JLG Boom Lift 600S 660SJ Parts Catalog 3122339500
Brand: JLG
Type of Machine: Boom Lift
Model: JLG 600S, 660SJ Boom Lift
Part Number: 3122339500
Publication Date: 2025
Number of Pages: 1344 Pages
SECTION 1 - FRAME
Brand: JLG
SECTION 1 - FRAME
FIGURE 1-1. AXLE INSTALLATION - FRONT
FIGURE 1-2. AXLE INSTALLATION - REAR (4WS ONLY)
FIGURE 1-3. AXLE INSTALLATION
FIGURE 1-4. STEER INSTALLATION - WITHOUT TOW PACKAGE
FIGURE 1-5. STEER INSTALLATION - WITH TOW PACKAGE
FIGURE 1-6. WHEEL DRIVE INSTALLATION - 4WD/2WS (MACHINES WITH SN STARTING WITH 03) (Prior to SN 0300330061)
FIGURE 1-7. WHEEL DRIVE INSTALLATION - 4WD/2WS (MACHINES WITH SN STARTING WITH 03) (SN 0300330062 through 0300336086, SN 0300329714 through 0300329716, SN 0300329727 through 0300329743, SN 0300329758 through 0300329759, SN 0300329764 through 030032976...
FIGURE 1-8. WHEEL DRIVE INSTALLATION - 4WD/2WS (SN 0300336087 to Present)
FIGURE 1-9. WHEEL DRIVE INSTALLATION - 4WD/4WS (MACHINES WITH SN STARTING WITH 03) (Prior to SN 0300330061)
FIGURE 1-10. WHEEL DRIVE INSTALLATION - 4WD/4WS (MACHINES WITH SN STARTING WITH 03) (SN 0300330062 through 0300336086, SN 0300329714 through 0300329716, SN 0300329727 through 0300329743, SN 0300329758 through 0300329759, SN 0300329764 through 03003297...
FIGURE 1-11. WHEEL DRIVE INSTALLATION - 4WD/4WS (SN 0300336087 to Present)
FIGURE 1-12. DRIVE MOTOR ASSEMBLY (MACHINES WITH SN STARTING WITH 03)
FIGURE 1-13. DRIVE MOTOR ASSEMBLY (MACHINES WITH SN STARTING WITH B3)
FIGURE 1-14. DRIVE HUB ASSEMBLY
FIGURE 1-15. TRACTION VALVE ASSEMBLY
FIGURE 1-16. TRACTION VALVE ASSEMBLY (MACHINES WITH SN STARTING WITH 03)
FIGURE 1-17. TIRE & WHEEL INSTALLATION - IN355-55 D625 FOAM FILLED (AVAILABLE ON ALL SPECS)
FIGURE 1-18. TIRE & WHEEL INSTALLATION - IN355-55 D625 FOAM FILLED NON-MARKING (AVAILABLE ON ALL SPECS)
FIGURE 1-19. TIRE & WHEEL INSTALLATION - 41-18LL X 22.5 FOAM FILLED TURF & SAND (AVAILABLE ON ALL SPECS EXCEPT AUSTRALIAN, CE & UK CA SPECS)
FIGURE 1-20. MATTRACKS INSTALLATION
FIGURE 1-21. LP TANKS AND BRACKETS INSTALLATION (FORD ENGINES)
FIGURE 1-22. FRAME COVERS INSTALLATION - 2WS
FIGURE 1-23. FRAME COVERS INSTALLATION - 4WS
FIGURE 1-24. TOW BAR INSTALLATION
SECTION 2 - TURNTABLEFIGURE 2-1. VALVE INSTALLATION - WITH 2WS (600S)
FIGURE 2-2. VALVE INSTALLATION - WITH 4WS (600S)
FIGURE 2-3. VALVE INSTALLATION - WITH 2WS (660SJ) (Prior to SN 0300332719, Prior to SN B300030390, Prior to SN C300002934)
FIGURE 2-4. VALVE INSTALLATION - WITH 2WS (660SJ) (SN 0300332720 to Present, SN B300030391 to Present, SN C300002935 to Present, Including B300030161 and C300002760)
FIGURE 2-5. VALVE INSTALLATION - WITH 4WS (660SJ) (Prior to SN 0300332719, Prior to SN B300030390, Prior to SN C300002934)
FIGURE 2-6. VALVE INSTALLATION - WITH 4WS (660SJ) (SN 0300332720 to Present, SN B300030391 to Present, SN C300002935 to Present, Including B300030161 and C300002760)
FIGURE 2-7. MAIN VALVE ASSEMBLY - 2WS
FIGURE 2-8. MAIN VALVE ASSEMBLY - 4WS
FIGURE 2-9. AXLE VALVE ASSEMBLY
FIGURE 2-10. SWING DRIVE INSTALLATION
FIGURE 2-11. SWING MOTOR/HUB ASSEMBLY
FIGURE 2-12. TURNTABLE BEARING AND LUBE INSTALLATION
FIGURE 2-13. TURNTABLE LOCK INSTALLATION
FIGURE 2-14. ROTARY COUPLING INSTALLATION - 2WS (600S)
FIGURE 2-15. ROTARY COUPLING ASSEMBLY - 2WS
FIGURE 2-16. ROTARY COUPLING INSTALLATION - 4WS (600S)
FIGURE 2-17. ROTATOR COUPLING INSTALLATION (MACHINES WITH SN STARTING WITH B3) (660SJ)
FIGURE 2-18. ROTATOR COUPLING ASSEMBLY (MACHINES WITH SN STARTING WITH B3) (660SJ)
FIGURE 2-19. TANKS INSTALLATION - DIESEL MACHINES (POLY FUEL TANK) (HYDRAULIC TANK WITH 6 INCH BREATHER)
FIGURE 2-20. TANKS INSTALLATION - DIESEL MACHINES (POLY FUEL TANK) (HYDRAULIC TANK WITH 4 INCH BREATHER)
FIGURE 2-21. TANKS INSTALLATION - DIESEL MACHINES (STEEL FUEL TANK) (HYDRAULIC TANK WITH 6 INCH BREATHER)
FIGURE 2-22. TANKS INSTALLATION - DIESEL MACHINES (STEEL FUEL TANK) (HYDRAULIC TANK WITH 4 INCH BREATHER)
FIGURE 2-23. TANKS INSTALLATION - GAS MACHINES (HYDRAULIC TANK WITH 6 INCH BREATHER)
FIGURE 2-24. TANKS INSTALLATION - GAS MACHINES (HYDRAULIC TANK WITH 4 INCH BREATHER)
FIGURE 2-25. HYDRAULIC TANK ASSEMBLY (HYDRAULIC TANK WITH 6 INCH BREATHER)
FIGURE 2-26. HYDRAULIC TANK ASSEMBLY
FIGURE 2-27. BATTERY AND AUXILIARY PUMP INSTALLATION
FIGURE 2-28. BATTERY AND AUXILIARY PUMP WITH DISCONNECT SWITCH INSTALLATION
FIGURE 2-29. ELECTRICAL COMPONENTS INSTALLATION- WITH 2WS
FIGURE 2-30. ELECTRICAL COMPONENTS INSTALLATION - 600S WITH 2WS AND DEUTZ TD2.2L3 (STAGE V) ENGINE
FIGURE 2-31. ELECTRICAL COMPONENTS INSTALLATION - WITH 4WS
FIGURE 2-32. ELECTRICAL COMPONENTS INSTALLATION - 600S WITH 4WS AND DEUTZ TD2.2L3 (STAGE V) ENGINE
FIGURE 2-33. ELECTRICAL COMPONENTS INSTALLATION - STANDARD WITH 2WS
FIGURE 2-34. ELECTRICAL COMPONENTS INSTALLATION - 660SJ STANDARD WITH 2WS AND DEUTZ TD2.2L3 (STAGE V) ENGINE
FIGURE 2-35. ELECTRICAL COMPONENTS INSTALLATION - STANDARD WITH 4WS
FIGURE 2-36. ELECTRICAL COMPONENTS INSTALLATION - 660SJ STANDARD WITH 4WS AND DEUTZ TD2.2L3 (STAGE V) ENGINE
FIGURE 2-37. ELECTRICAL COMPONENTS INSTALLATION - 660SJ 1K63FT WITH 2WS
FIGURE 2-38. ELECTRICAL COMPONENTS INSTALLATION - 660SJ 1K63FT WITH 4WS
FIGURE 2-39. ELECTRICAL COMPONENTS INSTALLATION - 660SJ 1K63FT WITH 2WS
FIGURE 2-40. GROUND CONTROL ASSEMBLY (600S)
FIGURE 2-41. GROUND CONTROL ASSEMBLY - 600S WITH DEUTZ TD2.2L3 (STAGE V) ENGINE (600S)
FIGURE 2-42. GROUND CONTROL ASSEMBLY (660SJ)
FIGURE 2-43. GROUND CONTROL ASSEMBLY - 660SJ WITH DEUTZ TD2.2L3 (STAGE V) ENGINE (660SJ)
FIGURE 2-44. HOODS INSTALLATIONS - ABS (DEUTZ D2.9L4 - 49HP ENGINE)
FIGURE 2-45. HOODS INSTALLATIONS - ABS (DEUTZ D2011, DEUTZ TD2.9L4 - 67HP AND FORD ENGINES)
FIGURE 2-46. HOOD ASSEMBLY - ENGINE SIDE (ABS)
FIGURE 2-47. HOOD ASSEMBLY - TANK SIDE (ABS)
FIGURE 2-48. HOODS INSTALLATIONS - STEEL (MACHINES WITH SN STARTING WITH 03) (DEUTZ D2.9L4 - 49HP ENGINE)
FIGURE 2-49. HOODS INSTALLATIONS - STEEL (MACHINES WITH SN STARTING WITH 03) (DEUTZ D2011, DEUTZ TD2.9L4 - 67HP AND FORD ENGINES)
FIGURE 2-50. HOODS INSTALLATIONS - STEEL (MACHINES WITH SN STARTING WITH B3)
FIGURE 2-51. HOODS INSTALLATION - STEEL (MACHINES WITH SN STARTING WITH B3) (DEUTZ D2.9L4 (CHINA IV) ENGINES)
FIGURE 2-52. HOOD ASSEMBLY - ENGINE SIDE (STEEL) (MACHINES WITH SN STARTING WITH 03)
FIGURE 2-53. HOOD ASSEMBLY - ENGINE SIDE (STEEL) (MACHINES WITH SN STARTING WITH B3)
FIGURE 2-54. HOODS ASSEMBLY - ENGINE SIDE (STEEL) (MACHINES WITH SN STARTING WITH B3) (DEUTZ D2.9L4 (CHINA IV) ENGINES)
FIGURE 2-55. HOOD ASSEMBLY - TANK SIDE (STEEL) (MACHINES WITH SN STARTING WITH 03)
FIGURE 2-56. HOOD ASSEMBLY - TANK SIDE (STEEL) (MACHINES WITH SN STARTING WITH B3)
FIGURE 2-57. HOOD INSTALLTION - DCPD (ALL SPECS EXCEPT CHINEESE, CE & UK CA) (MACHINES WITH SN STARTING WITH B3)
FIGURE 2-58. HOOD INSTALLTION - DCPD (CHINEESE, CE & UK CA SPECS) (MACHINES WITH SN STARTING WITH B3)
FIGURE 2-59. HOOD ASSEMBLY - ENGINE SIDE DCPD (MACHINES WITH SN STARTING WITH B3)
FIGURE 2-60. HOOD ASSEMBLY - TANK SIDE DCPD (MACHINES WITH SN STARTING WITH B3)
FIGURE 2-61. CLEARSKY INSTALLATION (WITH PLASTIC HOOD)
FIGURE 2-62. CLEARSKY INSTALLATION (WITH STEEL HOOD)
FIGURE 2-63. SIDE-SHEET ASSEMBLY - TANK SIDE
FIGURE 2-64. SIDE-SHEET ASSEMBLY - ENGINE SIDE
FIGURE 2-65. KEYSWITCH INSTALLATION -(ANSI, ANSI EXPORT, CSA AND JAPANESE SPECS) (600S)
FIGURE 2-66. KEYSWITCH INSTALLATION - (CE & UK CA SPECS) (600S)
FIGURE 2-67. KEYSWITCH INSTALLATION - 600S WITH DEUTZ TD2.2L3 (STAGE V) ENGINE (CE & UK CA SPECS) (600S)
FIGURE 2-68. KEYSWITCH INSTALLATION - (ALL SPECS EXCEPT CE & UK CA SPECS) (660SJ)
FIGURE 2-69. KEYSWITCH INSTALLATION - (CE & UK CA SPECS) (660SJ)
FIGURE 2-70. KEYSWITCH INSTALLATION - 660SJ WITH DEUTZ TD2.2L3 (STAGE V) ENGINE (CE & UK CA SPECS) (660SJ)
FIGURE 2-71. LIGHT PANEL INSTALLATION (MACHINES WITH SN STARTING WITH 03)
FIGURE 2-72. LIGHT PANEL INSTALLATION (MACHINES WITH SN STARTING WITH B3)
FIGURE 2-73. NOISE REDUCTION PACKAGE (600S)
FIGURE 2-74. NOISE REDUCTION PACKAGE (660SJ)
FIGURE 2-75. TURNTABLE COVERS INSTALLATION
FIGURE 2-76. STROBE LIGHT INSTALLATION - AMBER (OPTIONAL)
FIGURE 2-77. STROBE LIGHT INSTALLATION - BLUE (OPTIONAL)
FIGURE 2-78. STROBE LIGHT INSTALLATION - RED (OPTIONAL)
FIGURE 2-79. HOOD PLUGS INSTALLATION (HOODS WITHOUT STROBE LIGHT)
FIGURE 2-80. WHITE NOISE ALARM (AMBIENT) INSTALLATION
FIGURE 2-81. WHITE NOISE ALARM (CONSTANT) INSTALLATION
SECTION 3 - ENGINEFIGURE 3-1. DEUTZ D2011 ENGINE INSTALLATION - WITHOUT ARCTIC PACKAGE (MACHINES WITH SN STARTING WITH 03)
FIGURE 3-2. DEUTZ D2011 ENGINE AND PUMPS SUB-ASSEMBLY - WITHOUT ARCTIC PACKAGE (MACHINES WITH SN STARTING WITH 03)
FIGURE 3-3. DEUTZ D2011 ENGINE INSTALLATION - WITHOUT ARCTIC PACKAGE (MACHINES WITH SN STARTING WITH B3)
FIGURE 3-4. DEUTZ D2011 ENGINE AND PUMPS SUB-ASSEMBLY - WITHOUT ARCTIC PACKAGE (MACHINES WITH SN STARTING WITH B3)
FIGURE 3-5. DEUTZ D2011 ENGINE ASSEMBLY - WITHOUT ARCTIC PACKAGE
FIGURE 3-6. DEUTZ D2011 ENGINE INSTALLATION - WITH ARCTIC PACKAGE (MACHINES WITH SN STARTING WITH 03)
FIGURE 3-7. DEUTZ D2011 ENGINE AND PUMPS SUB-ASSEMBLY WITH ARCTIC PACKAGE (MACHINES WITH SN STARTING WITH 03)
FIGURE 3-8. DEUTZ D2011 ENGINE INSTALLATION - WITH ARCTIC PACKAGE (MACHINES WITH SN STARTING WITH B3)
FIGURE 3-9. DEUTZ D2011 ENGINE AND PUMPS SUB-ASSEMBLY - WITH ARCTIC PACKAGE (MACHINES WITH SN STARTING WITH B3)
FIGURE 3-10. DEUTZ D2011 ENGINE ASSEMBLY - WITH ARCTIC PACKAGE
FIGURE 3-11. DEUTZ D2011 ENGINE COMPONENTS
FIGURE 3-12. DEUTZ D2011 (STAGE V) ENGINE INSTALLATION
FIGURE 3-13. DEUTZ D2011 (STAGE V) ENGINE AND PUMPS SUB-ASSEMBLY
FIGURE 3-14. DEUTZ D2011 (STAGE V) ENGINE ASSEMBLY
FIGURE 3-15. DEUTZ D2011 (STAGE V) ENGINE COMPONENTS
FIGURE 3-16. DEUTZ TD2.2L3 (STAGE V) ENGINE INSTALLATION
FIGURE 3-17. DEUTZ TD2.2L3 (STAGE V) ENGINE AND PUMPS SUB-ASSEMBLY
FIGURE 3-18. DEUTZ TD2.2L3 (STAGE V) ENGINE ASSEMBLY
FIGURE 3-19. DEUTZ TD2.2L3 (STAGE V) ENGINE COMPONENTS
FIGURE 3-20. BREATHER HEATER INSTALLATION - DEUTZ D2.9L4 - 49HP AND DEUTZ TD2.9L4 - 67HP ENGINES WITH ARCTIC PACKAGE
FIGURE 3-21. DEUTZ D2.9L4 ENGINE INSTALLATION (CHINA IV)
FIGURE 3-22. DEUTZ D2.9L4 ENGINE AND PUMP SUB-ASSEMBLY (CHINA IV)
FIGURE 3-23. DEUTZ D2.9L4 ENGINE ASSEMBLY (CHINA IV)
FIGURE 3-24. DUETZ D2.9L4 ENGINE COMPONENTS (CHINA IV)
FIGURE 3-25. DEUTZ D2.9L4 EMR5 (49HP) ENGINE INSTALLATION WITHOUT ARCTIC PACKAGE
FIGURE 3-26. DEUTZ D2.9L4 - EMR5 (49HP) ENGINE AND PUMPS SUB-ASSEMBLY WITHOUT ARCTIC PACKAGE
FIGURE 3-27. DEUTZ D2.9L4 - EMR5 (49HP) ENGINE ASSEMBLY WITHOUT ARCTIC PACKAGE
FIGURE 3-28. DEUTZ D2.9L4 - EMR5 (49HP) ENGINE INSTALLATION WITH ARCTIC PACKAGE
FIGURE 3-29. DEUTZ D2.9L4 - EMR5 (49HP) ENGINE AND PUMPS SUB-ASSEMBLY WITH ARCTIC PACKAGE
FIGURE 3-30. DEUTZ D2.9L4 - EMR5 (49HP) ENGINE ASSEMBLY WITH ARCTIC PACKAGE
FIGURE 3-31. ENGINE COMPONENTS - DEUTZ D2.9L4 EMR5 ENGINE (ANSI, ANSI EXPORT AND CSA SPECS)
FIGURE 3-32. DEUTZ D2.9L4 - EMR5 (67HP) 600S ENGINE INSTALLATION WITH ARCTIC PACKAGE
FIGURE 3-33. DEUTZ D2.9L4 - EMR5 (67HP) ENGINE AND PUMPS SUB-ASSEMBLY WITH ARCTIC PACKAGE
FIGURE 3-34. DEUTZ D2.9L4 - EMR5 (67HP) ENGINE ASSEMBLY WITH ARCTIC PACKAGE
FIGURE 3-35. DEUTZ D2.9L4 - EMR5 (67HP) 600S ENGINE INSTALLATION WITHOUT ARCTIC PACKAGE
FIGURE 3-36. DEUTZ D2.9L4 - EMR5 (67HP) ENGINE AND PUMPS SUB-ASSEMBLY WITHOUT ARCTIC PACKAGE
FIGURE 3-37. DEUTZ D2.9L4 - EMR5 (67HP) ENGINE ASSEMBLY WITHOUT ARCTIC PACKAGE
FIGURE 3-38. ENGINE COMPONENTS - DEUTZ D2.9L4 EMR5 (67HP) ENGINE
FIGURE 3-39. FORD ENGINE INSTALLATION - WITHOUT ARCTIC PACKAGE
FIGURE 3-40. FORD ENGINE AND PUMPS SUB-ASSEMBLY - WITHOUT ARCTIC PACKAGE
FIGURE 3-41. FORD ENGINE ASSEMBLY - WITHOUT ARCTIC PACKAGE (Prior to SN 0300329726)
FIGURE 3-42. FORD ENGINE ASSEMBLY - WITHOUT ARCTIC PACKAGE (SN 0300329727 to Present, SN 0300329714 through 0300329716, Including 0300329698)
FIGURE 3-43. FORD ENGINE INSTALLATION - WITH ARCTIC PACKAGE
FIGURE 3-44. FORD ENGINE AND PUMPS SUB-ASSEMBLY - WITH ARCTIC PACKAGE
FIGURE 3-45. FORD ENGINE ASSEMBLY - WITH ARCTIC PACKAGE (Prior to SN 0300329726)
FIGURE 3-46. FORD ENGINE ASSEMBLY - WITH ARCTIC PACKAGE (SN 0300329727 to Present, SN 0300329714 through 0300329716, Including 0300329698)
FIGURE 3-47. FORD ENGINE PREP ASSEMBLY
FIGURE 3-48. FORD ENGINE COMPONENTS
FIGURE 3-49. PUMP COUPLING KIT (DEUTZ ENGINES)
FIGURE 3-50. PISTON PUMP ASSEMBLY - ALL ENGINES EXCEPT CHINA IV ENGINES AND DUETZ D2011 ENGINES ON MACHINES WITH SN STARTING WITH B3
FIGURE 3-51. PISTON PUMP ASSEMBLY - CHINA IV ENGINES AND DUETZ D2011 ENGINES ON MACHINES WITH SN STARTING WITH B3
FIGURE 3-52. BELT WITHOUT GENERATOR INSTALLATION (FORD ENGINES)
FIGURE 3-53. EXHAUST PIPE INSTALLATION - (DEUTZ D2011 ENGINES)
FIGURE 3-54. FUEL FILTER INSTALLATION (POLY FUEL TANK)
FIGURE 3-55. FUEL FILTER INSTALLATION (STEEL FUEL TANK) (DEUTZ D2011 ENGINES)
FIGURE 3-56. FUEL FILTER INSTALLATION (STEEL FUEL TANK) (DEUTZ TD2.9L4 ENGINES)
FIGURE 3-57. FUEL FILTER INSTALLATION (STEEL FUEL TANK) (DEUTZ D2.9L4 ENGINES)
FIGURE 3-58. MOTOR MOUNT INSTALLATION - WITHOUT GENERATOR (DEUTZ D2011 ENGINES)
FIGURE 3-59. MOTOR MOUNT INSTALLATION - WITHOUT GENERATOR (DEUTZ TD2.2L3 (STAGE V) ENGINES)
FIGURE 3-60. MOTOR MOUNT INSTALLATION - WITHOUT GENERATOR (DEUTZ D2.9L4 - 49HP AND DEUTZ D2.9L4 (CHINA IV) ENGINES)
FIGURE 3-61. MOTOR MOUNT INSTALLATION - WITHOUT GENERATOR (DEUTZ TD2.9L4 - 67HP ENGINES)
FIGURE 3-62. MOTOR MOUNT INSTALLATION - WITH GENERATOR (DEUTZ D2011 ENGINES)
FIGURE 3-63. MOTOR MOUNT INSTALLATION - WITH GENERATOR (DEUTZ TD2.2L3 (STAGE V) ENGINES)
FIGURE 3-64. MOTOR MOUNT INSTALLATION - WITH GENERATOR (DEUTZ TD2.9L4 - 49HP ENGINES)
FIGURE 3-65. MOTOR MOUNT INSTALLATION - WITH GENERATOR (DEUTZ TD2.9L4 - 67HP ENGINES)
FIGURE 3-66. MUFFLER INSTALLATION - SPARK ARRESTING (DEUTZ D2011 ENGINES)
FIGURE 3-67. RADIATOR ASSEMBLY - DUETZ D2.9L4 ENGINE (CHINA IV)
FIGURE 3-68. TRAY JACK INSTALLATION (DEUTZ D2011, DEUTZ TD2.9L4 - 67HP AND FORD ENGINES)
FIGURE 3-69. TRAY JACK INSTALLATION (DEUTZ TD2.2L3 (STAGE V), DEUTZ D2.9L4 - 49HP AND DEUTZ D2.9 (CHINA IV) ENGINES)
FIGURE 3-70. QUICKFIT OIL VALVE (DEUTZ D ENGINES)
FIGURE 3-71. ENGINE HOOD BAFFLES INSTALLATION - ABS HOODS (DEUTZ D2011, DEUTZ TD2.9L4 - 67HP AND FORD ENGINES)
FIGURE 3-72. ENGINE HOOD BAFFLES INSTALLATION - ABS HOODS (DEUTZ D2.9L4 - 49HP AND DEUTZ D2.9L4 (CHINA IV) ENGINES)
FIGURE 3-73. ENGINE HOOD BAFFLES INSTALLATION - STEEL HOODS (DEUTZ D2011, DEUTZ TD2.9L4 - 67HP AND FORD ENGINES)
FIGURE 3-74. ENGINE HOOD BAFFLES INSTALLATION - STEEL HOODS (DEUTZ D2.9L4 - 49HP AND DEUTZ D2.9L4 (CHINA IV) ENGINES)
FIGURE 3-75. 2500W GENERATOR INSTALLATION - 110V/60HZ (DEUTZ D2011 ENGINES) (OPTIONAL)
FIGURE 3-76. 2500W GENERATOR INSTALLATION - 110V/60HZ (DEUTZ D2.9L4 - 49HP ENGINES) (OPTIONAL)
FIGURE 3-77. 2500W GENERATOR INSTALLATION - 110V/60HZ (DEUTZ TD2.9L4 - 67HP ENGINES) (OPTIONAL)
FIGURE 3-78. 2500W GENERATOR INSTALLATION - 110V/60HZ (FORD ENGINES) (OPTIONAL)
FIGURE 3-79. 2500W GENERATOR INSTALLATION - 220V/50HZ (DEUTZ D2011 ENGINES) (OPTIONAL)
FIGURE 3-80. 4000W GENERATOR INSTALLATION - 110V/60HZ (DEUTZ D2011 ENGINES) (OPTIONAL) (Prior to SN 0300332719, Prior to SN B300030390)
FIGURE 3-81. 4000W GENERATOR INSTALLATION - 110V/60HZ (DEUTZ D2011 ENGINES) (OPTIONAL) (SN 0300332720 to Present, SN B300030391 to Present, Including B300030161)
FIGURE 3-82. 4000W GENERATOR INSTALLATION - 110V/60HZ (DEUTZ D2.9L4 - 49HP ENGINES) (OPTIONAL) (Prior to SN 0300332719, Prior to SN B300030390)
FIGURE 3-83. 4000W GENERATOR INSTALLATION - 110V/60HZ (DEUTZ D2.9L4 - 49HP ENGINES) (OPTIONAL) (SN 0300332720 to Present, SN B300030391 to Present, Including B300030161)
FIGURE 3-84. 4000W GENERATOR INSTALLATION - 110V/60HZ (DEUTZ TD2.9L4 - 67HP ENGINES) (OPTIONAL) (Prior to SN 0300332719, Prior to SN B300030390)
FIGURE 3-85. 4000W GENERATOR INSTALLATION - 110V/60HZ (DEUTZ TD2.9L4 - 67HP ENGINES) (OPTIONAL) (SN 0300332720 to Present, SN B300030391 to Present, Including B300030161)
FIGURE 3-86. 4000W GENERATOR INSTALLATION - 220V/50HZ (DEUTZ D2011 ENGINES) (OPTIONAL)
FIGURE 3-87. 4000W GENERATOR INSTALLATION - 220V/50HZ (DEUTZ TD2.2L3 (STAGE V) ENGINE) (OPTIONAL)
FIGURE 3-88. 4000W GENERATOR INSTALLATION - 220V/50HZ (DEUTZ TD2.9L4 - 67HP ENGINES) (OPTIONAL)
FIGURE 3-89. 7500W SKYPOWER GENERATOR INSTALLATION - 110/60HZ (DEUTZ D2011 ENGINES) (OPTIONAL) (Prior to SN 0300332719, Prior to SN B300030390)
FIGURE 3-90. 7500W SKYPOWER GENERATOR INSTALLATION - 110/60HZ (DEUTZ D2011 ENGINES) (OPTIONAL) (SN 0300332720 to Present, SN B300030391 to Present, Including B300030161)
FIGURE 3-91. 7500W SKYPOWER GENERATOR INSTALLATION - 110V/60HZ (DEUTZ D2.9L4 - 49HP ENGINES) (OPTIONAL) (Prior to SN 0300332719, Prior to SN B300030390)
FIGURE 3-92. 7500W SKYPOWER GENERATOR INSTALLATION - 110V/60HZ (DEUTZ D2.9L4 - 49HP ENGINES) (OPTIONAL) (SN 0300332720 to Present, SN B300030391 to Present, Including B300030161)
FIGURE 3-93. 7500W SKYPOWER GENERATOR INSTALLATION - 110V/60HZ (DEUTZ TD2.9L4 - 67HP ENGINES) (OPTIONAL) (Prior to SN 0300332719, Prior to SN B300030390)
FIGURE 3-94. 7500W SKYPOWER GENERATOR INSTALLATION - 110V/60HZ (DEUTZ TD2.9L4 - 67HP ENGINES) (OPTIONAL) (SN 0300332720 to Present, SN B300030391 to Present, Including B300030161)
FIGURE 3-95. 7500W SKYPOWER GENERATOR INSTALLATION - 110V/60HZ (FORD ENGINES) (OPTIONAL) (Prior to SN 0300332719)
FIGURE 3-96. 7500W SKYPOWER GENERATOR INSTALLATION - 110V/60HZ (FORD ENGINES) (OPTIONAL) (SN 0300332720 to Present)
FIGURE 3-97. 7500W SKYPOWER GENERATOR INSTALLATION - 220V/50HZ (DEUTZ D2011 ENGINES) (OPTIONAL) (Prior to SN 0300332719, Prior to SN B300030390)
FIGURE 3-98. 7500W SKYPOWER GENERATOR INSTALLATION - 220V/50HZ (DEUTZ D2011 ENGINES) (OPTIONAL) (SN 0300332720 to Present, SN B300030391 to Present, Including B300030161)
FIGURE 3-99. 7500W SKYPOWER GENERATOR INSTALLATION - 220V/50HZ (DEUTZ TD2.2L3 (STAGE V) ENGINE) (OPTIONAL)
FIGURE 3-100. 7500W SKYPOWER GENERATOR INSTALLATION - 220V/50HZ (DEUTZ TD2.9L4 - 67HP ENGINES) (OPTIONAL) (Prior to SN 0300332719)
FIGURE 3-101. 7500W SKYPOWER GENERATOR INSTALLATION - 220V/50HZ (DEUTZ TD2.9L4 - 67HP ENGINES) (OPTIONAL) (SN 0300332720 to Present)
SECTION 4 - BOOMFIGURE 4-1. BOOM INSTALLATION (600S)
FIGURE 4-2. BOOM INSTALLATION (ALL SPECS EXCEPT CHINESE SPEC) (660SJ)
FIGURE 4-3. BOOM INSTALLATION (1K63FT) (660SJ)
FIGURE 4-4. BOOM INSTALLATION (CHINESE SPEC ONLY) (660SJ)
FIGURE 4-5. BOOM INSTALLATION (CHINESE SPEC ONLY) (660SJ) (SN B300030892 to Present)
FIGURE 4-6. BOOM ASSEMBLY (600S)
FIGURE 4-7. BOOM ASSEMBLY (ALL SPECS EXCEPT CHINESE SPEC) (660SJ)
FIGURE 4-8. BOOM ASSEMBLY (1K63FT) (660SJ)
FIGURE 4-9. BOOM ASSEMBLY (CHINESE SPEC ONLY) (660SJ)
FIGURE 4-10. JIB ASSEMBLY - STANDARD (MACHINES WITH SN STARTING WITH 03) (660SJ)
FIGURE 4-11. JIB ASSEMBLY - STANDARD (MACHINES WITH SN STARTING WITH B3) (660SJ)
FIGURE 4-12. JIB ASSEMBLY (1K63FT) (660SJ)
FIGURE 4-13. PLATFORM ROTATOR ASSEMBLY (600S)
FIGURE 4-14. PLATFORM ROTATOR ASSEMBLY (1K63FT) (660SJ)
FIGURE 4-15. PLATFORM ROATOR ASSEMBLY (MACHINES WITH SN STARTING WITH 03) (660SJ)
FIGURE 4-16. PLATFORM ROATOR ASSEMBLY (MACHINES WITH SN STARTING WITH B3) (660SJ)
FIGURE 4-17. POWER TRACK INSTALLATION - 600S & 660SJ STANDARD
FIGURE 4-18. POWER TRACK INSTALLATION - WITH PLASTIC CLAMP (MACHINES WITH SN STARTING WITH B3)
FIGURE 4-19. POWER TRACK INSTALLATION - WITH STEEL CLAMP (MACHINES WITH SN STARTING WITH 03)
FIGURE 4-20. POWER TRACK INSTALLATION - WITH STEEL CLAMPS (MACHINES WITH SN STARTING WITH B3)(ALL SPECS EXCEPT CHINEESE) (660SJ)
FIGURE 4-21. POWER TRACK INSTALLATION - WITH STEEL CLAMPS (MACHINES WITH SN STARTING WITH B3)(ALL SPECS) (660SJ)
FIGURE 4-22. POWER TRACK INSTALLATION - WITH STEEL CLAMP (MACHINES WITH SN STARTING WITH B3)
FIGURE 4-23. POWER TRACK INSTALLATION (1K63FT) (660SJ)
FIGURE 4-24. BOOM VALVES INSTALLATION - WITH 2WS (600S)
FIGURE 4-25. BOOM VALVES INSTALLATION - WITH 4WS (600S)
FIGURE 4-26. BOOM VALVES INSTALLATION - WITH 2WS (660SJ) (Prior to SN 0300332719, Prior to SN B300030390, Prior to SN C300002934)
FIGURE 4-27. BOOM VALVES INSTALLATION - WITH 2WS (660SJ) (SN 0300332720 to Present, SN B300030391 to Present, SN C300002935 to Present, Including B300030161 and C300002760)
FIGURE 4-28. BOOM VALVES INSTALLATION - WITH 4WS (660SJ) (Prior to SN 0300332719, Prior to SN B300030390, Prior to SN C300002934)
FIGURE 4-29. BOOM VALVES INSTALLATION - WITH 4WS (660SJ) (SN 0300332720 to Present, SN B300030391 to Present, SN C300002935 to Present, Including B300030161 and C300002760)
FIGURE 4-30. PLATFORM VALVE ASSEMBLY (600S)
FIGURE 4-31. PLATFORM VALVE ASSEMBLY (660SJ)
FIGURE 4-32. BOOM SENSORS INSTALLATION (600S)
FIGURE 4-33. BOOM SENSORS INSTALLATION (660SJ)
FIGURE 4-34. BOOM SENSOR WITH COVERS INSTALLATION - STANDARD (660SJ)
FIGURE 4-35. BOOM SENSOR WITH COVERS INSTALLATION (1K63FT) (660SJ)
FIGURE 4-36. PLATFORM SUPPORT INSTALLATION (MACHINES WITH SN STARTING WITH 03) (Prior to SN 0300328305)
FIGURE 4-37. TRADITIONAL PLATFORM SUPPORT INSTALLATION (SN 0300328306 through 0300332719)
FIGURE 4-38. RAPID REPLACEABLE PLATFORM SUPPORT (MACHINES WITH SN STARTING WITH 03) (SN 0300332720 to Present)
FIGURE 4-39. RAPID REPLACEABLE PLATFORM SUPPORT (MACHINES WITH SN STARTING WITH B3 OR C3) (SN B300030892 to Present)
FIGURE 4-40. PLATFORM SUPPORT INSTALLATION WITH LSS (MACHINES WITH SN STARTING WITH B3) (Prior to SN 0300328305)
FIGURE 4-41. PLATFORM SUPPORT INSTALLATION (MACHINES WITH SN STARTING WITH B3) (Prior to SN B300030891)
SECTION 5 - PLATFORMFIGURE 5-1. TRADITIONAL PLATFORM ASSEMBLY - 30IN X 3FT (76CM X .91M) - DROP BAR ENTRY (MACHINES WITH SN STARTING WITH B3 OR C3) (Prior to SN 0300332719, Prior to SN B300030891)
FIGURE 5-2. TRADITIONAL PLATFORM ASSEMBLY - 30IN X 4FT (76CM X 1.22M) WITH SWING GATE (MACHINES WITH SN STARTING WITH B3 OR C3) (Prior to SN 0300332719, Prior to SN B300030891)
FIGURE 5-3. TRADITIONAL PLATFORM ASSEMBLY - 30IN X 4FT (76CM X 1.22M) WITH DROP BAR (MACHINES WITH SN STARTING WITH B3 OR C3) (Prior to SN 0300332719, Prior to SN B300030891)
FIGURE 5-4. TRADITIONAL PLATFORM ASSEMBLY - 30IN X 5FT (76CM X 1.52M) WITH SWING GATE (MACHINES WITH SN STARTING WITH B3 OR C3) (Prior to SN 0300332719, Prior to SN B300030891)
FIGURE 5-5. TRADITIONAL PLATFORM ASSEMBLY - 30IN X 5FT (76CM X 1.52M) WITH DROP BAR (MACHINES WITH SN STARTING WITH B3 OR C3) (Prior to SN 0300332719, Prior to SN B300030891)
FIGURE 5-6. TRADITIONAL PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) WITH SWING GATE (MACHINES WITH SN STARTING WITH B3 OR C3) (Prior to SN 0300332719, Prior to SN B300030891)
FIGURE 5-7. TRADITIONAL PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) WITH DROP BAR (MACHINES WITH SN STARTING WITH B3 OR C3) (Prior to SN 0300332719, Prior to SN B300030891)
FIGURE 5-8. TRADITIONAL PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) WITH DROP BAR (SHIPYARD MACHINES) (MACHINES WITH SN STARTING WITH B3) (Prior to SN 0300332719, Prior to SN B300030891)
FIGURE 5-9. TRADITIONAL PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) WITH FALL ARREST (ANSI, ANSI EXPORT, CHINA AND CSA SPECS) (MACHINES WITH SN STARTING WITH B3) (Prior to SN 0300332719, Prior to SN B300030891)
FIGURE 5-10. TRADITIONAL PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) TRI-ENTRY WITH SWING GATE (MACHINES WITH SN STARTING WITH B3 OR C3) (Prior to SN 0300332719, Prior to SN B300030891)
FIGURE 5-11. TRADITIONAL PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) TRI-ENTRY WITH DROP BAR (MACHINES WITH SN STARTING WITH B3 OR C3) (Prior to SN 0300332719, Prior to SN B300030891)
FIGURE 5-12. TRADITIONAL PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH SWING GATE (MACHINES WITH SN STARTING WITH 03) (Prior to SN 0300332719, Prior to SN B300030891)
FIGURE 5-13. TRADITIONAL PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH DROP BAR (MACHINES WITH SN STARTING WITH B3) (Prior to SN 0300332719, Prior to SN B300030891)
FIGURE 5-14. TRADITIONAL PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH FALL ARREST (MACHINES WITH SN STARTING WITH B3) (Prior to SN 0300332719, Prior to SN B300030891)
FIGURE 5-15. TRADITIONAL PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) TRI-ENTRY WITH SWING GATE (MACHINES WITH SN STARTING WITH B3 OR C3) (Prior to SN 0300332719, Prior to SN B300030891)
FIGURE 5-16. TRADITIONAL PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) TRI-ENTRY WITH DROP BAR (MACHINES WITH SN STARTING WITH B3 OR C3) (Prior to SN 0300332719, Prior to SN B300030891)
FIGURE 5-17. TRADITIONAL PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH SWING GATE (MACHINES WITH SN STARTING WITH B3 OR C3)
FIGURE 5-18. TRADITIONAL PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH DROP BAR (MACHINES WITH SN STARTING WITH B3 OR C3)
FIGURE 5-19. TRADITIONAL PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) WITH FALL ARREST (SN 0300332720 to Present)
FIGURE 5-20. TRADITIONAL PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH FALL ARREST (SN 0300332720 to Present)
FIGURE 5-21. TRADITIONAL PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH TRI-ENTRY (SN 0300332720 to Present)
FIGURE 5-22. RAPID REPLACEABLE PLATFORM (30IN X 4FT) (76CM X 1.22M)
FIGURE 5-23. RAPID REPLACEABLE PLATFORM (30IN X 5FT (76.2CM X 1.52M)
FIGURE 5-24. RAPID REPLACEABLE PLATFORM (36IN X 6FT (91.5CM X 1.83M)
FIGURE 5-25. RAPID REPLACEABLE PLATFORM (36IN X 8FT (91.5CM X 2.44M)
FIGURE 5-26. PLATFORM - SWING GATE INSTALLATION
FIGURE 5-27. PLATFORM - DROP BAR INSTALLATION
FIGURE 5-28. TRAY ASSEMBLY
FIGURE 5-29. PLATFORM CONSOLE AND FOOTSWITCH INSTALLATION (Prior to SN 0300331014, Prior to SN B300030047, Prior to SN C300001451)
FIGURE 5-30. PLATFORM CONSOLE AND FOOTSWITCH INSTALLATION (SN 0300331015 to Present, SN B300030184 to Present, SN C300001452 to Present, Including B300030142, B300030161, B300030182, C300001316 and C300001362)
FIGURE 5-31. CONSOLE BOX ASSEMBLY (Prior to SN 0300331014, Prior to SN B300030047, Prior to SN C300001451)
FIGURE 5-32. CONSOLE BOX ASSEMBLY (SN B300030048 to Present, SN C300001452 to Present, Including B300029979, B300030028, C300001316 and C300001362)
FIGURE 5-33. PLATFORM CONSOLE AND FOOTSWITCH ASSEMBLY (SN 0300331015 to Present, SN B300030184 to Present, SN C300001452 to Present, Including B300030142, B300030161, B300030182, C300001316 and C300001362)
FIGURE 5-34. STEER SWITCH INSTALLATION WITHOUT TOW PACKAGE (4WD/4WS MACHINES)
FIGURE 5-35. STEER SWITCH INSTALLATION WITH TOW PACKAGE (4WD/4WS MACHINES)
FIGURE 5-36. FOOTSWITCH ASSEMBLY
FIGURE 5-37. LIGHT PANEL INSTALLATION (MACHINES WITH SN STARTING WITH 03)
FIGURE 5-38. LIGHT PANEL INSTALLATION (MACHINES WITH SN STARTING WITH B3)
FIGURE 5-39. SKYLINE INSTALLATION (Prior to SN 0300332719, Prior to SN B300030891)
FIGURE 5-40. SKYLINE INSTALLATION (SN 0300332720 to Present, SN B300030892 to Present)
FIGURE 5-41. SKYGLAZIER INSTALLATION - 600S & 660SJ (ANSI, AUSTRALIAN AND CSA SPECS)
FIGURE 5-42. SKYGLAZIER INSTALLATION - 600S (BRAZIL SPECS)
FIGURE 5-43. SKYGLAZIER INSTALLATION - 600S (LATIN AMERICAN SPECS)
FIGURE 5-44. SKYGLAZIER INSTALLATION - (CE CA & UK SPECS)
FIGURE 5-45. SKYWELDER INSTALLATION (50HZ)
FIGURE 5-46. SKYWELDER INSTALLATION (60HZ)
FIGURE 5-47. SKYWELDER PREP PACKAGE (60HZ)
FIGURE 5-48. WELDER ASSEMBLY
FIGURE 5-49. SOFT TOUCH INSTALLATION - 6FT (1.83M) PLATFORM (OPTIONAL)
FIGURE 5-50. SOFT TOUCH INSTALLATION - 6FT (1.83M) FALL ARREST PLATFORM (600S)
FIGURE 5-51. SOFT TOUCH INSTALLATION - 8FT (2.4M) PLATFORM (OPTIONAL)
FIGURE 5-52. SOFT TOUCH INSTALLATION - 8FT (2.4M) FALL ARREST PLATFORM (600S) (OPTIONAL)
FIGURE 5-53. SOFT TOUCH INSTALLATION - OVERHEAD (CHINESE AND KOREAN SPECS)
FIGURE 5-54. FALL ARREST INSTALLATION (BOLT-ON) (4FT/1.22M PLATFORM)
FIGURE 5-55. FALL ARREST INSTALLATION (BOLT-ON EXTERNAL) (5FT/1.52M PLATFORM)
FIGURE 5-56. FALL ARREST INSTALLATION (BOLT-ON EXTERNAL) (6FT/1.82M PLATFORM)
FIGURE 5-57. FALL ARREST INSTALLATION (BOLT-ON EXTERNAL) (6FT/1.82M TRI-ENTRY PLATFORM)
FIGURE 5-58. FALL ARREST INSTALLATION (BOLT-ON EXTERNAL) (8FT/2.4M PLATFORM)
FIGURE 5-59. USB CHARGER INSTALLATION (Prior to SN 0300332719, Prior to SN B300030891)
FIGURE 5-60. USB CHARGER INSTALLATION (SN 0300332720 to Present, SN B300030892 to Present)
FIGURE 5-61. PLATFORM BEACON INSTALLATION (SN 0300332720 to Present)
FIGURE 6-2. AXLE LOCKOUT CYLINDER ASSEMBLY
FIGURE 6-3. LEVEL CYLINDER ASSEMBLY - PLATFORM SLAVE (600S)
FIGURE 6-4. LEVEL CYLINDER ASSEMBLY - PLATFORM SLAVE (STANDARD) (660SJ)
FIGURE 6-5. LEVEL CYLINDER ASSEMBLY - PLATFORM SLAVE (660SJ 1K63FT)
FIGURE 6-6. LIFT CYLINDER ASSEMBLY - BOOM (Prior to SN B300030891)
FIGURE 6-7. LIFT CYLINDER ASSEMBLY (SN B300030892 to Present)
FIGURE 6-8. LIFT CYLINDER ASSEMBLY - JIB (STANDARD) (MACHINES WITH SN STARTING WITH 03) (660SJ)
FIGURE 6-9. LIFT CYLINDER ASSEMBLY - JIB (STANDARD) (MACHINES WITH SN STARTING WITH B3) (660SJ)
FIGURE 6-10. LIFT CYLINDER ASSEMBLY - JIB (660SJ 1K63FT)
FIGURE 6-11. STEER CYLINDER ASSEMBLY
FIGURE 6-12. TELESCOPE CYLINDER ASSEMBLY (600S & 660SJ STANDARD)
FIGURE 6-13. TELESCOPE CYLINDER ASSEMBLY - CHINESE SPEC ONLY
FIGURE 6-14. TELESCOPE CYLINDER ASSEMBLY (660SJ 1K63FT)
FIGURE 6-15. VALVE ASSEMBLY
SECTION 7 - HYDRAULICFIGURE 7-1. DRIVE HYDRAULIC DIAGRAM (2WS WITHOUT ARCTIC PACKAGE)
FIGURE 7-2. DRIVE HYDRAULIC DIAGRAM (2WS WITH ARCTIC PACKAGE)
FIGURE 7-3. DRIVE HYDRAULIC DIAGRAM (4WS)
FIGURE 7-4. STANDARD HYDRAULIC DIAGRAM (2WS) (600S)
FIGURE 7-5. STANDARD HYDRAULIC DIAGRAM (4WS) (600S)
FIGURE 7-6. STANDARD HYDRAULIC DIAGRAM (2WS) (600S)
FIGURE 7-7. STANDARD HYDRAULIC DIAGRAM (4WS) (600S)
FIGURE 7-8. STANDARD HYDRAULIC DIAGRAM (2WS) (660SJ)
FIGURE 7-9. STANDARD HYDRAULIC DIAGRAM (4WS) (660SJ)
FIGURE 7-10. STANDARD HYDRAULIC DIAGRAM (2WS) (660SJ)
FIGURE 7-11. STANDARD HYDRAULIC DIAGRAM (4WS) (660SJ)
FIGURE 7-12. TOW HYDRAULIC DIAGRAM
SECTION 8 - ELECTRICALFIGURE 8-1. ELECTRICAL LAYOUT (660SJ)
FIGURE 8-2. AC BOX AT PLATFORM INSTALLATION - 110V (ALL SPECS EXCEPT AUSTRALIAN, CE & UK CA SPECS) (Prior to SN 0300330510)
FIGURE 8-3. AC BOX AT PLATFORM INSTALLATION - 110V IEC YELLOW (CE & UK CA SPECS WITHOUT 4000W/50HZ GENERATOR) (Prior to SN 0300330510, Prior to SN B300030891)
FIGURE 8-4. AC BOX AT PLATFORM INSTALLATION - 110V IEC YELLOW (CE & UK CA SPECS WITH 4000W/50HZ GENERATOR) (Prior to SN 0300330510, Prior to SN B300030891)
FIGURE 8-5. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE (CE & UK CA SPECS WITHOUT 4000W/50HZ GENERATOR) (Prior to SN 0300330510, Prior to SN B300030891)
FIGURE 8-6. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE (CE & UK CA SPECS WITH 4000W/50HZ GENERATOR) (Prior to SN 0300330510, Prior to SN B300030891)
FIGURE 8-7. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 2IN X 4IN POST GROUND (CE & UK CA SPECS WITHOUT 4000W/50HZ GENERATOR) (Prior to SN 0300330510, Prior to SN B300030891)
FIGURE 8-8. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 2IN X 4IN POST GROUND (CE & UK CA SPECS WITH 4000W/50HZ GENERATOR) (Prior to SN 0300330510, Prior to SN B300030891)
FIGURE 8-9. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 2IN X 4IN SIDE GROUND (CE & UK CA SPECS WITHOUT 4000W/50HZ GENERATOR) (Prior to SN 0300330510, Prior to SN B300030891)
FIGURE 8-10. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 2IN X 4IN SIDE GROUND (CE & UK CA SPECS WITH 4000W/50HZ GENERATOR) (Prior to SN 0300330510, Prior to SN B300030891)
FIGURE 8-11. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT107 (CE & UK CA SPECS WITHOUT 4000W/50HZ GENERATOR) (Prior to SN 0300330510, Prior to SN B300030891)
FIGURE 8-12. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT107 (CE & UK CA SPECS WITH 4000W/50HZ GENERATOR) (Prior to SN 0300330510, Prior to SN B300030891)
FIGURE 8-13. AC BOX AT PLATFORM INSTALLATION - 220V CUSTOMER SUPPLIED COMPONENTS (ANSI EXPORT, AUSTRALIAN, CHINA, CE & UK CA SPECS) (Prior to SN 0300330510, Prior to SN B300030891)
FIGURE 8-14. AC BOX AT PLATFORM INSTALLATION - 240V (WITH 4000W GENERATOR) (ALL SPECS EXCEPT AUSTRALIAN, CE & UK CA SPECS) (Prior to SN 0300330510)
FIGURE 8-15. AC BOX AT PLATFORM INSTALLATION - 240V (WITH 7500W SKYPOWER GENERATOR) (ALL SPECS EXCEPT AUSTRALIAN, CE & UK CA SPECS) (Prior to SN 0300330510)
FIGURE 8-16. AC BOX AT PLATFORM INSTALLATION - 110V IEC YELOW (SN 0300330511 to Present, SN B300030892 to Present)
FIGURE 8-17. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE (SN 0300330511 to Present, SN B300030892 to Present)
FIGURE 8-18. AC BOX AT PLATFORM INSTALLATION- 220V CEE7 2IN X 4IN POST GROUND (SN 0300330511 to Present, SN B300030892 to Present)
FIGURE 8-19. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 2IN X 4IN SIDE GROUND (SN 0300330511 to Present, SN B300030892 to Present)
FIGURE 8-20. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT107 (SN 0300330511 to Present, SN B300030892 to Present)
FIGURE 8-21. AC BOX AT PLATFORM INSTALLATION - 220V CUSTOMER SUPPLIED COMPONENTS (SN 0300330511 to Present, SN B300030892 to Present)
FIGURE 8-22. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 POST GROUND (SN 03003330511 to Present, SN B300030892 to Present)
FIGURE 8-23. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 SIDE GROUND (SN 03003330511 to Present, SN B300030892 to Present)
FIGURE 8-24. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT107 (CE & UK CA SPECS WITHOUT 4000S/50HZ GENERATOR) (SN 03003330511 to Present, SN B300030892 to Present)
FIGURE 8-25. AC BOX AT PLATFORM INSTALLATION - 110C IEC YELLOW (CE & UK CA SPECS WITHOUT 4000S/50HZ GENERATOR) (SN 03003330511 to Present, SN B300030892 to Present)
FIGURE 8-26. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE (CE & UK CA SPECS WITHOUT 4000S/50HZ GENERATOR) (SN 03003330511 to Present, SN B300030892 to Present)
FIGURE 8-27. AC BREAKER BOX INSTALLATION - SINGLE DOUBLE POLE BREAKER
FIGURE 8-28. AC BREAKER BOX INSTALLATION - SINGLE DOUBLE POLE BREAKER (MACHINES WITH SN STARTING WITH B3)
FIGURE 8-29. AC BREAKER BOX INSTALLATION - 3 BREAKERS
FIGURE 8-30. AC CABLES AND CLAMPS INSTALLATION - WITHOUT GENERATOR (ANSI, CSA AND JAPANESE SPECS) (600S)
FIGURE 8-31. AC CABLES AND CLAMPS INSTALLATION - WITHOUT GENERATOR (ANSI EXPORT, CE & UK CA SPECS) (600S)
FIGURE 8-32. AC CABLES AND CLAMPS INSTALLATION - WITH 2500W GENERATOR (ALL SPECS EXCEPT AUSTRALIAN, CE & UK CA SPECS) (600S)
FIGURE 8-33. AC CABLES AND CLAMPS INSTALLATION - WITH 4000W/50HZ GENERATOR (ANSI EXPORT, CE & UK CA SPECS) (600S)
FIGURE 8-34. AC CABLES AND CLAMPS INSTALLATION - WITH 4000W/60HZ GENERATOR (ALL SPECS EXCEPT AUSTRALIAN, CE & UK CA SPECS) (600S)
FIGURE 8-35. AC CABLES AND CLAMPS INSTALLATION - WITH 7500W SKYPOWER GENERATOR (600S)
FIGURE 8-36. AC CABLES AND CLAMPS INSTALLATION - 660SJ STANDARD WITHOUT GENERATOR (ANSI, CSA AND JAPANESE SPECS)
FIGURE 8-37. AC CABLES AND CLAMPS INSTALLATION - STANDARD WITHOUT GENERATOR (ANSI EXPORT, AUSTRALIAN, CHINESE & UK CA SPECS) (660SJ)
FIGURE 8-38. AC CABLES AND CLAMPS INSTALLATION - STANDARD WITH 2500W GENERATOR (ALL SPECS EXCEPT CE, AUSTRALIAN, CHINESE & UK CA SPECS) (660SJ)
FIGURE 8-39. AC CABLES AND CLAMPS INSTALLATION - WITH 4000W/50HZ GENERATOR (ANSI EXPORT, AUSTRALIAN, CE & UK CA SPECS) (660SJ)
FIGURE 8-40. AC CABLES AND CLAMPS INSTALLATION - STANDARD WITHOUT GENERATOR AND WITHOUT AC CABLES (MACHINES WITH SN STARTING WITH B3) (660SJ)
FIGURE 8-41. AC CABLES AND CLAMPS INSTALLATION - STANDARD WITH 4000W/60HZ GENERATOR (ALL SPECS EXCEPT AUSTRALIAN, CHINA, CE & UK CA SPECS) (660SJ) (Prior to SN 0300329356, Prior to SN B300029800)
FIGURE 8-42. AC CABLES AND CLAMPS INSTALLATION - STANDARD WITH 4000W/60HZ GENERATOR (ALL SPECS EXCEPT AUSTRALIAN, CHINA, CE & UK CA SPECS) (660SJ) (SN 0300329357 to Present, SN B300029801 to Present)
FIGURE 8-43. AC CABLES AND CLAMPS INSTALLATION - WITH 7500W SKYPOWER GENERATOR (660SJ) (Prior to SN 0300329356, Prior to SN B300029800)
FIGURE 8-44. AC CABLES AND CLAMPS INSTALLATION - WITH 7500W SKYPOWER GENERATOR (660SJ) (SN 0300329357 to Present, SN B300029801 to Present)
FIGURE 8-45. AC CABLES AND CLAMPS INSTALLATION - 660SJ 1K63FT WITHOUT GENERATOR (ANSI AND CSA SPECS)
FIGURE 8-46. AC CABLES AND CLAMPS INSTALLATION - 660SJ 1K63FT WITH 2500W GENERATOR (ANSI AND CSA SPECS)
FIGURE 8-47. AC CABLES AND CLAMPS INSTALLATION - 660SJ 1K63FT WITH 4000W/60HZ GENERATOR (ANSI AND CSA SPECS)
FIGURE 8-48. AC CABLES AND CLAMPS INSTALLATION - 660SJ 1K63FT WITH 7500W GENERATOR (ANSI AND CSA SPECS)
FIGURE 8-49. AC PLUG WITH AC CABLES INSTALLATION (MACHINES WITH SN STARTING WITH B3)
FIGURE 8-50. BATTERY DISCONNECT SWITCH INSTALLATION
FIGURE 8-51. BEACON JUMPER HARNESS
FIGURE 8-52. BREAKER BOX KIT - SINGLE DOUBLE POLE BREAKER (WITHOUT 4000W/50HZ GENERATOR)
FIGURE 8-53. BREAKER BOX KIT - SINGLE DOUBLE POLE BREAKER (WITH 4000W/50HZ GENERATOR)
FIGURE 8-54. BREAKER BOX KIT - 3 BREAKERS
FIGURE 8-55. BOOM SENSOR ASSEMBLY - LOWER (600S & 660SJ STANDARD)
FIGURE 8-56. BOOM SENSOR ASSEMBLY - UPPER
FIGURE 8-57. BOOM ANGLE SENSOR HARNESS (600S & 660SJ STANDARD)
FIGURE 8-58. BOOM SENSOR HARNESS - 660SJ 1K63FT
FIGURE 8-59. BOOM SENSOR ASSEMBLY - LOWER 660SJ 1K63FT
FIGURE 8-60. BOOM CABLE - LOWER
FIGURE 8-61. BOOM CABLE - UPPER (600S)
FIGURE 8-62. BOOM CABLE - UPPER (660SJ)
FIGURE 8-63. BREAKER BOX KIT
FIGURE 8-64. CAPACITY PROXIMITY HARNESS
FIGURE 8-65. CAPACITY PROXIMITY HARNESS
FIGURE 8-66. CAPACITY PROXIMITY EXTENSION HARNESS (660SJ 1K63FT)
FIGURE 8-67. CLEARSKY CS550 BEACON INSTALLATION (ABS HOODS)
FIGURE 8-68. CLEARSKY CS550 BEACON INSTALLATION (STEEL HOODS)
FIGURE 8-69. ECU POWER JUMPER HARNESS
FIGURE 8-70. ELECTRICAL COMPONENTS INSTALLATION - WITH 2WS
FIGURE 8-71. ELECTRICAL COMPONENTS INSTALLATION - WITH 2WS AND DEUTZ TD2.2L3 (STAGE V) ENGINE
FIGURE 8-72. ELECTRICAL COMPONENTS INSTALLATION - WITH 4WS
FIGURE 8-73. ELECTRICAL COMPONENTS INSTALLATION - WITH 4WS AND DEUTZ TD2.2L3 (STAGE V) ENGINE
FIGURE 8-74. ELECTRICAL COMPONENTS INSTALLATION - STANDARD WITH 2WS
FIGURE 8-75. ELECTRICAL COMPONENTS INSTALLATION - STANDARD WITH 2WS AND DEUTZ TD2.2L3 (STAGE V) ENGINE
FIGURE 8-76. ELECTRICAL COMPONENTS INSTALLATION - STANDARD WITH 4WS
FIGURE 8-77. ELECTRICAL COMPONENTS INSTALLATION - STANDARD WITH 4WS AND DEUTZ TD2.2L3 (STAGE V) ENGINE
FIGURE 8-78. ELECTRICAL COMPONENTS INSTALLATION - 660SJ 1K63FT WITH 2WS
FIGURE 8-79. ELECTRICAL COMPONENTS INSTALLATION - 660SJ 1K63FT WITH 4WS
FIGURE 8-80. ELECTRICAL COMPONENTS INSTALLATION - 660SJ 1K63FT WITH 2WS
FIGURE 8-81. ENGINE HARNESS - DEUTZ D2011 ENGINES
FIGURE 8-82. ENGINE HARNESS - DEUTZ TD2.2L3 (STAGE V) ENGINE
FIGURE 8-83. ENGINE HARNESS - DEUTZ D2.9L4 - 49HP AND DEUTZ TD2.9L4 - 67HP ENGINES
FIGURE 8-84. ENGINE HARNESS - DEUTZ TD2.9L4 (EMR ENGINE)
FIGURE 8-85. ENGINE HARNESS - DEUTZ D2.9 (CHINA IV) ENGINES
FIGURE 8-86. ENGINE HARNESS - FORD ENGINES
FIGURE 8-87. FUEL HARNESS - DEUTZ TD2.2L3 (STAGE V) ENGINE
FIGURE 8-88. FUEL PUMP HARNESS - DEUTZ D2.9L4 - 49HP, DEUTZ TD2.9L4 - 67HP AND DEUTZ TD2.2L3 (STAGE V) ENGINES
FIGURE 8-89. GENERATOR HARNESS - 2500W
FIGURE 8-90. GENERATOR HARNESS - 4000W
FIGURE 8-91. GENERATOR HARNESS - 7500W SKYPOWER
FIGURE 8-92. GENERATOR TO ENGINE HARNESS - 7500W SKYPOWER GENERATOR (DEUTZ D2011 ONLY)
FIGURE 8-93. GROUND CONTROL HARNESS
FIGURE 8-94. GROUND CONTROL HARNESS (660SJ-1K63FT)
FIGURE 8-95. HOUR METER JUMPER HARNESS
FIGURE 8-96. LIFT CYLINDER HARNESS
FIGURE 8-97. PLATFORM BOX HARNESS
FIGURE 8-98. PLATFORM BEACON HARNESS (SN 0300332720 to Present)
FIGURE 8-99. RECEPTACLE BOX KIT - 110V IEC YELLOW (CE & UK CA SPEC)
FIGURE 8-100. RECEPTACLE BOX KIT - 220V IEC BLUE (CE & UK CA SPEC)
FIGURE 8-101. RECEPTACLE BOX KIT - 220V CEE7 POST GROUND 2X4 BOX (CE & UK CA SPEC)
FIGURE 8-102. RECEPTACLE BOX KIT - 220V CEE7 SIDE GROUND (CE & UK CA SPEC)
FIGURE 8-103. RECEPTACLE BOX KIT - 220V AFSINT 107 (CE & UK CA SPEC)
FIGURE 8-104. RELAY & FUEL PUMP HARNESS
FIGURE 8-105. SKYEYE EMITTER HARNESS
FIGURE 8-106. SKYEYE INTERMEDIATE HARNESS
FIGURE 8-107. SKYEYE RECEIVER HARNESS
FIGURE 8-108. SKYGUARD INTERFACE HARNESS
FIGURE 8-109. SKYLINE HARNESS
FIGURE 8-110. STROBE LIGHT CONTROL HARNESS
FIGURE 8-111. STROBE LIGHT JUMPER HARNESS
FIGURE 8-112. TELE PROXIMITY HARNESS
FIGURE 8-113. TURNTABLE HARNESS
FIGURE 8-114. TURNTABLE HARNESS (STAGE V)
FIGURE 8-115. USB HARNESS (SN 0300332720 to Present, SN B300030892 to Present)
FIGURE 8-116. VALVE HARNESS - MAIN CONTROL (2WS)
FIGURE 8-117. VALVE HARNESS - MAIN CONTROL (2WS) (STAGE V)
FIGURE 8-118. VALVE HARNESS - MAIN CONTROL (4WS)
FIGURE 8-119. VALVE HARNESS - MAIN CONTROL (4WS) (STAGE V)
FIGURE 8-120. VALVE HARNESS - PLATFORM (600S)
FIGURE 8-121. VALVE HARNESS - PLATFORM (A92.5) (660SJ)
FIGURE 8-122. VALVE HARNESS - PLATFORM (A92.20) (660SJ)
FIGURE 8-123. WHITE NOISE ALARM HARNESS
FIGURE 8-124. WORKLIGHT HARNESS
SECTION 9 - DECALSFIGURE 9-1. DECAL INSTALLATION - (ANSI SPECS - ENGLISH LANGUAGE) (600S) (Prior to SN 0300332719)
FIGURE 9-2. DECAL INSTALLATION - (ANSI SPECS - ENGLISH LANGUAGE) (600S) (SN 0300332720 to Present)
FIGURE 9-3. DECAL INSTALLATION - (BRAZIL SPECS - PORTUGUESE/SPANISH LANGUAGES) (600S) (Prior to SN 0300332719)
FIGURE 9-4. DECAL INSTALLATION - (BRAZIL SPECS - PORTUGUESE/SPANISH LANGUAGES) (600S) (SN 0300332720 to Present)
FIGURE 9-5. DECAL INSTALLATION - (CE & UK CA SPECS - ENGLISH LANGUAGE) (600S)
FIGURE 9-6. DECAL INSTALLATION - (CHINESE SPECS - ENGLISH/SIMPLIFIED CHINESE LANGUAGES) (600S) (Prior to SN 0300332719)
FIGURE 9-7. DECAL INSTALLATION - (CHINESE SPECS - ENGLISH/SIMPLIFIED CHINESE LANGUAGES) (600S) (SN 0300332720 to Present)
FIGURE 9-8. DECAL INSTALLATION - (CHINESE SPECS - ENGLISH/TRADITIONAL CHINESE LANGUAGES) (600S) (Prior to SN 0300332719)
FIGURE 9-9. DECAL INSTALLATION - (CHINESE SPECS - ENGLISH/TRADITIONAL CHINESE LANGUAGES) (600S) (SN 0300332720 to Present)
FIGURE 9-10. DECAL INSTALLATION - (CSA SPECS - ENGLISH/FRENCH LANGUAGES) (600S) (Prior to SN 0300332719)
FIGURE 9-11. DECAL INSTALLATION - (CSA SPECS - ENGLISH/FRENCH LANGUAGES) (600S) (SN 0300332720 to Present)
FIGURE 9-12. DECAL INSTALLATION - (JAPANESE SPECS - ENGLISH/JAPANESE LANGUAGES) (600S) (Prior to SN 0300332719)
FIGURE 9-13. DECAL INSTALLATION - (JAPANESE SPECS - ENGLISH/JAPANESE LANGUAGES) (600S) (SN 0300332720 to Present)
FIGURE 9-14. DECAL INSTALLATION - (KOREAN SPECS - ENGLISH/KOREAN LANGUAGES) (600S) (Prior to SN 0300332719)
FIGURE 9-15. DECAL INSTALLATION - (KOREAN SPECS - ENGLISH/KOREAN LANGUAGES) (600S) (SN 0300332720 to Present)
FIGURE 9-16. DECAL INSTALLATION - (LATIN AMERICAN SPECS - ENGLISH/SPANISH LANGUAGES) (600S) (Prior to SN 0300332719)
FIGURE 9-17. DECAL INSTALLATION - (LATIN AMERICAN SPECS - ENGLISH/SPANISH LANGUAGES) (600S) (SN 0300332720 to Present)
FIGURE 9-18. DECAL INSTALLATION - STANDARD (ANSI SPECS - ENGLISH LANGUAGE) (660SJ) (Prior to SN 0300332719, Prior to SN B300030390)
FIGURE 9-19. DECAL INSTALLATION - STANDARD (ANSI SPECS - ENGLISH LANGUAGE) (660SJ) (SN 0300332720 to Present, SN B300030391 to Present, Including B300030161)
FIGURE 9-20. DECAL INSTALLATION - 660SJ 1K63FT (ANSI & CSA SPECS - ENGLISH LANGUAGE) (Prior to SN 0300332719)
FIGURE 9-21. DECAL INSTALLATION - 660SJ 1K63FT (ANSI & CSA SPECS - ENGLISH LANGUAGE) (SN 0300332720 to Present)
FIGURE 9-22. DECAL INSTALLATION - (AUSTRALIAN SPECS - ENGLISH LANGUAGE) (660SJ) (Prior to SN 0300332719, Prior to SN B300030390)
FIGURE 9-23. DECAL INSTALLATION - (AUSTRALIAN SPECS - ENGLISH LANGUAGE) (660SJ) (SN 0300332720 to Present, SN B300030391 to Present, Including B300030161)
FIGURE 9-24. DECAL INSTALLATION - (BRAZIL SPECS - PORTUGUESE/SPANISH LANGUAGES) (660SJ) (Prior to SN 0300332719, Prior to SN B300030390)
FIGURE 9-25. DECAL INSTALLATION - (BRAZIL SPECS - PORTUGUESE/SPANISH LANGUAGES) (660SJ) (SN 0300332720 to Present, SN B300030391 to Present, Including B300030161)
FIGURE 9-26. DECAL INSTALLATION - (CE & UK CA SPECS - ENGLISH LANGUAGE) (660SJ) (Prior to SN 0300332719, Prior to SN B300030390, Prior to SN C300002934)
FIGURE 9-27. DECAL INSTALLATION - (CE & UK CA SPECS - ENGLISH LANGUAGE) (660SJ) (SN 0300332720 to Present, SN B300030391 to Present, SN C300002935 to Present, Including B300030161 and C300002760)
FIGURE 9-28. DECAL INSTALLATION - (CHINESE SPECS - ENGLISH/SIMPLIFIED CHINESE LANGUAGES) (660SJ) (Prior to SN 0300332719, Prior to SN B300030390)
FIGURE 9-29. DECAL INSTALLATION - (CHINESE SPECS - ENGLISH/SIMPLIFIED CHINESE LANGUAGES) (660SJ) (SN 0300332720 to Present, SN B300030391 to Present, Including B300030161)
FIGURE 9-30. DECAL INSTALLATION - (CHINESE SPECS - ENGLISH/TRADITIONAL CHINESE LANGUAGES) (660SJ) (Prior to SN 0300332719, Prior to SN B300030390)
FIGURE 9-31. DECAL INSTALLATION - (CHINESE SPECS - ENGLISH/TRADITIONAL CHINESE LANGUAGES) (660SJ) (SN 0300332720 to Present, SN B300030391 to Present, Including B300030161)
FIGURE 9-32. DECAL INSTALLATION - STANDARD (CSA SPECS - ENGLISH/FRENCH LANGUAGES) (660SJ) (Prior to SN 0300332719, Prior to SN B300030390)
FIGURE 9-33. DECAL INSTALLATION - STANDARD (CSA SPECS - ENGLISH/FRENCH LANGUAGES) (660SJ) (SN 0300332720 to Present, SN B300030391 to Present, Including B300030161)
FIGURE 9-34. DECAL INSTALLATION - 660SJ 1K63FT (CSA SPECS - ENGLISH/FRENCH LANGUAGES) (Prior to SN 0300332719)
FIGURE 9-35. DECAL INSTALLATION - 660SJ 1K63FT (CSA SPECS - ENGLISH/FRENCH LANGUAGES) (SN 0300332720 to Present)
FIGURE 9-36. DECAL INSTALLATION - (JAPANESE SPECS - ENGLISH/JAPANESE LANGUAGES) (660SJ) (Prior to SN 0300332719, Prior to SN B300030390)
FIGURE 9-37. DECAL INSTALLATION - (JAPANESE SPECS - ENGLISH/JAPANESE LANGUAGES) (660SJ) (SN 0300332720 to Present, SN B300030391 to Present, Including B300030161)
FIGURE 9-38. DECAL INSTALLATION - (KOREAN SPECS - ENGLISH/KOREAN LANGUAGES) (660SJ) (Prior to SN 0300332719)
FIGURE 9-39. DECAL INSTALLATION - (KOREAN SPECS - ENGLISH/KOREAN LANGUAGES) (660SJ) (SN 0300332720 to Present)
FIGURE 9-40. DECAL INSTALLATION - (LATIN AMERICAN SPECS - ENGLISH/SPANISH LANGUAGES) (660SJ) (Prior to SN 0300332719, Prior to SN B300030390)
FIGURE 9-41. DECAL INSTALLATION - (LATIN AMERICAN SPECS - ENGLISH/SPANISH LANGUAGES) (660SJ) (SN 0300332720 to Present, SN B300030391 to Present, Including B300030161)
FIGURE 9-42. DECALS INSTALLATION - OPTIONS
FIGURE 9-43. DECAL INSTALLATION - SOFT-TOUCH (ANSI, ANSI EXPORT & CSA SPECS) (600S)
FIGURE 9-44. DECAL INSTALLATION - SOFT-TOUCH (CE & UK CA SPECS) (600S)
FIGURE 9-45. DECAL INSTALLATION - SOFT-TOUCH (ANSI, ANSI EXPORT, CHINA & CSA SPECS) (660SJ)
FIGURE 9-46. DECAL INSTALLATION - SOFT-TOUCH (CE & UK CA SPECS) (660SJ)
FIGURE 9-47. DECAL INSTALLATION - SKYWELDER (50HZ)
FIGURE 9-48. DECAL INSTALLATION - SKYWELDER (60HZ)
FIGURE 9-49. DECAL INSTALLATION - TOW (ANSI SPECS)
FIGURE 9-50. DECAL INSTALLATION - TOW (ANSI EXPORT, CHINA, CE & UK CA SPECS)
FIGURE 9-51. DECAL INSTALLATION - TOW (CSA SPECS)
PART NUMBER INDEX
- SuperPac Parts Manual
- StratoLift Parts Manual
