Hyundai
86
176,834
JLG Boom Lift 450AJ HC3 Service & Maintenance Manual 3122343000 2026
Brand: JLG
Type of Machine: Boom Lift
Model: JLG 450AJ HC3 Boom Lift
Part Number: 3122343000
Publication Date: 2026
Number of Pages: 944 Pages
Safety
General​
1.1.1 Disclaimer​
Safety Information​
Safety Hazards​
1.3.1 Personal Hazards​
1.3.2 Equipment Hazards​
1.3.3 General Hazards​
1.3.4 Operational Hazards​
Safety Decals​
Machine Verification​
Specifications​
2.1.1 Machine Specifications​
2.1.2 Machine Dimensional Data​
2.1.3 Engine Data​
2.1.4 Tires Specification​
2.1.5 Critical Stability Weights​
Serial Number Location​
Fluids and Lubrication​
2.3.1 General Information​
2.3.2 Hydraulic Oil​
2.3.3 Changing Hydraulic Oil​
2.3.4 Lubrication Specifications​
2.3.5 Fluids​
2.3.6 Capacities​
2.3.7 Lubrication Schedule​
Machine Characteristics​
2.4.1 Ground Control Keyswitch System​
2.4.2 Platform Control Enable System​
2.4.3 Cold Start System (DIESEL)​
2.4.4 Fuel Reserve / Cut-out System​
2.4.5 HRC Engine Emission Characteristics​
2.4.6 Diesel Particulate Filter (If Equipped)​
2.4.7 Drive System​
2.4.8 Drive Orientation System​
2.4.9 Function Speed Control System​
2.4.10 Oscillating Axle System​
2.4.11 Chassis Tilt Indicator System​
2.4.12 Platform Load Sensing System (LSS)​
2.4.13 ClearSkyTM System Ready​
2.4.14 Tires and Counterweight​
2.4.15 Side Entry Platform​
2.4.16 Transport Position Sensing System​
2.4.17 Beyond Transport Position - Drive Speed Cutback System​
2.4.18 Drive Steer - Boom Function Interlock System (CE Only)​
2.4.19 Ground Panel Display​
2.4.20 Jib Lift (if equipped) End of Stroke Dampening​
2.4.21 Main Boom Lift End of Stroke Dampening​
2.4.22 Emergency Decent System​
2.4.23 Diagnostics/Controller Programming​
2.4.24 Telescope Retracted Sensor​
2.4.25 Triple Capacity System​
2.4.26 Unrestricted capacity 660 lb (300 kg) - (Yellow)​
2.4.27 Restricted Capacity 750 lb (340 kg) - (Blue)​
2.4.28 Restricted Capacity 1000 lb (460 kg) - (Green)​
Clearsky Smart Fleet (If Equipped)​
2.5.1 General​
2.5.2 ClearSky Smart Fleet™ — Access Control​
Machine Preparation, Inspection, and Maintenance​
3.1.1 General​
3.1.2 Preparation, Inspection, and Maintenance​
3.1.3 Pre-Start Inspection​
3.1.4 Pre-Delivery Inspection and Frequent Inspection​
3.1.5 Annual Machine Inspection​
3.1.6 Preventive Maintenance​
Service and Guidelines​
3.2.1 General​
3.2.2 Safety and Workmanship​
3.2.3 Cleanliness​
3.2.6 Pressure-Fit Parts​
3.2.7 Bearings​
3.2.8 Gaskets​
3.2.11 Hydraulic System​
3.2.12 Lubrication​
3.2.13 Battery​
3.2.14 Welding on JLG Equipment​
Preventive Maintenance and Inspection Schedules​
3.3.1 Maintenance Schedules​
Pins and Composite Bearing Repair Guidelines​
Tires and Wheels​
3.5.1 Tire Replacement​
3.5.2 Tire Damage​
Fuel Tank Inspection​
Boom Inspection and Maintenance​
3.7.1 Boom Cleanliness Guidelines​
3.7.2 Boom Wear Pad Inspection​
Hydraulic Filter Replacement​
3.8.1 Hydraulic Filter Removal​
3.8.2 Hydraulic Filter Installation​
Turntable Bearing Inspection​
3.9.1 Turntable Bearing Mounting Bolt Condition Check​
3.9.2 Wear Tolerance​
Engine General Inspection​
3.10.1 General Maintenance​
3.10.2 Glow Plugs​
3.10.3 Checking Oil Level​
3.10.4 Replacing Engine Oil​
3.10.5 Replacing the Oil Filter​
3.10.6 Replacing the Primary Fuel Filters​
3.10.7 Replacing the Fuel Pre-Filter​
3.10.8 Replacing the Auxiliary Fuel Filter For Deutz D2011L03 T4I (Only)​
Bio Fuel In Deutz Engines​
3.11.1 General​
3.11.2 Bio Fuel​
3.11.3 Biological Contamination In Fuels​
Deutz EMR2​
Deutz EMR5​
Generator Inspection​
3.14.1 Maintenance Schedule​
3.14.2 Overload Protection​
3.14.3 Inspecting Brushes, Replacing Brushes and Cleaning Slip Rings​
3.14.4 Troubleshooting​
Testing, Calibrations and Special Procedures
Special Tools​
4.1.1 Multimeter Basics​
4.1.2 Threadlocking Compound​
4.1.3 Tools Catalog​
Testing Procedures​
4.2.1 Starter​
4.2.2 SkyGuard​
4.2.3 LSS Testing and Evaluation​
4.2.4 Troubleshooting​
Calibration Procedures​
4.3.1 JLG Analyzer​
4.3.2 Calibration Preparation​
4.3.3 Load Sensing System Calibration​
4.3.4 Tilt Sensor Calibration​
4.3.5 Boom Angle Calibration​
4.3.6 Calibrating Level Up CRKPT​
4.3.7 Calibrating Level Down Crackpoint​
4.3.8 Calibrating Platform Angle Sensor​
Special Procedures​
4.4.1 Fuel Tank Cleaning and Drying​
4.4.2 Cylinder Checking Procedure​
4.4.3 Cylinder Drift​
4.4.4 Hydraulic Circuits​
4.4.5 Hydraulic Pressure Settings and Adjustments​
4.4.6 Hydraulic Pressures​
4.4.7 Oscillating Axle Bleeding Procedure and Lockout Test​
4.4.8 Lubricating O-rings in the Hydraulic System​
4.4.9 Foot Switch Adjustment​
Wheel Drive Hub​
4.5.1 Roll and Leak Testing​
4.5.2 Tightening and Torquing Bolts​
System Software
5.1.1 Theory of Operation​
5.1.2 Load Sensing Gauge Removal/ Installation​
JLG Analyzer​
5.2.1 Introduction​
5.2.2 Machine Data Access​
5.2.3 Hand Held Analyzer​
5.2.4 Using the Analyzer​
5.2.5 Changing the Access Level of the Hand Held Analyzer​
5.2.6 Adjusting Parameters Using the Hand Held Analyzer​
5.2.7 Machine Setup​
5.2.8 Analyzer Flow Chart​
Analyzer Software Accessibility​
5.3.1 Access Level​
5.3.2 Machine Set-Up​
5.3.3 Personalities​
Function Test​
5.5.1 ClearSky Smart FleetTM CS550 Configuration​
5.5.2 Troubleshooting​
Fault Codes
Fault Codes Introduction​
Engine Diagnostic​
6.2.1 Deutz Trouble Codes (D2.9L4 Engine)​
6.2.2 Deutz D2.9L4 (Stage V) Engine​
6.2.3 Deutz D2.3 L3 Engine Trouble Codes​
6.2.4 Engine Fault Codes - Kubota Engine​
Machine Fault Codes​
6.3.1 General​
6.3.2 ClearSky Smart Fleet DTC Fault Codes​
ClearSky CS550 Troubleshooting Procedures​
Hydraulics
General Information and Safety​
Theories of Operation​
7.2.1 Cylinders​
7.2.2 Valves​
Hydraulic Components​
7.3.1 Hydraulic Oil Tank​
7.3.2 Drive Pump Pre-Fill Procedures​
7.3.3 Main Control Valve Pressure Setting​
Torque Values​
7.4.1 Cylinder Torque Specifications​
7.4.2 Valve Torque Specifications​
Hydraulics Installation​
7.5.1 Frame Hoses​
7.5.2 Turntable Hoses (US Built)​
7.5.3 Turntable Hoses (China Built)​
7.5.4 Boom Hoses​
Standard Hydraulic Diagram​
Electricals
8.1.1 Applying Silicone Dielectric Compound to Electrical Connections​
Electrical Connectors​
8.2.1 Deutsch Connectors​
Board Layouts​
8.3.1 Ground Control Module Pin Connections​
8.3.2 Platform Control Module Pin Connections​
AMP Connector​
8.4.1 Assembly​
8.4.2 Disassembly​
8.4.3 Wedge Lock​
8.4.4 Service - Voltage Reading​
Wiring Harness and Connector Label Diagrams​
8.5.1 Connector Labels​
8.5.2 Component Labels​
Telematics Gateway​
8.6.1 Telematics-Ready (TCU) Plug​
Electrical Installation​
Wheel and Tire​
Chassis/Frame Assembly​
9.2.1 Axle and Drive Assemblies Troubleshooting​
9.2.2 Axle Assembly​
9.2.3 Drive Hub and Motor​
9.2.4 Spindle Assembly​
Boom​
9.3.1 Boom Components Terminology​
9.3.2 Main Boom Powertrack​
9.3.3 Boom Assembly​
9.3.4 Rotator Assembly​
9.3.5 Jib Assembly​
Platform​
9.4.1 Platform (Rapid Replaceable Platform)​
9.4.2 Platform Support (Traditional Design)​
9.4.3 Platform Support (Rapid Replaceable Platform)​
9.4.4 Bolt-on External Fall Arrest​
Engine​
9.5.1 Component Terminology​
9.5.2 Engine Serial Number​
9.5.3 Engine Replacement​
9.5.4 Surge Tank (Deutz D2.9 L4 Stage V/D2.9 L4 T4F/China IV)​
9.5.5 Surge Tank (Kubota Engine)​
9.5.6 Pump Coupling Kit​
9.5.7 Air Filter Assembly​
9.5.8 Radiator Assembly​
9.5.9 Thermostat​
9.5.10 Coolant Temperature Sensor​
9.5.11 Relay Assembly​
9.5.12 Starter​
9.5.13 Alternator​
9.5.14 Fuel Tank​
9.5.15 Pre- Fuel Filter and Fuel Pump — Deutz Engine​
9.5.16 Pre-Fuel Filter and Fuel Pump-Kubota Engine​
Transmission​
Hydraulic Cylinders​
9.7.1 Main Boom Lift Cylinder​
9.7.2 Platform Level Cylinder​
9.7.3 Steer Cylinder​
9.7.4 Jib Lift Cylinder​
9.7.5 Axle Lockout Cylinder​
Hydraulic Valves​
9.8.1 Boom Mounted Valves​
9.8.2 Main Control Valve​
9.8.3 Traction Control Valve​
Hydraulic Pumps​
9.9.1 Function Pump​
9.9.2 Drive Pump​
Electrical Components​
9.10.1 Battery​
Turntable​
9.11.1 Swing Bearing​
9.11.2 Swing Motor​
9.11.3 Counterweight​
Generator and Pulley​
9.12.1 For 7500W Generator - Deutz D2011L03​
9.12.2 For 4000W Generator - Deutz D2011L03​
9.12.3 For 2500W Generator - Deutz D2011L03​
9.12.4 For 2500W Generator - Kubota WG2503 and Deutz T4F​
9.12.5 For 7500W and 4000W Generator - Kubota, Deutz T4F and D2.9L4 Stage V​
9.13.1 ClearSky® LED Motion / Amber Beacon (CS550) (if equipped)​
Disassembly and Assembly
Drive Assembly​
10.1.1 Drive Hub​
10.1.2 Drive Brake​
Platform​
Boom and Jib Assembly​
10.3.1 Upper Boom​
10.3.2 Jib​
10.3.3 Rotary Actuator​
Engine Components​
10.4.1 Engine Disassembly, Inspection and Service​
10.4.2 Fuel Tank​
Pumps​
10.5.1 Function Pump​
10.5.2 Drive Pump​
10.6.1 Axle Lockout Cylinder​
10.6.2 Platform Level Cylinder​
10.6.3 Jib Lift Cylinder​
10.6.4 Main Lift Cylinder​
10.6.5 Tower Boom Lift Cylinder​
10.6.6 Master Cylinder​
10.6.7 Steer Cylinder​
10.6.8 Telescope Cylinder​
Turntable​
10.7.1 Swing Motor​
10.7.2 Preparation Before Disassembly​
10.7.3 Disassembly and Inspection​
10.7.4 Assembly​
10.7.5 One Piece Stator Construction​
10.7.6 Two Piece Stator Construction​
10.7.7 Final Checks​
Generator Disassembly and Assembly​
Powertrack​
10.9.1 Remove Link​
10.9.2 Install New Link​
10.9.3 Replace Fixed End Brackets​
10.9.4 Replace Moving End Brackets​
Torque/Connection Information
Hydraulic Fittings​
11.1.1 Tapered Thread Types​
11.1.2 Straight Thread Types, Tube and Hose Connections​
11.1.3 Straight Thread Types, Port Connections​
11.1.4 Flange Connection Types​
11.1.5 Tightening Methods​
11.1.6 Assembly and Torque Specifications​
11.1.7 General Tube Type Fitting Assembly Instructions​
11.1.8 Assembly Instructions for American Standard Pipe Thread Tapered Connections.​
11.1.9 Assembly Instructions for British Standard Pipe Thread Tapered Connections​
11.1.10 Assembly Instructions for 37° (JIC) Flare Fittings​
11.1.11 Assembly Instructions for 45° SAE Flare Fittings​
11.1.12 Assembly Instructions for O-Ring Face Seal (ORFS) Fittings​
11.1.13 Assembly Instructions for DIN 24° Flare Bite Type Fittings (MBTL and MBTS)​
11.1.14 Assembly Instructions for Bulkhead (BH) Fittings​
11.1.15 Assembly Instructions for O-Ring Boss (ORB) Fittings​
11.1.16 Assembly Instructions for Adjustable Port End Metric Fittings​
11.1.17 Assembly Instructions for Metric ISO 6149 (MPP) Port Assembly Stud Ends​
11.1.18 Assembly instructions for Adjustable Port End (BSPP) Fittings​
11.1.19 Assembly Instructions for Flange Connections: (FL61 and FL62)​
11.1.20 Double Wrench Method​
11.1.21 FFWR and TFFT Methods​
11.1.22 Adjustable Stud End Assembly​
11.1.23 O-ring Installation (Replacement)​
Torque Charts​
11.2.1 SAE Fastener Torque Chart​
11.2.2 Metric Fastener Torque Chart​
Schematics
Hydraulic Schematics​
Electrical Schematics​
Deutz EMR2 Schematics​
12.3.1 Vehicle Side Connection Diagram​
12.3.2 Engine Side Connection Diagram - Sheet 1 of 2​
12.3.3 Engine Side Connection Diagram - Sheet 2 of 2​
12.3.4 Engine Plug Pin​
12.3.5 Vehicle Plug Pin Identification​
Deutz EMR5 Schematics​
12.4.1 Engine Plug Pin Identification​
12.4.2 Vehicle Plug Pin Identification​
4000W Generator Schematic​
12.5.1 Generator and Controller Circuit Diagram​
12.5.2 Lead Connection List​
7500W Generator Schematic​
12.6.1 Troubleshooting Circuit Diagram​
12.6.2 Generator and Controller Circuit Diagram​
12.6.3 Power Board PC1 Circuit Diagram​
12.6.4 Power Board PC2 Electrical Circuit Diagram​
12.6.5 Lead Connection List​
