Hyundai
86
176,834
JLG Boom Lift 520AJ HC3 Service & Maintenance Manual 31219154
Brand: JLG
Type of Machine: Boom Lift
Type of Manual: Service & Maintenance Manual, Electric Diagram
Model: JLG 520AJ HC3 Boom Lift
Part Number: 31219154
Publication Date: 2024
Number of Pages: 780 Pages
SPECIFICATIONS​
Operating Specifications (reference)​
Dimensional Data (reference)​
Capacities (reference)​
Tires (reference)​
Engine Data (reference)​
Engine Oil Specification (reference)​
Hydraulic Oil​
Maintenance and Lubrication (task)​
ThreadLocking Compound (reference)​
Torque Charts (reference)​
GENERAL​
Machine Preparation, Inspection, and Maintenance (reference)​
Service and Guidelines (task)​
Lubrication and Information (task)​
Cylinder Drift (reference)​
Pins and Composite Bearing Repair Guidelines (task)​
Welding on JLG Equipment (reference)​
CHASSIS & TURNTABLE​
Tires and Wheels (task)​
Oscillating Axle System (concept)​
Lockout Cylinder Bleeding (task)​
Oscillating Axle Lockout Test (task)​
Cold Start System (Diesel) (concept)​
Drive Orientation System (concept)​
Chassis Tilt Indicator System (concept)​
Drive System (reference)​
Wheel Drive Assembly (task)​
Torque Hub (task)​
Re-Align Torque Hub Input Coupling (task)​
Drive Motor (task)​
Swing Bearing (task)​
Swing Motor (task)​
Generator (task)​
Generator Pulley (Task)​
Deutz Engine D2011 L03 (task)​
Deutz Engine D2.9L4 (Stage V) (task)​
HRC Engine Emission Characteristics (reference)​
Diesel Particulate Filter (If Equipped)​
Bio Fuel in Deutz Engines (reference)​
DGC Diagnostic Support and Trouble CodeDefinitions (referenc​
Diagnostic Trouble Code Fault Descriptions (reference)​
Counterweight (reference)​
BOOM & PLATFORM​
Boom Systems (reference)​
Platform (task)​
Rotator (task)​
Jib (task)​
Platform Level Cylinder (task)​
Main Boom Powertrack (task)​
Powertrack Maintenance (task)​
Boom Cleanliness Guidelines (task)​
Boom Shimming Procedure (task)​
Boom Assembly (task)​
Rotary Actuator (task)​
Foot Switch Adjustment (reference)​
Skyguard (task)​
Bolt-on External Fall Arrest (task)​
BASIC HYDRAULICS INFORMATION & SCHEMATICS​
Lubricating O-rings In The Hydraulic System (reference)​
Hydraulic Connection Assembly and Torque Specification (task​
Hydraulic Cylinders (task)​
Pressure Setting Procedure (task)​
Drive Pump Pre-Fill Procedure (task)​
Hydraulic Schematics​
JLG CONTROL SYSTEM​
JLG Control System Analyzer Kit Instructions​
Boom Angle Calibration (Task)​
Load Sensing System (LSS)​
Resetting the MSSO System (task)​
Function Speed Control System (concept)​
Fuel Reserve / Cut-out System (concept)​
Machine Model Adjustment (task)​
BASIC ELECTRICAL INFORMATION & ELECTRICAL SCHEMATICS​
General (concept)​
Multimeter Basics (reference)​
Applying Silicone Dielectric Compound to Electrical Connecti​
Dielectric Grease Application (reference)​
AMP Connector (task)​
Deutsch Connectors (task)​
Telematics Gateway (reference)​
Wiring Harness Connector Labels (reference)​
Electrical Installation​
Wiring Harness​
Electrical Schematics​
