JLG Boom Lift 600AJ HC3 Operation Safety Manual 3122343800
Brand: JLG
Type of Machine: Boom Lift
Type of Manual: Operation Safety Manual
Model: JLG 600AJ HC3 Boom Lift
Part Number: 3122343800
Publication Date: 2025
Number of Pages: 168 Pages
600AJ HC3 2501 Cover Page
Foreword
600AJ HC3 2501 Revision Log
Brand: JLG
Foreword
Other Publications Available
Serial Number Location
Safety PrecautionsGeneral
Pre-Operation
1.2.1 Operator Training and Knowledge
1.2.2 Workplace Inspection
1.2.3 Machine Inspection
Operation
1.3.1 General
1.3.2 Trip and Fall Hazards
1.3.3 Electrocution Hazards
1.3.4 Tipping Hazards
1.3.5 Crushing and Collision Hazards
Towing, Lifting, and Hauling
Maintenance
1.5.1 Maintenance Hazards
1.5.2 Battery Hazards
Long-Term Storage
User Responsibilities, Machine Preparation, and InspectionPersonnel Training
2.1.1 Operator Training
2.1.2 Training Supervision
2.1.3 Operator Responsibility
2.1.4 Machine Familiarization
Preparation, Inspection and Maintenance
Machine Components
Pre-Start Inspection
Walk-Around Inspection
2.5.1 General
Function Check - AJ Model
SkyGuard® Function Check
Machine Controls and IndicatorsGeneral
Ground Control Station - 600AJ
3.3.1 Ground Control Station Functions
Multifunction Display - ICE V3
3.4.1 Multifunction Display Diagnostic Screen
Ground Control Indicator Panel - ICE HC3 - Fuel Gauge
3.5.1 Ground Control Indicator Panel Functions
Platform Control Station - 600AJ
3.6.1 Platform Control Station Functions
Platform Indicator Panel - ICE HC3 - Fuel Gauge
3.7.1 Platform Control Indicator Panel Functions
Beacons (With SkyGuard)
3.8.1 ClearSky® LED Motion / Amber Beacon (CS550)
3.8.2 Amber Beacon
3.8.3 Blue or Red SkyGuard® Beacon
Machine OperationGeneral AJ 360 Continuous Swing
Operating Characteristics And Limitations - HC3
4.2.1 Operating Conditions
4.2.2 Platform Load Sensing System (LSS)
4.2.3 Capacity Zones (Triple Capacity)
600AJ HC3 Reach Chart
600AJ Stability
Engine Operation
4.5.1 Starting Procedure
4.5.2 Shutdown Procedure
Air Shutoff Valve (ASOV)
Fuel Shutoff System (Reserve) - Fuel Gauge
Diesel Particulate Filter - Standstill Cleaning(If Equipped)
4.8.1 Standstill Cleaning/ Maintenance Standstill Cleaning
DPF - Canceling/Unsuccessful Standstill
4.9.1 Canceling Maintenance Standstill/Standstill Cleaning
4.9.2 Unsuccessful Cleaning Event
DPF Filter Replacement Due to Ash Load
Traveling (Driving)
4.11.1 Traveling Forward and Reverse
600AJ Traveling (Grade/Side Slope)
4.12.1 Traveling on a Grade
Steering
Platform - Standard Booms
4.14.1 Platform Level Adjustment
4.14.2 Platform Rotation
Boom - AJ Models
4.15.1 Swinging the Boom
4.15.2 Raising and Lowering the Tower Boom
4.15.3 Raising and Lowering the Main Boom
4.15.4 Telescoping the Main Boom
Re-Synchronize The Lower Lift Cylinder
4.16.1 Level Override Valve
4.16.2 Boom Upright Positioning
Function Speed Control - AJ Core Boom
USB Charging Port
ClearSky Smart Fleet
Access Control (Boom)
SkyGuard Activation/Deactivation - AJ
Oscillating Axle Lockout Test (If Equipped)
Towing (If Equipped)
Auxiliary Power - AJ
4.24.1 Activating from the Platform Control Station
4.24.2 Activating from the Ground Control Station
Dual Fuel System (Gas Engine Only)
4.25.1 Changing From Gasoline to LP Gas
4.25.2 Changing From LP Gas to Gasoline
Shut Down And Park
Lifting And Tie Down
4.27.1 Lifting
4.27.2 Tie Down
Lifting Chart - 600AJ HC3
600AJ HC3 Safety Decal Locations
Emergency ProceduresGeneral
Incident Notification - Boom
Emergency Operation
5.3.1 Operator Unable to Control Machine
5.3.2 Platform or Boom Caught Overhead
Emergency Towing Procedures
ClearSky Smart Fleet - Locked Out State
Accessories600AJ HC3 Accessory Table
Bolt-On External Fall Arrest
6.2.1 Inspection Before Use
Cable Ladder Carrier
Fabric Mesh to Mid/Top Rail
Fall Arrest Platform
6.5.1 Safety Precautions
Pipe Racks
6.6.1 Capacity Specifications
6.6.2 Safety Precautions
6.6.3 Preparation and Inspection
6.6.4 Operation
Platform Mesh to Mid/Top Rail
Platform Mid Rail Deck
6.8.1 Accessory Installation
6.8.2 Access to Manual Box
Platform Top Rail Extension
Platform Work Lights
Platform Work Surface
Portable Work Light
Nite Bright
SkyCutter
6.14.1 Safety Precautions
6.14.2 Generator Output
6.14.3 Preparation and Inspection
6.14.4 Operation
6.14.5 Accessory Ratings
SkyGlazier
6.15.1 Capacity Specifications
6.15.2 Safety Precautions
6.15.3 Preparation and Inspection
6.15.4 Operation
SkyPower 7.5kW and Generator 4kW
6.16.1 Output
6.16.2 Safety Precautions
6.16.3 Preparation and Inspection
6.16.4 Operation
SkySense
6.17.1 Preparation and Inspection
6.17.2 Operation
6.17.3 SkySense Platform Panel Indicators
6.17.4 SkySense Alarm
6.17.5 SkySense Override Button
6.17.6 SkySense Coverage Areas
SkySense Platform Bumper Padding
SkyWelder
6.19.1 Operation
6.19.2 Generator Output
6.19.3 Welding Accessories
6.19.4 Safety Precautions
6.19.5 Preparation and Inspection
Soft Touch
General Specifications and Operator MaintenanceGeneral
600AJ HC3 Operating Specifications
7.2.1 Dimensional Data
7.2.2 Capacities
7.2.3 Engine Data
7.2.4 Tires
Hydraulic Oil Specifications - Introduction
Engine Oil Operating Temperature Specifications
Operator Maintenance and Lubrication Diagram 600AJ
7.5.1 DEUTZ D2011L04
7.5.2 Deutz TD 2.9L, 2.2L Stage V
7.5.3 Ford DF 2.5L, MSG 425
Operator Maintenance 600AJ
Tires and Wheels - 9 Lug Nuts
7.7.1 Tire Damage
7.7.2 Tire Replacement
7.7.3 Wheel Replacement
7.7.4 Wheel Installation
Propane Fuel Filter Replacement
7.9.1 Removal
7.9.2 Installation
Propane Fuel System Pressure Relief
Radio Frequency (RF) Information
7.11.1 Federal Communications Commission (FCC)
7.11.2 Innovation, Science and Economic Development (ISED)
7.11.3 European Union Conformity (CE)
Supplemental Information - CE/UKCA
EC Declaration of Conformity - 600AJ Series
UKCA Declaration of Conformity - 600AJ Series
- SuperPac Parts Manual
- StratoLift Parts Manual
