Hyundai
86
178,635
JLG Boom Lift 450AJ HC3 Service & Maintenance Manual 31217152 2025
Brand: JLG
Type of Machine: Boom Lift
Type of Manual: Service & Maintenance Manual, Electric Diagram
Model: JLG 450AJ HC3 Boom Lift
Part Number: 31217152
Publication Date: 2025
Number of Pages: 806 Pages
SPECIFICATIONS​
Operating Specifications (reference)​
Dimensional Data (reference)​
Capacities (reference)​
Tires (reference)​
Engine Data (reference)​
Engine Oil Specification (reference)​
Hydraulic Oil (reference)​
Major Component Weight (reference)​
Maintenance and Lubrication (task)​
Threadlocking Compound (reference)​
Torque Charts (reference)​
GENERAL​
Machine Preparation, Inspection, and Maintenance (reference)​
Service and Guidelines (task)​
Lubrication and Information (task)​
Cylinder Drift Test (reference)​
Pins and Composite Bearing Repair Guidelines (task)​
Welding on JLG Equipment (reference)​
CHASSIS & TURNTABLE​
Tires and Wheels (task)​
Oscillating Axle System (concept)​
Lockout Cylinder Bleeding (task)​
Chassis Tilt Indicator System (concept)​
Oscillating Axle Lockout Test (task)​
Cold Start System (Diesel) (concept)​
Drive Orientation System (concept)​
Drive System​
Wheel Drive Assembly (task)​
Torque Hub (task)​
Re-Align Torque Hub Input Coupling (task)​
Drive Motor (task)​
Drive Brake (task)​
Swing Bearing (task)​
Swing Motor (task)​
Generator (task)​
Deutz Engine (concept)​
Kubota Engine (concept)​
Deutz Engine - D2.9L4 (task)​
Deutz Engine - D2011L03 (task)​
Kubota Engine General Maintenance (task)​
Deutz Engine D2.9L4 (Stage V) (task)​
HRC Engine Emission Characteristics (reference)​
Diesel Particulate Filter (If Equipped)​
Counterweight (concept)​
BOOM & PLATFORM​
Boom Systems (reference)​
Platform (task)​
Rotator (task)​
Jib (task)​
Platform Level Cylinder (task)​
Main Boom Powertrack (task)​
Powertrack Maintenance (task)​
Boom Cleanliness Guidelines (task)​
Boom Shimming Procedure (task)​
Boom Assembly (task)​
Rotary Actuator (task)​
Foot Switch Adjustment (reference)​
Skyguard (task)​
Bolt-on External Fall Arrest (task)​
BASIC HYDRAULICS INFORMATION & SCHEMATICS​
Lubricating O-rings in the Hydraulic System (reference)​
Hydraulic Connection Assembly and Torque Specification (task​
Hydraulic Cylinders​
Pressure Setting Procedure (task)​
Drive Pump Pre-Fill Procedure (task)​
Hydraulic Schematics (concept)​
JLG CONTROL SYSTEM​
JLG Control System Analyzer Kit Instructions​
Boom Angle Calibration (Task)​
LSS System (task)​
Resetting the MSSO System (task)​
Function Speed Control System (concept)​
Fuel Reserve / Cut-out System (concept)​
Machine Model Adjustment​
BASIC ELECTRICAL INFORMATION & SCHEMATICS​
General (concept)​
Multimeter Basics (reference)​
Applying Silicone Dielectric Compound to Electrical Connecti​
Dielectric Grease Application (reference)​
AMP Connector (task)​
Deutsch Connectors (task)​
Telematics Gateway (reference)​
Wiring Harness Connector Labels (reference)​
Electrical Installation (reference)​
Wiring Harness (reference)​
Electrical Schematics (reference)​
