATION - WITHOUT GENERATOR (DEUTZ D2011 ENGINES)
FIGURE 3-64. MOTOR MOUNT INSTALLATION - WITHOUT GENERATOR (DEUTZ TD 2.9L4 ENGINES)
FIGURE 3-65. MOTOR MOUNT INSTALLATION - WITH GENERATOR (DEUTZ D2011 ENGINES)
FIGURE 3-66. MOTOR MOUNT INSTALLATION - WITH GENERATOR (DEUTZ TD 2.9L4 ENGINES)
FIGURE 3-67. MOTOR MOUNT INSTALLATION - WITH GENERATOR (STAGE V) (DEUTZ TD 2.2L3 ENGINES)
FIGURE 3-68. MOTOR MOUNT INSTALLATION - WITHOUT GENERATOR (STAGE V) (DEUTZ TD 2.2L3 ENGINES)
FIGURE 3-69. MOTOR MOUNT INSTALLATION - WITH GENERATOR (DEUTZ TD 2.9L4 49HP ENGINES)
FIGURE 3-70. MOTOR MOUNT INSTALLATION - WITHOUT GENERATOR (DEUTZ TD 2.9L4 49HP ENGINES)
FIGURE 3-71. BELT WITHOUT GENERATOR INSTALLATION (FORD ENGINES)
FIGURE 3-72. TRAY JACK INSTALLATION
FIGURE 3-73. TRAY JACK INSTALLATION (STAGE V)
FIGURE 3-74. ENGINE HOOD BAFFLES INSTALLATION - ABS HOODS
FIGURE 3-75. ENGINE HOOD BAFFLES INSTALLATION - STEEL HOODS
FIGURE 3-76. ENGINE HOOD BAFFLES INSTALLATION - ABS HOODS (DEUTZ TD 2.2L3 ENGINES AND TD 2.9L4 49HP ENGINES)
FIGURE 3-77. ENGINE HOOD BAFFLES INSTALLATION - STEEL HOODS (DEUTZ TD 2.2L3 ENGINES AND TD 2.9L4 49HP ENGINES)
FIGURE 3-78. 2500W GENERATOR INSTALLATION - 110V/60HZ (DEUTZ D2011 ENGINES)
FIGURE 3-79. 2500W GENERATOR INSTALLATION - 110V/60HZ (DEUTZ TD2.9L4 ENGINES)
FIGURE 3-80. 2500W GENERATOR INSTALLATION - 110V/60HZ (FORD ENGINES)
FIGURE 3-81. 2500W GENERATOR INSTALLATION - 220V/50HZ (DEUTZ D2011 ENGINES)
FIGURE 3-82. 2500W GENERATOR INSTALLATION - 120V/60HZ (DEUTZ TD2.9L4 ENGINES)
FIGURE 3-83. 4000W GENERATOR INSTALLATION - 110V/60HZ (DEUTZ D2011 ENGINES)
FIGURE 3-84. 4000W GENERATOR INSTALLATION - 110V/60HZ (DEUTZ TD2.9L4 ENGINES)
FIGURE 3-85. 4000W GENERATOR INSTALLATION - 220V/50HZ (DEUTZ D2011 ENGINES)
FIGURE 3-86. 4000W GENERATOR INSTALLATION - 220V/50HZ (DEUTZ TD2.2L3 ENGINES) (SKYPOWER)
FIGURE 3-87. 4000W GENERATOR INSTALLATION - 220V/60HZ (DEUTZ TD2.9L4 ENGINES) (SKYPOWER)
FIGURE 3-88. 7500W GENERATOR INSTALLATION - 220V/60HZ (DEUTZ TD2.9L4 ENGINES) (SKYPOWER)
FIGURE 3-89. 7500W SKYPOWER GENERATOR INSTALLATION - 110/60HZ (DEUTZ D2011 ENGINES)
FIGURE 3-90. 7500W SKYPOWER GENERATOR INSTALLATION - 110V/60HZ (DEUTZ TD2.9L4 ENGINES)
FIGURE 3-91. 7500W SKYPOWER GENERATOR INSTALLATION - 110V/60HZ (FORD ENGINES)
FIGURE 3-92. 7500W SKYPOWER GENERATOR INSTALLATION - 220V/50HZ (DEUTZ D2011 ENGINES)
FIGURE 3-93. QUICKFIT OIL DRAIN (DEUTZ ENGINES)
SECTION 4 - BOOMFIGURE 4-1. BOOM INSTALLATION (600S HC3)
FIGURE 4-2. BOOM INSTALLATION (ALL SPECS EXCEPT CE SPECS WITH SN STARTING WITH B3) (660SJ HC3)
FIGURE 4-3. BOOM INSTALLATION (MACHINES BUILT WITH SN STARTING WITH B3) (ALL SPECS EXCEPT CE)
FIGURE 4-4. BOOM ASSEMBLY (600S HC3)
FIGURE 4-5. BOOM ASSEMBLY (ALL SPECS EXCEPT CE SPECS WITH SN STARTING WITH B3) (660SJ HC3)
FIGURE 4-6. BOOM ASSEMBLY (MACHINES BUILT WITH SN STARTING WITH B3) (ALL SPECS EXCEPT CE)
FIGURE 4-7. JIB ASSEMBLY (660SJ HC3)
FIGURE 4-8. JIB ASSEMBLY (MACHINES WITH SN STARTING WITH B3)
FIGURE 4-9. PLATFORM ROTATOR ASSEMBLY (600S HC3)
FIGURE 4-10. PLATFORM ROTATOR ASSEMBLY (660SJ HC3)
FIGURE 4-11. PLATFORM ROTATOR ASSEMBLY (MACHINES WITH SN STARTING WITH B3)
FIGURE 4-12. POWER TRACK INSTALLATION (600S HC3)
FIGURE 4-13. POWER TRACK ASSEMBLY (WITH SN STARTING WITH 03) (660SJ HC3)
FIGURE 4-14. POWER TRACK ASSEMBLY (WITH SN STARTING WITH B3) (660SJ HC3)
FIGURE 4-15. VALVE INSTALLATION (600S HC3)
FIGURE 4-16. BOOM VALVES INSTALLATION - WITH 2WS (660SJ HC3)
FIGURE 4-17. PLATFORM VALVE ASSEMBLY (600S HC3)
FIGURE 4-18. PLATFORM VALVE ASSEMBLY (660SJ HC3)
FIGURE 4-19. BOOM SENSORS INSTALLATION (600S HC3)
FIGURE 4-20. BOOM SENSORS INSTALLATION (660SJ HC3)
FIGURE 4-21. RAPID REPLACEABLE PLATFORM SUPPORT (MACHINES WITH SN STARTING WITH 03) (660SJ HC3)
FIGURE 4-22. RAPID REPLACEABLE PLATFORM SUPPORT (MACHINES WITH SN STARTING WITH 03) (600S HC3)
FIGURE 4-23. RAPID REPLACEABLE PLATFORM SUPPORT (MACHINES WITH SN STARTING WITH B3 OR C3)
SECTION 5 - PLATFORMFIGURE 5-1. TRADITIONAL PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) WITH FALL ARREST (ALL SPECS EXCEPT CE AND AUSTRALIAN SPECS) (MACHINES WITH SN STARTING WITH 03)
FIGURE 5-2. TRADITIONAL PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) WITH FALL ARREST (ALL SPECS EXCEPT CE AND AUSTRALIAN SPECS) (MACHINES WITH SN STARTING WITH B3 OR C3)
FIGURE 5-3. TRADITIONAL PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH FALL ARREST
FIGURE 5-4. TRADITIONAL PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH FALL ARREST (MACHINES WITH SN STARTING WITH B3 OR C3)
FIGURE 5-5. TRADITIONAL PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH TRI-ENTRY (MACHINES WITH SN STARTING WITH B3 OR C3)
FIGURE 5-6. TRADITIONAL PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH TRI-ENTRY (MACHINES WITH SN STARTING WITH 03)
FIGURE 5-7. RAPID REPLACEABLE PLATFORM (30IN X 4FT (76CM X 1.22M) (MACHINES WITH SN STARTING WITH 03)
FIGURE 5-8. RAPID REPLACEABLE PLATFORM (30IN X 4FT (76.2CM X 1.22M) (MACHINES WITH SN STARTING WITH B3 OR C3)
FIGURE 5-9. RAPID REPLACEABLE PLATFORM (30IN X 5FT (76.2CM X 1.52M) (MACHINES WITH SN STARTING WITH 03)
FIGURE 5-10. RAPID REPLACEABLE PLATFORM (30IN X 5FT (76.2CM X 1.52M) (MACHINES WITH SN STARTING WITH B3 OR C3)
FIGURE 5-11. RAPID REPLACEABLE PLATFORM (36IN X 6FT (91.5CM X 1.83M) (MACHINES WITH SN STARTING WITH 03)
FIGURE 5-12. RAPID REPLACEABLE PLATFORM (36IN X 6FT (91.5CM X 1.83M) (MACHINES WITH SN STARTING WITH B3 OR C3)
FIGURE 5-13. RAPID REPLACEABLE PLATFORM (36IN X 8FT (91.5CM X 2.44M) (MACHINES WITH SN STARTING WITH 03)
FIGURE 5-14. RAPID REPLACEABLE PLATFORM (36IN X 8FT (91.5CM X 2.44M) (MACHINES WITH SN STARTING WITH B3 OR C3)
FIGURE 5-15. PLATFORM - SWING GATE INSTALLATION (MACHINES WITH SN STARTING WITH 03)
FIGURE 5-16. PLATFORM SWING GATE INSTALLATION (MACHINES WITH SN STARTING WITH B3 OR C3)
FIGURE 5-17. PLATFORM - DROP BAR INSTALATION (MACHINES WITH SN STARTING WITH 03)
FIGURE 5-18. PLATFORM DROP BAR INSTALLATION (MACHINES WITH SN STARTING WITH B3 OR C3)
FIGURE 5-19. PLATFORM BEACON INSTALLATION
FIGURE 5-20. PLATFORM POWER USB
FIGURE 5-21. TRAY ASSEMBLY
FIGURE 5-22. PLATFORM CONSOLE AND FOOTSWITCH INSTALLATION (ALL SPECS EXCEPT AUSTRALIAN AND CE UK & CA)
FIGURE 5-23. PLATFORM CONSOLE AND FOOTSWITCH INSTALLATION
FIGURE 5-24. PLATFORM CONSOLE AND FOOTSWITCH ASSEMBLY
FIGURE 5-25. PLATFORM CONSOLE AND FOOTSWITCH ASSEMBLY
FIGURE 5-26. FOOTSWITCH ASSEMBLY
FIGURE 5-27. LIGHT PANEL INSTALLATION
FIGURE 5-28. SKYLINE INSTALLATION
FIGURE 5-29. SKYWELDER INSTALLATION (50HZ)
FIGURE 5-30. SKYWELDER INSTALLATION (60HZ)
FIGURE 5-31. SKYWELDER PREP PACKAGE (60HZ)
FIGURE 5-32. WELDER ASSEMBLY
FIGURE 5-33. WELDER ASSEMBLY (CST282)
FIGURE 5-34. SKYGLAZIER INSTALLATION
FIGURE 5-35. SOFT TOUCH INSTALLATION - 6FT (1.83M) PLATFORM
FIGURE 5-36. SOFT TOUCH INSTALLATION - 6FT (1.83M) FALL ARREST PLATFORM (600S HC3)
FIGURE 5-37. SOFT TOUCH INSTALLATION - 8FT (2.4M) PLATFORM
FIGURE 5-38. SOFT TOUCH INSTALLATION - 8FT (2.4M) FALL ARREST PLATFORM (600S)
FIGURE 5-39. FALL ARREST INSTALLATION (BOLT-ON EXTERNAL) (6FT/1.82M PLATFORM)
FIGURE 5-40. FALL ARREST INSTALLATION (BOLT-ON EXTERNAL) (2.5FT/1.22M PLATFORM)
FIGURE 5-41. FALL ARREST INSTALLATION (BOLT-ON EXTERNAL) (2.5FT/1.52M PLATFORM)
FIGURE 5-42. FALL ARREST INSTALLATION (BOLT-ON EXTERNAL) (8FT/2.4M PLATFORM)
SECTION 6 - CYLINDERFIGURE 6-1. AXLE LOCKOUT CYLINDER ASSEMBLY (MACHINES WITH SN STARTING WITH 03)
FIGURE 6-2. AXLE LOCKOUT CYLINDER ASSEMBLY (MACHINES WITH SN STARTING WITH B3)
FIGURE 6-3. LEVEL CYLINDER ASSEMBLY - PLATFORM SLAVE (600S HC3)
FIGURE 6-4. LEVEL CYLINDER ASSEMBLY - PLATFORM SLAVE (660SJ HC3)
FIGURE 6-5. LIFT CYLINDER ASSEMBLY BOOM (600S HC3)
FIGURE 6-6. LIFT CYLINDER ASSEMBLY BOOM (660SJ HC3)
FIGURE 6-7. LIFT CYLINDER ASSEMBLY - JIB (660SJ HC3)
FIGURE 6-8. LIFT CYLINDER ASSEMBLY - JIB (660SJ HC3)
FIGURE 6-9. LIFT CYLINDER ASSEMBLY - JIB (660SJ HC3)
FIGURE 6-10. STEER CYLINDER ASSEMBLY
FIGURE 6-11. TELESCOPE CYLINDER ASSEMBLY (600S HC3 & 660SJ HC3)
FIGURE 6-12. TELESCOPE CYLINDER ASSEMBLY (MACHINES WITH SN STARTING WITH B3 & ALL SPECS EXCEPT CE SPECS)
SECTION 7 - HYDRAULICFIGURE 7-1. DRIVE HYDRAULIC DIAGRAM (2WS WITHOUT ARCTIC PACKAGE) (600S HC3)
FIGURE 7-2. DRIVE HYDRAULIC DIAGRAM (2WS WITHOUT ARCTIC PACKAGE) (660SJ HC3)
FIGURE 7-3. DRIVE HYDRAULIC DIAGRAM (2WS WITH ARCTIC PACKAGE) (600S HC3)
FIGURE 7-4. DRIVE HYDRAULIC DIAGRAM (2WS WITH ARCTIC PACKAGE) (660SJ HC3)
FIGURE 7-5. STANDARD HYDRAULIC DIAGRAM (600S HC3)
FIGURE 7-6. STANDARD HYDRAULIC DIAGRAM (MACHINES WITH SN STARTING WITH 03) (660SJ HC3)
FIGURE 7-7. STANDARD HYDRAULIC DIAGRAM (MACHINES WITH SN STARTING WITH B3) (660SJ HC3)
FIGURE 7-8. VALVE ASSEMBLY
SECTION 8 - ELECTRICALFIGURE 8-1. ELECTRICAL LAYOUT
FIGURE 8-2. AC BOX AT PLATFORM INSTALLATION - 110V (ALL SPECS EXCEPT AUSTRALIAN, RUSSIA, CE & UK CA SPECS)
FIGURE 8-3. AC BOX AT PLATFORM INSTALLATION - 110V IEC YELLOW (RUSSIA, CE & UK CA SPECS WITH 4000W/50HZ GENERATOR)
FIGURE 8-4. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE (RUSSIA, CE & UK CA SPECS WITH 4000W/50HZ GENERATOR)
FIGURE 8-5. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 2IN X 4IN SIDE GROUND (RUSSIA, CE & UK CA SPECS WITH 4000W/50HZ GENERATOR)
FIGURE 8-6. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 2IN X 4IN SIDE GROUND (RUSSIA, CE & UK CA SPECS WITH 4000W/50HZ GENERATOR)
FIGURE 8-7. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT107 (RUSSIA, CE & UK CA SPECS WITH 4000W/50HZ GENERATOR)
FIGURE 8-8. AC BOX AT PLATFORM INSTALLATION - 220V CUSTOMER SUPPLIED COMPONENTS (ANSI EXPORT, AUSTRALIAN, RUSSIA, CHINA, CE & UK CA SPECS)
FIGURE 8-9. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 POST GROUND (MACHINES WITH SN STARTING WITH 03)
FIGURE 8-10. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 SIDE GROUND (MACHINES WITH SN STARTING WITH 03)
FIGURE 8-11. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT107 (CE & UK CA SPECS WITHOUT 4000S/50HZ GENERATOR) (MACHINES WITH SN STARTING WITH 03)
FIGURE 8-12. AC BOX AT PLATFORM INSTALLATION - 110C IEC YELLOW (CE & UK CA SPECS WITHOUT 4000S/50HZ GENERATOR) (MACHINES WITH SN STARTING WITH 03)
FIGURE 8-13. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE (CE & UK CA SPECS WITHOUT 4000S/50HZ GENERATOR) (MACHINES WITH SN STARTING WITH 03)
FIGURE 8-14. AC BOX AT PLATFORM INSTALLATION - 240V (WITH 4000W GENERATOR)
FIGURE 8-15. AC BOX AT PLATFORM INSTALLATION - 240V (WITH 7500W SKYPOWER GENERATOR)
FIGURE 8-16. AC BREAKER BOX INSTALLATION - SINGLE DOUBLE POLE BREAKER
FIGURE 8-17. AC BREAKER BOX INSTALLATION - SINGLE DOUBLE POLE BREAKER (MACHINES WITH SN STARTING WITH B3)
FIGURE 8-18. AC BREAKER BOX INSTALLATION - 3 BREAKERS
FIGURE 8-19. AC CABLES AND CLAMPS INSTALLATION - WITHOUT GENERATOR (ANSI, CSA & JAPANESE SPECS) (600S HC3)
FIGURE 8-20. AC CABLES AND CLAMPS INSTALLATION - WITHOUT GENERATOR (ANSI EXPORT,CE, RUSSIA CIS, CHINA & UK CA SPECS) (600S HC3)
FIGURE 8-21. AC CABLES AND CLAMPS INSTALLATION - WITH 2500W GENERATOR (ANSI, ANSI EXPORT, CHINA, CSA AND JAPANESE SPECS) (600S HC3)
FIGURE 8-22. AC CABLES AND CLAMPS INSTALLATION - WITH 4000W/50HZ GENERATOR (ANSI EXPORT, CE, CHINA, RUSSIAN CIS & UK CA SPECS) (600S HC3)
FIGURE 8-23. AC CABLES AND CLAMPS INSTALLATION - WITH 4000W/60HZ GENERATOR (ANSI, ANSI EXPORT, CSA AND JAPANESE SPECS) (600S HC3)
FIGURE 8-24. AC CABLES AND CLAMPS INSTALLATION - WITH 7500W GENERATOR (ANSI, ANSI EXPORT, CHINA, CSA, RUSSIAN CIS AND JAPANESE SPECS) (600S HC3)
FIGURE 8-25. AC CABLES AND CLAMPS INSTALLATION - WITHOUT GENERATOR (ANSI, CSA AND JAPANESE SPECS) (660SJ HC3)
FIGURE 8-26. AC CABLES AND CLAMPS INSTALLATION - WITHOUT GENERATOR (ANSI EXPORT, AUSTRALIAN, RUSSIA CIS, CHINA, CE & UK CA SPECS) (660SJ HC3)
FIGURE 8-27. AC CABLES AND CLAMPS INSTALLATION - WITH 2500W GENERATOR (ANSI, ANSI EXPORT, CHINA, CSA AND JAPANESE SPECS) (660SJ HC3)
FIGURE 8-28. AC CABLES AND CLAMPS INSTALLATION - WITH 4000W/50HZ GENERATOR (ANSI EXPORT, AUSTRALIAN, RUSSIA CIS, CHINA, CE & UK CA SPECS) (660SJ HC3)
FIGURE 8-29. AC CABLES AND CLAMPS INSTALLATION - WITH 4000W/60HZ GENERATOR (ANSI, ANSI EXPORT, CSA AND JAPANESE SPECS) (660SJ HC3)
FIGURE 8-30. AC CABLES AND CLAMPS INSTALLATION - WITH 7500W GENERATOR (ANSI, ANSI EXPORT, AUSTRALIAN, CHINA, CSA, RUSSIAN CIS, AND JAPANESE SPECS) (660SJ HC3)
FIGURE 8-31. BATTERY DISCONNECT SWITCH INSTALLATION
FIGURE 8-32. BEACON JUMPER HARNESS
FIGURE 8-33. BREAKER BOX KIT - SINGLE DOUBLE POLE BREAKER (WITHOUT 4000W/50HZ GENERATOR)
FIGURE 8-34. BREAKER BOX KIT - SINGLE DOUBLE POLE BREAKER (WITH 4000W/50HZ GENERATOR)
FIGURE 8-35. BREAKER BOX KIT - SINGLE DOUBLE POLE BREAKER (WITHOUT 4000W/50HZ GENERATOR) (MACHINES WITH SN STARTING WITH B3)
FIGURE 8-36. BREAKER BOX KIT - 3 BREAKERS
FIGURE 8-37. BOOM ANGLE SENSOR HARNESS
FIGURE 8-38. BOOM CABLE - LOWER
FIGURE 8-39. BOOM CABLE - UPPER (600S HC3)
FIGURE 8-40. BOOM CABLE - UPPER (660SJ HC3)
FIGURE 8-41. CAPACITY PROXIMITY HARNESS (1000LBS)
FIGURE 8-42. CAPACITY PROXIMITY HARNESS (750 LBS)
FIGURE 8-43. CLEARSKY CS550 BEACON INSTALLATION - WITH PLASTIC HOODS
FIGURE 8-44. CLEARSKY CS550 BEACON INSTALLATION - WITH STEEL HOODS
FIGURE 8-45. ECU POWER JUMPER HARNESS
FIGURE 8-46. ELECTRICAL COMPONENTS INSTALLATION - (ALL SPECS EXCEPT AUSTRALIAN, CE & UK CA (ULS) SPECS) (600S HC3)
FIGURE 8-47. ELECTRICAL COMPONENTS INSTALLATION - 1K63FT WITH 2WS (660SJ HC3)
FIGURE 8-48. ELECTRICAL COMPONENTS INSTALLATION - (CE & UK CA (ULS) SPECS)
FIGURE 8-49. ELECTRICAL COMPONENTS INSTALLATION - WITH 2WS (660SJ HC3)
FIGURE 8-50. ENGINE HARNESS - DEUTZ D2011 ENGINES
FIGURE 8-51. ENGINE HARNESS - DEUTZ D2.9L4 (CHINA IV)
FIGURE 8-52. ENGINE HARNESS - DEUTZ D2.9L4 - 49HP AND DEUTZ TD2.9L4 - 67HP ENGINES
FIGURE 8-53. ENGINE HARNES - DEUTZ TD2.9L4 (EMR ENGINE)
FIGURE 8-54. ENGINE HARNESS - FORD ENGINES
FIGURE 8-55. ENGINE HARNESS - DEUTZ TD2.2L3 ENGINES
FIGURE 8-56. FUEL FILTER HARNESS - DEUTZ TD2.2L3 (STAGE V) ENGINES
FIGURE 8-57. FUEL PUMP HARNESS - DEUTZ TD2.9L4 ENGINE
FIGURE 8-58. FUEL PUMP HARNESS - DEUTZ D2.9L4 - 49HP AND DEUTZ TD2.9L4 - 67HP ENGINES
FIGURE 8-59. GENERATOR HARNESS - 2500W
FIGURE 8-60. GENERATOR HARNESS - 4000W
FIGURE 8-61. GENERATOR HARNESS - 7500W SKYPOWER
FIGURE 8-62. GENERATOR TO ENGINE HARNESS - 7500W SKYPOWER GENERATOR (DEUTZ D2011 ONLY)
FIGURE 8-63. GROUND CONTROL HARNESS
FIGURE 8-64. GROUND CONTROL HARNESS (2WS)
FIGURE 8-65. GROUND CONTROL ASSEMBLY (CE & UK CA (ULS) SPECS)
FIGURE 8-66. HOUR METER JUMPER HARNESS
FIGURE 8-67. LIFT CYLINDER HARNESS
FIGURE 8-68. PLATFORM BOX HARNESS
FIGURE 8-69. PLATFORM CONSOLE BOX HARNESS
FIGURE 8-70. PLATFORM BEACON HARNESS
FIGURE 8-71. RECEPTACLE BOX KIT - 110V IEC YELLOW (RUSSIA, CE & UK CA SPECS)
FIGURE 8-72. RECEPTACLE BOX KIT - 220V IEC BLUE (RUSSIA, CE & UK CA SPECS)
FIGURE 8-73. RECEPTACLE BOX KIT - 220V CEE7 POST GROUND 2X4 BOX (RUSSIA, CE & UK CA SPECS)
FIGURE 8-74. RECEPTACLE BOX KIT - 220V CEE7 SIDE GROUND (RUSSIA, CE & UK CA SPECS)
FIGURE 8-75. RECEPTACLE BOX KIT - 220V AFSINT 107 (RUSSIA, CE & UK CA SPECS)
FIGURE 8-76. RELAY & FUEL PUMP HARNESS
FIGURE 8-77. SKYEYE EMITTER HARNESS
FIGURE 8-78. SKYEYE INTERMEDIATE HARNESS
FIGURE 8-79. SKYEYE RECEIVER HARNESS
FIGURE 8-80. SKYGUARD INTERFACE HARNESS
FIGURE 8-81. SKYLINE HARNESS
FIGURE 8-82. STROBE LIGHT HARNESS (RED AND BLUE BEACON LIGHTS)
FIGURE 8-83. STROBE LIGHT JUMPER HARNESS
FIGURE 8-84. TELE PROXIMITY HARNESS
FIGURE 8-85. TRANSPORT SWITCH HARNESS (660SJ HC3)
FIGURE 8-86. TURNTABLE HARNESS (ALL SPECS EXCEPT CE & UK CA (ULS) SPECS) (600S HC3)
FIGURE 8-87. TURNTABLE HARNESS(CE & UK CA (ULS) SPECS)
FIGURE 8-88. VALVE CABLE - PLATFORM VALVE
FIGURE 8-89. USB HARNESS
FIGURE 8-90. UPPER VALVE HARNESS
FIGURE 8-91. VALVE HARNESS - MAIN CONTROL (2WS)
FIGURE 8-92. VALVE HARNESS - MAIN CONTROL
FIGURE 8-93. VALVE HARNESS - PLATFORM VALVE - 600S HC3 (600S HC3)
FIGURE 8-94. VALVE HARNESS - PLATFORM VALVE (660SJ HC3)
FIGURE 8-95. WHITE NOISE ALARM HARNESS
FIGURE 8-96. WORKLIGHT HARNESS
SECTION 9 - DECALSFIGURE 9-1. DECAL INSTALLATION (ANSI SPECS - ENGLISH LANGUAGE)
FIGURE 9-2. DECAL INSTALLATION
FIGURE 9-3. DECAL INSTALLATION (BRAZIL SPECS - PORTUGUESE/SPANISH LANGUAGES)
FIGURE 9-4. DECAL INSTALLATION (CE & UK CA SPECS - ENGLISH LANGUAGE)
FIGURE 9-5. DECAL INSTALLATION (CHINESE SPECS - ENGLISH/SIMPLIFIED CHINESE LANGUAGES)
FIGURE 9-6. DECAL INSTALLATION (CHINESE SPECS - ENGLISH/TRADITIONAL CHINESE LANGUAGES)
FIGURE 9-7. DECAL INSTALLATION (CSA SPECS - ENGLISH/FRENCH LANGUAGES)
FIGURE 9-8. DECAL INSTALLATION (JAPANESE SPECS - ENGLISH/JAPANESE LANGUAGES)
FIGURE 9-9. DECAL INSTALLATION (KOREAN SPECS - ENGLISH/KOREAN LANGUAGES)
FIGURE 9-10. DECAL INSTALLATION - LATIN AMERICAN SPECS - ENGLISH/SPANISH LANGUAGES)
FIGURE 9-11. DECALS INSTALLATION - OPTIONS
FIGURE 9-12. DECAL INSTALLATION - SKYWELDER (50HZ)
FIGURE 9-13. DECAL INSTALLATION - SKYWELDER (60HZ)
FIGURE 9-14. DECAL INSTALLATION - TOW (ANSI SPECS)
FIGURE 9-15. DECAL INSTALLATION - TOW (ANSI EXPORT, RUSSIA, CHINA, CE & UK CA SPECS)
FIGURE 9-16. DECAL INSTALLATION - TOW (CSA SPECS)
PART NUMBER INDEX
- SuperPac Parts Manual
- StratoLift Parts Manual
