JLG Boom Lift 600S HC3 660SJ HC3 Parts Catalog 31220615
Brand: JLG
Type of Machine: Boom Lift
Model: JLG 600S HC3, 660SJ HC3 Boom Lift
Part Number: 31220615
Publication Date: 2025
Number of Pages: 1006 Pages
SECTION 1 - FRAME
Brand: JLG
SECTION 1 - FRAME
FIGURE 1-1. AXLE INSTALLATION (MACHINES WITH SN STARTING WITH 03)
FIGURE 1-2. AXLE INSTALLATION (MACHINES WITH SN STARTING WITH B3)
FIGURE 1-3. STEER INSTALLATION - WITHOUT TOW PACKAGE
FIGURE 1-4. STEER INSTALLATION - WITH TOW PACKAGE
FIGURE 1-5. WHEEL DRIVE INSTALLATION - 4WD/2WS (600S HC3)
FIGURE 1-6. WHEEL DRIVE INSTALLATION - 4WD/2WS (660SJ HC3)
FIGURE 1-7. DRIVE MOTOR ASSEMBLY (600S HC3)
FIGURE 1-8. DRIVE MOTOR ASSEMBLY (660SJ HC3)
FIGURE 1-9. DRIVE HUB ASSEMBY (600S HC3)
FIGURE 1-10. DRIVE HUB ASSEMBLY (660SJ HC3)
FIGURE 1-11. TRACTION VALVE ASSEMBLY
FIGURE 1-12. TIRE & WHEEL INSTALLATION - IN355-55 D625 FOAM FILLED (AVAILABLE ON ALL SPECS)
FIGURE 1-13. TIRE & WHEEL INSTALLATION - IN355-55 D625 FOAM FILLED NON-MARKING (AVAILABLE ON ALL SPECS)
FIGURE 1-14. TIRE & WHEEL INSTALLATION - 41-18LL X 22.5 FOAM FILLED TURF & SAND (AVAILABLE ON ALL SPECS EXCEPT AUSTRALIAN, RUSSIA, CE & UK CA SPECS)
FIGURE 1-15. MATTRACKS INSTALLATION
FIGURE 1-16. MATTRACKS INSTALLATION
FIGURE 1-17. MATTRACKS INSTALLATION
FIGURE 1-18. MATTRACKS INSTALLATION
FIGURE 1-19. LP TANKS AND BRACKETS INSTALLATION (FORD ENGINES)
FIGURE 1-20. FRAME COVERS INSTALLATION - 2WS
FIGURE 1-21. TOW BAR INSTALLATION (OPTIONAL)
SECTION 2 - TURNTABLEFIGURE 2-1. VALVE INSTALLATION (600S HC3)
FIGURE 2-2. VALVE INSTALLATION (660SJ HC3)
FIGURE 2-3. AXLE VALVE ASSEMBLY
FIGURE 2-4. MAIN VALVE ASSEMBLY - 2WS
FIGURE 2-5. SWING DRIVE INSTALLATION
FIGURE 2-6. SWING MOTOR/HUB ASSEMBLY
FIGURE 2-7. TURNTABLE BEARING AND LUBE INSTALLATION
FIGURE 2-8. TURNTABLE LOCK INSTALLATION
FIGURE 2-9. ROTARY COUPLING INSTALLATION
FIGURE 2-10. ROTARY COUPLING ASSEMBLY
FIGURE 2-11. TANKS INSTALLATION - DIESEL MACHINES (POLY FUEL TANK) (HYDRAULIC TANK WITH 6 INCH BREATHER) (600S HC3)
FIGURE 2-12. TANKS INSTALLATION - DIESEL MACHINES (POLY FUEL TANK) (HYDRAULIC TANK WITH 4 INCH BREATHER) (600S HC3)
FIGURE 2-13. TANKS INSTALLATION - DIESEL MACHINES (POLY FUEL TANK) (HYDRAULIC TANK WITH 6 INCH BREATHER) (660SJ HC3)
FIGURE 2-14. TANKS INSTALLATION - DIESEL MACHINES (POLY FUEL TANK) (HYDRAULIC TANK WITH 4 INCH BREATHER) (660SJ HC3)
FIGURE 2-15. TANKS INSTALLATION - DIESEL MACHINES (STEEL FUEL TANK) (HYDRAULIC TANK WITH 6 INCH BREATHER) (600S HC3)
FIGURE 2-16. TANKS INSTALLATION - DIESEL MACHINES (STEEL FUEL TANK) (HYDRAULIC TANK WITH 4 INCH BREATHER) (600S HC3)
FIGURE 2-17. TANKS INSTALLATION - DIESEL MACHINES (STEEL FUEL TANK) (HYDRAULIC TANK WITH 6 INCH BREATHER) (660SJ HC3)
FIGURE 2-18. TANKS INSTALLATION - DIESEL MACHINES (STEEL FUEL TANK) (HYDRAULIC TANK WITH 4 INCH BREATHER) (660SJ HC3)
FIGURE 2-19. TANKS INSTALLATION - GAS MACHINES (HYDRAULIC TANK WITH 6 INCH BREATHER) (600S HC3)
FIGURE 2-20. TANKS INSTALLATION - GAS MACHINES (HYDRAULIC TANK WITH 4 INCH BREATHER) (600S HC3)
FIGURE 2-21. TANKS INSTALLATION - GAS MACHINES (HYDRAULIC TANK WITH 6 INCH BREATHER) (660SJ HC3)
FIGURE 2-22. TANKS INSTALLATION - GAS MACHINES (HYDRAULIC TANK WITH 4 INCH BREATHER) (660SJ HC3)
FIGURE 2-23. HYDRAULIC TANK ASSEMBLY (HYDRAULIC TANK WITH 6 INCH BREATHER)
FIGURE 2-24. HYDRAULIC TANK ASSEMBLY (HYDRAULIC TANK WITH 4 INCH BREATHER)
FIGURE 2-25. BATTERY AND AUXILIARY PUMP INSTALLATION (MACHINES WITH SN STARTING WITH 03)
FIGURE 2-26. BATTERY AND AUXILIARY PUMP INSTALLATION (MACHINES WITH SN STARTING WITH B3)
FIGURE 2-27. BATTERY AND AUXILIARY PUMP WITH DISCONNECT SWITCH INSTALLATION (MACHINES WITH SN STARTING WITH 03)
FIGURE 2-28. BATTERY AND AUXILIARY PUMP INSTALLATION WITH DISCONNECT SWITCH (MACHINES WITH SN STARTING WITH B3)
FIGURE 2-29. AUXILIARYMOTOR/PUMP ASSEMBLY (MACHINES WITH SN STARTING WITH B3)
FIGURE 2-30. ELECTRICAL COMPONENTS INSTALLATION (ALL SPECS EXCEPT AUSTRALIAN, CE & UK CA (ULS) SPECS) (600S HC3) (Prior to SN 0300298219)
FIGURE 2-31. ELECTRICAL COMPONENTS INSTALLATION (ALL SPECS EXCEPT AUSTRALIAN, CE & UK CA (ULS) SPECS) (600S HC3) (SN 0300298219 to Present)
FIGURE 2-32. ELECTRICAL COMPONENTS INSTALLATION (CE & UK CA (ULS) SPECS) (600S HC3) (Prior to SN 0300298219)
FIGURE 2-33. ELECTRICAL COMPONENTS INSTALLATION (CE & UK CA (ULS) SPECS) (600S HC3) (SN 0300298219 to Present)
FIGURE 2-34. ELECTRICAL COMPONENTS INSTALLATION (ALL SPECS EXCEPT CE & UK CA (ULS) SPECS) (660SJ HC3) (Prior to SN 0300298219, Prior to SN B300017931, Excluding B300014582, B300014583, B30014929, B300014947, B300015022 and B300015307)
FIGURE 2-35. ELECTRICAL COMPONENTS INSTALLATION (ALL SPECS EXCEPT CE & UK CA (ULS) SPECS) (660SJ HC3) (SN 0300298219 to Present, SN B300017931 to Present, Including B300014582, B300014583, B30014929, B300014947, B300015022 and B300015307)
FIGURE 2-36. ELECTRICAL COMPONENTS INSTALLATION (CE & UK CA (ULS) SPECS) (660SJ HC3) (Prior to SN 0300298219, Prior to SN B300017931, Excluding B300014582, B300014583, B30014929, B300014947, B300015022 and B300015307)
FIGURE 2-37. ELECTRICAL COMPONENTS INSTALLATION (CE & UK CA (ULS) SPECS) (660SJ HC3) (SN 0300298219 to Present, SN B300017931 to Present, Including B300014582, B300014583, B30014929, B300014947, B300015022 and B300015307)
FIGURE 2-38. GROUND CONTROL ASSEMBLY (MACHINES WITH SN STARTING WITH 03 ALL SPECS EXCEPT AUSTRALIAN, CE & UK CA (ULS) SPECS) (600S HC3)
FIGURE 2-39. GROUND CONTROL ASSEMBLY (MACHINES WITH SN STARTING WITH 03 CE & UK CA (ULS) SPECS) (600S HC3)
FIGURE 2-40. GROUND CONTROL ASSEMBLY (ALL SPECS EXCEPT CE & UK CA (ULS) SPECS) (660SJ HC3)
FIGURE 2-41. GROUND CONTROL ASSEMBLY (CE & UK CA (ULS) SPECS) (660SJ HC3)
FIGURE 2-42. LIGHT PANEL INSTALLATION
FIGURE 2-43. KEYSWITCH INSTALLATION (ANSI, ANSI EXPORT, CHINA, CSA AND JAPANESE SPECS) (600S HC3)
FIGURE 2-44. KEYSWITCH INSTALLATION (RUSSIA, CE & UK CA SPECS) (600S HC3)
FIGURE 2-45. KEYSWITCH INSTALLATION (ANSI, ANSI EXPORT, AUSTRALIAN, CHINA, CSA AND JAPANESE SPECS) (660SJ HC3)
FIGURE 2-46. KEYSWITCH INSTALLATION (RUSSIA, CE & UK CA SPECS) (660SJ HC3)
FIGURE 2-47. KEYSWITCH INSTALLATION (WITHOUT JIB) (WITH MSSO) (CE & UK CA SPECS) (600S HC3)
FIGURE 2-48. KEYSWITCH INSTALLATION (WITH JIB) (WITH MSSO) (CE & UK CA SPECS) (660SJ HC3)
FIGURE 2-49. HOOD PLUG INSTALLATION - NO STROBE
FIGURE 2-50. HOODS INSTALLATIONS - ABS - DEUTZ D2011, DEUTZ TD 2.9L4 67HP AND FORD ENGINES (Prior to SN 0300298219, Prior to SN B300017931, Excluding B300014582, B300014583, B30014929, B300014947, B300015022 and B300015307)
FIGURE 2-51. HOODS INSTALLATIONS - ABS - DEUTZ D2011, DEUTZ TD 2.9L4 67HP AND FORD ENGINES (SN 0300298219 to Present, SN B300017931 to Present, Including B300014582, B300014583, B30014929, B300014947, B300015022 and B300015307)
FIGURE 2-52. HOODS INSTALLATIONS - ABS - DEUTZ TD 2.2L3 AND DEUTZ TD 2.9L4 49HP ENGINES (Prior to SN 0300298219, Prior to SN B300017931, Excluding B300014582, B300014583, B30014929, B300014947, B300015022 and B300015307)
FIGURE 2-53. HOODS INSTALLATIONS - ABS - DEUTZ TD 2.2L3 AND DEUTZ TD 2.9L4 49HP ENGINES (SN 0300298219 to Present, SN B300017931 to Present, Including B300014582, B300014583, B30014929, B300014947, B300015022 and B300015307)
FIGURE 2-54. HOOD ASSEMBLY - ENGINE SIDE (ABS)
FIGURE 2-55. HOOD ASSEMBLY - TANK SIDE (ABS) (Prior to SN 0300298219, Prior to SN B300017931, Excluding B300014582, B300014853, B300014929, B300014947, B300015022 and B300015307)
FIGURE 2-56. HOOD ASSEMBLY - TANK SIDE (ABS) (SN 0300298219 to Present, SN B300017931 to Present, Including B300014582, B300014583, B30014929, B300014947, B300015022 and B300015307)
FIGURE 2-57. HOODS INSTALLATIONS - STEEL - DEUTZ D2011, DEUTZ TD 2.9L4 67HP AND FORD ENGINES (SN STARTING WITH 03) (Prior to SN 0300298219)
FIGURE 2-58. HOODS INSTALLATIONS - STEEL - DEUTZ D2011, DEUTZ TD 2.9L4 67HP AND FORD ENGINES (SN STARTING WITH 03) (SN 0300298219 to Present)
FIGURE 2-59. HOODS INSTALLATIONS - STEEL - DEUTZ TD 2.2L3 AND DEUTZ TD 2.9L4 49HP ENGINES (Prior to SN 0300298219)
FIGURE 2-60. HOODS INSTALLATIONS - STEEL - DEUTZ TD 2.2L3 AND DEUTZ TD 2.9L4 49HP ENGINES (SN 0300298219 to Present)
FIGURE 2-61. HOOD ASSEMBLY - ENGINE SIDE (STEEL) - DEUTZ D2011, DEUTZ TD2.3L3 DEUTZ TD 2.9L4 49HP & 67HP AND FORD ENGINES
FIGURE 2-62. HOOD ASSEMBLY - TANK SIDE (STEEL) - DEUTZ D2011, DEUTZ TD2.3L3 DEUTZ TD 2.9L4 49HP & 67HP AND FORD ENGINES (Prior to SN 0300298219)
FIGURE 2-63. HOOD ASSEMBLY - TANK SIDE (STEEL) - DEUTZ D2011, DEUTZ TD2.3L3 DEUTZ TD 2.9L4 49HP & 67HP AND FORD ENGINES (SN 0300298219 to Present)
FIGURE 2-64. HOODS INSTALLATIONS - STEEL - DEUTZ D2011 WITH ARCTIC AND DEUTZ TD2.2L3 ENGINES (SN STARTING WITH B3) (660SJ HC3) (Prior to SN B300017931, Excluding B300014582, B300014853, B300014929, B300014947, B300015022 and B300015307)
FIGURE 2-65. HOODS INSTALLATIONS - STEEL - DEUTZ D2011 WITH ARCTIC AND DEUTZ TD2.2L3 ENGINES (SN STARTING WITH B3) (660SJ HC3) (SN B300017931 to Present, Including B300014852, B300014853, B300014947, B300015022 and B300015307)
FIGURE 2-66. HOOD ASSEMBLY - ENGINE SIDE (STEEL) - DEUTZ D2011 WITH ARCTIC AND DEUTZ TD2.2L3 ENGINES (660SJ HC3)
FIGURE 2-67. HOOD ASSEMBLY - TANK SIDE (STEEL) - DEUTZ D2011 WITH ARCTIC AND DEUTZ TD2.2L3 ENGINES (660SJ HC3) (Prior to SN B300017931, Excluding B300014582, B300014853, B300014929, B300014947, B300015022 and B300015307)
FIGURE 2-68. HOOD ASSEMBLY - TANK SIDE (STEEL) - DEUTZ D2011 WITH ARCTIC AND DEUTZ TD2.2L3 ENGINES (660SJ HC3) (SN B300017931 to Present, Including B300014852, B300014853, B300014947, B300015022 and B300015307)
FIGURE 2-69. NOISE REDUCTION PACKAGE (600S HC3)
FIGURE 2-70. NOISE REDUCTION PACKAGE (660SJ HC3)
FIGURE 2-71. STROBE LIGHT INSTALLATION - AMBER (WITHOUT CLEARSKY BEACON) (Prior to SN 0300298219)
FIGURE 2-72. STROBE LIGHT INSTALLATION - AMBER (WITHOUT CLEARSKY BEACON) (SN 0300298219 to Present)
FIGURE 2-73. STROBE LIGHT INSTALLATION - BLUE (WITHOUT CLEARSKY BEACON) (Prior to SN 0300298219, Prior to SN B300017931, Excluding B300014582, B300014583, B30014929, B300014947, B300015022 and B300015307)
FIGURE 2-74. STROBE LIGHT INSTALLATION - BLUE (WITHOUT CLEARSKY BEACON) (SN 0300298219 to Present, SN B300017931 to Present, Including B300014582, B300014583, B30014929, B300014947, B300015022 and B300015307)
FIGURE 2-75. STROBE LIGHT INSTALLATION - RED (WITHOUT CLEARSKY BEACON) (Prior to SN 0300298219, Prior to SN B300017931, Excluding B300014582, B300014583, B30014929, B300014947, B300015022 and B300015307)
FIGURE 2-76. STROBE LIGHT INSTALLATION - RED (WITHOUT CLEARSKY BEACON) (SN 0300298219 to Present, SN B300017931 to Present, Including B300014582, B300014583, B30014929, B300014947, B300015022 and B300015307)
FIGURE 2-77. TURNTABLE COVERS INSTALLATION
FIGURE 2-78. WHITE NOISE ALARM INSTALLATION (AMBIENT)
FIGURE 2-79. WHITE NOISE ALARM INSTALLATION (CONSTANT)
SECTION 3 - ENGINEFIGURE 3-1. DEUTZ D2011 ENGINE INSTALLATION - WITHOUT ARCTIC PACKAGE (MACHINES WITH SN STARTING WITH 03) (600S HC3)
FIGURE 3-2. DEUTZ D2011 ENGINE INSTALLATION - WITHOUT ARCTIC PACKAGE (MACHINES WITH SN STARTING WITH 03) (660SJ HC3)
FIGURE 3-3. DEUTZ D2011 ENGINE INSTALLATION - WITHOUT ARCTIC PACKAGE (MACHINES WITH SN STARTING WITH B3) (660SJ HC3)
FIGURE 3-4. DEUTZ D2011 ENGINE AND PUMPS SUB-ASSEMBLY - WITHOUT ARCTIC PACKAGE (MACHINES WITH SN STARTING WITH 03)
FIGURE 3-5. DEUTZ D2011 ENGINE AND PUMPS SUB-ASSEMBLY - WITHOUT ARCTIC PACKAGE (MACHINES WITH SN STARTING WITH B3) (660SJ HC3)
FIGURE 3-6. DEUTZ D2011 ENGINE ASSEMBLY - WITHOUT ARCTIC PACKAGE
FIGURE 3-7. DEUTZ D2011 ENGINE INSTALLATION - WITH ARCTIC PACKAGE (MACHINES WITH SN STARTING WITH 03) (600S HC3)
FIGURE 3-8. DEUTZ D2011 ENGINE INSTALLATION - WITH ARCTIC PACKAGE (MACHINES WITH SN STARTING WITH 03) (660SJ HC3)
FIGURE 3-9. DEUTZ D2011 ENGINE INSTALLATION - WITH ARCTIC PACKAGE (MACHINES WITH SN STARTING WITH B3) (660SJ HC3)
FIGURE 3-10. DEUTZ D2011 ENGINE AND PUMPS SUB-ASSEMBLY - WITH ARCTIC PACKAGE (MACHINES WITH SN STARTING WITH 03)
FIGURE 3-11. DEUTZ D2011 ENGINE AND PUMPS SUB-ASSEMBLY - WITH ARCTIC PACKAGE (MACHINES WITH SN STARTING WITH B3) (660SJ HC3)
FIGURE 3-12. DEUTZ D2011 ENGINE ASSEMBLY - WITH ARCTIC PACKAGE
FIGURE 3-13. DEUTZ D2011 ENGINE COMPONENTS
FIGURE 3-14. DEUTZ TD 2.2L3 (STAGE V) ENGINE INSTALLATION (600S HC3)
FIGURE 3-15. DEUTZ TD 2.2L3 (STAGE V) ENGINE INSTALLATION (660SJ HC3)
FIGURE 3-16. DEUTZ TD2.2L3 (STAGE V) ENGINE AND PUMPS SUB-ASSEMBLY
FIGURE 3-17. DEUTZ TD2.2L3 (STAGE V) ENGINE ASSEMBLY
FIGURE 3-18. DEUTZ TD2.2L3 (STAGE V) ENGINE COMPONENTS
FIGURE 3-19. DEUTZ D 2.9L4 - 49HP ENGINE INSTALLATION - WITHOUT ACTIC PACKAGE (600S HC3)
FIGURE 3-20. DEUTZ D 2.9L4 - 49HP ENGINE INSTALLATION - WITHOUT ACTIC PACKAGE (660SJ HC3)
FIGURE 3-21. DEUTZ TD2.9L4 - 49HP ENGINE AND PUMPS SUB-ASSEMBLY - WITHOUT ARCTIC PACKAGE
FIGURE 3-22. DEUTZ TD2.9L4 - 49HP ENGINE ASSEMBLY - WITHOUT ARCTIC PACKAGE (Prior to SN 0300294740)
FIGURE 3-23. DEUTZ TD2.9L4 - 49HP ENGINE ASSEMBLY - WITHOUT ARCTIC PACKAGE (SN 0300294844 to Present)
FIGURE 3-24. DEUTZ TD2.9L4 - 49HP ENGINE ASSEMBLY - WITHOUT ARCTIC PACKAGE (SN 0300294844 to Present)
FIGURE 3-25. DEUTZ D 2.9L4 - 49HP ENGINE INSTALLATION - WITH ARCTIC PACKAGE (600S HC3)
FIGURE 3-26. DEUTZ D 2.9L4 - 49HP ENGINE INSTALLATION - WITH ARCTIC PACKAGE (660SJ HC3)
FIGURE 3-27. DEUTZ TD2.9L4 - 49HP ENGINE AND PUMPS SUB-ASSEMBLY - WITH ARCTIC PACKAGE
FIGURE 3-28. DEUTZ TD2.9L4 - 49HP ENGINE ASSEMBLY - WITH ARCTIC PACKAGE
FIGURE 3-29. DEUTZ TD2.9L4 - 49HP ENGINE COMPONENTS
FIGURE 3-30. DEUTZ TD2.9L4 - 67HP ENGINE INSTALLATION - WITHOUT ARCTIC PACKAGE (600S HC3)
FIGURE 3-31. DEUTZ TD2.9L4 - 67HP ENGINE INSTALLATION - WITHOUT ARCTIC PACKAGE (660SJ HC3)
FIGURE 3-32. DEUTZ TD2.9L4 - 67HP ENGINE AND PUMPS SUB-ASSEMBLY - WITHOUT ARCTIC PACKAGE
FIGURE 3-33. DEUTZ TD2.9L4 - 67HP ENGINE ASSEMBLY - WITHOUT ARCTIC PACKAGE
FIGURE 3-34. DEUTZ TD2.9L4 - 67HP ENGINE INSTALLATION - WITH ARCTIC PACKAGE (600S HC3)
FIGURE 3-35. DEUTZ TD2.9L4 - 67HP ENGINE INSTALLATION - WITH ARCTIC PACKAGE (660SJ HC3)
FIGURE 3-36. DEUTZ TD2.9L4 - 67HP ENGINE AND PUMPS SUB-ASSEMBLY - WITH ARCTIC PACKAGE
FIGURE 3-37. DEUTZ TD2.9L4 - 67HP ENGINE ASSEMBLY - WITH ARCTIC PACKAGE
FIGURE 3-38. DEUTZ TD2.9L4 - 67HP ENGINE COMPONENTS
FIGURE 3-39. BREATHER HEATER INSTALLATION - DEUTZ D2.9L4 - 49HP AND DEUTZ TD2.9L4 - 67HP ENGINES WITH ARCTIC PACKAGE
FIGURE 3-40. FORD ENGINE INSTALLATION - WITHOUT ARCTIC PACKAGE (600S HC3)
FIGURE 3-41. FORD ENGINE INSTALLATION - WITHOUT ARCTIC PACKAGE (660SJ HC3)
FIGURE 3-42. FORD ENGINE AND PUMPS SUB-ASSEMBLY - WITHOUT ARCTIC PACKAGE
FIGURE 3-43. FORD ENGINE ASSEMBLY - WITHOUT ARCTIC PACKAGE
FIGURE 3-44. FORD ENGINE INSTALLATION - WITH ARCTIC PACKAGE (600S HC3)
FIGURE 3-45. FORD ENGINE INSTALLATION - WITH ARCTIC PACKAGE (660SJ HC3)
FIGURE 3-46. FORD ENGINE AND PUMPS SUB-ASSEMBLY - WITH ARCTIC PACKAGE
FIGURE 3-47. FORD ENGINE ASSEMBLY - WITH ARCTIC PACKAGE
FIGURE 3-48. FORD ENGINE PREP ASSEMBLY
FIGURE 3-49. FORD ENGINE COMPONENTS
FIGURE 3-50. PUMP COUPLING KIT (DEUTZ ENGINES)
FIGURE 3-51. PISTON PUMP ASSEMBLY - ALL ENGINES EXCEPT DUETZ D2011 ENGINES ON MACHINES WITH SN STARTING WITH B3
FIGURE 3-52. PISTON PUMP ASSEMBLY - DUETZ D2011 ENGINES ON MACHINES WITH SN STARTING WITH B3
FIGURE 3-53. FUEL FILTER INSTALLATION (POLY FUEL TANK)
FIGURE 3-54. FUEL FILTER INSTALLATION (STEEL FUEL TANK) (DEUTZ D2011 ENGINES)
FIGURE 3-55. FUEL FILTER INSTALLATION (STEEL FUEL TANK) (DEUTZ DT2.9L4 ENGINES)
FIGURE 3-56. MUFFLER INSTALLATION - SPARK ARRESTING (DEUTZ D2011 ENGINES)
FIGURE 3-57. EXHAUST PIPE INSTALLATION - (DEUTZ D2011 ENGINES)
FIGURE 3-58. MOTOR MOUNT INSTALLATION - WITHOUT GENERATOR (DEUTZ D2011 ENGINES)
FIGURE 3-59. MOTOR MOUNT INSTALLATION - WITHOUT GENERATOR (DEUTZ TD 2.9L4 ENGINES)
FIGURE 3-60. MOTOR MOUNT INSTALLATION - WITH GENERATOR (DEUTZ D2011 ENGINES)
FIGURE 3-61. MOTOR MOUNT INSTALLATION - WITH GENERATOR (DEUTZ TD 2.9L4 ENGINES)
FIGURE 3-62. MOTOR MOUNT INSTALLATION - WITH GENERATOR (STAGE V) (DEUTZ TD 2.2L3 ENGINES)
FIGURE 3-63. MOTOR MOUNT INSTALLATION - WITHOUT GENERATOR (STAGE V) (DEUTZ TD 2.2L3 ENGINES)
FIGURE 3-64. MOTOR MOUNT INSTALLATION - WITH GENERATOR (DEUTZ TD 2.9L4 49HP ENGINES)
FIGURE 3-65. MOTOR MOUNT INSTALLATION - WITHOUT GENERATOR (DEUTZ TD 2.9L4 49HP ENGINES)
FIGURE 3-66. BELT WITHOUT GENERATOR INSTALLATION (FORD ENGINES)
FIGURE 3-67. TRAY JACK INSTALLATION
FIGURE 3-68. TRAY JACK INSTALLATION (STAGE V)
FIGURE 3-69. ENGINE HOOD BAFFLES INSTALLATION - ABS HOODS
FIGURE 3-70. ENGINE HOOD BAFFLES INSTALLATION - STEEL HOODS
FIGURE 3-71. ENGINE HOOD BAFFLES INSTALLATION - ABS HOODS (DEUTZ TD 2.2L3 ENGINES AND TD 2.9L4 49HP ENGINES)
FIGURE 3-72. ENGINE HOOD BAFFLES INSTALLATION - STEEL HOODS (DEUTZ TD 2.2L3 ENGINES AND TD 2.9L4 49HP ENGINES)
FIGURE 3-73. 2500W GENERATOR INSTALLATION - 110V/60HZ (DEUTZ D2011 ENGINES)
FIGURE 3-74. 2500W GENERATOR INSTALLATION - 110V/60HZ (DEUTZ TD2.9L4 ENGINES)
FIGURE 3-75. 2500W GENERATOR INSTALLATION - 110V/60HZ (FORD ENGINES)
FIGURE 3-76. 2500W GENERATOR INSTALLATION - 220V/50HZ (DEUTZ D2011 ENGINES)
FIGURE 3-77. 2500W GENERATOR INSTALLATION - 120V/60HZ (DEUTZ TD2.9L4 ENGINES)
FIGURE 3-78. 4000W GENERATOR INSTALLATION - 110V/60HZ (DEUTZ D2011 ENGINES)
FIGURE 3-79. 4000W GENERATOR INSTALLATION - 110V/60HZ (DEUTZ TD2.9L4 ENGINES)
FIGURE 3-80. 4000W GENERATOR INSTALLATION - 220V/50HZ (DEUTZ D2011 ENGINES)
FIGURE 3-81. 4000W GENERATOR INSTALLATION - 220V/50HZ (DEUTZ TD2.2L3 ENGINES) (SKYPOWER)
FIGURE 3-82. 4000W GENERATOR INSTALLATION - 220V/60HZ (DEUTZ TD2.9L4 ENGINES) (SKYPOWER)
FIGURE 3-83. 7500W GENERATOR INSTALLATION - 220V/60HZ (DEUTZ TD2.9L4 ENGINES) (SKYPOWER)
FIGURE 3-84. 7500W SKYPOWER GENERATOR INSTALLATION - 110/60HZ (DEUTZ D2011 ENGINES)
FIGURE 3-85. 7500W SKYPOWER GENERATOR INSTALLATION - 110V/60HZ (DEUTZ TD2.9L4 ENGINES)
FIGURE 3-86. 7500W SKYPOWER GENERATOR INSTALLATION - 110V/60HZ (FORD ENGINES)
FIGURE 3-87. 7500W SKYPOWER GENERATOR INSTALLATION - 220V/50HZ (DEUTZ D2011 ENGINES)
FIGURE 3-88. QUICKFIT OIL DRAIN (DEUTZ ENGINES)
SECTION 4 - BOOMFIGURE 4-1. BOOM INSTALLATION (600S HC3)
FIGURE 4-2. BOOM INSTALLATION (660SJ HC3)
FIGURE 4-3. BOOM ASSEMBLY (600S HC3)
FIGURE 4-4. BOOM ASSEMBLY (660SJ HC3)
FIGURE 4-5. JIB ASSEMBLY (660SJ HC3)
FIGURE 4-6. PLATFORM ROTATOR ASSEMBLY (600S HC3)
FIGURE 4-7. PLATFORM ROTATOR ASSEMBLY (660SJ HC3)
FIGURE 4-8. POWER TRACK INSTALLATION (600S HC3)
FIGURE 4-9. POWER TRACK ASSEMBLY (660SJ HC3)
FIGURE 4-10. VALVE INSTALLATION (600S HC3)
FIGURE 4-11. BOOM VALVES INSTALLATION (660SJ HC3)
FIGURE 4-12. PLATFORM VALVE ASSEMBLY (600S HC3)
FIGURE 4-13. PLATFORM VALVE ASSEMBLY (660SJ HC3)
FIGURE 4-14. BOOM SENSORS INSTALLATION (600S HC3)
FIGURE 4-15. BOOM SENSORS INSTALLATION (660SJ HC3)
FIGURE 4-16. PLATFORM SUPPORT INSTALLATION
SECTION 5 - PLATFORMFIGURE 5-1. PLATFORM ASSEMBLY - 30IN X 3FT (76CM X .91M) - DROP BAR ENTRY
FIGURE 5-2. PLATFORM ASSEMBLY - 30IN X 4FT (76CM X 1.22M) WITH SWING GATE
FIGURE 5-3. PLATFORM ASSEMBLY - 30IN X 4FT (76CM X 1.22M) WITH DROP BAR
FIGURE 5-4. PLATFORM ASSEMBLY - 30IN X 5FT (76CM X 1.52M) WITH SWING GATE
FIGURE 5-5. PLATFORM ASSEMBLY - 30IN X 5FT (76CM X 1.52M) WITH DROP BAR
FIGURE 5-6. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) WITH SWING GATE
FIGURE 5-7. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) WITH DROP BAR
FIGURE 5-8. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) WITH FALL ARREST (ANSI, ANSI EXPORT, CHINA AND CSA SPECS)
FIGURE 5-9. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) TRI-ENTRY WITH SWING GATE
FIGURE 5-10. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) TRI-ENTRY WITH DROP BAR
FIGURE 5-11. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH SWING GATE
FIGURE 5-12. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH DROP BAR
FIGURE 5-13. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH FALL ARREST (ANSI, ANSI EXPORT, CHINA AND CSA SPECS)
FIGURE 5-14. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) TRI-ENTRY WITH SWING GATE
FIGURE 5-15. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) TRI-ENTRY WITH DROP BAR
FIGURE 5-16. PLATFORM POWER USB
FIGURE 5-17. TRAY ASSEMBLY
FIGURE 5-18. PLATFORM CONSOLE AND FOOTSWITCH INSTALLATION (600S HC3)
FIGURE 5-19. PLATFORM CONSOLE AND FOOTSWITCH INSTALLATION (660SJ HC3)
FIGURE 5-20. CONSOLE BOX ASSEMBLY
FIGURE 5-21. CONTROLLER ASSEMBLY (DRIVE AND STEER)
FIGURE 5-22. CONTROLLER ASSEMBLY (LIFT AND SWING)
FIGURE 5-23. FOOTSWITCH ASSEMBLY
FIGURE 5-24. LIGHT PANEL INSTALLATION
FIGURE 5-25. SKYEYE INSTALLATION
FIGURE 5-26. SKYGUARD BAR INSTALLATION
FIGURE 5-27. SKYLINE INSTALLATION
FIGURE 5-28. SKYWELDER INSTALLATION (50HZ)
FIGURE 5-29. SKYWELDER INSTALLATION (60HZ)
FIGURE 5-30. SKYWELDER PREP PACKAGE (60HZ)
FIGURE 5-31. WELDER ASSEMBLY
FIGURE 5-32. SKYGLAZIER INSTALLATION
FIGURE 5-33. SOFT TOUCH INSTALLATION - 6FT (1.83M) PLATFORM
FIGURE 5-34. SOFT TOUCH INSTALLATION - 6FT (1.83M) FALL ARREST PLATFORM (600S HC3)
FIGURE 5-35. SOFT TOUCH INSTALLATION - 8FT (2.4M) PLATFORM
FIGURE 5-36. SOFT TOUCH INSTALLATION - 8FT (2.4M) FALL ARREST PLATFORM (600S HC3)
FIGURE 5-37. FALL ARREST INSTALLATION (BOLT-ON EXTERNAL) (6FT/1.82M PLATFORM)
FIGURE 5-38. FALL ARREST INSTALLATION (BOLT-ON EXTERNAL) (6FT/1.82M TRI-ENTRY PLATFORM)
FIGURE 5-39. FALL ARREST INSTALLATION (BOLT-ON EXTERNAL) (2.5FT/1.22M PLATFORM)
FIGURE 5-40. FALL ARREST INSTALLATION (BOLT-ON EXTERNAL) (2.5FT/1.52M PLATFORM)
FIGURE 5-41. FALL ARREST INSTALLATION (BOLT-ON EXTERNAL) (8FT/2.4M PLATFORM)
SECTION 6 - CYLINDERFIGURE 6-1. AXLE LOCKOUT CYLINDER ASSEMBLY (MACHINES WITH SN STARTING WITH 03)
FIGURE 6-2. AXLE LOCKOUT CYLINDER ASSEMBLY (MACHINES WITH SN STARTING WITH B3)
FIGURE 6-3. LEVEL CYLINDER ASSEMBLY - PLATFORM SLAVE (600S HC3)
FIGURE 6-4. LEVEL CYLINDER ASSEMBLY - PLATFORM SLAVE (660SJ HC3)
FIGURE 6-5. LIFT CYLINDER ASSEMBLY BOOM (600S HC3)
FIGURE 6-6. LIFT CYLINDER ASSEMBLY BOOM (660SJ HC3)
FIGURE 6-7. LIFT CYLINDER ASSEMBLY - JIB (660SJ HC3)
FIGURE 6-8. LIFT CYLINDER ASSEMBLY - JIB (660SJ HC3)
FIGURE 6-9. LIFT CYLINDER ASSEMBLY - JIB (660SJ HC3)
FIGURE 6-10. STEER CYLINDER ASSEMBLY
FIGURE 6-11. TELESCOPE CYLINDER ASSEMBLY
SECTION 7 - HYDRAULICFIGURE 7-1. DRIVE HYDRAULIC DIAGRAM (2WS WITHOUT ARCTIC PACKAGE) (600S HC3)
FIGURE 7-2. DRIVE HYDRAULIC DIAGRAM (2WS WITHOUT ARCTIC PACKAGE) (660SJ HC3)
FIGURE 7-3. DRIVE HYDRAULIC DIAGRAM (2WS WITH ARCTIC PACKAGE) (600S HC3)
FIGURE 7-4. DRIVE HYDRAULIC DIAGRAM (2WS WITH ARCTIC PACKAGE) (660SJ HC3)
FIGURE 7-5. STANDARD HYDRAULIC DIAGRAM (600S HC3)
FIGURE 7-6. STANDARD HYDRAULIC DIAGRAM (MACHINES WITH SN STARTING WITH 03) (660SJ HC3)
FIGURE 7-7. STANDARD HYDRAULIC DIAGRAM (MACHINES WITH SN STARTING WITH B3) (660SJ HC3)
SECTION 8 - ELECTRICALFIGURE 8-1. ELECTRICAL LAYOUT
FIGURE 8-2. AC BOX AT PLATFORM INSTALLATION - 110V (ALL SPECS EXCEPT AUSTRALIAN, RUSSIA, CE & UK CA SPECS)
FIGURE 8-3. AC BOX AT PLATFORM INSTALLATION - 110V IEC YELLOW (RUSSIA, CE & UK CA SPECS WITHOUT 4000W/50HZ GENERATOR)
FIGURE 8-4. AC BOX AT PLATFORM INSTALLATION - 110V IEC YELLOW (RUSSIA, CE & UK CA SPECS WITH 4000W/50HZ GENERATOR)
FIGURE 8-5. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE (RUSSIA, CE & UK CA SPECS WITHOUT 4000W/50HZ GENERATOR)
FIGURE 8-6. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE (RUSSIA, CE & UK CA SPECS WITH 4000W/50HZ GENERATOR)
FIGURE 8-7. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 2IN X 4IN POST GROUND (RUSSIA, CE & UK CA SPECS WITHOUT 4000W/50HZ GENERATOR)
FIGURE 8-8. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 2IN X 4IN POST GROUND (RUSSIA, CE & UK CA SPECS WITH 4000W/50HZ GENERATOR)
FIGURE 8-9. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 2IN X 4IN SIDE GROUND (RUSSIA, CE & UK CA SPECS WITHOUT 4000W/50HZ GENERATOR)
FIGURE 8-10. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 2IN X 4IN SIDE GROUND (RUSSIA, CE & UK CA SPECS WITH 4000W/50HZ GENERATOR)
FIGURE 8-11. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT107 (RUSSIA, CE & UK CA SPECS WITHOUT 4000W/50HZ GENERATOR)
FIGURE 8-12. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT107 (RUSSIA, CE & UK CA SPECS WITH 4000W/50HZ GENERATOR)
FIGURE 8-13. AC BOX AT PLATFORM INSTALLATION - 220V CUSTOMER SUPPLIED COMPONENTS (ANSI EXPORT, AUSTRALIAN, RUSSIA, CHINA, CE & UK CA SPECS)
FIGURE 8-14. AC BOX AT PLATFORM INSTALLATION - 240V (WITH 4000W GENERATOR)
FIGURE 8-15. AC BOX AT PLATFORM INSTALLATION - 240V (WITH 7500W SKYPOWER GENERATOR)
FIGURE 8-16. AC BREAKER BOX INSTALLATION - SINGLE DOUBLE POLE BREAKER
FIGURE 8-17. AC BREAKER BOX INSTALLATION - 3 BREAKERS
FIGURE 8-18. AC CABLES AND CLAMPS INSTALLATION - WITHOUT GENERATOR (ANSI, CSA & JAPANESE SPECS) (600S HC3)
FIGURE 8-19. AC CABLES AND CLAMPS INSTALLATION - WITHOUT GENERATOR (ANSI EXPORT,CE, RUSSIA CIS, CHINA & UK CA SPECS) (600S HC3)
FIGURE 8-20. AC CABLES AND CLAMPS INSTALLATION - WITH 2500W GENERATOR (ANSI, ANSI EXPORT, CHINA, CSA AND JAPANESE SPECS) (600S HC3)
FIGURE 8-21. AC CABLES AND CLAMPS INSTALLATION - WITH 4000W/50HZ GENERATOR (ANSI EXPORT, CE, CHINA, RUSSIAN CIS & UK CA SPECS) (600S HC3)
FIGURE 8-22. AC CABLES AND CLAMPS INSTALLATION - WITH 4000W/60HZ GENERATOR (ANSI, ANSI EXPORT, CSA AND JAPANESE SPECS) (600S HC3)
FIGURE 8-23. AC CABLES AND CLAMPS INSTALLATION - WITH 7500W GENERATOR (ANSI, ANSI EXPORT, CHINA, CSA, RUSSIAN CIS AND JAPANESE SPECS) (600S HC3)
FIGURE 8-24. AC CABLES AND CLAMPS INSTALLATION - WITHOUT GENERATOR (ANSI, CSA AND JAPANESE SPECS) (660SJ HC3)
FIGURE 8-25. AC CABLES AND CLAMPS INSTALLATION - WITHOUT GENERATOR (ANSI EXPORT, AUSTRALIAN, RUSSIA CIS, CHINA, CE & UK CA SPECS) (660SJ HC3)
FIGURE 8-26. AC CABLES AND CLAMPS INSTALLATION - WITH 2500W GENERATOR (ANSI, ANSI EXPORT, CHINA, CSA AND JAPANESE SPECS) (660SJ HC3)
FIGURE 8-27. AC CABLES AND CLAMPS INSTALLATION - WITH 4000W/50HZ GENERATOR (ANSI EXPORT, AUSTRALIAN, RUSSIA CIS, CHINA, CE & UK CA SPECS) (660SJ HC3)
FIGURE 8-28. AC CABLES AND CLAMPS INSTALLATION - WITH 4000W/60HZ GENERATOR (ANSI, ANSI EXPORT, CSA AND JAPANESE SPECS) (660SJ HC3)
FIGURE 8-29. AC CABLES AND CLAMPS INSTALLATION - WITH 7500W GENERATOR (ANSI, ANSI EXPORT, AUSTRALIAN, CHINA, CSA, RUSSIAN CIS, AND JAPANESE SPECS) (660SJ HC3)
FIGURE 8-30. BATTERY DISCONNECT SWITCH INSTALLATION
FIGURE 8-31. BEACON JUMPER HARNESS
FIGURE 8-32. BREAKER BOX KIT - SINGLE DOUBLE POLE BREAKER (WITHOUT 4000W/50HZ GENERATOR)
FIGURE 8-33. BREAKER BOX KIT - SINGLE DOUBLE POLE BREAKER (WITH 4000W/50HZ GENERATOR)
FIGURE 8-34. BREAKER BOX KIT - 3 BREAKERS
FIGURE 8-35. BOOM ANGLE SENSOR HARNESS
FIGURE 8-36. BOOM CABLE - LOWER
FIGURE 8-37. BOOM CABLE - UPPER (600S HC3)
FIGURE 8-38. BOOM CABLE - UPPER (660SJ HC3)
FIGURE 8-39. CAPACITY PROXIMITY HARNESS (1000LBS)
FIGURE 8-40. CAPACITY PROXIMITY HARNESS (750 LBS)
FIGURE 8-41. CLEARSKY 3-WIRE TELEMATICS INSTALLATION (ALL SPECS EXCEPT CHINA SPECS)
FIGURE 8-42. CLEARSKY 3G CANBUS TELEMATICS INSTALLATION (ANSI EXPORT, RUSSIA, CE & UK CA SPECS)
FIGURE 8-43. CLEARSKY 3G CANBUS TELEMATICS INSTALLATION (AUSTRALIAN AND RUSSIA SPECS)
FIGURE 8-44. CLEARSKY 4G CANBUS TELEMATICS INSTALLATION (ALL SPECS EXCEPT AUSTRALIA AND CHINA SPECS)
FIGURE 8-45. CLEARSKY 4G CANBUS TELEMATICS INSTALLATION (CHINA SPECS)
FIGURE 8-46. CLEARSKY CS550 BEACON INSTALLATION - WITH METAL HOOD
FIGURE 8-47. CLEARSKY CS550 BEACON INSTALLATION - WITH PLASTIC HOOD
FIGURE 8-48. CLEARSKY HARNESS - 3-WIRE TELEMATICS
FIGURE 8-49. CLEARSKY HARNESS - CANBUS TELEMATICS
FIGURE 8-50. ECU POWER JUMPER HARNESS
FIGURE 8-51. ELECTRICAL COMPONENTS INSTALLATION (ALL SPECS EXCEPT AUSTRALIAN, CE & UK CA (ULS) SPECS) (600S HC3) (Prior to SN 0300298219)
FIGURE 8-52. ELECTRICAL COMPONENTS INSTALLATION (ALL SPECS EXCEPT AUSTRALIAN, CE & UK CA (ULS) SPECS) (600S HC3) (SN 0300298219 to Present)
FIGURE 8-53. ELECTRICAL COMPONENTS INSTALLATION (CE & UK CA (ULS) SPECS) (600S HC3) (Prior to SN 0300298219)
FIGURE 8-54. ELECTRICAL COMPONENTS INSTALLATION (CE & UK CA (ULS) SPECS) (600S HC3) (SN 0300298219 to Present)
FIGURE 8-55. ELECTRICAL COMPONENTS INSTALLATION (ALL SPECS EXCEPT CE & UK CA (ULS) SPECS) (660SJ HC3) (Prior to SN 0300298219, Prior to SN B300017931, Excluding B300014582, B300014583, B30014929, B300014947, B300015022 and B300015307)
FIGURE 8-56. ELECTRICAL COMPONENTS INSTALLATION (ALL SPECS EXCEPT CE & UK CA (ULS) SPECS) (660SJ HC3) (SN 0300298219 to Present, SN B300017931 to Present, Including B300014582, B300014583, B30014929, B300014947, B300015022 and B300015307)
FIGURE 8-57. ELECTRICAL COMPONENTS INSTALLATION (CE & UK CA (ULS) SPECS) (660SJ HC3) (Prior to SN 0300298219, Prior to SN B300017931, Excluding B300014582, B300014583, B30014929, B300014947, B300015022 and B300015307)
FIGURE 8-58. ELECTRICAL COMPONENTS INSTALLATION (CE & UK CA (ULS) SPECS) (660SJ HC3) (SN 0300298219 to Present, SN B300017931 to Present, Including B300014582, B300014583, B30014929, B300014947, B300015022 and B300015307)
FIGURE 8-59. ENGINE HARNESS - DEUTZ D2011 ENGINES
FIGURE 8-60. ENGINE HARNESS - DEUTZ TD2.2L3 ENGINES (Prior to SN 0300298219, Prior to SN B300017931, Excluding B300014582, B300014583, B30014929, B300014947, B300015022 and B300015307)
FIGURE 8-61. ENGINE HARNESS - DEUTZ TD2.2L3 ENGINES (SN 0300298219 to Present, SN B300017931 to Present, Including B300014582, B300014583, B30014929, B300014947, B300015022 and B300015307)
FIGURE 8-62. ENGINE HARNESS - DEUTZ D2.9L4 - 49HP AND DEUTZ TD2.9L4 - 67HP ENGINES
FIGURE 8-63. ENGINE HARNESS - FORD ENGINES
FIGURE 8-64. FUEL FILTER HARNESS - DEUTZ TD2.2L3 (STAGE V) ENGINES
FIGURE 8-65. FUEL PUMP HARNESS - DEUTZ D2.9L4 - 49HP AND DEUTZ TD2.9L4 - 67HP ENGINES
FIGURE 8-66. GENERATOR HARNESS - 2500W
FIGURE 8-67. GENERATOR HARNESS - 4000W
FIGURE 8-68. GENERATOR HARNESS - 7500W SKYPOWER
FIGURE 8-69. GENERATOR TO ENGINE HARNESS - 7500W SKYPOWER GENERATOR (DEUTZ D2011 ONLY)
FIGURE 8-70. GROUND CONTROL HARNESS
FIGURE 8-71. LIFT CYLINDER HARNESS
FIGURE 8-72. PLATFORM BOX HARNESS
FIGURE 8-73. RECEPTACLE BOX KIT - 110V IEC YELLOW (RUSSIA, CE & UK CA SPECS)
FIGURE 8-74. RECEPTACLE BOX KIT - 220V IEC BLUE (RUSSIA, CE & UK CA SPECS)
FIGURE 8-75. RECEPTACLE BOX KIT - 220V CEE7 POST GROUND 2X4 BOX (RUSSIA, CE & UK CA SPECS)
FIGURE 8-76. RECEPTACLE BOX KIT - 220V CEE7 SIDE GROUND (RUSSIA, CE & UK CA SPECS)
FIGURE 8-77. RECEPTACLE BOX KIT - 220V AFSINT 107 (RUSSIA, CE & UK CA SPECS)
FIGURE 8-78. RELAY & FUEL PUMP HARNESS
FIGURE 8-79. SKYEYE EMITTER HARNESS
FIGURE 8-80. SKYEYE INTERMEDIATE HARNESS
FIGURE 8-81. SKYEYE RECEIVER HARNESS
FIGURE 8-82. SKYGUARD INTERFACE HARNESS
FIGURE 8-83. SKYLINE HARNESS
FIGURE 8-84. STROBE LIGHT HARNESS (RED AND BLUE BEACON LIGHTS)
FIGURE 8-85. STROBE LIGHT JUMPER HARNESS
FIGURE 8-86. TELE PROXIMITY HARNESS
FIGURE 8-87. TRANSPORT SWITCH HARNESS (660SJ HC3)
FIGURE 8-88. TURNTABLE HARNESS (Prior to SN 0300298219, Prior to SN B300017931, Excluding B300014582, B300014583, B30014929, B300014947, B300015022 and B300015307)
FIGURE 8-89. TURNTABLE HARNESS (SN 0300298219 to Present, SN B300017931 to Present, Including B300014582, B300014583, B30014929, B300014947, B300015022 and B300015307)
FIGURE 8-90. VALVE CABLE - PLATFORM VALVE
FIGURE 8-91. VALVE HARNESS - MAIN VALVE (Prior to SN 0300298219, Prior to SN B300017931, Excluding B300014582, B300014583, B30014929, B300014947, B300015022 and B300015307)
FIGURE 8-92. VALVE HARNESS - MAIN VALVE (SN 0300298219 to Present, SN B300017931 to Present, Including B300014582, B300014583, B30014929, B300014947, B300015022 and B300015307)
FIGURE 8-93. VALVE HARNESS - PLATFORM VALVE (600S HC3)
FIGURE 8-94. VALVE HARNESS - PLATFORM VALVE (660SJ HC3)
FIGURE 8-95. WHITE NOISE ALARM HARNESS
SECTION 9 - DECALSFIGURE 9-1. DECAL INSTALLATION (ANSI SPECS - ENGLISH LANGUAGE)
FIGURE 9-2. DECAL INSTALLATION (AUSTRALIAN SPECS - ENGLISH LANGUAGE)
FIGURE 9-3. DECAL INSTALLATION (BRAZIL SPECS - PORTUGUESE/SPANISH LANGUAGES)
FIGURE 9-4. DECAL INSTALLATION (CE & UK CA SPECS - ENGLISH LANGUAGE)
FIGURE 9-5. DECAL INSTALLATION (CHINESE SPECS - ENGLISH/SIMPLIFIED CHINESE LANGUAGES)
FIGURE 9-6. DECAL INSTALLATION (CHINESE SPECS - ENGLISH/TRADITIONAL CHINESE LANGUAGES)
FIGURE 9-7. DECAL INSTALLATION (CSA SPECS - ENGLISH/FRENCH LANGUAGES)
FIGURE 9-8. DECAL INSTALLATION (JAPANESE SPECS - ENGLISH/JAPANESE LANGUAGES)
FIGURE 9-9. DECAL INSTALLATION (KOREAN SPECS - ENGLISH/KOREAN LANGUAGES)
FIGURE 9-10. DECAL INSTALLATION - LATIN AMERICAN SPECS - ENGLISH/SPANISH LANGUAGES)
FIGURE 9-11. DECALS INSTALLATION - OPTIONS
FIGURE 9-12. DECAL INSTALLATION - SKYWELDER (50HZ)
FIGURE 9-13. DECAL INSTALLATION - SKYWELDER (60HZ)
FIGURE 9-14. DECAL INSTALLATION - TOW (ANSI SPECS)
FIGURE 9-15. DECAL INSTALLATION - TOW (ANSI EXPORT, RUSSIA, CHINA, CE & UK CA SPECS)
FIGURE 9-16. DECAL INSTALLATION - TOW (CSA SPECS)
PART NUMBER INDEX
- SuperPac Parts Manual
- StratoLift Parts Manual
