Hyundai
86
176,834
JLG Boom Lift 600S HC3 660SJ HC3 Parts Catalog 3122323400
Brand: JLG
Type of Machine: Boom Lift
Model: JLG 600S HC3, 660SJ HC3 Boom Lift
Part Number: 3122323400
Publication Date: 2025
Number of Pages: 980 Pages
SECTION 1 - FRAME
FIGURE 1-1. AXLE INSTALLATION (MACHINES WITH SN STARTING WITH 03)​
FIGURE 1-2. AXLE INSTALLATION (MACHINES WITH SN STARTING WITH B3)​
FIGURE 1-3. STEER INSTALLATION - WITHOUT TOW PACKAGE​
FIGURE 1-4. STEER INSTALLATION - WITH TOW PACKAGE​
FIGURE 1-5. WHEEL DRIVE INSTALLATION - 4WD/2WS (MACHINES WITH SN STARTING WITH 03) (600S HC3)​
FIGURE 1-6. WHEEL DRIVE INSTALLATION - 4WD/2WS MACHINES WITH SN STARTING WITH 03) (660SJ HC3)​
FIGURE 1-7. WHEEL DRIVE INSTALLATION - 4WD/2WS (MACHINES WITH SN STARTING WITH B3)​
FIGURE 1-8. DRIVE MOTOR ASSEMBLY (600S HC3)​
FIGURE 1-9. DRIVE MOTOR ASSEMBLY (660SJ HC3)​
FIGURE 1-10. DRIVE HUB ASSEMBLY (600S HC3)​
FIGURE 1-11. DRIVE HUB ASSEMBLY (660SJ HC3)​
FIGURE 1-12. TRACTION VALVE ASSEMBLY​
FIGURE 1-13. TRACTION VALVE ASSEMBLY​
FIGURE 1-14. TIRE & WHEEL INSTALLATION - IN355-55 D625 FOAM FILLED (AVAILABLE ON ALL SPECS)​
FIGURE 1-15. TIRE & WHEEL INSTALLATION - IN355-55 D625 FOAM FILLED NON-MARKING (AVAILABLE ON ALL SPECS)​
FIGURE 1-16. TIRE & WHEEL INSTALLATION - 41-18LL X 22.5 FOAM FILLED TURF & SAND (AVAILABLE ON ALL SPECS EXCEPT AUSTRALIAN, RUSSIA, CE & UK CA SPECS)​
FIGURE 1-17. MATTRACKS INSTALLATION​
FIGURE 1-18. MATTRACKS INSTALLATION​
FIGURE 1-19. LP TANKS AND BRACKETS INSTALLATION (FORD ENGINES)​
FIGURE 1-20. FRAME COVERS INSTALLATION - 2WS​
FIGURE 1-21. TOW BAR INSTALLATION (OPTIONAL)​
SECTION 2 - TURNTABLE
FIGURE 2-1. VALVE INSTALLATION (600S HC3)​
FIGURE 2-2. VALVE INSTALLATION (660SJ HC3)​
FIGURE 2-3. AXLE VALVE ASSEMBLY​
FIGURE 2-4. MAIN VALVE ASSEMBLY - 2WS​
FIGURE 2-5. SWING DRIVE INSTALLATION (Prior to SN 0300320952, Prior to SN B300027185)​
FIGURE 2-6. SWING DRIVE INSTALLATION (SN 0300320953 to Present, SN B300027186 to Present)​
FIGURE 2-7. SWING MOTOR/HUB ASSEMBLY (Prior to SN 0300320952, Prior to SN B300027185)​
FIGURE 2-8. SWING MOTOR/HUB ASSEMBLY (SN 0300320953 to Present, SN B300027186 to Present)​
FIGURE 2-9. TURNTABLE BEARING AND LUBE INSTALLATION​
FIGURE 2-10. TURNTABLE LOCK INSTALLATION​
FIGURE 2-11. ROTARY COUPLING INSTALLATION​
FIGURE 2-12. ROTARY COUPLING ASSEMBLY​
FIGURE 2-13. TANKS INSTALLATION - DIESEL MACHINES (POLY FUEL TANK) (HYDRAULIC TANK WITH 6 INCH BREATHER) (600S HC3)​
FIGURE 2-14. TANKS INSTALLATION - DIESEL MACHINES (POLY FUEL TANK) (HYDRAULIC TANK WITH 4 INCH BREATHER) (600S HC3)​
FIGURE 2-15. TANKS INSTALLATION - DIESEL MACHINES (POLY FUEL TANK) (HYDRAULIC TANK WITH 6 INCH BREATHER) (660SJ HC3)​
FIGURE 2-16. TANKS INSTALLATION - DIESEL MACHINES (POLY FUEL TANK) (HYDRAULIC TANK WITH 4 INCH BREATHER) (660SJ HC3)​
FIGURE 2-17. TANKS INSTALLATION - DIESEL MACHINES (STEEL FUEL TANK) (HYDRAULIC TANK WITH 6 INCH BREATHER) (600S HC3)​
FIGURE 2-18. TANKS INSTALLATION - DIESEL MACHINES (STEEL FUEL TANK) (HYDRAULIC TANK WITH 4 INCH BREATHER) (600S HC3)​
FIGURE 2-19. TANKS INSTALLATION - DIESEL MACHINES (STEEL FUEL TANK) (HYDRAULIC TANK WITH 6 INCH BREATHER) (660SJ HC3)​
FIGURE 2-20. TANKS INSTALLATION - DIESEL MACHINES (STEEL FUEL TANK) (HYDRAULIC TANK WITH 4 INCH BREATHER) (660SJ HC3)​
FIGURE 2-21. TANKS INSTALLATION - GAS MACHINES (HYDRAULIC TANK WITH 6 INCH BREATHER) (600S HC3)​
FIGURE 2-22. TANKS INSTALLATION - GAS MACHINES (HYDRAULIC TANK WITH 4 INCH BREATHER) (600S HC3)​
FIGURE 2-23. TANKS INSTALLATION - GAS MACHINES (HYDRAULIC TANK WITH 6 INCH BREATHER) (660SJ HC3)​
FIGURE 2-24. TANKS INSTALLATION - GAS MACHINES (HYDRAULIC TANK WITH 4 INCH BREATHER) (660SJ HC3)​
FIGURE 2-25. HYDRAULIC TANK ASSEMBLY (HYDRAULIC TANK WITH 6 INCH BREATHER)​
FIGURE 2-26. HYDRAULIC TANK ASSEMBLY (HYDRAULIC TANK WITH 4 INCH BREATHER)​
FIGURE 2-27. BATTERY AND AUXILIARY PUMP INSTALLATION (MACHINES WITH SN STARTING WITH 03)​
FIGURE 2-28. BATTERY AND AUXILIARY PUMP INSTALLATION (MACHINES WITH SN STARTING WITH B3)​
FIGURE 2-29. BATTERY AND AUXILIARY PUMP WITH DISCONNECT SWITCH INSTALLATION (MACHINES WITH SN STARTING WITH 03)​
FIGURE 2-30. BATTERY AND AUXILIARY PUMP INSTALLATION WITH DISCONNECT SWITCH (MACHINES WITH SN STARTING WITH B3)​
FIGURE 2-31. AUXILIARYMOTOR/PUMP ASSEMBLY (MACHINES WITH SN STARTING WITH B3)​
FIGURE 2-32. ELECTRICAL COMPONENTS INSTALLATION (ALL SPECS EXCEPT AUSTRALIAN, CE & UK CA (ULS) SPECS)​
FIGURE 2-33. ELECTRICAL COMPONENTS INSTALLATION - (CE & UK CA (ULS) SPECS)​
FIGURE 2-34. ELECTRICAL COMPONENTS INSTALLATION - (CE & UK CA (ULS) SPECS)​
FIGURE 2-35. ELECTRICAL COMPONENTS INSTALLATION - STANDARD WITH 2WS​
FIGURE 2-36. GROUND CONTROL ASSEMBLY - (MACHINES WITH SN STARTING WITH 03 ALL SPECS EXCEPT AUSTRALIAN, CE & UK CA (ULS) SPECS) (600S HC3)​
FIGURE 2-37. GROUND CONTROL ASSEMBLY - (MACHINES WITH SN STARTING WITH 03 CE & UK CA (ULS) SPECS) (600S HC3)​
FIGURE 2-38. GROUND CONTROL ASSEMBLY (2WS) (CHINA IV) (660SJ HC3)​
FIGURE 2-39. LIGHT PANEL INSTALLATION​
FIGURE 2-40. KEYSWITCH INSTALLATION - (ANSI, ANSI EXPORT, CHINA, CSA AND JAPANESE SPECS) (600S HC3)​
FIGURE 2-41. KEYSWITCH INSTALLATION - (RUSSIA, CE & UK CA SPECS) (600S HC3)​
FIGURE 2-42. KEYSWITCH INSTALLATION - (ANSI, ANSI EXPORT, AUSTRALIAN, CHINA, CSA AND JAPANESE SPECS) (660SJ HC3)​
FIGURE 2-43. KEYSWITCH INSTALLATION - (RUSSIA, CE & UK CA SPECS) (660SJ HC3)​
FIGURE 2-44. KEYSWITCH INSTALLATION - (WITHOUT JIB) (WITH MSSO) (CE & UK CA SPECS) (660SJ HC3)​
FIGURE 2-45. KEYSWITCH INSTALLATION - (WITH JIB) (WITH MSSO) (CE & UK CA SPECS) (660SJ HC3)​
FIGURE 2-46. HOOD PLUG INSTALLATION - NO STROBE​
FIGURE 2-47. HOODS INSTALLATIONS - ABS - DEUTZ D2011, DEUTZ TD 2.9L4 67HP AND FORD ENGINES​
FIGURE 2-48. HOODS INSTALLATIONS - ABS - DEUTZ TD 2.2L3 AND DEUTZ TD 2.9L4 49HP ENGINES​
FIGURE 2-49. HOOD ASSEMBLY - ENGINE SIDE (ABS)​
FIGURE 2-50. HOOD ASSEMBLY - TANK SIDE (ABS)​
FIGURE 2-51. HOODS INSTALLATIONS - STEEL - DEUTZ D2011, DEUTZ TD 2.9L4 67HP AND FORD ENGINES (SN STARTING WITH 03)​
FIGURE 2-52. HOODS INSTALLATIONS - STEEL - DEUTZ TD 2.2L3 AND DEUTZ TD 2.9L4 49HP ENGINES​
FIGURE 2-53. HOOD ASSEMBLY - ENGINE SIDE (STEEL) - DEUTZ D2011, DEUTZ TD2.3L3 DEUTZ TD 2.9L4 49HP & 67HP AND FORD ENGINES​
FIGURE 2-54. HOOD ASSEMBLY - TANK SIDE (STEEL) - DEUTZ D2011, DEUTZ TD2.3L3 DEUTZ TD 2.9L4 49HP & 67HP AND FORD ENGINES​
FIGURE 2-55. HOODS INSTALLATIONS - STEEL - DEUTZ D2011 WITH ARCTIC AND DEUTZ TD2.2L3 ENGINES (SN STARTING WITH B3) (660SJ HC3)​
FIGURE 2-56. HOODS INSTALLATION - STEEL (MACHINES WITH SN STARTING WITH B3) (DEUTZ D2.9L4 (CHINA IV) ENGINES)​
FIGURE 2-57. HOOD ASSEMBLY - ENGINE SIDE (STEEL) - DEUTZ D2011 WITH ARCTIC AND DEUTZ TD2.2L3 ENGINES (660SJ HC3)​
FIGURE 2-58. HOOD ASSEMBLY - TANK SIDE (STEEL) - DEUTZ D2011 WITH ARCTIC AND DEUTZ TD2.2L3 ENGINES (660SJ HC3)​
FIGURE 2-59. HOOD ASSEMBLY - ENGINE SIDE (STEEL) - DEUTZ D2011 WITH ARCTIC AND DEUTZ TD2.2L3 ENGINES (660SJ HC3)​
FIGURE 2-60. NOISE REDUCTION PACKAGE (600S HC3)​
FIGURE 2-61. NOISE REDUCTION PACKAGE (660SJ HC3)​
FIGURE 2-62. TURNTABLE COVERS INSTALLATION​
FIGURE 2-63. WHITE NOISE ALARM INSTALLATION (AMBIENT)​
FIGURE 2-64. WHITE NOISE ALARM INSTALLATION (CONSTANT)​
SECTION 3 - ENGINE
FIGURE 3-1. DEUTZ D2011 ENGINE INSTALLATION - WITHOUT ARCTIC PACKAGE (MACHINES WITH SN STARTING WITH 03) (600S HC3)​
FIGURE 3-2. DEUTZ D2011 ENGINE INSTALLATION - WITHOUT ARCTIC PACKAGE (MACHINES WITH SN STARTING WITH 03) (660SJ HC3)​
FIGURE 3-3. DEUTZ D2011 ENGINE INSTALLATION - WITHOUT ARCTIC PACKAGE (MACHINES WITH SN STARTING WITH B3) (660SJ HC3)​
FIGURE 3-4. DEUTZ D2011 ENGINE AND PUMPS SUB-ASSEMBLY - WITHOUT ARCTIC PACKAGE (MACHINES WITH SN STARTING WITH 03)​
FIGURE 3-5. DEUTZ D2011 ENGINE AND PUMPS SUB-ASSEMBLY - WITHOUT ARCTIC PACKAGE (MACHINES WITH SN STARTING WITH B3) (660SJ HC3)​
FIGURE 3-6. DEUTZ D2011 ENGINE ASSEMBLY - WITHOUT ARCTIC PACKAGE​
FIGURE 3-7. DEUTZ D2011 ENGINE INSTALLATION - WITH ARCTIC PACKAGE (MACHINES WITH SN STARTING WITH 03) (600S HC3)​
FIGURE 3-8. DEUTZ D2011 ENGINE INSTALLATION - WITH ARCTIC PACKAGE (MACHINES WITH SN STARTING WITH 03) (660SJ HC3)​
FIGURE 3-9. DEUTZ D2011 ENGINE INSTALLATION - WITH ARCTIC PACKAGE (MACHINES WITH SN STARTING WITH B3) (660SJ HC3)​
FIGURE 3-10. DEUTZ D2011 ENGINE AND PUMPS SUB-ASSEMBLY - WITH ARCTIC PACKAGE (MACHINES WITH SN STARTING WITH 03)​
FIGURE 3-11. DEUTZ D2011 ENGINE AND PUMPS SUB-ASSEMBLY - WITH ARCTIC PACKAGE (MACHINES WITH SN STARTING WITH B3) (660SJ HC3)​
FIGURE 3-12. DEUTZ D2011 ENGINE ASSEMBLY - WITH ARCTIC PACKAGE​
FIGURE 3-13. DEUTZ D2011 ENGINE COMPONENTS​
FIGURE 3-14. DEUTZ TD 2.2L3 (STAGE V) ENGINE INSTALLATION (600S HC3)​
FIGURE 3-15. DEUTZ TD 2.2L3 (STAGE V) ENGINE INSTALLATION (660SJ HC3)​
FIGURE 3-16. DEUTZ TD2.2L3 (STAGE V) ENGINE AND PUMPS SUB-ASSEMBLY​
FIGURE 3-17. DEUTZ TD2.2L3 (STAGE V) ENGINE ASSEMBLY​
FIGURE 3-18. DEUTZ TD2.2L3 (STAGE V) ENGINE COMPONENTS​
FIGURE 3-19. DEUTZ D2.9L4 - EMR5 (49HP) ENGINE INSTALLATION WITHOUT ARCTIC PACKAGE (600S HC3)​
FIGURE 3-20. DEUTZ D2.9L4 - EMR5 (49HP) ENGINE INSTALLATION WITHOUT ARCTIC PACKAGE (660SJ HC3)​
FIGURE 3-21. DEUTZ D2.9L4 - EMR5 (49HP) ENGINE AND PUMPS SUB-ASSEMBLY WITHOUT ARCTIC PACKAGE​
FIGURE 3-22. DEUTZ D2.9L4 - EMR5 (49HP) ENGINE ASSEMBLY WITHOUT ARCTIC PACKAGE (Prior to SN 0300321273, Prior to SN B300027301)​
FIGURE 3-23. DEUTZ D2.9L4 - EMR5 (49HP) ENGINE ASSEMBLY WITHOUT ARCTIC PACKAGE (SN 0300321274 to Present, SN B300027302 to Present)​
FIGURE 3-24. DEUTZ D2.9L4 - EMR5 (49HP) ENGINE INSTALLATION WITH ARCTIC PACKAGE (600S HC3)​
FIGURE 3-25. DEUTZ D2.9L4 - EMR5 (49HP) ENGINE INSTALLATION WITH ARCTIC PACKAGE (660SJ HC3)​
FIGURE 3-26. DEUTZ D2.9L4 - EMR5 (49HP) ENGINE AND PUMPS SUB-ASSEMBLY WITH ARCTIC PACKAGE​
FIGURE 3-27. DEUTZ D2.9L4 - EMR5 (49HP) ENGINE ASSEMBLY WITH ARCTIC PACKAGE (Prior to SN 0300321273, Prior to SN B300027301)​
FIGURE 3-28. DEUTZ D2.9L4 - EMR5 (49HP) ENGINE ASSEMBLY WITH ARCTIC PACKAGE (SN 0300321274 to Present, SN B300027302 to Present)​
FIGURE 3-29. ENGINE COMPONENTS - DEUTZ D2.9L4 EMR5 ENGINE (ANSI, ANSI EXPORT AND CSA SPECS​
FIGURE 3-30. DEUTZ D2.9L4 - EMR5 (67HP) ENGINE INSTALLATION WITH ARCTIC PACKAGE (660SJ HC3)​
FIGURE 3-31. DEUTZ D2.9L4 - EMR5 (67HP) ENGINE INSTALLATION WITH ARCTIC PACKAGE (600S HC3)​
FIGURE 3-32. DEUTZ D2.9L4 - EMR5 (67HP) ENGINE AND PUMPS SUB-ASSEMBLY WITH ARCTIC PACKAGE​
FIGURE 3-33. DEUTZ D2.9L4 - EMR5 (67HP) ENGINE ASSEMBLY WITH ARCTIC PACKAGE (Prior to SN 0300321273, Prior to SN B300027301)​
FIGURE 3-34. DEUTZ D2.9L4 - EMR5 (67HP) ENGINE ASSEMBLY WITH ARCTIC PACKAGE (SN 0300321274 to Present, SN B300027302 to Present)​
FIGURE 3-35. DEUTZ D2.9L4 - EMR5 (67HP) ENGINE INSTALLATION WITHOUT ARCTIC PACKAGE (660SJ HC3)​
FIGURE 3-36. DEUTZ D2.9L4 - EMR5 (67HP) ENGINE INSTALLATION WITHOUT ARCTIC PACKAGE (600S HC3)​
FIGURE 3-37. DEUTZ D2.9L4 - EMR5 (67HP) ENGINE AND PUMPS SUB-ASSEMBLY WITHOUT ARCTIC PACKAGE​
FIGURE 3-38. DEUTZ D2.9L4 - EMR5 (67HP) ENGINE ASSEMBLY WITHOUT ARCTIC PACKAGE (Prior to SN 0300321273, Prior to SN B300027301)​
FIGURE 3-39. DEUTZ D2.9L4 - EMR5 (67HP) ENGINE ASSEMBLY WITHOUT ARCTIC PACKAGE (SN 0300321274 to Present, SN B300027302 to Present)​
FIGURE 3-40. ENGINE COMPONENTS - DEUTZ D2.9L4 EMR5 (67HP) ENGINE​
FIGURE 3-41. RADIATOR ASSEMBLY​
FIGURE 3-42. DEUTZ D2.9L4 ENGINE INSTALLATION​
FIGURE 3-43. DEUTZ D2.9L4 ENGINE AND PUMP SUB-ASSEMBLY​
FIGURE 3-44. DEUTZ D2.9L4 ENGINE ASSEMBLY​
FIGURE 3-45. DEUTZ D2.9L4 ENGINE COMPONENTS​
FIGURE 3-46. BREATHER HEATER INSTALLATION - DEUTZ D2.9L4 - 49HP AND DEUTZ TD2.9L4 - 67HP ENGINES WITH ARCTIC PACKAGE​
FIGURE 3-47. FORD ENGINE INSTALLATION - WITHOUT ARCTIC PACKAGE (600S HC3)​
FIGURE 3-48. FORD ENGINE INSTALLATION - WITHOUT ARCTIC PACKAGE (660SJ HC3)​
FIGURE 3-49. FORD ENGINE AND PUMPS SUB-ASSEMBLY WITHOUT ARCTIC PACKAGE​
FIGURE 3-50. FORD ENGINE ASSEMBLY - WITHOUT ARCTIC PACKAGE​
FIGURE 3-51. FORD ENGINE INSTALLATION - WITH ARCTIC PACKAGE (600S HC3)​
FIGURE 3-52. FORD ENGINE INSTALLATION - WITH ARCTIC PACKAGE (660SJ HC3)​
FIGURE 3-53. FORD ENGINE AND PUMPS SUB-ASSEMBLY WITH ARCTIC PACKAGE​
FIGURE 3-54. FORD ENGINE ASSEMBLY - WITH ARCTIC PACKAGE​
FIGURE 3-55. FORD ENGINE PREP ASSEMBLY​
FIGURE 3-56. FORD ENGINE COMPONENTS​
FIGURE 3-57. PUMP COUPLING KIT (DEUTZ ENGINES)​
FIGURE 3-58. PISTON PUMP ASSEMBLY - ALL ENGINES EXCEPT DUETZ D2011 ENGINES ON MACHINES WITH SN STARTING WITH B3​
FIGURE 3-59. PISTON PUMP ASSEMBLY - DUETZ D2011 ENGINES ON MACHINES WITH SN STARTING WITH B3​
FIGURE 3-60. FUEL FILTER INSTALLATION (POLY FUEL TANK)​
FIGURE 3-61. FUEL FILTER INSTALLATION (STEEL FUEL TANK) (DEUTZ D2011 ENGINES)​
FIGURE 3-62. FUEL FILTER INSTALLATION (STEEL FUEL TANK) (DEUTZ DT2.9L4 ENGINES)​
FIGURE 3-63. FUEL FILTER INSTALLATION (STEEL FUEL TANK) (DEUTZ D2.9L4 ENGINES)​
FIGURE 3-64. MUFFLER INSTALLATION - SPARK ARRESTING (DEUTZ D2011 ENGINES)​
FIGURE 3-65. EXHAUST PIPE INSTALLATION - (DEUTZ D2011 ENGINES)​
FIGURE 3-66. MOTOR MOUNT INSTALLATION - WITHOUT GENERATOR (DEUTZ D2011 ENGINES)​
FIGURE 3-67. MOTOR MOUNT INSTALLATION - WITHOUT GENERATOR (DEUTZ TD 2.9L4 ENGINES)​
FIGURE 3-68. MOTOR MOUNT INSTALLATION - WITH GENERATOR (DEUTZ D2011 ENGINES)​
FIGURE 3-69. MOTOR MOUNT INSTALLATION - WITH GENERATOR (DEUTZ TD 2.9L4 ENGINES)​
FIGURE 3-70. MOTOR MOUNT INSTALLATION - WITH GENERATOR (STAGE V) (DEUTZ TD 2.2L3 ENGINES)​
FIGURE 3-71. MOTOR MOUNT INSTALLATION - WITHOUT GENERATOR (STAGE V) (DEUTZ TD 2.2L3 ENGINES)​
FIGURE 3-72. MOTOR MOUNT INSTALLATION - WITH GENERATOR (DEUTZ TD 2.9L4 49HP ENGINES)​
FIGURE 3-73. MOTOR MOUNT INSTALLATION - WITHOUT GENERATOR (DEUTZ TD 2.9L4 49HP ENGINES)​
FIGURE 3-74. BELT WITHOUT GENERATOR INSTALLATION (FORD ENGINES)​
FIGURE 3-75. TRAY JACK INSTALLATION​
FIGURE 3-76. TRAY JACK INSTALLATION (STAGE V)​
FIGURE 3-77. ENGINE HOOD BAFFLES INSTALLATION - ABS HOODS​
FIGURE 3-78. ENGINE HOOD BAFFLES INSTALLATION - STEEL HOODS​
FIGURE 3-79. ENGINE HOOD BAFFLES INSTALLATION - ABS HOODS (DEUTZ TD 2.2L3 ENGINES AND TD 2.9L4 49HP ENGINES)​
FIGURE 3-80. ENGINE HOOD BAFFLES INSTALLATION - STEEL HOODS (DEUTZ TD 2.2L3 ENGINES AND TD 2.9L4 49HP ENGINES)​
FIGURE 3-81. 2500W GENERATOR INSTALLATION - 110V/60HZ (DEUTZ D2011 ENGINES)​
FIGURE 3-82. 2500W GENERATOR INSTALLATION - 110V/60HZ (DEUTZ TD2.9L4 ENGINES)​
FIGURE 3-83. 2500W GENERATOR INSTALLATION - 110V/60HZ (FORD ENGINES)​
FIGURE 3-84. 2500W GENERATOR INSTALLATION - 220V/50HZ (DEUTZ D2011 ENGINES)​
FIGURE 3-85. 2500W GENERATOR INSTALLATION - 120V/60HZ (DEUTZ TD2.9L4 ENGINES)​
FIGURE 3-86. 4000W GENERATOR INSTALLATION - 110V/60HZ (DEUTZ D2011 ENGINES)​
FIGURE 3-87. 4000W GENERATOR INSTALLATION - 110V/60HZ (DEUTZ TD2.9L4 ENGINES)​
FIGURE 3-88. 4000W GENERATOR INSTALLATION - 220V/50HZ (DEUTZ D2011 ENGINES)​
FIGURE 3-89. 4000W GENERATOR INSTALLATION - 220V/50HZ (DEUTZ TD2.2L3 ENGINES) (SKYPOWER)​
FIGURE 3-90. 4000W GENERATOR INSTALLATION - 220V/60HZ (DEUTZ TD2.9L4 ENGINES) (SKYPOWER)​
FIGURE 3-91. 7500W GENERATOR INSTALLATION - 220V/60HZ (DEUTZ TD2.9L4 ENGINES) (SKYPOWER)​
FIGURE 3-92. 7500W SKYPOWER GENERATOR INSTALLATION - 110/60HZ (DEUTZ D2011 ENGINES)​
FIGURE 3-93. 7500W SKYPOWER GENERATOR INSTALLATION - 110V/60HZ (DEUTZ TD2.9L4 ENGINES)​
FIGURE 3-94. 7500W SKYPOWER GENERATOR INSTALLATION - 110V/60HZ (FORD ENGINES)​
FIGURE 3-95. 7500W SKYPOWER GENERATOR INSTALLATION - 220V/50HZ (DEUTZ D2011 ENGINES)​
FIGURE 3-96. QUICKFIT OIL DRAIN (DEUTZ ENGINES)​
SECTION 4 - BOOM
FIGURE 4-1. BOOM INSTALLATION (600S HC3)​
FIGURE 4-2. BOOM INSTALLATION (660SJ HC3)​
FIGURE 4-3. BOOM ASSEMBLY (600S HC3)​
FIGURE 4-4. BOOM ASSEMBLY (660SJ HC3)​
FIGURE 4-5. JIB ASSEMBLY (660SJ HC3)​
FIGURE 4-6. PLATFORM ROTATOR ASSEMBLY (600S HC3)​
FIGURE 4-7. PLATFORM ROTATOR ASSEMBLY (660SJ HC3)​
FIGURE 4-8. POWER TRACK INSTALLATION (600S HC3)​
FIGURE 4-9. POWER TRACK ASSEMBLY - (WITH SN STARTING WITH 03) (660SJ HC3)​
FIGURE 4-10. POWER TRACK ASSEMBLY - (WITH SN STARTING WITH B3) (660SJ HC3)​
FIGURE 4-11. VALVE INSTALLATION (600S HC3)​
FIGURE 4-12. BOOM VALVES INSTALLATION (660SJ HC3)​
FIGURE 4-13. PLATFORM VALVE ASSEMBLY (600S HC3)​
FIGURE 4-14. PLATFORM VALVE ASSEMBLY (660SJ HC3)​
FIGURE 4-15. BOOM SENSORS INSTALLATION (600S HC3)​
FIGURE 4-16. BOOM SENSORS INSTALLATION (660SJ HC3)​
FIGURE 4-17. PLATFORM SUPPORT INSTALLATION​
SECTION 5 - PLATFORM
FIGURE 5-1. PLATFORM ASSEMBLY - 30IN X 3FT (76CM X .91M) - DROP BAR ENTRY​
FIGURE 5-2. PLATFORM ASSEMBLY - 30IN X 4FT (76CM X 1.22M) WITH SWING GATE​
FIGURE 5-3. PLATFORM ASSEMBLY - 30IN X 4FT (76CM X 1.22M) WITH DROP BAR​
FIGURE 5-4. PLATFORM ASSEMBLY - 30IN X 5FT (76CM X 1.52M) WITH SWING GATE​
FIGURE 5-5. PLATFORM ASSEMBLY - 30IN X 5FT (76CM X 1.52M) WITH DROP BAR​
FIGURE 5-6. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) WITH SWING GATE​
FIGURE 5-7. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) WITH DROP BAR​
FIGURE 5-8. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) WITH FALL ARREST (ANSI, ANSI EXPORT, CHINA AND CSA SPECS)​
FIGURE 5-9. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) TRI-ENTRY WITH SWING GATE​
FIGURE 5-10. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) TRI-ENTRY WITH DROP BAR​
FIGURE 5-11. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH SWING GATE​
FIGURE 5-12. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH DROP BAR​
FIGURE 5-13. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH FALL ARREST (ANSI, ANSI EXPORT, CHINA AND CSA SPECS)​
FIGURE 5-14. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) TRI-ENTRY WITH SWING GATE​
FIGURE 5-15. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) TRI-ENTRY WITH DROP BAR​
FIGURE 5-16. PLATFORM POWER USB​
FIGURE 5-17. TRAY ASSEMBLY​
FIGURE 5-18. PLATFORM CONSOLE AND FOOTSWITCH INSTALLATION (600S HC3)​
FIGURE 5-19. PLATFORM CONSOLE AND FOOTSWITCH INSTALLATION (660SJ HC3)​
FIGURE 5-20. CONSOLE BOX ASSEMBLY​
FIGURE 5-21. FOOTSWITCH ASSEMBLY​
FIGURE 5-22. LIGHT PANEL INSTALLATION​
FIGURE 5-23. SKYLINE INSTALLATION​
FIGURE 5-24. SKYWELDER INSTALLATION (50HZ)​
FIGURE 5-25. SKYWELDER INSTALLATION (60HZ)​
FIGURE 5-26. SKYWELDER PREP PACKAGE (60HZ)​
FIGURE 5-27. WELDER ASSEMBLY​
FIGURE 5-28. WELDER ASSEMBLY (CST282)​
FIGURE 5-29. SKYGLAZIER INSTALLATION​
FIGURE 5-30. SOFT TOUCH INSTALLATION - 6FT (1.83M) PLATFORM​
FIGURE 5-31. SOFT TOUCH INSTALLATION - 6FT (1.83M) FALL ARREST PLATFORM (600S HC3)​
FIGURE 5-32. SOFT TOUCH INSTALLATION - 8FT (2.4M) PLATFORM​
FIGURE 5-33. SOFT TOUCH INSTALLATION - 8FT (2.4M) FALL ARREST PLATFORM (600S HC3)​
FIGURE 5-34. FALL ARREST INSTALLATION (BOLT-ON EXTERNAL) (6FT/1.82M PLATFORM)​
FIGURE 5-35. FALL ARREST INSTALLATION (BOLT-ON EXTERNAL) (6FT/1.82M TRI-ENTRY PLATFORM)​
FIGURE 5-36. FALL ARREST INSTALLATION (BOLT-ON EXTERNAL) (2.5FT/1.22M PLATFORM)​
FIGURE 5-37. FALL ARREST INSTALLATION (BOLT-ON EXTERNAL) (2.5FT/1.52M PLATFORM)​
FIGURE 5-38. FALL ARREST INSTALLATION (BOLT-ON EXTERNAL) (8FT/2.4M PLATFORM)​
SECTION 6 - CYLINDER
FIGURE 6-1. AXLE LOCKOUT CYLINDER ASSEMBLY (MACHINES WITH SN STARTING WITH 03)​
FIGURE 6-2. AXLE LOCKOUT CYLINDER ASSEMBLY (MACHINES WITH SN STARTING WITH B3)​
FIGURE 6-3. LEVEL CYLINDER ASSEMBLY - PLATFORM SLAVE (600S HC3)​
FIGURE 6-4. LEVEL CYLINDER ASSEMBLY - PLATFORM SLAVE (660SJ HC3)​
FIGURE 6-5. LIFT CYLINDER ASSEMBLY BOOM (600S HC3)​
FIGURE 6-6. LIFT CYLINDER ASSEMBLY BOOM (660SJ HC3)​
FIGURE 6-7. LIFT CYLINDER ASSEMBLY - JIB (660SJ HC3)​
FIGURE 6-8. LIFT CYLINDER ASSEMBLY - JIB (660SJ HC3)​
FIGURE 6-9. LIFT CYLINDER ASSEMBLY - JIB (660SJ HC3)​
FIGURE 6-10. STEER CYLINDER ASSEMBLY​
FIGURE 6-11. TELESCOPE CYLINDER ASSEMBLY​
SECTION 7 - HYDRAULIC
FIGURE 7-1. DRIVE HYDRAULIC DIAGRAM (2WS WITHOUT ARCTIC PACKAGE) (600S HC3)​
FIGURE 7-2. DRIVE HYDRAULIC DIAGRAM (2WS WITHOUT ARCTIC PACKAGE) (660SJ HC3)​
FIGURE 7-3. DRIVE HYDRAULIC DIAGRAM (2WS WITH ARCTIC PACKAGE) (600S HC3)​
FIGURE 7-4. DRIVE HYDRAULIC DIAGRAM (2WS WITH ARCTIC PACKAGE) (660SJ HC3)​
FIGURE 7-5. STANDARD HYDRAULIC DIAGRAM (600S HC3)​
FIGURE 7-6. STANDARD HYDRAULIC DIAGRAM (MACHINES WITH SN STARTING WITH 03) (660SJ HC3)​
FIGURE 7-7. STANDARD HYDRAULIC DIAGRAM (MACHINES WITH SN STARTING WITH B3) (660SJ HC3)​
SECTION 8 - ELECTRICAL
FIGURE 8-1. ELECTRICAL LAYOUT​
FIGURE 8-2. AC BOX AT PLATFORM INSTALLATION - 110V (ALL SPECS EXCEPT AUSTRALIAN, RUSSIA, CE & UK CA SPECS)​
FIGURE 8-3. AC BOX AT PLATFORM INSTALLATION - 110V IEC YELLOW (RUSSIA, CE & UK CA SPECS WITHOUT 4000W/50HZ GENERATOR)​
FIGURE 8-4. AC BOX AT PLATFORM INSTALLATION - 110V IEC YELLOW (RUSSIA, CE & UK CA SPECS WITH 4000W/50HZ GENERATOR)​
FIGURE 8-5. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE (RUSSIA, CE & UK CA SPECS WITHOUT 4000W/50HZ GENERATOR)​
FIGURE 8-6. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE (RUSSIA, CE & UK CA SPECS WITH 4000W/50HZ GENERATOR)​
FIGURE 8-7. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 2IN X 4IN POST GROUND (RUSSIA, CE & UK CA SPECS WITHOUT 4000W/50HZ GENERATOR)​
FIGURE 8-8. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 2IN X 4IN POST GROUND (RUSSIA, CE & UK CA SPECS WITH 4000W/50HZ GENERATOR)​
FIGURE 8-9. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 2IN X 4IN SIDE GROUND (RUSSIA, CE & UK CA SPECS WITHOUT 4000W/50HZ GENERATOR)​
FIGURE 8-10. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 2IN X 4IN SIDE GROUND (RUSSIA, CE & UK CA SPECS WITH 4000W/50HZ GENERATOR)​
FIGURE 8-11. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT107 (RUSSIA, CE & UK CA SPECS WITHOUT 4000W/50HZ GENERATOR)​
FIGURE 8-12. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT107 (RUSSIA, CE & UK CA SPECS WITH 4000W/50HZ GENERATOR)​
FIGURE 8-13. AC BOX AT PLATFORM INSTALLATION - 220V CUSTOMER SUPPLIED COMPONENTS (ANSI EXPORT, AUSTRALIAN, RUSSIA, CHINA, CE & UK CA SPECS)​
FIGURE 8-14. AC BOX AT PLATFORM INSTALLATION - 240V (WITH 4000W GENERATOR)​
FIGURE 8-15. AC BOX AT PLATFORM INSTALLATION - 240V (WITH 7500W SKYPOWER GENERATOR)​
FIGURE 8-16. AC BREAKER BOX INSTALLATION - SINGLE DOUBLE POLE BREAKER​
FIGURE 8-17. AC BREAKER BOX INSTALLATION - SINGLE DOUBLE POLE BREAKER (MACHINES WITH SN STARTING WITH B3)​
FIGURE 8-18. AC BREAKER BOX INSTALLATION - 3 BREAKERS​
FIGURE 8-19. AC CABLES AND CLAMPS INSTALLATION - WITHOUT GENERATOR (ANSI, CSA & JAPANESE SPECS) (600S HC3)​
FIGURE 8-20. AC CABLES AND CLAMPS INSTALLATION - WITHOUT GENERATOR (ANSI EXPORT,CE, RUSSIA CIS, CHINA & UK CA SPECS) (600S HC3)​
FIGURE 8-21. AC CABLES AND CLAMPS INSTALLATION - WITH 2500W GENERATOR (ANSI, ANSI EXPORT, CHINA, CSA AND JAPANESE SPECS) (600S HC3)​
FIGURE 8-22. AC CABLES AND CLAMPS INSTALLATION - WITH 4000W/50HZ GENERATOR (ANSI EXPORT, CE, CHINA, RUSSIAN CIS & UK CA SPECS) (600S HC3)​
FIGURE 8-23. AC CABLES AND CLAMPS INSTALLATION - WITH 4000W/60HZ GENERATOR (ANSI, ANSI EXPORT, CSA AND JAPANESE SPECS) (600S HC3)​
FIGURE 8-24. AC CABLES AND CLAMPS INSTALLATION - WITH 7500W GENERATOR (ANSI, ANSI EXPORT, CHINA, CSA, RUSSIAN CIS AND JAPANESE SPECS) (600S HC3)​
FIGURE 8-25. AC CABLES AND CLAMPS INSTALLATION - WITHOUT GENERATOR (ANSI, CSA AND JAPANESE SPECS) (660SJ HC3)​
FIGURE 8-26. AC CABLES AND CLAMPS INSTALLATION - WITHOUT GENERATOR (ANSI EXPORT, AUSTRALIAN, RUSSIA CIS, CHINA, CE & UK CA SPECS) (660SJ HC3)​
FIGURE 8-27. AC CABLES AND CLAMPS INSTALLATION - WITH 2500W GENERATOR (ANSI, ANSI EXPORT, CHINA, CSA AND JAPANESE SPECS) (660SJ HC3)​
FIGURE 8-28. AC CABLES AND CLAMPS INSTALLATION - WITH 4000W/50HZ GENERATOR (ANSI EXPORT, AUSTRALIAN, RUSSIA CIS, CHINA, CE & UK CA SPECS) (660SJ HC3)​
FIGURE 8-29. AC CABLES AND CLAMPS INSTALLATION - WITH 4000W/60HZ GENERATOR (ANSI, ANSI EXPORT, CSA AND JAPANESE SPECS) (660SJ HC3)​
FIGURE 8-30. AC CABLES AND CLAMPS INSTALLATION - WITH 7500W GENERATOR (ANSI, ANSI EXPORT, AUSTRALIAN, CHINA, CSA, RUSSIAN CIS, AND JAPANESE SPECS) (660SJ HC3)​
FIGURE 8-31. BATTERY DISCONNECT SWITCH INSTALLATION​
FIGURE 8-32. BREAKER BOX KIT - SINGLE DOUBLE POLE BREAKER (WITHOUT 4000W/50HZ GENERATOR)​
FIGURE 8-33. BREAKER BOX KIT - SINGLE DOUBLE POLE BREAKER (WITH 4000W/50HZ GENERATOR)​
FIGURE 8-34. BREAKER BOX KIT - SINGLE DOUBLE POLE BREAKER (WITHOUT 4000W/50HZ GENERATOR) (MACHINES WITH SN STARTING WITH B3)​
FIGURE 8-35. BREAKER BOX KIT - 3 BREAKERS​
FIGURE 8-36. BOOM ANGLE SENSOR HARNESS​
FIGURE 8-37. BOOM CABLE - LOWER​
FIGURE 8-38. BOOM CABLE - UPPER (600S HC3)​
FIGURE 8-39. BOOM CABLE - UPPER (660SJ HC3)​
FIGURE 8-40. CAPACITY PROXIMITY HARNESS (1000LBS)​
FIGURE 8-41. CAPACITY PROXIMITY HARNESS (750 LBS)​
FIGURE 8-42. CLEARSKY CS550 BEACON INSTALLATION - WITH METAL HOOD​
FIGURE 8-43. CLEARSKY CS550 BEACON INSTALLATION - WITH PLASTIC HOOD​
FIGURE 8-44. ECU POWER JUMPER HARNESS​
FIGURE 8-45. ELECTRICAL COMPONENTS INSTALLATION - (ALL SPECS EXCEPT AUSTRALIAN, CE & UK CA (ULS) SPECS)​
FIGURE 8-46. ELECTRICAL COMPONENTS INSTALLATION - (CE & UK CA (ULS) SPECS)​
FIGURE 8-47. ELECTRICAL COMPONENTS INSTALLATION - (CE & UK CA (ULS) SPECS)​
FIGURE 8-48. ELECTRICAL COMPONENTS INSTALLATION - WITH 2WS (660SJ HC3)​
FIGURE 8-49. ENGINE HARNESS - DEUTZ D2011 ENGINES​
FIGURE 8-50. ENGINE HARNESS - DEUTZ TD2.2L3 ENGINES​
FIGURE 8-51. ENGINE HARNESS - DEUTZ D2.9L4 - 49HP AND DEUTZ TD2.9L4 - 67HP ENGINES​
FIGURE 8-52. ENGINE HARNES - DEUTZ TD2.9L4 (EMR ENGINE)​
FIGURE 8-53. ENGINE HARNESS - FORD ENGINES​
FIGURE 8-54. ENGINE HARNESS - DEUTZ D2.9L4 (CHINA IV)​
FIGURE 8-55. FUEL FILTER HARNESS - DEUTZ TD2.2L3 (STAGE V) ENGINES​
FIGURE 8-56. FUEL PUMP HARNESS - DEUTZ D2.9L4 - 49HP AND DEUTZ TD2.9L4 - 67HP ENGINES​
FIGURE 8-57. GENERATOR HARNESS - 2500W​
FIGURE 8-58. GENERATOR HARNESS - 4000W​
FIGURE 8-59. GENERATOR HARNESS - 7500W SKYPOWER​
FIGURE 8-60. GENERATOR TO ENGINE HARNESS - 7500W SKYPOWER GENERATOR (DEUTZ D2011 ONLY)​
FIGURE 8-61. GROUND CONTROL HARNESS​
FIGURE 8-62. GROUND CONTROL HARNESS (2WS)​
FIGURE 8-63. GROUND CONTROL HARNESS (CE & UK CA (ULS) SPECS)​
FIGURE 8-64. HOUR METER JUMPER HARNESS​
FIGURE 8-65. LIFT CYLINDER HARNESS​
FIGURE 8-66. PLATFORM BOX HARNESS​
FIGURE 8-67. RECEPTACLE BOX KIT - 110V IEC YELLOW (RUSSIA, CE & UK CA SPECS)​
FIGURE 8-68. RECEPTACLE BOX KIT - 220V IEC BLUE (RUSSIA, CE & UK CA SPECS)​
FIGURE 8-69. RECEPTACLE BOX KIT - 220V CEE7 POST GROUND 2X4 BOX (RUSSIA, CE & UK CA SPECS)​
FIGURE 8-70. RECEPTACLE BOX KIT - 220V CEE7 SIDE GROUND (RUSSIA, CE & UK CA SPECS)​
FIGURE 8-71. RECEPTACLE BOX KIT - 220V AFSINT 107 (RUSSIA, CE & UK CA SPECS)​
FIGURE 8-72. RELAY & FUEL PUMP HARNESS​
FIGURE 8-73. SKYEYE EMITTER HARNESS​
FIGURE 8-74. SKYEYE INTERMEDIATE HARNESS​
FIGURE 8-75. SKYEYE RECEIVER HARNESS​
FIGURE 8-76. SKYGUARD INTERFACE HARNESS​
FIGURE 8-77. SKYLINE HARNESS​
FIGURE 8-78. TELE PROXIMITY HARNESS​
FIGURE 8-79. TRANSPORT SWITCH HARNESS (660SJ HC3)​
FIGURE 8-80. TURNTABLE HARNESS​
FIGURE 8-81. VALVE CABLE - PLATFORM VALVE​
FIGURE 8-82. VALVE HARNESS - MAIN CONTROL (2WS)​
FIGURE 8-83. VALVE HARNESS - PLATFORM VALVE (600S HC3)​
FIGURE 8-84. VALVE HARNESS - PLATFORM VALVE (660SJ HC3)​
FIGURE 8-85. WHITE NOISE ALARM HARNESS​
SECTION 9 - DECALS
FIGURE 9-1. DECAL INSTALLATION (ANSI SPECS - ENGLISH LANGUAGE)​
FIGURE 9-2. DECAL INSTALLATION (AUSTRALIAN SPECS - ENGLISH LANGUAGE)​
FIGURE 9-3. DECAL INSTALLATION (BRAZIL SPECS - PORTUGUESE/SPANISH LANGUAGES)​
FIGURE 9-4. DECAL INSTALLATION (CE & UK CA SPECS - ENGLISH LANGUAGE)​
FIGURE 9-5. DECAL INSTALLATION (CHINESE SPECS - ENGLISH/SIMPLIFIED CHINESE LANGUAGES)​
FIGURE 9-6. DECAL INSTALLATION (CHINESE SPECS - ENGLISH/TRADITIONAL CHINESE LANGUAGES)​
FIGURE 9-7. DECAL INSTALLATION (CSA SPECS - ENGLISH/FRENCH LANGUAGES)​
FIGURE 9-8. DECAL INSTALLATION (JAPANESE SPECS - ENGLISH/JAPANESE LANGUAGES)​
FIGURE 9-9. DECAL INSTALLATION (KOREAN SPECS - ENGLISH/KOREAN LANGUAGES)​
FIGURE 9-10. DECAL INSTALLATION - LATIN AMERICAN SPECS - ENGLISH/SPANISH LANGUAGES)​
FIGURE 9-11. DECALS INSTALLATION - OPTIONS​
FIGURE 9-12. DECAL INSTALLATION - SKYWELDER (50HZ)​
FIGURE 9-13. DECAL INSTALLATION - SKYWELDER (60HZ)​
FIGURE 9-14. DECAL INSTALLATION - TOW (ANSI SPECS)​
FIGURE 9-15. DECAL INSTALLATION - TOW (ANSI EXPORT, RUSSIA, CHINA, CE & UK CA SPECS)​
FIGURE 9-16. DECAL INSTALLATION - TOW (CSA SPECS)​
SECTION 11 - SPECIAL OPTIONS/ACCESSORIES/KITS
PART NUMBER INDEX
