JLG Boom Lift 600AJ Service & Maintenance Manual 3122561300 2026
Brand: JLG
Type of Machine: Boom Lift
Model: JLG 600AJ Boom Lift
Part Number: 3122561300
Publication Date: 2026
Number of Pages: 906 Pages
Safety
Brand: JLG
Safety
General
1.1.1 Disclaimer
1.1.2 Operation & Safety Manual
Safety Information
1.2.1 Safety Alert System and Signal Words
Safety Hazards
1.3.1 Personal Hazards
1.3.2 Equipment Hazards
1.3.3 General Hazards
1.3.4 Operational Hazards
Safety Decals
Machine Verification
General Machine Information and SpecificationsSpecifications
2.1.1 Machine Specifications
2.1.2 Machine Dimensional Data
2.1.3 Engine Data
2.1.4 Tires
2.1.5 Critical Stability Weights
2.1.6 Torque Requirements
Machine Temperature Chart
Serial Number Location
Fluids and Lubrication
2.4.1 General Information
2.4.2 Hydraulic Oil
2.4.3 Changing Hydraulic Oil
2.4.4 Lubrication Specifications
2.4.5 Fluids
2.4.6 Capacities
2.4.7 Lubrication Schedule
Machine Characteristics
2.5.1 Ground Control Keyswitch System
2.5.2 Platform Control Enable System
2.5.3 Cold Start System (Diesel)
2.5.4 Fuel level Cutout System
2.5.5 HRC Engine Emission Characteristics
2.5.6 Diesel Particulate Filter (If Equipped)
2.5.7 Drive System
2.5.8 Drive Orientation System
2.5.9 Function Speed Control System
2.5.10 Oscillating Axle System
2.5.11 Chassis Tilt Indicator System
2.5.12 Platform Load Sensing System (LSS)
2.5.13 Auxiliary Power System
2.5.14 ClearSky™ System Ready
2.5.15 Tires and Counterweight
2.5.16 Platform
2.5.17 Transport Position Sensing System
2.5.18 Beyond Transport - Drive Speed Cutback System
2.5.19 Drive/Steer – Boom Function Interlock System
2.5.20 Ground Panel Display
Clearsky Smart Fleet (If Equipped)
2.6.1 General
2.6.2 ClearSky Smart Fleet™ — Access Control
Maintenance and Inspection SchedulesMachine Preparation, Inspection, and Maintenance
3.1.1 General
3.1.2 Preparation, Inspection, and Maintenance
3.1.3 Pre-Start Inspection
3.1.4 Pre-Delivery Inspection and Frequent Inspection
3.1.5 Annual Machine Inspection
3.1.6 Preventive Maintenance
Service and Guidelines
3.2.1 General
3.2.2 Safety and Workmanship
3.2.3 Cleanliness
3.2.4 Components Removal and Installation
3.2.5 Component Disassembly and Reassembly
3.2.6 Pressure-Fit Parts
3.2.7 Bearings
3.2.8 Gaskets
3.2.9 Bolt Usage and Torque Application
3.2.10 Hydraulic Lines and Electrical Wiring
3.2.11 Hydraulic System
3.2.12 Lubrication
3.2.13 Battery
3.2.14 Welding on JLG Equipment
Preventive Maintenance and Inspection Schedule
3.3.1 Daily
3.3.2 First 50 Hours
3.3.3 Every 150 Hours or 3 Months
3.3.4 First 300 Hours or 6 Months
3.3.5 Every 600 Hours or 1 Year
3.3.6 Every 1200 Hours or 1 Year
3.3.7 Every 1200 Hours or 2 Years
Pins and Composite Bearing Repair Guidelines
Tires and Wheels
3.5.1 Tire Inflation
3.5.2 Tire Damage
Fuel Tank Inspection
Boom Inspection and Maintenance
3.7.1 Boom Cleanliness Guidelines
3.7.2 Boom Wear Pad Inspection
Hydraulic Filter Replacement
Turntable Bearing Inspection
3.9.1 Turntable Bearing Mounting Bolt Condition Check
3.9.2 Wear Tolerance
Engine General Inspection
3.10.1 General Maintenance
3.10.2 Checking Oil Level
3.10.3 Changing Engine Oil
3.10.4 Replacing the Oil Filter
3.10.5 Replacing the Primary Fuel Filters
3.10.6 Replacing the Fuel Pre-Filter
3.10.7 Replacing the Auxiliary Fuel Filter For Deutz D2011L04 T4I (Only)
3.10.8 Spark Arrester Cleaning Instructions For Deutz D2011L04 T4I (Only)
3.10.9 Replacing the Fuel Strainer For Deutz D2011L04 T4I (Only)
Bio Fuel In Deutz Engines
3.11.1 General
3.11.2 Bio Fuel
3.11.3 Biological Contamination In Fuels
Deutz EMR2
Deutz EMR4
Deutz EMR5
Generator Inspection
3.15.1 2500W Generator
3.15.2 4000W Generator
3.15.3 7500W Generator
Testing, Calibrations and Special ProceduresSpecial Tools
4.1.1 Multimeter Basics
4.1.2 Threadlocking Compound
4.1.3 Tools Catalog
Testing Procedures
4.2.1 Starter
4.2.2 SkyGuard
4.2.3 LSS Testing and Evaluation
Calibration Procedures
4.3.1 JLG Analyzer
4.3.2 Calibration Preparation
4.3.3 Load Sensing System Calibration
Special Procedures
4.4.1 Fuel Tank Cleaning and Drying
4.4.2 Cylinder Checking Procedure
4.4.3 Cylinder Drift
4.4.4 Hydraulic Circuits
4.4.5 Free Wheeling Option
4.4.6 Oscillating Axle Bleeding Procedure and Lockout Test
Wheel Drive Hub
4.5.1 Oil Information
4.5.2 Roll and Leak Testing
4.5.3 Tightening and Torquing Bolts
Swing Drive
4.6.1 Roll, Leak and Brake Testing
4.6.2 Tightening and Torquing Bolts
System SoftwareLoad Sensing System (LSS)
5.1.1 Theory of Operation
5.1.2 Load Sensing Gauge Removal/ Installation
JLG Analyzer
5.2.1 Machine Data Access
5.2.2 Hand Held Analyzer
5.2.3 Mobile Analyzer
5.2.4 Analyzer Flow Chart
Analyzer Software Accessibility
5.3.1 Access Level
5.3.2 Diagnostic
5.3.3 Machine Configuration Programming Information
5.3.4 Personalities
5.3.5 Operator Tools
5.3.6 Calibrations
Function Test
5.4.1 Test Notes
CANBUS Communications
ClearSky (CS550) Configuration and Troubleshooting
5.6.1 ClearSky Smart FleetTM CS550 Configuration
5.6.2 Troubleshooting
Fault CodesFault Codes Introduction
Engine Diagnostic
6.2.1 Deutz TD2.9L4 (T4F)/D2.9L4 (T4F)
6.2.2 Deutz TD2.2L3 (Stage V)/D2.9L4 China IV Engines
6.2.3 Deutz D2011L04 Engine Trouble Codes
6.2.4 Ford Engine Trouble Codes
Machine Fault Codes
6.3.1 General
6.3.2 ClearSky Smart Fleet DTC Fault Codes
6.3.3 LSS Troubleshooting
ClearSky CS550 Troubleshooting Procedures
Machine Diagnostics Parameters
Deutz EMR Fault codes
6.6.1 EMR2 Fault Codes
6.6.2 EMR4 Fault Codes
6.6.3 EMR5 Fault Codes
HydraulicsGeneral Information and Safety
Theories of Operation
7.2.1 Cylinders
7.2.2 Valves
Hydraulic Components
7.3.1 Hydraulic Oil Tank
7.3.2 Hydraulic Component Start-Up
7.3.3 Hydraulic Pump Pre-Fill Procedures
7.3.4 Main Valve Block Pressure Settings
7.3.5 Platform Valve Block Pressure Settings
Torque Values
7.4.1 Cylinder Torque Specifications
7.4.2 Valve Torque Specification
Standard Hydraulic Diagram - Boom And Turntable
7.5.1 Deutz T4i
7.5.2 Deutz T4F/TD2.2L3 Stage V/D2.9L4 China IV
7.5.3 Ford DF
Hydraulic Diagram - Chassis
7.6.1 2WD 2WS
7.6.2 2WD 4WS
7.6.3 4WD 2WS
7.6.4 4WD 4WS
ElectricalsGeneral Information
8.1.1 Applying Silicone Dielectric Compound to Electrical Connections
8.1.2 Dielectric Grease Application
Electrical Connectors
8.2.1 Deutsch Connectors
Electrical Component Terminology
Harness Layouts
8.4.1 Turntable Harness
8.4.2 Turntable Component
8.4.3 Engine Deutz 2.9L4
8.4.4 Boom
8.4.5 Platform
8.4.6 Controls
Board Layouts
8.5.1 Ground Control Module Pin Connections
8.5.2 Platform Control Module Pin Connections
AMP Connector
8.6.1 Assembly
8.6.2 Disassembly
8.6.3 Wedge Lock
8.6.4 Service - Voltage Reading
Wiring Harness and Connector Label Diagrams
8.7.1 Connector Labels
8.7.2 Component Labels
Telematic Gateway
8.8.1 Telematics-Ready (TCU) Plug
Removal and InstallationWheel and Tire
Chassis/Frame Assembly
9.2.1 Axle and Drive Assemblies Troubleshooting
9.2.2 Front and Rear Axle System
9.2.3 Drive Hub and Motor
9.2.4 Knuckle Assembly
Boom
9.3.1 Boom Components Terminology
9.3.2 Troubleshooting
9.3.3 Main Boom Powertrack
9.3.4 Main Boom Assembly
9.3.5 Upright
9.3.6 Tower Boom Assembly
9.3.7 Jib and Platform Rotate Actuator
Platform
9.4.1 Platform (Rapid Replaceable Platform)
9.4.2 Platform Support (Traditional Design)
9.4.3 Platform Support (Rapid Replaceable Platform)
9.4.4 Bolt-On External Fall Arrest
9.5.1 Component Terminology
9.5.2 Engine Serial Number
9.5.3 Engine Replacement
9.5.4 Surge Tank (Deutz TD2.9L4 T4F/D2.9L4 T4F/D2.9L4 China IV/TD2.2L3 Stage V)
9.5.5 Pump Coupling Kit
9.5.6 Air Filter Assembly
9.5.7 Radiator Assembly
9.5.8 Thermostat
9.5.9 Coolant Temperature Sensor
9.5.10 Relay Assembly
9.5.11 Starter
9.5.12 Alternator
9.5.13 Fuel Tank
9.5.14 Pre- Fuel Filter and Fuel Pump
Hydraulic Cylinders
9.7.1 Main Boom Lift Cylinder
9.7.2 Main Boom Telescope Cylinder
9.7.3 Upright Level Cylinder
9.7.4 Tower Boom Lift Cylinder
9.7.5 Tower Telescope Cylinder
9.7.6 Steer Cylinder
Hydraulic Valves
Hydraulic Pumps
9.9.1 Function Pump Assembly
9.9.2 Drive Pump Assembly
Electrical Components
9.10.1 Battery
Turntable
9.11.1 Swing Drive
9.11.2 Swing Bearing
Generator and Pulley
9.12.1 Generator and Pulley (4000W Deutz Stage V TD 2.2)
9.12.2 Generator and Pulley (2500W Deutz D2011)
9.12.3 Generator and Pulley (7500W Deutz D2011)
9.12.4 Generator and Pulley (7500W and 4000W Deutz T4F)
9.12.5 Generator and Pulley (4000W Deutz D2011)
9.12.6 Generator and Pulley (2500W Deutz T4F)
9.12.7 Generator and Pulley (7500W Ford DF 2.5L)
9.12.8 Generator and Pulley (2500W Ford DF 2.5L)
ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)
9.13.1 ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)
Disassembly and AssemblyDrive Assembly
10.1.1 Drive Motor (2WD/2WS)
10.1.2 Drive Motor (4WD/4WS)
Boom and Jib Assembly
10.2.1 Main Boom
10.2.2 Tower Boom
10.2.3 Jib
10.2.4 Helac Rotary Actuator
10.2.5 Platform Rotate Actuator
Platform
Engine Components
10.4.1 Engine Disassembly, Inspection and Service
10.4.2 Fuel Tank
Pumps
10.5.1 Gear Pump Disassembly
10.5.2 Variable Pump
10.5.3 Charge Pump Disassembly
Hydraulic Cylinders
10.6.1 Tower Boom Lift Cylinder
10.6.2 Upright Level Cylinder
10.6.3 Master Cylinder
10.6.4 Main Boom Lift Cylinder
10.6.5 Main Boom Telescope Cylinder
10.6.6 Tower Boom Telescope Cylinder
10.6.7 Platform Level Cylinder
10.6.8 Jib Lift Cylinder (US Market)
10.6.9 Jib Lift Cylinder (China Market)
10.6.10 Steer Cylinder
10.6.11 Axle Lockout Cylinder
Hydraulic Valves
10.8.1 Hydraulic Oil Tank
Turntable
10.9.1 Swing Motor
10.9.2 Rotary Coupling Seal Kit
Generator Disassembly and Assembly
10.10.1 7500W Generator
10.10.2 4000W Generator
Powertrack
10.11.1 Remove Link
10.11.2 Install New Link
10.11.3 Replace Fixed End Brackets
10.11.4 Replace Moving End Brackets
Torque/Connection InformationHydraulic Fittings
11.1.1 Tapered Thread Types
11.1.2 Straight Thread Types, Tube and Hose Connections
11.1.3 Straight Thread Types, Port Connections
11.1.4 Flange Connection Types
11.1.5 Tightening Methods
11.1.6 Assembly and Torque Specifications
11.1.7 General Tube Type Fitting Assembly Instructions
11.1.8 Assembly Instructions for American Standard Pipe Thread Tapered Connections.
11.1.9 Assembly Instructions for British Standard Pipe Thread Tapered Connections
11.1.10 Assembly Instructions for 37° (JIC) Flare Fittings
11.1.11 Assembly Instructions for 45° SAE Flare Fittings
11.1.12 Assembly Instructions for O-Ring Face Seal (ORFS) Fittings
11.1.13 Assembly Instructions for DIN 24° Flare Bite Type Fittings (MBTL and MBTS)
11.1.14 Assembly Instructions for Bulkhead (BH) Fittings
11.1.15 Assembly Instructions for O-Ring Boss (ORB) Fittings
11.1.16 Assembly Instructions for Adjustable Port End Metric Fittings
11.1.17 Assembly Instructions for Metric ISO 6149 (MPP) Port Assembly Stud Ends
11.1.18 Assembly instructions for Adjustable Port End (BSPP) Fittings
11.1.19 Assembly Instructions for Flange Connections: (FL61 and FL62)
11.1.20 Double Wrench Method
11.1.21 FFWR and TFFT Methods
11.1.22 Adjustable Stud End Assembly
11.1.23 O-ring Installation (Replacement)
Torque Charts
11.2.1 SAE Fastener Torque Chart
11.2.2 Metric Fastener Torque Chart
SchematicsHydraulic Schematics
Electrical Schematics
Deutz EMR2 Schematics
12.3.1 Vehicle Side Connection Diagram
12.3.2 Engine Side Connection Diagram - Sheet 1 of 2
12.3.3 Engine Side Connection Diagram - Sheet 2 of 2
12.3.4 Engine Plug Pin
12.3.5 Vehicle Plug Pin Identification
Deutz EMR4 Schematics
12.4.1 Power Harness
12.4.2 Equipment Harness
12.4.3 D2.1 Engine Plug Pin Assignment
12.4.4 D2.2 Unit Plug Pin Assignment
Deutz EMR5 Schematics
12.5.1 Power Harness
12.5.2 Exhaust After Treatment Harness
12.5.3 Equipment Harness - Sheet 1 of 5
12.5.4 Equipment Harness - Sheet 2 of 5
12.5.5 Equipment Harness - Sheet 3 of 5
12.5.6 Equipment Harness - Sheet 4 of 5
12.5.7 Equipment Harness - Sheet 5 of 5
12.5.8 Engine Plug Pin Identification
12.5.9 Vehicle Plug Pin Identification
4000W Generator Schematic
12.6.1 Generator and Controller Circuit Diagram
12.6.2 Lead Connection List
7500W Generator Schematic
12.7.1 Troubleshooting Circuit Diagram
12.7.2 Generator and Controller Circuit Diagram
12.7.3 Power Board PC1 Circuit Diagram
12.7.4 Power Board PC2 Electrical Circuit Diagram
12.7.5 Lead Connection List
- SuperPac Parts Manual
- StratoLift Parts Manual
