Hyundai
86
176,834
JLG Boom Lift 600S 660SJ Parts Catalog 31223019
Brand: JLG
Type of Machine: Boom Lift
Model: JLG 600S, 660SJ Boom Lift
Part Number: 31223019
Publication Date: 2025
Number of Pages: 1158 Pages
SECTION 1 - FRAME
FIGURE 1-1. AXLE INSTALLATION - FRONT​
FIGURE 1-2. AXLE INSTALLATION - REAR (4WS ONLY)​
FIGURE 1-3. AXLE INSTALLATION​
FIGURE 1-4. STEER INSTALLATION - WITHOUT TOW PACKAGE​
FIGURE 1-5. STEER INSTALLATION - WITH TOW PACKAGE​
FIGURE 1-6. WHEEL DRIVE INSTALLATION - 4WD/2WS (MACHINES WITH SN STARTING WITH 03)​
FIGURE 1-7. WHEEL DRIVE INSTALLATION - 4WD/2WS (MACHINES WITH SN STARTING WITHB3)​
FIGURE 1-8. WHEEL DRIVE INSTALLATION - 4WD/4WS (MACHINES WITH SN STARTING WITH 03)​
FIGURE 1-9. WHEEL DRIVE INSTALLATION - 4WD/4WS (MACHINES WITH SN STARTING WITH B3)​
FIGURE 1-10. DRIVE MOTOR ASSEMBLY (MACHINES WITH SN STARTING WITH 03)​
FIGURE 1-11. DRIVE MOTOR ASSEMBLY (MACHINES WITH SN STARTING WITH B3)​
FIGURE 1-12. DRIVE HUB ASSEMBLY​
FIGURE 1-13. TRACTION VALVE ASSEMBLY​
FIGURE 1-14. TRACTION VALVE ASSEMBLY (MACHINES WITH SN STARTING WITH 03)​
FIGURE 1-15. TIRE & WHEEL INSTALLATION - IN355-55 D625 FOAM FILLED (AVAILABLE ON ALL SPECS)​
FIGURE 1-16. TIRE & WHEEL INSTALLATION - IN355-55 D625 FOAM FILLED NON-MARKING (AVAILABLE ON ALL SPECS)​
FIGURE 1-17. TIRE & WHEEL INSTALLATION - 41-18LL X 22.5 FOAM FILLED TURF & SAND (AVAILABLE ON ALL SPECS EXCEPT AUSTRALIAN, CE & UK CA SPECS)​
FIGURE 1-18. MATTRACKS INSTALLATION​
FIGURE 1-19. LP TANKS AND BRACKETS INSTALLATION (FORD ENGINES)​
FIGURE 1-20. FRAME COVERS INSTALLATION - 2WS​
FIGURE 1-21. FRAME COVERS INSTALLATION - 4WS​
FIGURE 1-22. TOW BAR INSTALLATION​
SECTION 2 - TURNTABLE
FIGURE 2-1. VALVE INSTALLATION - WITH 2WS (600S)​
FIGURE 2-2. VALVE INSTALLATION - WITH 4WS (600S)​
FIGURE 2-3. VALVE INSTALLATION - WITH 2WS (660SJ)​
FIGURE 2-4. VALVE INSTALLATION - WITH 4WS (660SJ)​
FIGURE 2-5. MAIN VALVE ASSEMBLY - 2WS​
FIGURE 2-6. MAIN VALVE ASSEMBLY - 4WS​
FIGURE 2-7. AXLE VALVE ASSEMBLY​
FIGURE 2-8. SWING DRIVE INSTALLATION (Prior to SN B300025235, Prior to SN 0300315071)​
FIGURE 2-9. SWING DRIVE INSTALLATION (SN B300025235 to Present, SN 0300315071 to Present)​
FIGURE 2-10. SWING MOTOR/HUB ASSEMBLY (Prior to SN B300025235, Prior to SN 0300315071)​
FIGURE 2-11. SWING MOTOR/HUB ASSEMBLY (SN B300025235 to Present, SN 0300315071 to Present)​
FIGURE 2-12. TURNTABLE BEARING AND LUBE INSTALLATION​
FIGURE 2-13. TURNTABLE LOCK INSTALLATION​
FIGURE 2-14. ROTARY COUPLING INSTALLATION - 2WS​
FIGURE 2-15. ROTARY COUPLING ASSEMBLY - 2WS​
FIGURE 2-16. ROTARY COUPLING INSTALLATION - 4WS​
FIGURE 2-17. TANKS INSTALLATION - DIESEL MACHINES (POLY FUEL TANK) (HYDRAULIC TANK WITH 6 INCH BREATHER)​
FIGURE 2-18. TANKS INSTALLATION - DIESEL MACHINES (POLY FUEL TANK) (HYDRAULIC TANK WITH 4 INCH BREATHER)​
FIGURE 2-19. TANKS INSTALLATION - DIESEL MACHINES (STEEL FUEL TANK) (HYDRAULIC TANK WITH 6 INCH BREATHER)​
FIGURE 2-20. TANKS INSTALLATION - DIESEL MACHINES (STEEL FUEL TANK) (HYDRAULIC TANK WITH 4 INCH BREATHER)​
FIGURE 2-21. TANKS INSTALLATION - GAS MACHINES (HYDRAULIC TANK WITH 6 INCH BREATHER)​
FIGURE 2-22. TANKS INSTALLATION - GAS MACHINES (HYDRAULIC TANK WITH 4 INCH BREATHER)​
FIGURE 2-23. HYDRAULIC TANK ASSEMBLY (HYDRAULIC TANK WITH 6 INCH BREATHER)​
FIGURE 2-24. HYDRAULIC TANK ASSEMBLY (HYDRAULIC TANK WITH 4 INCH BREATHER)​
FIGURE 2-25. BATTERY AND AUXILIARY PUMP INSTALLATION​
FIGURE 2-26. BATTERY AND AUXILIARY PUMP WITH DISCONNECT SWITCH INSTALLATION​
FIGURE 2-27. ELECTRICAL COMPONENTS INSTALLATION- WITH 2WS (600S) (Prior to SN B300024404, Prior to SN 0300313003, Except SN 0300310881 through 0300310884)​
FIGURE 2-28. ELECTRICAL COMPONENTS INSTALLATION- WITH 2WS (SN B300024404 to Present, SN 0300313003 to Present, SN 0300310881 through 0300310884)​
FIGURE 2-29. ELECTRICAL COMPONENTS INSTALLATION - WITH 2WS AND DEUTZ TD2.2L3 (STAGE V) ENGINE (600S) (Prior to SN B300024404, Prior to SN 0300313003, Except SN 0300310881 through 0300310884)​
FIGURE 2-30. ELECTRICAL COMPONENTS INSTALLATION - WITH 2WS AND DEUTZ TD2.2L3 (STAGE V) ENGINE (600S) (SN B300024404 to Present, SN 0300313003 to Present, SN 0300310881 through 0300310884)​
FIGURE 2-31. ELECTRICAL COMPONENTS INSTALLATION - WITH 4WS (600S) (Prior to SN B300024404, Prior to SN 0300313003, Except SN 0300310881 through 0300310884)​
FIGURE 2-32. ELECTRICAL COMPONENTS INSTALLATION - WITH 4WS (SN B300024404 to Present, SN 0300313003 to Present, SN 0300310881 through 0300310884)​
FIGURE 2-33. ELECTRICAL COMPONENTS INSTALLATION - WITH 4WS AND DEUTZ TD2.2L3 (STAGE V) ENGINE (600S) (Prior to SN B300024404, Prior to SN 0300313003, Except SN 0300310881 through 0300310884)​
FIGURE 2-34. ELECTRICAL COMPONENTS INSTALLATION - WITH 4WS AND DEUTZ TD2.2L3 (STAGE V) ENGINE (600S) (SN B300024404 to Present, SN 0300313003 to Present, SN 0300310881 through 0300310884)​
FIGURE 2-35. ELECTRICAL COMPONENTS INSTALLATION - STANDARD WITH 2WS (660SJ) (Prior to SN B300024404, Prior to SN 0300313003, Except SN 0300310881 through 0300310884)​
FIGURE 2-36. ELECTRICAL COMPONENTS INSTALLATION - STANDARD WITH 2WS (SN B300024404 to Present, SN 0300313003 to Present, SN 0300310881 through 0300310884)​
FIGURE 2-37. ELECTRICAL COMPONENTS INSTALLATION - STANDARD WITH 2WS AND DEUTZ TD2.2L3 (STAGE V) ENGINE (660SJ) (Prior to SN B300024404, Prior to SN 0300313003, Except SN 0300310881 through 0300310884)​
FIGURE 2-38. ELECTRICAL COMPONENTS INSTALLATION - STANDARD WITH 2WS AND DEUTZ TD2.2L3 (STAGE V) ENGINE (660SJ) (SN B300024404 to Present, SN 0300313003 to Present, SN 0300310881 through 0300310884)​
FIGURE 2-39. ELECTRICAL COMPONENTS INSTALLATION - STANDARD WITH 4WS (660SJ) (Prior to SN B300024404, Prior to SN 0300313003, Except SN 0300310881 through 0300310884)​
FIGURE 2-40. ELECTRICAL COMPONENTS INSTALLATION - STANDARD WITH 4WS (SN B300024404 to Present, SN 0300313003 to Present, SN 0300310881 through 0300310884)​
FIGURE 2-41. ELECTRICAL COMPONENTS INSTALLATION - STANDARD WITH 4WS AND DEUTZ TD2.2L3 (STAGE V) ENGINE (660SJ) (Prior to SN B300024404, Prior to SN 0300313003, Except SN 0300310881 through 0300310884)​
FIGURE 2-42. ELECTRICAL COMPONENTS INSTALLATION - STANDARD WITH 4WS AND DEUTZ TD2.2L3 (STAGE V) ENGINE (660SJ) (SN B300024404 to Present, SN 0300313003 to Present, SN 0300310881 through 0300310884)​
FIGURE 2-43. ELECTRICAL COMPONENTS INSTALLATION - 1K63FT WITH 2WS (660SJ)​
FIGURE 2-44. ELECTRICAL COMPONENTS INSTALLATION - 1K63FT WITH 4WS (660SJ)​
FIGURE 2-45. ELECTRICAL COMPONENTS INSTALLATION - 1K63FT WITH 2WS (660SJ)​
FIGURE 2-46. GROUND CONTROL ASSEMBLY (600S)​
FIGURE 2-47. GROUND CONTROL ASSEMBLY - WITH DEUTZ TD2.2L3 (STAGE V) ENGINE (600S)​
FIGURE 2-48. GROUND CONTROL ASSEMBLY (660SJ)​
FIGURE 2-49. GROUND CONTROL ASSEMBLY - WITH DEUTZ TD2.2L3 (STAGE V) ENGINE (660SJ)​
FIGURE 2-50. HOODS INSTALLATIONS - ABS (DEUTZ D2.9L4 - 49HP ENGINE)​
FIGURE 2-51. HOODS INSTALLATIONS - ABS (DEUTZ D2011, DEUTZ TD2.9L4 - 67HP AND FORD ENGINES)​
FIGURE 2-52. HOOD ASSEMBLY - ENGINE SIDE (ABS)​
FIGURE 2-53. HOOD ASSEMBLY - TANK SIDE (ABS)​
FIGURE 2-54. HOODS INSTALLATIONS - STEEL (MACHINES WITH SN STARTING WITH 03) (DEUTZ D2.9L4 - 49HP ENGINE)​
FIGURE 2-55. HOODS INSTALLATIONS - STEEL (MACHINES WITH SN STARTING WITH 03) (DEUTZ D2011, DEUTZ TD2.9L4 - 67HP AND FORD ENGINES)​
FIGURE 2-56. HOODS INSTALLATIONS - STEEL (MACHINES WITH SN STARTING WITH B3)​
FIGURE 2-57. HOODS INSTALLATION - STEEL (MACHINES WITH SN STARTING WITH B3) (DEUTZ D2.9L4 (CHINA IV) ENGINES)​
FIGURE 2-58. HOOD ASSEMBLY - ENGINE SIDE (STEEL) (MACHINES WITH SN STARTING WITH 03)​
FIGURE 2-59. HOOD ASSEMBLY - ENGINE SIDE (STEEL) (MACHINES WITH SN STARTING WITH B3)​
FIGURE 2-60. HOODS ASSEMBLY - ENGINE SIDE (STEEL) (MACHINES WITH SN STARTING WITH B3) (DEUTZ D2.9L4 (CHINA IV) ENGINES)​
FIGURE 2-61. HOOD ASSEMBLY - TANK SIDE (STEEL) (MACHINES WITH SN STARTING WITH 03)​
FIGURE 2-62. HOOD ASSEMBLY - TANK SIDE (STEEL) (MACHINES WITH SN STARTING WITH B3)​
FIGURE 2-63. CLEARSKY INSTALLATION (WITH PLASTIC HOOD)​
FIGURE 2-64. CLEARSKY INSTALLATION (WITH STEEL HOOD)​
FIGURE 2-65. SIDE-SHEET ASSEMBLY - TANK SIDE​
FIGURE 2-66. SIDE-SHEET ASSEMBLY - ENGINE SIDE​
FIGURE 2-67. KEYSWITCH INSTALLATION -(ANSI, ANSI EXPORT, CSA AND JAPANESE SPECS) (600S)​
FIGURE 2-68. KEYSWITCH INSTALLATION - (CE & UK CA SPECS) (600S)​
FIGURE 2-69. KEYSWITCH INSTALLATION - WITH DEUTZ TD2.2L3 (STAGE V) ENGINE (CE & UK CA SPECS) (600S)​
FIGURE 2-70. KEYSWITCH INSTALLATION - (ALL SPECS EXCEPT CE & UK CA SPECS) (660SJ)​
FIGURE 2-71. KEYSWITCH INSTALLATION - (CE & UK CA SPECS) (660SJ)​
FIGURE 2-72. KEYSWITCH INSTALLATION - WITH DEUTZ TD2.2L3 (STAGE V) ENGINE (CE & UK CA SPECS) (660SJ)​
FIGURE 2-73. LIGHT PANEL INSTALLATION (MACHINES WITH SN STARTING WITH 03)​
FIGURE 2-74. LIGHT PANEL INSTALLATION (MACHINES WITH SN STARTING WITH B3)​
FIGURE 2-75. NOISE REDUCTION PACKAGE (600S)​
FIGURE 2-76. NOISE REDUCTION PACKAGE (660SJ)​
FIGURE 2-77. TURNTABLE COVERS INSTALLATION​
FIGURE 2-78. WHITE NOISE ALARM (AMBIENT) INSTALLATION​
FIGURE 2-79. WHITE NOISE ALARM (CONSTANT) INSTALLATION​
SECTION 3 - ENGINE
FIGURE 3-1. DEUTZ D2011 ENGINE INSTALLATION - WITHOUT ARCTIC PACKAGE (MACHINES WITH SN STARTING WITH 03)​
FIGURE 3-2. DEUTZ D2011 ENGINE AND PUMPS SUB-ASSEMBLY - WITHOUT ARCTIC PACKAGE (MACHINES WITH SN STARTING WITH 03)​
FIGURE 3-3. DEUTZ D2011 ENGINE INSTALLATION - WITHOUT ARCTIC PACKAGE (MACHINES WITH SN STARTING WITH B3)​
FIGURE 3-4. DEUTZ D2011 ENGINE AND PUMPS SUB-ASSEMBLY - WITHOUT ARCTIC PACKAGE (MACHINES WITH SN STARTING WITH B3)​
FIGURE 3-5. DEUTZ D2011 ENGINE ASSEMBLY - WITHOUT ARCTIC PACKAGE​
FIGURE 3-6. DEUTZ D2011 ENGINE INSTALLATION - WITH ARCTIC PACKAGE (MACHINES WITH SN STARTING WITH 03)​
FIGURE 3-7. DEUTZ D2011 ENGINE AND PUMPS SUB-ASSEMBLY WITH ARCTIC PACKAGE (MACHINES WITH SN STARTING WITH 03)​
FIGURE 3-8. DEUTZ D2011 ENGINE INSTALLATION - WITH ARCTIC PACKAGE (MACHINES WITH SN STARTING WITH B3)​
FIGURE 3-9. DEUTZ D2011 ENGINE AND PUMPS SUB-ASSEMBLY - WITH ARCTIC PACKAGE (MACHINES WITH SN STARTING WITH B3)​
FIGURE 3-10. DEUTZ D2011 ENGINE ASSEMBLY - WITH ARCTIC PACKAGE​
FIGURE 3-11. DEUTZ D2011 ENGINE COMPONENTS​
FIGURE 3-12. DEUTZ D2011 (STAGE V) ENGINE INSTALLATION​
FIGURE 3-13. DEUTZ D2011 (STAGE V) ENGINE AND PUMPS SUB-ASSEMBLY​
FIGURE 3-14. DEUTZ D2011 (STAGE V) ENGINE ASSEMBLY​
FIGURE 3-15. DEUTZ D2011 (STAGE V) ENGINE COMPONENTS​
FIGURE 3-16. DEUTZ TD2.2L3 (STAGE V) ENGINE INSTALLATION​
FIGURE 3-17. DEUTZ TD2.2L3 (STAGE V) ENGINE AND PUMPS SUB-ASSEMBLY​
FIGURE 3-18. DEUTZ TD2.2L3 (STAGE V) ENGINE ASSEMBLY​
FIGURE 3-19. DEUTZ TD2.2L3 (STAGE V) ENGINE COMPONENTS​
FIGURE 3-20. BREATHER HEATER INSTALLATION - DEUTZ D2.9L4 - 49HP AND DEUTZ TD2.9L4 - 67HP ENGINES WITH ARCTIC PACKAGE​
FIGURE 3-21. DEUTZ D2.9L4 ENGINE INSTALLATION (CHINA IV)​
FIGURE 3-22. DEUTZ D2.9L4 ENGINE AND PUMP SUB-ASSEMBLY (CHINA IV)​
FIGURE 3-23. DEUTZ D2.9L4 ENGINE ASSEMBLY (CHINA IV)​
FIGURE 3-24. DUETZ D2.9L4 ENGINE COMPONENTS (CHINA IV)​
FIGURE 3-25. DEUTZ D2.9L4 EMR5 (49HP) ENGINE INSTALLATION WITHOUT ARCTIC PACKAGE​
FIGURE 3-26. DEUTZ D2.9L4 - EMR5 (49HP) ENGINE AND PUMPS SUB-ASSEMBLY WITHOUT ARCTIC PACKAGE​
FIGURE 3-27. DEUTZ D2.9L4 - EMR5 (49HP) ENGINE ASSEMBLY WITHOUT ARCTIC PACKAGE (Prior to SN B300022197, Prior to SN 0300307233)​
FIGURE 3-28. DEUTZ D2.9L4 - EMR5 (49HP) ENGINE ASSEMBLY WITHOUT ARCTIC PACKAGE (SN B300022197 to Present, SN 0300307233 to Present)​
FIGURE 3-29. DEUTZ D2.9L4 - EMR5 (49HP) ENGINE INSTALLATION WITH ARCTIC PACKAGE​
FIGURE 3-30. DEUTZ D2.9L4 - EMR5 (49HP) ENGINE AND PUMPS SUB-ASSEMBLY WITH ARCTIC PACKAGE​
FIGURE 3-31. DEUTZ D2.9L4 - EMR5 (49HP) ENGINE ASSEMBLY WITH ARCTIC PACKAGE​
FIGURE 3-32. ENGINE COMPONENTS - DEUTZ D2.9L4 EMR5 ENGINE (ANSI, ANSI EXPORT AND CSA SPECS)​
FIGURE 3-33. DEUTZ D2.9L4 - EMR5 (67HP) ENGINE INSTALLATION WITH ARCTIC PACKAGE​
FIGURE 3-34. DEUTZ D2.9L4 - EMR5 (67HP) ENGINE AND PUMPS SUB-ASSEMBLY WITH ARCTIC PACKAGE​
FIGURE 3-35. DEUTZ D2.9L4 - EMR5 (67HP) ENGINE ASSEMBLY WITH ARCTIC PACKAGE​
FIGURE 3-36. DEUTZ D2.9L4 - EMR5 (67HP) ENGINE INSTALLATION WITHOUT ARCTIC PACKAGE​
FIGURE 3-37. DEUTZ D2.9L4 - EMR5 (67HP) ENGINE AND PUMPS SUB-ASSEMBLY WITHOUT ARCTIC PACKAGE​
FIGURE 3-38. DEUTZ D2.9L4 - EMR5 (67HP) ENGINE ASSEMBLY WITHOUT ARCTIC PACKAGE​
FIGURE 3-39. ENGINE COMPONENTS - DEUTZ D2.9L4 EMR5 (67HP) ENGINE​
FIGURE 3-40. FORD ENGINE INSTALLATION - WITHOUT ARCTIC PACKAGE​
FIGURE 3-41. FORD ENGINE AND PUMPS SUB-ASSEMBLY - WITHOUT ARCTIC PACKAGE​
FIGURE 3-42. FORD ENGINE ASSEMBLY - WITHOUT ARCTIC PACKAGE​
FIGURE 3-43. FORD ENGINE INSTALLATION - WITH ARCTIC PACKAGE​
FIGURE 3-44. FORD ENGINE AND PUMPS SUB-ASSEMBLY - WITH ARCTIC PACKAGE​
FIGURE 3-45. FORD ENGINE ASSEMBLY - WITH ARCTIC PACKAGE​
FIGURE 3-46. FORD ENGINE PREP ASSEMBLY​
FIGURE 3-47. FORD ENGINE COMPONENTS​
FIGURE 3-48. PUMP COUPLING KIT (DEUTZ ENGINES)​
FIGURE 3-49. PISTON PUMP ASSEMBLY - ALL ENGINES EXCEPT CHINA IV ENGINES AND DUETZ D2011 ENGINES ON MACHINES WITH SN STARTING WITH B3​
FIGURE 3-50. PISTON PUMP ASSEMBLY - CHINA IV ENGINES AND DUETZ D2011 ENGINES ON MACHINES WITH SN STARTING WITH B3​
FIGURE 3-51. BELT WITHOUT GENERATOR INSTALLATION (FORD ENGINES)​
FIGURE 3-52. EXHAUST PIPE INSTALLATION - (DEUTZ D2011 ENGINES)​
FIGURE 3-53. FUEL FILTER INSTALLATION (POLY FUEL TANK)​
FIGURE 3-54. FUEL FILTER INSTALLATION (STEEL FUEL TANK) (DEUTZ D2011 ENGINES)​
FIGURE 3-55. FUEL FILTER INSTALLATION (STEEL FUEL TANK) (DEUTZ TD2.9L4 ENGINES)​
FIGURE 3-56. FUEL FILTER INSTALLATION (STEEL FUEL TANK) (DEUTZ D2.9L4 ENGINES)​
FIGURE 3-57. MOTOR MOUNT INSTALLATION - WITHOUT GENERATOR (DEUTZ D2011 ENGINES)​
FIGURE 3-58. MOTOR MOUNT INSTALLATION - WITHOUT GENERATOR (DEUTZ TD2.2L3 (STAGE V) ENGINES)​
FIGURE 3-59. MOTOR MOUNT INSTALLATION - WITHOUT GENERATOR (DEUTZ D2.9L4 - 49HP AND DEUTZ D2.9L4 (CHINA IV) ENGINES)​
FIGURE 3-60. MOTOR MOUNT INSTALLATION - WITHOUT GENERATOR (DEUTZ TD2.9L4 - 67HP ENGINES)​
FIGURE 3-61. MOTOR MOUNT INSTALLATION - WITH GENERATOR (DEUTZ D2011 ENGINES)​
FIGURE 3-62. MOTOR MOUNT INSTALLATION - WITH GENERATOR (DEUTZ TD2.2L3 (STAGE V) ENGINES)​
FIGURE 3-63. MOTOR MOUNT INSTALLATION - WITH GENERATOR (DEUTZ TD2.9L4 - 49HP ENGINES)​
FIGURE 3-64. MOTOR MOUNT INSTALLATION - WITH GENERATOR (DEUTZ TD2.9L4 - 67HP ENGINES)​
FIGURE 3-65. MUFFLER INSTALLATION - SPARK ARRESTING (DEUTZ D2011 ENGINES)​
FIGURE 3-66. RADIATOR ASSEMBLY - DUETZ D2.9L4 ENGINE (CHINA IV)​
FIGURE 3-67. TRAY JACK INSTALLATION (DEUTZ D2011, DEUTZ TD2.9L4 - 67HP AND FORD ENGINES)​
FIGURE 3-68. TRAY JACK INSTALLATION (DEUTZ TD2.2L3 (STAGE V), DEUTZ D2.9L4 - 49HP AND DEUTZ D2.9 (CHINA IV) ENGINES)​
FIGURE 3-69. QUICKFIT OIL VALVE (DEUTZ D ENGINES)​
FIGURE 3-70. ENGINE HOOD BAFFLES INSTALLATION - ABS HOODS (DEUTZ D2011, DEUTZ TD2.9L4 - 67HP AND FORD ENGINES)​
FIGURE 3-71. ENGINE HOOD BAFFLES INSTALLATION - ABS HOODS (DEUTZ D2.9L4 - 49HP AND DEUTZ D2.9L4 (CHINA IV) ENGINES)​
FIGURE 3-72. ENGINE HOOD BAFFLES INSTALLATION - STEEL HOODS (DEUTZ D2011, DEUTZ TD2.9L4 - 67HP AND FORD ENGINES)​
FIGURE 3-73. ENGINE HOOD BAFFLES INSTALLATION - STEEL HOODS (DEUTZ D2.9L4 - 49HP AND DEUTZ D2.9L4 (CHINA IV) ENGINES)​
FIGURE 3-74. 2500W GENERATOR INSTALLATION - 110V/60HZ (DEUTZ D2011 ENGINES) (OPTIONAL)​
FIGURE 3-75. 2500W GENERATOR INSTALLATION - 110V/60HZ (DEUTZ D2.9L4 - 49HP ENGINES) (OPTIONAL)​
FIGURE 3-76. 2500W GENERATOR INSTALLATION - 110V/60HZ (DEUTZ TD2.9L4 - 67HP ENGINES) (OPTIONAL)​
FIGURE 3-77. 2500W GENERATOR INSTALLATION - 110V/60HZ (FORD ENGINES) (OPTIONAL)​
FIGURE 3-78. 2500W GENERATOR INSTALLATION - 220V/50HZ (DEUTZ D2011 ENGINES) (OPTIONAL)​
FIGURE 3-79. 4000W GENERATOR INSTALLATION - 110V/60HZ (DEUTZ D2011 ENGINES) (OPTIONAL)​
FIGURE 3-80. 4000W GENERATOR INSTALLATION - 110V/60HZ (DEUTZ D2.9L4 - 49HP ENGINES) (OPTIONAL)​
FIGURE 3-81. 4000W GENERATOR INSTALLATION - 110V/60HZ (DEUTZ TD2.9L4 - 67HP ENGINES) (OPTIONAL)​
FIGURE 3-82. 4000W GENERATOR INSTALLATION - 220V/50HZ (DEUTZ D2011 ENGINES) (OPTIONAL)​
FIGURE 3-83. 4000W GENERATOR INSTALLATION - 220V/50HZ (DEUTZ TD2.2L3 (STAGE V) ENGINE) (OPTIONAL)​
FIGURE 3-84. 4000W GENERATOR INSTALLATION - 220V/50HZ (DEUTZ TD2.9L4 - 67HP ENGINES) (OPTIONAL)​
FIGURE 3-85. 7500W SKYPOWER GENERATOR INSTALLATION - 110/60HZ (DEUTZ D2011 ENGINES) (OPTIONAL)​
FIGURE 3-86. 7500W SKYPOWER GENERATOR INSTALLATION - 110V/60HZ (DEUTZ D2.9L4 - 49HP ENGINES) (OPTIONAL)​
FIGURE 3-87. 7500W SKYPOWER GENERATOR INSTALLATION - 110V/60HZ (DEUTZ TD2.9L4 - 67HP ENGINES) (OPTIONAL)​
FIGURE 3-88. 7500W SKYPOWER GENERATOR INSTALLATION - 110V/60HZ (FORD ENGINES) (OPTIONAL)​
FIGURE 3-89. 7500W SKYPOWER GENERATOR INSTALLATION - 220V/50HZ (DEUTZ D2011 ENGINES) (OPTIONAL)​
FIGURE 3-90. 7500W SKYPOWER GENERATOR INSTALLATION - 220V/50HZ (DEUTZ TD2.2L3 (STAGE V) ENGINE) (OPTIONAL)​
FIGURE 3-91. 7500W SKYPOWER GENERATOR INSTALLATION - 220V/50HZ (DEUTZ TD2.9L4 - 67HP ENGINES) (OPTIONAL)​
SECTION 4 - BOOM
FIGURE 4-1. BOOM INSTALLATION (600S)​
FIGURE 4-2. BOOM INSTALLATION - (ALL SPECS EXCEPT CHINESE SPEC) (660SJ)​
FIGURE 4-3. BOOM INSTALLATION - 1K63FT MACHINES (660SJ)​
FIGURE 4-4. BOOM INSTALLATION - (CHINESE SPEC ONLY) (660SJ)​
FIGURE 4-5. BOOM ASSEMBLY (600S)​
FIGURE 4-6. BOOM ASSEMBLY - (ALL SPECS EXCEPT CHINESE SPEC) (660SJ)​
FIGURE 4-7. BOOM ASSEMBLY - 1K63FT MACHINES (660SJ)​
FIGURE 4-8. BOOM ASSEMBLY - (CHINESE SPEC ONLY) (660SJ)​
FIGURE 4-9. JIB ASSEMBLY - STANDARD (MACHINES WITH SN STARTING WITH 03) (660SJ)​
FIGURE 4-10. JIB ASSEMBLY - STANDARD (MACHINES WITH SN STARTING WITH B3) (660SJ)​
FIGURE 4-11. JIB ASSEMBLY - 1K63FT MACHINES (660SJ)​
FIGURE 4-12. PLATFORM ROTATOR ASSEMBLY (600S)​
FIGURE 4-13. PLATFORM ROATOR ASSEMBLY - (MACHINES WITH SN STARTING WITH 03) (660SJ)​
FIGURE 4-14. PLATFORM ROATOR ASSEMBLY - (MACHINES WITH SN STARTING WITH B3) (660SJ)​
FIGURE 4-15. POWER TRACK INSTALLATION - STANDARD MACHINES​
FIGURE 4-16. POWER TRACK INSTALLATION - WITH PLASTIC CLAMP (MACHINES WITH SN STARTING WITH B3)​
FIGURE 4-17. POWER TRACK INSTALLATION - WITH STEEL CLAMP (MACHINES WITH SN STARTING WITH 03)​
FIGURE 4-18. POWER TRACK INSTALLATION - WITH STEEL CLAMP (MACHINES WITH SN STARTING WITH B3)​
FIGURE 4-19. POWER TRACK INSTALLATION - 1K63FT MACHINES (660SJ)​
FIGURE 4-20. BOOM VALVES INSTALLATION - WITH 2WS (600S)​
FIGURE 4-21. BOOM VALVES INSTALLATION - WITH 4WS (600S)​
FIGURE 4-22. BOOM VALVES INSTALLATION - WITH 2WS (660SJ)​
FIGURE 4-23. BOOM VALVES INSTALLATION - WITH 4WS (660SJ)​
FIGURE 4-24. PLATFORM VALVE ASSEMBLY (600S)​
FIGURE 4-25. PLATFORM VALVE ASSEMBLY (660SJ)​
FIGURE 4-26. BOOM SENSORS INSTALLATION (600S)​
FIGURE 4-27. BOOM SENSORS INSTALLATION (660SJ)​
FIGURE 4-28. BOOM SENSOR WITH COVERS INSTALLATION - STANDARD (660SJ)​
FIGURE 4-29. BOOM SENSOR WITH COVERS INSTALLATION - 1K63FT MACHINES (660SJ)​
FIGURE 4-30. PLATFORM SUPPORT INSTALLATION (MACHINES WITH SN STARTING WITH 03)​
FIGURE 4-31. PLATFORM SUPPORT INSTALLATION WITH LSS (MACHINES WITH SN STARTING WITH B3)​
FIGURE 4-32. PLATFORM SUPPORT INSTALLATION (MACHINES WITH SN STARTING WITH B3)​
FIGURE 4-33. ROTATOR ASSEMBLY​
SECTION 5 - PLATFORM
FIGURE 5-1. PLATFORM ASSEMBLY - 30IN X 3FT (76CM X .91M) - DROP BAR ENTRY​
FIGURE 5-2. PLATFORM ASSEMBLY - 30IN X 4FT (76CM X 1.22M) WITH SWING GATE​
FIGURE 5-3. PLATFORM ASSEMBLY - 30IN X 4FT (76CM X 1.22M) WITH DROP BAR​
FIGURE 5-4. PLATFORM ASSEMBLY - 30IN X 5FT (76CM X 1.52M) WITH SWING GATE​
FIGURE 5-5. PLATFORM ASSEMBLY - 30IN X 5FT (76CM X 1.52M) WITH DROP BAR​
FIGURE 5-6. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) WITH SWING GATE​
FIGURE 5-7. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) WITH DROP BAR​
FIGURE 5-8. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) WITH DROP BAR (SHIPYARD MACHINES)​
FIGURE 5-9. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) WITH FALL ARREST (ANSI, ANSI EXPORT, CHINA AND CSA SPECS)​
FIGURE 5-10. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) TRI-ENTRY WITH SWING GATE​
FIGURE 5-11. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) TRI-ENTRY WITH DROP BAR​
FIGURE 5-12. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH SWING GATE (MACHINES WITH SN STARTING WITH 03)​
FIGURE 5-13. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH DROP BAR (MACHINES WITH SN STARTING WITH B3)​
FIGURE 5-14. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH FALL ARREST​
FIGURE 5-15. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) TRI-ENTRY WITH SWING GATE​
FIGURE 5-16. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) TRI-ENTRY WITH DROP BAR​
FIGURE 5-17. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH SWING GATE (MACHINES WITH SN STARTING WITH B3)​
FIGURE 5-18. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH DROP BAR (MACHINES WITH SN STARTING WITH B3)​
FIGURE 5-19. TRAY ASSEMBLY​
FIGURE 5-20. PLATFORM CONSOLE AND FOOTSWITCH INSTALLATION​
FIGURE 5-21. CONSOLE BOX ASSEMBLY​
FIGURE 5-22. STEER SWITCH INSTALLATION WITHOUT TOW PACKAGE (4WD/4WS MACHINES)​
FIGURE 5-23. STEER SWITCH INSTALLATION WITH TOW PACKAGE (4WD/4WS MACHINES)​
FIGURE 5-24. FOOTSWITCH ASSEMBLY​
FIGURE 5-25. LIGHT PANEL INSTALLATION (MACHINES WITH SN STARTING WITH 03)​
FIGURE 5-26. LIGHT PANEL INSTALLATION (MACHINES WITH SN STARTING WITH B3)​
FIGURE 5-27. SKYLINE INSTALLATION​
FIGURE 5-28. SKYGLAZIER INSTALLATION (ANSI, AUSTRALIAN AND CSA SPECS)​
FIGURE 5-29. SKYGLAZIER INSTALLATION (BRAZIL SPECS) (600S)​
FIGURE 5-30. SKYGLAZIER INSTALLATION (LATIN AMERICAN SPECS) (600S)​
FIGURE 5-31. SKYWELDER INSTALLATION (50HZ)​
FIGURE 5-32. SKYWELDER INSTALLATION (60HZ)​
FIGURE 5-33. SKYWELDER PREP PACKAGE (60HZ)​
FIGURE 5-34. WELDER ASSEMBLY​
FIGURE 5-35. SOFT TOUCH INSTALLATION - 6FT (1.83M) PLATFORM (OPTIONAL)​
FIGURE 5-36. SOFT TOUCH INSTALLATION - 6FT (1.83M) FALL ARREST PLATFORM (600S)​
FIGURE 5-37. SOFT TOUCH INSTALLATION - 8FT (2.4M) PLATFORM (OPTIONAL)​
FIGURE 5-38. SOFT TOUCH INSTALLATION - 8FT (2.4M) FALL ARREST PLATFORM (600S)​
FIGURE 5-39. SOFT TOUCH INSTALLATION - OVERHEAD (CHINESE AND KOREAN SPECS)​
FIGURE 5-40. FALL ARREST INSTALLATION (BOLT-ON) (4FT/1.22M PLATFORM)​
FIGURE 5-41. FALL ARREST INSTALLATION (BOLT-ON EXTERNAL) (5FT/1.52M PLATFORM)​
FIGURE 5-42. FALL ARREST INSTALLATION (BOLT-ON EXTERNAL) (6FT/1.82M PLATFORM)​
FIGURE 5-43. FALL ARREST INSTALLATION (BOLT-ON EXTERNAL) (6FT/1.82M TRI-ENTRY PLATFORM)​
FIGURE 5-44. FALL ARREST INSTALLATION (BOLT-ON EXTERNAL) (8FT/2.4M PLATFORM)​
FIGURE 5-45. USB CHARGER INSTALLATION​
SECTION 6 - CYLINDER
FIGURE 6-1. AXLE LOCKOUT CYLINDER ASSEMBLY​
FIGURE 6-2. AXLE LOCKOUT CYLINDER ASSEMBLY​
FIGURE 6-3. LEVEL CYLINDER ASSEMBLY - PLATFORM SLAVE (600S)​
FIGURE 6-4. LEVEL CYLINDER ASSEMBLY - PLATFORM SLAVE (STANDARD) (660SJ)​
FIGURE 6-5. LEVEL CYLINDER ASSEMBLY - PLATFORM SLAVE (1K63FT MACHINES) (660SJ)​
FIGURE 6-6. LIFT CYLINDER ASSEMBLY - BOOM​
FIGURE 6-7. LIFT CYLINDER ASSEMBLY - JIB (STANDARD) (MACHINES WITH SN STARTING WITH 03) (660SJ)​
FIGURE 6-8. LIFT CYLINDER ASSEMBLY - JIB (STANDARD) (MACHINES WITH SN STARTING WITH B3) (660SJ)​
FIGURE 6-9. LIFT CYLINDER ASSEMBLY - JIB (1K63FT MACHINES) (660SJ)​
FIGURE 6-10. STEER CYLINDER ASSEMBLY​
FIGURE 6-11. TELESCOPE CYLINDER ASSEMBLY (STANDARD)​
FIGURE 6-12. TELESCOPE CYLINDER ASSEMBLY - CHINESE SPEC ONLY​
FIGURE 6-13. TELESCOPE CYLINDER ASSEMBLY (1K63FT MACHINES) (660SJ)​
SECTION 7 - HYDRAULIC
FIGURE 7-1. DRIVE HYDRAULIC DIAGRAM (2WS WITHOUT ARCTIC PACKAGE)​
FIGURE 7-2. DRIVE HYDRAULIC DIAGRAM (2WS WITH ARCTIC PACKAGE)​
FIGURE 7-3. DRIVE HYDRAULIC DIAGRAM (4WS)​
FIGURE 7-4. STANDARD HYDRAULIC DIAGRAM (2WS) (600S)​
FIGURE 7-5. STANDARD HYDRAULIC DIAGRAM (4WS) (600S)​
FIGURE 7-6. STANDARD HYDRAULIC DIAGRAM (2WS) (600S)​
FIGURE 7-7. STANDARD HYDRAULIC DIAGRAM (4WS) (600S)​
FIGURE 7-8. STANDARD HYDRAULIC DIAGRAM (2WS) (660SJ)​
FIGURE 7-9. STANDARD HYDRAULIC DIAGRAM (4WS) (660SJ)​
FIGURE 7-10. STANDARD HYDRAULIC DIAGRAM (2WS) (660SJ)​
FIGURE 7-11. STANDARD HYDRAULIC DIAGRAM (4WS) (660SJ)​
FIGURE 7-12. TOW HYDRAULIC DIAGRAM​
SECTION 8 - ELECTRICAL
FIGURE 8-1. ELECTRICAL LAYOUT​
FIGURE 8-2. AC BOX AT PLATFORM INSTALLATION - 110V (ALL SPECS EXCEPT AUSTRALIAN, CE & UK CA SPECS)​
FIGURE 8-3. AC BOX AT PLATFORM INSTALLATION - 110V IEC YELLOW (CE & UK CA SPECS WITHOUT 4000W/50HZ GENERATOR)​
FIGURE 8-4. AC BOX AT PLATFORM INSTALLATION - 110V IEC YELLOW (CE & UK CA SPECS WITH 4000W/50HZ GENERATOR)​
FIGURE 8-5. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE (CE & UK CA SPECS WITHOUT 4000W/50HZ GENERATOR)​
FIGURE 8-6. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE (CE & UK CA SPECS WITH 4000W/50HZ GENERATOR)​
FIGURE 8-7. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 2IN X 4IN POST GROUND (CE & UK CA SPECS WITHOUT 4000W/50HZ GENERATOR)​
FIGURE 8-8. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 2IN X 4IN POST GROUND (CE & UK CA SPECS WITH 4000W/50HZ GENERATOR)​
FIGURE 8-9. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 2IN X 4IN SIDE GROUND (CE & UK CA SPECS WITHOUT 4000W/50HZ GENERATOR)​
FIGURE 8-10. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 2IN X 4IN SIDE GROUND (CE & UK CA SPECS WITH 4000W/50HZ GENERATOR)​
FIGURE 8-11. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT107 (CE & UK CA SPECS WITHOUT 4000W/50HZ GENERATOR)​
FIGURE 8-12. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT107 (CE & UK CA SPECS WITH 4000W/50HZ GENERATOR)​
FIGURE 8-13. AC BOX AT PLATFORM INSTALLATION - 220V CUSTOMER SUPPLIED COMPONENTS (ANSI EXPORT, AUSTRALIAN, CHINA, CE & UK CA SPECS)​
FIGURE 8-14. AC BOX AT PLATFORM INSTALLATION - 240V (WITH 4000W GENERATOR) (ALL SPECS EXCEPT AUSTRALIAN, CE & UK CA SPECS)​
FIGURE 8-15. AC BOX AT PLATFORM INSTALLATION - 240V (WITH 7500W SKYPOWER GENERATOR) (ALL SPECS EXCEPT AUSTRALIAN, CE & UK CA SPECS)​
FIGURE 8-16. AC BREAKER BOX INSTALLATION - SINGLE DOUBLE POLE BREAKER​
FIGURE 8-17. AC BREAKER BOX INSTALLATION - SINGLE DOUBLE POLE BREAKER (MACHINES WITH SN STARTING WITH B3)​
FIGURE 8-18. AC BREAKER BOX INSTALLATION - 3 BREAKERS​
FIGURE 8-19. AC CABLES AND CLAMPS INSTALLATION - WITHOUT GENERATOR (ANSI, CSA AND JAPANESE SPECS) (600S)​
FIGURE 8-20. AC CABLES AND CLAMPS INSTALLATION - WITHOUT GENERATOR (ANSI EXPORT, CE & UK CA SPECS) (600S)​
FIGURE 8-21. AC CABLES AND CLAMPS INSTALLATION - WITH 2500W GENERATOR (ALL SPECS EXCEPT AUSTRALIAN, CE & UK CA SPECS) (600S)​
FIGURE 8-22. AC CABLES AND CLAMPS INSTALLATION - WITH 4000W/50HZ GENERATOR (ANSI EXPORT, CE & UK CA SPECS) (600S)​
FIGURE 8-23. AC CABLES AND CLAMPS INSTALLATION - WITH 4000W/60HZ GENERATOR (ALL SPECS EXCEPT AUSTRALIAN, CE & UK CA SPECS) (600S)​
FIGURE 8-24. AC CABLES AND CLAMPS INSTALLATION - WITH 7500W SKYPOWER GENERATOR (600S)​
FIGURE 8-25. AC CABLES AND CLAMPS INSTALLATION - STANDARD WITHOUT GENERATOR (ANSI, CSA AND JAPANESE SPECS) (660SJ)​
FIGURE 8-26. AC CABLES AND CLAMPS INSTALLATION - STANDARD WITHOUT GENERATOR (ANSI EXPORT, AUSTRALIAN, CHINESE & UK CA SPECS) (660SJ)​
FIGURE 8-27. AC CABLES AND CLAMPS INSTALLATION - STANDARD WITH 2500W GENERATOR (ALL SPECS EXCEPT CE, AUSTRALIAN, CHINESE & UK CA SPECS) (660SJ)​
FIGURE 8-28. AC CABLES AND CLAMPS INSTALLATION - WITH 4000W/50HZ GENERATOR (ANSI EXPORT, AUSTRALIAN, CE & UK CA SPECS) (660SJ)​
FIGURE 8-29. AC CABLES AND CLAMPS INSTALLATION - STANDARD WITHOUT GENERATOR AND WITHOUT AC CABLES (MACHINES WITH SN STARTING WITH B3) (660SJ)​
FIGURE 8-30. AC CABLES AND CLAMPS INSTALLATION - STANDARD WITH 4000W/60HZ GENERATOR (ALL SPECS EXCEPT AUSTRALIAN, CHINA, CE & UK CA SPECS) (660SJ)​
FIGURE 8-31. AC CABLES AND CLAMPS INSTALLATION - WITH 7500W SKYPOWER GENERATOR (660SJ)​
FIGURE 8-32. AC CABLES AND CLAMPS INSTALLATION - 1K63FT MACHINES WITHOUT GENERATOR (ANSI AND CSA SPECS) (660SJ)​
FIGURE 8-33. AC CABLES AND CLAMPS INSTALLATION - 1K63FT MACHINES WITH 4000W/60HZ GENERATOR (ANSI AND CSA SPECS) (660SJ)​
FIGURE 8-34. AC CABLES AND CLAMPS INSTALLATION - 1K63FT MACHINES WITH 7500W GENERATOR (ANSI AND CSA SPECS) (660SJ)​
FIGURE 8-35. AC PLUG WITH AC CABLES INSTALLATION (MACHINES WITH SN STARTING WITH B3)​
FIGURE 8-36. BATTERY DISCONNECT SWITCH INSTALLATION​
FIGURE 8-37. BREAKER BOX KIT - SINGLE DOUBLE POLE BREAKER (WITHOUT 4000W/50HZ GENERATOR)​
FIGURE 8-38. BREAKER BOX KIT - SINGLE DOUBLE POLE BREAKER (WITH 4000W/50HZ GENERATOR)​
FIGURE 8-39. BREAKER BOX KIT - 3 BREAKERS​
FIGURE 8-40. BOOM SENSOR ASSEMBLY - LOWER (STANDARD)​
FIGURE 8-41. BOOM SENSOR ASSEMBLY - UPPER​
FIGURE 8-42. BOOM ANGLE SENSOR HARNESS (STANDARD)​
FIGURE 8-43. BOOM SENSOR HARNESS - 1K63FT MACHINES (660SJ)​
FIGURE 8-44. BOOM SENSOR ASSEMBLY - LOWER (1K63FT MACHINES) (660SJ)​
FIGURE 8-45. BOOM CABLE - LOWER​
FIGURE 8-46. BOOM CABLE - UPPER (600S)​
FIGURE 8-47. BOOM CABLE - UPPER (660SJ)​
FIGURE 8-48. BREAKER BOX KIT​
FIGURE 8-49. CAPACITY PROXIMITY HARNESS​
FIGURE 8-50. CAPACITY PROXIMITY HARNESS​
FIGURE 8-51. CAPACITY PROXIMITY EXTENSION HARNESS (1K63FT MACHINES) (660SJ)​
FIGURE 8-52. CLEARSKY CS550 BEACON INSTALLATION - WITH METAL HOOD​
FIGURE 8-53. CLEARSKY CS550 BEACON INSTALLATION - WITH PLASTIC HOOD​
FIGURE 8-54. ECU POWER JUMPER HARNESS​
FIGURE 8-55. ELECTRICAL COMPONENTS INSTALLATION - WITH 2WS (600S) (Prior to SN B300024404, Prior to SN 0300313003, Except SN 0300310881 through 0300310884)​
FIGURE 8-56. ELECTRICAL COMPONENTS INSTALLATION - WITH 2WS (SN B300024404 to Present, SN 0300313003 to Present, SN 0300310881 through 0300310884)​
FIGURE 8-57. ELECTRICAL COMPONENTS INSTALLATION - WITH 2WS AND DEUTZ TD2.2L3 (STAGE V) ENGINE (600S) (Prior to SN B300024404, Prior to SN 0300313003, Except SN 0300310881 through 0300310884)​
FIGURE 8-58. ELECTRICAL COMPONENTS INSTALLATION - WITH 2WS AND DEUTZ TD2.2L3 (STAGE V) ENGINE (SN B300024404 to Present, SN 0300313003 to Present, SN 0300310881 through 0300310884)​
FIGURE 8-59. ELECTRICAL COMPONENTS INSTALLATION - WITH 4WS (600S) (Prior to SN B300024404, Prior to SN 0300313003, Except SN 0300310881 through 0300310884)​
FIGURE 8-60. ELECTRICAL COMPONENTS INSTALLATION - WITH 4WS (SN B300024404 to Present, SN 0300313003 to Present, SN 0300310881 through 0300310884)​
FIGURE 8-61. ELECTRICAL COMPONENTS INSTALLATION - WITH 4WS AND DEUTZ TD2.2L3 (STAGE V) ENGINE (600S) (Prior to SN B300024404, Prior to SN 0300313003, Except SN 0300310881 through 0300310884)​
FIGURE 8-62. ELECTRICAL COMPONENTS INSTALLATION - WITH 4WS AND DEUTZ TD2.2L3 (STAGE V) ENGINE (SN B300024404 to Present, SN 0300313003 to Present, SN 0300310881 through 0300310884)​
FIGURE 8-63. ELECTRICAL COMPONENTS INSTALLATION - STANDARD WITH 2WS (660SJ) (Prior to SN B300024404, Prior to SN 0300313003, Except SN 0300310881 through 0300310884)​
FIGURE 8-64. ELECTRICAL COMPONENTS INSTALLATION - STANDARD WITH 2WS (SN B300024404 to Present, SN 0300313003 to Present, SN 0300310881 through 0300310884)​
FIGURE 8-65. ELECTRICAL COMPONENTS INSTALLATION - STANDARD WITH 2WS AND DEUTZ TD2.2L3 (STAGE V) ENGINE (660SJ) (Prior to SN B300024404, Prior to SN 0300313003, Except SN 0300310881 through 0300310884)​
FIGURE 8-66. ELECTRICAL COMPONENTS INSTALLATION - STANDARD WITH 2WS AND DEUTZ TD2.2L3 (STAGE V) ENGINE (SN B300024404 to Present, SN 0300313003 to Present, SN 0300310881 through 0300310884)​
FIGURE 8-67. ELECTRICAL COMPONENTS INSTALLATION - STANDARD WITH 4WS (660SJ) (Prior to SN B300024404, Prior to SN 0300313003, Except SN 0300310881 through 0300310884)​
FIGURE 8-68. ELECTRICAL COMPONENTS INSTALLATION - STANDARD WITH 4WS (SN B300024404 to Present, SN 0300313003 to Present, SN 0300310881 through 0300310884)​
FIGURE 8-69. ELECTRICAL COMPONENTS INSTALLATION - STANDARD WITH 4WS AND DEUTZ TD2.2L3 (STAGE V) ENGINE (660SJ) (Prior to SN B300024404, Prior to SN 0300313003, Except SN 0300310881 through 0300310884)​
FIGURE 8-70. ELECTRICAL COMPONENTS INSTALLATION - STANDARD WITH 4WS AND DEUTZ TD2.2L3 (STAGE V) ENGINE (SN B300024404 to Present, SN 0300313003 to Present, SN 0300310881 through 0300310884)​
FIGURE 8-71. ELECTRICAL COMPONENTS INSTALLATION - 1K63FT MACHINES WITH 2WS (660SJ)​
FIGURE 8-72. ELECTRICAL COMPONENTS INSTALLATION - 1K63FT MACHINES WITH 4WS (660SJ)​
FIGURE 8-73. ELECTRICAL COMPONENTS INSTALLATION - 1K63FT MACHINES WITH 2WS (660SJ)​
FIGURE 8-74. ENGINE HARNESS - DEUTZ D2011 ENGINES​
FIGURE 8-75. ENGINE HARNESS - DEUTZ TD2.2L3 (STAGE V) ENGINE​
FIGURE 8-76. ENGINE HARNESS - DEUTZ D2.9L4 - 49HP AND DEUTZ TD2.9L4 - 67HP ENGINES​
FIGURE 8-77. ENGINE HARNESS - DEUTZ TD2.9L4 (EMR ENGINE)​
FIGURE 8-78. ENGINE HARNESS - DEUTZ D2.9 (CHINA IV) ENGINES​
FIGURE 8-79. ENGINE HARNESS - FORD ENGINES​
FIGURE 8-80. FUEL HARNESS - DEUTZ TD2.2L3 (STAGE V) ENGINE​
FIGURE 8-81. FUEL PUMP HARNESS - DEUTZ D2.9L4 - 49HP, DEUTZ TD2.9L4 - 67HP AND DEUTZ TD2.2L3 (STAGE V) ENGINES​
FIGURE 8-82. GENERATOR HARNESS - 2500W​
FIGURE 8-83. GENERATOR HARNESS - 4000W​
FIGURE 8-84. GENERATOR HARNESS - 7500W SKYPOWER​
FIGURE 8-85. GENERATOR TO ENGINE HARNESS - 7500W SKYPOWER GENERATOR (DEUTZ D2011 ONLY)​
FIGURE 8-86. GROUND CONTROL HARNESS (Prior to SN B300024404, Prior to SN 0300313003, Except SN 0300310881 through 0300310884)​
FIGURE 8-87. GROUND CONTROL HARNESS (SN B300024404 to Present, SN 0300313003 to Present, SN 0300310881 through 0300310884)​
FIGURE 8-88. HOUR METER JUMPER HARNESS​
FIGURE 8-89. LIFT CYLINDER HARNESS​
FIGURE 8-90. PLATFORM BOX HARNESS​
FIGURE 8-91. RECEPTACLE BOX KIT - 110V IEC YELLOW (CE & UK CA SPEC)​
FIGURE 8-92. RECEPTACLE BOX KIT - 220V IEC BLUE (CE & UK CA SPEC)​
FIGURE 8-93. RECEPTACLE BOX KIT - 220V CEE7 POST GROUND 2X4 BOX (CE & UK CA SPEC)​
FIGURE 8-94. RECEPTACLE BOX KIT - 220V CEE7 SIDE GROUND (CE & UK CA SPEC)​
FIGURE 8-95. RECEPTACLE BOX KIT - 220V AFSINT 107 (CE & UK CA SPEC)​
FIGURE 8-96. RELAY & FUEL PUMP HARNESS​
FIGURE 8-97. SKYEYE EMITTER HARNESS​
FIGURE 8-98. SKYEYE INTERMEDIATE HARNESS​
FIGURE 8-99. SKYEYE RECEIVER HARNESS​
FIGURE 8-100. SKYGUARD INTERFACE HARNESS​
FIGURE 8-101. SKYLINE HARNESS​
FIGURE 8-102. TELE PROXIMITY HARNESS​
FIGURE 8-103. TURNTABLE HARNESS​
FIGURE 8-104. VALVE HARNESS - MAIN CONTROL (2WS) (Prior to SN B300025432, Prior to SN 0300315421, Except SN B300025343 through B300025344, Except SN 0300315393 through 0300315404, Except SN 0300315407 through 0300315408, Excluding 0300315417)​
FIGURE 8-105. VALVE HARNESS - MAIN CONTROL (2WS) (SN B300025432 to Present, SN B300025343 through B300025344, SN 0300315421 to Present, SN 0300315393 through 0300315404, SN 0300315407 through 0300315408, Including 0300315417)​
FIGURE 8-106. VALVE HARNESS - MAIN CONTROL (4WS) (Prior to SN B300025432, Prior to SN 0300315421, Except SN B300025343 through B300025344, Except SN 0300315393 through 0300315404, Except SN 0300315407 through 0300315408, Excluding 0300315417)​
FIGURE 8-107. VALVE HARNESS - MAIN CONTROL (4WS) (SN B300025432 to Present, SN B300025343 through B300025344, SN 0300315421 to Present, SN 0300315393 through 0300315404, SN 0300315407 through 0300315408, Including 0300315417)​
FIGURE 8-108. VALVE HARNESS - PLATFORM (600S)​
FIGURE 8-109. VALVE HARNESS - PLATFORM (A92.5) (660SJ)​
FIGURE 8-110. VALVE HARNESS - PLATFORM (A92.20) (660SJ)​
FIGURE 8-111. WHITE NOISE ALARM HARNESS​
SECTION 9 - DECALS
FIGURE 9-1. DECAL INSTALLATION - (ANSI SPECS - ENGLISH LANGUAGE) (600S)​
FIGURE 9-2. DECAL INSTALLATION - (BRAZIL SPECS - PORTUGUESE/SPANISH LANGUAGES) (600S)​
FIGURE 9-3. DECAL INSTALLATION - (CE & UK CA SPECS - ENGLISH LANGUAGE) (600S)​
FIGURE 9-4. DECAL INSTALLATION - (CHINESE SPECS - ENGLISH/SIMPLIFIED CHINESE LANGUAGES) (600S)​
FIGURE 9-5. DECAL INSTALLATION - (CHINESE SPECS - ENGLISH/TRADITIONAL CHINESE LANGUAGES) (600S)​
FIGURE 9-6. DECAL INSTALLATION - (CSA SPECS - ENGLISH/FRENCH LANGUAGES) (600S)​
FIGURE 9-7. DECAL INSTALLATION - (JAPANESE SPECS - ENGLISH/JAPANESE LANGUAGES) (600S)​
FIGURE 9-8. DECAL INSTALLATION - (KOREAN SPECS - ENGLISH/KOREAN LANGUAGES) (600S)​
FIGURE 9-9. DECAL INSTALLATION - (LATIN AMERICAN SPECS - ENGLISH/SPANISH LANGUAGES) (600S)​
FIGURE 9-10. DECAL INSTALLATION - STANDARD (ANSI SPECS - ENGLISH LANGUAGE) (660SJ)​
FIGURE 9-11. DECAL INSTALLATION - 1K63FT MACHINES (ANSI & CSA SPECS - ENGLISH LANGUAGE) (660SJ)​
FIGURE 9-12. DECAL INSTALLATION - (AUSTRALIAN SPECS - ENGLISH LANGUAGE) (660SJ)​
FIGURE 9-13. DECAL INSTALLATION - (BRAZIL SPECS - PORTUGUESE/SPANISH LANGUAGES) (660SJ)​
FIGURE 9-14. DECAL INSTALLATION - (CE & UK CA SPECS - ENGLISH LANGUAGE) (660SJ)​
FIGURE 9-15. DECAL INSTALLATION - (CHINESE SPECS - ENGLISH/SIMPLIFIED CHINESE LANGUAGES) (660SJ)​
FIGURE 9-16. DECAL INSTALLATION - (CHINESE SPECS - ENGLISH/TRADITIONAL CHINESE LANGUAGES) (660SJ)​
FIGURE 9-17. DECAL INSTALLATION - STANDARD (CSA SPECS - ENGLISH/FRENCH LANGUAGES) (660SJ)​
FIGURE 9-18. DECAL INSTALLATION - 1K63FT MACHINES (CSA SPECS - ENGLISH/FRENCH LANGUAGES) (660SJ)​
FIGURE 9-19. DECAL INSTALLATION - (JAPANESE SPECS - ENGLISH/JAPANESE LANGUAGES) (660SJ)​
FIGURE 9-20. DECAL INSTALLATION - (KOREAN SPECS - ENGLISH/KOREAN LANGUAGES) (660SJ)​
FIGURE 9-21. DECAL INSTALLATION - (LATIN AMERICAN SPECS - ENGLISH/SPANISH LANGUAGES) (660SJ)​
FIGURE 9-22. DECALS INSTALLATION - OPTIONS​
FIGURE 9-23. DECAL INSTALLATION - SOFT-TOUCH (ANSI, ANSI EXPORT & CSA SPECS) (600S)​
FIGURE 9-24. DECAL INSTALLATION - SOFT-TOUCH (CE & UK CA SPECS) (600S)​
FIGURE 9-25. DECAL INSTALLATION - SOFT-TOUCH (ANSI, ANSI EXPORT, CHINA & CSA SPECS) (660SJ)​
FIGURE 9-26. DECAL INSTALLATION - SOFT-TOUCH (CE & UK CA SPECS) (660SJ)​
FIGURE 9-27. DECAL INSTALLATION - SKYWELDER (50HZ)​
FIGURE 9-28. DECAL INSTALLATION - SKYWELDER (60HZ)​
FIGURE 9-29. DECAL INSTALLATION - TOW (ANSI SPECS)​
FIGURE 9-30. DECAL INSTALLATION - TOW (ANSI EXPORT, CHINA, CE & UK CA SPECS)​
FIGURE 9-31. DECAL INSTALLATION - TOW (CSA SPECS)​
SECTION 11 - SPECIAL OPTIONS/ACCESSORIES/KITS
PART NUMBER INDEX
