JLG Boom Lift 600AJ HC3 Parts Catalog 31223061
Brand: JLG
Type of Machine: Boom Lift
Model: JLG 600AJ HC3 Boom Lift
Part Number: 31223061
Publication Date: 2025
Number of Pages: 820 Pages
SECTION 1 - FRAME
Brand: JLG
SECTION 1 - FRAME
FIGURE 1-1. AXLE INSTALLATION (WITHOUT TOW PACKAGE)
FIGURE 1-2. AXLE INSTALLATION (WITH TOW PACKAGE)
FIGURE 1-3. STEERING INSTALLATION (WITHOUT TOW PACKAGE)
FIGURE 1-4. STEERING INSTALLATION (WITH TOW PACKAGE)
FIGURE 1-5. WHEEL DRIVE INSTALLATION - 4WD/2WS
FIGURE 1-6. DRIVE MOTOR ASSEMBLY
FIGURE 1-7. DRIVE HUB ASSEMBLY
FIGURE 1-8. FLOW DIVIDER ASSEMBLY
FIGURE 1-9. TIRE AND WHEEL INSTALLATION - FOAM FILLED
FIGURE 1-10. TIRE AND WHEEL INSTALLATION - FOAM FILLED NON-MARKING
FIGURE 1-11. TIRE AND WHEEL INSTALLATION - FOAM FILLED (TURF)
FIGURE 1-12. FRAME SHIELDS INSTALLATION – 2WS (8FT/2.4M WIDE MACHINES)
FIGURE 1-13. TOW PACKAGE INSTALLATION (ANSI SPECS) (OPTIONAL)
FIGURE 1-14. TOW PACKAGE INSTALLATION (CSA SPECS) (OPTIONAL)
FIGURE 1-15. TOW PACKAGE INSTALLATION (CE, RUSSIAN & UK CA SPECS) (OPTIONAL)
FIGURE 1-16. TOW BAR ASSEMBLY
FIGURE 1-17. LP TANKS INSTALLATION
SECTION 2 - TURNTABLEFIGURE 2-1. CONTROL VALVES INSTALLATION - DEUTZ D2011 ENGINES
FIGURE 2-2. CONTROL VALVES INSTALLATION - DEUTZ DT2.9L4, DEUTZ TD2.2L3 STAGE V & FORD ENGINES
FIGURE 2-3. MAIN VALVE BLOCK ASSEMBLY - 2WS
FIGURE 2-4. AUXILIARY PUMP INSTALLATION
FIGURE 2-5. AUXILIARY PUMP INSTALLATION WITH BATTERY DISCONNECT
FIGURE 2-6. AUXILIARY PUMP ASSEMBLY
FIGURE 2-7. SWING DRIVE INSTALLATION
FIGURE 2-8. SWING MOTOR/HUB ASSEMBLY
FIGURE 2-9. TURNTABLE BEARING INSTALLATION
FIGURE 2-10. TURNTABLE LOCK INSTALLATION (DEUTZ D2011 & FORD ENGINE MACHINES)
FIGURE 2-11. TURNTABLE LOCK INSTALLATION (DEUTZ TD2.9L4 & DEUTZ TD2.2L3 STAGE V ENGINE MACHINES)
FIGURE 2-12. ROTARY COUPLING INSTALLATION
FIGURE 2-13. TANK INSTALLATION – DEUTZ D2011 ENGINE
FIGURE 2-14. TANK INSTALLATION – DEUTZ TD2.9L4 & TD2.2L3 STAGE V ENGINES
FIGURE 2-15. TANK INSTALLATION – FORD ENGINE
FIGURE 2-16. HYDRAULIC OIL TANK ASSEMBLY
FIGURE 2-17. HYDRAULIC OIL COOLER INSTALLATION - DEUTZ D2011 ENGINES (OPTIONAL)
FIGURE 2-18. HYDRAULIC OIL COOLER INSTALLATION - DEUTZ TD2.2L3 STAGE V ENGINES (OPTIONAL)
FIGURE 2-19. HYDRAULIC OIL COOLER INSTALLATION - DEUTZ TD2.9L4 ENGINES (OPTIONAL)
FIGURE 2-20. HYDRAULIC OIL COOLER INSTALLATION - FORD ENGINES (OPTIONAL)
FIGURE 2-21. GROUND CONTROL BOX ASSEMBLY - DEUTZ 2011 ENGINE
FIGURE 2-22. GROUND CONTROL BOX ASSEMBLY - DEUTZ D2011 ENGINES AND MSSO
FIGURE 2-23. GROUND CONTROL BOX ASSEMBLY - DEUTZ TD2.9L4 AND DEUTZ TD2.9L4 (CHINA IV) ENGINES
FIGURE 2-24. GROUND CONTROL BOX ASSEMBLY - FORD DF 2.5
FIGURE 2-25. GROUND CONTROL BOX ASSEMBLY - DEUTZ TD2.2L3 ENGINE
FIGURE 2-26. GROUND CONTROL BOX ASSEMBLY - DEUTZ D2011 ENGINE AND TOWER STOW
FIGURE 2-27. GROUND CONTROL BOX ASSEMBLY - DEUTZ 2011 ENGINES AND TOWER STOW AND MSSO
FIGURE 2-28. GROUND CONTROL BOX ASSEMBLY - DEUTZ TD2.9L4 AND CHINA IV ENGINES AND TOWER STOW
FIGURE 2-29. GROUND CONTROL BOX ASSEMBLY - FORD DF 2.5L AND TOWER STOW
FIGURE 2-30. GROUND CONTROL BOX ASSEMBLY - DEUTZ TD2.2L3 (STAGE V) ENGINES AND TOWER STOW
FIGURE 2-31. LIGHT PANEL INSTALLATION - GROUND CONTROL
FIGURE 2-32. CRIBBING ENABLE SWITCH INSTALLATION
FIGURE 2-33. ALARM INSTALLATION
FIGURE 2-34. ALARM (WHITE NOISE AMBIENT) INSTALLATION
FIGURE 2-35. ALARM (WHITE NOISE) INSTALLATION
FIGURE 2-36. HOODS INSTALLATION - DEUTZ D2011 ENGINES WITHOUT NOISE REDUCTION (ABS)
FIGURE 2-37. HOODS INSTALLATION - DEUTZ D2011 ENGINES WITH NOISE REDUCTION (ABS)
FIGURE 2-38. HOODS INSTALLATION - DEUTZ TD2.2L3 STAGE V ENGINES (ABS)
FIGURE 2-39. HOODS INSTALLATION - DEUTZ TD2.9L4 AND FORD DF 2.5L ENGINES (ABS)
FIGURE 2-40. NOISE REDUCTION INSTALLATION - DEUTZ D2011 & DEUTZ TD2.9L4 ENGINES
FIGURE 2-41. NOISE REDUCTION INSTALLATION - DEUTZ TD2.2L3 ENGINES
SECTION 3 - ENGINEFIGURE 3-1. DEUTZ D2011 ENGINE INSTALLATION – WITHOUT ARCTIC PACKAGE
FIGURE 3-2. DEUTZ D2011 ENGINE INSTALLATION – WITH ARCTIC PACKAGE
FIGURE 3-3. DEUTZ D2011 ENGINE/PUMP SUB-ASSEMBLY – WITHOUT ARCTIC PACKAGE
FIGURE 3-4. DEUTZ D2011 ENGINE/PUMP SUB-ASSEMBLY – WITH ARCTIC PACKAGE
FIGURE 3-5. DEUTZ D2011 ENGINE ASSEMBLY – WITHOUT ARCTIC PACKAGE
FIGURE 3-6. DEUTZ D2011 ENGINE ASSEMBLY – WITH ARCTIC PACKAGE
FIGURE 3-7. DEUTZ D2011 ENGINE COMPONENTS
FIGURE 3-8. DEUTZ TD2.2L3 (STAGE V) ENGINE INSTALLATION - (WITHOUT ARCTIC PACKAGE)
FIGURE 3-9. DEUTZ TD2.2L3(STAGE V) ENGINE/PUMP SUB ASSEMBLY - (WITHOUT ARCTIC PACKAGE)
FIGURE 3-10. DEUTZ TD2.2L3 (STAGE V) ENGINE ASSEMBLY
FIGURE 3-11. DEUTZ TD2.2L3 (STAGE V) ENGINE COMPONENTS
FIGURE 3-12. BRACKET ASSEMBLY - FUEL PUMP AND FILTER (DEUTZ D2.2L3 ENGINE)
FIGURE 3-13. DEUTZ D2.9L4 EMR5 ENGINE INSTALLATION (WITH ARCTIC PACKAGE)
FIGURE 3-14. DEUTZ D2.9L4 EMR5 ENGINE/PUMP SUB ASSEMBLY (WITH ARCTIC PACKAGE)
FIGURE 3-15. DEUTZ D2.9L4 EMR5 (49HP) ENGINE INSTALLATION (WITHOUT ARCTIC PACKAGE)
FIGURE 3-16. DEUTZ D2.9L4 EMR5 (49HP) ENGINE/PUMP SUB ASSEMBLY (WITHOUT ARCTIC PACKAGE)
FIGURE 3-17. DEUTZ D2.9L4 EMR5 (49HP) ENGINE ASSEMBLY (WITHOUT ARCTIC PACKAGE)
FIGURE 3-18. DEUTZ D2.9L4 EMR5 (49HP) ENGINE ASSEMBLY (WITHOUT ARCTIC PACKAGE)
FIGURE 3-19. ENGINE COMPONENTS - DEUTZ D2.9L4 ERM5 ENGINE (49HP)
FIGURE 3-20. ENGINE ASSEMBLY - DEUTZ D2.9L4 EMR5 ENGINE (WITH ARCTIC PACKAGE)
FIGURE 3-21. DEUTZ D2.9L4 EMR5 (67HP) ENGINE INSTALLATION (WITHOUT ARCTIC PACKAGE)
FIGURE 3-22. DEUTZ D2.9L4 EMR5 (67HP) ENGINE/PUMP SUB-ASSEMBLY (WITHOUT ARCTIC PACKAGE)
FIGURE 3-23. DEUTZ D2.9L4 EMR5 (67HP) ENGINE ASSEMBLY (WITHOUT ARCTIC PACKAGE)
FIGURE 3-24. DEUTZ D2.9L4 EMR5 (67HP) ENGINE ASSEMBLY (WITHOUT ARCTIC PACKAGE)
FIGURE 3-25. DEUTZ D2.9L4 EMR5 (67HP) ENGINE INSTALLATION (WITH ARCTIC PACKAGE)
FIGURE 3-26. DEUTZ D2.9L4 EMR5 (67HP) ENGINE/PUMP SUB-ASSEMBLY (WITH ARCTIC PACKAGE)
FIGURE 3-27. DEUTZ D2.9L4 EMR5 (67HP) ENGINE ASSEMBLY (WITH ARCTIC PACKAGE)
FIGURE 3-28. DEUTZ D2.9L4 EMR5 (67HP) ENGINE ASSEMBLY (WITH ARCTIC PACKAGE)
FIGURE 3-29. DEUTZ D2.9L4 EMR5 (67HP) ENGINE COMPONENTS
FIGURE 3-30. BRACKET ASSEMBLY - FUEL PUMP AND FILTER (DEUTZ D2.9L4 ENGINE)
FIGURE 3-31. BREATHER HEATER INSTALLATION - DEUTZ D2.9L4 ENGINES WITH ARCTIC PACKAGE
FIGURE 3-32. QUICKFIT OIL DRAIN (DEUTZ TD 2.9L)
FIGURE 3-33. QUICKFIT OIL DRAIN (DEUTZ D ENGINES)
FIGURE 3-34. FORD ENGINE INSTALLATION - (WITHOUT ARCTIC PACKAGE)
FIGURE 3-35. FORD ENGINE INSTALLATION - (WITH ARCTIC PACKAGE)
FIGURE 3-36. FORD ENGINE/PUMP SUB ASSEMBLY – (WITHOUT ARCTIC PACKAGE)
FIGURE 3-37. FORD ENGINE/PUMP SUB ASSEMBLY - (WITH ARCTIC PACKAGE)
FIGURE 3-38. FORD ENGINE ASSEMBLY - WITHOUT ARCTIC PACKAGE
FIGURE 3-39. FORD ENGINE ASSEMBLY - WITH ARCTIC PACKAGE
FIGURE 3-40. PUMP COUPLING AND FUEL SYSTEM ASSEMBLY (FORD ENGINES)
FIGURE 3-41. FORD ENGINE COMPONENTS
FIGURE 3-42. DRIVE BELT INSTALLATION - FORD ENGINES MACHINES WITHOUT GENERATORS
FIGURE 3-43. PUMP COUPLING KIT - DEUTZ ENGINES
FIGURE 3-44. PISTON PUMP ASSEMBLY - DEUTZ ENGINES - DANFOSS
FIGURE 3-45. PISTON PUMP AND FITTINGS SUB-ASSEMBLY - DEUTZ ENGINES - HENGLI
FIGURE 3-46. PISTON PUMP AND FITTINGS SUB-ASSEMBLY - FORD ENGINES - HENGLI
FIGURE 3-47. PISTON PUMP ASSEMBLY - HENGLI
FIGURE 3-48. GEAR PUMP ASSEMBLY
FIGURE 3-49. SPARK ARRESTOR MUFFLER INSTALLATION - DEUTZ D2011 ENGINES
FIGURE 3-50. EXHAUST PIPE INSTALLATION - FORD ENGINES
FIGURE 3-51. FUEL-WATER SEPARATOR INSTALLATION - DEUTZ D2011 ENGINES (OPTIONAL)
FIGURE 3-52. RIGHT ENGINE SUPPORT INSTALLATION (DEUTZ D2011 ENGINES MACHINES WITHOUT GENERATORS)
FIGURE 3-53. RIGHT ENGINE SUPPORT INSTALLATION (DEUTZ D2011 ENGINES MACHINES WITH GENERATORS)
FIGURE 3-54. RIGHT ENGINE SUPPORT INSTALLATION (DEUTZ TD2.2L3 ENGINES MACHINES WITHOUT GENERATORS)
FIGURE 3-55. RIGHT ENGINE SUPPORT INSTALLATION (DEUTZ TD2.2L3 ENGINES MACHINES WITH GENERATORS)
FIGURE 3-56. RIGHT ENGINE SUPPORT INSTALLATION (DEUTZ TD2.9L4 ENGINES MACHINES WITHOUT GENERATORS)
FIGURE 3-57. RIGHT ENGINE SUPPORT INSTALLATION (DEUTZ TD2.9L4 ENGINES MACHINES WITH GENERATORS)
FIGURE 3-58. ENGINE TRAY JACK INSTALLATION - DEUTZ D2011 ENIGNES
FIGURE 3-59. ENGINE TRAY JACK INSTALLATION - DEUTZ TD2.9L4 & TD2.2L3 STAGE V ENGINES
FIGURE 3-60. ENGINE TRAY JACK INSTALLATION - FORD ENIGNES
FIGURE 3-61. 2500W/110V/60HZ GENERATOR INSTALLATION - DEUTZ D2011 ENGINES
FIGURE 3-62. 2500W/220V/50HZ GENERATOR INSTALLATION - DEUTZ D2011 ENGINES
FIGURE 3-63. 2500W/110V/60HZ GENERATOR INSTALLATION - DEUTZ TD2.9L4 ENGINES
FIGURE 3-64. 2500W/220V/50HZ GENERATOR INSTALLATION - DEUTZ D2011 ENGINES (ANSI EXPORT AND CHINA SPECS)
FIGURE 3-65. 2500W GENERATOR INSTALLATION - FORD ENGINES
FIGURE 3-66. 4000W/60HZ GENERATOR INSTALLATION - DEUTZ D2011 ENGINES
FIGURE 3-67. 4000W/50HZ GENERATOR INSTALLATION - DEUTZ D2011 ENGINES
FIGURE 3-68. 4000W/50HZ GENERATOR INSTALLATION - DEUTZ TD2.2L3 ENGINES
FIGURE 3-69. 4000W/60HZ GENERATOR INSTALLATION - DEUTZ TD2.9L4 ENGINES
FIGURE 3-70. 4000W/50HZ GENERATOR INSTALLATION - DEUTZ TD2.9L4 ENGINES
FIGURE 3-71. 7500W/60HZ SKYPOWER GENERATOR INSTALLATION - DEUTZ D2011 ENGINES
FIGURE 3-72. 7500W/50HZ SKYPOWER GENERATOR INSTALLATION - DEUTZ D2011 ENGINES
FIGURE 3-73. 7500W/50HZ SKYPOWER GENERATOR INSTALLATION - DEUTZ TD2.2L3 STAGE V ENGINES
FIGURE 3-74. 7500W/60HZ SKYPOWER GENERATOR INSTALLATION - DEUTZ TD2.9L4 ENGINES
FIGURE 3-75. 7500W/60HZ SKYPOWER GENERATOR INSTALLATION - FORD ENGINES
SECTION 4 - BOOMFIGURE 4-1. BOOMS AND CYLINDERS INSTALLATION
FIGURE 4-2. TOWER BOOM ASSEMBLY
FIGURE 4-3. MAIN BOOM ASSEMBLY
FIGURE 4-4. JIB BOOM ASSEMBLY
FIGURE 4-5. ROTATOR ASSEMBLY
FIGURE 4-6. PLATFORM SUPPORT INSTALLATION
FIGURE 4-7. POWER TRACK INSTALLATION - MAIN BOOM
FIGURE 4-8. POWER TRACK INSTALLATION - TOWER BOOM
FIGURE 4-9. CONTROL VALVES INSTALLATION - DEUTZ D2011 AND STAGE V ENGINES
FIGURE 4-10. CONTROL VALVES INSTALLATION - DEUTZ TD2.9L4 & FORD ENGINES
FIGURE 4-11. BOOM VALVE ASSEMBLY
FIGURE 4-12. BOOM VALVES AND LIMIT SWITCHES INSTALLATION
FIGURE 4-13. BOOM SENSOR INSTALLATION (TOWER STOW)
SECTION 5 - PLATFORMFIGURE 5-1. PLATFORM ASSEMBLY - 30IN X 4FT (76.2CM X 1.22M) WITH SWING GATE
FIGURE 5-2. PLATFORM ASSEMBLY - 30IN X 5FT (76CM X 1.52M) - GATE ENTRY
FIGURE 5-3. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) WITH SWING GATE
FIGURE 5-4. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH SWING GATE
FIGURE 5-5. PLATFORM ASSEMBLY - 30IN X 3FT (76CM X .91M) - DROP BAR ENTRY
FIGURE 5-6. PLATFORM ASSEMBLY - 30IN X 4FT (76.2CM X 1.22M) WITH DROP BAR
FIGURE 5-7. PLATFORM ASSEMBLY - 30IN X 5FT (76CM X 1.52M) - DROP BAR ENTRY
FIGURE 5-8. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) WITH DROP BAR
FIGURE 5-9. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH DROP BAR
FIGURE 5-10. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) WITH FALL ARREST
FIGURE 5-11. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) WITH FALL ARREST
FIGURE 5-12. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) TRI-ENTRY WITH SWING GATE
FIGURE 5-13. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) TRI-ENTRY WITH SWING GATE
FIGURE 5-14. PLATFORM ASSEMBLY - 36IN X 6FT (91.5CM X 1.83M) TRI-ENTRY WITH DROPBAR
FIGURE 5-15. PLATFORM ASSEMBLY - 36IN X 8FT (91.5CM X 2.44M) TRI-ENTRY WITH DROPBAR
FIGURE 5-16. TRAY ASSEMBLY
FIGURE 5-17. CONSOLE AND FOOTSWITCH INSTALLATION
FIGURE 5-18. CONSOLE AND FOOTSWITCH INSTALLATION (TOWER STOW)
FIGURE 5-19. CONSOLE BOX ASSEMBLY WITH FOOTSWITCH (WITHOUT TOWER STOW) (Prior to SN 0300316689)
FIGURE 5-20. CONSOLE BOX ASSEMBLY WITH FOOTSWITCH (WITHOUT TOWER STOW) (SN 0300316689 to Present)
FIGURE 5-21. CONSOLE BOX ASSEMBLY WITH FOOTSWITCH (WITH TOWER STOW) (Prior to SN 0300316689)
FIGURE 5-22. CONSOLE BOX ASSEMBLY WITH FOOTSWITCH (WITH TOWER STOW) (SN 0300316689 to Present)
FIGURE 5-23. FOOTSWITCH ASSEMBLY
FIGURE 5-24. CRAB STEER SWITCH INSTALLATION - 4WS (WITHOUT TOW PACKAGE)
FIGURE 5-25. CRAB STEER SWITCH INSTALLATION - 4WS (WITH TOW PACKAGE)
FIGURE 5-26. LIGHT PANEL INSTALLATION
FIGURE 5-27. STEER SWITCH INSTALLATION – 4WS
FIGURE 5-28. SKYEYE INSTALLATION
FIGURE 5-29. SKYGUARD BAR INSTALLATION
FIGURE 5-30. SKYLINE INSTALLATION
FIGURE 5-31. SKYGLAZIER INSTALLATION
FIGURE 5-32. SKYGLAZIER INSTALLATION (ALL SPECS EXCEPT CHINA, JAPANESE, CE & UK CA SPECS) (OPTIONAL)
FIGURE 5-33. SKYCUTTER INSTALLATION (OPTIONAL)
FIGURE 5-34. PLASMA CUTTER ASSEMBLY
FIGURE 5-35. SKYWELDER/SKYCUTTER COMBO INSTALLATION (60HZ) (OPTIONAL)
FIGURE 5-36. SKYWELDER INSTALLATION (50HZ) (OPTIONAL)
FIGURE 5-37. SKYWELDER INSTALLATION (60HZ) (OPTIONAL)
FIGURE 5-38. WELDER ASSEMBLY
FIGURE 5-39. SKYWELDER PREP PACKAGE (60HZ) (OPTIONAL)
FIGURE 5-40. SKYWELDER LOCKING BRACKET INSTALLATION (OPTIONAL)
FIGURE 5-41. SOFT TOUCH SYSTEM INSTALLATION - 6FT/1.8M PLATFORMS (OPTIONAL)
FIGURE 5-42. SOFT TOUCH SYSTEM INSTALLATION - 6FT/1.8M FALL ARREST PLATFORMS (OPTIONAL)
FIGURE 5-43. SOFT TOUCH SYSTEM INSTALLATION - 8FT/2.44M PLATFORM (OPTIONAL)
FIGURE 5-44. SOFT TOUCH SYSTEM INSTALLATION - 8FT/2.44M FALL ARREST PLATFORM (OPTIONAL)
FIGURE 5-45. PLATFORM PADDING INSTALLATION (30IN/76CM DEPTH PLATFORMS) (ANSI, ANSI EXPORT, CSA AND CHINA SPECS) (OPTIONAL)
FIGURE 5-46. FALL ARREST (BOLT-ON) INSTALLATION - 30IN X 4FT PLATFORM (ALL SPECS EXCEPT CE & UK CA SPECS) (OPTIONAL)
FIGURE 5-47. FALL ARREST (BOLT-ON) INSTALLATION - 30IN X 5FT PLATFORM (ALL SPECS EXCEPT CE & UK CA SPECS) (OPTIONAL)
FIGURE 5-48. FALL ARREST (BOLT-ON) INSTALLATION - 36IN X 6FT PLATFORM (ALL SPECS EXCEPT CE & UK CA SPECS) (OPTIONAL)
FIGURE 5-49. FALL ARREST (BOLT-ON) INSTALLATION - 36IN X 6FT TRI-ENTRY PLATFORM (ALL SPECS EXCEPT CE & UK CA SPECS) (OPTIONAL)
FIGURE 5-50. FALL ARREST (BOLT-ON) INSTALLATION - 36IN X 8FT PLATFORM (ALL SPECS EXCEPT CE & UK CA SPECS) (OPTIONAL)
FIGURE 5-51. USB CHARGER INSTALLATION
FIGURE 6-2. LEVEL (PLATFORM SLAVE) CYLINDER ASSEMBLY
FIGURE 6-3. LEVEL (UPRIGHT) CYLINDER ASSEMBLY
FIGURE 6-4. LIFT CYLINDER ASSEMBLY - JIB
FIGURE 6-5. LIFT CYLINDER ASSEMBLY - JIB
FIGURE 6-6. LIFT CYLINDER ASSEMBLY - JIB
FIGURE 6-7. LIFT CYLINDER ASSEMBLY - MAIN BOOM
FIGURE 6-8. LIFT CYLINDER ASSEMBLY - MAIN BOOM
FIGURE 6-9. MASTER CYLINDER ASSEMBLY
FIGURE 6-10. STEER CYLINDER ASSEMBLY
FIGURE 6-11. TELESCOPE CYLINDER ASSEMBLY - MAIN BOOM
FIGURE 6-12. TELESCOPE CYLINDER ASSEMBLY - TOWER BOOM
SECTION 7 - HYDRAULICFIGURE 7-1. DRIVE HYDRAULIC DIAGRAM - 4WD/2WS WITHOUT ARCTIC PACKAGE
FIGURE 7-2. DRIVE HYDRAULIC DIAGRAM - 4WD/2WS WITH ARCTIC PACKAGE
FIGURE 7-3. FLUSHING LOOP HYDRAULIC INSTALLATION - 4WD
FIGURE 7-4. HYDRAULIC DIAGRAM - STANDARD (DEUTZ D2011 ENGINE)
FIGURE 7-5. HYDRAULIC DIAGRAM - STANDARD (DEUTZ TD2.9L4 & DEUTZ TD2.2L3 STAGE V ENGINES)
FIGURE 7-6. HYDRAULIC DIAGRAM - STANDARD (FORD ENGINES)
FIGURE 7-7. HYDRAULIC DIAGRAM - OSCILLATING AXLE
FIGURE 7-8. HYDRAULIC DIAGRAM - TOW BAR
SECTION 8 - ELECTRICALFIGURE 8-1. AC CABLE CONNECTOR INSTALLATION - 110V/220V (MACHINES NO GENERATOR) (ANSI EXPORT, AUSTRALIAN, CHINA, CE & UK CA SPECS)
FIGURE 8-2. AC CABLE CONNECTOR INSTALLATION - SKYPOWER (MACHINES NO GENERATOR) (ALL SPECS)
FIGURE 8-3. AC CABLE CONNECTOR INSTALLATION - 4000W GENERATOR (MACHINES NO GENERATOR) (ALL SPECS EXCEPT AUSTRALIAN, CE & UK CA SPECS)
FIGURE 8-4. AC BOX AT PLATFORM INSTALLATION - 110V GFI RECEPTACLE (MACHINES WITH 2500W GENERATOR/NO GENERATOR OPTIONS) (ALL SPECS EXCEPT AUSTRALIAN, CE& UK CA SPECS)
FIGURE 8-5. AC BOX AT PLATFORM INSTALLATION - 220V RECEPTACLE (MACHINES WITH 2500W GENERATOR/NO GENERATOR OPTIONS) (ANSI, CSA AND JAPANESE SPECS)
FIGURE 8-6. AC BOX AT PLATFORM INSTALLATION - BOX WITH COVER (2X4 BOX) (ANSI EXPORT SPECS) (4000W GENERATOR)
FIGURE 8-7. AC BOX AT PLATFORM INSTALLATION – DUAL AC 110V GFI (MACHINES WITH 2500W GENERATOR) (ANSI EXPORT AND CHINA SPECS)
FIGURE 8-8. AC BOX AT PLATFORM INSTALLATION - 110V IEC YELLOW (CE & UK CA SPECS)
FIGURE 8-9. AC BOX AT PLATFORM INSTALLATION - 110V IEC 60309 YELLOW (CE & UK CA SPECS) (4000W GENERATOR)
FIGURE 8-10. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE (CE& UK CA SPECS)
FIGURE 8-11. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE (CE & UK CA SPECS) (2500W GENERATOR)
FIGURE 8-12. AC BOX AT PLATFORM INSTALLATION - 220V IEC 60309 BLUE (CE & UK CA SPECS) (4000W GENERATOR)
FIGURE 8-13. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 POST GROUND (CE & UK CA SPECS)
FIGURE 8-14. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 POST GROUND (CE & UK CA SPECS) (2500W GENERATOR)
FIGURE 8-15. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 POST GROUND (2X4 BOX) (CE & UK CA SPECS) (4000W GENERATOR)
FIGURE 8-16. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 SIDE GROUND (CE & UK CA SPECS)
FIGURE 8-17. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 SIDE GROUND (CE & UK CA SPECS) (2500W GENERATOR)
FIGURE 8-18. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 SIDE GROUND (2X4 BOX) (CE & UK CA SPECS) (4000W GENERATOR)
FIGURE 8-19. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT 107 (CE & UK CA SPECS)
FIGURE 8-20. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT 107 (CE & UK CA SPECS) (2500W GENERATOR)
FIGURE 8-21. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT 107 KEYED GROUND (2X4 BOX) (CE & UK CA SPECS) (4000W GENERATOR)
FIGURE 8-22. AC BOX AT PLATFORM INSTALLATION - 240V GFCI RECEPTACLE (ANSI, ANSI EXPORT, CHINA, CSA AND JAPANESE SPECS WITH 4000W SKYPOWER GENERATOR)
FIGURE 8-23. AC BOX AT PLATFORM INSTALLATION - 240V GFCI RECEPTACLE (ANSI AND CSA SPECS WITH 7500W SKYPOWER GENERATOR)
FIGURE 8-24. BATTERY DISCONNECT SWITCH INSTALLATION – DEUTZ D2011 ENGINES
FIGURE 8-25. BATTERY DISCONNECT SWITCH INSTALLATION (DEUTZ TD2.9L4, DEUTZ D2.9L4, DEUTZ TD2.2L3 STAGE V AND FORD DF2.5L ENGINES)
FIGURE 8-26. BOOM CABLES INSTALLATION - WITH 2500W GENERATOR OR NO GENERATOR
FIGURE 8-27. BOOM CABLE INSTALLATION - WITH 4000W/50HZ GENERATOR
FIGURE 8-28. BOOM CABLES INSTALLATION - WITH 4000W/60HZ GENERATOR
FIGURE 8-29. BOOM CABLE INSTALLATION - WITH 7500W GENERATOR
FIGURE 8-30. BOOM CABLE - MAIN BOOM
FIGURE 8-31. BOOM CABLE - TOWER BOOM (WITHOUT ARCTIC PACKAGE)
FIGURE 8-32. BREAKER BOX KIT - SINGLE DOUBLE POLE BREAKER (WITH 4000W/50HZ GENERATOR)
FIGURE 8-33. BREAKER BOX KIT - 30MA/16 AMP (WITH GENERATOR)
FIGURE 8-34. CLEARSKY CS550 BEACON INSTALLATION
FIGURE 8-35. ENGINE HARNESS ASSEMBLY (DEUTZ TD2.L4 ENGINES)
FIGURE 8-36. ENGINE HARNESS ASSEMBLY (DEUTZ D2011 ENGINES)
FIGURE 8-37. ENGINE HARNESS ASSEMBLY (DEUTZ TD2.9L4 & DEUTZ DT2.2L3 STAGE V ENGINES)
FIGURE 8-38. ENGINE HARNESS - DEUTZ TD2.2L3 ENGINES
FIGURE 8-39. ENGINE HARNESS - DEUTZ TD2.9L4 ENGINES
FIGURE 8-40. ENGINE HARNESS ASSEMBLY (FORD DF2.5L ENGINES)
FIGURE 8-41. ECU POWER JUMPER HARNESS
FIGURE 8-42. FUEL HARNESS - DEUTZ TD2.2L3 (STAGE V) ENGINE
FIGURE 8-43. FUEL HARNESS - DEUTZ TD2.9L4 ENGINES
FIGURE 8-44. FULL EXTENSION PROXIMITY HARNESS
FIGURE 8-45. GENERATOR TO CONTROL BOX HARNESS - 4000W
FIGURE 8-46. GENERATOR TO CONTROL BOX HARNESS - 7500W GENERATOR
FIGURE 8-47. GENERATOR HARNESS - 7500W GENERATOR (FORD ENGINES)
FIGURE 8-48. GENERATOR HARNESS - 7500W GENERATOR (DEUTZ TD2.9L4 ENGINES)
FIGURE 8-49. GENERATOR TO ENGINE HARNESS - 2500W
FIGURE 8-50. GENERATOR TO ENGINE HARNESS - 4000W
FIGURE 8-51. GENERATOR TO ENGINE HARNESS - 7500W SKYPOWER GENERATOR (DEUTZ D2011 ONLY)
FIGURE 8-52. GENERATOR TO REAR OF BOOM HARNESS - 110V
FIGURE 8-53. GENERATOR TO REAR OF BOOM HARNESS - 220V
FIGURE 8-54. GROUND CONTROL BOX HARNESS
FIGURE 8-55. MID PROXIMITY HARNESS
FIGURE 8-56. PLATFORM CONSOLE BOX HARNESS (Prior to SN 0300316689)
FIGURE 8-57. PLATFORM CONSOLE BOX HARNESS (SN 0300316689 to Present)
FIGURE 8-58. RECEPTACLE BOX KIT - 110V IEC YELLOW (CE & UK CA SPEC)
FIGURE 8-59. RECEPTACLE BOX KIT - 220V IEC BLUE (CE & UK CA SPEC)
FIGURE 8-60. RECEPTACLE BOX KIT - 220V IEC BLUE (CE & UK CA SPECS) (2500W GENERATOR)
FIGURE 8-61. RECEPTACLE BOX KIT - 220V CEE7 POST GROUND WITHOUT 2500W GENERSTOR (2X4 BOX) (CE & UK CA SPECS)
FIGURE 8-62. RECEPTACLE BOX KIT - 220V CEE7 POST GROUND (2X4 BOX) (CE & UK CA SPECS) (2500W GENERATOR)
FIGURE 8-63. RECEPTACLE BOX KIT - 220V CEE7 SIDE GROUND (CE & UK CA SPEC)
FIGURE 8-64. RECEPTACLE BOX KIT - 220V CEE7 SIDE GROUND (2X4 BOX) (CE & UK CA SPECS) (2500W GENERATOR)
FIGURE 8-65. RECEPTACLE BOX KIT - 220V AFSINT 107 (CE & UK CA SPEC)
FIGURE 8-66. RECEPTACLE BOX KIT - 220V AFSINT 107 KEYED GROUND (2X4 BOX) (CE & UK CA SPECS) (2500W GENERATOR)
FIGURE 8-67. SKYEYE INTERMEDIATE HARNESS
FIGURE 8-68. SKYEYE EMITTER HARNESS
FIGURE 8-69. SKYEYE RECEIVER HARNESS
FIGURE 8-70. SKYLINE HARNESS
FIGURE 8-71. SKYGUARD INTERFACE HARNESS
FIGURE 8-72. TILT SENSOR HARNESS
FIGURE 8-73. VALVE HARNESS - BOOM VALVE
FIGURE 8-74. VALVE HARNESS
FIGURE 8-75. WHITE NOISE ALARM HARNESS
SECTION 9 - DECALSFIGURE 9-1. DECAL INSTALLATION - ANSI SPECS
FIGURE 9-2. DECAL INSTALLATION - AUSTRALIAN SPECS
FIGURE 9-3. DECAL INSTALLATION - BRAZIL SPECS
FIGURE 9-4. DECAL INSTALLATION - CE, RUSSIAN & UK CA SPECS
FIGURE 9-5. DECAL INSTALLATION - CHINESE SPECS (SIMPLIFIED)
FIGURE 9-6. DECAL INSTALLATION - CHINESE SPECS (TRADITIONAL)
FIGURE 9-7. DECAL INSTALLATION - CSA SPECS
FIGURE 9-8. DECAL INSTALLATION - JAPANESE SPECS
FIGURE 9-9. DECAL INSTALLATION - KOREAN SPECS
FIGURE 9-10. DECAL INSTALLATION - LATIN AMERICAN SPECS
FIGURE 9-11. DECAL INSTALLATION - OPTIONS
FIGURE 9-12. SKYCUTTER DECAL INSTALLATION (ALL SPECS EXCEPT AUSTRALIAN, CE & JAPANESE SPECS)
FIGURE 9-13. SKYCUTTER DECAL INSTALLATION (JAPANESE SPECS)
FIGURE 9-14. SKYWELDER DECAL INSTALLATION - 50HZ
FIGURE 9-15. SKYWELDER DECAL INSTALLATION - 60HZ
SECTION 10 - RECOMMENDED SERVICE PARTS STOCKFIGURE 10-1. RECOMMENDED SERVICE PART STOCK
PART NUMBER INDEX
- SuperPac Parts Manual
- StratoLift Parts Manual
