Hyundai
86
176,834
JLG Boom Lift 600AJ Operation Safety Manual 31223023
Brand: JLG
Type of Machine: Boom Lift
Type of Manual: Operation Safety Manual
Model: JLG 600AJ Boom Lift
Part Number: 31223023
Publication Date: 2024
Number of Pages: 166 Pages
Cover - 600AJ - PVC 2401 - 31223023
Foreword
Revision Log - 600AJ - PVC 2401
Other Publications Available​
Safety Precautions
General​
Pre-Operation​
1.2.1 Operator Training and Knowledge​
1.2.2 Workplace Inspection​
1.2.3 Machine Inspection​
Operation​
1.3.1 General​
1.3.2 Trip and Fall Hazards​
1.3.3 Electrocution Hazards​
1.3.4 Tipping Hazards​
1.3.5 Crushing and Collision Hazards​
Towing, Lifting, and Hauling​
Maintenance​
1.5.1 Maintenance Hazards​
1.5.2 Battery Hazards​
User Responsibilities, Machine Preparation, and Inspection
Personnel Training​
2.1.1 Operator Training​
2.1.2 Training Supervision​
2.1.3 Operator Responsibility​
2.1.4 Machine Familiarization​
Preparation, Inspection and Maintenance​
Machine Components​
Pre-Start Inspection​
Walk-Around Inspection​
2.5.1 General​
Function Check - AJ Model​
SkyGuard® Function Check​
Machine Controls and Indicators
General​
Controls & Indicators​
Ground Control Station​
3.3.1 Ground Control Station Functions​
Ground Control Indicator Panel - ICE - Fuel Gauge​
3.4.1 Ground Control Indicator Panel Functions​
600AJ Platform Control Station​
3.5.1 Platform Control Station Functions​
Platform Indicator Panel - ICE - Fuel Gauge​
3.6.1 Platform Control Indicator Panel Functions​
Beacons (With SkyGuard)​
3.7.1 ClearSky® LED Motion / Amber Beacon (CS550)​
3.7.2 Amber Beacon​
3.7.3 Blue or Red SkyGuard® Beacon​
Machine Operation
General AJ 360 Continuous Swing​
Operating Characteristics And Limitations​
4.2.1 Operating Conditions​
4.2.2 Platform Load Sensing System (LSS)​
600AJ Stability​
Engine Operation​
4.4.1 Starting Procedure​
4.4.2 Shutdown Procedure​
Air Shutoff Valve (ASOV)​
Fuel Shutoff System (Reserve) - Fuel Gauge​
Diesel Particulate Filter (If Equipped)​
Traveling (Driving)​
4.8.1 Traveling Forward and Reverse​
600AJ Traveling (Grade/Side Slope)​
4.9.1 Traveling on a Grade​
Steering​
Platform - Standard Booms​
4.11.1 Platform Level Adjustment​
4.11.2 Platform Rotation​
Boom - AJ Models​
4.12.1 Swinging the Boom​
4.12.2 Raising and Lowering the Tower Boom​
4.12.3 Raising and Lowering the Main Boom​
4.12.4 Telescoping the Main Boom​
Re-Synchronize The Lower Lift Cylinder​
4.13.1 Level Override Valve​
4.13.2 Boom Upright Positioning​
Function Speed Control - AJ Core Boom​
USB Charging Port​
ClearSky Smart Fleet​
Access Control (Boom)​
Machine Safety System Override (MSSO) (If Equipped)​
SkyGuard Activation/Deactivation - AJ​
Shut Down And Park​
Oscillating Axle Lockout Test (If Equipped)​
Towing (If Equipped)​
Auxiliary Power - AJ​
4.23.1 Activating from the Platform Control Station​
4.23.2 Activating from the Ground Control Station​
Dual Fuel System (Gas Engine Only)​
4.24.1 Changing From Gasoline to LP Gas​
4.24.2 Changing From LP Gas to Gasoline​
Lifting And Tie Down​
4.25.1 Lifting​
4.25.2 Tie Down​
Lifting Chart - 600AJ​
600AJ Safety Decal Locations​
Emergency Procedures
General​
Incident Notification - Boom​
Emergency Operation​
5.3.1 Operator Unable to Control Machine​
5.3.2 Platform or Boom Caught Overhead​
Emergency Towing Procedures​
ClearSky Smart Fleet - Locked Out State​
Machine Safety System Override (MSSO)​
600AJ Accessory Table​
Bolt-On External Fall Arrest​
6.2.1 Inspection Before Use​
Cable Ladder Carrier​
Fabric Mesh to Mid/Top Rail​
Fall Arrest Platform​
6.5.1 Safety Precautions​
Pipe Racks​
6.6.1 Capacity Specifications (Australia Only)​
6.6.2 Safety Precautions​
6.6.3 Preparation and Inspection​
6.6.4 Operation​
Platform Mesh to Mid/Top Rail​
Platform Mid Rail Deck​
6.8.1 Accessory Installation​
6.8.2 Access to Manual Box​
Platform Top Rail Extension​
Platform Work Lights​
Platform Work Surface​
Portable Work Light​
Nite Bright​
SkyCutter​
6.14.1 Safety Precautions​
6.14.2 Generator Output​
6.14.3 Preparation and Inspection​
6.14.4 Operation​
6.14.5 Accessory Ratings​
SkyGlazier​
6.15.1 Capacity Specifications​
6.15.2 Safety Precautions​
6.15.3 Preparation and Inspection​
6.15.4 Operation​
SkyPower 7.5kW and Generator 4kW​
6.16.1 Output​
6.16.2 Safety Precautions​
6.16.3 Preparation and Inspection​
6.16.4 Operation​
SkySense​
6.17.1 Preparation and Inspection​
6.17.2 Operation​
6.17.3 SkySense Platform Panel Indicators​
6.17.4 SkySense Alarm​
6.17.5 SkySense Override Button​
6.17.6 SkySense Coverage Areas​
SkySense Platform Bumper Padding​
SkyWelder​
6.19.1 Operation​
6.19.2 Generator Output​
6.19.3 Welding Accessories​
6.19.4 Safety Precautions​
6.19.5 Preparation and Inspection​
Soft Touch​
General Specifications and Operator Maintenance
General​
Serial Number Location 600AJ​
600AJ Operating Specifications​
7.3.1 Dimensional Data​
7.3.2 Capacities​
7.3.3 Engine Data​
7.3.4 Tires​
Hydraulic Oil Specifications - Introduction​
Hydraulic Oil Operating Temperature - Deutz/Ford​
Engine Oil Operating Temp Spec - Introduction Note​
Engine Oil Operating Temp Spec - Deutz Engine​
Engine Oil Operating Temp Spec - Ford Engine​
Operator Maintenance and Lubrication Diagram 600AJ​
7.9.1 DEUTZ D2011L04​
7.9.2 Deutz TD 2.9L, 2.2L Stage V​
7.9.3 Ford DF 2.5L, MSG 425​
Operator Maintenance 600AJ​
Tires and Wheels - 9 Lug Nuts​
7.11.1 Tire Damage​
7.11.2 Tire Replacement​
7.11.3 Wheel Replacement​
7.11.4 Wheel Installation​
Propane Fuel Filter Replacement​
7.13.1 Removal​
7.13.2 Installation​
Propane Fuel System Pressure Relief​
Radio Frequency (RF) Information​
7.15.1 Federal Communications Commission (FCC)​
7.15.2 Innovation, Science and Economic Development (ISED)​
Supplemental Information Only Applicable to CE/UKCA​
EC Declaration of Conformity - 600AJ​
UKCA Declaration of Conformity - 600AJ​
