JLG Boom Lift 600S HC3 660SJ HC3 Operation Safety Manual 31223056
Brand: JLG
Type of Machine: Boom Lift
Type of Manual: Operation Safety Manual
Model: JLG 600S HC3, 660SJ HC3 Boom Lift
Part Number: 31223056
Publication Date: 2024
Number of Pages: 154 Pages
Cover - 600S HC3 660SJ HC3 - PVC 2401 - 31223056
Foreword
Revision Log - 600S HC3 660SJ HC3 - PVC 2401
Brand: JLG
Foreword
Other Publications Available
Safety PrecautionsGeneral
Pre-Operation
1.2.1 Operator Training and Knowledge
1.2.2 Workplace Inspection
1.2.3 Machine Inspection
Operation
1.3.1 General
1.3.2 Trip and Fall Hazards
1.3.3 Electrocution Hazards
1.3.4 Tipping Hazards
1.3.5 Crushing and Collision Hazards
Towing, Lifting, and Hauling
Maintenance
1.5.1 Maintenance Hazards
1.5.2 Battery Hazards
User Responsibilities, Machine Preparation, and InspectionPersonnel Training
2.1.1 Operator Training
2.1.2 Training Supervision
2.1.3 Operator Responsibility
2.1.4 Machine Familiarization
Preparation, Inspection and Maintenance
Machine Components
Pre-Start Inspection
Walk-Around Inspection
2.5.1 Walk-Around Inspection
Function Check - SJ Model
SkyGuard® Function Check
Machine Controls and IndicatorsGeneral
Ground Control Station
Ground Control Indicator Panel - ICE HC3 - Fuel Gauge
3.4.1 Ground Control Indicator Panel Functions
600S/660SJ Platform Control Station
3.5.1 Platform Control Station Functions
Platform Indicator Panel - ICE HC3 - Fuel Gauge
3.6.1 Platform Control Indicator Panel Functions
Beacons (With SkyGuard)
3.7.1 ClearSky® LED Motion / Amber Beacon (CS550)
3.7.2 Amber Beacon
3.7.3 Blue or Red SkyGuard® Beacon
Machine OperationGeneral SJ 360 Continuous Swing
Operating Characteristics And Limitations - HC3
4.2.1 Operating Conditions
4.2.2 Platform Load Sensing System (LSS)
4.2.3 Capacity Zones (Triple Capacity)
600S/660SJ Stability
Engine Operation
4.4.1 Starting Procedure
4.4.2 Shutdown Procedure
Air Shutoff Valve (ASOV)
Fuel Shutoff System (Reserve) - Fuel Gauge
Diesel Particulate Filter (If Equipped)
Traveling (Driving)
4.8.1 Traveling Forward and Reverse
600S/660SJ Traveling (Grade/Side Slope)
4.9.1 Traveling on a Grade
Steering
Platform - Standard Booms
4.11.1 Platform Level Adjustment
4.11.2 Platform Rotation
Boom - SJ Models
4.12.1 Swinging the Boom
4.12.2 Raising and Lowering the Main Boom
4.12.3 Telescoping the Main Boom
Shut Down And Park
Battery Quick-Disconnect (If Equipped)
Function Speed Control - SJ Core Boom
USB Charging Port
ClearSky Smart Fleet
Access Control (Boom)
Machine Safety System Override (MSSO) (If Equipped)
SkyGuard Activation/Deactivation - SJ
Oscillating Axle Lockout Test (If Equipped)
Towing (If Equipped)
Auxiliary Power - SJ
4.23.1 Activating Auxiliary Power from the Platform Control Station
4.23.2 Activating Auxiliary Power from the Ground Control Station
Dual Fuel System (Gas Engine Only)
4.24.1 Changing From Gasoline to LP Gas
4.24.2 Changing From LP Gas to Gasoline
Lifting And Tie Down
4.25.1 Lifting
4.25.2 Tie Down
Lifting Chart - 600S-660SJ
600S/660SJ HC3 Safety Decal Locations
Emergency ProceduresGeneral
Incident Notification - Boom
Emergency Operation
5.3.1 Operator Unable to Control Machine
5.3.2 Platform or Boom Caught Overhead
Emergency Towing Procedures
ClearSky Smart Fleet - Locked Out State
Accessories600S HC3 660SJ HC3 Accessory Table
Bolt-On External Fall Arrest
6.2.1 Inspection Before Use
Fabric Mesh to Mid/Top Rail
Fall Arrest Platform
6.4.1 Safety Precautions
Nite Bright
Pipe Racks
6.6.1 Capacity Specifications (Australia Only)
6.6.2 Safety Precautions
6.6.3 Preparation and Inspection
6.6.4 Operation
Platform Mesh to Mid/Top Rail
Platform Mid Rail Deck
6.8.1 Accessory Installation
6.8.2 Access to Manual Box
Platform Top Rail Extension
Platform Work Lights
SkyGlazier
6.11.1 Capacity Specifications
6.11.2 Safety Precautions
6.11.3 Preparation and Inspection
6.11.4 Operation
SkyPower 7.5kW and Generator 4kW
6.12.1 Output
6.12.2 Safety Precautions
6.12.3 Preparation and Inspection
6.12.4 Operation
SkySense
6.13.1 Preparation and Inspection
6.13.2 Operation
6.13.3 SkySense Platform Panel Indicators
6.13.4 SkySense Alarm
6.13.5 SkySense Override Button
6.13.6 SkySense Coverage Areas
SkySense Platform Bumper Padding
SkyWelder
6.15.1 Operation
6.15.2 Generator Output
6.15.3 Welding Accessories
6.15.4 Safety Precautions
6.15.5 Preparation and Inspection
Soft Touch
General Specifications and Operator MaintenanceGeneral
Serial Number Location 600S/660SJ
600S/660SJ HC3 Operating Specifications
7.3.1 Dimensional Data
7.3.2 Capacities
7.3.3 Engine Data
7.3.4 Tires
7.3.5 Critical Stability Weights
Hydraulic Oil Specifications - Introduction
Engine Oil Operating Temperature Specifications
Operator Maintenance and Lubrication Diagram 600S/660SJ
7.6.1 Deutz 2011 Engine
7.6.2 Deutz TD 2.9L, 2.2L Stage V
7.6.3 Ford DF 2.5L, MSG 425
Operator Maintenance 600S/660SJ
Tires and Wheels - 9 Lug Nuts
7.8.1 Tire Damage
7.8.2 Tire Replacement
7.8.3 Wheel Replacement
7.8.4 Wheel Installation
Propane Fuel System Pressure Relief
Radio Frequency (RF) Information
7.11.1 Federal Communications Commission (FCC)
7.11.2 Innovation, Science and Economic Development (ISED)
Supplemental Information Only Applicable to CE/UKCA
600S/660SJ EC Declaration of Conformity
600S/660SJ UKCA Declaration of Conformity
- SuperPac Parts Manual
- StratoLift Parts Manual
