JLG Boom Lift 450AJ HC3 Parts Manual 31219152
Brand: JLG
Type of Machine: Boom Lift
Model: JLG 450AJ HC3 Boom Lift
Part Number: 31219152
Publication Date: 2024
Number of Pages: 730 Pages
SECTION 1 - FRAME
Brand: JLG
SECTION 1 - FRAME
FIGURE 1-1. AXLE INSTALLATION (MACHINES WITH SN STARTING WITH 03)
FIGURE 1-2. AXLE INSTALLATION (MACHINES WITH SN STARTING WITH B3)
FIGURE 1-3. STEER INSTALLATION WITHOUT TOW PACKAGE
FIGURE 1-4. STEER INSTALLATION WITH TOW PACKAGE
FIGURE 1-5. WHEEL DRIVE INSTALLATION (4WD) (Prior to SN 0300286739, Prior to SN B300013937, Except SN B300012459 through B300012460, Except SN B300013643 through B300013878)
FIGURE 1-6. WHEEL DRIVE INSTALLATION (4WD) (SN 0300286739 to Present, Including B300013937)
FIGURE 1-7. DRIVE HUB AND BRAKE ASSEMBLY - REAR
FIGURE 1-8. DRIVE HUB ASSEMBLY - FRONT
FIGURE 1-9. DRIVE MOTOR ASSEMBLY (4WD) (Prior to SN 0300286739, Prior to SN B300013937, Except SN B300012459 through B300012460, Except SN B300013643 through B300013878)
FIGURE 1-10. DRIVE MOTOR ASSEMBLY (4WD) (SN 0300286739 to Present, Including B300013937)
FIGURE 1-11. FRAME SHIELD INSTALLATION
FIGURE 1-12. TIRE AND WHEEL INSTALLATION - 12 X 16.5 FOAM FILLED (AVAILABLE ON ANSI, ANSI EXPORT, CSA AND JAPANESE SPECS)
FIGURE 1-13. TIRE AND WHEEL INSTALLATION - 12 X 16.5 FOAM FILLED NON MARKING (AVAILABLE ON ANSI, ANSI EXPORT, CSA AND JAPANESE SPECS)
FIGURE 1-14. TIRE AND WHEEL INSTALLATION - 14 X17.5 FOAM FILLED
FIGURE 1-15. TIRE AND WHEEL INSTALLATION - 14 X17.5 FOAM FILLED NON-MARKING
FIGURE 1-16. TIRE AND WHEEL INSTALLATION - 33 X 12-20 FOAM-FILLED (AVAILABLE ON ALL SPECS)
FIGURE 1-17. TIRE AND WHEEL INSTALLATION - 33 X 12-20 SOLID NON-MARKING (AVAILABLE ON ANSI EXPORT, AUSTRALIAN, CE, CIS/EAC & UK CA SPECS)
FIGURE 1-18. TIRE AND WHEEL INSTALLATION - 33/1550 X 16.5 FOAM-FILLED (AVAILABLE ON ALL SPECS)
FIGURE 1-19. TIRE AND WHEEL INSTALLATION - 33 X 16L500 TURF AND SAND FOAM-FILLED (AVAILABLE ON ANSI, ANSI EXPORT & CSA SPECS)
FIGURE 1-20. TIRE AND WHEEL INSTALLATION - 315/55 D20 FOAM FILLED (AVAILABLE ON ANSI EXPORT, AUSTRALIAN, CE, CHINA, CIS/EAC & UK CA SPECS)
FIGURE 1-21. TIRE AND WHEEL INSTALLATION - 315/55 D20 FOAM FILLED NON-MARKING (AVAILABLE ON ANSI EXPORT, AUSTRALIAN, CE, CHINA, CIS/EAC & UK CA SPECS)
FIGURE 1-22. VALVES INSTALLATION - FRAME MOUNTED (MACHINES WITH SN STARTING WITH 03)
FIGURE 1-23. VALVES INSTALLATION - FRAME MOUNTED (MACHINES WITH SN STARTING WITH B3)
FIGURE 1-24. TRACTION VALVE ASSEMBLY - 4WD
FIGURE 1-25. TOW PACKAGE INSTALLATION (OPTIONAL)
FIGURE 1-26. TOW BAR ASSEMBLY
SECTION 2 - TURNTABLEFIGURE 2-1. VALVES INSTALLATION - TURNTABLE (MACHINES WITH SN STARTING WITH 03)
FIGURE 2-2. VALVES INSTALLATION - TURNTABLE (MACHINES WITH SN STARTING WITH B3)
FIGURE 2-3. MAIN VALVE ASSEMBLY
FIGURE 2-4. AUXILIARY PUMP ASSEMBLY (MACHINES WITH SN STARTING WITH 03)
FIGURE 2-5. AUXILIARY PUMP ASSEMBLY (MACHINES WITH SN STARTING WITH B3)
FIGURE 2-6. SWING DRIVE AND TURNTABLE BEARING INSTALLATION
FIGURE 2-7. SWING MOTOR ASSEMBLY
FIGURE 2-8. TURNTABLE BEARING ASSEMBLY
FIGURE 2-9. TURNTABLE COVERS INSTALLATION
FIGURE 2-10. TURNTABLE LOCK INSTALLATION
FIGURE 2-11. TANKS INSTALLATION - DIESEL MACHINES (HYDRAULIC TANK WITH 4 INCH BREATHER)
FIGURE 2-12. TANKS INSTALLATION - DIESEL MACHINES (HYDRAULIC TANK WITH 6 INCH BREATHER)
FIGURE 2-13. TANKS INSTALLATION - GAS MACHINES
FIGURE 2-14. HYDRAULIC TANK ASSEMBLY - WITH 4 INCH BREATHER (DIESEL MACHINES)
FIGURE 2-15. DRIVE ORIENTATION INSTALLATION
FIGURE 2-16. GROUND CONTROL ASSEMBLY (ALL SPECS EXCEPT CE, CIS/EAC & UK CA SPECS)
FIGURE 2-17. GROUND CONTROL ASSEMBLY (CE, CIS/EAC & UK CA SPECS)
FIGURE 2-18. GROUND CONTROL ASSEMBLY (STAGE V ONLY) (CE & UK CA SPECS)
FIGURE 2-19. LIGHT PANEL INSTALLATION – GROUND CONTROL (Prior to SN 0300284825, Prior to SN B300013124, Except SN 0300284528 through 0300284530, Except SN B300012416 through B300012460, Excluding 0300284525 and B300013069)
FIGURE 2-20. LIGHT PANEL INSTALLATION - GROUND CONTROL
FIGURE 2-21. ELECTRICAL SYSTEM INSTALLATION
FIGURE 2-22. WHITE NOISE ALARM AMBIENT INSTALLATION
FIGURE 2-23. WHITE NOISE ALARM INSTALLATION
FIGURE 2-24. BEACON LIGHT INSTALLATION - AMBER
FIGURE 2-25. BEACON LIGHT INSTALLATION - ORANGE
FIGURE 2-26. BEACON LIGHT INSTALLATION - BLUE
FIGURE 2-27. BEACON LIGHT INSTALLATION - RED
FIGURE 2-28. BATTERY AND CABLE INSTALLATION
FIGURE 2-29. HOOD PLUGS INSTALLATION (HOOD WITHOUT STROBE LIGHT)
FIGURE 2-30. HOODS INSTALLATION (ABS) - DEUTZ ENGINES (MACHINES WITH SN STARTING WITH 03)
FIGURE 2-31. HOODS INSTALLATION (ABS) - DEUTZ ENGINES (MACHINES WITH SN STARTING WITH B3 FOR ANSI EXPORT, CHINA, CIS/EAC & JAPANESE SPECS)
FIGURE 2-32. HOODS INSTALLATION (ABS) - DEUTZ ENGINES (MACHINES WITH SN STARTING WITH B3 FOR AUSTRALIAN, CE & UK CA SPECS)
FIGURE 2-33. HOODS INSTALLATION (STEEL)
FIGURE 2-34. HOODS INSTALLATION (ABS) - KUBOTA ENGINE
FIGURE 2-35. HOOD ASSEMBLY (ABS) - TANK SIDE (Prior to SN 0300298674, Prior to SN B300017693)
FIGURE 2-36. HOOD ASSEMBLY (ABS) - TANK SIDE (SN 0300298674 to Present, SN B300017693 to Present)
FIGURE 2-37. HOOD ASSEMBLY (ABS) - TANK SIDE (MACHINES WITH SN STARTING WITH B3 FOR AUSTRAIAN, CE & UK CA SPECS) (Prior to SN B300017693)
FIGURE 2-38. HOOD ASSEMBLY (ABS) - TANK SIDE (MACHINES WITH SN STARTING WITH B3 FOR AUSTRALIAN, CE & UK CA SPECS) (SN B300017693 to Present)
FIGURE 2-39. HOOD ASSEMBLY (STEEL) - ENGINE SIDE
FIGURE 2-40. HOOD ASSEMBLY (ABS) - ENGINE SIDE (MACHINES WITH SN STARTING WITH 03)
FIGURE 2-41. HOOD ASSEMBLY (ABS) - ENGINE SIDE (MACHINES WITH SN STARTING WITH B3 FOR ANSI EXPORT, CHINA, CIS/EAC & JAPANESE SPECS)
FIGURE 2-42. HOOD ASSEMBLY (ABS) - ENGINE SIDE (MACHINES WITH SN STARTING WITH B3 FOR AUSTRALIAN, CE & UK CA SPECS)
FIGURE 2-43. HOOD ASSEMBLY (STEEL) - TANK SIDE
SECTION 3 - ENGINEFIGURE 3-1. ENGINE INSTALLATION - DEUTZ D2011 ENGINE (WITHOUT ARCTIC PACKAGE) (ANSI EXPORT, AUSTRALIAN, CE (LRC), CHINA CIS/EAC & UK CA SPECS)
FIGURE 3-2. ENGINE AND PUMP SUB-ASSEMBLY - DEUTZ D2011 (WITHOUT ARCTIC PACKAGE) (ANSI EXPORT, AUSTRALIAN, CE (LRC), CHINA, CIS/EAC & UK CA SPECS)
FIGURE 3-3. ENGINE ASSEMBLY - DEUTZ D2011 ENGINE (WITHOUT ARCTIC PACKAGE) (ANSI EXPORT, AUSTRALIAN, CE (LRC), CHINA, CIS/EAC & UK CA SPECS)
FIGURE 3-4. ENGINE INSTALLATION - DEUTZ D2011 ENGINE (WITH ARCTIC PACKAGE) (ANSI EXPORT, CHINA, CIS/EAC & UK CA SPECS)
FIGURE 3-5. ENGINE AND PUMP SUB-ASSEMBLY - DEUTZ D2011 (WITH ARCTIC PACKAGE) (ANSI EXPORT, CHINA, CIS/EAC & UK CA SPECS)
FIGURE 3-6. ENGINE ASSEMBLY - DEUTZ D2011 ENGINE (WITH ARCTIC PACKAGE) (ANSI EXPORT, CHINA, CIS/EAC & UK CA SPECS)
FIGURE 3-7. ENGINE ASSEMBLY - DEUTZ D2011 ENGINE (WITH ARCTIC PACKAGE) (ANSI EXPORT, CHINA, CIS/EAC & UK CA SPECS)
FIGURE 3-8. ENGINE ASSEMBLY - DEUTZ D2011 ENGINE (WITH ARCTIC PACKAGE) (ANSI EXPORT, CHINA, CIS/EAC & UK CA SPECS)
FIGURE 3-9. ENGINE ASSEMBLY - DEUTZ D2011 ENGINE (WITH ARCTIC PACKAGE) (ANSI EXPORT, CHINA, CIS/EAC & UK CA SPECS)
FIGURE 3-10. ENGINE COMPONENTS - DEUTZ D2011
FIGURE 3-11. ENGINE INSTALLATION - DEUTZ D2.9L4 ENGINE (WITHOUT ARCTIC PACKAGE) (ANSI, ANSI EXPORT, CSA AND JAPANESE SPECS)
FIGURE 3-12. ENGINE AND PUMP SUB-ASSEMBLY - DEUTZ D2.9L4 (WITHOUT ARCTIC PACKAGE) (ANSI, ANSI EXPORT, CSA AND JAPANESE SPECS)
FIGURE 3-13. ENGINE ASSEMBLY - DEUTZ D2.9L4 ENGINE (WITHOUT ARCTIC PACKAGE) (ANSI, ANSI EXPORT, CSA AND JAPANESE SPECS)
FIGURE 3-14. ENGINE INSTALLATION - DEUTZ D2.9L4 ENGINE (WITH ARCTIC PACKAGE) (ANSI AND CSA SPECS)
FIGURE 3-15. ENGINE INSTALLATION - DEUTZ D2.9L4 ENGINE (WITH ARCTIC PACKAGE) (ANSI AND CSA SPECS)
FIGURE 3-16. ENGINE INSTALLATION - DEUTZ D2.9L4 ENGINE (WITH ARCTIC PACKAGE) (ANSI AND CSA SPECS)
FIGURE 3-17. ENGINE INSTALLATION - DEUTZ D2.9L4 ENGINE (WITH ARCTIC PACKAGE) (ANSI AND CSA SPECS)
FIGURE 3-18. ENGINE AND PUMP SUB-ASSEMBLY - DEUTZ D2.9L4 (WITH ARCTIC PACKAGE) (ANSI AND CSA SPECS)
FIGURE 3-19. ENGINE ASSEMBLY - DEUTZ D2.9L4 ENGINE (WITH ARCTIC PACKAGE) (ANSI AND CSA SPECS)
FIGURE 3-20. ENGINE COMPONENTS - DEUTZ D2.9L4 ENGINE (ANSI, ANSI EXPORT, CSA AND JAPANSESE SPECS)
FIGURE 3-21. ENGINE INSTALLATION - DEUTZ D2.9L4 ENGINE (STAGE V) (CE SPECS)
FIGURE 3-22. ENGINE AND PUMP SUB-ASSEMBLY - DEUTZ D2.9L4 ENGINE (STAGE V) (CE & UK CA SPECS) (Prior to SN 0300295169, Prior to SN B300016789)
FIGURE 3-23. ENGINE AND PUMP SUB-ASSEMBLY - DEUTZ D2.9L4 ENGINE (STAGE V) (CE & UK CA SPECS) (SN 0300295169 to Present, Including B300016789)
FIGURE 3-24. ENGINE ASSEMBLY – DEUTZ D2.9L4 ENGINE (STAGE V) (CE & UK CA SPECS)
FIGURE 3-25. ENGINE COMPONENTS - DEUTZ D2.9L4 ENGINE (STAGE V) (CE & UK CA SPECS)
FIGURE 3-26. MOTOR MOUNT INSTALLATION - DEUTZ D2.9L4 ENGINE (STAGE V) WITHOUT GENERATOR
FIGURE 3-27. MOTOR MOUNT INSTALLATION - DEUTZ D2.9L4 ENGINE (STAGE V) WITH GENERATOR
FIGURE 3-28. BRACKET ASSEMBLY - FUEL PUMP AND FILTER (DEUTZ D2.9L4 ENGINE)
FIGURE 3-29. BRACKET ASSEMBLY - FUEL PUMP AND FILTER (DEUTZ D2.9L4 ENGINE) (STAGE V)
FIGURE 3-30. BREATHER HEATER INSTALLATION - DEUTZ D2.9L4 ENGINE WITH ARCTIC PACKAGE
FIGURE 3-31. PUMP COUPLING KIT – DEUTZ ENGINES
FIGURE 3-32. ENGINE INSTALLATION - KUBOTA ENGINE (WITHOUT ARCTIC PACKAGE)
FIGURE 3-33. ENGINE AND PUMP SUB-ASSEMBLY - KUBOTA ENGINE (WITHOUT ARCTIC PACKAGE)
FIGURE 3-34. ENGINE ASSEMBLY - KUBOTA ENGINE (WITHOUT ARCTIC PACKAGE)
FIGURE 3-35. ENGINE INSTALLATION - KUBOTA ENGINE (WITH ARCTIC PACKAGE)
FIGURE 3-36. ENGINE AND PUMP SUB-ASSEMBLY - KUBOTA ENGINE (WITH ARCTIC PACKAGE)
FIGURE 3-37. ENGINE ASSEMBLY - KUBOTA ENGINE (WITH ARCTIC PACKAGE)
FIGURE 3-38. ENGINE COMPONENTS - KUBOTA
FIGURE 3-39. PUMP COUPLING KIT - KUBOTA ENGINE
FIGURE 3-40. PISTON PUMP ASSEMBLY
FIGURE 3-41. SPARK ARRESTOR INSTALLATION - DEUTZ D2011 ENGINE
FIGURE 3-42. ENGINE BAFFLE INSTALLATION - WITH DEUTZ ENGINES
FIGURE 3-43. ENGINE BAFFLE INSTALLATION – WITH KUBOTA ENGINE
FIGURE 3-44. GENERATOR INSTALLATION - 2500W/50HZ (DEUTZ D2011 ENGINE)
FIGURE 3-45. GENERATOR INSTALLATION - 2500W/60HZ (DEUTZ D2011 ENGINE)
FIGURE 3-46. GENERATOR INSTALLATION - 2500W/60HZ (DEUTZ D2.9L4 ENGINE)
FIGURE 3-47. GENERATOR INSTALLATION - 2500W/60HZ (KUBOTA ENGINE)
FIGURE 3-48. GENERATOR INSTALLATION - 4000W/50HZ (DEUTZ D2011 ENGINE)
FIGURE 3-49. GENERATOR INSTALLATION - 4000W/60HZ (DEUTZ D2011 ENGINE)
FIGURE 3-50. GENERATOR INSTALLATION - 4000W/60HZ (DEUTZ D2.9L4 ENGINE)
FIGURE 3-51. GENERATOR INSTALLATION - 4000W/50HZ (DEUTZ ENGINE) (STAGE V)
FIGURE 3-52. GENERATOR INSTALLATION - 7500W/50HZ (DEUTZ D2011 ENGINE)
FIGURE 3-53. GENERATOR INSTALLATION - 7500W/60HZ (DEUTZ D2011 ENGINE)
FIGURE 3-54. GENERATOR INSTALLATION - 7500W/60HZ (DEUTZ D2.9L4 ENGINE)
FIGURE 3-55. GENERATOR INSTALLATION - 7500W/60HZ (KUBOTA ENGINE)
SECTION 4 - BOOMFIGURE 4-1. BOOM INSTALLATION
FIGURE 4-2. MAIN BOOM ASSEMBLY (Prior to SN 0300284525, Prior to SN B300012384)
FIGURE 4-3. MAIN BOOM ASSEMBLY (SN 0300284525 to Present, SN B300012384 to Present)
FIGURE 4-4. TOWER BOOM ASSEMBLY
FIGURE 4-5. JIB INSTALLATION (MACHINES WITH SN STARTING WITH 03)
FIGURE 4-6. JIB INSTALLATION (MACHINES WITH SN STARTING WITH B3)
FIGURE 4-7. ROTATOR ASSEMBLY
FIGURE 4-8. PLATFORM SUPPORT INSTALLATION
FIGURE 4-9. VALVES INSTALLATION - BOOM MOUNTED (MACHINES WITH SN STARTING WITH 03)
FIGURE 4-10. VALVES INSTALLATION - BOOM MOUNTED (MACHINES WITH SN STARTING WITH B3)
FIGURE 4-11. UPRIGHT VALVE ASSEMBLY
FIGURE 4-12. BOOM VALVE ASSEMBLY - 450AJ
SECTION 5 - PLATFORMFIGURE 5-1. PLATFORM ASSEMBLY - 30IN X 3FT (76CM X .91M) - DROP BAR ENTRY
FIGURE 5-2. PLATFORM ASSEMBLY - 30IN X 4FT (76CM X 1.22M) - SIDE GATE ENTRY
FIGURE 5-3. PLATFORM ASSEMBLY - 30IN X 4FT (76CM X 1.22M) - WITH DROP BAR
FIGURE 5-4. PLATFORM ASSEMBLY - 30IN X 5FT (76CM X 1.52M) - SIDE GATE ENTRY
FIGURE 5-5. PLATFORM ASSEMBLY - 30IN X 5FT (76CM X 1.52M) - WITH DROP BAR
FIGURE 5-6. PLATFORM ASSEMBLY - 30IN X 5FT (76CM X 1.52M - FALL ARREST
FIGURE 5-7. PLATFORM ASSEMBLY - 30IN X 6FT (76CM X 1.83M) - SIDE GATE ENTRY
FIGURE 5-8. PLATFORM ASSEMBLY - 30IN X 6FT (76CM X 1.83M) - WITH DROP BAR
FIGURE 5-9. PLATFORM CONSOLE BOX INSTALLATION
FIGURE 5-10. PLATFORM CONSOLE BOX ASSEMBLY
FIGURE 5-11. LIGHT PANEL INSTALLATION - PLATFORM CONSOLE (Prior to SN 0300284825, Prior to SN B300013124, Except SN 0300284528 through 0300284530, Except SN B300012416 through B300012460, Excluding 0300284525 and B300013069)
FIGURE 5-12. LIGHT PANEL INSTALLATION - PLATFORM CONSOLE (SN 0300284825 to Present, SN B300013124 to Present)
FIGURE 5-13. CONTROLLER ASSEMBLY - DRIVE AND STEER
FIGURE 5-14. CONTROLLER ASSEMBLY - LIFT AND SWING
FIGURE 5-15. FOOTSWITCH ASSEMBLY
FIGURE 5-16. TRAY ASSEMBLY
FIGURE 5-17. USB CHARGER INSTALLATION
FIGURE 5-18. SKYEYE INSTALLATION
FIGURE 5-19. SKYGUARD BAR INSTALLATION
FIGURE 5-20. SKYLINE INSTALLATION
FIGURE 5-21. SKYGLAZIER INSTALLATION (ANSI, AUSTRALIAN & CSA SPECS)
FIGURE 5-22. SKYWELDER INSTALLATION (50HZ)
FIGURE 5-23. SKYWELDER INSTALLATION (60HZ)
FIGURE 5-24. SKYWELDER PREP PACKAGE INSTALLATION
FIGURE 5-25. WELDER ASSEMBLY
FIGURE 5-26. PIPE RACK INSTALLATION (ALL SPECS EXCEPT AUSTRALIAN, CE & UK CA SPECS)
FIGURE 5-27. PIPE RACK INSTALLATION (AUSTRALIAN SPEC)
FIGURE 5-28. SOFT TOUCH INSTALLATION (WITHOUT FALL ARREST)
FIGURE 5-29. SOFT TOUCH INSTALLATION (WITH FALL ARREST)
FIGURE 5-30. FALL ARREST INSTALLATION (BOLT-ON) (5FT/1.52M PLATFORM)
FIGURE 5-31. FALL ARREST INSTALLATION (BOLT-ON) (4FT/1.22M PLATFORM)
FIGURE 6-2. AXLE LOCKOUT CYLINDER ASSEMABLY (MACHINES WITH SN STARTING WITH B3)
FIGURE 6-3. LEVEL (PLATFORM SLAVE) CYLINDER ASSEMBLY
FIGURE 6-4. LIFT CYLINDER ASSEMBLY - JIB
FIGURE 6-5. LIFT CYLINDER ASSEMBLY - MAIN LIFT
FIGURE 6-6. LIFT CYLINDER ASSEMBLY - TOWER BOOM
FIGURE 6-7. MASTER CYLINDER ASSEMBLY
FIGURE 6-8. STEER CYLINDER ASSEMBLY
FIGURE 6-9. TELESCOPE CYLINDER ASSEMBLY (Prior to SN 0300284525, Prior to SN B300012384)
FIGURE 6-10. TELESCOPE CYLINDER ASSEMBLY (SN 0300284525 to Present, SN B300012384 to Present)
SECTION 7 - HYDRAULICFIGURE 7-1. 4WD HYDRAULIC SYSTEM INSTALLATION - 450AJ (SN THAT START WITH B3) (Prior to SN 0300286739)
FIGURE 7-2. 4WD HYDRAULIC SYSTEM INSTALLATION - 450AJ (WITH 36 GAL HYD. TANK)
FIGURE 7-3. 4WD HYDRAULIC SYSTEM INSTALLATION - 450AJ (WITH 36 GAL HYD. TANK)
FIGURE 7-4. 4WD HYDRAULIC SYSTEM INSTALLATION - 450AJ (WITH 36 GAL HYD. TANK)
FIGURE 7-5. 4WD HYDRAULIC SYSTEM INSTALLATION - 450AJ (WITH 36 GAL HYD. TANK)
FIGURE 7-6. 4WD HYDRAULIC SYSTEM INSTALLATION - 450AJ (SN THAT START WITH 03) (SN 0300286739 to Present)
FIGURE 7-7. 4WD HYDRAULIC SYSTEM INSTALLATION - 450AJ (SN THAT START WITH 03) (SN 0300286739 to Present)
FIGURE 7-8. 4WD HYDRAULIC SYSTEM INSTALLATION - 450AJ (SN THAT START WITH 03) (SN 0300286739 to Present)
FIGURE 7-9. 4WD HYDRAULIC SYSTEM INSTALLATION - 450AJ (SN THAT START WITH 03) (SN 0300286739 to Present)
SECTION 8 - ELECTRICALFIGURE 8-1. AC BOX AT PLATFORM INSTALLATION - 110V - ANSI, ANSI EXPORT, CHINA, CSA AND JAPANESE SPECS
FIGURE 8-2. AC BOX AT PLATFORM INSTALLATION - 110V IEC YELLOW (CE, CIS/EAC & UK CA SPECS WITH 4000W/50HZ GENERATOR)
FIGURE 8-3. AC BOX AT PLATFORM INSTALLATION - 110V IEC 60309 YELLOW WITHOUT 2500W GENERATOR (CE, CIS/EAC & UK CA SPECS)
FIGURE 8-4. AC BOX AT PLATFORM INSTALLATION - 220V IEC BLUE (CE, CIS/EAC & UK CA SPECS WITH 4000W/50HZ GENERATOR)
FIGURE 8-5. AC BOX AT PLATFORM INSTALLATION - 220V IEC 60309 BLUE WITHOUT 2500W GENERATOR (CE, CIS/EAC & UK CA SPECS)
FIGURE 8-6. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 POST GROUND (2X4 BOX) WITHOUT 2500W GENERATOR (CE, CIS/EAC & UK CA SPECS)
FIGURE 8-7. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 SIDE GROUND (2X4 BOX) WITHOUT 2500W GENERATOR (CE, CIS/EAC & UK CA SPECS)
FIGURE 8-8. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 2IN X 4IN POST GROUND (CE, CIS/EAC & UK CA SPECS WITH 4000W/50HZ GENERATOR)
FIGURE 8-9. AC BOX AT PLATFORM INSTALLATION - 220V CEE7 2IN X 4IN SIDE GROUND (CE, CIS/EAC & UK CA SPECS WITH 4000W/50HZ GENERATOR)
FIGURE 8-10. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT107 (CE, CIS/EAC & UK CA SPECS WITH 4000W/50HZ GENERATOR)
FIGURE 8-11. AC BOX AT PLATFORM INSTALLATION - 220V AFSINT 107 KEYED GROUND (2X4 BOX) WITHOUT 2500W GENERATOR (CE, CIS/EAC & UK CA SPECS)
FIGURE 8-12. AC BOX AT PLATFORM INSTALLATION - 220V CUSTOMER SUPPLIED COMPONENTS (AUSTRALIAN, CE & UK CA SPECS)
FIGURE 8-13. AC BOX AT PLATFORM INSTALLATION - 240V (WITH 4000W GENERATOR) (ANSI, ANSI EXPORT, CSA AND JAPANESE SPECS)
FIGURE 8-14. AC BOX AT PLATFORM INSTALLATION - 240V (WITH 7500W SKYPOWER GENERATOR) (ANSI, ANSI EXPORT, CSA AND JAPANESE SPECS)
FIGURE 8-15. AC CABLE INSTALLATION - WITH TWO BREAKERS (CE, CIS/EAC & UK CA SPECS)
FIGURE 8-16. AC CABLE INSTALLATION - WITH THREE BREAKERS (CE, CIS/EAC & UK CA SPECS)
FIGURE 8-17. AC CABLE AND PLUG INSTALLATION (MACHINES WITH SN STARTING WITH B3)
FIGURE 8-18. BATTERY DISCONNECT SWITCH
FIGURE 8-19. BEACON JUMPER HARNESS (AMBER)
FIGURE 8-20. BEACON LIGHT HARNESS (BLUE AND RED BEACON LIGHT)
FIGURE 8-21. BOOM CABLES AND CLAMPS INSTALLATION (MACHINES WITHOUT GENERATOR & WITHOUT AC CABLES)
FIGURE 8-22. BOOM CABLES AND CLAMPS INSTALLATION (MACHINES WITHOUT GENERATOR & WITH AC CABLES)
FIGURE 8-23. BOOM CABLES AND CLAMPS INSTALLATION (MACHINES WITHOUT GENERATOR AND WITH ARCTIC PACKAGE)
FIGURE 8-24. BOOM CABLES AND CLAMPS INSTALLATION (MACHINES WITH 50HZ 4000W GENERATOR)
FIGURE 8-25. BOOM CABLES AND CLAMPS INSTALLATION (MACHINES WITH 60HZ 4000W GENERATOR)
FIGURE 8-26. BOOM CABLES AND CLAMPS INSTALLATION (MACHINES WITH 7500W GENERATOR)
FIGURE 8-27. BOOM CABLES AND CLAMPS INSTALLATION (MACHINES WITH 7500W GENERATOR AND WITH ARCTIC PACKAGE)
FIGURE 8-28. BOOM HARNESS (MAIN BOOM) (WITHOUT ARCTIC PACKAGE)
FIGURE 8-29. BOOM HARNESS (MAIN BOOM) (WITH ARCTIC PACKAGE)
FIGURE 8-30. BOOM HARNESS (MAIN BOOM AC CABLE) (WITHOUT GENERATOR AND WITHOUT ARCTIC PACKAGE)
FIGURE 8-31. BOOM HARNESS (MAIN BOOM AC CABLE) (WITHOUT GENERATOR AND WITH ARCTIC PACKAGE)
FIGURE 8-32. BOOM HARNESS - TOWER BOOM (WITHOUT ARCTIC PACKAGE)
FIGURE 8-33. BOOM HARNESS - TOWER BOOM (WITH ARCTIC PACKAGE)
FIGURE 8-34. BOOM HARNESS - TOWER BOOM AC CABLE (WITHOUT ARCTIC PACKAGE)
FIGURE 8-35. BOOM HARNESS - TOWER BOOM AC CABLE (WITH ARCTIC PACKAGE)
FIGURE 8-36. BOOM SENSORS INSTALLATION
FIGURE 8-37. BOOM SENSOR HARNESS
FIGURE 8-38. BREAKER BOX KIT WITH SINGLE DOUBLE POLE BREAKER (CE, CIS/EAC & UK CA SPECS)
FIGURE 8-39. BREAKER BOX KIT WITH THREE BREAKERS (CE, CIS/EAC & UK CA SPECS)
FIGURE 8-40. BREAKER BOX KIT - 30MA/16 AMP
FIGURE 8-41. CAPACITY HARNESS
FIGURE 8-42. CHASSIS SOLENOID HARNESS
FIGURE 8-43. CLEARSKY 3-WIRE CONNECTION INSTALLATION
FIGURE 8-44. CLEARSKY TELEMATICS HARNESS
FIGURE 8-45. ENGINE HARNESS - DEUTZ D2011
FIGURE 8-46. ENGINE HARNESS - DEUTZ D2.9L4
FIGURE 8-47. ENGINE HARNESS - DEUTZ D2.9L4 ENGINE (STAGE V)
FIGURE 8-48. ENGINE HARNESS - KUBOTA
FIGURE 8-49. FUEL HARNESS - DEUTZ D2.9L4 ENGINE
FIGURE 8-50. GENERATOR HARNESS - 2500W GENERATOR (60HZ)
FIGURE 8-51. GENERATOR HARNESS - 2500W GENERATOR (50HZ)
FIGURE 8-52. GENERATOR HARNESS - 4000W GENERATOR
FIGURE 8-53. GROUND CONTROL PANEL HARNESS
FIGURE 8-54. KUBOTA D/F POWER HARNESS
FIGURE 8-55. PLATFORM CONSOLE BOX HARNESS
FIGURE 8-56. PLATFORM INTERFACE HARNESS
FIGURE 8-57. RECEPTACLE BOX KIT - 110V IEC YELLOW (CE, CIS/EAC & UK CA SPECS)
FIGURE 8-58. RECEPTACLE BOX KIT - 220V IEC BLUE (CE, CIS/EAC & UK CA SPECS)
FIGURE 8-59. RECEPTACLE BOX KIT - 220V CEE7 POST GROUND 2IN X 4IN BOX (CE, CIS/EAC & UK CA SPECS)
FIGURE 8-60. RECEPTACLE BOX KIT - 220V CEE7 SIDE GROUND 2IN X 4IN BOX (CE, CIS/EAC & UK CA SPECS)
FIGURE 8-61. RECEPTACLE BOX KIT - 220V AFSINT 107 (CE, CIS/EAC & UK CA SPECS)
FIGURE 8-62. SKYEYE INTERMEDIATE HARNESS
FIGURE 8-63. SKYEYE RECEIVER HARNESS
FIGURE 8-64. SKYEYE EMITTER HARNESS
FIGURE 8-65. SKYLINE HARNESS
FIGURE 8-66. TRANSPORT HARNESS
FIGURE 8-67. TURNTABLE HARNESS
FIGURE 8-68. VALVE HARNESS - BOOM
FIGURE 8-69. VALVE HARNESS - MAIN VALVE
FIGURE 8-70. VALVE HARNESS - PLATFORM VALVE
SECTION 9 - DECALSFIGURE 9-1. DECAL INSTALLATION - ANSI, ANSI EXPORT AND CSA SPECS WITH DEUTZ ENGINES (ENGLISH LANGUAGE)
FIGURE 9-2. DECAL INSTALLATION - ANSI AND ANSI EXPORT SPECS WITH KUBOTA ENGINES (ENGLISH LANGUAGE)
FIGURE 9-3. DECAL INSTALLATION - AUSTRALIAN SPEC (ENGLISH LANGUAGE)
FIGURE 9-4. DECAL INSTALLATION - BRAZIL SPEC (PORTUGUESE/SPANISH LANGUAGES)
FIGURE 9-5. DECAL INSTALLATION - CE & UK CA SPEC (ENGLISH LANGUAGE)
FIGURE 9-6. DECAL INSTALLATION - CSA SPEC WITH DEUTZ ENGINES (FRENCH/ENGLISH LANGUAGES)
FIGURE 9-7. DECAL INSTALLATION - CSA SPEC WITH KUBOTA ENGINES (FRENCH/ENGLISH LANGUAGES)
FIGURE 9-8. DECAL INSTALLATION - CHINESE SPEC (CHINESE/ENGLISH LANGUAGES)
FIGURE 9-9. DECAL INSTALLATION - JAPANESE SPEC (JAPANESE/ENGLISH LANGUAGES)
FIGURE 9-10. DECAL INSTALLATION - KOREAN SPEC (KOREAN/ENGLISH LANGUAGES)
FIGURE 9-11. DECAL INSTALLATION - LATIN AMERICA SPEC (SPANISH/ENGLISH LANGUAGES)
FIGURE 9-12. DECAL INSTALLATION - OPTIONS
FIGURE 9-13. TOW BAR DECAL INSTALLATION - ENGLISH LANGUAGE (ANSI, ANSI EXPORT, CE, CHINA, CIS/EAC, JAPANESE & UK CA SPECS)
FIGURE 9-14. TOW BAR DECAL INSTALLATION - ENGLISH/SPANISH LANGUAGE (ANSI EXPORT SPECS)
FIGURE 9-15. TOW BAR DECAL INSTALLATION - SPANISH LANGUAGE (ANSI EXPORT, CE, CIS/EAC & UK CA SPECS)
FIGURE 9-16. SKYWELDER DECAL INSTALLATION – 50HZ (ANSI EXPORT SPECS)
FIGURE 9-17. SKYWELDER DECAL INSTALLATION - 60HZ (ANSI EXPORT SPECS)
PART NUMBER INDEX
- SuperPac Parts Manual
- StratoLift Parts Manual
